TMI8837
TMI8837S
Low Voltage H-Bridge Motor Drive
FEATURES
GENERAL DESCRIPTION
Support the input voltage range:
Motor power: 1.8V~11V
Control power supply: 1.8V~7V
LDMOS RDS(ON) (HS+LS) 650mΩ (typical)
Ultra-low power sleep mode
45nA (typical) VM sleep mode current
17nA (typical) VCC sleep mode current
Up to 1.5A Peak current output capacity
Built-in UVLO Protection
TMI8837 and TMI8837S are low voltage DC
motor driver IC. Internal integration 650mΩ
(HS+LS typical) H bridge NMOS switch, which
can support the 1.8V~11V input voltage range.
The Peak current capacity is up to 1.5A,
support for ultra-low power sleep mode; built-in
UVLO, Thermal Shutdown, OCP protection
circuit. TMI8837 and TMI8837S can be used in
camera, toys and consumer products.
Built-in Over Temperature Protection
Built-in Short Circuit Protection
APPLICATIONS
Built-in Over Current Protection
Built-in Charge Pump
TMI8837: DFN2x2-8 package
TMI8837S: SOP8 package
Cameras
Toys
Consumer Products
TYPICAL APPILCATION
Figure 1. Basic Application Circuit
TMI and SUNTO are the brands of TOLL microelectronic
TMI8837 TMI8837S V1.4 2022.03
www.toll-semi.com
1
TMI8837
TMI8837S
ABSOLUTE MAXIMUM RATINGS
Parameter
Value
Unit
VM Voltage Range
-0.3~11
V
VCC, IN1, IN2, EN Voltages Range
-0.3~7
V
OUT1, OUT2 Voltage Range
-0.3~Vin+0.3
V
Storage Temperature Range
-50~150
°C
Junction Temperature
-40~150
°C
Package Thermal Resistance θJA of DFN2x2-8
70
°C/W
Package Thermal Resistance θJA of SOP8
90
°C/W
PACKAGE/ORDER INFORMATION
DFN2x2-8 (Top View)
SOP8 (Top View)
TMI8837
TMI8837S
Top Mark: TFCX/XX (TFC: Device Code, X/XX: Inside Code) for TMI8837
Top Mark: T8837S/XXXXX (T8837S: Device Code, XXXXX: Inside Code) for TMI8837S
Part Number
Package
Top Mark
Quantity/ Reel
TMI8837
DFN2x2-8
TFCX/XX
3000
TMI8837S
SOP8
T8837S/XXXXX
3000
TMI8837 and TMI8837S devices are Pb-free and RoHS compliant.
www.toll-semi.com
2
TMIandSUNTOarethebrandsofTOLLmicroelectronic
TMI8837
TMI8837S
PIN FUNCTIONS
Pin
Name
Function
Power Supply for Driver. Connect a 0.1μF bypass ceramic capacitor to GND. A
1
VM
bulk capacitor with at least 22μF capacitance on VM to GND is needed and
helpful to stabilize VM voltage during motor operation.
2
OUT1
Motor Driver output 1
3
OUT2
Motor Driver output 2
4
GND
Ground pin
5
IN2
PWM input2
6
IN1
PWM input1
Chip Enable Input Pin. When this pin is in logic low, the device enters
7
EN
low-power sleep mode. The device operates normally when this pin is logic
high. The pin has an internal pull-down resistor to GND.
8
VCC
Power Supply for Logic Input. Connect a 0.1μF bypass ceramic capacitor to
GND
ESD RATING
Items
Description
Value
Unit
VESD
Human Body Model for all pins
±2000
V
JEDEC specification JS-001
RECOMMENDED OPERATING CONDITIONS
Items
Description
Min
Max
Unit
Voltage Range
VM
1.8
11
V
TJ
Operating Junction Temperature Range
-40
125
°C
www.toll-semi.com
3
TMI8837
TMI8837S
ELECTRICAL CHARACTERISTICS
(VM=5V, TA = 25°C, unless otherwise noted.)
Parameter
Symbol
Conditions
Min
Typ
Max
Unit
11
V
Input Power Supplies (VM and VCC)
VM Voltage Range
VVM
1.8
VM=5V, VCC=3V
VM Supply Current
IVM
No PWM
VM=5V, VCC=3V
50kHz PWM
VM sleep mode supply current
IVMQ
VCC Voltage Range
VVCC
VM=5V, VCC=3V
IVCC
IVCCQ
0.53
mA
1.8
No PWM
VM=5V, VCC=3V
50kHz PWM
VCC sleep mode supply current
μA
45
Sleep Mode
VM=5V, VCC=3V
VCC Supply Current
124
VM=5V, VCC=3V
nA
7
V
180
μA
0.32
mA
17
Sleep Mode
95
35
nA
PWM Control Logic Inputs (IN1, IN2 and EN)
Input Logic Low Voltage Falling
Threshold
Input Logic High Voltage Rising
Threshold
Input logic Hysteresis
VIL_F
0.25x
0.4x
VCC
VCC
VIH_R
IIL
Input Logic High Current
IIH
Input Pull Down Resistor
RIN
0.5x
0.6x
VCC
VCC
0.1x
VHYS
Input Logic Low Current
V
V
VCC
-5
V
5
μA
40
μA
100
kΩ
0.65
Ω
Motor Driver Outputs (OUT1 and OUT2)
Output Switch
On-Resistance (HS+LS)
Output Switch Leakage Current
RON
VM=5V, VCC=3V
Iload=800mA
ILEAK
-200
200
nA
Protection Function
VCC UVLO Voltage
UVLO Hysteresis
VUVLO
1.7
V
VUVLO_HY
100
mV
1.75
A
IOCP
1.6
Over Current Retry Time
TOCP_RT
1
ms
Thermal Shutdown Threshold
TSDN
160
°C
Thermal Shutdown Hysteresis
TSDN_HY
°C
ELECTRICAL CHARACTERISTICS (continued)
www.toll-semi.com
4
TMI8837
TMI8837S
(VIN=5V, TA = 25°C, unless otherwise noted.)
Parameter
Symbol Conditions
Min
Typ
Max
Unit
Output Enable time
T1
180
265
ns
Output Disable time
T2
70
100
ns
T3
140
215
ns
T4
160
240
ns
Output rise time
T5
60
120
ns
Output fall time
T6
38
100
ns
Delay Time
IN1 low to OUT2 high
IN2 low to OUT1 high
Delay Time
IN2 high to OUT1 low
IN1 high to OUT2 low
FUNCTIONAL BLOCK DIAGRAM
Figure 2. TMI8837/S Block Diagram
www.toll-semi.com
5
TMI8837
TMI8837S
INPUT OUTPUT LOGIC
EN
IN1
IN2
OUT1
OUT2
Function
X
X
Z
Z
Coast
1
Z
Z
Coast
1
1
H
L
Forward
1
L
H
Reverse
1
1
1
L
L
Brake
www.toll-semi.com
6
TMI8837
TMI8837S
PACKAGE INFORMATION
DFN2x2-8
Unit: mm
Symbol
Dimensions In Millimeters
Min
Typ
Max
A
0.70
0.75
0.80
A1
A3
b
0.19
Symbol
Min
Typ
Max
L
0.30
0.35
0.40
0.05
K
0.20
0.20 REF
aaa
0.15
0.24
0.29
bbb
0.10
D
2.00 BSC
ccc
0.10
E
2.00 BSC
ddd
0.05
D2
1.25
1.30
1.35
eee
0.08
E2
0.75
0.80
0.85
fff
0.10
e
0.50 BSC
Note:
1) All dimensions are in millimeters.
www.toll-semi.com
7
TMI8837
TMI8837S
PACKAGE INFORMATION
SOP8
Unit: mm
Symbol
Min
Max
A
4.70
5.10
B
3.70
L
6.00
E
K
Min
Max
C
1.35
1.75
4.10
a
0.35
0.49
6.40
R
0.30
0.60
P
0°
7°
b
0.40
1.25
1.27 BSC
0.12
Symbol
0.22
Note:
2) Package length does not include mold flash, protrusion or gate burr.
3) Package width does not include inter lead flash or protrusion.
4) Lead popularity (bottom of leads after forming) shall be 0.10 millimeters max.
5) Pin 1 is lower left pin when reading top mark from left to right.
www.toll-semi.com
8
TMI8837
TMI8837S
TAPE AND REEL INFORMATION
TAPE DIMENSIONS: DFN2x2-8
REEL DIMENSIONS: DFN2x2-8
Unit: mm
TAPE WIDTH
Ø A (±1.0)
Ø N (±2.0)
W1 (+1.5/-0)
W2 (Max)
8MM
178
54
8.4
14.4
Note:
1) All Dimensions are in Millimeter
2) Quantity of Units per Reel is 3000
3) MSL level is level 3.
www.toll-semi.com
9
TMI8837
TMI8837S
TAPE DIMENSIONS:
REEL DIMENSIONS:
Unit: mm
A
B
C
D
E
F
T1
Ø 330±1
12.7±0.5
16.5±0.3
Ø 99.5±0.5
Ø 13.6±0.2
2.8±0.2
1.9±0.2
Note:
4) All Dimensions are in Millimeter
5) Quantity of Units per Reel is 3000
6) MSL level is level 3.
www.toll-semi.com
10
很抱歉,暂时无法提供与“TMI8837S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.51001
- 20+0.46501
- 100+0.42001
- 500+0.37500
- 1000+0.35400
- 2000+0.33900
