NodeMCU-32S
NodeMCU-32S
    AI-THINKER(安信可)
    DIP-38
    WiFi及蓝牙模块 DIP-38 2.6~3.6V PCB Antenna
NodeMCU-32S 数据手册
NodeMCU-32S 规格书 V2.0 NodeMCU-32S 规格书 版本 V2.0 版权 ©2021 Copyright © 2021 Shenzhen Ai-Thinker Technology Co., Ltd All Rights Reserved 第 1 页 共 15 页 NodeMCU-32S 规格书 V2.0 文件履历表 版本 日期 制定/修订内容 制定 核准 V2.0 2021.12.25 首次制定,全新改版 黄方可 徐宏 Copyright © 2021 Shenzhen Ai-Thinker Technology Co., Ltd All Rights Reserved 第 2 页 共 15 页 NodeMCU-32S 规格书 V2.0 目录 1. 产品概述..................................................................................................................................4 2. 主要参数..................................................................................................................................5 2.1. 电源选型.....................................................................................................................5 2.2. 电气参数.....................................................................................................................6 2.3. 电气特性.......................................................................................................................6 2.4. 射频性能.....................................................................................................................6 2.5. 功耗.............................................................................................................................7 3. 外观尺寸..................................................................................................................................8 4. 按键说明..................................................................................................................................9 5. 管脚定义...............................................................................................................................11 6. 原理图...................................................................................................................................14 7. 产品包装信息........................................................................................................................14 8. 联系我们................................................................................................................................14 免责申明和版权公告.................................................................................................................15 注 意...........................................................................................................................................15 Copyright © 2021 Shenzhen Ai-Thinker Technology Co., Ltd All Rights Reserved 第 3 页 共 15 页 NodeMCU-32S 规格书 V2.0 1. 产品概述 本规格书适用于在售的板载 CP2012 和 CH340 两款 NodeMCU-32S 的 开发板。 NodeMCU-32S 开发板是针对安信可 ESP32-S 模组而设计的一款核心开发板。此款 模组的核心是 ESP32 芯片 ,具 有可扩展、自适应的特点。两个 CPU 核可以被单独 控制。时钟频率的调节范围为 80MHz 到 240MHz,支持 RTOS 操作系统二次开发, 是一款通用 Wi-Fi+BT+BLE MCU 模组。 NodeMCU-32S 开发板集成了传统蓝牙、低功耗蓝牙和 Wi-Fi。具有广泛的用途: Wi-Fi 支持极大范围的通信连接,也支持通过路由器直接连接互联网;而蓝牙可以让用 户连接 手机或者广播 BLE Beacon 以便于信号检测。模组支持的数据传输速率高达 150 Mbps, 天线输出功率达到 20 dBm,可实现最大范围的无线通信。因此,这款模 组具有行业领 先的技术规格,在高集成度、无线传输距离、功耗以及网络联通等方面性 能极佳。 ESP32-S 模组的操作系统是带有 LwIP 的 freeRTOS,还内置了带有硬件加速功能 的 TLS 1.2。芯片同时支持 OTA 加密升级,方便用户在产品发布之后继续升级。 它具有以下特点:               支持 802.11b/g/n WIFI 频率范围 2400 ~ 2483.5MHz 时钟频率的调节范围 80MHz 到 240MHz,支持 RTOS 内置 2 路 12bit 高精度 ADC,多达 18 个通道 接口类型:标准 Micro USB+2.54mm 间距排针 提供 UART/GPIO/ADC/PWM/I2C/I2S 接口 集成 Wi-Fi MAC/BB/RF/PA/LNA 串口速率最高可达 4Mbps 内嵌 Lwip 协议栈 支持 STA/AP/STA+AP 工作模式 支持安卓、IOS 的 Smart Config(APP)/AirKiss(微信) 一键配网 支持串口本地升级和远程固件升级(FOTA) 通用 AT 指令可快速上手 支持二次开发,集成了 Windows、Liunx 开发环境 Copyright © 2021 Shenzhen Ai-Thinker Technology Co., Ltd All Rights Reserved 第 4 页 共 15 页 NodeMCU-32S 规格书 V2.0 2. 主要参数 表 1 主要参数说明 开发板型号 适合模组 NodeMCU-32S ESP32-S 封装 DIP-38(2.54 间距标准排针) 尺寸 25.4*48.26*3(±0.2)mm 天线形式 板载 PCB 天线 频谱范围 2400 ~ 2483.5MHz 工作温度 -40 ℃ ~ 85 ℃ 存储环境 -40 ℃ ~ 125 ℃ , < 90%RH 供电范围 Micro USB 供电电压 4.75~5.25V,推荐 5.0V,供电电流 > 500mA 支持接口 UART/GPIO/ADC/PWM/I2C/I2S/SPI/SDIO 可用 IO 口数量 22 个 串口速率 安全性 Flash 支持 110 ~ 4608000 bps ,默认 115200 bps WEP/WPA-PSK/WPA2-PSK 默认 32Mbit(最大可支持 128Mbit) Mode-Sleep 模式 15mA(单模组) 功耗 Light-Sleep 模式 0.8mA(单模组) Deep-Sleep 模式 5uA(单模组) 重量 约 1.45g 待机模式:70mA(单模组) 2.1.电源选型 您可从以下三种供电方式中任选其一给开发板供电:  Micro-USB 接口供电(默认)  5V 和 GND 排针供电  3V3 和 GND 排针供电 建议选择第一种供电方式:Micro-USB 接口供电。 Copyright © 2021 Shenzhen Ai-Thinker Technology Co., Ltd All Rights Reserved 第 5 页 共 15 页 NodeMCU-32S 规格书 V2.0 2.2.电气参数 NodeMCU-32S 开发板是静电敏感设备,在搬运时需要采取特殊预防措施。 图 3 ESD 防静电图 2.3. 电气特性 表 2 电气特性表 参数 最小值 典型值 最大值 单位 MicroUSB 供电电压 4.75 5 5.25 V 供电电压 2.6 3.3 3.6 V 工作温度 -20 - +85 ℃ 储存温度 -40 - +125 ℃ 2.4.射频性能 表 3 Wi-Fi 射频性能表 描述 典型值 单位 工作频率 2400~2483.5 MHz 输出功率 11n 模式下,PA 输出功率为 13±2 dBm 11g 模式下,PA 输出功率为 14±2 dBm 11b 模式下,PA 输出功率为 16±2 dBm 接收灵敏度 CCK,1Mbps
NodeMCU-32S 价格&库存
很抱歉,暂时无法提供与“NodeMCU-32S”相匹配的价格&库存,您可以联系我们找货
