MURS220-MAURS260A
Surface Mount Rectifiers
VOLTAGE RANGE: 600 V
CURRENT: 2.0 A
SMA/DO-214AC
Features
Low cost
0. 181( 4. 60)
0. 161( 4. 10)
Low leakage
Low forward
voltage drop
current capability
Easily cleaned with Alcohol,Isopropanol
and similar solvents
The plastic material carries U/L recognition 94V-0
0. 108( 2. 75)
0. 096( 2. 45)
0. 063(1.60)
0. 051(1.30)
High
0. 209( 5. 30)
0. 193( 4. 90)
0. 012(0.30)
0. 006(0.15)
Mechanical Data
0.096(2.45)
0.078(2.00)
Case:JEDEC DO-214AA,molded
0. 059( 1. 50)
0. 035( 0. 90)
plastic
0.008(0.20)
0. 002(0.05)
Polarity:
Color band denotes cathode
0.003 ounces,0.093 grams
Mounting position: Any
Weight:
Dimensions in inches and(millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25 ambient temperature unless otherwise specified.
Single phase,half wave,60 Hz,resistive or inductive load. For capacitive load,derate by 20%.
MURS220A
MURS240A
MURS260A
UNITS
Maximum recurrent peak reverse voltage
VRRM
200
400
600
V
Maximum RMS voltage
V RMS
200
400
600
V
DC blocking voltage
VR
200
400
600
V
I F(AV)
2.0
2.0
2.0
A
IFSM
40
35
35
A
VF
0.95
1.4
1.3
V
2.0
5.0
5.0
Average rectified forward current
@TL=125
Non-repetitive peak surge current
(Surge applied at rated load conditions
halfwave,single phase,60Hz)
Maximum instantaneous forward
@TJ =25
voltage at 2.0 A (Note2)
Maximum reverse current
at rated DC blocking voltage
@TA=25
IR
Maximum reverse recovery time
A
150
@T A=125
t rr
(Note1)
R θJL
Thermal resistance,junction-to-lead
50
13.0
TJ
- 65 ---- + 175
TSTG
- 65 ---- + 175
Operating junction temperature range
Storage temperature range
25
50
ns
/W
NOTE: 1. Measured with I F =0.5A, I R =1A, I rr =0.25A.
2. Pulse Test: Pulse Width = 300µ s,Duty Cycle≤2.0%
ht t p : //
Revision:20170701-P1
www.lgesemi .c o m
mail:lge@lgesemi.com
MURS220A-MURS260A
Ratings AND Charactieristic Curves
10
TJ=25
Pulse Width=300uS
4
2
1.0
AMPERES
0.4
0.2
0.1
0.06
0.04
0.02
0.01
0.6
0.8
1.0
1.2
1.4
1.6
1.8
2.0
INSTANTANEOUS REVERSE LEAKAGE CURRENT
100
FIG.2 -- TYPICAL REVERSE LEAKAGE
CHARACTERISTICS
1000
100
O
TJ=125 C
10
O
TJ=75 C
1
TJ=25OC
0.1
0.01
60
80
100
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
FIG.3 -- PEAK FORWARD SURGE CURRENT
FIG.4 -- FORWARD DERATING CURVE
45
40
TJ =125
8.3ms Single Half
Sine-Wave
35
30
25
10
5
1
2
4
8 10
20 40
60 80 100
AVERAGE FORWARD CURRENT
AMPERES
INSTANTANEOUS FORWARD VOLTAGE,VOLTS
AMPERES
INSTANTANEOUS FORWARD CURRENT
FIG.1 -- TYPICAL FORWARD CHARACTERISTIC
2.4
2.0
1.6
1.2
0.8
Single Phase
Half Wave 60H Z
Resistive or
Inductive Load
0.4
50
ht t p : //
100
125
150
175
LEAD TEMPERATURE,
NUMBER OF CYCLES AT 60Hz
75
www.lgesemi .c o m
很抱歉,暂时无法提供与“MURS260A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.18750
- 100+0.17500
- 300+0.16250
- 500+0.15000
- 2000+0.14375
- 5000+0.14000
