SRV05-4LA
PROTECTION PRODUCTS
Description
The
SRV05-4LA
Feature
is
a
low
capacitance
TVS
Low clamping voltage
(Transient Voltage Suppressor) array designed to
Protects one bidirectional or four unidirectional
protect high speed data interfaces. It has been
lines
specifically designed to protect sensitive electronic
Working voltage: 5V
components which are connected to data and
Low leakage current
transmission lines from over-stress caused by ESD
Low capacitance: CI/O - GND = 0.5pF typ.
(Electrostatic Discharge).
RoHS compliant
Transient protection for high speed data Lines to
IEC61000-4-2(ESD)±15kV(air),±15kV (Contact)
Ordering Information
Applications
Device : SRV05-4LA
USB 2.0
Package : SOT23-6L
HDMI 1.3
Material : Halogen free
SATA and eSATA
Packing : Tape & Reel
DVI
Quantity per reel : 3,000 PCS
IEEE 1394
Flammability Rating : UL 94V-0
PCI Express
Reel size : 7 inch
Portable Electronics
Notebooks
Circuit Diagram
Schematic & Pin Configuration
1/4
SRV05-4LA
PROTECTION PRODUCTS
Ordering Information per line@25℃( unless otherwise specified)
Parameter
Symbol
Rating
Unit
Peak pulse power (tp = 8/20μs)
Ppk
60
W
Peak pulse current (tp = 8/20μs)
IPP
4
A
ESD according to IEC61000-4-2 air discharge
±15
VESD
ESD according to IEC61000-4-2 contact discharge
Junction temperature
kV
±15
TJ
125
Operating temperature
TOP
-40~85
Lead temperature
TL
260
TSTG
-55~150
Storage temperature
Electrical Characteristics per line@25℃( unless otherwise specified)
Parameter
Symbol
Reverse Stand-off Voltage
Reverse Breakdown Voltage
Conditions
It=1mA
Reverse Leakage Current
IR
VRWM=5V
Clamping Voltage
VC
Clamping Voltage
VC
CJ
Any I/O pin to Ground
IPP=4A tp=8/20us
VR=0V, f = 1MHz
Any I/O pin to I/O pin
Electronics Parameter
VRWM
IR
VBR
6
IPP=1A tp=8/20us
VR=0V, f = 1MHz
Symbol
Typ.
VRWM
VBR
Junction Capacitance
Min.
Parameter
Peak Reverse Working Voltage
Reverse Leakage Current @ VRWM
Breakdown Voltage @ IT
IT
Test Current
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
PPP
Peak Pulse Power
CJ
IF
Forward Current
VF
Forward Voltage @ IF
2/4
Max.
Units
5
V
9.5
V
1
uA
9
V
15
V
0.5
0.8
0.25
0.4
pF
SRV05-4LA
PROTECTION PRODUCTS
Typical Characteristics
100
Test Waveform Parameters
tf=8us tp=20us
80
% of Rated Power
IPP - Peak Pulse Current - % of I PP
100
60
40
tp=20us(IPP/2)
60
40
10
15
t - Time(us)
50
75
100
125
150
TL - Lead Temperture(C)
Pulse Waveform
Power Derating Curve
1000
15
14
Pulse waveform : tp=8/20us
13
Peak pulse power (W)
VC- Clamping valtage(V)
25
12
11
10
100
10
9
8
1
2
3
4
1
5
IPP - Peak pulse current(A)
1
10
100
1000
Pulse time(us)
Clamping voltage vs. Peak pulse current
Non repetitive peak pulse power vs. Pulse time
3/4
SRV05-4LA
PROTECTION PRODUCTS
Product dimension(SOT-23-6L)
4/4
很抱歉,暂时无法提供与“SRV05-4LA 4A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.14601
- 100+0.13601
- 300+0.12601
- 500+0.11601
- 2000+0.11101
- 5000+0.10801
