1ZCM08000KK0B
1ZCM08000KK0B
    KDS(大真空)
    SMD3225_2P
    无源晶振 8MHz 8pF ±50ppm -40℃~+125℃ 400Ω SMD3225_2P
1ZCM08000KK0B 数据手册
Serial No. : 2011-1360 DATE : 2011/10/24 CRYSTAL RESONATOR ITEM : DSX320G TYPE : --------------------------------------------------------------------------------------------------------------------------------- 8.000MHz NOMINAL FREQUENCY : -------------------------------------------------------------------------------------------------------------------------------- SPEC No. : 1ZCM08000KK0B --------------------------------------------------------------------------------------------------------------------------------- --------------------------------------------------------------------------------------------------------------------------------- RECEIPT DATE RECEIVED (signature) (name) General Manufacture of Quartz Devices 1389 Shinzaike, Hiraoka-cho, Kakogawa, Hyogo 675-0194 Japan Phone (81)79-425-3141 Fax (81)79-425-1134 http://www.kds.info/index_en.htm C.ENG. ENG. Serial No. 2011-1360 1. ELECTRICAL CHARACTERISTICS (This test shall be performed under the conditions of temp.at 25 ± 3°C, Relative Humidity 60% max.) (1) NOMINAL FREQUENCY 8.000000 MHz (2) OVERTONE ORDER Fundamental 8.0 (3) LOAD CAPACITANCE(CL) pF (4) FREQUENCY TOLERANCE ±50 ppm max. (at +25 ± 3 °C) (5) DRIVE LEVEL 10 ± 2 µW 400 Ω max. (at Series) (6) SERIES RESISTANCE (7) OPERATING TEMPERATURE RANGE -40 ~ +125 °C (8) FREQUENCY CHARACTERISTICS OVER TEMPERATURE ±100 ppm max. / -40 ~ +125 °C (ref. to +25°C) 2.0 pF max. (9) SHUNT CAPACITANCE 500 MΩ min. / DC 100 ± 15V (10) INSULATION RESISTANCE (11) STORAGE TEMPERATURE RANGE -40 ~ +125 °C 2. CONSTRUCTION (1) DIMENSIONS AND MARKING Refer to 4. 3. OTHER SPECIFICATIONS (1) EMBOSS CARRIER TAPE & REEL Refer to 5. (2) PACKING Refer to 6. (3) REFLOW CONDITIONS (REFERENCE) Refer to 7. (4) LAND PATTERN (REFERENCE) Refer to 8. (5) RELIABILITY SPECIFICATION Refer to 9.~11. (6) OTHER HANDLING INSTRUCTIONS Refer to 12. TITLE DSX320G TYPE QUARTZ CRYSTAL SPECIFICATION REMARK SPEC. No. DATE REV. PAGE 1ZCM08000KK0B 2011/10/24 1 / 12 DAISHINKU CORP. DM-Z0002:Style-010 Serial No. 2011-1360 4. DIMENSIONS AND MARKING 0 .15 3 .20 F requency Lo t No . 0 .85 ±0 .15 Logo 2 .50 (1)(2)(3) 1 .8 4 -0 .1 < Top V iew > #2 #1 2 -1 .3 2 -1 .5 0 .5 0 .8 #2 #1 2 -1 .0 2 -1 .2 Figure-1 unit : mm Tolerance : ±0.1 Logo(1) and Nominal Frequency (2) should be printed as follows by producing district Made in INDONESIA --> Spec. No.: 1ZCM08000EK0A , Logo : D , Frequency: 08 * Made in INDONESIA : Under Bar with D Nominal Frequency ( 2 ) = Mark two digits from upper decimal point (ex. 8.000000 MHz ----> 08 ) Manufacturing lot No.( 3 ) 2011 (year) ex. October (Month) ex. (Table-1.) Year Jan. Mark A Feb. B shall be marked as ' shall be marked as ' Mar. C Apr. D May. E 1 K Jun. F ' (The last digit of the year) ' (As shown in Table-1.) Jul. G Aug. H Sep. J Oct. K Nov. L Dec. M Plating material of a terminal. : Ni Plating + Au Plating. A clearance between the soldering terminal portion and a print circuit board side should be less than 0.1mm. TITLE DSX320G TYPE QUARTZ CRYSTAL SPECIFICATION REMARK SPEC. No. DATE REV. PAGE 1ZCM08000KK0B 2011/10/24 2 / 12 DAISHINKU CORP. DM-Z0002:Style-010 Serial No. 2011-1360 5. EMBOSS CARRIER TAPE & REEL 1 . 7 5+ / - 0 . 1 D249B 0 . 25+ / -0 . 05 2 . 0+ / -0 . 05 4 . 0+ / -0 . 1 1.15d ia.+/ -0.05 3 . 5+ / - 0 . 0 5 1.55d ia.+/ -0.05 4 . 0+ / -0 . 1 8 . 0+ / - 0 . 2 3 . 5+ / - 0 . 1 (1) Dimensions of embossed carrier tape 1.0+/ -0.1 User Direction of feed 2 .8+ / -0 .1 ( Un i t :mm ) Figure-2 U E q 2 F q F3 (2) Dimensions of tape reel V B A C F1 W1 W2 Figure-3 TITLE DSX320G TYPE QUARTZ CRYSTAL SPECIFICATION REMARK SPEC. No. DATE REV. PAGE 1ZCM08000KK0B 2011/10/24 3 / 12 DAISHINKU CORP. DM-Z0002:Style-010 Serial No. 2011-1360 (UNIT:mm) Products Mark DSX320G Dimensions Angle Diameter A 180 Φ +0.0 / -3.0 Inside of Frange W1 9.0 ± 0.3 Outside of Frange W2 11.4 ± 1.0 Inside Diameter B φ60 +1.0-0 F1 3.0 ± 0.2 F2 4.0 ± 0.2 F3 5.0 ± 0.2 Length V 11.9 +0.5 / -0.0 Angle q 120° Spindle Diameter C 13 Φ ± 0.2 Width E 2.0 ± 0.5 Length U 10.5 ± 0.4 Angle q 120° Item Flange Width Center Core Slit Center Core Key Seats (3) Storage condition Temperature : +40 °C max. Relative Humidity : 80% max. ( It is a guaranteed term because it obtains an excellent soldering: 6 months) (4) Standard packing quantity 3,000 pcs/reel (5) Material of the tape Tape Material Carrier tape Polystyrene+Carbon Cover tape Polyester TITLE DSX320G TYPE QUARTZ CRYSTAL SPECIFICATION REMARK SPEC. No. DATE REV. PAGE 1ZCM08000KK0B 2011/10/24 4 / 12 DAISHINKU CORP. DM-Z0002:Style-010 Serial No. 2011-1360 (6) Label contents Type Our specification No. Your Part No. Lot No. Nominal Frequency Quantity Our Company Name Producting Country Stick a label on the each reel. (7) Taping dimension Cover-tape Leader Carrier-tape Cover-tape Terminal Carrier-tape The length of cover-tape in the leader is more than 400mm including empty embossed area. After all products were packaged, must remain more than twenty pieces or 400mm empty area, which should be sealed by cover-tape. The tip of cover-tape shall be fixed temporary by paper tape and roll around the core of reel one round. The empty embossed area which are sealed by cover-tape must remain more than 40mm. Terminal Leader Component Empty Components Unreeling direction Empty Components Cover-tape Carrier-tape Figure-4 (8) Joint of tape The carrier-tape and cover-tape should not be jointed. (9) Release strength of cover tape It has to between 0.1 ~ 0.7N under following condition. Pulling direction 165 ~ 180 ° Speed 300mm/min. Otherwise unless specified. 165 ~ 180 ° Pulling direction Figure-5 Other standards shall be based on JIS C 0806 -1990. TITLE DSX320G TYPE QUARTZ CRYSTAL SPECIFICATION REMARK SPEC. No. DATE REV. PAGE 1ZCM08000KK0B 2011/10/24 5 / 12 DAISHINKU CORP. DM-Z0002:Style-010 Serial No. 2011-1360 6. PACKING (1) STORAGE METHOD Label contents LABEL The type of product Lot No. Specification Quantity Shipment Day Remark Figure-6 (2) BOX SIZE From lot size packingsize shall be changed. In the upper and lower part and the opening in box it shall be protected products using aircushion sheets. TITLE DSX320G TYPE QUARTZ CRYSTAL SPECIFICATION REMARK SPEC. No. DATE REV. PAGE 1ZCM08000KK0B 2011/10/24 6 / 12 DAISHINKU CORP. DM-Z0002:Style-010 Serial No. 2011-1360 7. REFLOW CONDITIONS (REFERENCE) During the solder reflow process, please complete within following temperature, period. Reflow soldering shall be allowed only 3 times. 260 ± 5 °C 220 ± 5 °C 160 ~ 180 °C 10 s 60 s 120 s Total time : 240 s max. Figure-7 HANDSOLDERING METHOD : 350 ± 10 °C , 3+1/-0s Each terminal once (Please take care so that a soldering iron should not touch a product directly.) 8. LAND PATTERN (REFERENCE) 0 .9 2 .0 2 .0 1 .6 unit : mm Figure-8 TITLE DSX320G TYPE QUARTZ CRYSTAL SPECIFICATION REMARK SPEC. No. DATE REV. PAGE 1ZCM08000KK0B 2011/10/24 7 / 12 DAISHINKU CORP. DM-Z0002:Style-010 Serial No. 9. MECHANICAL ENDURANCE 2011-1360 Compatible with AEC-Q200. (1) SHOCK (ACCELERATION) After the following test,parts shall conform specification 11.A. 1000m/s2 by 6ms X,Y,Z each axis (6 directions) , 3cycles (2) SHOCK (MOUNTING DROP) After the following test,parts shall conform specification 11.A. 3cycles(18times) drop from 150 cm heights to concrete. Further,parts shall be solderd on substrate, fixed Aluminum materials(about 100g). Substrate materials : Glass Epoxy 1 cycle : each 1 times of 6 directions (3) VIBRATION After the following test,parts shall conform specification 11.A. and no abnormal appearance shall be observed. Frequency of Vibration : 10 ~ 2000 ~ 10 Hz Amplitude(p-p) : Sine waves of 1.5mm or 50m/s 2 Cycle : 20min Vibration axis : X.Y.Z Vibration period : 4 h for each axis (4) SEAL Less than 2.0×10-9 Pa m 3/s. by Helium leak detector. Also, no serial bubble is observed by Fluorocarbon tests. (5) SOLDERABILITY After the following test, more than 95% of terminal shall be covered by new solder. 3 ± 0.5 s dip in 245 ± 5 °C solder. (Solder composition : Sn-3Ag-0.5Cu) (Use rosin type flux for solder.) (6) RESISTANCE TO SOLDERING HEAT (REFLOW) 48 h past at room temperature from following test,parts shall conform specification 11.A. perform the attached Reflow conditions to reference. (7) RESISTANCE TO SOLDERING HEAT (HAND SOLDERING METHOD) 48 h past at room temperature from following test,parts shall conform specification 11.A. 350 ± 10°C , 3+1/-0s Each terminal once. (8) SUBSTRATE BENDING After the following test,parts shall conform specification 11.A. and no abnormality shall be observed in external appearance and sealing tightnen and others shall be based on ET-7403 of EIAJ. Mount the specimen on substrate. Apply the following pressure Direction : see right figure pressure Speed : about 1.0 mm/s Hours : 5±1s Amount of substrate : 3 mm max. 20 jig 45+/-2 TITLE DSX320G TYPE QUARTZ CRYSTAL SPECIFICATION R230 P.C.B. 45+/-2 REMARK SPEC. No. DATE REV. PAGE 1ZCM08000KK0B 2011/10/24 8 / 12 DAISHINKU CORP. DM-Z0002:Style-010 Serial No. 2011-1360 (9) SHEAR After the following test,parts shall conform specification 11.A. and no abnormality shall be observed in external appearance and sealing tightness and others shall be based on ET-7403 of EIAJ. Mount the specimen on substrate. Apply the following pressure Weight : 10 N Hours : 10 ± 1 s Direction : see right figure P.C.B. pressure jig specimen R0.5 (10) BODY STRENGTH After the following test,parts shall conform specification 11.A. and no abnormality shall be observed in external appearance and sealing tightness and others shall be based on ET-7403 of EIAJ. Mount the specimen on substrate. Apply the following pressure Weight : 5N Hours : 10 ± 1 s Direction : see right figure pressure jig R0.5 specimen W L 0.5L L >= W L TITLE DSX320G TYPE QUARTZ CRYSTAL SPECIFICATION REMARK SPEC. No. DATE REV. PAGE 1ZCM08000KK0B 2011/10/24 9 / 12 DAISHINKU CORP. DM-Z0002:Style-010 Serial No. 2011-1360 10. ENVIRONMENTAL ENDURANCE Compatible with AEC-Q200. (1) LOW TEMPERATURE 2 h past at room temperature after following test, parts shall conform specification 11.A. 1000 h , -40 ± 3 °C. (2) HUMIDITY 2 h past at room temperature after following test, parts shall conform specification 11.A. 1000 h +85 ± 2 °C , relative humidity 85 ± 5%. (3) HIGH TEMPERATURE 2 h past at room temperature after following test, parts shall conform specification 11.A. 1000 h , +125 ± 2 °C. (4) TEMPERATURE CYCLE 2 h past at room temperature after 1000 cycles of followingtest, parts shall conform specification 11.A. 30min +125°C +25°C Transport Time 2-3min -40°C 30min 1 cycle 11. SPECIFICATION Frequency Variation and Equivalent Resistance shall be within Table below after the reliability test. Spec. A Frequency Variation ±10ppm Equivalent Resistance ±25 % or 10.0 Ω max. (Use larger specification) TITLE DSX320G TYPE QUARTZ CRYSTAL SPECIFICATION REMARK SPEC. No. DATE REV. PAGE 1ZCM08000KK0B 2011/10/24 10 / 12 DAISHINKU CORP. DM-Z0002:Style-010 Serial No. 2011-1360 12. DSX320G TYPE QUARTZ CRYSTAL HANDLING INSTRUCTIONS (1) SOLDERING Please perform the attached Reflow conditions to reference within 3 times. (2) MOUNT Crystal products are designed to be compatible with automatic mounting. Be sure to have a mounting test in advance by using the actual mounting machine and check that the characteristics of the products are not damaged by the automatic mounting. In the process where the boad is warped, such as board separation process, be careful that the warping does not influence the characteristics and soldering of crystal products. Since mounting by Ultrasonic welding and processing have a possibility of an excessive vibration spreading inside a crystal resonator and becoming the cause of characteristic deterioration and not oscillating, it does not recommend. (3) WASHING About use of the washing liquid of a basin system, an alcoholic system, and a chlorofluorocarbon-replacing material system, it is checking that it is satisfactory. However please consult in advance about other washing liquid. Although the check about ultrasonic washing is performed, since it is an examination with a simple substance, the check for the second time by the use state is recommended. (4) THE CAUTIONS ON USE The piece of crystal it is processed very smaller than the conventional thing inside DSX320G series crystal unit may be damaged, if excessive excitation electric power is applied. Please use it below with the value specified on a catalog and specifications. Please refrain from forming patterns between crystal land pattern's since there is a possibility to cause crack in base. If the temperature is higher than 280 °C, there is a possibility for the sealing glass to remelt. Avoid using the product at temperature higher than specified. (5) HANDLING OF A PRODUCT DSX320G series has sufficient intensity to fall and vibration. However when too much shock is added according to a certain cause, the use after a characteristic check is recommended. (6) STORAGE Since the soldering nature of a terminal may be degraded, please avoid storage in high temperature and a humid place. Please keep it in the place which direct rays do not hit and dew condensation does not generate. TITLE DSX320G TYPE QUARTZ CRYSTAL SPECIFICATION REMARK SPEC. No. DATE REV. PAGE 1ZCM08000KK0B 2011/10/24 11 / 12 DAISHINKU CORP. DM-Z0002:Style-010 2011-1360 REVISION RECORD Rev.No Date Reason - 2011/10/24 - Contents The first edition. -12/12- Approved Checked Drawn T.Okishio Y.Maeda M.Shikai DM-Z0002:Style-008
1ZCM08000KK0B 价格&库存
很抱歉,暂时无法提供与“1ZCM08000KK0B”相匹配的价格&库存,您可以联系我们找货
1ZCM08000KK0B
    • 1+2.87390
    库存:65
    1ZCM08000KK0B
    • 1+2.21999
    • 30+2.14499
    • 100+1.99499
    • 500+1.84500
    • 1000+1.77000
