ES2J
ES2J
    SLKOR(萨科微)
    SMA(DO-214AC)
    快/超快恢复二极管 SMA VRRM=600V If=2A VF=1.68V
ES2J 数据手册
ES2A-ES2J Surface Mount Superfast Recovery Rectifier Reverse Voltage – 50 to 600 V PINNING Forward Current –2 A FEATURES • For surface mounted applications • Low profile package • Glass Passivated Chip Junction • Superfast reverse recovery time • Lead free in comply with EU RoHS 2011/65/EU directives 1 Cathode 2 Anode 2 1 Top View Marking Code: ES2A~ES2J Simplified outline SMA and symbol MECHANICAL DATA • Case: SMA • Terminals: Solderable per MIL-STD-750, Method 2026 • A pprox. Weight: 0.055g / 0.002oz Absolute Maximum Ratings and Characteristics Ratings at 25 °C ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load. For capacitive load, derate current by 20%. Symbols ES2A ES2B ES2C ES2D ES2E ES2G ES2J Units Maximum Repetitive Peak Reverse Voltage V RRM 50 100 150 200 300 400 600 V Maximum RMS voltage V RMS 35 70 105 140 210 280 420 V Maximum DC Blocking Voltage V DC 50 100 150 200 300 400 600 V Maximum Average Forward Rectified Current at T c = 125 °C I F(AV) 2 A Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load I FSM 50 A Maximum Forward Voltage at 2 A VF Parameter Maximum DC Reverse Current T a = 25 °C at Rated DC Blocking Voltage T a =125 °C Typical Junction Capacitance at V R =4V, f=1MHz Maximum Reverse Recovery Time (1) Typical Thermal Resistance (2) Operating and Storage Temperature Range 1.68 V IR 5 100 μA Cj 40 pF t rr 35 ns RθJA 60 °C/W T j , T stg -55 ~ +150 °C (1)Measured with I F = 0.5 A, I R = 1 A, I rr = 0.25 A . (2)P.C.B. mounted with 1.0 X 1.0" (2.54 X 2.54 cm) copper pad areas. www.slkormicro.com 1.25 1 1 ES2A-ES2J Fig.1 Reverse Recovery Time Characteristic And Test Circuit Diagram 50 ohm Noninductive t rr 10 ohm Noninductive +0.5 D.U.T + PULSE GENERATOR Note 2 25Vdc approx 0 - -0.25 1 ohm NonInductive OSCILLOSCOPE Note 1 -1.0 Note:1.Rise Time = 7ns, max. Input Impedance = 1megohm,22pF. 2. Ries Time =10ns, max. Source Impedance = 50 ohms. 10ns/div Set time Base for 10ns/div Fig.3 Typical Reverse Characteristics 3.0 300 2.5 I R - Reverse Current ( μ A) Average Forward Current (A) Fig.2 Maximum Average Forward Current Rating 2.0 1.5 1.0 0.5 Single phase half-wave 60 Hz resistive or inductive load 100 T J =125°C 10 T J =75°C 1.0 T J =25°C 0.1 0.0 25 50 75 100 125 150 175 40 20 0 Case Temperature (°C) 10 T J =25°C 1.0 ES2A~ES2D ES2E/ES2G ES2J 0.01 T J =25°C 100 10 T J=25°C f = 1.0MHz V sig = 50mV p-p 1 0.001 0.5 0 1.0 1.5 2.0 2.5 0.1 Instaneous Forward Voltage (V) 60 50 40 30 20 10 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 10 100 Number of Cycles www.slkormicro.com 1.0 10 Reverse Voltage (V) Fig.6 Maximum Non-Repetitive Peak Forward Surage Current Peak Forward Surage Current (A) 100 Fig.5 Typical Junction Capacitance Junction Capacitance ( pF) Instaneous Forward Current (A) Fig.4 Typical Forward Characteristics 0.1 80 60 % of PIV.VOLTS 2 100 ES2A-ES2J PACKAGE OUTLINE Plastic surface mounted package; 2 leads A A SMA c a b VM e A HE g e E A D E HE c e g b max 2.2 4.5 2.7 5.2 0.31 1.6 1.5 0.2 min 1.9 4.0 2.3 4.7 0.15 1.3 0.9 0.05 max 87 181 106 205 12 63 59 7.9 min 75 157 91 185 6 51 35 2 UNIT mm mil g e A D 0.3 The recommended mounting pad size 1.8 (71) ES2A 1.8 (71) 2.4 (94) mm Unit : (mil) www.slkormicro.com 12 Marking Type number 1.8 (71) a 3 Marking code ES2A ES2B ES2B ES2C ES2C ES2D ES2D ES2E ES2E ES2G ES2G ES2J ES2J
很抱歉,暂时无法提供与“ES2J”相匹配的价格&库存,您可以联系我们找货
ES2J
  • 1+0.08821
  • 100+0.08233
  • 300+0.07645
  • 500+0.07057
  • 2000+0.06763
  • 5000+0.06586
库存:3249
