Plastic-Encap sulate Diodes
Schottky Barrier Diode
PINNING
DESCRIPTION
PIN
FEATURES
z
Small surface mounting type
z
Low IR
z
High reliability
1
Cathode
2
Anode
1
D1
2
Top View
Marking Code: "D1"
Simplified outline SOD-523 and symbol
MARKING: D1
The marking bar indicates the cathode
Solid dot = Green molding compound device,if none,
the normal device.
Maximum Ratings and Electrical Characteristics, Single Diode @TA=25℃
Symbol
Limit
Unit
DC reverse voltage
VR
40
V
Mean rectifying current
IO
0.2
A
IFSM
1
A
Power Dissipation
PD
150
mW
Thermal resistance from junction to ambient
RθJA
Parameter
Non-repetitive peak forward surge current@t=8.3ms
667
Junction temperature
TJ
125
Storage temperature
TSTG
-55~+150
℃/W
Electrical Ratings @TA=25℃
Parameter
Symbol
Forward voltage
VF
Reverse current
IR
Min
Typ
Max
0.304
0.446
0.605
2.837
0.39
0.55
1
10
Unit
V
μA
Conditions
IF=10mA
IF=100mA
VR=10V
VR=40V
1 of 3
Copyright © All right reserved: Heyuan China Base Electronics Technology Co., Ltd.
C
REVERSE CURRENT IR
C
o
Ta
=2
5
1
0.1
0.01
0.0
0.2
0.4
FORWARD VOLTAGE
VF
Characteristics
o
Ta=100 C
10
o
Ta=25 C
1
0.1
0.8
(V)
10
REVERSE VOLTAGE
30
VR
40
(V)
Power Derating Curve
200
150
PD
(mW)
Ta=25℃
f=1MHz
POWER DISSIPATION
CAPACITANCE BETWEEN TERMINALS
CT (pF)
0.6
Capacitance Characteristics
100
Reverse
100
o
Ta
=1
00
(mA)
10
IF
FORWARD CURRENT
Characteristics
(uA)
Forward
100
10
1
10
REVERSE VOLTAGE
15
VR
50
100
AMBIENT TEMPERATURE
(V)
2 of 3
150
Ta
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SOD-523
3 of 3
很抱歉,暂时无法提供与“RB520S-40”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.06720
- 50+0.06216
- 200+0.05796
- 600+0.05376
- 1500+0.05040
- 3000+0.04830
