NJM4580E
NJM4580E
    NISSHINBO(日清纺)
    SOP-8
    音频 放大器 2 电路 8-SOP
NJM4580E 数据手册
NJM4580 DUAL OPERATIONAL AMPLIFIER ■ GENERAL DESCRIPTION NJM4580 is the dual operational amplifier, specially designed for improving the tone control, which is most suitable for the audio application. Featuring noiseless, higher gain bandwidth, high output current and low distortion ratio, and it is most suitable not only for acoustic electronic parts of audio pre-amp and active filter, but also for the industrial measurement tools. It is also suitable for the head phone amp at higher output current, and further more, it can be applied for the handy type set operational amplifier of general purpose in application of low voltage single supply type which is properly biased of the low voltage source. ■ FEATURES ● Operating Voltage ● Low Input Noise Voltage ● Wide Gain Bandwidth Product ● Low Distortion ● Slew Rate ● Package Outline ● Bipolar Technology ■ PACKAGE OUTLINE NJM4580D NJM4580L NJM4580E NJM4580V NJM4580M ( ±2V~±18V ) ( 0.8µVrms typ. ) ( 15MHz typ. ) ( 0.0005% typ. ) ( 5V/µs typ. ) DIP8,SIP8,EMP8,SSOP8,DMP8 ■ PIN CONFIGURATION NJM4580D,NJM4580E NJM4580M,NJM4580V NJM4580L PIN FUNCTION 1.A OUTPUT 2.A –INPUT 3.A +INPUT 4.V 5.B +INPUT 6.B –INPUT 7.B OUTPUT + 8.V ■ EQUIVALENT CIRCUIT ( 1/2 Shown ) Ver.2003-03-18 -1- NJM4580 ■ ABSOLUTE MAXIMUM RATINGS ( Ta=25˚C ) PARAMETER Supply Voltage Input Voltage Differential Input Voltage Output Current SYMBOL + V /V VIC VID IO Power Dissipation PD Operating Temperature Range Storage Temperature Range Topr Tstg RATINGS ± 18 ± 15 ( note ) ± 30 ( note ) ± 50 ( DIP8 ) 800 ( SIP8 ) 800 ( DMP8 ) 300 ( EMP8 ) 300 ( SSOP8 ) 250 -40~+85 -40~+125 UNIT V V V mA mW ˚C ˚C ■ ELECTRICAL CHARACTERISTICS ( Ta=25˚C,V+/V-=±15V ) PARAMETER Input Offset Voltage Input Offset Current Input Bias Current Large Signal Voltage Gain Output Voltage Swing Input Common Mode Voltage Range Common Mode Rejection Ratio Supply Voltage Rejection Ratio Operating Current Slew Rate Gain Bandwidth Product Total Harmonic Distortion Input Noise Voltage -2- SYMBOL VIO IIO IB AV VOM VICM CMR SVR ICC SR GB THD VNI TEST CONDITION RS≤10kΩ RL≥2kΩ,VO=±10V RL≥2kΩ RS≤10kΩ RS≤10kΩ RL≥2kΩ f=10kHz AV=20dB,VO=5V,RL=2kΩ,f=1kHz RIAA,RS=2.2kΩ,30kHz LPF MIN. 90 ± 12 ± 12 80 80 - TYP. 0.5 5 100 110 ± 13.5 ± 13.5 110 110 6 5 15 0.0005 0.8 MAX. 3 200 500 9 - UNIT mV nA nA dB V V dB dB mA V/µs MHz % µVrms Ver.2003-03-18 NJM4580 ■ TYPICAL CHARACTERISTICS Ver.2003-03-18 -3- NJM4580 ■ TYPICAL CHARACTERISTICS [CAUTION] The specifications on this databook are only given for information , without any guarantee as regards either mistakes or omissions. The application circuits in this databook are described only to show representative usages of the product and not intended for the guarantee or permission of any right including the industrial rights. -4- Ver.2003-03-18
NJM4580E 价格&库存
很抱歉,暂时无法提供与“NJM4580E”相匹配的价格&库存,您可以联系我们找货
