SRV05-4
Order Code: SRV05-4
Transient Voltage Suppressor
Features
Low operating voltage: 5V
Low capacitance
Solid-state silicon-avalanche and active circuit
triggering technology
Back-drive protection for power-down mode
Lead-free version available
IEC COMPATIBILITY (EN61000-4)
IEC 61000-4-2 (ESD) ±25kV (air), ±20kV (contact)
IEC 61000-4-4 (EFT) 40A (5/50ns)
IEC 61000-4-5 (Lightning) 3A (8/20μs)
Mechanical Characteristics
Applications
SOT-23-6L package
Video/Graphics Card
Molding compound flammability rating: UL
Digital Visual Interface (DVI)
94V-0
USB2.0 Power and Data lines protection
Marking: Marking Code
Notebook and PC Computers
Packaging: Tape and Reel
Monitors and Flat Panel Displays
RoHS Compliant
Circuit Diagram
Schematic & PIN Configuration
5
1
3
4
1
6
2
5
3
4
6
2
SOT-23-6L (Top View)
www.dowosemi.cn
1/4
Order Code:SRV05-4
Absolute Maximum Rating
Rating
Symbol
Value
Units
Peak Pulse Power ( tp =8/20μs )
PPP
70
Watts
Peak Pulse Current ( tp =8/20μs )
Ipp
3
A
Operating Temperature
TJ
-55 to + 85
°C
TSTG
-55 to +150
°C
Storage Temperature
Electrical Parameters (T=25℃)
Symbol
Parameter
I
IPP
Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
VRWM
IR
VBR
IF
Working Peak Reverse Voltage
VC VBR VRWM
Reverse Leakage Current @ VRWM
Breakdown Voltage @ IT
IT
Test Current
IF
Forward Current
VF
Forward Voltage @ IF
V
IR V F
IT
IPP
Electrical Characteristics
SRV05-4
Parameter
Reverse Stand-Off Voltage
Symbol
Conditions
VRWM
Pin5 to pin2 T=25°C
VBR
IT=1mA
Pin 5 to pin2
IR
VRWM=5V, T=25°C
Pin 5 to pin2
Forward Voltage
VF
IT=15mA
Clamping Voltage
VC
IPP=3.0A, tp=8/20μs
I/O pin to GND
Reverse Breakdown Voltage
Junction Capacitance
Cj
Minimum
Typical
Maximum
Units
5.0
V
5.6
V
0.8
500
nA
1.5
V
22
V
VR = 0V, f = 1MHz
I/O pin to GND
2.5
3.5
pF
VR = 0V, f = 1MHz
Between I/O pins
1.0
2.0
pF
www.dowosemi.cn
2/4
Order Code:SRV05-4
Typical Characteristics
Figure 2: Power Derating Curve
10
110
Percent of Rated Power for Ipp
Ppp – Peak Pulse Power - Ppp(KW)
Figure 1: Peak Pulse Power vs. Pulse Time
1
70w 8/20µs
Waveform
0.1
0.01
0.1
1
10
100
100
90
80
70
60
50
40
30
td – Pulse Duration - µs
50
75
100
125
150
Ambient Temperature - TA ( )
Figure 3: Pulse Waveform
Figure 4: Clamping Voltage vs. Peak Pulse
Current
110
90
Percent
Ipp
80
70
Clamping Voltage -VC(V)
Waveform
Paramters
tr=8µs
td=20µs
100
e-t
60
50
40
td=Ipp/2
30
10
15
30
28
26
24
22
16
14
12
10
8
6
4
2
2
3
4
Peak Pulse Current -Ipp(A)
Time (µs)
Figure 5: Capacitance vs. Reverse Voltage
Figure 6: Forward Voltage vs. Forward Current
8
7
Forward Voltage–VF(V)
Capacitance–Cj (pF)
f=1 MHz
6
4.5
I/O Pin to Gnd
3
Between I/O Lines
1.5
6
5
4
3
Test
Waveform
Paramters
tr=8µs
td=20µs
2
1
2
3
4
5
Reverse Voltage–VR (V)
4
6
8
10
12
Forward Current–IF(A)
www.dowosemi.cn
3/4
Order Code:SRV05-4
Outline Drawing – SOT-23-6L
PACKAGE OUTLINE
A
D
e1
SOT-23-6L
N
2X E/2
E1
DIMENSIONS
SEE DETAIL A
E
SIDE VIEW
2X
DIM
2
1
ccc
C
N/2 TIPS
e
B
H
D
aaa
C
A2 A
SEATING
PLANE
c
GAGE
PLANE
0.25
A1
bxN
bbb
bbb M C
C
L
θ1
(L1)
A-B
D
DETAIL A
NOTES:
INCHES
NOM
MAX
MIN
NOM
MAX
A
.035
.057
0.90
1.45
A1
.000
.006
0.00
0.15
A2
.035
.049
.051
0.90
1.25
1.30
b
.010
.020
0.35
0.50
c
.003
.007
0.08
0.20
D
.110
.114
.122
2.80
2.90
3.00
E1
.060
.063
.069
1.50
1.625
1.75
E
.110BSC
2.80 BSC
e
.037 BSC
0.95 BSC
e1
1. Controlling Dimensions are In Millimeters (Angles In Degrees).
L
2. Datums -A- And -B- To Be Determined At Datum Plane -H- .
L1
θ1
3. Dimensions “E1” And “D” Do Not Include Mold Flash,Protrusions Or Gate
Burrs.
MILLIMETERS
MIN
.075BSC
.013
.018
1.90 BSC
.024
0.35
(.024)
0°
0.45
8°
0°
N
6
6
aaa
.004
0.10
bbb
.008
0.20
ccc
.008
0.20
Notes
DIMENSIONS
X
(C)
G
Z
Y
P
DIM
INCHES
MILLIMETERS
C
(.098)
G
.055
1.40
(2.50)
P
.037
0.95
X
.024
0.60
Y
.043
1.10
Z
.141
3.60
THIS LAND PATTERN IS FOR REFERENCE PURPOSES ONLY.
CONSULT YOUR MANUFACTURING GROUP TO ENSURE YOUR
COMPANY'S MANUFACTURING GUIDELINES ARE MET.
Marking Codes
Part Number
SRV05-4
Marking Code
V5L
Package Information
Qty:3k/Reel
www.dowosemi.cn
0.60
(0.60)
4/4
8°
很抱歉,暂时无法提供与“SRV05-4LA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.15001
- 100+0.14001
- 300+0.13001
- 500+0.12001
- 2000+0.11501
- 5000+0.11201
