S2AF
S2MF
THRU
2.0 AMP SURFACE MOUNT SILICON RECTIFIERS
VOLTAGE RANGE
50 to 1000 Volts
CURRENT
2.0 Ampere
FEATURES
* Ideal for surface mount applications
* Easy pick and place
* Built-in strain relief
* High surge current capability
SMAF
.146(3.7)
.130(3.3)
.063(1.6)
.051(1.3)
MECHANICAL DATA
.193(4.9)
.173(4.4)
* Case: Molded plastic
* Epoxy: UL 94V-0 rate flame retardant
* Terminals: Solder plated, solderable per MIL-STD-202F,
method 208 guranteed
* Polarity: Color band denotes cathode end
* Mounting position: Any
.008(0.20)
.005(0.12)
.047(1.20)
.035(0.90)
.106(2.7)
.094(2.4)
.047(1.2)
.031(0.8)
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Rating 25 C ambient temperature uniess otherwies specified.
Single phase half wave, 60Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
TYPE NUMBER
Maximum Recurrent Peak Reverse Voltage
Maximum RMS Voltage
Maximum DC Blocking Voltage
Maximum Average Forward Rectified Current
S2AF
50
35
50
S2BF
S2DF
S2GF
S2JF
S2KF
S2MF
100
70
100
200
140
200
400
280
400
600
420
600
800
560
800
1000
700
1000
at Ta=75 C
Peak Forward Surge Current, 8.3 ms single half sine-wave
superimposed on rated load (JEDEC method)
Maximum Instantaneous Forward Voltage at 2.0A
Maximum DC Reverse Current
Ta=25 C
at Rated DC Blocking Voltage
Ta=100 C
Typical Junction Capacitance (Note 1)
Typical Thermal Resistance RqJA (Note 2)
Operating and Storage Temperature Range TJ, TSTG
2.0
A
50
A
V
1.1
5.0
100
60
47
-55
UNITS
V
V
V
+150
pF
C/W
C
NOTES:
1. Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2. Thermal Resistance from Junction to Ambient.
REV 1.0 2015 JAN
PAGE:1/2
RATING AND CHARACTERISTIC CURVES (S2AF THRU S2MF)
FIG.1-TYPICAL FORWARD
FIG.2-TYPICAL FORWARD CURRENT DERATING CURVE
CHARACTERISTICS
AVERAGE FORWARD CURRENT,(A)
10
1
3.0
2.5
2.0
1.5
1.0
0.5
Tj=25 C
40
60
80
100
120
140
160
180
200
AMBIENT TEMPERATURE ( C)
Pulse Width 300us
1% Duty Cycle
.1
.01
.6
.8
1.0
1.2
1.4
1.6
1.8
2.0
FORWARD VOLTAGE,(V)
FIG.3 - TYPICAL REVERSE
CHARACTERISTICS
PEAK FORWAARD SURGE CURRENT,(A)
FIG.4-MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
50
40
30
8.3ms Single Half
Tj=25 C
Sine Wave
JEDEC method
1
100
10
50
100
NUMBER OF CYCLES AT 60Hz
10
FIG.5-TYPICAL JUNCTION CAPACITANCE
Tj=100 C
175
1.0
Tj=25 C
.1
.01
JUNCTION CAPACITANCE,(pF)
INSTANTANEOUS FORWARD CURRENT,(A)
100
150
125
100
75
50
25
60
80
100 120 140
PERCENTAGE RATED PEAK REVERSE VOLTAGE
.05
.1
.5
1
5
10
50
100
REVERSE VOLTAGE,(V)
REV 1.0 2015 JAN
PAGE:2/2
很抱歉,暂时无法提供与“S2MF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.05100
- 150+0.04350
- 1000+0.03600
- 5000+0.03300
