Product Specification
Part Name:
Customer Part ID:
OLED Display Module
0.96寸4针IIC模块
Customer:
Approved by
1
Revised History
Part Number
Revision
A
Revision Content
New
Revised on
2020-06-06
2
TABLE OF Contents
Part Name: OLED Display Module................................................................................................................1
1. Basic Specifications......................................................................................................................................5
2.
3.
1.1
Display Specifications.................................................................................................................. 5
1.2
Mechanical Specifications........................................................................................................... 5
1.3
Active Area / Memory Mapping & Pixel Construction................................................................5
1.4
Mechanical Drawing....................................................................................................................6
1.5
Pin Definition...............................................................................................................................7
1.6
product picture............................................................................................................................7
1.7
Schematic Diagram.................................................................................................................8
Absolute Maximum Ratings........................................................................................................................ 9
Optics & Electrical Characteristics.............................................................................................................10
3.1
Optics Characteristics................................................................................................................10
3.2
DC Characteristics......................................................................................................................10
3.3
AC Characteristics......................................................................................................................11
3.3.1
4.
5.
6.
7.
I2C Interface Timing Characteristics:............................................................................... 11
Functional Specification............................................................................................................................ 12
4.1
Commands.................................................................................................................................12
4.2
VCC Generated by Internal DC/DC Circuit.................................................................................13
Reliability................................................................................................................................................... 18
5.1
Contents of Reliability Tests......................................................................................................18
5.2
Failure Check Standard..............................................................................................................18
Outgoing Quality Control Specifications................................................................................................... 18
6.1
Environment Required.............................................................................................................. 18
6.2
Sampling Plan............................................................................................................................ 19
6.3
Criteria & Acceptable Quality Level.......................................................................................... 19
6.3.1
Cosmetic Check (Display Off) in Non-Active Area............................................................. 19
6.3.2
Cosmetic Check (Display Off) in Active Area..................................................................... 19
6.3.3
Pattern Check (Display On) in Active Area........................................................................ 21
Precautions When Using These OEL Display Modules............................................................................. 22
7.1
Handling Precautions................................................................................................................ 22
3
7.2
Storage Precautions.................................................................................................................. 23
7.3
Designing Precautions............................................................................................................... 23
7.4
Precautions when disposing of the OEL display modules.........................................................24
7.5
Other Precautions..................................................................................................................... 24
4
1.1Display Specifications
1)
2)
3)
Display Mode:
Display Color:
Drive Duty:
Passive Matrix
Monochrome (White)
1/64 Duty
1.2Mechanical Specifications
1)
Outline Drawing:
According to the annexed outline drawing
2)
3)
4)
5)
6)
Number of Pixels:
PCB Size:
Active Area:
Pixel Pitch:
Pixel Size:
128 64
27.327.8 2.65 (mm)
21.744 10.864 (mm)
0.17 0.17 (mm)
0.154 0.154 (mm)
1.3Active Area / Memory Mapping & Pixel Construction
5
Remark
20190425
Original Drawing
Pin Descriptions
10.86(AA)
2.000
19.26(PANEL)
23.80(HOLE)
27.80 (PCBA)
Pin Symbol
6.65
50
3.
4 - .0 0
2
4 -?
6
NOTES:
1.DISPLAY TYPE: 0.96" OLED
2.VIEWING DIRECTION: All
3.POLARIZER MODE: TRANSMISSIVE/NORMALLY BLACK
4.DRIVER IC: SSD1306
5.Resolution:128x64
6.INTERFACE:IIC
7.VOLTAGE:3.3V
8.OPERATING TEMP: -40°C~70°C
14.00
6.65
2.00
1.45
1.20
1
VCC
2
GND
3
SCL
4
SDA
1.4Mechanical Drawing
Date
A
2.65
1.50
4.27
6.37
27.30(PCBA)
26.70( PANEL)
23.30(HOLE)
21.74(AA)
9.84
Item
1.5Pin Definition
PIN No.
Symbol
1
VCC
2
GND
3
4
SCL
SDA
Description
Power Supply for OLED
This is a voltage supply pin. It must be connected to source
Ground of Logic Circuit
This is a ground pin. It must be connected to ground
The serial clock input SCL
The serial data input SDA
1.6product picture
Top view
Bottom view
7
1.7 Schematic
Diagram
The I2C communication interface consists of slave address bit DC, I2C-bus data signal SDA (SDAOUT/D2
for output and SDAIN/D1 for input) and I2C-bus clock signal SCL (D0). Both the data and clock signals must
be connected to pull-up resistors.
a) Slave address bit (SA0) has to recognize the slave address before transmitting or receiving any
information by the I2C-bus. The device will respond to the slave address following by the slave address bit
(“SA0” bit) and the read/write select bit (“R/W#” bit) with the following byte format,
b7 b6
b5
1
b4
1
b3 b2 b1 b0
1 0 SA0 R/W#
b)“SA0” bit provides an extension bit for the slave address. Either “0111100” or “0111101”, can be
selected as the slave address of OLED. D/C# pin acts as SA0 for slave address selection.“R/W#” bit is used to
determine the operation mode of the I2C-bus interface. R/W#=1, it is in read mode. R/W#=0, it is in write
mode
0x3C
0 1 1 1 1 00 0
(=0x78)
DC=0
0x3D
0 1 1 1 1 01 0
(=0x7A)
DC=1
8
The default
The user needs to switch the
resistance position to modify
the IIC address
2. Absolute Maximum Ratings
Parameter
Symbol
Min
Max
Unit
Notes
Supply Voltage for Display
VCC
3
5
V
1, 2
Supply Voltage for Logic
SCL/SDA
1.65
3.3
V
Operating Temperature
TOP
-40
80
C
Storage Temperature
TSTG
-40
85
C
3
Life Time (120 cd/m2)
10,000
hour
4
Life Time (80 cd/m )
30,000
hour
4
Life Time (60 cd/m2)
50,000
hour
4
2
Note 1: All the above voltages are on the basis of “GND = 0V”.
Note 2: When this module is used beyond the above absolute maximum ratings, permanent breakage
of the module may occur. Also, for normal operations, it is desirable to use this module under
the conditions according to Section 3. “Optics & Electrical Characteristics”. If this module is
used beyond these conditions, malfunctioning of the module can occur and the reliability of
the module may deteriorate.
Note 3: The defined temperature ranges do not include the polarizer. The maximum withstood
temperature of the polarizer should be 80C.
Note 4: VCC = 3.3 V, Ta = 25°C, 50% Checkerboard.
Software configuration follows Section 4.4 Initialization.
End of lifetime is specified as 50% of initial brightness reached. The average operating
lifetime at room temperature is estimated by the accelerated operation at high temperature
conditions.
9
3.Optics & Electrical Characteristics
3.1Optics Characteristics
Characteristics
Symbol
Conditions
Min
Typ
Max
Unit
Lbr
Note 5
150
cd/m2
Lbr
Note 6
150
180
cd/m2
C.I.E.
(x)
(y)
C.I.E. 1931
0.28
0.31
0.32
0.35
0.36
0.39
Dark Room Contrast
CR
2000:1
Free
Brightness
(VCC Supplied Externally)
Brightness
(VCC Generated Internal DC/DC)
Viewing Angle
degree
* Optical measurement taken at VDD = 2.8V, VCC = 7.25V.
Software configuration follows Section 4.2 Initialization.
3.2DC Characteristics
Characteristics
Symbol
VDD
(Supplied Externally)
VCC
Supply Voltage for DC/DC
VBAT
(Generated by Internal DC/DC)
Min
Typ
Max
Unit
1.65
2.8
3.3
V
11.5
12
12.5
V
Internal DC/DC Enable
3.5
4.2
V
VCC
Note 6
(Internal DC/DC Enable)
7.0
7.5
V
High Level Input
VIH
IOUT = 100μA, 3.3MHz
0.8xVDD
VDD
V
Low Level Input
VIL
0.2xVDD
V
High Level Output
VOH
0.9xVDD
VDD
V
Low Level Output
VOL
0.1xVDD
V
Operating Current for VDD
IDD
180
300
uA
Operating Current for VCC
Operating Current for VBAT
(VCC Generated by Internal
DC/DC)
Conditions
Note 5
(Internal DC/DC Disable)
ICC
Note 7
9
15
mA
IBAT
Note 8
25.6
32
mA
Sleep Mode Current for VDD
IDD,SLEEP
1
5
uA
Sleep Mode Current for VCC
ICC,SLEEP
2
10
uA
10
Note 5 & 6: Brightness (Lbr) and Supply Voltage for Display (VPP) are subject to the change of the panel
characteristics and the customer’s request.
Note 7: VDD = 2.8V, VCC = 12V, 100% Display Area Turn on.
Note 8: VDD = 2.8V, VCC = 7.25V, 100% Display Area Turn on.
* Software configuration follows Section 4.2 Initialization.
3.3AC Characteristics
3.3.1
Symbol
tcycle
tHSTART
tHD
tSD
tSSTART
tSSTOP
tR
tF
tIDLE
Description
Min
Max
Unit
Clock Cycle Time
2.5
μs
Start Condition Hold Time
0.6
μs
ns
Data Hold Time (for “SDAOUT” Pin)
Data Hold Time (for “SDAIN” Pin)
300
Data Setup Time
100
ns
Start Condition Setup Time
(Only relevant for a repeated Start condition)
0.6
μs
Stop Condition Setup Time
0.6
μs
Rise Time for Data and Clock Pin
300
ns
Fall Time for Data and Clock Pin
300
ns
μs
Idle Time before a New Transmission can Start
11
1.3
4. Functional Specification
4.1Commands
D/C# Hex D7 D6 D5 D4 D3
1
A[7:0] A7 A6 A5 A4
A3
D2 D1 D0 Command
Description
1 Set Contrast Control Double byte command to select 1 out of 256
A2
A1
A0
contrast steps. Contrast increases as the
value increases.
(RESET = 7Fh )
DB
1
1
1
1
A[7:0
A6
A5
A4
1
X0 Set Normal/Inverse A6h, X[0]=0b: Normal display (RESET) 0
in RAM: OFF in display panel 1
Display
Set VCOMH Deselect
Level
A6/A7
A[6:4]
000b
010b
011b
Hex
code
00h
20h
30h
V COMH deselect level
~ 0.65 x VCC
~ 0.77 x VCC (RESET)
~ 0.83 x VCC
in RAM: ON in display panel
A7h, X[0]=1b: Inverse display
0 in RAM: ON in display panel 1
Set Display ON/OFF AEh, X[0]=0b:Display OFF (sleep mode)
(RESET)
AFh X[0]=1b:Display ON in normal mode
AE
AF
1
1
1
X0
A0/A1
1
X0 Set Segment Re-map A0h, X[0]=0b: column address 0 is
mapped to SEG0 (RESET)
A1h, X[0]=1b: column address 127 is
mapped to SEG0
C0/C8
1
1
X3
Set COM Output
Scan Direction
12
C0h, X[3]=0b: normal mode (RESET) Scan
from COM0 to COM[N –1]
C8h, X[3]=1b: remapped mode. Scan
from COM[N-1] to COM0
Where N is the Multiplex ratio.
4.2VCC Generated by Internal DC/DC Circuit
If the noise is accidentally occurred at the displaying window during the operation, please reset the
display in order to recover the display function.
13
Normal Operation
Power Stabilized
(100ms Delay Recommended)
Set Display Off
0xAE
Power down VBAT
(50ms Delay Recommended)
Set Charge Pump
0x8D, 0x10
Power down VDD
VDD/VBAT off State
Normal Operation
Set Charge Pump
0x8D, 0x10
Set Display Off
0xAE
Power down VBAT
Sleep Mode
Sleep Mode
Set Charge Pump
0x8D, 0x14
Power Stabilized
Power up VBAT
Set Display On
0xAF
Normal Operation
14
void OLED_Init(void)
//OLED 复位
OLED_RES_Clr();//RES 置 0
delay_ms(200);//延时 200ms
OLED_RES_Set();//RES 置 1
//OLED 初始化
OLED_WR_Byte(0xAE,OLED_CMD);//--turn off oled panel
OLED_WR_Byte(0x00,OLED_CMD);//---set low column address
OLED_WR_Byte(0x10,OLED_CMD);//---set high column address
OLED_WR_Byte(0x40,OLED_CMD);//--set start line address
OLED_WR_Byte(0x81,OLED_CMD);//--set contrast control register
OLED_WR_Byte(0xCF,OLED_CMD);// Set SEG Output Current Brightness
OLED_WR_Byte(0xA1,OLED_CMD);//--Set SEG/Column Mapping
0xa0 左 右 反 置
0xa1 正常
OLED_WR_Byte(0xC8,OLED_CMD);//Set COM/Row Scan Direction
0xc0 上 下 反 置
0xc8 正常
OLED_WR_Byte(0xA6,OLED_CMD);//--set normal display
OLED_WR_Byte(0xA8,OLED_CMD);//--set multiplex ratio(1 to 64)
OLED_WR_Byte(0x3f,OLED_CMD);//--1/64 duty
OLED_WR_Byte(0xD3,OLED_CMD);//-set display offset Shift Mapping RAM Counter
(0x00~0x3F)
OLED_WR_Byte(0x00,OLED_CMD);//-not offset
OLED_WR_Byte(0xd5,OLED_CMD);//--set display clock divide ratio/oscillator frequency
OLED_WR_Byte(0x80,OLED_CMD);//--set divide ratio, Set Clock as 100 Frames/Sec
OLED_WR_Byte(0xD9,OLED_CMD);//--set pre-charge period
OLED_WR_Byte(0xF1,OLED_CMD);//Set Pre-Charge as 15 Clocks & Discharge as 1 Clock
OLED_WR_Byte(0xDA,OLED_CMD);//--set com pins hardware configuration
OLED_WR_Byte(0x12,OLED_CMD);
OLED_WR_Byte(0xDB,OLED_CMD);//--set vcomh
OLED_WR_Byte(0x30,OLED_CMD);//Set VCOM Deselect Level
OLED_WR_Byte(0x20,OLED_CMD);//-Set Page Addressing Mode (0x00/0x01/0x02)
OLED_WR_Byte(0x02,OLED_CMD);//
OLED_WR_Byte(0x8D,OLED_CMD);//--set Charge Pump enable/disable
OLED_WR_Byte(0x14,OLED_CMD);//--set(0x10) disable
OLED_Clear();
OLED_WR_Byte(0xAF,OLED_CMD);
15
//延时
void IIC_delay(void)
u8 t=1;
while(t--);
//起始信号
void I2C_Start(void)
OLED_SDA_Set();
OLED_SCL_Set();
IIC_delay();
OLED_SDA_Clr();
IIC_delay();
OLED_SCL_Clr();
IIC_delay();
//结束信号
void I2C_Stop(void)
OLED_SDA_Clr();
OLED_SCL_Set();
IIC_delay();
OLED_SDA_Set();
//等待信号响应
void I2C_WaitAck(void) //测数据信号的电平
OLED_SDA_Set();
IIC_delay();
OLED_SCL_Set();
IIC_delay();
OLED_SCL_Clr();
IIC_delay();
16
//写入一个字节
void Send_Byte(u8 dat)
u8 i;
for(i=0;i 0.1
L≤2
n≤1
L>2
n=0
Φ ≤ 0.1
Ignore
0.1 < Φ ≤ 0.25
n≤1
0.25 < Φ
n=0
Φ ≤ 0.5
Ignore if no Influence on Display
0.5 < Φ
n=0
Not Allowable
* Protective film should not be tear off when cosmetic check.
** Definition of W & L & Φ (Unit: mm): Φ = (a + b) / 2
L
b: Minor Axis
W
a: Major Axis
Check Item
Classification
No Display
Major
Missing Line
Major
Pixel Short
Major
Darker Pixel
Major
Wrong Display
Major
21
Criteria
Un-uniform
Major
7. Precautions When Using These OEL Display
Modules
7.1Handling Precautions
1)
2)
3)
4)
5)
Since the display panel is being made of glass, do not apply mechanical impacts such us
dropping from a high position.
If the display panel is broken by some accident and the internal organic substance leaks out,
be careful not to inhale nor lick the organic substance.
If pressure is applied to the display surface or its neighborhood of the OEL display module, the
cell structure may be damaged and be careful not to apply pressure to these sections.
The polarizer covering the surface of the OEL display module is soft and easily scratched.
Please be careful when handling the OEL display module.
When the surface of the polarizer of the OEL display module has soil, clean the surface. It
takes advantage of by using following adhesion tape.
* Scotch Mending Tape No. 810 or an equivalent
Never try to breathe upon the soiled surface nor wipe the surface using cloth containing solvent such as ethyl alcohol, since the surface
of the polarizer will become cloudy.
Also, pay attention that the following liquid and solvent may spoil the polarizer:
6)
* Water
* Ketone
* Aromatic Solvents
Hold OEL display module very carefully when placing OEL display module into the system
housing. Do not apply excessive stress or pressure to OEL display module. And, do not over
bend the film with electrode pattern layouts. These stresses will influence the display
performance. Also, secure sufficient rigidity for the outer cases.
7)
8)
Do not apply stress to the driver IC and the surrounding molded sections.
Do not disassemble nor modify the OEL display module.
22
9) Do not apply input signals while the logic power is off.
10) Pay sufficient attention to the working environments when handing OEL display modules to
prevent occurrence of element breakage accidents by static electricity.
* Be sure to make human body grounding when handling OEL display modules.
* Be sure to ground tools to use or assembly such as soldering irons.
* To suppress generation of static electricity, avoid carrying out assembly work under dry
environments.
* Protective film is being applied to the surface of the display panel of the OEL display
module.
Be careful since static electricity may be generated when exfoliating the
protective film.
11) Protection film is being applied to the surface of the display panel and removes the protection
film before assembling it. At this time, if the OEL display module has been stored for a long
period of time, residue adhesive material of the protection film may remain on the surface of
the display panel after removed of the film. In such case, remove the residue material by
the method introduced in the above Section 5).
12) If electric current is applied when the OEL display module is being dewed or when it is placed
under high humidity environments, the electrodes may be corroded and be careful to avoid
the above.
7.2Storage Precautions
1)
When storing OEL display modules, put them in static electricity preventive bags avoiding
exposure to direct sun light nor to lights of fluorescent lamps. and, also, avoiding high
temperature and high humidity environment or low temperature (less than 0 C)
environments. (We recommend you to store these modules in the packaged state when
they were shipped from ZhongJingYuan technology Co.,Ltd.)
At that time, be careful not to let water drops adhere to the packages or bags nor let dewing occur with them.
2)
If electric current is applied when water drops are adhering to the surface of the OEL display
module, when the OEL display module is being dewed or when it is placed under high
humidity environments, the electrodes may be corroded and be careful about the above.
7.3Designing Precautions
1)
2)
3)
4)
5)
6)
The absolute maximum ratings are the ratings which cannot be exceeded for OEL display
module, and if these values are exceeded, panel damage may be happen.
To prevent occurrence of malfunctioning by noise, pay attention to satisfy the VIL and VIH
specifications and, at the same time, to make the signal line cable as short as possible.
We recommend you to install excess current preventive unit (fuses, etc.) to the power circuit
(VDD). (Recommend value: 0.5A)
Pay sufficient attention to avoid occurrence of mutual noise interference with the neighboring
devices.
As for EMI, take necessary measures on the equipment side basically.
When fastening the OEL display module, fasten the external plastic housing section.
23
7)
If power supply to the OEL display module is forcibly shut down by such errors as taking out
the main battery while the OEL display panel is in operation, we cannot guarantee the quality
of this OEL display module.
8) The electric potential to be connected to the rear face of the IC chip should be as follows:
SSD1306
* Connection (contact) to any other potential than the above may lead to rupture of the IC.
7.4Precautions when disposing of the OEL display modules
1) Request the qualified companies to handle industrial wastes when disposing of the OEL display
modules.
Or, when burning them, be sure to observe the environmental and hygienic laws and
regulations.
7.5Other Precautions
1)
When an OEL display module is operated for a long of time with fixed pattern may remain as
an after image or slight contrast deviation may occur.
Nonetheless, if the operation is interrupted and left unused for a while, normal state can be
restored. Also, there will be no problem in the reliability of the module.
2) To protect OEL display modules from performance drops by static electricity rapture, etc., do
not touch the following sections whenever possible while handling the OEL display modules.
* Pins and electrodes
* Pattern layouts such as the FPC
3) With this OEL display module, the OEL driver is being exposed.
Generally speaking,
semiconductor elements change their characteristics when light is radiated according to the
principle of the solar battery.
Consequently, if this OEL driver is exposed to light,
malfunctioning may occur.
* Design the product and installation method so that the OEL driver may be shielded from light in
actual usage.
* Design the product and installation method so that the OEL driver may be shielded from light during
the inspection processes.
4)
5)
Although this OEL display module stores the operation state data by the commands and the
indication data, when excessive external noise, etc. enters into the module, the internal status
may be changed. It therefore is necessary to take appropriate measures to suppress noise
generation or to protect from influences of noise on the system design.
We recommend you to construct its software to make periodical refreshment of the operation
statuses (re-setting of the commands and re-transference of the display data) to cope with
catastrophic noise.
24
Warranty:
The warranty period shall last twelve (12) months from the date of delivery. Buyer shall be
completed to assemble all the processes within the effective twelve (12) months. ZhongJingYuan
technology Co.,Ltd. shall be liable for replacing any products which contain defective material or
process which do not conform to the product specification, applicable drawings and specifications
during the warranty period. All products must be preserved, handled and appearance to permit
efficient handling during warranty period. The warranty coverage would be exclusive while the
returned goods are out of the terms above.
25
