Important notice
Dear Customer,
On 7 February 2017 the former NXP Standard Product business became a new company with the
tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS
semiconductors with its focus on the automotive, industrial, computing, consumer and wearable
application markets
In data sheets and application notes which still contain NXP or Philips Semiconductors references, use
the references to Nexperia, as shown below.
Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/,
use http://www.nexperia.com
Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use
salesaddresses@nexperia.com (email)
Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on
the version, as shown below:
- © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights
reserved
Should be replaced with:
- © Nexperia B.V. (year). All rights reserved.
If you have any questions related to the data sheet, please contact our nearest sales office via e-mail
or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and
understanding,
Kind regards,
Team Nexperia
PBLS2003D
20 V PNP BISS loadswitch
Rev. 02 — 27 August 2009
Product data sheet
1. Product profile
1.1 General description
PNP low VCEsat Breakthrough in Small Signal (BISS) transistor and NPN ResistorEquipped Transistor (RET) in a SOT457 (SC-74) small Surface Mounted Device (SMD)
plastic package.
1.2 Features
n
n
n
n
n
Low VCEsat (BISS) and resistor-equipped transistor in one package
Low threshold voltage (< 1 V) compared to MOSFET
Low drive power required
Space-saving solution
Reduction of component count
1.3 Applications
n
n
n
n
Supply line switches
Battery charger switches
High-side switches for LEDs, drivers and backlights
Portable equipment
1.4 Quick reference data
Table 1.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
TR1; PNP low VCEsat transistor
VCEO
collector-emitter voltage
IC
collector current (DC)
RCEsat
collector-emitter saturation
resistance
open base
IC = −1 A;
IB = −100 mA
[1]
−20
V
−1
A
185
280
mΩ
50
V
TR2; NPN resistor-equipped transistor
VCEO
IO
output current
100
mA
R1
bias resistor 1 (input)
7
10
13
kΩ
R2/R1
bias resistor ratio
0.8
1
1.2
[1]
Pulse test: tp ≤ 300 µs; δ ≤ 0.02
open base
PBLS2003D
NXP Semiconductors
2. Pinning information
Table 2.
Pinning
Pin
Description
Simplified outline
1
emitter TR1
2
base TR1
3
output (collector) TR2
4
GND (emitter) TR2
5
input (base) TR2
6
collector TR1
6
5
4
1
2
3
Symbol
6
5
R1
4
R2
TR2
TR1
1
2
3
sym036
3. Ordering information
Table 3.
Type number
PBLS2003D
Package
Name
Description
Version
SC-74
plastic surface mounted package; 6 leads
SOT457
4. Marking
Table 4.
Marking codes
Type number
Marking code
PBLS2003D
F8
5. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
open emitter
−20
V
VCBO
collector-base voltage
VCEO
open base
−20
V
VEBO
emitter-base voltage
open collector
−5
V
IC
−1
A
ICM
peak collector current
−2
A
IB
base current (DC)
−0.3
A
IBM
peak base current
tp ≤ 300 µs
−0.6
A
total power dissipation
Tamb ≤ 25 °C
[1]
250
mW
[2]
350
mW
[3]
400
mW
Ptot
tp ≤ 300 µs
PBLS2003D_2
Product data sheet
© NXP B.V. 2009. All rights reserved.
2 of 16
PBLS2003D
NXP Semiconductors
Table 5.
Limiting values …continued
Symbol
Parameter
Conditions
Min
Max
Unit
50
V
VCBO
open emitter
VCEO
open base
50
V
VEBO
open collector
10
V
VI
input voltage
positive
+40
V
negative
−10
V
IO
output current
100
mA
ICM
tp ≤ 300 µs
Tamb ≤ 25 °C
Ptot
100
mA
[1]
200
mW
[1]
400
mW
[2]
530
mW
[3]
600
mW
Per device
Ptot
Tstg
storage temperature
−65
+150
°C
Tj
junction temperature
150
°C
Tamb
ambient temperature
−65
+150
°C
[1]
Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard
footprint.
[2]
Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for collector 1cm2.
[3]
Device mounted on a ceramic PCB, Al2O3, standard footprint.
006aaa414
0.8
Ptot
(W)
(1)
0.6
(2)
(3)
0.4
0.2
80
120
160
Tamb (°C)
(1) Ceramic PCB, Al2O3, standard footprint
(2) FR4 PCB, mounting pad for collector 1cm2
(3) FR4 PCB, standard footprint
Fig 1.
Power derating curves
PBLS2003D_2
Product data sheet
3 of 16
PBLS2003D
NXP Semiconductors
6. Thermal characteristics
Table 6.
Symbol
Parameter
Conditions
thermal resistance from
junction to ambient
in free air
Min
Typ
Max
Unit
[1]
315
K/W
[2]
236
K/W
[3]
210
K/W
Per device
Rth(j-a)
[1]
Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint.
[2]
[3]
006aaa415
103
duty cycle =
1
Zth(j-a)
0.75
(K/W)
0.5
0.33
102 0.2
0.1
0.05
10
1
0.02
0.01
10−1
10−5
10−4
10−3
10−2
10−1
1
10
102
103
t p (s)
Fig 2.
TR1 (PNP): Transient thermal impedance from junction to ambient as a function of pulse time; typical
values
PBLS2003D_2
Product data sheet
4 of 16
PBLS2003D
NXP Semiconductors
006aaa463
103
Zth(j-a)
(K/W)
δ=1
0.75
0.5
0.33
0.2
102
0.1
0.05
10
0.02
0.01
10−5
10−4
10−3
10−2
10−1
1
10
102
103
tp (s)
Fig 3.
values
006aaa464
103
Zth(j-a)
(K/W) δ = 1
0.75
0.5
2
10
0.33
0.2
0.1
0.05
10
0.02
0.01
10−5
10−4
10−3
10−2
10−1
1
10
102
103
tp (s)
Fig 4.
values
PBLS2003D_2
Product data sheet
5 of 16
PBLS2003D
NXP Semiconductors
7. Characteristics
Table 7.
Characteristics
Tamb = 25 °C unless otherwise specified
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VCB = −20 V; IE = 0 A
−0.1
µA
VCB = −20 V; IE = 0 A;
Tj = 150 °C
−50
µA
ICBO
collector-base cut-off
current
ICES
collector-emitter
cut-off current
VCE = −20 V; VBE = 0 V
−0.1
µA
IEBO
emitter-base cut-off
current
VEB = −5 V; IC = 0 A
−0.1
µA
hFE
DC current gain
VCE = −2 V; IC = −1 mA
220
495
VCE = −2 V; IC = −100 mA
VCEsat
collector-emitter
saturation voltage
220
440
VCE = −2 V; IC = −500 mA
[1]
220
310
VCE = −2 V; IC = −1 A
[1]
155
220
VCE = −2 V; IC = −2 A
[1]
60
120
IC = −100 mA; IB = −1 mA
−55
−90
mV
IC = −500 mA; IB = −50 mA
[1]
−100
−150
mV
IC = −1 A; IB = −50 mA
[1]
−200
−300
mV
IC = −1 A; IB = −100 mA
[1]
−185
−280
mV
185
280
mΩ
RCEsat
collector-emitter
saturation resistance
[1]
VBEsat
base-emitter
saturation voltage
[1]
−0.95
−1.1
V
[1]
−1
−1.1
V
VBEon
base-emitter
turn-on voltage
VCE = −5 V; IC = −1 A
[1]
−0.85
−1.1
V
td
delay time
8
ns
tr
rise time
IC = −1 A; IBon = −50 mA;
IBoff = 50 mA
34
ns
ton
turn-on time
42
ns
ts
storage time
140
ns
tf
fall time
45
ns
toff
turn-off time
185
ns
fT
transition frequency
IC = −50 mA; VCE = −10 V;
f = 100 MHz
150
185
MHz
Cc
collector capacitance
VCB = −10 V; IE = ie = 0 A;
f = 1 MHz
15
pF
PBLS2003D_2
Product data sheet
6 of 16
PBLS2003D
NXP Semiconductors
Table 7.
Characteristics …continued
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
ICBO
current
VCB = 50 V; IE = 0 A
100
nA
ICEO
collector-emitter
cut-off current
VCE = 30 V; IB = 0 A
1
µA
VCE = 30 V; IB = 0 A;
Tj = 150 °C
50
µA
µA
IEBO
current
VEB = 5 V; IC = 0 A
400
hFE
DC current gain
VCE = 5 V; IC = 5 mA
30
VCEsat
collector-emitter
saturation voltage
IC = 10 mA; IB = 0.5 mA
150
mV
VI(off)
off-state input voltage VCE = 5 V; IC = 100 µA
1.1
0.8
V
VI(on)
on-state input voltage VCE = 0.3 V; IC = 10 mA
2.5
1.8
V
R1
7
10
13
kΩ
R2/R1
bias resistor ratio
Cc
[1]
VCB = 10 V; IE = ie = 0 A;
f = 1 MHz
1
1.2
2.5
pF
PBLS2003D_2
Product data sheet
0.8
7 of 16
PBLS2003D
NXP Semiconductors
006aaa416
1000
hFE
006aaa417
−1
VCEsat
(V)
800
(1)
−10−1
600
(1)
(2)
(3)
(2)
400
−10−2
(3)
200
−10−1
−1
−10
−102
−103
−104
IC (mA)
−10−3
−10−1
VCE = −2 V
−1
−102
−103
−104
IC (mA)
IC/IB = 20
(1) Tamb = 100 °C
(1) Tamb = 100 °C
(2) Tamb = 25 °C
(2) Tamb = 25 °C
(3) Tamb = −55 °C
(3) Tamb = −55 °C
Fig 5.
−10
TR1 (PNP): DC current gain as a function of
collector current; typical values
006aaa418
−1.0
Fig 6.
TR1 (PNP): Collector-emitter saturation
voltage as a function of collector current;
typical values
006aaa419
−1.2
VBEsat
(V)
VBE
(V)
−0.8
(1)
−1.0
(2)
−0.8
(1)
(2)
−0.6
−0.6
(3)
−0.4
(3)
−0.4
−0.2
−10−1
−1
−10
−102
−103
−104
IC (mA)
−0.2
−10−1
VCE = −5 V
−1
(1) Tamb = −55 °C
(2) Tamb = 25 °C
(2) Tamb = 25 °C
(3) Tamb = 100 °C
(3) Tamb = 100 °C
TR1 (PNP): Base-emitter voltage as a function
of collector current; typical values
Fig 8.
−103
−104
IC (mA)
TR1 (PNP): Base-emitter saturation voltage as
a function of collector current; typical values
PBLS2003D_2
Product data sheet
−102
IC/IB = 20
(1) Tamb = −55 °C
Fig 7.
−10
8 of 16
PBLS2003D
NXP Semiconductors
006aaa420
−2.0
−11.7 mA
−10.4 mA
−9.1 mA
−7.8 mA
IB = −13 mA
IC
(A)
−1.6
006aaa421
102
RCEsat
(Ω)
−6.5 mA
−5.2 mA
−1.2
10
−3.9 mA
−2.6 mA
−0.8
1
(1)
(2)
(3)
−1.3 mA
−0.4
−0
−0
−2
−4
−6
10−1
−10−1
−1
−10
−102
VCE (V)
Tamb = 25 °C
−103
−104
IC (mA)
IC/IB = 20
(1) Tamb = 100 °C
(2) Tamb = 25 °C
(3) Tamb = −55 °C
Fig 9.
TR1 (PNP): Collector current as a function of
collector-emitter voltage; typical values
006aaa422
−1
Fig 10. TR1 (PNP): Collector-emitter saturation
resistance as a function of collector current;
typical values
006aaa423
103
RCEsat
(Ω)
VCEsat
(V)
102
−10−1
10
(1)
(2)
−10−2
1
(3)
(1)
(2)
(3)
−10−3
−10−1
−1
−10
−102
−103
−104
IC (mA)
Tamb = 25 °C
10−1
−10−1
−1
−102
−103
−104
IC (mA)
Tamb = 25 °C
(1) IC/IB = 100
(1) IC/IB = 100
(2) IC/IB = 50
(2) IC/IB = 50
(3) IC/IB = 10
(3) IC/IB = 10
Fig 11. TR1 (PNP): Collector-emitter saturation
typical values
Fig 12. TR1 (PNP): Collector-emitter saturation
typical values
PBLS2003D_2
Product data sheet
−10
9 of 16
PBLS2003D
NXP Semiconductors
006aaa034
103
(1)
(2)
(3)
hFE
006aaa035
1
VCEsat
(V)
102
(1)
(2)
(3)
10−1
10
1
10−1
1
102
10
10−2
1
IC (mA)
VCE = 5 V
IC/IB = 20
(1) Tamb = 150 °C
(1) Tamb = 100 °C
(2) Tamb = 25 °C
(2) Tamb = 25 °C
(3) Tamb = −40 °C
(3) Tamb = −40 °C
Fig 13. TR2 (NPN): DC current gain as a function of
006aaa036
10
102
10
IC (mA)
Fig 14. TR2 (NPN): Collector-emitter saturation
typical values
006aaa037
10
VI(off)
(V)
VI(on)
(V)
(1)
(2)
(1)
(3)
1
(2)
1
(3)
10−1
10−1
1
102
10
10−1
10−2
10−1
IC (mA)
10
IC (mA)
VCE = 0.3 V
VCE = 5 V
(1) Tamb = −40 °C
(1) Tamb = −40 °C
(2) Tamb = 25 °C
(2) Tamb = 25 °C
(3) Tamb = 100 °C
(3) Tamb = 100 °C
Fig 15. TR2 (NPN): On-state input voltage as a
Fig 16. TR2 (NPN): Off-state input voltage as a
PBLS2003D_2
Product data sheet
1
10 of 16
PBLS2003D
NXP Semiconductors
8. Test information
− IB
input pulse
(idealized waveform)
90 %
− I Bon (100 %)
10 %
− I Boff
output pulse
− IC
90 %
− I C (100 %)
10 %
t
td
ts
tr
t on
tf
t off
006aaa266
Fig 17. BISS transistor switching time definition
VBB
RB
VCC
RC
Vo
(probe)
oscilloscope
450 Ω
(probe)
450 Ω
oscilloscope
R2
VI
DUT
R1
mgd624
IC = −1 A; IBon = −50 mA; IBoff = 50 mA; R1 = open; R2 = 45 Ω; RB = 145 Ω; RC = 10 Ω
Fig 18. Test circuit for switching times
PBLS2003D_2
Product data sheet
11 of 16
PBLS2003D
NXP Semiconductors
9. Package outline
3.1
2.7
6
3.0
2.5
1.7
1.3
1.1
0.9
5
4
2
3
0.6
0.2
pin 1 index
1
0.40
0.25
0.95
0.26
0.10
1.9
Dimensions in mm
04-11-08
Fig 19. Package outline SOT457 (SC-74)
10. Packing information
Table 8.
Packing methods
The indicated -xxx are the last three digits of the 12NC ordering code.[1]
Type number
PBLS2003D
Package
SOT457
Description
3000
10000
4 mm pitch, 8 mm tape and reel; T1
[2]
-115
-135
4 mm pitch, 8 mm tape and reel; T2
[3]
-125
-165
[1]
For further information and the availability of packing methods, see Section 14.
[2]
T1: normal taping
[3]
T2: reverse taping
PBLS2003D_2
Product data sheet
Packing quantity
12 of 16
PBLS2003D
NXP Semiconductors
11. Soldering
3.45
1.95
solder lands
0.95
solder resist
0.45 0.55
3.30 2.825
occupied area
solder paste
1.60
1.70
3.10
3.20
msc422
Dimensions in mm
Fig 20. Reflow soldering footprint
5.30
solder lands
5.05
0.45 1.45 4.45
solder resist
occupied area
1.40
msc423
4.30
Dimensions in mm
Fig 21. Wave soldering footprint
PBLS2003D_2
Product data sheet
13 of 16
PBLS2003D
NXP Semiconductors
12. Revision history
Table 9.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
PBLS2003D_2
20090827
Product data sheet
PBLS2003D_1
Modifications:
PBLS2003D_1
This data sheet was changed to reflect the new company name NXP Semiconductors,
including new legal definitions and disclaimers. No changes were made to the technical
content.
Figure 21 “Wave soldering footprint”: updated
20050624
Product data sheet
PBLS2003D_2
Product data sheet
14 of 16
PBLS2003D
NXP Semiconductors
13. Legal information
13.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nxp.com.
13.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. NXP Semiconductors does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local NXP Semiconductors sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
13.3 Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, NXP Semiconductors does not give any representations or
warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such
information.
Right to make changes — NXP Semiconductors reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — NXP Semiconductors products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of an NXP Semiconductors product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. NXP Semiconductors accepts no liability for inclusion and/or use of
NXP Semiconductors products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. NXP Semiconductors makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — NXP Semiconductors products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.nxp.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by NXP Semiconductors. In case of
any inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from national authorities.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
13.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
14. Contact information
For more information, please visit: http://www.nxp.com
For sales office addresses, please send an email to: salesaddresses@nxp.com
PBLS2003D_2
Product data sheet
15 of 16
PBLS2003D
NXP Semiconductors
15. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
9
10
11
12
13
13.1
13.2
13.3
13.4
14
15
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1
General description. . . . . . . . . . . . . . . . . . . . . . 1
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Quick reference data. . . . . . . . . . . . . . . . . . . . . 1
Pinning information . . . . . . . . . . . . . . . . . . . . . . 2
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2
Thermal characteristics. . . . . . . . . . . . . . . . . . . 4
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 6
Test information . . . . . . . . . . . . . . . . . . . . . . . . 11
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 12
Packing information. . . . . . . . . . . . . . . . . . . . . 12
Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 14
Legal information. . . . . . . . . . . . . . . . . . . . . . . 15
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 15
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 15
Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 15
Contact information. . . . . . . . . . . . . . . . . . . . . 15
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section ‘Legal information’.
© NXP B.V. 2009.
Date of release: 27 August 2009
Document identifier: PBLS2003D_2
