Technical Data 4122
Effective February 2017
Supersedes October 2015
HC3
High current power inductors
Applications
Distributed power systems DC-DC converters
General-purpose low voltage supplies
Computer systems
Servers
Point of Load (POL) converters
Industrial Equipment
Environmental data
Storage temperature range (component):
-40°C to +125°C
Operating temperature range: -40°C to +125°C
(ambient plus self-temperature rise)
Solder reflow temperature: J-STD-020D compliant.
Product description
Compact footprint
Designed for high density, high current/low
voltage applications
Foil technology that adds higher reliability factor
over the traditional magnet wire used for higher
frequency circuit designs
Inductance range from 0.50uH to 6.52uH
Current range from 30 to 120 Amps
Ferrite core material
Packaging
Supplied in bulk packaging, 24 parts per tray
Pb
HC3
Technical Data 4122
Product specifications
Part number5
OCL1 (μH) ±20%
lrms2 (amps)
lsat3 (amps)
DCR (mΩ) maximum @ 20°C
Volt-μsec4 (V-μs) ref.
HC3-R50-R
0.50
78.00
120
0.42
17.33
HC3-1R0-R
1.05
78.00
78
0.42
17.33
HC3-2R2-R
2.05
55.50
60
0.70
26.01
HC3-3R3-R
3.63
42.45
46
1.20
34.65
HC3-4R7-R
4.98
33.80
38
2.17
43.30
HC3-5R6-R
5.68
33.80
34.5
2.17
43.30
HC3-6R0-R
6.52
33.80
30.0
2.17
43.30
3. Peak current for approximately 30% rolloff (@20°C).
4. Applied Volt-Time product (V-μs) across the inductor. This value represents the applied V-μs at 300kHz
necessary to generate a core loss equal to 10% of the total losses for a 40°C temperature rise.
5. Part number definition - HC3-xxx-R:
HC3 = Product code and size
-xxx = Inductance value R = Decimal point (if no “R” is present, last character equals number of zeros )
-R Suffix = RoHS compliant
1. OCL (Open Circuit Inductance) Test parameters: 300kHz, .25Vrms, 0.0ADC & Isat.
2. DC current for approximately ∆T of 40°C without core loss De-rating is necessary for AC currents.
PCB layout, trace thickness and width, air flow and proximity of other heat generating components
will affect temperature rise. It is recommended that the temperature of the part not exceed 125°C
under worst case conditions verified in the end application.
Dimensions–mm
TOP VIEW
RECOMMENDED
PCB PAD LAYOUT
FRONT VIEW
SCHEMATIC
14.5 typ
1
30.0 max
22.0
HC3-xxx
wwllyy R
4.0 typ
HT max
2
5.50
19.0
5.50
3.0 typ
25.3 max
Part marking: HC3-xxx (-xxx= inductance value, R= decimal point,
if no R is present then last character equals number of zeros)
wwllyy= date code, R= Revision level
2
www.eaton.com/electronics
Part number
Height max
HC3-R50-R
18.0
HC3-1R0-R
17.5
HC3-2R2-R
17.5
HC3-3R3-R
17.5
HC3-4R7-R
17.5
HC3-5R6-R
17.5
HC3-6R0-R
17.5
HC3
Technical Data 4122
Inductance characteristics
OCL vs Isat
100
90
80
% of OCL
70
60
50
40
30
40
50
60
70
80
90
100
110
120
130
% of Isat
Core loss
Irms DERATING W ITH CO RE LOSS for HC3
% Applied Volt-u Seconds
10
30
50
70
90
110
130
150
170
190
%of Irms specified from
zero ripple application
30
40
50
60
70
80
100kHz
200kHz
300kHz
400kHz
500kHz
90
100
3
HC3
Technical Data 4122
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
t
Table 1 - Standard SnPb Solder (Tc)
Package
Thickness
Volume
mm3
很抱歉,暂时无法提供与“HC3-3R3-R”相匹配的价格&库存,您可以联系我们找货
