2D Drawing
IGES
STEP
3D PDF
Solder Profile
CofC RoHS Compliant
CofC REACH Compliant
UL Plastic File
Certificate of Origin
Check Stock
Request a Sample
Send Us An Email
Generated Part Number
KMDGX-3S-N
Part Number Builder
R
E 140125
LR78160
MINI/CIRCULAR DINs: KMDGX Series
Right Angle Mini-DIN
Product Features
PC99 Colors Available
Shielded Options Available for Good Conductivity,
Grounding and EMI/RFI Protection
Mates with Standard and Snap and Lock Plugs
Visual and Mechanical Polarization for Plug Insertion
Reflow Compatible Design Available
Gold Plated Contacts
CSA/NRTL Certified File No. LR78160
UL File No. E140125
Performance Specifications
Materials and Finish
Body
PBT Thermoplastic, Black, Purple, or Green Color
Contacts
Copper Alloy, Gold Plated
Shield
See Drawing
KMDGX
3
S
N
Series
Number
of Contacts
Contact
Type
Option
Series
KMDGX - Right Angle PCB Mount Mini-DIN
Number of Contacts
3 Contacts
4 Contacts
5 Contacts
6 Contacts
7 Contacts
8 Contacts
9 Contacts
10 Contacts (10 Available only with BS option)
Contact Type
S - Receptacle
Shielding Option
N - Non-Shielded
AS - Sides and Back Shielded
BS - Fully Shielded (Contact Kycon for 9 Contacts)
Contact Kycon for Other Options
Mechanical Characteristics
Insertion Force
3.0kg Max.
Extraction Force
0.3kg - 3.0kg
Durability
1000 Cycles Min.
KMDGX Series
Dimensions in mm
KMDGX-8S-BS
Electrical Characteristics
Rated Current
2A
Rated Voltage
12V DC
Insulation Resistance
500 Megohm Min. at 500V DC
Contact Resistance
Before Durability Test
Plug to Terminals: 30 milliohms Max.
After Durability Test
Plug to Terminals: 60 milliohms Max.
Dielectric Withstanding Voltage
500V RMS AC for 1 Minute
Operating Temperature
-25°C to + 80°C
Phone: +1.408.494.0330 l Fax: +1.408.494.0325 l WWW.KYCON.COM l 0418
很抱歉,暂时无法提供与“KMDGX-5S-BS”相匹配的价格&库存,您可以联系我们找货
