NO.
ECAB2008043
Acknowledgement Book
Customer
Production name : HC-49S X'TAL 11.50×4.70×3.68
Nominal Freq.
: 8.000000MHz
Customer P/N
P/N
: B08000J065
Receiver
Please return one after acknowledgement
Approved By
MFG
QA
PE/RD
BOOK OF MODIFICATION
No.
DATE
CONTENT OF
MODIFICATION
INTIAL RELEASED
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
REASON OF
MODIFICATION
PAGE
ITEM
APPROVE
P: 2/8
QUARTZ CRYSTAL UNITS
No:
ECAB2008043
Date:
2020-8-25
SPECIFICATION OF QUARTZ CRYSTAL UNITS
1.HOLDER TYPE HC-49S X'TAL 11.50×4.70×3.68
2.GENERAL
2-1 FREQUENCY (F0)
8.000000MHz
2-2 MODE OF OSCILLATION (Mn)
FUNDAMENTAL
2-3 OPERATION TEMPERATURE RANGE (T 0)
-20℃ ~ +70℃
2-4 STORAGE TEMPERATURE RANGE (Ts)
-50℃/+125℃
2-5 TEST SET
S&A 250B ANALYSIS SYSTEM
2-6 DRIVE LEVEL (DL)
100μw
2-7 LOADING CAPACITANCE (CL)
20PF
TYPE (500μw MAX)
3.ELECTRICAL CHARACTERISTICS
(This test shall be performed under the condition of temperature at 25±3℃.)
3-1 FREQUENCY TOLERANCE (△f)
±20 ppmMAX
3-2 EQUIVALENT RESISTANCE (Rr)
40ΩMax/Series
3-3 TEMPERATURE DRIFT (T C)
±20ppm/MAX -20℃+70℃
3-4 SHUNT CAPACITANCE (C0)
<7.0PF
3-5 INSULATION RESISTANCE
500MΩmin/DC 100V±15V
(Lead to lead ,case to lead)
4.DIMENSIONS AND MARKING
4-1 HOLDER TYPE
JinHua East Crystal Electronic
Co.,Ltd.
DESIGN
INSPECTION
陈振辉
王晓东
P: 3/8
No:
ECAB2008043
Date:
2020-8-25
DESIGN
INSPECTION
陈振辉
王晓东
4-2 DIMENSION (mm)
HC-49U/S
A
B
C
D
E
F
G
H
11.50MAX
10.30MAX
4.88±0.2
0.45±0.05
13.2±0.5
3.80MAX
4.70MAX
3.68MAX
4-3 MARKING
HC-49S
Corporation name
8.000JH0
Frequency
Year code
CL
Month code
Co.,Ltd.
P: 4/8
No:
ECAB2008043
Date:
2020-8-25
4-4 PACKING
Put 200pcs crystals into a plastic bags with bubbly sheet surrounded
into inner-box,put 20 inner-boxes with foam sheet surrounded into a paper case,
then write HOLD.FREQ.QTY in inner-box and paper case.
Co.,Ltd.
DESIGN
INSPECTION
陈振辉
王晓东
P: 5/8
No:
ECAB2008043
Date:
2020-8-25
5.MECHANICAL ENDURANCE
Provided that measurement shall be carried out after letting it alone in the room
temperature for 1 hour.
5-1.SHOCK
Electrical charateristics shall be satisfied after dropping three times from the
height of 75cm onto the board of the 3cm thickness.
5-2.VIBRATION
Electrical charateristics shall be satisfied after supplying following vibration.
a).ENTIRE FREQUENCY RANGE
10~55Hz
b).REPEATED PERIOD
1~2min
c).AMPLITUDE
1.5mm
d).DIRECTION
X.Y.Z
e).PERIOD
2hours/Each Direction
5-3.STRENGTH OF TERMINALS/LEAD-WIRES
①TENSILE
a).Body of specimen shall be fixed,and 900g of tension weight shall be supplied
gradually to axial direction of terminals/lead-wires for 30 sec.
b).After above test a),there is no distinct damage or damage to sealing.
②BENDING
a).Body of specimen shall be fixed,and 90 degree bending shall be given,being supplied
225g tension weight.After that,terminals/lead-wires shall be straightened gradually.
Then the same bending and straightening shall be supplied to the opposite direction in the
same axial.
b).After above test a),there is no observation of any visual damages on the specimen.
5-4.SEALING TIGHTNESS
Put the specimens in C2H5OH,raise pressure it with 0.5Mpa for 10 min,
test the insulation resistance at DC.100V,the result shall be over 500MΩ.
Electrical characteristics shall be satisfied and no sealing damage.
Co.,Ltd.
DESIGN
INSPECTION
陈振辉
王晓东
P: 6/8
No:
ECAB2008043
Date:
2020-8-25
5-5.SOLDERING HEAT RESISTANCE
Electrical characteristics shall be satisfied .Without distinct looseness of terminals.
①.FLOW(WAVE)SOLDERING
Following profile of heat stress is applied to resonator,then being place in the natural
condition for 1 hour,resonator shall be measured.
Peak temperature
Dipping time
Soldering
260°C
10±5 sec
1 time
Dipping to the lead joint of component
②.SOLDERING DIP
Terminals/lead-wires of specimen shall be dipped into solder melter tank
at +230℃±5℃ for 3 sec.
Dipping depth shall be 2mm from the bottom of specimens body.(After
applying ROSIN FLUX) soldering portion shall be covered in over 95% of
Terminals/lead-wires dipped.
5-6.BEND STRENGTH PCB
①.Resonator is soldered into the ceater of PCB which is laid on the 2 small
supporters spaced 90cm. PCB deflected to 1mm below from horizontal level by
the pressing force with 20 x10.R10 stick.
The force is supplied for 1 second,5 times repeatedly.
②.After above test ①.there is no observation of any visual damages on specimen
and the electical characteristic shall be satisfied.
Co.,Ltd.
DESIGN
INSPECTION
陈振辉
王晓东
P: 7/8
No:
ECAB2008043
Date:
2020-8-25
5-7.ENVIRONMENTAL ENDURANCE
alone in the room temperature for 1 hour.
①HUMIDITY
Electrical characteristics shall be satisfied after letting it alone at 65±2℃
in humidity of 90~95% for 250 hours.
②.STORAGE IN LOW TEMPRATURE
Electrical characteristics shall be satisfied after letting it alone at -45±2℃
for 250 hours.
③.STORAGE IN HIGH TEMPRATURE
Electrical characteristics shall be satisfied after letting it alone at 85±2℃
for 250 hours.
④.TEMPERATURE CYCLE
Electrical characteristics shall be satisfied after supplying the following temperature
cycle(3cycle).Temperature shift from low to high, high to low shall be done in
1℃/sec.
(refer to Fig-3)
30min
'+85 ±3 ℃
25±5℃
30min
'-30 ±3 ℃
1 cycle
( Fig-3 )
Co.,Ltd.
DESIGN
INSPECTION
陈振辉
王晓东
P: 8/8
No:
ECAB2008043
Date:
2020-8-25
6. Structure Illustration
1
3
4
5
2
(BOTTOM VIEW)
No.
Items
Materials
Manufacture's name
1
Metal Can(Cap)
Ni Alloy
TOGAWA SEIKO CHINA
2
Substrate(Base)
Kovar (Pb free)
XURI ELEC. CHINA
3
Conductive Adhesive
Ag+Epoxy Resin
Three Bond JAPAN
4
5
Intemal Electrode
Element(Blank)
Ag
SiO2
SOLAR CHINA
ECEC CHINA
Co.,Ltd.
DESIGN
INSPECTION
陈振辉
王晓东
很抱歉,暂时无法提供与“B08000J065”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.30720
- 10+0.29520
- 100+0.25920
- 500+0.25200
