IIC201
IIC201
    IFM(易福门)
    Cylinder,Threaded-M18
    INDUCTIVE SENSOR; M30 X 1.5 / L
IIC201 数据手册
IIC201 Inductive sensor IIB3022-BPKG/M/US-104-DPS Product characteristics Electrical design PNP Output function normally open Sensing range [mm] Housing 22 threaded type Dimensions [mm] M30 x 1.5 / L = 50 Application Special feature Gold-plated contacts; Increased sensing range Application Use in machine tools, coolants and lubricants Electrical data Operating voltage Current consumption [V] 10...36 DC [mA] 10; (24 V) Protection class II Reverse polarity protection yes Outputs Electrical design PNP Output function normally open Max. voltage drop switching output DC [V] 2.5 Permanent current rating of switching output DC [mA] 100 Switching frequency DC [Hz] 100 Short-circuit protection yes Type of short-circuit protection pulsed Overload protection yes ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IIC201-00 — 21.02.2008 — IIC201 Inductive sensor IIB3022-BPKG/M/US-104-DPS Detection zone Sensing range [mm] 22 Real sensing range Sr [mm] 22 ± 10 % Operating distance [mm] 0...17.82 Increased sensing range yes Accuracy / deviations Correction factor steel: 1 / stainless steel: 0.7 / brass: 0.5 / aluminium: 0.4 / copper: 0.3 Hysteresis [% of Sr] 3...15 Switch point drift [% of Sr] -10...10 [°C] -25...70 Operating conditions Ambient temperature Protection IP 68; ("Coolant") Tests / approvals EMC MTTF EN 61000-4-2 ESD 4 kV CD / 8 kV AD EN 61000-4-3 HF radiated 10 V/m EN 61000-4-4 Burst 2 kV EN 61000-4-6 HF conducted 10 V EN 55011 class B [years] UL approval 1955 Ta 0...40 °C Enclosure type Type 1 voltage supply Limited Voltage/Current File number UL E174191 Mechanical data Weight [g] 104 Housing threaded type Mounting non-flush mountable Dimensions [mm] M30 x 1.5 / L = 50 Thread designation Materials M30 x 1.5 brass white bronze coated; sensing face: LCP Displays / operating elements Display switching status 4 x 90° LED, yellow Accessories Items supplied lock nuts: 2 Remarks Pack quantity 1 pcs. Electrical connection - plug Connector: 1 x M12; Contacts: gold-plated ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IIC201-00 — 21.02.2008 — IIC201 Inductive sensor IIB3022-BPKG/M/US-104-DPS Connection ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IIC201-00 — 21.02.2008 —
IIC201 价格&库存
很抱歉,暂时无法提供与“IIC201”相匹配的价格&库存,您可以联系我们找货
