RH6030_SPEC
单通道触摸感应开关
RH6030
规格书
Revision 2.1 2012-3-19
RH6030_SPEC_Ver2.1
1/9页
03/19/2012
RH6030_SPEC
目
录
1. 简介 ............................................................................................................................................................... 3
2. 特点 ............................................................................................................................................................... 3
3. 引脚示意图 .................................................................................................................................................... 3
4. 功能描述........................................................................................................................................................ 4
4.1
快速/低功耗模式(FST) ....................................................................................................................... 4
4.2
保持/同步模式(HLD) .......................................................................................................................... 4
4.3
输出模式选择(OLH) ...................................................................................................................... 4
4.4
灵敏度调节......................................................................................................................................... 4
4.5
最大开启时间模式(MOT) ................................................................................................................... 4
5. 绝对最大值 .................................................................................................................................................... 5
6. 电气参数........................................................................................................................................................ 5
7. 应用电路图 .................................................................................................................................................... 5
7.1
LED台灯 ............................................................................................................................................ 5
7.2
墙体开关 ............................................................................................................................................ 6
8. 穿透力应用说明............................................................................................................................................. 7
8.1
穿透力与铺地、感应电极大小对应关系 ............................................................................................. 7
8.2
穿透力与触摸引脚并联电容对应关系................................................................................................. 7
9. 封装信息........................................................................................................................................................ 8
9.1
SOT23-6L .......................................................................................................................................... 8
9.2
SOP-14L............................................................................................................................................ 9
RH6030_SPEC_Ver2.1
2/9页
03/19/2012
RH6030_SPEC
1.简介
2.特点
RH6030 是一款单通道电容式触摸感应控制开关 IC,
工作电压:2.0V~5.5V
可以替代传统的机械式开关。
最高功耗工作电流为 10uA,低功耗模式工作电
该 IC 采用 CMOS 工艺制造,结构简单,性能稳定。
流仅 1.5uA(均指 3.0V 供电且不带负载的条件下)
该 IC 可通过外部引脚配置成多种工作模式,可广泛应
可通过外部引脚配置为多种模式
用于灯光控制、玩具、家用电器等产品中。
高可靠性,芯片内置去抖动电路,可有效防止由
外部噪声干扰导致的误动作
可用于玻璃、陶瓷、塑料等介质表面
3.引脚示意图
图 1 SOP-14/SOT23-6L 封装示意图
注意:SOT23-6L 为常用封装
表 1 引脚功能描述
SOT23-6L
SOP14
管脚名称
1,7,8,10
NC
2
OLH
I
输出高/低有效模式选择
3
RST
I
外部复位
4
SLS
I
采样时长模式选择
5
MOT
I
最大开启时间选择
3
6
TCH
I
触摸按键输入
1
9
OUT
O
CMOS 输出
2
11
GND
P
负电源
12
FST
I
快速/低功耗模式选择
6
13
HLD
I
保持/同步模式选择
5
14
VDD
P
正电源
4
I/O
Descrption
No Connection
RH6030_SPEC_Ver2.1
3/9页
03/19/2012
RH6030_SPEC
4.功能描述
RH6030 可通过外部引脚配置为多种工作模式。外部配置引脚悬空时,配置位自动设置为默认值(Default)。
表 2 功能描述表
NAME
FST
HLD
OLH
SLS
MOT
选
项
功
能
=1
快速模式
=0(Default)
低功耗模式
=1
保持模式
=0(Default)
同步模式
=1
输出低电平有效
=0(Default)
输出高电平有效
=1(Default)
采样时间约 1.5ms
=0
采样时间约 3.0ms
=1(Default)
禁止最大开启时间功能
=0
最大开启时间 75s
备
注
低功耗模式下触摸检测响应时间将变长
4.1 快速/低功耗模式(FST)
控制 OUT 输出电平
此选项只在同步模式下有效
4.4 灵敏度调节
通过对管脚 FST 的设置,可配置为快速模式或者低功
1. 设置 SLS。当该管脚悬空时,默认由内部上拉
耗模式,当该管脚悬空时,默认由内部上拉为高电平,
为高电平,采样时间长度设置为 1.5ms;
即置为快速模式;
SLS 设置为 0 时,采样时间长度设置为 3.0ms,
FST 设置为 1 (快速模式)时,触摸响应时间约 40ms;
此时芯片对触摸感应响应的灵敏度高于 SLS
FST 设置为 0 (低功耗模式)时,触摸响应时间约 160
设置为 1 时的灵敏度。
ms。
2. 外接调节电容 Cj。调节电容值的范围是 0pF~
50 pF,电容值的增加将导致灵敏度降低。
4.2 保持/同步模式(HLD)
3. 改变连接到 TCH 的触摸按键的面积和形状。如
当管脚 HLD 悬空时,默认由内部下拉为低电平,即置
为同步模式;
HLD 设置为 1 时,选择保持模式,此时输出 OUT 状
态在触摸响应后保持:当触摸消失后仍保持为响应状
态;再次触摸并响应后恢复为初始状态;
HLD 设置为 0 时,选择同步模式,此时输出 OUT 状
需增加触摸感应灵敏度,可适当增大触摸按键
的面积;但触摸按键面积增大到一定程度后,
面积的继续增加几乎不能对灵敏度产生影响。
4. 触摸按键到 TCH 管脚的导线长度,及 PCB 的
布局,都会对灵敏度产生一定的影响。
态与触摸响应同步:只有检测到触摸时有输出响应;
4.5 最大开启时间模式(MOT)
当触摸消失时,OUT 状态恢复为初始状态。
此模式只在同步模式下有效,当管脚 MOT 悬空时,
默认为由内部上拉为高电平,禁止最大开启时间复位
4.3 输出模式选择(OLH)
功能;
RH6030 可设置多种输出模式,当管脚 OLH 悬空时,
默认为由内部下拉为低电平,即置管脚 OUT 为高电
平有效模式;
MOT 设置为 0 时,同步模式下触摸响应后,如持续检
测到触摸存在达到约 75s(3V),则自动复位并校准,
同时置输出 OUT 为未检测到触摸时的状态。
OLH 设置为 1 时,OUT 脚为低电平有效模式;
OLH 设置为 0 时,OUT 脚为高电平有效模式。
RH6030_SPEC_Ver2.1
4/9页
03/19/2012
RH6030_SPEC
5.绝对最大值
表 4 工作条件规格表
项
目
符
号
范
围
单
位
VDD
-0.3~5.5
V
VI / VO
-0.5~VDD +0.5
V
工作温度
TOPR
-20 ~ 70
储藏温度
TSTG
-50 ~ 125
工作电压
输入/输出电压
所列电压均以 GND 为参考
6.电气参数
表 5 电气参数表
参数
工作电压
符号
条件
VDD
TOPR =-20 ~ 70℃
FST=0
工作电流
IDD
FST=1
最小值
典型值
最大值
单位
2.0
3.0
5.5
V
SLS=1
1.5
3.5
SLS=0
2.5
5.0
SLS=1
6.0
8.5
SLS=0
10.0
15.0
uA
若无特别说明,VDD 为 3.0V﹐环境温度为 25℃,芯片输出无负载
7.应用电路图
7.1 LED台灯
图 2 LED 台灯应用电路
RH6030_SPEC_Ver2.1
5/9页
03/19/2012
RH6030_SPEC
7.2 墙体开关
图 3 墙体开关应用电路示意图
说明:
1.
Cj 指调节灵敏度的电容,电容值大小 0pF~50pF(电容值的增大将导致灵敏度降低)。
2.
Rs 指在触摸电极和触摸输入脚之间串联的电阻,用于提高触摸的抗干扰能力,可根据具体应用进行选择。
3.
VDD 与 GND 间需并联滤波电容以消除噪声。供电电源需稳定,如果电源电压漂移或者快速变化,可能引
起灵敏度漂移或检测错误。
4.
应该在触摸电极上铺好覆盖介质后再上电,这样芯片会在上电时候检测环境以及初始电容。如在芯片已经
初始化后再放上覆盖物,则有可能被系统检测到电容突变而无法将其作为环境,引起误判断!
5.
请参看,以改善实际应用之可靠性。
RH6030_SPEC_Ver2.1
6/9页
03/19/2012
RH6030_SPEC
8. 穿透力应用说明
8.1 穿透力与铺地、感应电极大小对应关系
8.2 穿透力与触摸引脚并联电容对应关系
感应电
PCB顶层不铺地
PCB顶层铺实铜
电容(*)值
亚克力材料穿透力
极面积
底层不铺地
底层35%铺地
未接
4.9mm
6×6mm
8mm
1.7mm
1pF
4.9mm
7×7mm
10mm
2.8mm
5pF
3mm
8×8mm
14mm
3.8mm
10pF
2mm
10×10mm
16mm
4.9mm
20pF
1mm
12×12mm
18mm
6mm
30pF
1mm
15×15mm
22mm
8mm
说明:
1. 此表仅供参考,具体焊盘大小应根据实际模具外
壳厚度来调整。
2.
触摸焊盘面积越大,可穿透介质材料越厚。
3.
PCB铺地比例越小,PCB点触焊盘与地之间的寄
(*)触摸引脚并联电容到地,
测试条件:感应电极(直径10mm),PCB
顶层铺实铜,PCB底层35%铺地。
说明:
此表仅供参考,并联电容越小,可穿透介质材料越厚。
生电容越小,人体触摸后新生的手指电容相对
PCB寄生电容变化越大,触摸灵敏度越高,可穿
透介质越厚。
4.
PCB铺地比例越小,越易受到外界干扰。
5.
建议实际应用时兼顾灵敏度和抗干扰设计PCB
的铺地形式。如对穿透介质厚度要求不高,建议
增加铺地比例以提高抗干扰性能。
RH6030_SPEC_Ver2.1
7/9页
03/19/2012
RH6030_SPEC
9.封装信息
9.1 SOT23-6L
Symbol
Dimensions in mm
Min
Typ
Max
A
1.35
A1
0.04
0.15
A2
1.00
1.10
1.20
A3
0.55
0.65
0.75
b
0.34
0.43
b1
0.33
0.35
0.38
c
0.15
0.21
c1
0.14
0.15
0.16
D
2.72
2.92
3.12
E
2.60
2.80
3.00
E1
1.40
1.60
1.80
e
0.95BSC
e1
1.90BSC
L
0.30
0.60
θ
8°
RH6030_SPEC_Ver2.1
8/9页
03/19/2012
RH6030_SPEC
9.2 SOP-14L
Symbol
Dimensions in mm
Min
Typ
Max
A
1.75
A1
0.05
0.225
A2
1.30
1.40
1.50
A3
0.60
0.65
0.70
b
0.39
0.48
b1
0.38
0.41
0.43
c
0.21
0.26
c1
0.19
0.20
0.21
D
8.45
8.65
8.85
E
5.80
6.00
6.20
E1
3.70
3.90
4.10
1.27BSC
e
h
0.25
0.50
L
0.50
0.80
1.05BSC
L1
θ
8°
注意:
规格如有更新﹐恕不另行通知。请在使用该 IC 前更新规格书至最新版本。
RH6030_SPEC_Ver2.1
9/9页
03/19/2012
很抱歉,暂时无法提供与“RH6030”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.66195
- 50+0.55822
- 150+0.50636
- 500+0.46747
- 3000+0.38832
- 6000+0.37276
- 国内价格
- 5+0.70800
- 50+0.59700
- 150+0.54150
- 500+0.50000
- 3000+0.41530
- 6000+0.39860
