2D Drawing
IGES
STEP
3D PDF
Solder Profile
CofC RoHS Compliant
CofC REACH Compliant
UL Plastic File
Certificate of Origin
Check Stock
Request a Sample
Send Us An Email
Generated Part Number
KMDGX-4S/4S-S4N
Part Number Builder
LR78160
MINI/CIRCULAR DINs: KMDGX-*S/*S Series
Stacked Mini-DIN Gold Plated
Product Features
Audio, Video, Computer and Digital Equipment Applications
Mates with Standard and Snap and Lock Plugs
Space Saving Stacked Design
Shielded Options Available for Good Conductivity,
Grounding and EMI/RFI Protection
Visual and Mechanical Polarization for Plug Insertion
Gold Plated Contacts
Reflow Compatible Design Available
CSA/NRTL Certified File No. LR78160
4S/4S
S4N
Series
Configuration
Shield Option
Series
KMDGX - Stacked PCB Mount Mini-DIN
Configuration
4S/4S - 4 Contacts over 4 Contacts
6S/6S - 6 Contacts over 6 Contacts
8S/8S - 8 Contacts over 8 Contacts (Not available with S4N1)
Shield Option
S4N - Fully Shielded
S4N1 - Fully Shielded with Mounting Hole
Performance Specifications
Materials and Finish
Body
PBT Thermoplastic, Black Color, UL 94V-0 Rated
Contacts
Copper Alloy
Shield
See Drawing
Plating
Gold Flash over Nickel on Contacts. Tin over Nickel on
Soldertails.
KMDGX
Contact Kycon for Other Options
KMDGX Series
Dimensions in mm
KMDGX-4S/4S-S4N
Mechanical Characteristics
Insertion Force
4.5kg Max.
Extraction Force
0.4kg - 3.5kg
Durability
500 Cycles Minimum
Electrical Characteristics
Rated Current
2A
Rated Voltage
12V DC
Insulation Resistance
500 Megohm Min.
Contact Resistance
Before Durability Test
Plug to Terminals: 30 milliohms Max.
After Durability Test
Plug to Terminals: 60 milliohms Max.
Dielectric Withstanding Voltage
500V AC for 1 Minute
Operating Temperature
-25°C to + 85°C
Phone: +1.408.494.0330 l Fax: +1.408.494.0325 l WWW.KYCON.COM l 0419
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Kycon:
KMDGX-6SG/P-S4N1 KMDGX-4S/4S-S4N KMDGX-6S/6S-S4N KMDGX-8S/8S-S4N KMDGX-6SG/P-S4N
KMDGX-6S/6S-S4N1 KMDGX-4S/4S-S4N1
很抱歉,暂时无法提供与“KMDGX-4S/4S-S4N”相匹配的价格&库存,您可以联系我们找货
