NJM4580C
DUAL OPERATIONAL AMPLIFIER
■ GENERAL DESCRIPTION
NJM4580C is the dual operational amplifier, specially designed
for improving the tone control, which is suitable for the audio
application.
Featuring noiseless, higher gain bandwidth, high output current
and low distortion ratio, and it is most suitable not only for acoustic
electronic parts of audio pre-amp and active filter, but also for the
industrial measurement tools. It is also suitable for the head phone
amp at higher output current, and further more, it can be applied
for the handy type set operational amplifier of general purpose in
application of low voltage single supply type which is properly
biased of the low voltage source.
■ PACKAGE OUTLINE
■ FEATURES
● Operating Voltage
±2V to ±18V
● Low Input Noise Voltage 5nV/√ Hz typ. at f=1kHz
● Gain Bandwidth Product 15MHz typ.
● Low Distortion
0.0005 typ.
● Slew Rate
5V/μs typ.
● Bipolar Technology
● Package Outline
SOP8, SSOP8
● Internal ESD protection
Human body model (HBM) ±2000V typ.
■ PIN CONFIGURATION
NJM4580CV
(SSOP8)
NJM4580CG
(SOP8)
(Top View)
1
2
3
8
7
A
B
4
6
5
PIN FUNCTION
1.A OUTPUT
2.A -INPUT
3.A +INPUT
4.V
5.B +INPUT
6.B -INPUT
7.B OUTPUT
8.V
NJM4580CG
NJM4580CV
■ EQUIVALENT CIRCUIT ( 1/2 Shown )
V
-INPUT
+INPUT
OUTPUT
V
ver. 04
-1-
NJM4580C
■ABSOLUTE MAXIMUM RATINGS (Ta=25ºC, unless otherwise noted.)
PARAMETER
RATING
UNIT
V /V
±18
V
Differential Input Voltage (Note1) (Note2)
VID
±36
V
Input Voltage (Note2)
VIC
±18
V
Power Dissipation
PD
SOP : 550 (Note3)
SSOP : 350 (Note3)
Supply Voltage
SYMBOL
820(Note4)
440(Note4)
mW
Operating Temperature Range
Topr
- 40~+85
ºC
Storage Temperature Range
Tstg
- 65~+125
ºC
(Note1) Differential voltage is the voltage difference between +INPUT and -INPUT.
(Note2) For supply voltage less than ±15V, the absolute maximum rating is equal to the supply voltage.
The normal operation will establish when any input is within the Common Mode Input Voltage Range of electrical characteristics.
( Note3) EIA/JEDEC STANDARD Test board (76.2 x 114.3 x 1.6mm, 2layers, FR-4) mounting
( Note4) EIA/JEDEC STANDARD Test board (76.2 x 114.3 x 1.6mm, 4layers, FR-4) mounting
■ RECOMMENDED OPERATING CONDITIONS (Ta=25ºC)
PARAMETER
Supply Voltage
SYMBOL
CONDITION
MIN.
TYP.
MAX.
UNIT
±2
±18
V
MIN.
TYP.
MAX.
UNIT
0.3
3
mV
V /V
■ ELECTRICAL CHARACTERISTICS (V+/V =±15V, Ta=25ºC, unless otherwise noted.)
PARAMETER
SYMBOL
TEST CONDITION
Input Offset Voltage
VIO
RS≤10kΩ
Input Offset Current
IIO
5
200
nA
Input Bias Current
IB
100
500
nA
Input Resistance
RIN
0.5
MΩ
Large Signal Voltage Gain
AV
RL≥2kΩ, VO=±10V
90
110
dB
Maximum Output Voltage
VOM
RL≥2kΩ
±12
±13.5
V
VICM
±12
±13.5
V
Common Mode Rejection Ratio
CMR
RS≤10kΩ
80
110
dB
Supply Voltage Rejection Ratio
SVR
RS≤10kΩ
80
110
dB
6
9
mA
Supply Current
ICC
Slew Rate
SR
RL≥2kΩ
5
V/μs
GBP
f=10kHz
15
MHz
Total Harmonic Distortion
THD
AV=20dB, VO=5V, RL=2kΩ,f=1kHz
0.0005
Equivalent Input Noise Voltage1
VNI
RIAA, RS=2.2kΩ, 30kHz LPF
0.8
μVrms
Equivalent Input Noise Voltage2
en
f=1kHz
5
nV/√ Hz
-2-
ver. 04
NJM4580C
■ TYPICAL CHARACTERISTICS
Gain/Phase vs. Frequency
50
50
Gain
40
40
Ta=25ºC
Ta=85ºC
10
-60
Ta=-40ºC
-10
-90
Ta=25ºC
-20
Voltage Gain [dB]
Ta=85ºC
-30
-40
10k
100k
1M
Frequency [Hz]
10M
100M
-40
10k
Ta=85ºC
-5
Ta=25ºC
-150
100k
1M
10M
Frequency [Hz]
-180
100M
Maximum Output Voltage vs. Load Resistance
Maximum Output Voltage [V]
Ta=85ºC
CL=10pF
CL=680pF
V /V =±15V, Gv=open
Ta=-40ºC
5
-90
-120
CL=330pF
Ta=25ºC
-60
CL=100pF
15
+VOM
CL=100pF
10
-10
-30
CL=680pF
-30
V /V =±15V
15
CL=330pF
10
Maximum Output Voltage vs. Output Current
Phase
-20
-150
1k
Gain
30
Ta=-40ºC
Phase
Phase [deg]
Voltage Gain [dB]
30
V /V =±15V, Gv=40dB, RL=2kΩ, Ta=25ºC
Phase [deg]
V /V =±15V, Gv=40dB, RL=2kΩ, CL=10pF
-VOM
+VOM
10
Ta=85ºC
5
Ta=25ºC
Ta=-40ºC
Ta=-40ºC
-5
Ta=25ºC
Ta=85ºC
-10
-VOM
-VOM
Ta=-40ºC
-15
-15
1
10
Output Current [mA]
100
100
THD+N vs. Output Voltage
1
0.01
THD+N [%]
THD+N [%]
100k
V /V =±15V, GV=20dB, RL=2kΩ, Ta=25ºC
0.1
1k
10k
Load Resistance[Ω]
f=20kHz
0.1
V /V =±2V, GV=20dB, RL=2kΩ, Ta=25°C
f=20Hz
f=1kHz
f=20kHz
0.001
f=1kHz
f=20Hz
0.0001
0.1
ver. 04
1
Output Voltage [Vrms]
10
0.01
0.01
0.1
1
-3-
NJM4580C
Maximum Output Voltage Swing vs. Frequency
25
10
5
V /V =±15V, GV=40dB, RF=2kΩ
30
[nV/Hz]
30
VOPP [Vpp]
Voltage Noise vs. Frequency
V /V =±15V, RL=2kΩ, Ta=25ºC
25
10
5
1k
10k
100k
Frequency[Hz]
1M
10M
1
Supply Current vs. Supply Voltage
10
100
1k
Frequency [Hz]
RL=open
8
8
Ta=25ºC
6
7
Ta=-40ºC
Supply Current [mA]
Supply Current [mA]
7
5
4
3
Ta=85ºC
2
1
V /V =±18V
6
V /V =±15V
5
4
V /V =±2V
3
2
1
±2
±4 ±6 ±8 ±10 ±12 ±14 ±16 ±18
+ Supply Voltage V /V [V]
-50
Input Offset Voltage vs. Temperature
2
V /V =±2V
V /V =±15V
1
V /V =±18V
-1
-2
-25
25 50 75 100 125 150
Ambient Temperature [ºC]
Input Offset Voltage vs. Supply Voltage
3
Input Offset Voltage [mV]
3
100k
Supply Current vs. Temperature
RL=open
2
Ta=25ºC
Ta=-40ºC
1
Ta=85ºC
-1
-2
-50
-4-
10k
-25
±2
ver. 04
NJM4580C
vs. Common-Mode Input Voltage
V /V =±15V
2
Ta=-40ºC
Ta=85ºC
1
Ta=25ºC
-1
-2
-15
-10
-5
10
Common-Mode Input Voltage [V]
2
Ta=25ºC
V /V =±2V
200
150
100
V /V =±18V
50
Large Signal Voltage Gain [dB]
Input Bias Current [nA]
300
110
105
100
95
90
85
-25
-50
-25
CMR vs. Temperature
110
105
100
95
90
85
80
V /V =±9V±18V
120
Supply Voltage Rejection Ratio [dB]
115
SVR vs. Temperature
V /V =±15V, VCM=-12.2V~12.2V
120
Common-Mode Rejection Ratio [dB]
V /V =±15V, RL=2kΩ to GND
80
-50
115
110
105
100
95
90
85
80
-50
ver. 04
2.0
Large Signal Voltage Gainvs. Temperature
120
350
V /V =±15V
Ta=-40ºC
-2
-2.0 -1.5 -1.0 -0.5 0
0.5 1.0 1.5
15
VICM=0V
250
Ta=85ºC
1
Input Bias Current vs. Temperature
400
V /V=-±2V
3
3
-25
-50
-25
-5-
NJM4580C
Maximum Output Voltage vs. Temperature
15
12
+VOM
V /V =±18V
V /V =±15V
9
6
V /V =±2V
3
V /V =±2V
-6
-9
V /V =±15V
V /V =±18V
-VOM
-12
RL=2kΩ to GND
18
18
Maximum Output Voltage vs. Supply Voltage
Gv=open, RL=2kΩ, RL to GND
12
6
Ta=25ºC Ta=-40ºC
Ta=85ºC
-6
-12
-15
-18
-18
-50
-25
±2
±4
Pulse Response
Voltage [0.5V/div]
Vin
CL=10pF
CL=330pF
CL=680pF
Time [1μs/div]
-6-
ver. 04
NJM4580C
■PACKAGE OUTLINE UNIT : mm
SOP8
6.0±0.2
3.9±0.1
4.9±0.1
0.175±0.075
0.1 S
0.42±0.07
0.25 M
0.22±0.03
1.55±0.2
1.27
0.825±0.425 0°~ 7°
S
SSOP8
+0.3
3.50 - 0.1
0 ~ 10º
0.5±0.2
4.4±0.2
6.4±0.3
5
8
1
4
0.65
+0.1
0.15 - 0.05
0.1±0.1
1.15±0.1
0.9MAX
0.1
0.22±0.1
ver. 04
0.1
M
[CAUTION]
The specifications on this databook are only
given for information , without any guarantee
as regards either mistakes or omissions. The
application circuits in this databook are
described only to show representative usages
of the product and not intended for the
guarantee or permission of any right including
the industrial rights.
-7-
