DZL4728 thru DZL4764
Glass Passivated Zener
SOD-123FL
Features
For surface mounted applications in
order to optimize board space
Low profile space
Glass passivated chip
High reliability
For use in stabilizing and clipping
0.114(2.9)
0.098(2.5)
circuits with high power rating.
0.043(1.09)
0.035(0.89)
0.075(1.90)
0.067(1.70)
0.008(0.20)
0.004(0.10)
0.047(1.19)
0.043(1.09)
Component in accordance to
RoHS 2002/95/EC and WEEE 2002/96/EC
0.030(0.76)
0.018(0.45)
Mechanical Date
Case: JEDEC SOD-123FL molded plastic
over passivated chip
Terminals: Solder plated, solderable per
MIL-STD-750 Method 2026
Polarity: types the band by laser
0.154(3.9)
0.138(3.5)
Dimensions in inches and(millimeters)
denotes the cathode
Weight: 0.017gram
Applications
Voltage stabilization
Maximum Ratings & Thermal Characteristics
(TA = 25 °C unless otherwise noted)
power dissipation
Symbol
VALUE
UNIT
P
1.0
W
Typical thermal resistance, junction to ambient
RθJA
°C / W
Typical thermal resistance, junction to lead
RθJL
°C / W
Junction temperature
TJ
150
°C
storage temperature range
TSTG
–55 to +150
°C
ht t p : //
Revision:20170701-P1
www.lgesemi .c o m
mail:lge@lgesemi.com
Electrical Characteristics
TA =25℃ unless otherwise noted.
Zener Voltage
DEVICE
House No.
Leakage Current
Zener Impedance
VZ(Volts)
@IZT
ZZT@IZT
ZZK@IZK
IR@VR
Min
Nom
Max
mA
Ω
Ω
mA
uA
Volts
DZL4728
3.13
3.3
3.47
76
10
400
1.0
100
1.0
DZL4729
3.42
3.6
3.78
69
10
400
1.0
100
1.0
DZL4730
3.70
3.9
4.10
64
9
400
1.0
50
1.0
DZL4731
4.08
4.3
4.52
58
9
400
1.0
50
1.0
DZL4732
4.46
4.7
4.94
53
8
500
1.0
10
1.0
DZL4733
4.84
5.1
5.36
49
7
550
1.0
10
1.0
DZL4734
5.32
5.6
5.88
45
5
600
1.0
10
2.0
DZL4735
5.89
6.2
6.51
41
2
700
1.0
10
3.0
DZL4736
6.46
6.8
7.14
37
3.5
700
1.0
10
4.0
DZL4737
7.12
7.5
7.88
34
4
700
0.5
10
5.0
DZL4738
7.79
8.2
8.61
31
4.5
700
0.5
10
6.0
DZL4739
8.64
9.1
9.56
28
5
700
0.5
10
7.0
DZL4740
9.50
10
10.50
25
7
700
0.25
10
7.6
DZL4741
10.45
11
11.55
23
8
700
0.25
5
8.4
DZL4742
11.40
12
12.60
21
9
700
0.25
5
9.1
DZL4743
12.35
13
13.65
19
10
700
0.25
5
9.9
DZL4744
14.25
15
15.75
17
14
700
0.25
5
11.4
DZL4745
15.20
16
16.80
15.5
16
700
0.25
5
12.2
DZL4746
17.10
18
18.90
14
0.25
5
13.7
DZL4747
19.00
12.5
22
750
0.25
5
15.2
DZL4748
20.90
22
23.10
11.5
23
750
0.25
5
16.7
DZL4749
22.80
24
25.20
10.5
25
750
0.25
5
18.2
DZL4750
25.65
27
28.35
9.5
35
750
0.25
5
20.6
DZL4751
28.50
30
31.50
8.5
40
1000
0.25
5
22.8
DZL4752
31.35
33
34.65
7.5
45
1000
0.25
5
25.1
DZL4753
34.20
36
37.80
7
50
1000
0.25
5
27.4
DZL4754
37.05
39
40.95
6.5
60
1500
0.25
5
29.7
DZL4755
40.85
43
45.15
6
70
1500
0.25
5
32.7
DZL4756
44.65
47
49.35
5.5
80
1500
0.25
5
35.8
DZL4757
48.45
51
53.55
5
95
1500
0.25
5
38.8
DZL4758
53.20
56
58.80
4.5
110
2000
0.25
5
42.6
DZL4759
58.90
62
65.10
4
125
2000
0.25
5
47.1
DZL4760
64.60
68
71.40
3.7
150
2000
0.25
5
51.7
DZL4761
71.25
75
78.75
3.3
175
2000
0.25
5
56.0
DZL4762
77.90
82
86.10
3
200
3000
0.25
5
62.2
DZL4763
86.45
91
95.55
2.8
250
3000
0.25
5
69.2
DZL4764
95.00
100
105.00
2.5
350
3000
0.25
5
76.0
PACKAGE
SPQ/PCS
CARTON
SPQ/PCS
CARTON
SIZE/CM
CARTON
GW/KG
CARTON
NW/KG
SOD-123FL
3000/REEL
90000
40X20X22
5.00
4.00
ht t p : //
www.lgesemi .c o m
很抱歉,暂时无法提供与“DZL4740”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.22499
- 100+0.20999
- 300+0.19499
- 500+0.18000
- 2000+0.17250
- 5000+0.16800
