GR8837T
Green-Mode PWM Controller with Hiccup Protection
Features
Description
Current Mode Control
The GR8837T is a highly-integrated, low startup
Standby Power below 100mW
current,
Under-Voltage Lockout (UVLO)
green-mode function. The integrated functions also
Non-Audible-Noise Green-Mode Control
include the leading-edge blanking of the current
65KHz Switching Frequency
sensing, internal slope compensation, soft start
Internal Leading-Edge Blanking
OLP, and OCP. Besides, The RTL pin Auto recovery
Internal Slope Compensation
function by injecting a high over 3.5V to provide
Internal Soft Start
OVP Auto recovery and low below 1V to provide
Gate Output Voltage Clamp
OTP Auto recovery protection. These functions
Jitter and Soft Driving for Reducing EMI
enable the power supply to easily meet even the
External OVP Auto Recovery Mode
strictest power requirements.
External OTP Auto Recovery Mode
The GR8837T improves the performance and
Over-Load Protection (OLP)- -Auto Recovery
reduces the cost of power supplies. It is with 8-pin
Mode
DIP and 6-pin SOT-26 package.
Vcc OVP Protection- Auto Recovery Mode
300mA Driving Capability
Application
current
mode
PWM
controller
with
Battery Charger
Open Frame SMPS
Switching AC/DC Adapter
Ordering and Marking Information
GR8837T
Package Code
RoHS Code
G: Green (Halogen Free) Device
L: PB Free Device
J: DIP-8
C: SOT-26
DIP-8
SOT-26
GR8837T
X X XXX
37T X X
XXX
Code 1
Serial No.
Code 1
Serial No.
Code 2
Code 1
8
Year 2008
Code 2
9
2009
A
2010
B
2011
Code 2
1
2
3
4
Month
Jan.
Feb.
Mar.
Apr.
G
2016
H
2017
I
2018
J
2019
9
A
B
C
Sep.
Oct.
Nov.
Dec.
Nanjing Greenchip Semiconductor Co., Ltd. Inc. (Grenergy OPTO, Inc.) reserves the right to make changes to improve
reliability or manufacture ability without notice, and advise customers to obtain the latest version of relevant information to
verify before placing orders.
2018.09 Ver.1.0 Copyright Nanjing Greenchip Semiconductor Co., Ltd. Inc. (Grenergy OPTO, Inc.) www.grenergy-ic.com
1
GR8837T
Pin Configuration
GND
1
6
OUT
COMP
2
5
VCC
RTL
3
4
CS
Pin Description
Pin No.
Name
Function
1
GND
2
COMP
3
RTL
4
CS
5
VCC
Power supply pin
6
OUT
The output driver for driving the external MOSFET
Ground pin
Voltage feedback pin, by connecting a photo-coupler to control the duty cycle
Resistor trigger will enter auto recovery mode which a high over 3.5V for OVP auto
recovery and a low below 1V for OTP auto recovery
Current sense pin, connect to sense the MOSFET current
Absolute Maximum Ratings
Supply voltage VCC
COMP, RTL, CS
OUT
Junction temperature
30V
-0.3 ~ 7V
-0.3 ~ VCC + 0.3V
------------------------------------------------------------------------------------------------------- 150℃
Operating ambient temperature
Storage temperature range
SOT-26 package thermal resistance (junction to ambient)
-65℃ ~ 150 ℃
Power dissipation (SOT-26, at ambient temperature = 85℃)
Power dissipation (DIP-8, at ambient temperature = 85℃)
-20℃ ~ 85℃
250℃/W
250mW
650mW
Lead temperature (All Pb free packages, soldering, 10 sec)
260℃
2
GR8837T
ESD voltage protection, human body model
ESD voltage protection, machine model
2KV
200V
Electrical Characteristics (VCC = 15.0V & TA = +25℃,unless otherwise specified.)
Parameter
Pin
Min.
Typ.
Max.
Unit
15
uA
SUPPLY VOLTAGE
Startup Current (VCC=UVLO on - 1V)
5
8
Operating Current (with 1nF load on OUT pin), Vcomp = 0V
5
800
Operating Current (with 1nF load on OUT pin), Vcomp = 2.5V
5
1
2
3
mA
5
0.4
0.7
1
mA
UVLO(off)
5
5.8
6.8
7.8
V
UVLO(on)
5
10.3
11.3
12.3
V
OVP Level on VCC Pin –Auto Recovery Mode
5
27
28
29
V
0.8
mA
5.5
V
Operating Current (with 1nF load on OUT pin), Protection
Tripped (OLP, OVP)
uA
VOLTAGE FEEDBACK
Short Circuit Current, Vcomp = 0V
2
Open Loop Voltage, COMP Pin Open
2
Green-Mode Start Voltage
2
1.5
V
Burst Mode Start Voltage
2
0.85
V
4.4
CURRENT SENSING
Maximum Input Voltage, Vcs(off)- Auto Recovery Mode
4
Leading-Edge Blanking Time
4
Input Impedance
4
Delay to Output
4
0.80
0.85
0.9
350
V
nS
1
MΩ
100
nS
OSCILLATOR
Frequency
Jitter Frequency
Green Mode Frequency
Temp. Stability (-40°C ~ 110°C)
Voltage Stability (VCC = 11V~25V)
60
65
70
+6
KHz
25
KHz
5
3
Output Low Level, VCC = 15V, Io = 20mA
6
1
V
Output High Level, VCC = 15V, Io = 20mA
6
Rising Time, Load Capacitance = 1000pF
6
200
nS
Falling Time, Load Capacitance = 1000pF
6
80
nS
GATE DRIVER OUTPUT
8
V
3
GR8837T
VGATE-Clamp (VCC = 25V )
6
12
13
V
OLP SECTION
OLP Trip Level, Vcomp (OLP)
3.5
V
OLP Delay Time
60
mS
PWM SECTION
Maximum Duty Cycle
70
75
80
4
GR8837T
RTL SECTION
Over Voltage Protection Threshold Voltage
3
3.2
3.5
3.8
OVP Debounce Time
3
Over Temperature Protection Threshold Voltage
3
OTP Debounce Time
3
Output Current from RTL Pin
3
75
80
85
uA
RTL Pin Voltage When Floating
3
1.8
2.4
3.0
V
100
0.95
1
V
uS
1.05
100
V
us
5
GR8837T
6
GR8837T
10.8
7.0
10.7
6.9
UVLO (off) (V)
UVLO (on) (V)
Typical Performance Characteristics
10.6
10.5
6.8
6.7
6.6
10.4
10.3
-40
80
6.5
-40
120 125
10.0
8.0
6.0
4.0
-40
80
120 125
80
120 125
1.8
1.6
1.4
1.2
-40
80
120 125
Temperature (℃ )
Fig. 3 VDD Start up current vs. Temperature
Fig. 4 Operating current vs. Temperature
Maximum Input Voltage of CS pin(V)
3.8
3.6
3.4
3.2
3.0
-40
2.0
Temperature (℃ )
4.0
OLP-Trip Level (V)
40
2.2
Operating current (mA)
VDD Start up current (uA)
12.0
2.0
Temperature (℃ )
Fig. 2 UVLO (off) vs. Temperature
Temperature (℃ )
Fig. 1 UVLO (on) vs. Temperature
80
Temperature (℃ )
Fig. 5 OLP Trip
- Level vs. Temperature
120 125
0.90
0.89
0.88
0.87
0.86
0.85
-40
80
120 125
Temperature (℃ )
Fig. 6 Maximum Input Voltage of CS pin vs. Temperature
7
GR8837T
2
5
Green Mode Frequency (KHz)
68
Frequency (KHz)
67
66
65
64
63
-40
80
Temperature (℃ )
Fig. 7 Frequency vs. Temperature
120 125
24
23
22
21
80
120 125
Temperature (℃ )
Fig. 8 Green Mode Frequency vs. Temperature
8
GR8837T
Application Information
Start-up Current
Fig.9
The typical start-up current is around 8uA. Very low
start-up current allows the PWM controller to
increase the value of start-up resistor and then
reduce the power dissipation on it.
UVLO (Under Voltage Lockout)
A hysteresis UVLO comparator is implemented in
GR8837T Then turn-on and turn-off thresholds level
are fixed at 11.3V and 6.8V respectively. This
hysteresis shown in Fig.9 ensures that the start-up
capacitor will be adequate to supply the chip during
Soft Start
During initial power on, the GR8837T provides
16ms soft start function. It effectively suppresses
the start up peak current to reduce the power
MOSFET drain voltage especially at high line.
Oscillator
The maximum duty-cycle of internal oscillator is
limited to 75% for avoiding the transformer
saturation. The frequency of the oscillator is fixed to
65KHz by internal setting.
start-up. The GR8837T is designed to meet the
standby power below 100mW. So the start-up
resistor can be used as several Mega Ohms to
Green-Mode Operation
reduce the power loss. Due to the low UVLO on
When the load decreases to an extent, the
level, so the turn-on delay time will be also never
frequency of the controller will decrease so as to
greater than the general PWM IC.
reduce
Vcc
the
system
power
consumption.
The
minimum frequency is about 22 KHz, which is
outside the audio range.
UVLO (on) 11.3V
UVLO (off) 6.8V
LEB (Leading-Edge Blanking)
Each time the power MOSFET is switched on, a
turn-on spike will inevitably occur at the sense
resistor. To avoid fault trigger, a 350ns leading-edge
blanking time is built in. Conventional RC filtering
can therefore be omitted. During this blanking
9
GR8837T
period, the current-limit comparator is disabled and
OVP (Over Voltage Protection) on VCC
can not switch off the gate driver.
To prevent power MOSFET from being damaged,
the GR8837T is implemented an OVP function on
Built-in slope compensation circuit adds voltage
ramp in the current sense input voltage for PWM
generation. This greatly improves the close loop
stability at CCM and prevents the sub-harmonic
oscillation and thus reduces the output ripple
VCC. When the VCC voltage is higher than the OVP
threshold voltage, the output gate driver circuit will
be shut down immediately to stop the switching of
power MOSFET. The VCC pin OVP function is an
Auto-recovery type protection. GR8837T is working
in
voltage.
Auto-recovery mode as shown in Fig. 11.
VCC
OLP (Over Load Protection)
OVP Tripped
The GR8837T has over load protection function. An
internal circuit detects the load level, when the load
OVP Level
UVLO(on)
UVLO(off)
is larger than a threshold level and the condition
lasts more than 60ms, the gate output will keep on
t
OUT
low level. Then VCC decreases below UVLO off
level, the controller resets again. Fig.10 shows the
Switching
Non-Switching
Switching
waveform of the OLP operation.
t
Fig. 11
Gate Clamp/Soft Driving
Driver is clamped to 13V by an internal clamping
circuit. A totem pole gate driver is fine tuned to meet
both EMI and efficiency requirement in low power
application. An internal pull low circuit is activated
after pretty low Vdd to prevent external MOSFET
from accidentally turning on during UVLO.
VCC Mode Operation
VCC
In order to avoid the output voltage shut down by
UVLO(on)
load changing from full to no load, the GR8837T is
UVLO(off)
OLP
built-in the VCC mode function. When the load from
( off )
OLP Counter Reset
t
full changes to no load, the output voltage will
COMP
OLP delay time
overshoot and pull low the COMP pin by feedback
3.5 V
loop. Thus the duty will disappear and no power
OLP trip Level
t
delivers to the secondary. If there is without any
OUT
mechanism to prevent this situation, the VCC pin
Switching
Non - Switching
Switching
voltage will down to UVLO off and the IC will re-start
t
again. In the GR8837T, before the VCC is down to
UVLO off, it will force the OUT pin outputs the
Fig. 10
specified duty to pull the VCC higher than UVLO off.
10
GR8837T
The operation is shown in Fig.12.
protection and the NTC thermal resistor is setting as
external OTP protection. In the RTL pin, there are
two comparators for Auto-recovery protection. While
VCC
the voltage on this pin is higher than 3.5V or lower
Burst mode
VCC mode
VCC mode(off)
VCC mode(on)
than 1.0V, the GR8837T will enter Auto-recovery
UVLO(off)
protection after the de-bounce time 100us.
t
LOAD
Full load
t
OUT
Switching
t
Fig. 12
The VCC mode function is used to prevent the
output re-start again when load changes. So never
let the system operate on the VCC mode at no load.
The system should operate on burst mode,
otherwise the input power maybe become larger.
RTL Pin Auto-Recovery Mode
VDD
Auto-Recovery
Mode
VH_TH
3.5V
Normal Operation
RTL
pin
1V
VL_TH
Auto-Recovery
Mode
Fig. 13
The typical application for RTL pin is shown in Fig.
13. The Zener diode is setting as external OVP
11
GR8837T
12
GR8837T
Typical Application Circuit
GR8837T
13
GR8837T
Package Information
SOT-26
SOT-26
SYMBOL
MILLIMETERS
MIN.
INCHES
MAX.
A
MIN.
MAX.
1.45
0.057
A1
0.00
0.15
0.000
0.006
A2
0.90
1.30
0.035
0.051
b
0.30
0.50
0.012
0.020
c
0.08
0.22
0.003
0.009
D
2.70
3.10
0.106
0.122
E
2.60
3.00
0.102
0.118
E1
1.40
1.80
0.055
0.071
e
0.95 BSC
0.037 BSC
e1
1.90 BSC
0.075 BSC
L
θ
0.30
o
8
o
0.012
0.024
o
o
Note: 1. Followed from JEDEC MO-178 AB.
2. Dimension D and E1 do not include mold flash, protrusions or gate burrs. Mold flash, protrusions or
gate burrs shall not exceed 10 mil per side
14
GR8837T
Package Information
DIP-8
DIP-8
SYMBOL
MILLIMETERS
MIN.
INCHES
MAX.
A
MIN.
MAX.
5.33
0.210
A1
0.38
0.015
A2
2.92
4.95
0.115
0.195
b
0.36
0.56
0.014
0.022
b2
1.14
1.78
0.045
0.070
c
0.20
0.35
0.008
0.014
D
9.01
10.16
0.355
0.400
D1
0.13
E
7.62
8.26
0.300
0.325
E1
6.10
7.11
0.240
0.280
0.005
e
2.54 BSC
eA
7.62 BSC
eB
L
0.100 BSC
0.300 BSC
10.92
2.92
3.81
0.430
0.115
0.150
Note: 1. Followed from JEDEC MS-001 BA.
2. Dimension D, D1 and E1 do not include mold flash or protrusions. Mold flash or protrusions shall not
exceed 10 mil.
15
GR8837T
Carrier Tape & Reel Dimensions
SOT-26
Application
A
H
178.0±2.00
50 MIN.
P0
P1
P2
D0
D1
4.0±0.10
4.0±0.10
2.0±0.05
1.5+0.10
-0.00
1.0 MIN.
SOT-26
Application
SOT -26
T1
C
d
8.4+2.00 13.0+0.50 1.5 MIN.
-0.00
-0.20
D
W
E1
F
20.2 MIN. 8.0±0.30 1.75±0.10 3.5±0.05
T
A0
B0
K0
0.6+0.00
-0.40 3.20±0.20 3.10±0.20 1.50±0.20
Carrier Width
Cover Tape Width
Devices Per Reel
8
5.3
3000
(mm)
16
GR8837T
Tape and Specification Reel
SOT 26
Direction of feed
______________________________________________________________________
Nanjing Greenchip Semiconductor Co., Ltd. Inc. (Grenergy OPTO, Inc.) reserves the right to make corrections, modifications,
enhancements, improvements, and other changes to its products and services at any time and to discontinue any product or
service without notice. Customers should obtain the latest relevant information before placing orders and should verify that
such information is current and complete.
17
