ME2206
3W High Power White LED ME2206
Description
Features
The ME2206 is a CMOS BOOST DC-DC
LED Power Efficiency: up to 90%
converter that delivers a regulated output current. It
Current Accuracy: ±10%
switches at a 1MHz constant frequency (TYP),
Low Start-Up Voltage: 0.9V(ILED=270mA)
using of small value external inductor and ceramic
Low Hold Voltage:0.75V(ILED=200mA)
capacitors.
1MHz Switching Frequency
The ME2206 is aimed to be used for driving
Uses small, Low Profile External Components
loads up to 1A from a one or two-cell alkaline
Low RDS(ON) : 100mΩ (TYP.)
battery (according to specific package). Additionally,
Open LED Protection
it can limit the LED current by the sense resistor
Over Temperature Protection
connected between the feedback pin (FB) and
Pb-Free Package
ground. A low 95mV feedback voltage reduces the
power loss in the Rs for better efficiency. During the
shutdown
mode, the
current consumption
is
reduced to less than 1uA.
Applications
Package
White LED Torch (Flashlight)
6-pin :SOT23-6
White LED Camera Flash
5-pin :SOT89-5
DSC(Digital Still Camera)Flash
Cellular Camera Phone Flash
PDA Camera Flash
Camcorder Torch(Flashlight) Lamp
V07
www.microne.com.cn
Page 1 of 9
ME2206
Typical Application Circuit
Rs Resistor Value Selection:
TYP.(mΩ)
127
270
ILED (mA)
750
351.8
Precautions:
ME2206 is only applicable to two battery-driven 1W or 3W white LED, ME2206A a battery can drive 1W or
3W white LED.
Selection Guide
ME 22 06 X XX G
Environment mark
Package
M6:SOT23-6
P5:SOT89-5
Function
Product Type
Product Series
Microne
V07
product series
product description
ME2206M6G
two battery-driven;package:SOT23-6
ME2206P5G
two battery-driven;package:SOT89-5
ME2206AM6G
a battery-driven;package:SOT23-6
ME2206AP5G
a battery-driven;package:SOT89-5
www.microne.com.cn
Page 2 of 9
ME2206
Pin Configuration
6
5
4
1
2
3
5
4
1
2
SOT23-6
3
SOT89-5
Pin Assignment
Pin Number
Name
Function
4
SW
Switch
2
2
GND
Ground
3
3
FB
Feedback
4
1
SHDN
Shut Down
5
5
VOUT
Output
6
VIN
Input
SOT23-6
SOT89-5
1
Block Diagram
95mv Vref
Error
AMP
FB
SHDN
PWM
VOUT
OSC
GND
slope
compensation
SW
VIN
Sampling
inductor
current
V07
Limit current
DRV
Vref
www.microne.com.cn
Page 3 of 9
ME2206
Absolute Maximum Ratings
Parameter
Symbol
Ratings
Units
Input Voltage
VIN
-0.3V~6V
V
SW Pin Voltage
SW
-0.3V~6V
V
SHDN, FB Pin Voltage
SHDN/FB
-0.3V~6V
V
Operating Temperature Range
TOPR
-40℃~85℃
Storage Temperature Range
TSTG
-55℃~125℃
Lead Temperature (Soldering, 10 sec)
TL
260℃
SOT23-6
PD
400
mW
SOT89-5
PD
500
mW
Internal Power Dissipation
Electrical Characteristic
T=25℃,Vin=2.4V,ILED =750mA,VSHDN =Vin,L=2.2uH,Cin=Cout=10uF,unless otherwise noted.
Parameter
Symbol
Condition
Min
Input Voltage Range
Vin
0.9
Feedback Voltage
VFB
85
Start-up Voltage
VSTART
Hold Voltage
VHOLD
Oscillator Frequency
FOSC
SHDN Input High
VSH
Vin=1.8V
SHDN Input Low
Over Temperature
Shutdown
Over Temperature
Hysteresis
Maximum Output
Current Range
VSL
Vin=1.8V
Vin:0V~3V
ILED =270mA
Vin:3V~0V
ILED =750mA~200mA
Typ
95
Max
Unit
VF-0.2
V
105
mV
0.9
V
0.75
V
1
MHz
1.0
V
0.4
OTS
150
OTH
15
IMAX
750
ILED =0mA,Vout=3.4V,
Device Switch at 1MHz
Shutdown mode
Quiescent Current
IQ
Shutdown Current
Switch on
Resistance
Current Limit
ISD
RDSON
Vout=3.4V
ILIM
Vout=3.4V
Efficiency
η
ILED =750mA
V
mA
1
3
1
mA
uA
Ω
0.1
2
A
90
Note: VF for LED forward voltage
Operation Principles
The ME2206 could work at low input voltage condition. The ME2206 is supplied by VOUT. When the output
voltage is lower than 2V, the internal low voltage OSC starts work. After the VOUT voltage is higher than 2V, the
circuit loop began to work normally. According to the sampled feedback voltage at FB pin, the chip adjusts the
Duty, to make the output constant current. The ME2206 has the limiting inductor’s current function, and the
limiting current is 2A. When the chip’s temperature is higher than 150℃, it enters the OTP function. And the chip
V07
www.microne.com.cn
Page 4 of 9
ME2206
stops work. When the chip’s temperature down to135℃ , the ME2206 works again. If the load open, The
ME2206 enters load open protection state. Then the VOUT will up to 5V and the ME2206 stops working. After
the VOUT down to 4.6V, ME2206 began working again.
External Parts Selection
1. Inductor
The recommended L value of the ME2206 Series is 2.2μH.
The inductance (L) has a strong influence on the maximum output current (IOUT) and efficiency (η). The
inductor peak current (IPK) increases when L is decreased, which improves the circuit stability and increases the I
OUT users can obtain. The ME2206 can use small value inductors due to its switching frequency of 1MHz. User
could accord to applications to choose the value of inductor in range of 2.2μH to 4.7μH. The inductor should
have low DCR (DC resistance) to minimize the I2R power loss, and it requires a current rating of 2A to handle the
peak inductor current without saturating.
2. Diode
It’s necessary to use a Schottky diode rated at 2A with the ME2206. Using a Schottky diode with a lower
forward voltage drop is better to improve the power LED efficiency, and its reverse breakdown voltage should be
greater than the output voltage.
3. Input capacitor (CIN) and output capacitor (COUT)
To improve efficiency, an input capacitor (CIN) lowers the power supply impedance and averages the input
current.
For better input decoupling, Low ESR (equivalent series resistance) capacitors should be used at the input.
At least 10uF input capacitor is recommended for most applications.
An output capacitor (COUT), which is used to smooth the output voltage, requires a capacitance larger than that of
the step-down type because the current is intermittently supplied from the input to the output side in the step-up
type. A minimum output ceramic capacitor value of 10uF is recommended for the ME2206. However, a higher
capacitance is recommended if the output voltage is high or the load current is large. 10uF~22uF output
capacitor is recommended for higher power applications.
4. LED Current Setting
The LED current is set by the single external Rs resistor connected to the FB pin as shown in the typical
application circuit. The typical FB reference is internally regulated to 95mV. The LED current is 95mV/Rs. It’s
recommended to use a 1% or better precision resistor for the better LED current accuracy. The formula and table
for Rs selection are shown as follows:
V07
www.microne.com.cn
Page 5 of 9
ME2206
Rs=95mV/ILED
Standard Value(Ω)
ILED(mA)
0.18
528
0.15
633
0.12
792
0.10
950
5. PCB Layout Guidelines
The input capacitor and output capacitor should be placed respectively as close as possible to the input pin
and out pin of the IC; the inductor and schottky diode should be placed as close as possible to the switch pin by
using wide and short traces for the main current path; the current sense resistor should be placed as close as
possible between the GND pin and FB pin.
Typical Performance Characteristics
T=25℃,L=2.2uH,Cin=Cout=10uF,unless otherwise noted.
V07
www.microne.com.cn
Page 6 of 9
ME2206
Packaging Information
Package type:SOT23-6
Millimeters
DIM
Inches
Min
Max
Min
Max
A
1.05
1.45
0.0413
0.0571
A1
0.0000
0.0059
A2
0.9
1.3
0.0354
0.0512
A3
0.55
0.75
0.0217
0.0295
b
0.25
0.5
0.0098
0.0197
c
0.1
0.25
0.0039
0.0098
D
2.7
3.12
0.1063
0.1228
e1
1.9(TYP)
0.0748(TYP)
E
2.6
3.1
0.1024
0.1220
E1
1.4
1.8
0.0551
0.0709
e
0.95(TYP)
0.0374(TYP)
L
0.25
0.6
0.0098
0.0236
θ
8°
0.0000
8°
c1
0.2(TYP)
V07
0.0079(TYP)
www.microne.com.cn
Page 7 of 9
ME2206
Package type:SOT89-5
Millimeters
DIM
Inches
Min
Max
Min
Max
A
1.4
1.6
0.0551
0.0630
b
0.32
0.52
0.0126
0.0205
b1
0.38
0.58
0.0150
0.0228
c
0.35
0.47
0.0138
0.0185
D
4.4
4.6
0.1732
0.1811
D1
1.55(TYP)
0.061(TYP)
e1
3(TYP)
0.1181(TYP)
E
2.3
2.6
0.0906
0.1023
E1
3.94
4.4
0.1551
0.1732
e
1.5(TYP)
L
0.8
V07
0.0591(TYP)
1.2
www.microne.com.cn
0.0315
0.0472
Page 8 of 9
ME2206
The information described herein is subject to change without notice.
Nanjing Micro One Electronics Inc is not responsible for any problems caused by circuits or diagrams
described herein whose related industrial properties, patents, or other rights belong to third parties.
The application circuit examples explain typical applications of the products, and do not guarantee the
success of any specific mass-production design.
Use of the information described herein for other purposes and/or reproduction or copying without the
express permission of Nanjing Micro One Electronics Inc is strictly prohibited.
The products described herein cannot be used as part of any device or equipment affecting the human
body, such as exercise equipment, medical equipment, security systems, gas equipment, or any
apparatus installed in airplanes and other vehicles, without prior written permission of Nanjing Micro
One Electronics Inc.
Although Nanjing Micro One Electronics Inc exerts the greatest possible effort to ensure high quality
and reliability, the failure or malfunction of semiconductor products may occur. The user of these
products should therefore give thorough consideration to safety design, including redundancy,
fire-prevention measures, and malfunction prevention, to prevent any accidents, fires, or community
damage that may ensue.
V07
www.microne.com.cn
Page 9 of 9
很抱歉,暂时无法提供与“ME2206AM6G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.16640
- 50+0.94241
- 150+0.84629
- 国内价格
- 5+0.82990
- 20+0.75490
- 100+0.67990
- 500+0.60490
- 1000+0.56990
- 2000+0.54490
