UMW
R
UMW TL432
Adjustable Accurate Reference Source
DEVICE DESCRIPSION:
The UMW TL432 is a three-terminal adjustable shunt regulator
highly accurate 1.25V band gap reference with 0.5%, 1%
tolerance. The device offers thermal stability, wide operating
current (50mA) and an extended temperature range of 0℃ to 85℃
for operation in power supply applications. The UMW TL432 offers
a wide operating voltage range of up to 12V and is an excellent
choice for voltage reference requirements in an isolated feedback
circuit for 3.0V ~ 3.3V switching mode power supplies. The tight
tolerance guarantees a lower design cost for the power supply
manufacturer by virtually eliminating the need for an extra power
supply manufacturing process of the power supply
FEATURES:
.Low dynamic output impedance
.The effective temperature compensation in the working
range of full temperature
.Low output noise voltage
.Fast on -state response
.Sink current capability of 0.1mA to100mA
APPLICATION:
MARKING:
● Shunt Regulator
● High-Current Shunt Regulator
● Precision Current Limiter
ABSOLUTE MAXIMUM RATINGS (Operating temperature range applies unless otherwise specified)
Parameter
Symbol
Value
Unit
Cathode Voltage
VKA
18
V
Cathode Current Range (Continuous)
IKA
100
mA
Reference lnput Current Range
Iref
6
mA
Power Dissipation
PD
350
mW
RθJA
350
℃/W
Tj
125
Operating Ambient Temperature Range
Topr
-40~+85
Storage temperature Range
Tstg
-40~+150
Thermal Resistance from Junction
to Ambient
Operating Junction Temperature
www.umw-ic.com
1
友台半导体有限公司
UMW
R
UMW TL432
ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified)
Parameter
Symbol
Test Condition
Min
Typ
Max
Unit
Vref
VKA=VREF, IKA=10mA
1.22
1.25
1.26
V
4.5
16
mV
1
2.5
mV/V
1.5
4
µA
0.2
0.6
µA
0.1
mA
0.05
0.5
µA
0.15
0.5
Ω
Reference input voltage (Fig.1)
Deviation of reference voltage over
full temperature range (Fig 1)
VKA =VREF, IKA =10mA
△Vref /△T
0℃≤Ta≤70℃
Ratio of change in reference input
voltage to the change in cathode △Vref /△VKA
IKA=10mA
△VKA=1.25V~15V
voltage (Fig.2)
lref
Reference input current (Fig.2)
Deviation Of reference input curren
over full temperature range (Fig.2) t
△lref /△T
Minimum cathode current for
regulation (Fig.1)
Off-state cathode Current (Fig.3)
Dynamic impedance
lKA=10mA, R1=10kΩ
R2=∞
lKA=10mA, R1=10kΩ R2=∞
0℃≤Ta≤70℃
IKA(min)
VKA=VREF, IKA=10mA
IKA(OFF)
VKA=36V,VREF=0
ZKA
VKA=VREF, lKA=1
to100mA
f≤1.0kHz
Note: TMIN=-25℃ ,TMAX=+85℃
CLASSIFICATION of Vref
Rank
0.5%
1.00%
Range
1.234-1.246
1.228-1.252
Figure 1. Test Circuit for VKA = Vref
www.umw-ic.com
Figure 2. Test Circuit for VKA >Vref
2
Figure 3. Test Circuit for Ioff
友台半导体有限公司
UMW
R
UMW TL432
www.umw-ic.com
3
友台半导体有限公司
很抱歉,暂时无法提供与“TL432 0.5%”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.17331
- 20+0.17013
- 100+0.16377
