SD2401P4-3
1-Line High Power TVS Diode
Features
4000W peak pulse power (8/20µs)
Low leakage: nA level
Low operating voltage: 24V
Ultra low clamping voltage
One power line protects
Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±30kV
Contact discharge: ±30kV
– IEC61000-4-4 (EFT) 80A (5/50ns)
Dimensions DFN2020-3
– IEC61000-4-5 (Lightning) 140A (8/20μs)
Pin Configuration
RoHS Compliant
Applications
Power Management
Industrial Application
Power Supply Protection
3
1, 2
Mechanical Characteristics
Package: DFN2020-3
Lead Finish: NiPdAu
Case Material: “Green” Molding Compound
UL Flammability Classification Rating 94V-0
Moisture Sensitivity: Level 3 per J-STD-020
Terminal Connections: See Diagram Below
Marking Information: See Below
Absolute Maximum Ratings(Tamb=25°C unless otherwise specified)
Parameter
Peak Pulse Power (8/20µs)
ESD per IEC 61000−4−2 (Air)
Symbol
Ppp
Value
7000
Unit
W
±30
VESD
Kv
±30
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
TJ
-55 to +125
Storage Temperature Range
TSTJ
-55 to +150
Rev : 01.06.2014
1/4
www.leiditech.com
SD2401P4-3
Electrical Characteristics(TA=25°C unless otherwise specified)
Vc
Part Number
SD2401P4-3
Rev : 01.06.2014
Device
Marking
VRWM
(V)
23P
24
VBR
(V)
24.8
IT
(mA)
VC
@50A
1
32
2/4
(Max)
50
(@A)
140
IR
μA
(Max)
C
(Pf)
(Typ.)
10
1500
www.leiditech.com
SD2401P4-3
Typical Performance Characteristics (T A=25°C unless otherwise Specified)
Peak Pulse Power vs. Pulse Time
Junction Capacitance vs. Reverse Voltage
Power Derating Curve
Clamping Voltage vs. Peak Pulse Current
ESD Clamping Voltage
8 X 20μs Pulse Waveform
Rev : 01.06.2014
8 kV Contact per IEC61000−4−2
3/4
www.leiditech.com
SD2401P4-3
DFN2020-3 Package Outline Drawing
Suggested Land Pattern
Shanghai Leiditech Electronic Co.,Ltd
Email: sale1@leiditech.com
Tel : +86- 021 50828806
Fax : +86- 021 50477059
Rev : 01.06.2014
4/4
www.leiditech.com
很抱歉,暂时无法提供与“SD2401P4-3”相匹配的价格&库存,您可以联系我们找货
