1N5817 W - 1N5819W
SCHOTTKY BARRIER DIODE
FEATURES
Low Forward Voltage
High frequency inverters
Small Surface Mount device
PN Junction Guard Ring for Transient and ESD Protection
Low Capacitance
SOD-123
MECHANICAL DATA
Case: SOD-123
Case Material: Molded Plastic. UL flammability
Classification Rating: 94V-0
Weight: 0.005 grams (approximate)
MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
Parameter
Symbol 1N5817W 1N5818W 1N5819W
40
VR
Peak Reverse Voltage
14
21
28
Unit
V
RMS Reverse Voltage
VR(RMS)
Forward Current
IF
1
A
Non-Repetitive Peak Forward Surge Current@ t = 8.3 ms
IFSM
9
A
Power Dissipation
500
mW
Thermal Resistance From Junction To Ambient
PD
RθJA
200
°C/W
Junction Temperature
TJ
125
°C
Storage Temperature
TSTG
-55 ~+150
°C
V
ELECTRICAL CHARACTERISTICS (TA = 25°C unless otherwise specified)
Parameter
Symbol
Test conditions
1N5817W 1N5818W 1N5819W Unit
Maximum forward voltage
VF
IF = 1.0A
IF = 3.0A
0.450
0.750
0.550
0.875
0.600
0.900
V
Maximum reverse breakdown voltage
VR
IR=1mA
40
V
Maximum reverse current
IR
VR=20V 1N5817W
VR=30V 1N5818W
VR=40V 1N5819W
1.0
mA
Type junction capacitance
CD
VR = 4.0V, f = 1MHz
120
pF
© SHENZHEN HOTTECH ELECTRONICS CO.,LTD
E-mail:hkt@heketai.com
1/4
1N5817 W - 1N5819W
Typical Characteristics
Forward
10
Characteristics
Reverse
10
Characteristics
REVERSE CURRENT IR
a
=2
5℃
1
0.4
0.8
1.2
FORWARD VOLTAGE
VF
100
10
VR
100
(V)
10
15
(mW)
500
400
VR
25
(V)
Power Derating Curve
600
Ta=25℃
REVERSE VOLTAGE
0.01
REVERSE VOLTAGE
Capacitance Characteristics
1
o
Ta=25 C
(V)
f=1MHz
10
0.1
0.1
1E-3
2.0
POWER DISSIPATION
CAPACITANCE BETWEEN TERMINALS
CT (pF)
1000
1.6
o
Ta=100 C
1
PD
0.1
0.0
a
T
FORWARD CURRENT
T
IF
=1
00
(A)
(mA)
Pulsed
300
200
100
50
75
100
AMBIENT TEMPERATURE
Ta
125
150
2/4
1N5817 W - 1N5819W
SOD-123 Package Outline Dimensions
Symbol
Dimensions In Millimeters
Dimensions In Inches
Min.
Max.
Min.
Max.
A
1.050
1.250
0.041
0.049
A1
0.000
0.100
0.000
0.004
A2
1.050
1.150
0.041
0.045
b
0.450
0.650
0.018
0.026
c
0.080
0.150
0.003
0.006
D
1.500
1.700
0.059
0.067
E
2.600
2.800
0.102
0.110
E1
3.550
3.850
0.140
0.152
L
0.500RE F
0.020 REF
L1
0.250
0.450
0.010
0.018
θ
0°
8°
0°
8°
SOD-123 Suggested Pad Layout
Note:
1.Controlling dimension: in millimeters
2.General tolerance: ±0.05mm
3.The pad layout is for reference purposes only
3/4
1N5817 W - 1N5819W
SOD-123 Tape and Reel
SOD-123 Embossed Carrier Tape
SOD-123 Tape Leader and Trailer
DIMENSIONS ARE IN MILLIMETER
TYPE
A
B
C
d
E
F
P0
P
P1
W
SOD-123
1.85
3.95
1.57
Ø1.55
1.75
3.50
4.00
4.00
2.00
8.00
TOLERANCE
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
SOD-123 Reel
REEL OPTION
7’’ DIA
TOLERANCE
D
D1
D2
G
H
I
W1
W2
Ø178
54.40
13.00
R78
R25.60
R6.50
9.50
12.30
±2
±1
±1
±1
±1
±1
±1
±1
4/4
很抱歉,暂时无法提供与“1N5819W”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.03530
- 100+0.03440
- 1000+0.03370
- 国内价格
- 20+0.06039
- 200+0.05687
- 500+0.05336
- 1000+0.04985
- 3000+0.04810
- 6000+0.04564
