山东晶导微电子有限公司
S3AB THRU S3MB
Jingdao Microelectronics
Surface Mount General Purpose Silicon Rectifiers
Reverse Voltage - 50 to 1000 V
PINNING
Forward Current - 3 A
PIN
FEATURES
• For surface mounted applications
• Low profile package
• Glass Passivated Chip Junction
• Easy to pick and place
• Lead free in comply with EU RoHS 2011/65/EU directives
DESCRIPTION
1
Cathode
2
Anode
2
1
Top View
MECHANICAL DATA
• Case: SMB
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 0.055g / 0.002oz
Marking Code: S3A~S3M
Simplified outline SMB and symbol
Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.
Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %.
Symbols
Parameter
S3AB
S3BB
S3DB
S3GB
S3JB
S3KB
S3MB
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
50
100
200
400
600
800
1000
V
Maximum RMS voltage
V RMS
35
70
140
280
420
560
700
V
Maximum DC Blocking Voltage
V DC
50
100
200
400
600
800
1000
V
Maximum Average Forward Rectified Current
I F(AV)
3
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
I FSM
90
A
Maximum Instantaneous Forward Voltage at 3 A
VF
1.1
V
IR
5
100
μA
Cj
35
pF
RθJA
RθJC
48
16
°C/W
T j , T stg
-55 ~ +150
°C
Maximum DC Reverse Current
T a = 25 °C
at Rated DC Blocking Voltage
T a =125 °C
Typical Junction Capacitance
Typical Thermal Resistance
(1)
(2)
Operating and Storage Temperature Range
(1)Measured at 1 MHz and applied reverse voltage of 4 V D.C
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
2017.01
SMB-A-S3AB~S3MB-3A1KV
Page 1 of 3
山东晶导微电子有限公司
S3AB THRU S3MB
Fig.2 Typical Instaneous Reverse
Characteristics
5.0
4.0
3.0
2.0
1.0
0.0
25
50
75
100
125
150
175
Instaneous Reverse Current ( μ A)
Average Forward Current (A)
Fig.1 Forward Current Derating Curve
100
T J =150°C
T J =125°C
10
T J =100°C
1.0
T J =75°C
0.1
T J =25°C
0.01
800
Fig.4 Typical Junction Capacitance
Fig.3 Typical Forward Characteristic
10
Junction Capacitance ( pF)
Instaneous Forward Current (A)
400
200
Instaneous Reverse Voltage (V)
Case Temperature (°C)
1.0
100
T J =25°C
10
T J =25°C
0.1
0.4
1
0.6
0.8
1.0
1.2
1.4
1.6
1.8
0.1
1.0
10
100
Reverse Voltage (V)
Instaneous Forward Voltage (V)
Peak Forward Surage Current (A)
Fig.5 Maximum Non-Repetitive Peak
100
80
60
40
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles
2017.01
www.sdjingdao.com
Page 2 of 3
山东晶导微电子有限公司
S3AB THRU S3MB
PACKAGE OUTLINE
SMB
Plastic surface mounted package; 2 leads
L
A
A1
C
A
b
D
E
E1
VM
A
SMB mechanical data
UNIT
mm
mil
A1
L
C
b
5.59
0.20
1.5
0.305
2.2
3.3
5.08
0.05
0.8
0.152
1.9
155
220
7.9
59
12
87
200
2.0
32
6
75
A
E
D
max
2.44
4.70
3.94
min
2.13
4.06
max
96
185
min
84
130
160
E1
The recommended mounting pad size
Marking
Type number
S3AB
2.2
(86)
2.4
(94)
2.8
(110)
2.4
(94)
mm
Unit :
(mil)
2017.01
JD702229B0
Marking code
S3A
S3BB
S3B
S3DB
S3D
S3GB
S3G
S3JB
S3J
S3KB
S3K
S3MB
S3M
Page 3 of 3
很抱歉,暂时无法提供与“S3BB”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.14101
- 100+0.13161
- 300+0.12221
- 500+0.11281
- 2000+0.10811
- 5000+0.10529
