1N5819W
Schottky Barrier Diode
PINNING
FEATURES
PIN
• Low Forward Voltage Drop
• Guard Ring Construction for Transient Protection
DESCRIPTION
1
Cathode
2
Anode
• Negligible Reverse Recovery Time
2
• Low Capacitance
1
MECHANICAL DATA
▪Case: SOD-123
▪Terminals: Solderable per MIL-STD-750, Method 2026
▪ Approx. Weight:16mg/0.00056oz
Top View
Marking Code: S4
Simplified outline SOD-123 and symbol
JS
Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.
MI
Symbols
Parameter
1N5819W
CR
V RRM
40V
RMS reverse voltage
V RMS
28V
V DC
40V
I FSM
13A
O
Peak Repetitive Reverse Voltage
Working Peak Reverse Voltage
Se
Peak Forward Surge Current, 8.3ms single half
sine-wave superimposed on rated load (JEDEC method)
u
nd
co
mi
Maximum Instantaneous Forward Voltage
I F =20mA
0.37
VF
I F =200mA
Power Dissipation
0.60
PD
V R =20V
IR
V R =10V
I R =100uA
Reverse recovery time
I F =I R =200mA,Irr=0.1xI R ,R L =100Ω
IN5819W
V (BR)
or
ct
Reverse voltage
– uA
RθJA
Thermal Resistance, Junction to Ambient Air
400 mW
5
V R =30V
Reverse current
V
300°C/W
40V
trr
10ns
I FM
350mA
C tot
28pF
Junction temperature
Tj
125℃
Storage temperature
T stg
-55 ~ +150℃
Forward Continuons Current
Total capacitance
V R =0V.f=1MH Z
www.jsmsemi.com
第1/3页
1N5819W
Fig.2 Typical Reverse Characteristics
Instaneous Reverse Current ( μA)
Fig.1 Power Derating Curve
Power Dissipation (mW)
600
500
400
300
200
100
75
50
100
125
150
1000
T J =100°C
100
10
1
T J =25°C
0.1
TA, Ambient Temperature (°C)
30
40
50
Reverse Voltage(v)
MI
JS
Fig.4 Maximum Non-Repetitive Peak
Forward Surage Current
T J =25°C
Se
10
400
200
600
800
1000
T J =25°C
f=1MHz
10
1
1
10
12
09
06
03
00
1
10
100
Reverse Voltage (V)
Fig.6 Typical Transient Thermal Impedance
2000
1000
100
10
0.01
or
ct
Junction Capacitance ( pF)
Fig.5 Typical Junction Capacitance
8.3 ms Single Half Sine Wave
(JEDEC Method)
15
Number of Cycles at 50Hz
FORWARD VOLTAGE VF(mV)
100
18
u
nd
co
mi
0.1
Transient Thermal Impedance( °C /W)
T J =100°C
100
O
FORWARD CURRENT IF(mA)
CR
1000
Peak Forward Surage Current (A)
Fig.3 Forward Characteristics
0.1
1
10
100
t, Pulse Duration(sec)
www.jsmsemi.com
第2/3页
1N5819W
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SOD-123
A
D
b
E
A1
JS
C
∠ALL ROUND
MI
L1
O
CR
E1
A
UNIT
C
D
Se
max
1.3
min
0.9
max
51
8.7
min
35
3.5
mm
SOD-123 mechanical data
E
E1
L1
b
A1
0.2
0.22
1.8
2.8
3.9
0.45
0.7
0.09
1.5
2.5
3.6
0.25
0.5
u
nd
co
mi
mil
71
110
154
18
28
59
98
142
10
9°
8
or
ct
The recommended mounting pad size
Marking
Type number
2.0
(79)
1N5819W
1.2
(47)
Marking code
S4
1.2
(47)
1.2
(47)
Unit: mm
(mil)
www.jsmsemi.com
第3/3页
很抱歉,暂时无法提供与“1N5819W”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.03000
- 500+0.02700
- 5000+0.02500
- 10000+0.02400
- 30000+0.02300
- 50000+0.02240
