RS256M32LZ4D2BNP-62BT
    RAYSON(晶存)
    VFBGA200_10X14.5MM
    200b: x32 Mobile LPDDR4X SDRAM
RS256M32LZ4D2BNP-62BT 数据手册
200b: x32 Mobile LPDDR4X SDRAM Features Mobile LPDDR4X SDRAM RS256M32LZ4D2BNP-62BT Introduction Options • VDD1/VDD2/VDDQ: 1.8V/1.1V/0.6V • Array configuration – 256 Meg x 32 (2 channels x16 I/O) – 512 Meg x 32 (2 channels x16 I/O) – 1024 Meg x 32 (2 channels x8 I/O x 2) • Device configuration – 256M16 x 2 channel x 1 die – 256M16 x 2 channel x 2 die – 512M8 x 2 channel x 4 die • FBGA “green” package – 200-ball VFBGA (10mm x 14.5mm x 0.95mm) • Speed grade, cycle time – 625ps @ RL = 28/32 (x16 device) – 625ps @ RL = 32/36 (x8 device) – 755ps @ RL= 24/28 (x16 device) This product supports both LPDDR4 (VDDQ = 1.1V) and LPDDR4X (VDDQ = 0.6V) operations. Only LPDDR4X specification is available in this data sheet. Features • Ultra-low-voltage core and I/O power supplies – VDD1 = 1.70–1.95V; 1.8V nominal – VDD2 = 1.06–1.17V; 1.1V nominal – VDDQ = 0.57–0.65V; 0.6V nominal • Frequency range – 1600–10 MHz (data rate range: 3200–20 Mb/s/ pin) • 16n prefetch DDR architecture • 8 internal banks per channel for concurrent operation • Single-data-rate CMD/ADR entry • Bidirectional/differential data strobe per byte lane • Programmable READ and WRITE latencies (RL/WL) • Programmable and on-the-fly burst lengths (BL = 16, 32) • Directed per-bank refresh for concurrent bank operation and ease of command scheduling • Up to 8.53 GB/s per die (×16) , Up to 4.62 GB/s per die (×8) • On-chip temperature sensor to control self refresh rate • Partial-array self refresh (PASR) • Selectable output drive strength (DS) • Clock-stop capability • RoHS-compliant, “green” packaging • Programmable V SS (ODT) termination Marking B 256M32 512M32 1024M32 D1 D2 D4 NP -62 -75 – 755ps @ RL= 28/32 (x8 device) • Operating temperature range Table 1: Key Timing Parameters Speed Grade -62 -75 Array configuration WRITE Latency READ Latency Device Type Clock Rate (MHz) Data Rate (Mb/s/pin) Set A Set B DBI Disabled DBI Enabled x16 device 1600 3200 14 26 28 32 1024Mb x 32 x8 device 1600 3200 14 26 32 36 256Mb x 32 512Mb x 32 x16 device 1333 2667 12 22 24 28 1024Mb x 32 x8 device 1333 2667 12 22 28 32 256Mb x 32 512Mb x 32 1 200b: x32 Mobile LPDDR4X SDRAM SDRAM Addressing SDRAM Addressing The table below shows the addressing for the 8Gb die density. Where applicable, a distinction is made between per-channel and per-die parameters. All bank, row, and column addresses are shown per-channel. Table 2: Device Addressing Configuration 256M32 (8Gb) 512M32 (16Gb) 1 2 4 Device density (per die) 8Gb 8Gb 8Gb Device density (per channel) 4Gb 8Gb 16Gb Die per package Configuration 1024M32 (32Gb) 32Mb x 16 DQ x 8 banks 32Mb x 16 DQ x 8 banks 64Mb x 8 DQ x 8 banks x 2 channels x 1 rank x 2 channels x 2 ranks x 2 channels x 2 ranks x 2 Number of channels (per die) 2 2 2 Number of ranks per channel 1 2 2 Number of banks (per channel) 8 8 8 Array prefetch (bits) (per channel) Number of rows (per bank) Number of columns (fetch boundaries) Page size (bytes) 256 256 128 32,768 32,768 65,536 64 64 32 2048 2048 1024 Channel density (bits per channel) 4,294,967,296 8,589,934,592 17,179,869,184 Total density (bits per die) 8,589,934,592 8,589,934,592 8,589,934,592 BA[2:0] BA[2:0] BA[2:0] – Bank address x16 Row addresses R[14:0] R[14:0] Column addresses C[9:0] C[9:0] – x8 Row addresses – – R[15:0] Column addresses – – C[9:0] 64-bit 64-bit 64-bit Burst starting address boundary Notes: 3 1. The lower two column addresses (C0–C1) are assumed to be zero and are not transmitted on the CA bus. 2. Row and column address values on the CA bus that are not used for a particular density are "Don't Care." 3. Refer to Byte Mode section for further information about 1024M32 (32Gb) configuration. 2 200b: x32 Mobile LPDDR4X SDRAM Part Number Ordering Information Part Number Ordering Information Figure 1: Part Number Chart RS 256M32 LZ4 D2 B NP - 62 BT Rayson Configuration 256M32 = 256 Meg x 32 Product Family LZ4= Mobile LPDDR4 SDRAM(This datasheet for LPDDR4X) Packaging BT = Dry Pack(Tray) BR= Tape and Reel Addressing D2 = LPDDR4, 2 die D4 = LPDDR4, 4 die Speed 62= 3200Mbps Package code NP= 200ball FBGA-10*14.5*1.0mm Operating Voltage A= 1.10V VDD2 / 0.60V or 1.10V VDDQ 3 200b: x32 Mobile LPDDR4X SDRAM Part Number Ordering Information Contents General Description ....................................................................................................................................... 17 General Notes ............................................................................................................................................ 17 Package Block Diagrams ................................................................................................................................. 18 Ball Assignments and Descriptions ................................................................................................................. 21 Package Dimensions ....................................................................................................................................... 23 MR0, MR[6:3], MR8, MR13 Readout ................................................................................................................. 25 IDD Parameters ............................................................................................................................................... 26 Functional Description ................................................................................................................................... 28 Monolithic Device Addressing ......................................................................................................................... 28 Simplified Bus Interface State Diagram ............................................................................................................ 32 Power-Up and Initialization ............................................................................................................................ 33 Voltage Ramp ............................................................................................................................................. 34 Reset Initialization with Stable Power .......................................................................................................... 36 Power-Off Sequence ....................................................................................................................................... 37 Controlled Power-Off .................................................................................................................................. 37 Uncontrolled Power-Off .............................................................................................................................. 37 Mode Registers ............................................................................................................................................... 38 Mode Register Assignments and Definitions ................................................................................................ 38 Commands and Timing .................................................................................................................................. 64 Truth Tables ................................................................................................................................................... 64 ACTIVATE Command ..................................................................................................................................... 67 Read and Write Access Modes ......................................................................................................................... 68 Preamble and Postamble ................................................................................................................................ 69 Burst READ Operation .................................................................................................................................... 72 Read Timing ............................................................................................................................................... 74 tLZ(DQS), tLZ(DQ), tHZ(DQS), tHZ(DQ) Calculation ..................................................................................... 74 tLZ(DQS) and tHZ(DQS) Calculation for ATE (Automatic Test Equipment) .................................................... 75 tLZ(DQ) and tHZ(DQ) Calculation for ATE (Automatic Test Equipment) ........................................................ 76 Burst WRITE Operation .................................................................................................................................. 78 Write Timing .............................................................................................................................................. 80 tWPRE Calculation for ATE (Automatic Test Equipment) .............................................................................. 81 tWPST Calculation for ATE (Automatic Test Equipment) ............................................................................... 81 MASK WRITE Operation ................................................................................................................................. 82 Mask Write Timing Constraints for BL16 ...................................................................................................... 84 Data Mask and Data Bus Inversion (DBI[DC]) Function ................................................................................... 86 Preamble and Postamble Behavior .................................................................................................................. 90 Preamble, Postamble Behavior in READ-To-READ Operations ...................................................................... 90 READ to READ Operations – Seamless ......................................................................................................... 90 READ to READ Operations – Consecutive .................................................................................................... 91 Write to Write Operations – Seamless .......................................................................................................... 98 Write to Write Operations – Consecutive ..................................................................................................... 101 PRECHARGE Operation ................................................................................................................................. 105 Burst Read Operation Followed by Precharge .............................................................................................. 105 Burst Write Followed by Precharge ............................................................................................................. 106 Auto Precharge .............................................................................................................................................. 107 Burst READ With Auto Precharge ............................................................................................................... 107 Burst WRITE With Auto Precharge .............................................................................................................. 108 RAS Lock Function .................................................................................................................................... 112 Delay time from Write to Read with Auto Precharge .................................................................................... 113 REFRESH Command ..................................................................................................................................... 114 4 200b: x32 Mobile LPDDR4X SDRAM Part Number Ordering Information Refresh Requirement ..................................................................................................................................... 119 SELF REFRESH Operation .............................................................................................................................. 120 Self Refresh Entry and Exit ......................................................................................................................... 120 Power-Down Entry and Exit During Self Refresh ......................................................................................... 121 Command Input Timing After Power Down Exit .......................................................................................... 122 Self Refresh Abort ...................................................................................................................................... 123 MRR, MRW, MPC Command During tXSR, tRFC .......................................................................................... 123 Power-Down Mode ........................................................................................................................................ 126 Power-Down Entry and Exit ....................................................................................................................... 126 Input Clock Stop and Frequency Change ........................................................................................................ 136 Clock Frequency Change – CKE LOW ......................................................................................................... 136 Clock Stop – CKE LOW ............................................................................................................................... 136 Clock Frequency Change – CKE HIGH ........................................................................................................ 136 Clock Stop – CKE HIGH ............................................................................................................................. 137 MODE REGISTER READ Operation ................................................................................................................ 138 MRR after Read and Write Command ......................................................................................................... 139 MRR after Power-Down Exit ....................................................................................................................... 141 MODE REGISTER WRITE ............................................................................................................................... 142 Mode Register Write States ......................................................................................................................... 142 VREF Current Generator (VRCG) ..................................................................................................................... 144 VREF Training ................................................................................................................................................. 146 VREF(CA) Training ........................................................................................................................................ 146 VREF(DQ) Training ....................................................................................................................................... 151 Command Bus Training ................................................................................................................................. 156 Command Bus Training Mode .................................................................................................................... 156 Training Sequence for Single-Rank Systems ................................................................................................ 157 Training Sequence for Multiple-Rank Systems ............................................................................................ 158 Relation between CA Input pin DQ Output pin ........................................................................................... 159 Write Leveling ............................................................................................................................................... 163 Mode Register Write-WR Leveling Mode ..................................................................................................... 163 Write-Leveling Procedure: .......................................................................................................................... 163 Input Clock Frequency Stop and Change .................................................................................................... 164 MULTIPURPOSE Operation ........................................................................................................................... 167 Read DQ Calibration Training ........................................................................................................................ 172 Read DQ Calibration Procedure ................................................................................................................. 172 DQ Read Training Example ........................................................................................................................ 174 MPC of Read DQ Calibration after Power-Down Exit ................................................................................... 175 Write Training ............................................................................................................................................... 176 Internal Interval Timer .............................................................................................................................. 181 DQS Interval Oscillator Matching Error ...................................................................................................... 183 OSC Count Readout Time .......................................................................................................................... 184 Thermal Offset .............................................................................................................................................. 186 Temperature Sensor ...................................................................................................................................... 186 ZQ Calibration ............................................................................................................................................... 187 ZQCAL Reset ............................................................................................................................................. 188 Multichannel Considerations ..................................................................................................................... 189 ZQ External Resistor, Tolerance, and Capacitive Loading ............................................................................. 189 Frequency Set Points ..................................................................................................................................... 190 Frequency set point update Timing ............................................................................................................ 191 Pull-Up and Pull-Down Characteristics and Calibration .................................................................................. 195 On-Die Termination for the Command/Address Bus ....................................................................................... 196 ODT Mode Register and ODT State Table .................................................................................................... 196 5 200b: x32 Mobile LPDDR4X SDRAM Part Number Ordering Information ODT Mode Register and ODT Characteristics ............................................................................................. 197 ODT for CA Update Time ........................................................................................................................... 199 DQ On-Die Termination ................................................................................................................................ 199 Output Driver and Termination Register Temperature and Voltage Sensitivity .............................................. 202 ODT Mode Register ................................................................................................................................... 203 Asynchronous ODT ................................................................................................................................... 203 DQ ODT During Power-Down and Self Refresh Modes ................................................................................ 205 ODT During Write Leveling Mode .............................................................................................................. 205 TRR Mode – Target Row Refresh ..................................................................................................................... 206 TRR Mode Operation ................................................................................................................................. 206 Post-Package Repair ...................................................................................................................................... 208 Failed Row Address Repair ......................................................................................................................... 208 Read Preamble Training ................................................................................................................................. 210 Electrical Specifications ................................................................................................................................. 211 Absolute Maximum Ratings ....................................................................................................................... 211 AC and DC Operating Conditions ................................................................................................................... 211 AC and DC Input Measurement Levels ........................................................................................................... 213 Input Levels for CKE .................................................................................................................................. 213 Differential Input Voltage for CK ................................................................................................................ 213 Peak Voltage Calculation Method ............................................................................................................... 214 Single-Ended Input Voltage for Clock ......................................................................................................... 214 Differential Input Slew Rate Definition for Clock ......................................................................................... 215 Differential Input Cross-Point Voltage ........................................................................................................ 217 Differential Input Voltage for DQS .............................................................................................................. 217 Peak Voltage Calculation Method ............................................................................................................... 218 Single-Ended Input Voltage for DQS ........................................................................................................... 219 Differential Input Slew Rate Definition for DQS .......................................................................................... 220 Differential Input Cross-Point Voltage ........................................................................................................ 221 Input Levels for ODT ................................................................................................................................. 222 AC and DC Output Measurement Levels ......................................................................................................... 222 Single-Ended Output Slew Rate .................................................................................................................. 222 Differential Output Slew Rate ..................................................................................................................... 223 Overshoot and Undershoot Specifications .................................................................................................. 224 Driver Output Timing Reference Load ............................................................................................................ 225 LVSTL I/O System .......................................................................................................................................... 225 Input/Output Capacitance ............................................................................................................................. 227 IDD Specification Parameters and Test Conditions ........................................................................................... 228 IDD Specifications ...................................................................................................................................... 232 AC Timing ..................................................................................................................................................... 234 CA Rx Voltage and Timing .............................................................................................................................. 244 DQ Tx Voltage and Timing ............................................................................................................................. 247 DRAM Data Timing ................................................................................................................................... 247 DQ Rx Voltage and Timing ............................................................................................................................. 248 Clock Specification ........................................................................................................................................ 251 tCK(abs), tCH(abs), and tCL(abs) ................................................................................................................ 252 Clock Period Jitter .......................................................................................................................................... 252 Clock Period Jitter Effects on Core Timing Parameters ................................................................................. 252 Cycle Time Derating for Core Timing Parameters ........................................................................................ 253 Clock Cycle Derating for Core Timing Parameters ....................................................................................... 253 Clock Jitter Effects on Command/Address Timing Parameters ..................................................................... 253 Clock Jitter Effects on READ Timing Parameters .......................................................................................... 253 Clock Jitter Effects on WRITE Timing Parameters ........................................................................................ 254 6 200b: x32 Mobile LPDDR4X SDRAM Part Number Ordering Information Byte Mode ..................................................................................................................................................... 255 Monolithic Device Addressing (Byte Mode) ................................................................................................ 255 Mode Register ........................................................................................................................................... 256 Mode Register Assignments and Definitions ........................................................................................... 256 Command Truth Table ............................................................................................................................... 266 Command Bus Training ............................................................................................................................. 267 Training Mode 1 .................................................................................................................................... 267 Training Sequence of Mode 1 for Single-Rank Systems ............................................................................ 268 Training Sequence of Mode 1 for Multi-Rank Systems ............................................................................. 269 Relation between the CA Input Pin and the DQ Output Pin for Mode 1 .................................................... 270 Timing for CA Training Mode 1 ............................................................................................................... 270 Read DQ Training ...................................................................................................................................... 272 RD DQ Calibration Training Procedure ................................................................................................... 273 DQ Read Training Example .................................................................................................................... 274 On-Die Termination .................................................................................................................................. 274 ODT Control ......................................................................................................................................... 274 AC Timing ................................................................................................................................................. 276 Revision History ............................................................................................................................................ 278 Rev. B– 4/16 ............................................................................................................................................... 278 Rev. A – 7/15 .............................................................................................................................................. 278 7 200b: x32 Mobile LPDDR4X SDRAM Part Number Ordering Information List of Figures Figure 1: Part Number Chart ............................................................................................................................ 3 Figure 2: Single-Die, Dual-Channel Package Block Diagram ............................................................................ 18 Figure 3: Dual-Die, Dual-Channel Package Block Diagram .............................................................................. 19 Figure 4: Quad-Die, Dual-Channel Package Block Diagram ............................................................................. 20 Figure 5: 200-Ball Dual-Channel Discrete FBGA ............................................................................................. 21 Figure 6: 200-Ball WFBGA – 10mm x 14.5mm (Package Code: NP) ................................................................... 23 Figure 7: 200-Ball VFBGA – 10mm x 14.5mm (Package Code: NQ) .................................................................... 24 Figure 8: Simplified State Diagram ................................................................................................................. 32 Figure 9: Simplified State Diagram ................................................................................................................. 33 Figure 10: Voltage Ramp and Initialization Sequence ...................................................................................... 35 Figure 11: ACTIVATE Command .................................................................................................................... 68 Figure 12: tFAW Timing .................................................................................................................................. 68 Figure 13: DQS Read Preamble and Postamble – Toggling Preamble and 0.5nCK Postamble ............................. 69 Figure 14: DQS Read Preamble and Postamble – Static Preamble and 1.5nCK Postamble .................................. 69 Figure 15: DQS Write Preamble and Postamble – 0.5nCK Postamble ................................................................ 70 Figure 16: DQS Write Preamble and Postamble – 1.5nCK Postamble ................................................................ 71 Figure 17: Burst Read Timing ......................................................................................................................... 72 Figure 18: Burst Read Followed by Burst Write or Burst Mask Write .................................................................. 73 Figure 19: Seamless Burst Read ...................................................................................................................... 73 Figure 20: Read Timing .................................................................................................................................. 74 Figure 21: tLZ(DQS) Method for Calculating Transitions and Endpoint ............................................................ 75 Figure 22: tHZ(DQS) Method for Calculating Transitions and Endpoint ........................................................... 75 Figure 23: tLZ(DQ) Method for Calculating Transitions and Endpoint .............................................................. 76 Figure 24: tHZ(DQ) Method for Calculating Transitions and Endpoint ............................................................. 77 Figure 25: Burst WRITE Operation ................................................................................................................. 78 Figure 26: Burst Write Followed by Burst Read ................................................................................................ 79 Figure 27: Write Timing ................................................................................................................................. 80 Figure 28: Method for Calculating tWPRE Transitions and Endpoints ............................................................... 81 Figure 29: Method for Calculating tWPST Transitions and Endpoints ............................................................... 81 Figure 30: Mask Write Command - Same Bank ............................................................................................... 82 Figure 31: Masked Write Command - Different Bank ...................................................................................... 83 Figure 32: MASKED WRITE Command with Write DBI Enabled; DM Enabled .................................................. 88 Figure 33: WRITE Command with Write DBI Enabled; DM Disabled ................................................................ 89 Figure 34: READ Operations: tCCD = Min, Preamble = Toggle, 1.5nCK Postamble ............................................. 90 Figure 35: Seamless READ: tCCD = Min +1, Preamble = Toggle, 1.5nCK Postamble ........................................... 91 Figure 36: Consecutive READ: tCCD = Min +1, Preamble = Toggle, 0.5nCK Postamble ....................................... 91 Figure 37: Consecutive READ: tCCD = Min +1, Preamble = Static, 1.5nCK Postamble ........................................ 92 Figure 38: Consecutive READ: tCCD = Min +1, Preamble = Static, 0.5nCK Postamble ........................................ 92 Figure 39: Consecutive READ: tCCD = Min + 2, Preamble = Toggle, 1.5nCK Postamble ...................................... 93 Figure 40: Consecutive READ: tCCD = Min + 2, Preamble = Toggle, 0.5nCK Postamble ...................................... 94 Figure 41: Consecutive READ: tCCD = Min + 2, Preamble = Static, 1.5nCK Postamble ....................................... 94 Figure 42: Consecutive READ: tCCD = Min + 2, Preamble = Static, 0.5nCK Postamble ....................................... 95 Figure 43: Consecutive READ: tCCD = Min + 3, Preamble = Toggle, 1.5nCK Postamble ...................................... 96 Figure 44: Consecutive READ: tCCD = Min + 3, Preamble = Toggle, 0.5nCK Postamble ...................................... 96 Figure 45: Consecutive READ: tCCD = Min + 3, Preamble = Static, 1.5nCK Postamble ....................................... 97 Figure 46: Consecutive READ: tCCD = Min + 3, Preamble = Static, 0.5nCK Postamble ....................................... 97 Figure 47: Seamless Write: tCCD = Min, 0.5nCK Postamble .............................................................................. 98 Figure 48: Seamless Write: tCCD = Min, 1.5nCK Postamble, 533MHz < Clock Frequency ≤ 800MHz, ODT Worst Timing Case ............................................................................................................................................... 99 Figure 49: Seamless Write: tCCD = Min, 1.5nCK Postamble ............................................................................. 100 8 200b: x32 Mobile LPDDR4X SDRAM Part Number Ordering Information Figure 50: Consecutive Write: tCCD = Min + 1, 0.5nCK Postamble ................................................................... 101 Figure 51: Consecutive Write: tCCD = Min + 1, 1.5nCK Postamble ................................................................... 101 Figure 52: Consecutive Write: tCCD = Min + 2, 0.5nCK Postamble ................................................................... 102 Figure 53: Consecutive Write: tCCD = Min + 2, 1.5nCK Postamble ................................................................... 102 Figure 54: Consecutive Write: tCCD = Min + 3, 0.5nCK Postamble ................................................................... 103 Figure 55: Consecutive Write: tCCD = Min + 3, 1.5nCK Postamble ................................................................... 104 Figure 56: Consecutive Write: tCCD = Min + 4, 1.5nCK Postamble ................................................................... 104 Figure 57: Burst Read Followed by Precharge – BL16, Toggling Preamble, 0.5nCK Postamble ........................... 106 Figure 58: Burst Read Followed by Precharge – BL32, 2tCK, 0.5nCK Postamble ................................................ 106 Figure 59: Burst WRITE Followed by PRECHARGE – BL16, 2nCK Preamble, 0.5nCK Postamble ........................ 107 Figure 60: Burst READ With Auto Precharge – BL16, Non-Toggling Preamble, 0.5nCK Postamble ..................... 108 Figure 61: Burst READ With Auto Precharge – BL32, Toggling Preamble, 1.5nCK Postamble ............................. 108 Figure 62: Burst WRITE With Auto Precharge – BL16, 2 nCK Preamble, 0.5nCK Postamble ................................ 109 Figure 63: Command Input Timing with RAS Lock ......................................................................................... 113 Figure 64: Delay Time from Write to Read with Auto Precharge ...................................................................... 113 Figure 65: All-Bank REFRESH Operation ....................................................................................................... 116 Figure 66: Per Bank REFRESH Operation ....................................................................................................... 117 Figure 67: Postponing REFRESH Commands (Example) ................................................................................. 119 Figure 68: Pulling In REFRESH Commands (Example) ................................................................................... 119 Figure 69: Self Refresh Entry/Exit Timing ...................................................................................................... 121 Figure 70: Self Refresh Entry/Exit Timing with Power-Down Entry/Exit .......................................................... 122 Figure 71: Command Input Timings after Power-Down Exit during Self Refresh .............................................. 123 Figure 72: MRR, MRW, and MPC Commands Issuing Timing During tXSR ....................................................... 124 Figure 73: MRR, MRW, and MPC Commands Issuing Timing During tRFC ...................................................... 125 Figure 74: Basic Power-Down Entry and Exit Timing ...................................................................................... 127 Figure 75: Read and Read with Auto Precharge to Power-Down Entry ............................................................. 128 Figure 76: Write and Mask Write to Power-Down Entry .................................................................................. 129 Figure 77: Write with Auto Precharge and Mask Write with Auto Precharge to Power-Down Entry .................... 130 Figure 78: Refresh Entry to Power-Down Entry .............................................................................................. 131 Figure 79: Activate Command to Power-Down Entry ...................................................................................... 131 Figure 80: Precharge Command to Power-Down Entry ................................................................................... 132 Figure 81: Mode Register Read to Power-Down Entry ..................................................................................... 133 Figure 82: Mode Register Write to Power-Down Entry .................................................................................... 134 Figure 83: Multi Purpose Command for Start ZQ Calibration to Power-Down Entry ......................................... 135 Figure 84: MODE REGISTER READ Operation ............................................................................................... 139 Figure 85: READ to MRR Timing ................................................................................................................... 140 Figure 86: Write to MRR Timing .................................................................................................................... 141 Figure 87: MRR Following Power-Down ......................................................................................................... 142 Figure 88: MODE REGISTER WRITE Timing .................................................................................................. 142 Figure 89: VRCG Enable Timing .................................................................................................................... 145 Figure 90: VRCG Disable Timing ................................................................................................................... 145 Figure 91: V REF Operating Range (VREF,max, V REF,min) ....................................................................................... 146 Figure 92: V REF Set-Point Tolerance and Step Size .......................................................................................... 147 Figure 93: tVref for Short, Middle and Long Timing Diagram ........................................................................... 148 Figure 94: V REF(CA) Single-Step Increment ...................................................................................................... 148 Figure 95: V REF(CA) Single-Step Decrement ..................................................................................................... 149 Figure 96: V REF(CA) Full Step from V REF,min to V REF,max ...................................................................................... 149 Figure 97: V REF(CA) Full Step from V REF,max to V REF,min ...................................................................................... 149 Figure 98: V REF Operating Range (VREF,max, V REF,min) ....................................................................................... 151 Figure 99: V REF Set Tolerance and Step Size .................................................................................................... 152 Figure 100: V REF(DQ) Transition Time for Short, Middle, or Long Changes ........................................................ 153 Figure 101: V REF(DQ) Single-Step Size Increment ............................................................................................. 153 9 200b: x32 Mobile LPDDR4X SDRAM Part Number Ordering Information Figure 102: Figure 103: Figure 104: Figure 105: Figure 106: Figure 107: Figure 108: Figure 109: Figure 110: Figure 111: Figure 112: Figure 113: Figure 114: Figure 115: Figure 116: Figure 117: Figure 118: Figure 119: Figure 120: Figure 121: Figure 122: Figure 123: Figure 124: Figure 125: Figure 126: Figure 127: Figure 128: Figure 129: Figure 130: Figure 131: Figure 132: Figure 133: Figure 134: Figure 135: Figure 136: Figure 137: Figure 138: Figure 139: Figure 140: Figure 141: Figure 142: Figure 143: Figure 144: Figure 145: Figure 146: Figure 147: Figure 148: Figure 149: Figure 150: Figure 151: Figure 152: Figure 153: V REF(DQ) Single-Step Size Decrement ............................................................................................ 154 V REF(DQ) Full Step from V REF,min to V REF,max ................................................................................... 154 V REF(DQ) Full Step from V REF,max to V REF,min ................................................................................... 154 Command Bus Training Mode Entry – CA Training Pattern I/O With V REF(CA) Value Update ............ 159 Consecutive V REF(CA) Value Update .............................................................................................. 160 Command Bus Training Mode Exit With Valid Command ............................................................. 161 Command Bus Training Mode Exit With Power-Down Entry ......................................................... 162 Write-Leveling Timing – tDQSL (MAX) ......................................................................................... 164 Write Leveling Timing – tDQSL (MIN) .......................................................................................... 164 Clock Stop and Timing During Write Leveling .............................................................................. 165 DQS_t/DQS_c to CK_t/CK_t Timings at the Pins Referenced from the Internal Latch ..................... 166 WR-FIFO – tWPRE = 2nCK, tWPST = 0.5nCK ................................................................................. 168 RD-FIFO – tWPRE = 2nCK, tWPST = 0.5nCK, tRPRE = Toggling, tRPST = 1.5nCK .............................. 169 RD-FIFO – tRPRE = Toggling, tRPST = 1.5nCK ............................................................................... 170 DQ Read Training Timing: Read to Read DQ Calibration ............................................................... 173 DQ Read Training Timing: Read DQ Calibration to Read DQ Calibration/Read .............................. 173 MPC Read DQ Calibration Following Power-Down State ............................................................... 175 WRITE to MPC [WRITE FIFO] Operation Timing .......................................................................... 177 MPC [WRITE FIFO] to MPC [READ FIFO] Timing ......................................................................... 178 MPC [READ FIFO] to Read Timing ............................................................................................... 179 MPC [WRITE FIFO] with DQ ODT Timing .................................................................................... 180 Power Down Exit to MPC [WRITE FIFO] Timing ........................................................................... 181 Interval Oscillator Offset – OSCoffset ............................................................................................. 183 In case of DQS Interval Oscillator is stopped by MPC Command ................................................... 184 In case of DQS Interval Oscillator is stopped by DQS interval timer ............................................... 185 Temperature Sensor Timing ........................................................................................................ 187 ZQCal Timing ............................................................................................................................. 188 Frequency Set Point Switching Timing ......................................................................................... 192 Training for Two Frequency Set Points ......................................................................................... 194 Example of Switching Between Two Trained Frequency Set Points ................................................ 194 Example of Switching to a Third Trained Frequency Set Point ....................................................... 195 ODT for CA ................................................................................................................................. 196 ODT for CA Setting Update Timing in 4-Clock Cycle Command .................................................... 199 Functional Representation of DQ ODT ........................................................................................ 200 Asynchronous ODTon/ODToff Timing ......................................................................................... 204 Target Row Refresh Mode ............................................................................................................ 207 Post-Package Repair Timing ........................................................................................................ 209 Read Preamble Training .............................................................................................................. 210 AC Input Timing Definition ......................................................................................................... 213 CK Differential Input Voltage ....................................................................................................... 213 Definition of Differential Clock Peak Voltage ................................................................................ 214 Clock Single-Ended Input Voltage ................................................................................................ 215 Differential Input Slew Rate Definition for CK_t, CK_c .................................................................. 216 V ix Definition (Clock) .................................................................................................................. 217 DQS Differential Input Voltage .................................................................................................... 218 Definition of Differential DQS Peak Voltage .................................................................................. 219 DQS Single-Ended Input Voltage ................................................................................................. 219 Differential Input Slew Rate Definition for DQS_t, DQS_c ............................................................. 220 V ix Definition (DQS) .................................................................................................................... 221 Single-Ended Output Slew Rate Definition ................................................................................... 223 Differential Output Slew Rate Definition ...................................................................................... 224 Overshoot and Undershoot Definition ......................................................................................... 225 10 200b: x32 Mobile LPDDR4X SDRAM Part Number Ordering Information Figure 154: Figure 155: Figure 156: Figure 157: Figure 158: Figure 159: Figure 160: Figure 161: Figure 162: Figure 163: Figure 164: Figure 165: Figure 166: Figure 167: Figure 168: Figure 169: Figure 170: Figure 171: Figure 172: Figure 173: Driver Output Timing Reference Load ......................................................................................... 225 LVSTL I/O Cell ............................................................................................................................ 226 Pull-Up Calibration ..................................................................................................................... 227 tCMDCKE Timing ....................................................................................................................... 238 tESCKE Timing ........................................................................................................................... 241 CA Receiver (Rx) Mask ................................................................................................................ 244 Across Pin V REF CA Voltage Variation ............................................................................................ 244 CA Timings at the DRAM Pins ..................................................................................................... 245 CA tcIPW and SRIN_cIVW Definition (for Each Input Pulse) .......................................................... 245 CA V IHL_AC Definition (for Each Input Pulse) ................................................................................ 245 Read Data Timing Definitions – tQH and tDQSQ Across DQ Signals per DQS Group ....................... 247 DQ Receiver (Rx) Mask ................................................................................................................ 248 Across Pin V REF DQ Voltage Variation ........................................................................................... 248 DQ-to-DQS tDQS2DQ and tDQDQ .............................................................................................. 249 DQ tDIPW and SRIN_dIVW Definition for Each Input Pulse .......................................................... 250 DQ V IHL(AC) Definition (for Each Input Pulse) ............................................................................... 250 Entering CBT Mode and CA Training Pattern (Input and Output) .................................................. 270 Exiting CBT Mode with Valid Command ...................................................................................... 271 Exiting CBT Mode with Power Down Entry ................................................................................... 272 DQ Read Training Timing ............................................................................................................ 274 11 200b: x32 Mobile LPDDR4X SDRAM Part Number Ordering Information List of Tables Table 1: Key Timing Parameters ....................................................................................................................... 1 Table 2: Device Addressing .............................................................................................................................. 2 Table 3: Ball/Pad Descriptions ....................................................................................................................... 22 Table 4: Mode Register Contents .................................................................................................................... 25 Table 5: IDD Parameters – Single-Die .............................................................................................................. 26 Table 6: IDD6 Full-Array Self Refresh Current ................................................................................................... 27 Table 7: Monolithic Device Addressing – 2 Channels per Die ........................................................................... 29 Table 8: Monolithic Device Addressing – 1 Channel per Die ............................................................................. 30 Table 9: Mode Register Default Settings .......................................................................................................... 34 Table 10: Voltage Ramp Conditions ................................................................................................................ 34 Table 11: Initialization Timing Parameters ...................................................................................................... 36 Table 12: Reset Timing Parameter .................................................................................................................. 37 Table 13: Power Supply Conditions ................................................................................................................ 37 Table 14: Power-Off Timing ............................................................................................................................ 38 Table 15: Mode Register Assignments ............................................................................................................. 38 Table 16: MR0 Device Feature 0 (MA[7:0] = 00h) .............................................................................................. 39 Table 17: MR0 Op-Code Bit Definitions .......................................................................................................... 39 Table 18: MR1 Device Feature 1 (MA[7:0] = 01h) .............................................................................................. 40 Table 19: MR1 Op-Code Bit Definitions .......................................................................................................... 40 Table 20: Burst Sequence ............................................................................................................................... 42 Table 21: MR2 Device Feature 2 (MA[7:0] = 02h) .............................................................................................. 43 Table 22: MR2 Op-Code Bit Definitions .......................................................................................................... 43 Table 23: Frequency Ranges for RL, WL, nWR and nRTP Settings ..................................................................... 45 Table 24: MR3 I/O Configuration 1 (MA[7:0] = 03h) ......................................................................................... 45 Table 25: MR3 Op-Code Bit Definitions .......................................................................................................... 46 Table 26: MR4 Device Temperature (MA[7:0] = 04h) ........................................................................................ 47 Table 27: MR4 Op-Code Bit Definitions .......................................................................................................... 47 Table 28: MR5 Basic Configuration 1 (MA[7:0] = 05h) ...................................................................................... 48 Table 29: MR5 Op-Code Bit Definitions .......................................................................................................... 48 Table 30: MR6 Basic Configuration 2 (MA[7:0] = 06h) ...................................................................................... 48 Table 31: MR6 Op-Code Bit Definitions .......................................................................................................... 48 Table 32: MR7 Basic Configuration 3 (MA[7:0] = 07h) ...................................................................................... 48 Table 33: MR7 Op-Code Bit Definitions .......................................................................................................... 48 Table 34: MR8 Basic Configuration 4 (MA[7:0] = 08h) ...................................................................................... 49 Table 35: MR8 Op-Code Bit Definitions .......................................................................................................... 49 Table 36: MR9 Test Mode (MA[7:0] = 09h) ....................................................................................................... 49 Table 37: MR9 Op-Code Definitions ............................................................................................................... 49 Table 38: MR10 Calibration (MA[7:0] = 0Ah) ................................................................................................... 49 Table 39: MR10 Op-Code Bit Definitions ........................................................................................................ 50 Table 40: MR11 ODT Control (MA[7:0] = 0Bh) ................................................................................................. 50 Table 41: MR11 Op-Code Bit Definitions ........................................................................................................ 50 Table 42: MR12 Register Information (MA[7:0] = 0Ch) ..................................................................................... 51 Table 43: MR12 Op-Code Bit Definitions ........................................................................................................ 51 Table 44: MR13 Register Control (MA[7:0] = 0Dh) ............................................................................................ 51 Table 45: MR13 Op-Code Bit Definition .......................................................................................................... 52 Table 46: Mode Register 14 (MA[7:0] = 0Eh) .................................................................................................... 53 Table 47: MR14 Op-Code Bit Definition .......................................................................................................... 53 Table 48: V REF Setting for Range[0] and Range[1] ............................................................................................. 54 Table 49: MR15 Register Information (MA[7:0] = 0Fh) ..................................................................................... 55 Table 50: MR15 Op-code Bit Definition .......................................................................................................... 55 12 200b: x32 Mobile LPDDR4X SDRAM Part Number Ordering Information Table 51: MR15 Invert Register Pin Mapping ................................................................................................... 55 Table 52: MR16 PASR Bank Mask (MA[7:0] = 010h) .......................................................................................... 55 Table 53: MR16 Op-Code Bit Definitions ........................................................................................................ 55 Table 54: MR17 PASR Segment Mask (MA[7:0] = 11h) ...................................................................................... 56 Table 55: MR17 PASR Segment Mask Definitions ............................................................................................ 56 Table 56: MR17 PASR Segment Mask .............................................................................................................. 56 Table 57: MR18 Register Information (MA[7:0]=12h) ....................................................................................... 57 Table 58: MR18 LSB DQS Oscillator Count ...................................................................................................... 57 Table 59: MR19 Register Information (MA[7:0] = 13h) ..................................................................................... 57 Table 60: MR19 DQS Oscillator Count ............................................................................................................ 57 Table 61: MR20 Register Information (MA[7:0] = 14h) ..................................................................................... 58 Table 62: MR20 Register Information ............................................................................................................. 58 Table 63: MR20 Invert Register Pin Mapping ................................................................................................... 58 Table 64: MR21 Register Information (MA[7:0] = 15h) ..................................................................................... 58 Table 65: MR22 Register Information (MA[7:0] = 16h) ..................................................................................... 58 Table 66: MR22 Register Information ............................................................................................................. 59 Table 67: MR23 Register Information (MA[7:0] = 17h) ..................................................................................... 60 Table 68: MR23 Register Information ............................................................................................................. 60 Table 69: MR24 Register Information (MA[7:0] = 18h) ..................................................................................... 60 Table 70: MR24 Register Information ............................................................................................................. 61 Table 71: MR25 Register Information (MA[7:0] = 19h) ..................................................................................... 61 Table 72: MR25 Register Information ............................................................................................................. 61 Table 73: MR26:31 Register Information (MA[7:0] = 1Ah–1Fh) ......................................................................... 62 Table 74: MR32 Register Information (MA[7:0] = 20h) ..................................................................................... 62 Table 75: MR32 Register Information ............................................................................................................. 62 Table 76: DQ Read Calibration Bit Order and Inversion Example – MR32 = 1Ch, MR40 = 59h, MR15 = MR20 = 55h ............................................................................................................................................................ 62 Table 77: MR33:39 Register Information (MA[7:0] = 21h–27h) .......................................................................... 63 Table 78: MR40 Register Information (MA[7:0] = 28h) ..................................................................................... 63 Table 79: MR40 Register Information ............................................................................................................. 63 Table 80: MR41:47 Register Information (MA[7:0] = 29h–2Fh) .......................................................................... 64 Table 81: MR48:63 Register Information (MA[7:0] = 30h–3Fh) .......................................................................... 64 Table 82: Command Truth Table .................................................................................................................... 64 Table 83: Reference Voltage for tLZ(DQS), tHZ(DQS) Timing Measurements ..................................................... 76 Table 84: Reference Voltage for tLZ(DQ), tHZ(DQ) Timing Measurements ........................................................ 77 Table 85: Method for Calculating tWPRE Transitions and Endpoints ................................................................ 81 Table 86: Reference Voltage for tWPST Timing Measurements ......................................................................... 82 Table 87: Same Bank (ODT disabled) .............................................................................................................. 84 Table 88: Different Bank (ODT disabled) ........................................................................................................ 84 Table 89: Same Bank (ODT enabled) .............................................................................................................. 85 Table 90: Different Bank (ODT enabled) ......................................................................................................... 85 Table 91: Function Behavior of DMI Signal During WRITE, MASKED WRITE, and READ Operations ................. 86 Table 92: Precharge Bank Selection ............................................................................................................... 105 Table 93: Timing Between Commands (PRECHARGE and AUTO PRECHARGE): DQ ODT is Disable ................. 109 Table 94: Timing Between Commands (PRECHARGE and AUTO PRECHARGE): DQ ODT is Enable ................. 112 Table 95: Bank and Refresh Counter Increment Behavior ............................................................................... 114 Table 96: REFRESH Command Timing Constraints ........................................................................................ 116 Table 97: Legacy REFRESH Command Timing Constraints ............................................................................. 118 Table 98: Modified REFRESH Command Timing Constraints ......................................................................... 118 Table 99: Refresh Requirement Parameters .................................................................................................... 119 Table 100: MRR ............................................................................................................................................ 138 Table 101: Truth Table for MRR and MRW ..................................................................................................... 143 13 200b: x32 Mobile LPDDR4X SDRAM Part Number Ordering Information Table 102: Table 103: Table 104: Table 105: Table 106: Table 107: Table 108: Table 109: Table 110: Table 111: Table 112: Table 113: Table 114: Table 115: Table 116: Table 117: Table 118: Table 119: Table 120: Table 121: Table 122: Table 123: Table 124: Table 125: Table 126: Table 127: Table 128: Table 129: Table 130: Table 131: Table 132: Table 133: Table 134: Table 135: Table 136: Table 137: Table 138: Table 139: Table 140: Table 141: Table 142: Table 143: Table 144: Table 145: Table 146: Table 147: Table 148: Table 149: Table 150: Table 151: Table 152: Table 153: MRR/MRW Timing Constraints: DQ ODT is Disable ...................................................................... 143 MRR/MRW Timing Constraints: DQ ODT is Enable ....................................................................... 144 VRCG Enable/Disable Timing ....................................................................................................... 145 Internal V REF(CA) Specifications ..................................................................................................... 150 Internal V REF(DQ) Specifications .................................................................................................... 155 Mapping MR12 Op Code and DQ Numbers ................................................................................... 157 Mapping CA Input pin DQ Output pin .......................................................................................... 159 Write Leveling Timing Parameters ................................................................................................. 165 Write Leveling Setup and Hold Timing .......................................................................................... 165 MPC Command Definition ........................................................................................................... 167 MPC Commands .......................................................................................................................... 168 Timing Constraints for Training Commands .................................................................................. 170 Invert Mask Assignments .............................................................................................................. 172 DQ Read Calibration Bit Ordering and Inversion Example .............................................................. 174 MR Setting vs. DMI Status ............................................................................................................. 175 MPC [WRITE FIFO] AC Timing ..................................................................................................... 181 DQS Oscillator Matching Error Specification ................................................................................. 183 AC Timing .................................................................................................................................... 185 Temperature Sensor ..................................................................................................................... 187 ZQ Calibration Parameters ........................................................................................................... 188 Mode Register Function with Two Physical Registers ...................................................................... 190 Relation Between MR Setting and DRAM Operation ...................................................................... 191 Frequency Set Point AC Timing ..................................................................................................... 192 tFC Value Mapping ....................................................................................................................... 192 tFC Value Mapping ....................................................................................................................... 193 Pull-Down Driver Characteristics – ZQ Calibration ........................................................................ 195 Pull-Up Characteristics – ZQ Calibration ....................................................................................... 195 Valid Calibration Points ................................................................................................................ 195 Command Bus ODT State ............................................................................................................. 197 ODT DC Electrical Characteristics – up to 3200 Mbps .................................................................... 197 ODT DC Electrical Characteristics – Beyond 3200 Mbps ................................................................. 198 ODT DC Electrical Characteristics – up to 3200 Mbps .................................................................... 200 ODT DC Electrical Characteristics – Beyond 3200 Mbps ................................................................. 201 Output Driver and Termination Register Sensitivity Definition ....................................................... 202 Output Driver and Termination Register Temperature and Voltage Sensitivity ................................. 202 ODTLON and ODTLOFF Latency Values .......................................................................................... 204 Termination State in Write Leveling Mode ..................................................................................... 205 Post-Package Repair Timing Parameters ........................................................................................ 209 Absolute Maximum DC Ratings .................................................................................................... 211 Recommended DC Operating Conditions ..................................................................................... 211 Input Leakage Current .................................................................................................................. 212 Input/Output Leakage Current ..................................................................................................... 212 Operating Temperature Range ...................................................................................................... 212 Input Levels ................................................................................................................................. 213 CK Differential Input Voltage ........................................................................................................ 214 Clock Single-Ended Input Voltage ................................................................................................. 215 Differential Input Slew Rate Definition for CK_t, CK_c ................................................................... 216 Differential Input Level for CK_t, CK_c .......................................................................................... 216 Differential Input Slew Rate for CK_t, CK_c .................................................................................... 216 Cross-Point Voltage for Differential Input Signals (Clock) ............................................................... 217 DQS Differential Input Voltage ...................................................................................................... 218 DQS Single-Ended Input Voltage ................................................................................................... 220 14 200b: x32 Mobile LPDDR4X SDRAM Part Number Ordering Information Table 154: Table 155: Table 156: Table 157: Table 158: Table 159: Table 160: Table 161: Table 162: Table 163: Table 164: Table 165: Table 166: Table 167: Table 168: Table 169: Table 170: Table 171: Table 172: Table 173: Table 174: Table 175: Table 176: Table 177: Table 178: Table 179: Table 180: Table 181: Table 182: Table 183: Table 184: Table 185: Table 186: Table 187: Table 188: Table 189: Table 190: Table 191: Table 192: Table 193: Table 194: Table 195: Table 196: Table 197: Table 198: Table 199: Table 200: Table 201: Table 202: Table 203: Table 204: Table 205: Differential Input Slew Rate Definition for DQS_t, DQS_c .............................................................. 220 Differential Input Level for DQS_t, DQS_c ..................................................................................... 221 Differential Input Slew Rate for DQS_t, DQS_c ............................................................................... 221 Cross-Point Voltage for Differential Input Signals (DQS) ................................................................ 222 Input Levels ................................................................................................................................. 222 Single-Ended AC and DC Output Levels – ODT Enabled ................................................................. 222 Single-Ended Output Slew Rate .................................................................................................... 223 Differential Output Slew Rate ....................................................................................................... 223 AC Overshoot/Undershoot Specifications ..................................................................................... 224 Overshoot/Undershoot Specification for CKE and RESET .............................................................. 224 Input/Output Capacitance ........................................................................................................... 227 IDD Measurement Conditions ....................................................................................................... 228 CA Pattern for IDD4R ...................................................................................................................... 228 CA Pattern for IDD4W ..................................................................................................................... 229 Data Pattern for IDD4W (DBI Off) ................................................................................................... 229 Data Pattern for IDD4R (DBI Off) .................................................................................................... 230 IDD Specification Parameters and Operating Conditions ................................................................ 232 Clock Timing ............................................................................................................................... 234 Read Output Timing ..................................................................................................................... 234 Write Voltage and Timing ............................................................................................................. 236 CKE Input Timing ........................................................................................................................ 237 Command Address Input Timing .................................................................................................. 238 Boot Timing Parameters (10–55 MHz) ........................................................................................... 239 Mode Register Timing Parameters ................................................................................................. 239 Core Timing Parameters ............................................................................................................... 240 CA Bus ODT Timing ..................................................................................................................... 241 CA Bus Training Parameters .......................................................................................................... 241 Asynchronous ODT Turn On and Turn Off Timing ......................................................................... 242 Temperature Derating Parameters ................................................................................................ 242 DRAM CMD/ADR, CS ................................................................................................................... 246 DQs In Receive Mode ................................................................................................................... 250 Definitions and Calculations ........................................................................................................ 251 tCK(abs), tCH(abs), and tCL(abs) Definitions ................................................................................. 252 2-channel Byte Mode Addressing .................................................................................................. 255 Mode Register Assignments .......................................................................................................... 256 MR0 Device Feature 0 (MA[7:0] = 00h) ........................................................................................... 257 MR0 Op-Code Bit Definitions ....................................................................................................... 257 MR1 Device Feature 1 (MA[7:0] = 01h) ........................................................................................... 258 MR1 Op-Code Bit Definitions ....................................................................................................... 258 Burst Sequence ............................................................................................................................ 259 MR2 Device Feature 2 (MA[7:0] = 02h) ........................................................................................... 260 MR2 Op-Code Bit Definitions ....................................................................................................... 260 Byte Mode Frequency Ranges for RL, WL, and nWR ....................................................................... 262 MR8 Basic Configuration 4 (MA[7:0] = 08h) ................................................................................... 262 MR8 Op-Code Bit Definitions ....................................................................................................... 262 MR11 ODT Control (MA[7:0] = 0Bh) .............................................................................................. 263 MR11 Op-Code Bit Definitions ...................................................................................................... 263 MR17 PASR Segment Mask (MA[7:0] = 11h) ................................................................................... 264 MR17 PASR Segment Mask Definitions .......................................................................................... 264 MR17 PASR Segment Mask ........................................................................................................... 264 MR22 Register Information (MA[7:0] = 16h) ................................................................................... 265 MR22 Register Information ........................................................................................................... 265 15 200b: x32 Mobile LPDDR4X SDRAM Part Number Ordering Information Table 206: Table 207: Table 208: Table 209: Table 210: Table 211: Table 212: Table 213: Table 214: Command Truth Table Change ..................................................................................................... 266 Command Bus Training Steps ....................................................................................................... 268 Mapping of CA Input Pin and DQ Output Pin ................................................................................ 270 Invert Mask Assignments .............................................................................................................. 273 DQ Read Training Output ............................................................................................................. 274 ODTLon_rd and ODTLoff_rd Latency Values (Non Target DRAM) ................................................... 275 Core AC Timing ............................................................................................................................ 276 CBT AC Timing for Mode 1 ........................................................................................................... 276 AC Timing Parameters for 2 channel x8 CBT Mode ......................................................................... 276 16 200b: x32 Mobile LPDDR4X SDRAM General Description General Description The 8Gb Mobile Low-Power DDR4 SDRAM (LPDDR4) is a high-speed CMOS, dynamic random-access memory. The device is internally configured with 2 channels x16 I/O and 2 channels x8 I/O, each channel having 8-banks. Each of the x16’s 536,870,912-bit banks is organized as 32,768 rows by 1024 columns by 16 bits. And each of the x8’s 536,870,912-bit banks is organized as 65,536 rows 1024 columns by 8 bits. General Notes Throughout the data sheet, figures and text refer to DQs as “DQ.” DQ should be interpreted as any or all DQ collectively, unless specifically stated otherwise. “DQS” and “CK” should be interpreted as DQS_t, DQS_c and CK_t, CK_c respectively, unless specifically stated otherwise. “CA” includes all CA pins used for a given density. Complete functionality may be described throughout the entire document. Any page or diagram may have been simplified to convey a topic and may not be inclusive of all requirements. Any specific requirement takes precedence over a general statement. Any functionality not specifically stated herein is considered undefined, illegal, is not supported, and will result in unknown operation. 17 200b: x32 Mobile LPDDR4X SDRAM Package Block Diagrams Package Block Diagrams Figure 2: Single-Die, Dual-Channel Package Block Diagram VDD1 VDD2 VSS VDDQ VDDQ RZQ Die ZQ0 RESET_n CS0_A CKE0_A CK_t_A CK_c_A CA[5:0]_A CS0_B CKE0_B LPDDR4 Channel A LPDDR4 Channel B DMI[1:0]_A DQ[15:0]_A DQS[1:0]_t_A DQS[1:0]_c_A ODT_CA_A CK_t_B CK_c_B CA[5:0]_B DMI[1:0]_B DQ[15:0]_B DQS[1:0]_t_B DQS[1:0]_c_B ODT_CA ODT_CA 18 ODT_CA_B 200b: x32 Mobile LPDDR4X SDRAM Package Block Diagrams Figure 3: Dual-Die, Dual-Channel Package Block Diagram VDD1 VDD2 VSS VDDQ ZQ0 Die RESET_n CS0_A CKE0_A CS0_B CKE0_B CK_t_A CK_c_A CA[5:0]_A LPDDR4 Channel A RZQ VDDQ CK_t_B CK_c_B CA[5:0]_B LPDDR4 Channel B DMI[1:0]_A DQ[15:0]_A DQS[1:0]_t_A DQS[1:0]_c_A DMI[1:0]_B DQ[15:0]_B DQS[1:0]_t_B DQS[1:0]_c_B ODT_CA ODT_CA ODT_CA_A ODT_CA_B ZQ1 Die CS1_A CKE1_A CS1_B CKE1_B RZQ VDDQ LPDDR4 Channel A LPDDR4 Channel B ODT_CA ODT_CA VSS Note: VSS 1. ODT_CA for Rank 0 of each channel is wired to the respective ODT ball. ODT_CA for Rank 1 of each channel is wired to VSS in the package. 19 200b: x32 Mobile LPDDR4X SDRAM Package Block Diagrams Figure 4: Quad-Die, Dual-Channel Package Block Diagram VDD1 VDD2 VSS VDDQ ZQ0 Die RESET_n CS0_A CKE0_A CS0_B CKE0_B CK_t_A CK_c_A CA[5:0]_A LPDDR4 Channel A (x8) DMI0_A DQ[7:0]_A DQS0_t_A DQS0_c_A ODT_CA ODT_CA_A RZQ VDDQ CK_t_B CK_c_B CA[5:0]_B LPDDR4 Channel B (x8) DMI0_B DQ[7:0]_B DQS0_t_B DQS0_c_B ODT_CA ODT_CA_B Die CS1_B CKE1_B CS1_A CKE1_A LPDDR4 Channel A (x8) ODT_CA LPDDR4 Channel B (x8) ODT_CA VSS VSS ZQ1 Die RZQ VDDQ LPDDR4 Channel A (x8) DMI1_A DQ[15:8]_A DQS1_t_A DQS1_c_A ODT_CA LPDDR4 Channel B (x8) DMI1_B DQ[15:8]_B DQS1_t_B DQS1_c_B ODT_CA Die LPDDR4 Channel A (x8) ODT_CA LPDDR4 Channel B (x8) ODT_CA VSS Note: VSS 1. ODT_CA for Rank 0 of each channel is wired to the respective ODT ball. ODT_CA for Rank 1 of each channel is wired to VSS in the package. 20 200b: x32 Mobile LPDDR4X SDRAM Ball Assignments and Descriptions Ball Assignments and Descriptions Figure 5: 200-Ball Dual-Channel Discrete FBGA 1 2 3 4 5 A DNU DNU VSS VDD2 B DNU DQ0_A VDDQ C VSS DQ1_A D VDDQ VSS E VSS F VDD1 DQ3_A VDDQ G VSS ODT_CA_A H VDD2 J K 8 9 10 11 12 ZQ0 ZQ1 VDD2 VSS DNU DNU DQ7_A VDDQ VDDQ DQ15_A VDDQ DQ8_A DNU DMI0_A DQ6_A VSS VSS DQ14_A DMI1_A DQ9_A VSS DQS0_t_A VSS VDDQ VDDQ VSS DQS1_t_A VSS VDDQ VSS VSS DQ4_A VDD2 VDD2 VSS VDD1 VSS CA0_A CS1_A CS0_A VSS CA1_A VSS VDD2 VSS N VDD2 P DQ2_A DQS0_c_A DQ5_A 6 7 DQ13_A DQS1_c_A DQ10_A VSS DQ12_A VDDQ DQ11_A VDD1 VSS VDD1 VSS ZQ2 VSS VDD2 VDD2 CA2_A CA3_A CA4_A VDD2 CKE0_A CKE1_A CK_t_A CK_c_A VSS CA5_A VSS VDD2 VSS CS2_A CKE2_A VSS VDD2 VSS VDD2 VSS VDD2 VSS CS2_B CKE2_B VSS VDD2 VSS VDD2 VSS CA1_B VSS CKE0_B CKE1_B CK_t_B CK_c_B VSS CA5_B VSS R VDD2 CA0_B CS1_B CS0_B VDD2 VDD2 CA2_B CA3_B CA4_B VDD2 T VSS ODT_CA_B VSS VDD1 VSS VSS VDD1 VSS RESET_n VSS U VDD1 DQ3_B VDDQ DQ4_B VDD2 VDD2 DQ12_B VDDQ DQ11_B VDD1 V VSS VSS VSS W VDDQ VSS DQS0_t_B VSS VDDQ VDDQ VSS DQS1_t_B VSS VDDQ Y VSS DQ1_B DMI0_B DQ6_B VSS VSS DQ14_B DMI1_B DQ9_B VSS AA DNU DQ0_B VDDQ DQ7_B VDDQ VDDQ DQ15_B VDDQ DQ8_B DNU AB DNU DNU VSS VDD2 VSS VSS VDD2 VSS DNU DNU 1 2 3 4 5 8 9 10 11 12 L M DQ2_B DQS0_c_B DQ5_B 6 7 DQ13_B DQS1_c_B DQ10_B VSS Top View (ball down) DDR4_A (Channel A) DDR4_B (Channel B) 21 ZQ, ODT_CA, RESET Supply Ground 200b: x32 Mobile LPDDR4X SDRAM Ball Assignments and Descriptions Table 3: Ball/Pad Descriptions Symbol Type Description CK_t_A, CK_c_A, CK_t_B, CK_c_B Input Clock: CK_t and CK_c are differential clock inputs. All address, command and control input signals are sampled on positive edge of CK_t and the negative edge of CK_c. AC timings for CA parameters are referenced to clock. Each channel (A, B) has its own clock pair. CKE0_A, CKE1_A, CKE0_B, CKE1_B Input Clock enable: CKE HIGH activates and CKE LOW deactivates the internal clock signals, input buffers, and output drivers. Power saving modes are entered and exited via CKE transitions. CKE is sampled at the rising edge of CK. CS0_A, CS1_A, CS0_B, CS1_B Input Chip select: Each channel (A, B) has its own CS signals. CA[5:0]_A, CA[5:0]_B Input Command/address inputs: Provide the command and address inputs according to the command truth table. Each channel (A, B) has its own CA signals. ODT_CA_A, ODT_CA_B Input CA ODT control: The ODT_CA pin is ignored by LPDDR4X devices. CA ODT is fully controlled through MR11 and MR22. The ODT_CA pin shall be connected to a valid logic level. DQ[15:0]_A, DQ[15:0]_B I/O Data input/output: Bidirectional data bus. DQS[1:0]_t_A, DQS[1:0]_c_A, DQS[1:0]_t_B, DQS[1:0]_c_B I/O Data strobe: DQS_t and DQS_c are bi-directional differential output clock signals used to strobe data during a READ or WRITE. The data strobe is generated by the DRAM for a READ and is edge-aligned with data. The data strobe is generated by the SoC memory controller for a WRITE and is trained to precede data. Each byte of data has a data strobe signal pair. Each channel (A, B) has its own DQS_t and DQS_c strobes. DMI[1:0]_A, DMI[1:0]_B I/O Data mask/Data bus inversion: DMI is a dual use bi-directional signal used to indicate data to be masked, and data which is inverted on the bus. For data bus inversion (DBI), the DMI signal is driven HIGH when the data on the data bus is inverted, or driven LOW when the data is in its normal state. DBI can be disabled via a mode register setting. For data mask, the DMI signal is used in combination with the data lines to indicate data to be masked in a MASK WRITE command (see the Data Mask (DM) and Data Bus Inversion (DBI) sections for details). The data mask function can be disabled via a mode register setting. Each byte of data has a DMI signal. Each channel has its own DMI signals. ZQ0, ZQ1 Reference ZQ calibration reference: Used to calibrate the output drive strength and the termination resistance. The ZQ pin shall be connected to VDDQ through a 240Ω ±1% resistor. VDDQ, VDD1, VDD2 Supply Power supplies: Isolated on the die for improved noise immunity. VSS Supply Ground reference: Power supply ground reference. RESET_n Input DNU – Do not use: Must be grounded or left floating. NC – No connect: Not internally connected. RESET: When asserted LOW, the RESET pin resets all channels of the die. 22 200b: x32 Mobile LPDDR4X SDRAM Package Dimensions Figure 7: 200-Ball VFBGA – 10mm x 14.5mm (Package Code: NP) Seating plane A 200X Ø0.312 Dimensions apply to solder balls postreflow on Ø0.28 SMD ball pads. 0.08 A Ball A1 ID (covered by SR) 12 11 10 9 8 5 4 3 2 Ball A1 ID 1 A B C D E F G H J K L M N P R T U V W Y AA AB 14.5 ±0.1 13.65 CTR 0.65 TYP 0.85 ±0.1 0.8 TYP 8.8 CTR 10 ±0.1 Notes: 0.225 ±0.05 1. All dimensions are in millimeters. 2. The package height does not include room temperature warpage. 24 200b: x32 Mobile LPDDR4X SDRAM MR0, MR[6:3], MR8, MR13 Readout MR0, MR[6:3], MR8, MR13 Readout Table 4: Mode Register Contents Mode Register OP7 OP6 OP5 OP4 OP3 OP2 OP1 OP0 REF MR0 0b: Both legacy and modified refresh mode supported PPRP MR3 0b: PPR protection disabled (default) 1b: Reserved SR Abort MR4 0b: Disable (default) 1b: Reserved Manufacturer ID MR5 1111 1111b : Micron Revision ID1 MR6 0000 0010b MR8 I/O width Density OP[7:6] = 00b: x16/channel OP[7:6] = 01b: x8/channel All others: Reserved OP[5:2] = 0010b: 8Gb per die (4Gb per channel) MR13 VRO 0b: Normal operation (default) 1b: Output the VREF(CA) value on DQ7 and VREF(DQ) value on DQ6 Notes: 1. The contents of MR0, MR[6:3], MR8, and MR13 will reflect information specific to each in these packages. 2. Other bits not defined above and other mode registers are referred to in Mode Register Assignments and Definitions section. 3. Refer to Byte Mode section for further information about 1024M32 (32Gb) configuration. 25 200b: x32 Mobile LPDDR4X SDRAM IDD Parameters IDD Parameters Refer to IDD Specification Parameters and Test Conditions section for detailed conditions. Table 6: IDD Parameters – Single-Die VDD2 = 1.06–1.17V; VDDQ = 0.57–0.65V; VDD1 = 1.70–1.95V; TC = 0°C to +85°C Speed Grade Parameter IDD01 Supply 3200 Mbps Unit VDD1 7 mA IDD02 VDD2 80 IDD0Q VDDQ 1.5 IDD2P1 VDD1 2 IDD2P2 VDD2 3.5 IDD2PQ VDDQ 1.5 IDD2PS1 VDD1 2 IDD2PS2 VDD2 3.5 IDD2PSQ VDDQ 1.5 IDD2N1 VDD1 2 IDD2N2 VDD2 45 IDD2NQ VDDQ 1.5 IDD2NS1 VDD1 2 IDD2NS2 VDD2 25 IDD2NSQ VDDQ 1.5 IDD3P1 VDD1 2 IDD3P2 VDD2 10 IDD3PQ VDDQ 1.5 IDD3PS1 VDD1 2 IDD3PS2 VDD2 10 IDD3PSQ VDDQ 1.5 IDD3N1 VDD1 4 IDD3N2 VDD2 57 IDD3NQ VDDQ 1.5 IDD3NS1 VDD1 4 IDD3NS2 VDD2 40 IDD3NSQ VDDQ 1.5 IDD4R1 VDD1 5 IDD4R2 VDD2 450 IDD4RQ VDDQ 270 IDD4W1 VDD1 5 IDD4W2 VDD2 350 IDD4WQ VDDQ 100 26 Note mA mA mA mA mA mA mA mA mA mA 3 200b: x32 Mobile LPDDR4X SDRAM IDD Parameters Table 6: IDD Parameters – Single-Die (Continued) VDD2 = 1.06–1.17V; VDDQ = 0.57–0.65V; VDD1 = 1.70–1.95V; TC = 0°C to +85°C Speed Grade Parameter Supply 3200 Mbps Unit VDD1 20 mA IDD51 IDD52 VDD2 170 IDD5Q VDDQ 1.5 IDD5AB1 VDD1 4 IDD5AB2 VDD2 60 IDD5ABQ VDDQ 1.5 IDD5PB1 VDD1 4 IDD5PB2 VDD2 60 IDD5PBQ VDDQ 1.5 Notes: Note mA mA 1. IDD values reflect dual-channel operation with the same pattern for each channel. 2. Published IDD values except ID4RQ are the maximum of the distribution of the arithmetic mean. Refer to another note for IDD4RQ. And refer to another table for IDD6. 3. IDD4RQ value is reference only. Typical value. DBI Disabled, VOH = VDDQ/3, Tc = 25°C Table 7: IDD6 Full-Array Self Refresh Current VDD2 = 1.06–1.17V; VDDQ = 0.57–0.65V; VDD1 = 1.70–1.95V Temperature Supply Full-Array Self Refresh Current Unit 25°C VDD1 0.4 mA 85°C Notes: VDD2 0.7 VDDQ 0.1 VDD1 2.2 VDD2 7 VDDQ 1.5 1. IDD values reflect dual-channel operation with the same pattern for each channel. 2. IDD6 25°C is the typical, and IDD6 85°C is the maximum of the distribution of the arithmetic mean. 27 200b: x32 Mobile LPDDR4X SDRAM Functional Description Functional Description The Mobile Low-Power DDR4 SDRAM (LPDDR4) is a high-speed CMOS, dynamic random-access memory. The device is internally configured with 16 DQs and 8 banks per channel. LPDDR4 uses a 2-tick, single-data-rate (SDR) protocol on the CA bus to reduce the number of input signals in the system. The term "2-tick" means that the command/ address is decoded across two transactions, such that half of the command/address is captured with each of two consecutive rising edges of CK. The 6-bit CA bus contains command, address, and bank information. Some commands such as READ, WRITE, MASKED WRITE, and ACTIVATE require two consecutive 2-tick SDR commands to complete the instruction. LPDDR4 uses a double-data-rate (DDR) protocol on the DQ bus to achieve high-speed operation. The DDR interface transfers two data bits to each DQ lane in one clock cycle and is matched to a 16n-prefetch DRAM architecture. A write/read access consists of a single 16n-bit-wide data transfer to/from the DRAM core and 16 corresponding n-bitwide data transfers at the I/O pins. Read and write accesses to the device are burst-oriented. Accesses start at a selected column address and continue for a programmed number of columns in a programmed sequence. Accesses begin with the registration of an ACTIVATE command to open a row in the memory core, followed by a WRITE or READ command to access column data within the open row. The address and bank address (BA) bits registered by the ACTIVATE command are used to select the bank and row to be opened. The address and BA bits registered with the WRITE or READ command are used to select the bank and the starting column address for the burst access. Prior to normal operation, the LPDDR4 SDRAM must be initialized. Following sections provide detailed information about device initialization, register definition, command descriptions and device operations. Monolithic Device Addressing The table below includes all monolithic device addressing options defined by JEDEC. Under the SDRAM Addressing heading near the beginning of this data sheet are addressing details for this product data sheet. 28 Table 7: Monolithic Device Addressing – 2 Channels per Die Memory density (per die) 6Gb 8Gb 12Gb 16Gb 2Gb 3Gb 4Gb 6Gb 8Gb Configuration 16Mb x 16DQ x 8 banks x 2 channels 24Mb x 16DQ x 8 banks x 2 channels 32Mb x 16DQ x 8 banks x 2 channels 48Mb x 16DQ x 8 banks x 2 channels 64Mb x 16DQ x 8 banks x 2 channels Number of channels (per die) 2 2 2 2 2 Number of banks (per channel) 8 8 8 8 8 Array pre-fetch (bits, per channel) 256 256 256 256 256 Number of rows (per channel) 16,384 24,576 32,768 49,152 65,536 Number of columns (fetch boundaries) 64 64 64 64 64 Page size (bytes) 2048 2048 2048 2048 2048 Channel density (bits per channel) 2,147,483,648 3,221,225,472 4,294,967,296 6,442,450,944 8,589,934,592 Total density (bits per die) 4,294,967,296 6,442,450,944 8,589,934,592 12,884,901,888 17,179,869,184 Bank address BA[2:0] BA[2:0] BA[2:0] BA[2:0] BA[2:0] x16 Row add R[13:0] R[14:0] (R13 = 0 when R14 = 1) R[14:0] R[15:0] (R14 = 0 when R15 = 1) R[15:0] Col. add C[9:0] C[9:0] C[9:0] C[9:0] C[9:0] 64 bit 64 bit 64 bit 64 bit 64 bit Memory density (per channel) 29 Burst starting address boundary 200b: x32 Mobile LPDDR4X SDRAM Monolithic Device Addressing 4Gb Table 8: Monolithic Device Addressing – 1 Channel per Die Memory density (per die) 4Gb 6Gb 8Gb Memory density (per channel) 4Gb 6Gb 8Gb 32Mb x 16 DQ x 8 banks 48Mb x 16 DQ x 8 banks 64Mb x 16 DQ x 8 banks Number of channels (per die) Configuration 1 1 1 Number of banks (per channel) 8 8 8 Array pre-fetch (bits, per channel) Number of rows (per channel) Number of columns (fetch boundaries) 256 256 256 32,768 49,152 65,536 64 64 64 2048 2048 2048 Channel density (bits per channel) 4,294,967,296 6,442,450,944 8,589,934,592 Total density (bits per die) 4,294,967,296 6,442,450,944 8,589,934,592 BA[2:0] BA[2:0] BA[2:0] R[14:0] R[15:0] (R14 = 0 when R15 = 1) R[15:0] Page size (bytes) Bank address x16 Row add Column add 30 Burst starting address boundary C[9:0] C[9:0] C[9:0] 64 bit 64 bit 64 bit 200b: x32 Mobile LPDDR4X SDRAM Monolithic Device Addressing 200b: x32 Mobile LPDDR4X SDRAM Monolithic Device Addressing Notes: 1. The lower two column addresses (C0–C1) are assumed to be zero and are not transmitted on the CA bus. 2. Row and column address values on the CA bus that are not used for a particular density should be at valid logic levels. 3. For non - binary memory densities, only a half of the row address space is valid. When the MSB address bit is HIGH, then the MSB - 1 address bit must be LOW. 31 200b: x32 Mobile LPDDR4X SDRAM Simplified Bus Interface State Diagram Simplified Bus Interface State Diagram The state diagram provides a simplified illustration of the bus interface, supported state transitions, and the commands that control them. For a complete description of device behavior, use the information provided in the state diagram with the truth tables and timing specifications. The truth tables describe device behavior and applicable restrictions when considering the actual state of all banks. For command descriptions, see the Commands and Timing section. Figure 8: Simplified State Diagram Automatic sequence Command sequence MPCbased training Power-on MR write MPCbased training L E M = CK E MPC H n t_ se Re = H = RR M M REF MPC All bank refresh Idle SRX RW REF SRE Self refresh MPC MR write Per bank refresh RW CK MPCbased training MRW MRW RW MR write Reset Command bus training MR read MPC M n t_ se Re = L SR powerdown MR R M W MR RR MR W =L CKE Command bus training MR read R MRW MR CKE =H MR read MPCbased training ACT Idle powerdown MR write MR read Activating Active powerdown MR write M = CK E RW CK L E R MR = H MPCbased training R or Per bank refresh RD MW MPC MPCbased training M RD RR or Read RA W WRA or MWRA RDA PRE or PREA A RE PR E Write or mask write with auto precharge or E PR PR EA Precharging Notes: MR read A RD Write or mask write M W RA WR W MR REF Bank active WR or MWR MR write MR read P or Read with auto precharge PRE(A) = PRECHARGE (ALL) ACT = ACTIVATE WR(A) = WRITE (with auto precharge) MWR(A) = Mask WRITE (with auto precharge) RD(A) = READ (with auto precharge) MRW = MODE REGISTER WRITE MRR = MODE REGISTER READ "CKE = L" = Enter power-down "CKE = H" = Exit power-down SRE = Enter self refresh SRX = Exit self refresh REF = REFRESH MPC = Mult-purpose command (with NOP) 1. From the self refresh state, the device can enter power-down, MRR, MRW, or any of the training modes initiated with the MPC command. See the Self Refresh section. 32 200b: x32 Mobile LPDDR4X SDRAM Power-Up and Initialization 2. All banks are precharged in the idle state. 3. In the case of using an MRW command to enter a training mode, the state machine will not automatically return to the idle state at the conclusion of training. See the applicable training section for more information. 4. In the case of an MPC command to enter a training mode, the state machine may not automatically return to the idle state at the conclusion of training. See the applicable training section for more information. 5. This diagram is intended to provide an overview of the possible state transitions and commands to control them; however, it does not contain the details necessary to operate the device. In particular, situations involving more than one bank are not captured in complete detail. 6. States that have an "automatic return" and can be accessed from more than one prior state (that is, MRW from either idle or active states) will return to the state where they were initiated (that is, MRW from idle will return to idle). 7. The RESET pin can be asserted from any state and will cause the device to enter the reset state. The diagram shows RESET applied from the power-on and idle states as an example, but this should not be construed as a restriction on RESET. 8. MRW commands from the active state cannot change operating parameters of the device that affect timing. Mode register fields which may be changed via MRW from the active state include: MR1-OP[3:0], MR1-OP[7], MR3-OP[7:6], MR10-OP[7:0], MR11OP[7:0], MR13-OP[5], MR15-OP[7:0], MR16-OP[7:0], MR17-OP[7:0], MR20-OP[7:0], and MR22-OP[4:0]. Figure 9: Simplified State Diagram a) FIFO-Based Write/Read Timing MPC Automatic sequence Command sequence MPC MPCbased training MPC b) Read DQ Calibration MPC FIFO WRTR MPC FIFO RDTR MPC MPC DQ calibration = WRW MPC FIFO WRTR WRW c) ZQ CAL Start MPC d) ZQ CAL Latch ZQ calibration start MPC ZQ calibration latch Power-Up and Initialization To ensure proper functionality for power-up and reset initialization, default values for the MR settings are provided in the table below. 33 200b: x32 Mobile LPDDR4X SDRAM Power-Up and Initialization Table 9: Mode Register Default Settings Item Mode Register Setting Default Setting FSP-OP/WR MR13 OP[7:6] 00b Description FSP-OP/WR[0] are enabled WLS MR2 OP[6] 0b WRITE latency set A is selected WL MR2 OP[5:3] 000b WL = 4 RL MR2 OP[2:0] 000b RL = 6, nRTP = 8 nWR MR1 OP[6:4] 000b nWR = 6 DBI-WR/RD MR3 OP[7:6] 00b Write and read DBI are disabled CA ODT MR11 OP[6:4] 000b CA ODT is disabled DQ ODT MR11 OP[2:0] 000b VREF(CA) setting MR12 OP[6] 1b VREF(CA) value MR12 OP[5:0] 011101b VREF(DQ) setting MR14 OP[6] 1b VREF(DQ) value MR14 OP[5:0] 011101b DQ ODT is disabled VREF(CA) range[1] is enabled Range1: 50.3% of VDDQ VREF(DQ) range[1] enabled Range1: 50.3% of VDDQ The following sequence must be used to power up the device. Unless specified otherwise, this procedure is mandatory. The power-up sequence of all channels must proceed simultaneously. Voltage Ramp 1. While applying power (after Ta), RESET_n should be held LOW (≤0.2 × V DD2), and all other inputs must be between V IL,min and V IH,max. The device outputs remain at High-Z while RESET_n is held LOW. Power supply voltage ramp requirements are provided in the table below. V DD1 must ramp at the same time or earlier than V DD2. V DD2 must ramp at the same time or earlier than V DDQ. Table 10: Voltage Ramp Conditions After... Applicable Conditions Ta is reached VDD1 must be greater than VDD2 VDD2 must be greater than VDDQ - 200mV Notes: 1. Ta is the point when any power supply first reaches 300mV. 2. Voltage ramp conditions in above table apply between Ta and power-off (controlled or uncontrolled). 3. Tb is the point at which all supply and reference voltages are within their defined operating ranges. 4. Power ramp duration tINIT0 (Tb–Ta) must not exceed 20ms. 5. The voltage difference between any VSS and VSSQ must not exceed 100mV. 2. Following completion of the of the voltage ramp (Tb), RESET_n must be held LOW for tINIT1. DQ, DMI, DQS_t, and DQS_c voltage levels must be between V SSQ and V DDQ during voltage ramp to avoid latch-up. CK_t and CK_c, CS, and CA input levels must be between V SS and V DD2 during voltage ramp to avoid latch-up. Voltage ramp power supply requirements are provided in the table below. 34 200b: x32 Mobile LPDDR4X SDRAM Power-Up and Initialization 3. Beginning at Tb, RESET_n must remain LOW for at least tINIT1(Tc), after which RESET_n can be de-asserted to HIGH(Tc). At least 10ns before CKE de-assertion, CKE is required to be set LOW. All other input signals are "Don't Care." Figure 10: Voltage Ramp and Initialization Sequence Ta Tb Power Ramp Tc Reset Te Td Tf Tg Th Initialization Tj Ti Tk Training tINIT4=5tCK(MIN) CK_c CK_t tINIT0=20ms(MAX) tINIT1=200μs(MIN) Supplies Reset_n tINIT2=10ns(MIN) tINIT3=2ms(MIN) CKE tINIT5=2μs(MIN) CA[5:0] CS Exit PD DES MRW MRR tZQCAL=1μs(MIN) DES DQs ZQ Cal Start DES ZQ Cal Latch tZQLAT=MAX(30ns, 8 t CK)(MIN) DES CA BUS Training Valid DES Write Leveling Valid DES DQ Training DES Valid Valid Don’t Care Note: 1. Training is optional and may be done at the system designer's discretion. The order of training may be different than what is shown here. 4. After RESET_n is de-asserted(Tc), wait at least tINIT3 before activating CKE. CK_t, CK_c must be started and stabilized for tINIT4 before CKE goes active(Td). CS must remain LOW when the controller activates CKE. 5. After CKE is set to HIGH, wait a minimum of tINIT5 to issue any MRR or MRW commands(Te). For MRR and MRW commands, the clock frequency must be within the range defined for tCKb. Some AC parameters (for example, tDQSCK) could have relaxed timings (such as tDQSCKb) before the system is appropriately configured. 6. After completing all MRW commands to set the pull-up, pull-down, and Rx termination values, the controller can issue the ZQCAL START command to the memory(Tf). This command is used to calibrate the V OH level and the output impedance over process, voltage, and temperature. In systems where more than one device share one external ZQ resistor, the controller must not overlap the ZQ calibration sequence of each device. The ZQ calibration sequence is completed after tZQCAL (Tg). The ZQCAL LATCH command must be issued to update the DQ drivers and DQ + CA ODT to the calibrated values. 7. After tZQLAT is satisfied (Th), the command bus (internal V REF(CA), CS, and CA) should be trained for high-speed operation by issuing an MRW command (command bus training mode). This command is used to calibrate the device's internal V REF and align CS/CA with CK for high-speed operation. The device will power-up with receivers configured for low-speed operations and with V REF(CA) set to a default factory setting. Normal device operation at clock speeds higher than tCKb may not be possible until command bus training is complete. The command bus training MRW command uses the CA bus as inputs for the calibration data stream, and it outputs the results asynchro35 200b: x32 Mobile LPDDR4X SDRAM Power-Up and Initialization nously on the DQ bus. See command bus training in the MRW section for information on how to enter/exit the training mode. 8. After command bus training, the controller must perform write leveling. Write leveling mode is enabled when MR2 OP[7] is HIGH(Ti). See the Write Leveling section for a detailed description of the write leveling entry and exit sequence. In write leveling mode, the controller adjusts write DQS timing to the point where the device recognizes the start of write DQ data burst with desired WRITE latency. 9. After write leveling, the DQ bus (internal V REF(DQ), DQS, and DQ) should be trained for high-speed operation using the MPC TRAINING commands and by issuing MRW commands to adjust V REF(DQ). The device will power-up with receivers configured for low-speed operations and with V REF(DQ) set to a default factory setting. Normal device operation at clock speeds higher than tCKb should not be attempted until DQ bus training is complete. The MPC READ CALIBRATION command is used together with MPC FIFO WRITE/READ commands to train the DQ bus without disturbing the memory array contents. See the DQ Bus Training section for more information on the DQ bus training sequence. 10. At Tk, the device is ready for normal operation and is ready to accept any valid command. Any mode registers that have not previously been configured for normal operation should be written at this time. Table 11: Initialization Timing Parameters Parameter Min Max Unit tINIT0 – 20 ms Maximum voltage ramp time tINIT1 200 – μs Minimum RESET_n LOW time after completion of voltage ramp tINIT2 10 – ns Minimum CKE LOW time before RESET_n goes HIGH tINIT3 2 – ms Minimum CKE LOW time after RESET_n goes HIGH tINIT4 5 – tCK Minimum stable clock before first CKE HIGH tINIT5 2 tCKb Note – 1, 2 Notes: Note 1, 2 Comment μs Minimum idle time before first MRW/MRR command ns Clock cycle time during boot 1. Minimum tCKb guaranteed by DRAM test is 18ns. 2. The system may boot at a higher frequency than dictated by minimum tCKb. The higher boot frequency is system dependent. Reset Initialization with Stable Power The following sequence is required for RESET at no power interruption initialization. 1. Assert RESET_n below 0.2 × V DD2 anytime when reset is needed. RESET_n needs to be maintained for minimum tPW_RESET. CKE must be pulled LOW at least 10ns before de-asserting RESET_n. 2. Repeat steps 4–10 in Voltage Ramp section. 36 200b: x32 Mobile LPDDR4X SDRAM Power-Off Sequence Table 12: Reset Timing Parameter Value Parameter tPW_RESET Min Max Unit Comment 100 – ns Minimum RESET_n LOW time for reset initialization with stable power Power-Off Sequence Controlled Power-Off While powering off, CKE must be held LOW (≤0.2 × V DD2); all other inputs must be between V IL,min and V IH,max. The device outputs remain at High-Z while CKE is held LOW. DQ, DMI, DQS_t, and DQS_c voltage levels must be between V SSQ and V DDQ during the power-off sequence to avoid latch-up. CK_t, CK_c, CS, and CA input levels must be between V SS and V DD2 during the power-off sequence to avoid latch-up. Tx is the point where any power supply drops below the minimum value specified in the minimum DC Operating Condition. Tz is the point where all power supplies are below 300mV. After Tz, the device is powered off. Table 13: Power Supply Conditions The voltage difference between VSS and VSSQ must not exceed 100mV Between... Applicable Conditions VDD1 must be greater than VDD2 Tx and Tz VDD2 must be greater than VDDQ - 200mV Uncontrolled Power-Off When an uncontrolled power-off occurs, the following conditions must be met. • At Tx, when the power supply drops below the minimum values specified in the Recommended DC Operating Conditions table, all power supplies must be turned off and all power supply current capacity must be at zero, except for any static charge remaining in the system. • After Tz (the point at which all power supplies first reach 300mV), the device must power off. During this period, the relative voltage between power supplies is uncontrolled. V DD1 and V DD2 must decrease with a slope lower than 0.5 V/μs between Tx and Tz. An uncontrolled power-off sequence can occur a maximum of 400 times over the life of the device. 37 200b: x32 Mobile LPDDR4X SDRAM Mode Registers Table 14: Power-Off Timing Parameter Power-off ramp time Symbol Min Max Unit tPOFF – 2 sec Mode Registers Mode Register Assignments and Definitions Mode register definitions are provided in the Mode Register Assignments table. In the access column of the table, R indicates read-only; W indicates write-only; R/W indicates read- or write-capable or enabled. The MRR command is used to read from a register. The MRW command is used to write to a register. Table 15: Mode Register Assignments Notes 1–5 apply to entire table MR# MA[7:0] Function Access OP7 OP6 OP5 RFU RFU OP4 OP3 OP2 OP1 RFU Link REF Go to MR0 0 00h Device info R CATR 1 01h Device feature 1 W RDPST 2 02h Device feature 2 W WR Lev WLS WL 3 03h I/O config-1 W DBIWR DBI-RD PDDS 4 04h Refresh and training R /W TUF Thermal offset PPRE 5 05h Basic config-1 R LPDDR4 Manufacturer ID Go to MR5 6 06h Basic config-2 R Revision ID1 Go to MR6 7 07h Basic config-3 R Revision ID2 Go to MR7 8 08h Basic config-4 R 9 09h Test mode W 10 0Ah I/O calibration W 11 0Bh ODT W 12 0Ch VREF(CA) 13 0Dh Register control 14 0Eh 15 0Fh RZQI OP0 nWR (for AP) I/O width RDPRE WRPRE BL Go to MR1 RL PPRP SR Abort Go to MR2 WRPST PUCAL Refresh rate Density Type Vendor-specific test mode RFU VRCA W FSP-OP FSPWR VREF(DQ) R/W RFU VRDQ DQI-LB W DQ ODT RFU Go to MR11 VREF(CA) DMD Go to MR8 ZQ RST Go to MR10 CA ODT R/W Go to MR4 Go to MR9 RFU RFU Go to MR3 RRO VRCG VRO Go to MR12 RPT VREF(DQ) Lower-byte invert register for DQ calibration CBT Go to MR13 Go to MR14 Go to MR15 16 10h PASR_Bank W PASR bank mask Go to MR16 17 11h PASR_Seg W PASR segment mask Go to MR17 18 12h IT-LSB R DQS oscillator count – LSB Go to MR18 19 13h IT-MSB R DQS oscillator count – MSB Go to MR19 20 14h DQI-UB W Upper-byte invert register for DQ calibration Go to MR20 21 15h Vendor use W RFU Go to MR21 38 200b: x32 Mobile LPDDR4X SDRAM Mode Registers Table 15: Mode Register Assignments (Continued) Notes 1–5 apply to entire table MR# MA[7:0] Function Access 22 16h ODT feature 2 W 23 17h DQS oscillator stop W 24 18h TRR control 25 19h PPR resources 26–31 1Ah~1F h 20h 32 – DQ calibration pattern A 33–39 21h≈27h Do not use OP7 OP6 RFU OP5 OP4 OP3 OP2 ODTD- ODTE- ODTECA CS CK R/W TRR Mode R B7 TRR bank address B6 B5 B4 Unltd MAC B3 – Reserved for future use W See DQ Calibration section Do not use See DQ Calibration section 41–47 29h≈2Fh Do not use – Do not use 48–63 30h≈3Fh Reserved – Reserved for future use Notes: Go to MR23 MAC value B2 Link Go to MR22 DQS oscillator run-time setting – DQ calibration pattern B OP0 SoC ODT W 28h 40 OP1 B1 Go to MR24 B0 Go to MR25 Go to MR32 Go to MR40 1. RFU bits must be set to 0 during MRW commands. 2. RFU bits are read as 0 during MRR commands. 3. All mode registers that are specified as RFU or write-only shall return undefined data when read via an MRR command. 4. RFU mode registers must not be written. 5. Writes to read-only registers will not affect the functionality of the device. Table 16: MR0 Device Feature 0 (MA[7:0] = 00h) OP7 OP6 CATR OP5 OP4 RFU OP3 OP2 RZQI OP1 RFU OP0 REF Table 17: MR0 Op-Code Bit Definitions Register Information Tag Type OP Refresh mode REF Read only OP[0] Built-in self-test for RZQ information RZQI Read only OP[4:3] Definition Notes 0b: Both legacy and modified refresh mode supported 1b: Only modified refresh mode supported 00b: RZQ self-test not supported 01b: ZQ may connect to VSSQ or float 10b: ZQ may short to VDDQ 11b: ZQ pin self-test completed, no error condition detected (ZQ may not connect to VSSQ, float, or short to VDDQ) 39 1–4 200b: x32 Mobile LPDDR4XSDRAM Mode Registers Table 17: MR0 Op-Code Bit Definitions (Continued) Register Information CA terminating rank Notes: Tag Type OP CATR Read only OP[7] Definition Notes 0b: CA for this rank is not terminated 1b: CA for this rank is terminated 1. RZQI, if supported, will be set upon completion of MPC ZQ CALIBRATION START command. (tZQCAL after MPC ZQ CALIBRATION START command.) RZQI value will be lost after reset. 2. If ZQ is connected to VSSQ to set default calibration, OP[4:3] must be set to 01b. If ZQ is not connected to VSSQ, either OP[4:3] = 01b or OP[4:3] = 10b might indicate a ZQ pin assembly error. It is recommended that the assembly error be corrected. 3. In the case of possible assembly error, the device will default to factory trim settings for RON, and will ignore ZQ CALIBRATION commands. In either case, the device may not function as intended. 4. If the ZQ pin self-test returns OP[4:3] = 11b, the device has detected a resistor connected to the ZQ pin. However, this result cannot be used to validate the ZQ resistor value or that the ZQ resistor meets the specified limits (that is, 240Ω  Table 18: MR1 Device Feature 1 (MA[7:0] = 01h) OP7 OP6 RD-PST OP5 OP4 nWR (for AP) OP3 OP2 RD-PRE WR-PRE OP1 OP0 BL Table 19: MR1 Op-Code Bit Definitions Feature Type OP BL Burst length Write only OP[1:0] Definition Notes 00b: BL = 16 sequential (default) 1, 5, 6 01b: BL= 32 sequential 10b: BL = 16 or 32 sequential (on-the-fly) 11b: Reserved WR-PRE Write preamble length Write only OP[2] RD-PRE Read preamble type Write only OP[3] nWR Write-recovery for autoprecharge command Write only OP[6:4] 0b: Reserved 5, 6 1b: WR preamble = 2 × tCK 0b: RD preamble = Static (default) 3, 5, 6 1b: RD preamble = Toggle 000b: nWR = 6 (default) 001b: nWR = 10 010b: nWR = 16 011b: nWR = 20 100b: nWR = 24 101b: nWR = 30 110b: nWR = 34 111b: nWR = 40 40 2, 5, 6 200b: x32 Mobile LPDDR4XSDRAM Mode Registers Table 19: MR1 Op-Code Bit Definitions (Continued) Feature Type OP RD-PST Read postamble length Write only OP[7] Notes: Definition Notes 0b: RD postamble = 0.5 × tCK (default) 1b: RD postamble = 1.5 × 4, 5, 6 tCK 1. Burst length on-the-fly can be set to either BL = 16 or BL = 32 by setting the BL bit in the command operands. See the Command Truth Table. 2. The programmed value of nWR is the number of clock cycles the device uses to determine the starting point of an internal precharge after a write burst with auto precharge (AP) enabled. See Frequency Ranges for RL, WL, and nWR Settings table. 3. For READ operations, this bit must be set to select between a toggling preamble and a non-toggling preamble. (See the Preamble section.) 4. OP[7] provides an optional READ postamble with an additional rising and falling edge of DQS_t. The optional postamble cycle is provided for the benefit of certain memory controllers. 5. There are two physical registers assigned to each bit of this MR parameter, designated set point 0 and set point 1. Only the registers for the set point determined by the state of the FSP‐WR bit (MR13 OP[6]) will be written to with an MRW command to this MR address. 6. There are two physical registers assigned to each bit of this MR parameter, designated set point 0 and set point 1. The device will operate only according to the values stored in the registers for the active set point, that is, the set point determined by the state of the FSP‐OP bit (MR13 OP[7]). The values in the registers for the inactive set point will be ignored by the device and may be changed without affecting device operation. 41 Table 20: Burst Sequence C4 C3 C2 C1 C0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 16-Bit READ Operation V 0 0 0 0 0 1 2 3 4 5 6 7 8 9 A B C D E F V 0 1 0 0 4 5 6 7 8 9 A B C D E F 0 1 2 3 V 1 0 0 0 8 9 A B C D E F 0 1 2 3 4 5 6 7 V 1 1 0 0 C D E F 0 1 2 3 4 5 6 7 8 9 A B 1 2 3 4 5 6 7 8 9 A B C D E F 2 3 4 5 6 7 8 9 A B C D E F 10 11 12 13 14 15 16 17 18 19 1A 1B 1C 1D 1E 1F 16-Bit WRITE Operation V 0 0 0 0 0 32-Bit READ Operation 0 0 0 0 0 0 1 0 0 1 0 0 4 5 6 7 8 9 A B C D E F 0 1 2 3 14 15 16 17 18 19 1A 1B 1C 1D 1E 1F 10 11 12 13 0 1 0 0 0 8 9 A B C D E F 0 1 2 3 4 5 6 7 18 19 1A 1B 1C 1D 1E 1F 10 11 12 13 14 15 16 17 0 1 1 0 0 C D E F 0 1 2 3 4 5 6 7 8 9 A B 1C 1D 1E 1F 10 11 12 13 14 15 16 17 18 19 1A 1B 1 0 0 0 0 10 11 12 13 14 15 16 17 18 19 1A 1B 1C 1D 1E 1F 0 1 2 3 4 5 6 7 8 9 A B C D E F 42 1 0 1 0 0 14 15 16 17 18 19 1A 1B 1C 1D 1E 1F 10 11 12 13 4 5 6 7 8 9 A B C D E F 0 1 2 3 1 1 0 0 0 18 19 1A 1B 1C 1D 1E 1F 10 11 12 13 14 15 16 17 8 9 A B C D E F 0 1 2 3 4 5 6 7 1 1 1 0 0 1C 1D 1E 1F 10 11 12 13 14 15 16 17 18 19 1A 1B C D E F 0 1 2 3 4 5 6 7 8 9 A B 32-Bit WRITE Operation 0 0 0 0 0 1 Notes: 2 3 4 5 6 7 8 9 A B C D E F 10 11 12 13 14 15 16 17 18 19 1A 1B 1C 1D 1E 1F 1. First two left-most columns not shown include: Burst length bit = 16-bit or 32-bit; READ/WRITE operation bit = READ or WRITE operation. 2. C[1:0] are not present on the CA bus; they are implied to be zero. 3. The starting burst address on 64-bit (4n) boundaries. 4. C2–C4 must be set to 0 for all WRITE operations. 200b: x32 Mobile LPDDR4XSDRAM Mode Registers 0 200b: x32 Mobile LPDDR4XSDRAM Mode Registers Table 21: MR2 Device Feature 2 (MA[7:0] = 02h) OP7 OP6 WR Lev WLS OP5 OP4 OP3 OP2 OP1 WL OP0 RL Table 22: MR2 Op-Code Bit Definitions Feature Type OP RL READ latency Writeonly OP[2:0] Definition Notes RL and nRTP for DBI-RD disabled (MR3 OP[6] = 0b) 1, 3, 4 000b: RL = 6, nRTP = 8 (default) 001b: RL = 10, nRTP = 8 010b: RL = 14, nRTP = 8 011b: RL = 20, nRTP = 8 100b: RL = 24, nRTP = 10 101b: RL = 28, nRTP = 12 110b: RL = 32, nRTP = 14 111b: RL = 36, nRTP = 16 RL and nRTP for DBI-RD enabled (MR3 OP[6] = 1b) 000b: RL = 6, nRTP = 8 001b: RL = 12,nRTP = 8 010b: RL = 16, nRTP = 8 011b: RL = 22, nRTP = 8 100b: RL = 28, nRTP = 10 101b: RL = 32, nRTP = 12 110b: RL = 36, nRTP = 14 111b: RL = 40, nRTP = 16 43 200b: x32 Mobile LPDDR4XSDRAM Mode Registers Table 22: MR2 Op-Code Bit Definitions (Continued) Feature Type OP WL WRITE latency Writeonly OP[5:3] Definition Notes WL Set A (MR2 OP[6] = 0b) 1, 3, 4 000b: WL = 4 (default) 001b: WL = 6 010b: WL = 8 011b: WL = 10 100b: WL = 12 101b: WL = 14 110b: WL = 16 111b: WL = 18 WL Set B (MR2 OP[6] = 1b) 000b: WL = 4 001b: WL = 8 010b: WL = 12 011b: WL = 18 100b: WL = 22 101b: WL = 26 110b: WL = 30 111b: WL = 34 WLS WRITE latency set Writeonly OP[6] WR Lev Write leveling Writeonly OP[7] Notes: 0b: Use WL Set A (default) 1, 3, 4 1b: Use WL Set B 0b: Disable write leveling (default) 2 1b: Enable write leveling 1. See Latency Code Frequency Table for allowable frequency ranges for RL/WL/nWR. 2. After an MRW command to set the write-leveling enable bit (OP[7] = 1b), the device remains in the MRW state until another MRW command clears the bit (OP[7] = 0b). No other commands are allowed until the write-leveling enable bit is cleared. 3. There are two physical registers assigned to each bit of this MR parameter, designated set point 0 and set point 1. Only the registers for the set point determined by the state of the FSP‐WR bit (MR13 OP[6]) will be written to with an MRW command this MR address, or read from with an MRR command to this address. 4. There are two physical registers assigned to each bit of this MR parameter, designated set point 0 and set point 1. The device will operate only according to the values stored in the registers for the active set point, that is, the set point determined by the state of the FSP‐OP bit (MR13 OP[7]). The values in the registers for the inactive set point will be ignored by the device and may be changed without affecting device operation. 5. nRTP is valid for BL16 only. For BL32, the SDRAM will add 8 clocks to the nRTP value before starting a precharge. 44 200b: x32 Mobile LPDDR4XSDRAM Mode Registers Table 23: Frequency Ranges for RL, WL, nWR and nRTP Settings READ Latency WRITE Latency Lower FreUpper Frequency Lim- quency Limit (>) it(≤ ≤) No DBI w/DBI Set A Set B nWR nRTP 6 6 4 4 6 8 10 266 10 12 6 8 10 8 266 533 14 16 8 12 16 8 533 800 20 22 10 18 20 8 800 1066 24 28 12 22 24 10 1066 1333 28 32 14 26 30 12 1333 1600 32 36 16 30 34 14 1600 1866 36 40 18 34 40 16 1866 2133 Notes: Units Notes MHz 1–6 1. The device should not be operated at a frequency above the upper frequency limit or below the lower frequency limit shown for each RL, WL or nWR value. 2. DBI for READ operations is enabled in MR3 OPO[6]. When MR3 OP[6] = 0, then the "No DBI" column should be used for READ latency. When MR3 OP[6] = 1, then the "w/DBI" column should be used for READ latency. 3. WRITE Latency Set A and Set B are determined by MR2 OP[6]. When MR2 OP[6] = 0, then Write Latency Set A should be used. When MR2 OP[6] = 1, then Write Latency Set B should be used. 4. The programmed value for nRTP is the number of clock cycles the device uses to determine the starting point of an internal PRECHARGE operation after a READ burst with AP (auto-pre-charge) enabled . It is determined by RU(tRTP/tCK). 5. The programmed value of nWR is the number of clock cycles the device uses to determine the starting point of an internal PRECHARGE operation after a WRITE burst with AP (auto precharge) enabled. It is determined by RU(tWR/tCK). 6. nRTP shown in this table is valid for BL16 only. For BL32, the device will add 8 clocks to the nRTP value before starting a precharge. Table 24: MR3 I/O Configuration 1 (MA[7:0] = 03h) OP7 OP6 DBI-WR DBI-RD OP5 OP4 OP3 PDDS 45 OP2 OP1 OP0 PPRP WR-PST PU-CAL 200b: x32 Mobile LPDDR4XSDRAM Mode Registers Table 25: MR3 Op-Code Bit Definitions Feature OP Definition Notes PU-CAL (Pull-up calibration point) Type OP[0] 0b: VDDQ/2.5 1-4 WR-PST (WR postamble length) OP[1] 1b: VDDQ/3 (default) 0b: WR Post-Amble=0.5 × tCK (default) 2,3,5 1b: WR Post-Amble=1.5 × tCK PPRP (Post-package repair protection) 0b: PPR protection disabled (default) OP[2] 6 1b: PPR protection enabled PDDS (Pull-down drive strength) 000b: RFU 1,2,3 001b: RZQ/1 010b: RZQ/2 Write-only 011b: RZQ/3 OP[5:3] 100b: RZQ/4 101b: RZQ/5 110b:RZQ/6 (default) 111b: Reserved DBI-RD (DBI-read enable) OP[6] DBI-WR (DBI-write enable) OP[7] 0b: Disabled (default) 2,3 1b: Enabled 0b: Disabled (default) 2,3 1b: Enabled Notes: 1. All values are typical. The actual value after calibration will be within the specified tolerance for a given voltage and temperature. Recalibration may be required as voltage and temperature vary. 2. There are two physical registers assigned to each bit of this MR parameter, designated set point 0 and set point 1. Only the registers for the set point determined by the state of the FSP‐WR bit (MR13 OP[6]) will be written to with an MRW command to this MR address, or read from with an MRR command to this address. 3. There are two physical registers assigned to each bit of this MR parameter, designated set point 0 and set point 1.The device will operate only according to the values stored in the registers for the active set point, i.e., the set point determined by the state of the FSP‐OP bit (MR13 OP[7]). The values in the registers for the inactive set point will be determined by the state of the FSP‐OP bit (MR13 OP[7]). The values in the registers for the inactive set point will be ignored by the device, and may be changed without affecting device operation. 4. PU‐CAL (MR3‐OP[0]) must be set the same for both channels on a die. The SDRAM will read the value of only one register (Ch.A or Ch.B), vendor specific, so both channels must be set the same. 5. Refer to the supplier data sheet for vender specific function. 1.5*tCK apply => 1.6GHz clock. 6. If MR3 OP[2] is set to 1b, PPR protection mode is enabled. The PPR protection bit is a sticky bit and can only be set to 0b by a power on reset. MR4 OP[4] controls entry to PPR Mode. If PPR protection is enabled then the DRAM will not allow writing of 1b to MR4 OP[4] 46 200b: x32 Mobile LPDDR4XSDRAM Mode Registers Table 26: MR4 Device Temperature (MA[7:0] = 04h) OP7 OP6 TUF OP5 Thermal offset OP4 OP3 PPRE SR Abort OP2 OP1 OP0 Refresh rate Table 27: MR4 Op-Code Bit Definitions Feature Refresh rate Type OP Read-only OP[2:0] Definition Notes 000b: SDRAM low temperature operating limit exceeded 1–4, 7– 9 001b: 4x refresh 010b: 2x refresh 011b: 1x refresh (default) 100b: 0.5x refresh 101b: 0.25x refresh, no derating 110b: 0.25x refresh, with derating 111b: SDRAM high temperature operating limit exceeded SR Abort (Self Refresh Abort) Write OP[3] 0b: Disable (default) PPRE (Post-package repair entry/exit) Write OP[4] 0b: Exit PPR mode (default) Thermal Offset-Controller offset to TCSR (Vendor Specific Function) Write 9 1b: Device dependent 5, 9, 1b: Enter PPR mode (Reference MR25 OP[7:0] for available PPR resources) OP[6:5] 00b: No offset, 0~5°C gradient (default) 9 01b: 5°C offset, 5~10°C gradient 10b: 10°C offset, 10~15°C gradient 11b: Reserved TUF (Temperature update flag) Read-only OP7 0b: OP[2:0] No change in OP[2:0] since last MR4 read (default) 6–8 1b: Change in OP[2:0] since last MR4 read Notes: 1. The refresh rate for each MR4 OP[2:0] setting applies to tREFI, tREFIpb, and tREFW. MR4 OP[2:0] = 011b corresponds to a device temperature of 85°C. Other values require either a longer (2x, 4x) refresh interval at lower temperatures or a shorter (0.5x, 0.25x) refresh interval at higher temperatures. If MR4 OP[2] = 1b, the device temperature is greater than 85°C. 2. At higher temperatures (>85°C), AC timing derating may be required. If derating is required the device will set MR4 OP[2:0] = 110b. See derating timing requirements in the AC Timing section. 3. DRAM vendors may or may not report all of the possible settings over the operating temperature range of the device. Each vendor guarantees that their device will work at any temperature within the range using the refresh interval requested by their device. 4. The device may not operate properly when MR4 OP[2:0 ] = 000b or 111b. 5. Post‐package repair can be entered or exited by writing to MR4 OP[4]. 6. When MR4 OP[7] = 1b, the refresh rate reported in MR4 OP[2:0] has changed since the last MR4 read. A mode register read from MR4 will reset MR4 OP[7] to 0b. 7. MR4 OP[7] = 0b at power‐up. MR4 OP[2:0] bits are undefined at power‐up. 47 200b: x32 Mobile LPDDR4XSDRAM Mode Registers 8. See the Temperature Sensor section for information on the recommended frequency of reading MR4. 9. MR4 OP[6:3] can be written in this register. All other bits will be ignored by the device during an MRW command to this register. Table 28: MR5 Basic Configuration 1 (MA[7:0] = 05h) OP7 OP6 OP5 OP4 OP3 OP2 OP1 OP0 OP1 OP0 OP1 OP0 Manufacturer ID Table 29: MR5 Op-Code Bit Definitions Feature Manufacturer ID Type OP Definition Read-only OP[7:0] 1111 1111b : Micron All others: Reserved Table 30: MR6 Basic Configuration 2 (MA[7:0] = 06h) OP7 OP6 OP5 OP4 OP3 OP2 Revision ID1 Note: 1. MR6 is vendor-specific. Table 31: MR6 Op-Code Bit Definitions Feature Revision ID1 Note: Type OP Definition Read-only OP[7:0] xxxx xxxxb: Revision ID1 1. MR6 is vendor-specific. Table 32: MR7 Basic Configuration 3 (MA[7:0] = 07h) OP7 OP6 OP5 OP4 OP3 OP2 Revision ID2 Table 33: MR7 Op-Code Bit Definitions Feature Revision ID2 Note: Type OP Definition Read-only OP[7:0] 1. MR7 is vendor-specific. 48 xxxx xxxxb: Revision ID2 200b: x32 Mobile LPDDR4XSDRAM Mode Registers Table 34: MR8 Basic Configuration 4 (MA[7:0] = 08h) OP7 OP6 OP5 OP4 I/O width OP3 OP2 OP1 Density OP0 Type Table 35: MR8 Op-Code Bit Definitions Feature Type Type OP Read-only OP[1:0] Definition 00b: S16 SDRAM (16n prefetch) All others: Reserved Density Read-only OP[5:2] 0000b: 4Gb per die (2Gb per channel) 0001b: 6Gb per die (3Gb per channel) 0010b: 8Gb per die (4Gb per channel) or 4Gb per die (4Gb per channel) 0011b: 12Gb per die (6Gb per channel) or 6Gb per die (6Gb per channel) 0100b: 16Gb per die (8Gb per channel) or 8Gb per die (8Gb per channel) 0101b: 24Gb per die (12Gb per channel) 0110b: 32Gb per die (16Gb per channel) All others: Reserved I/O width Read-only OP[7:6] 00b: x16/channel All others: Reserved Table 36: MR9 Test Mode (MA[7:0] = 09h) OP7 OP6 OP5 OP4 OP3 OP2 OP1 OP0 Vendor-specific test mode Table 37: MR9 Op-Code Definitions Feature Test mode Type OP Write-only OP[7:0] Definition 0000000b; Vendor-specific test mode disabled(default) Table 38: MR10 Calibration (MA[7:0] = 0Ah) OP7 OP6 OP5 OP4 OP3 RFU OP2 OP1 OP0 ZQ RESET 49 200b: x32 Mobile LPDDR4XSDRAM Mode Registers Table 39: MR10 Op-Code Bit Definitions Feature Type OP ZQ Reset Write-only OP[0] Definition 0b: Normal operation (default) 1b: ZQ reset Notes: 1. See AC Timing table for calibration latency and timing. 2. If ZQ is connected to VDDQ through RZQ, either the ZQ calibration function or default calibration (via ZQ reset) is supported. If ZQ is connected to VSS, the device operates with default calibration and ZQ CALIBRATION commands are ignored. In both cases, the ZQ connection must not change after power is supplied to the device. Table 40: MR11 ODT Control (MA[7:0] = 0Bh) OP7 OP6 RFU OP5 OP4 OP3 CA ODT OP2 RFU OP1 OP0 DQ ODT Table 41: MR11 Op-Code Bit Definitions Notes 1-3 apply to entire table Feature Type DQ ODT DQ bus receiver On-DieTermination Write-only OP OP[2:0] Definition 000b: Disable (default) 001b: RZQ/1 010b: RZQ/2 011b: RZQ/3 100b: RZQ/4 101b: RZQ/5 110b: RZQ/6 111b: RFU CA ODT CA bus receiver On-DieTermination Write-only OP[6:4] 000b: Disable (default) 001b: RZQ/1 010b: RZQ/2 011b: RZQ/3 100b: RZQ/4 101b: RZQ/5 110b: RZQ/6 111b: RFU Notes: 1. All values are typical. The actual value after calibration will be within the specified tolerance for a given voltage and temperature. Re‐calibration may be required as voltage and temperature vary. 2. There are two physical registers assigned to each bit of this MR parameter, designated set point 0 and set point 1. Only the registers for the set point determined by the state of the FSP‐WR bit (MR13 OP[6]) will be written to with an MRW command to this MR address, or read from with an MRR command to this address. 50 200b: x32 Mobile LPDDR4XSDRAM Mode Registers 3. There are two physical registers assigned to each bit of this MR parameter, designated set point 0 and set point 1. The device will operate only according to the values stored in the registers for the active set point, i.e., the set point determined by the state of the FSP‐OP bit (MR13 OP[7]). The values in the registers for the inactive set point will be ignored by the device and may be changed without affecting device operation. Table 42: MR12 Register Information (MA[7:0] = 0Ch) OP7 OP6 RFU VRCA OP5 OP4 OP3 OP2 OP1 OP0 VREF(CA) Table 43: MR12 Op-Code Bit Definitions Feature Type OP VREF(CA) VREF(CA) settings Read/ Write OP[5:0] VRCA VREF(CA) range Read/ Write OP[6] Notes: Data Notes 000000b–110010b: See VREF Settings Table 1-3, 5, 6 All others: Reserved 0b: VREF(CA) range[0] enabled 1, 2, 4, 5, 6 1b: VREF(CA) range[1] enabled (default) 1. This register controls the VREF(CA) levels for frequency set point[1:0]. Values from either VR(ca)[0] or VR(ca)[1] may be selected by setting MR12 OP[6] appropriately. 2. A read to MR12 places the contents of OP[7:0] on DQ[7:0]. Any RFU bits and unused DQs shall be set to 0. See the MRR Operation section. 3. A write to MR12 OP[5:0] sets the internal VREF(CA) level for FSP[0] when MR13 OP[6] = 0b or sets FSP[1] when MR13 OP[6] = 1b. The time required for VREF(CA) to reach the set level depends on the step size from the current level to the new level. See the VREF(CA) training section. 4. A write to MR12 OP[6] switches the device between two internal VREF(CA) ranges. The range (range[0] or range[1]) must be selected when setting the VREF(CA) register. The value, once set, will be retained until overwritten or until the next power‐on or reset event. 5. There are two physical registers assigned to each bit of this MR parameter, designated set point 0 and set point 1. Only the registers for the set point determined by the state of the FSP‐WR bit (MR13 OP[6]) will be written to with an MRW command to this MR address, or read from with an MRR command to this address. 6. There are two physical registers assigned to each bit of this MR parameter, designated set point 0 and set point 1. The device will operate only according to the values stored in the registers for the active set point, i.e., the set point determined by the state of the FSP‐OP bit (MR13 OP[7]). The values in the registers for the inactive set point will be ignored by the device, and may be changed without affecting device operation. Table 44: MR13 Register Control (MA[7:0] = 0Dh) OP[7] OP[6] OP[5] OP[4] OP[3] OP[2] OP[1] OP[0] FSP-OP FSP-WR DMD RRO VRCG VRO RPT CBT 51 200b: x32 Mobile LPDDR4XSDRAM Mode Registers Table 45: MR13 Op-Code Bit Definition Feature CBT Command bus training Type OP Write-only OP[0] Definition 0b: Normal operation (default) Notes 1 1b: Command bus training mode enabled RPT Read Preamble training OP[1] 0b: Disabled (default) VRO VREF output OP[2] 0b: Normal operation (default) VRCG VREF current generator OP[3] 0b: Normal operation (default) RRO Refresh rate option OP[4] DMD Data mask Disable OP[5] FSP-WR Frequency Set Point Write enable OP[6] FSP-OP Frequency Set Point Operation mode OP[7] 1b: Read Preamble training mode enabled 2 1b: Output the VREF(CA) and VREF(DQ) values on DQ bits 3 1b: Fast response (high current) mode 0b: Disable MR4 OP[2:0] (default) 4, 5 1b: Enable MR4 OP[2:0] 0b: DATA MASK operation enabled (default) 6 1b: DATA MASK operation disabled Notes: 0b: Frequency set point[0] (default) 7 1b: Frequency set point[1] 0b: Frequency set point[0] (default) 8 1b: Frequency set point[1] 1. A write to set OP[0]=1 causes the LPDDR4‐SDRAM to enter the Command Bus Training mode. When OP[0]=1 and CKE goes LOW, commands are ignored and the contents of CA[5:0] are mapped to the DQ bus. CKE must be brought HIGH before doing a MRW to clear this bit (OP[0]=0) and return to normal operation. See the Command Bus Training section for more information. 2. When set, the device will output the VREF(CA) and VREF(DQ) voltage on DQ pins. Only the "active" frequency set point, as defined by MR13 OP[7], will be output on the DQ pins. This function allows an external test system to measure the internal VREF levels. The DQ pins used for VREF output are vendor specific. 3. When OP[3] = 1, the VREF circuit uses a high current mode to improve VREF settling time. 4. MR13 OP[4] RRO bit is valid only when MR0 OP[0] = 1. For LPDDR4‐SDRAM with MR0 OP[0] = 0, MR4 OP[2:0] bits are not dependent on MR13 OP[4]. 5. When OP[4] = 0, only 001b and 010b in MR4 OP[2:0] are disabled. LPDDR4‐SDRAM must report 011b instead of 001b or 010b in this case. Controller should follow the refresh mode reported by MR4 OP[2:0], regardless of RRO setting. TCSR function does not depend on RRO setting. 6. When enabled (OP[5] = 0b) data masking is enabled for the device. When disabled (OP[5] = 1b), the device will ignore any mask patterns issued during a MASKED WRITE command. See the Data Mask section for more information. 7. FSP‐WR determines which frequency set point registers are accessed with MRW and MRR commands for the following functions such as VREF(CA) setting, VREF(CA) range, VREF(DQ) setting, VREF(DQ) range. For more information, refer to Frequency Set Point section. 8. FSP‐OP determines which frequency set point register values are currently used to specify device operation for the following functions such as VREF(CA) setting, VREF(CA) range, VREF(DQ) setting, VREF(DQ) range. For more information, refer to Frequency Set Point section. 52 200b: x32 Mobile LPDDR4XSDRAM Mode Registers Table 46: Mode Register 14 (MA[7:0] = 0Eh) OP[7] OP[6] RFU VRDQ OP[5] OP[4] OP[3] OP[2] OP[1] OP[0] VREF(DQ) Table 47: MR14 Op-Code Bit Definition Feature Type OP VREF(DQ) VREF(DQ) setting Read/ Write OP[5:0] VRDQ VREF(DQ) range Definition Notes 000000b–110010b: See VREF Settings Table 1-3, 5, 6 All Others: Reserved OP[6] 0b: VREF(DQ) range[0] enabled 1, 2, 4-6 1b: VREF(DQ) range[1] enabled (default) Notes: 1. This register controls the VREF(DQ) levels for frequency set point[1:0]. Values from either VRDQ[vendor defined] or VRDQ[vendor defined] may be selected by setting OP[6] appropriately. 2. A read (MRR) to this register places the contents of OP[7:0] on DQ[7:0]. Any RFU bits and unused DQs shall be set to 0. See the MRR Operation section. 3. A write to OP[5:0] sets the internal VREF(DQ) level for FSP[0] when MR13 OP[6] = 0b, or sets FSP[1] when MR13 OP[6] = 1b. The time required for VREF(DQ) to reach the set level depends on the step size from the current level to the new level. See the VREF(DQ) training section. 4. A write to OP[6] switches the device between two internal VREF(DQ) ranges. The range (range[0] or range[1]) must be selected when setting the VREF(DQ) register. The value, once set, will be retained until overwritten, or until the next power‐on or reset event. 5. There are two physical registers assigned to each bit of this MR parameter, designated set point 0 and set point 1. Only the registers for the set point determined by the state of the FSP‐WR bit (MR13 OP[6]) will be written to with an MRW command to this MR address, or read from with an MRR command to this address. 6. There are two physical registers assigned to each bit of this MR parameter, designated set point 0 and set point 1. The device will operate only according to the values stored in the registers for the active set point, i.e., the set point determined by the state of the FSP‐OP bit (MR13 OP[7]). The values in the registers for the inactive set point will be ignored by the device, and may be changed without affecting device operation. 53 200b: x32 Mobile LPDDR4XSDRAM Mode Registers Table 48: VREF Setting for Range[0] and Range[1] Notes 1-3 apply to entire table Range[0] Values Function VREF setting for MR12 and MR14 OP Range[1] Values VREF(CA) (% of VDDQ) VREF(DQ) (% of VDDQ) VREF(CA) (% of VDDQ) VREF(DQ) (% of VDDQ) OP[5:0] 000000b: 15.0% 011010b: 30.5% 000000b: 32.9% 011010b: 48.5% 000001b: 15.6% 011011b: 31.1% 000001b: 33.5% 011011b: 49.1% 000010b: 16.2% 011100b: 31.7% 000010b: 34.1% 011100b: 49.7% 000011b: 16.8% 011101b: 32.3% 000011b: 34.7% 011101b: 50.3% (Default) 000100b: 17.4% 011110b: 32.9% 000100b: 35.3% 011110b: 50.9% 000101b: 18.0% 011111b: 33.5% 000101b: 35.9% 011111b: 51.5% 000110b: 18.6% 100000b: 34.1% 000110b: 36.5% 100000b: 52.1% 000111b: 19.2% 100001b: 34.7% 000111b: 37.1% 100001b: 52.7% 001000b: 19.8% 100010b: 35.3% 001000b: 37.7% 100010b: 53.3% 001001b: 20.4% 100011b: 35.9% 001001b: 38.3% 100011b: 53.9% 001010b: 21.0% 100100b: 36.5% 001010b: 38.9% 100100b: 54.5% 001011b: 21.6% 100101b: 37.1% 001011b: 39.5% 100101b: 55.1% 001100b: 22.2% 100110b: 37.7% 001100b: 40.1% 100110b: 55.7% 001101b: 22.8% 100111b: 38.3% 001101b: 40.7% 100111b: 56.3% 001110b: 23.4% 101000b: 38.9% 001110b: 41.3% 101000b: 56.9% 001111b: 24.0% 101001b: 39.5% 001111b: 41.9% 101001b: 57.5% 010000b: 24.6% 101010b: 40.1% 010000b: 42.5% 101010b: 58.1% 010001b: 25.1% 101011b: 40.7% 010001b: 43.1% 101011b: 58.7% 010010b: 25.7% 101100b: 41.3% 010010b: 43.7% 101100b: 59.3% 010011b: 26.3% 101101b: 41.9% 010011b: 44.3% 101101b: 59.9% 010100b: 26.9% 101110b: 42.5% 010100b: 44.9% 101110b: 60.5% 010101b: 27.5% 101111b: 43.1% 010101b: 45.5% 101111b: 61.1% 010110b: 28.1% 110000b: 43.7% 010110b: 46.1% 110000b: 61.7% 010111b: 28.7% 110001b: 44.3% 010111b: 46.7% 110001b: 62.3% 011000b: 29.3% 110010b: 44.9% 011000b: 47.3% 110010b: 62.9% 011001b: 29.9% All others: Reserved 011001b: 47.9% All others: Reserved Notes: 1. These values may be used for MR14 OP[5:0] and MR12 OP[5:0] to set the VREF(CA) or VREF(DQ) levels in the device. 2. The range may be selected in each of the MR14 or MR12 registers by setting OP[6] appropriately. 3. Each of the MR14 or MR12 registers represents either FSP[0] or FSP[1]. Two frequency set points each for CA and DQ are provided to allow for faster switching between terminated and un‐terminated operation or between different high‐frequency settings which may use different terminations values. 54 200b: x32 Mobile LPDDR4XSDRAM Mode Registers Table 49: MR15 Register Information (MA[7:0] = 0Fh) OP[7] OP[6] OP[5] OP[4] OP[3] OP[2] OP[1] OP[0] Lower-Byte Invert Register for DQ Calibration Table 50: MR15 Op-code Bit Definition Feature Lower-byte invert for DQ calibration Type OP Definition Write-Only OP[7:0] Notes The following values may be written for any operand OP[7:0] and will be applied to the corresponding DQ locations DQ[7:0] within a byte lane 1–3 0b: Do not invert 1b: Invert the DQ calibration patterns in MR32 and MR40 Default value for OP[7:0] = 55h Notes: 1. This register will invert the DQ Calibration pattern found in MR32 and MR40 for any single DQ or any combination of DQs. Example: If MR15 OP[7:0] = 00010101b, then the DQ calibration patterns transmitted on DQ[7,6,5,3,1] will not be inverted, but the DQ calibration patterns transmitted on DQ[4,2,0] will be inverted. 2. DM[0] is not inverted and always transmits the "true" data contained in MR32 and MR40. 3. No data bus inversion (DBI) function is enacted during DQ read calibration, even if DBI is enabled in MR3-OP[6]. Table 51: MR15 Invert Register Pin Mapping PIN DQ0 DQ1 DQ2 DQ3 DMIO DQ4 DQ5 DQ6 DQ7 MR15 OP0 OP1 OP2 OP3 No-Invert OP4 OP5 OP6 OP7 Table 52: MR16 PASR Bank Mask (MA[7:0] = 010h) OP7 OP6 OP5 OP4 OP3 OP2 OP1 PASR Bank Mask Table 53: MR16 Op-Code Bit Definitions Feature Bank[7:0] mask Type OP Write-only OP[7:0] Definition 0b: Bank refresh enabled (default) 1b: Bank refresh disabled OP[n] Bank Mask 8-Bank SDRAM 0 xxxxxxx1 Bank 0 1 xxxxxx1x Bank 1 55 OP0 200b: x32 Mobile LPDDR4XSDRAM Mode Registers OP[n] Bank Mask 8-Bank SDRAM 2 xxxxx1xx Bank 2 3 xxxx1xxx Bank 3 4 xxx1xxxx Bank 4 5 xx1xxxxx Bank 5 6 x1xxxxxx Bank 6 7 1xxxxxxx Bank 7 Notes: 1. When a mask bit is asserted (OP[n] = 1), refresh to that bank is disabled. 2. PASR bank masking is on a per-channel basis; the two channels on the die may have different bank masking. Table 54: MR17 PASR Segment Mask (MA[7:0] = 11h) OP7 OP6 OP5 OP4 OP3 OP2 OP1 OP0 PASR segment mask Table 55: MR17 PASR Segment Mask Definitions Feature Segment[7:0] mask Type OP Write-only OP[7:0] Definition 0b: Segment refresh enabled (default) 1b: Segment refresh disabled Table 56: MR17 PASR Segment Mask Density (per channel) Segment OP Segment Mask 0 0 XXXXXXX1 2Gb 3Gb 4Gb 6Gb 8Gb 12Gb 16Gb R[13:11] R[14:12] R[14:12] R[15:13] R[15:13] TBD TBD 110b Not allowed 110b 000b 1 1 XXXXXX1X 001b 2 2 XXXXX1XX 010b 3 3 XXXX1XXX 011b 4 4 XXX1XXXX 100b 5 5 XX1XXXXX 6 6 X1XXXXXX 110b 7 7 1XXXXXXX 111b Notes: 101b Not allowed 110b 111b Not allowed 111b 111b 1. This table indicates the range of row addresses in each masked segment. "X" is “Don’t Care” for a particular segment. 2. PASR segment-masking is on a per-channel basis. The two channels on the die may have different segment masking. 3. For 3Gb, 6Gb, and 12Gb density per channel, OP[7:6] must always be LOW (= 00b). 56 200b: x32 Mobile LPDDR4XSDRAM Mode Registers Table 57: MR18 Register Information (MA[7:0]=12h) OP7 OP6 OP5 OP4 OP3 OP2 OP1 OP0 DQS oscillator count - LSB Table 58: MR18 LSB DQS Oscillator Count Notes 1–3 apply to entire table Function Type DQS oscillator count (WR training DQS oscillator) Read-only Notes: OP OP[7:0] Definition 0h - FFh LSB DRAM DQS oscillator count 1. MR18 reports the LSB bits of the DRAM DQS oscillator count. The DRAM DQS oscillator count value is used to train DQS to the DQ data valid window. The value reported by the DRAM in this mode register can be used by the memory controller to periodically adjust the phase of DQS relative to DQ. 2. Both MR18 and MR19 must be read (MRR) and combined to get the value of the DQS oscillator count. 3. The value in this register is reset each time an MPC command is issued to start in the DQS oscillator counter. Table 59: MR19 Register Information (MA[7:0] = 13h) OP7 OP6 OP5 OP4 OP3 OP2 OP1 OP0 DQS oscillator count – MSB Table 60: MR19 DQS Oscillator Count Notes 1–3 apply to the entire table Function Type DQS oscillator count – MSB (WR training DQS oscillator) Read-only Notes: OP OP[7:0] Definition 0h - FFh MSB DRAM DQS oscillator count 1. MR19 reports the MSB bits of the DRAM DQS oscillator count. The DRAM DQS oscillator count value is used to train DQS to the DQ data valid window. The value reported by the DRAM in this mode register can be used by the memory controller to periodically adjust the phase of DQS relative to DQ. 2. Both MR18 and MR19 must be read (MRR) and combined to get the value of the DQS oscillator count. 3. A new MPC [start DQS oscillator] should be issued to reset the contents of MR18/MR19. 57 200b: x32 Mobile LPDDR4XSDRAM Mode Registers Table 61: MR20 Register Information (MA[7:0] = 14h) OP7 OP6 OP5 OP4 OP3 OP2 OP1 OP0 Upper-byte invert register for DQ calibration Table 62: MR20 Register Information Notes 1–3 apply to entire table Function Type Upper-byte invert for DQ calibration OP Write-only OP[7:0] Definition The following values may be written for any operand OP[7:0] and will be applied to the corresponding DQ locations DQ[15:8] within a byte lane 0b: Do not invert 1b: Invert the DQ Calibration patterns in MR32 and MR40 Default value for OP[7:0] = 55h Notes: 1. This register will invert the DQ calibration pattern found in MR32 and MR40 for any single DQ or any combination of DQs. For example, if MR20 OP[7:0] = 00010101b, the DQ calibration patterns transmitted on DQ[15,14,13,11,9] will not be inverted, but the DQ calibration patterns transmitted on DQ[12,10,8] will be inverted. 2. DM[1] is not inverted and always transmits the true data contained in MR32 and MR40. 3. No data bus inversion (DBI) function is enacted during DQ read calibration, even if DBI is enabled in MR3 OP[6]. Table 63: MR20 Invert Register Pin Mapping Pin DQ8 DQ9 DQ10 DQ11 DMI1 DQ12 DQ13 DQ14 DQ15 MR20 OP0 OP1 OP2 OP3 No invert OP4 OP5 OP6 OP7 Table 64: MR21 Register Information (MA[7:0] = 15h) OP7 OP6 OP5 OP4 OP3 OP2 OP1 OP0 OP2 OP1 OP0 RFU Table 65: MR22 Register Information (MA[7:0] = 16h) OP7 OP6 RFU OP5 OP4 OP3 ODTD-CA ODTE-CS ODTE-CK 58 SOC ODT 200b: x32 Mobile LPDDR4XSDRAM Mode Registers Table 66: MR22 Register Information Function Type OP Data SOC ODT (controller ODT val- Write-only OP[2:0] 000b: Disable (default) ue for VOH calibration) 001b: RZQ/1 Notes 1, 2, 3 010b: RZQ/2 011b: RZQ/3 100b: RZQ/4 101b: RZQ/5 110b: RZQ/6 111b: RFU ODTE-CK (CK ODT enabled for non-terminating rank) Write-only OP[3] 2, 3, 4, 6, 8 1b: ODT-CK override enabled ODTE-CS (CS ODT enabled for Write-only non-terminating rank) OP[4] ODTD-CA (CA ODT termination disable) OP[5] Notes: 0b: ODT-CK override disabled (default) Write-only 0b: ODT-CS override disabled (default) 2, 3, 5, 6, 8 1b: ODT-CS override enabled 0b: CA ODT obeys ODT_CA bond pad (default) 2, 3, 6, 7, 8 1b: CA ODT disabled 1. All values are typical. 2. There are two physical registers assigned to each bit of this MR parameter: designated set point 0 and set point 1. Only the registers for the set point determined by the state of the FSP-WR bit (MR13 OP[6]) will be written to with an MRW command or read from with an MRR command to this address. 3. There are two physical registers assigned to each bit of this MR parameter: designated set point 0 and set point 1. The device will operate only according to the values stored in the registers for the active set point determined by the state of the FSP-OP bit (MR13 OP[7]). The values in the registers for the inactive set point will be ignored by the device and may be changed without affecting device operation. 4. When OP[3] = 1 the CK signals will be terminated to the value set by MR11 OP[6:4] regardless of the state of the ODT_CA bond pad. This overrides the ODT_CA bond pad for configurations where CA is shared by two or more devices but CK is not, enabling CK to terminate on all devices. 5. When OP[4] = 1 the CS signal will be terminated to the value set by MR11 OP[6:4] regardless of the state of the ODT_CA bond pad. This overrides the ODT_CA bond pad for configurations where CA is shared by two or more devices but CS is not, enabling CS to terminate on all devices. 6. For system configurations where the CK, CS, and CA signals are shared between packages, the package design should provide for the ODT_CA ball to be bonded on the system board outside of the memory package. This provides the necessary control of the ODT function for all die with shared command bus signals. 7. When OP[5] = 0, CA[5:0] will terminate when the ODT_CA bond pad is HIGH and MR11 OP[6:4] is valid and disable termination when ODT_CA is LOW or MR11 OP[6:4] is disabled. When OP[5] = 1, termination for CA[5:0] is disabled regardless of the state of the ODT_CA bond pad or MR11 OP[6:4]. 8. To ensure proper operation in a multi-rank configuration, when CA, CK or CS ODT is enabled via MR11 OP[6:4] and also via MR22 or ODT_CA pad setting, the rank providing ODT will continue to terminate the command bus in all DRAM states including Active, Self-refresh, Self-refresh Power-down, Active Power-down and Precharge Power-down. 59 200b: x32 Mobile LPDDR4XSDRAM Mode Registers Table 67: MR23 Register Information (MA[7:0] = 17h) OP7 OP6 OP5 OP4 OP3 OP2 OP1 OP0 DQS interval timer run-time setting Table 68: MR23 Register Information Notes 1–2 apply to entire table Function Type DQS interval timer runtime OP Write-only OP[7:0] Data 00000000b: Disabled (default) 00000001b: DQS timer stops automatically at the 16th clock after timer start 00000010b: DQS timer stops automatically at the 32nd clock after timer start 00000011b: DQS timer stops automatically at the 48th clock after timer start 00000100b: DQS timer stops automatically at the 64th clock after timer start --------- Through --------00111111b: DQS timer stops automatically at the (63 × 16)th clock after timer start 01XXXXXXb: DQS timer stops automatically at the 2048th clock after timer start 10XXXXXXb: DQS timer stops automatically at the 4096th clock after timer start 11XXXXXXb: DQS timer stops automatically at the 8192nd clock after timer start Notes: 1. MPC command with OP[6:0] = 1001101b (stop DQS Interval Oscillator) stops the DQS interval timer in the case of MR23 OP[7:0] = 00000000b. 2. MPC command with OP[6:0] = 1001101b (stop DQS Interval Oscillator) is illegal with valid non-zero values in MR23 OP[7:0]. Table 69: MR24 Register Information (MA[7:0] = 18h) OP7 TRR Mode OP6 OP5 OP4 OP3 TRR Mode BAn Unlimited MAC 60 OP2 OP1 MAC value OP0 200b: x32 Mobile LPDDR4XSDRAM Mode Registers Table 70: MR24 Register Information Function Type MAC value Read OP Data Notes OP[2:0] 000b: Unknown (OP[3] = 0) or Unlimited (OP[3]=1) 1,2 001b: 700K 010b: 600K 011b: 500K 100b: 400K 101b: 300K 110b: 200K 111b: Reserved Unlimited MAC Read OP[3] 0b: OP[2:0] defines the MAC value 1b: Unlimited MAC value TRR Mode BAn Write 2, 3 OP[6:4] 000b: Bank 0 001b: Bank 1 010b: Bank 2 011b: Bank 3 100b: Bank 4 101b: Bank 5 110b: Bank 6 111b: Bank 7 TRR Mode Write OP[7] 0b: Disabled (default) 1b: Enabled Notes: 1. Unknown means that the device is not tested for tMAC and pass/fail values are unknown. Unlimited means that there is no restriction on the number of activates between refresh windows 2. There is no restriction to the number of activates. 3. MR24 OP[2:0] set to 000b. Table 71: MR25 Register Information (MA[7:0] = 19h) OP7 OP6 OP5 OP4 OP3 OP2 OP1 OP0 Bank 7 Bank 6 Bank 5 Bank 4 Bank 3 Bank 2 Bank 1 Bank 0 Table 72: MR25 Register Information Function PPR resources Type OP Data Read-only OP[7:0] 0b: PPR resource is not available 1b: PPR resource is available Note: 1. When OP[n] = 0, there is no PPR resource available for that bank. When OP[n] = 1, there is a PPR resource available for that bank, and PPR can be initiated by the controller. 61 200b: x32 Mobile LPDDR4XSDRAM Mode Registers Table 73: MR26:31 Register Information (MA[7:0] = 1Ah–1Fh) OP7 OP6 OP5 OP4 OP3 OP2 OP1 OP0 OP3 OP2 OP1 OP0 Reserved Table 74: MR32 Register Information (MA[7:0] = 20h) OP7 OP6 OP5 OP4 DQ calibration pattern A (default = 5Ah) Table 75: MR32 Register Information Function Type OP Data Notes 1, 2, 3 Return DQ calibration pattern Write-only OP[7:0] Xb: An MPC command issued with OP[6:0] = 1000011b causes the device to return the DQ caliMR32 + MR40 bration pattern contained in this register and (followed by) the contents of MR40. A default pattern 5Ah is loaded at power-up or reset, or the pattern may be overwritten with a MRW to this register. The contents of MR15 and MR20 will invert the MR32/MR40 data pattern for a given DQ (see MR15/MR20 for more information). Notes: 1. The patterns contained in MR32 and MR40 are transmitted on DQ[15:0] and DMI[1:0] when DQ read calibration is initiated via an MPC command. The pattern is transmitted serially on each data lane and organized little endian such that the low-order bit in a byte is transmitted first. If the data pattern is 27H, the first bit transmitted is a 1 followed by 1, 1, 0, 0, 1, 0, and 0. The bit stream will be 00100111. 2. MR15 and MR20 may be used to invert the MR32/MR40 data pattern on the DQ pins. See MR15 and MR20 for more information. Data is never inverted on the DMI[1:0] pins. 3. The data pattern is not transmitted on the DMI[1:0] pins if DBI-RD is disabled via MR3 OP[6]. 4. No data bus inversion (DBI) function is enacted during DQ read calibration, even if DBI is enabled in MR3 OP[6]. Table 76: DQ Read Calibration Bit Order and Inversion Example – MR32 = 1Ch, MR40 = 59h, MR15 = MR20 = 55h Bit Sequence Pin Invert 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 DQ0 Yes 1 0 1 0 0 1 1 0 1 1 1 0 0 0 1 1 DQ1 No 0 1 0 1 1 0 0 1 0 0 0 1 1 1 0 0 DQ2 Yes 1 0 1 0 0 1 1 0 1 1 1 0 0 0 1 1 DQ3 No 0 1 0 1 1 0 0 1 0 0 0 1 1 1 0 0 62 200b: x32 Mobile LPDDR4XSDRAM Mode Registers Table 76: DQ Read Calibration Bit Order and Inversion Example – MR32 = 1Ch, MR40 = 59h, MR15 = MR20 = 55h (Continued) Bit Sequence Invert Pin 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 DMI0 Never 0 1 0 1 1 0 0 1 0 0 0 1 1 1 0 0 DQ4 Yes 1 0 1 0 0 1 1 0 1 1 1 0 0 0 1 1 DQ5 No 0 1 0 1 1 0 0 1 0 0 0 1 1 1 0 0 DQ6 Yes 1 0 1 0 0 1 1 0 1 1 1 0 0 0 1 1 DQ7 No 0 1 0 1 1 0 0 1 0 0 0 1 1 1 0 0 DQ8 Yes 1 0 1 0 0 1 1 0 1 1 1 0 0 0 1 1 DQ9 No 0 1 0 1 1 0 0 1 0 0 0 1 1 1 0 0 DQ10 Yes 1 0 1 0 0 1 1 0 1 1 1 0 0 0 1 1 DQ11 No 0 1 0 1 1 0 0 1 0 0 0 1 1 1 0 0 0 1 0 1 1 0 0 1 0 0 0 1 1 1 0 0 DMI1 Never DQ12 Yes 1 0 1 0 0 1 1 0 1 1 1 0 0 0 1 1 DQ13 No 0 1 0 1 1 0 0 1 0 0 0 1 1 1 0 0 DQ14 Yes 1 0 1 0 0 1 1 0 1 1 1 0 0 0 1 1 DQ15 No 0 1 0 1 1 0 0 1 0 0 0 1 1 1 0 0 Table 77: MR33:39 Register Information (MA[7:0] = 21h–27h) OP7 OP6 OP5 OP4 OP3 OP2 OP1 OP0 OP3 OP2 OP1 OP0 Do not use Table 78: MR40 Register Information (MA[7:0] = 28h) OP7 OP6 OP5 OP4 DQ calibration pattern B (default = 3Ch) Table 79: MR40 Register Information Function Type OP Data Return DQ calibration pattern Write-only OP[7:0] Xb: A default pattern 3Ch is loaded at power-up MR32 + MR40 or reset, or the pattern may be overwritten with a MRW to this register. See MR32 for more information. Notes: Notes 1, 2, 3 1. The pattern contained in MR40 is concatenated to the end of MR32 and transmitted on DQ[15:0] and DMI[1:0] when DQ read calibration is initiated via an MPC command. The 63 200b: x32 Mobile LPDDR4XSDRAM Commands and Timing pattern is transmitted serially on each data lane and organized little endian such that the low-order bit in a byte is transmitted first. If the data pattern in MR40 is 27H, the first bit transmitted will be a 1, followed by 1, 1, 0, 0, 1, 0, and 0. The bit stream will be 00100111. 2. MR15 and MR20 may be used to invert the MR32/MR40 data patterns on the DQ pins. See MR15 and MR20 for more information. Data is never inverted on the DMI[1:0] pins. 3. The data pattern is not transmitted on the DMI[1:0] pins if DBI-RD is disabled via MR3 OP[6]. 4. No data bus inversion (DBI) function is enacted during DQ read calibration, even if DBI is enabled in MR3 OP[6]. Table 80: MR41:47 Register Information (MA[7:0] = 29h–2Fh) OP7 OP6 OP5 OP4 OP3 OP2 OP1 OP0 OP2 OP1 OP0 Do not use Table 81: MR48:63 Register Information (MA[7:0] = 30h–3Fh) OP7 OP6 OP5 OP4 OP3 Reserved Commands and Timing Commands transmitted on the CA bus are encoded into two parts and are latched on two consecutive rising edges of the clock. This is called 2-tick CA capture because each command requires two clock edges to latch and decode the entire command. Truth Tables Truth tables provide complementary information to the state diagram. They also clarify device behavior and applicable restrictions when considering the actual state of the banks. Unspecified operations and timings are illegal. To ensure proper operation after an illegal event, the device must be either reset by asserting the RESET_n command or powered down and then restarted using the specified initialization sequence before normal operation can continue. CKE signal has to be held HIGH when the commands listed in the command truth table input. Table 82: Command Truth Table Commands are transmitted to the device across a six-lane interface and use CK, CKE, and CS to control the capture of transmitted data SDR CA Pins Command CS CA0 CA1 CA2 CA3 CA4 CA5 MRW-1 H L H H L L OP7 1 L MA0 MA1 MA2 MA3 MA4 MA5 2 64 CK Edge Notes 1, 2, 11 200b: x32 Mobile LPDDR4XSDRAM Truth Tables Table 82: Command Truth Table (Continued) Commands are transmitted to the device across a six-lane interface and use CK, CKE, and CS to control the capture of transmitted data SDR CA Pins Command CS CA0 CA1 CA2 CA3 CA4 CA5 MRW-2 H L H H L H OP6 1 L OP0 OP1 OP2 OP3 OP4 OP5 2 H L H H H L V 1 L MA0 MA1 MA2 MA3 MA4 MA5 2 REFRESH (all/per bank) H L L L H L AB 1 L BA0 BA1 BA2 V V V 2 ENTER SELF REFRESH H L L L H H V 1 ACTIVATE-1 H H L R12 R13 R14 R15 1 L BA0 BA1 BA2 V R10 R11 2 H H H R6 R7 R8 R9 1 L R0 R1 R2 R3 R4 R5 2 H L L H L L BL 1 L BA0 BA1 BA2 V C9 AP 2 EXIT SELF REFRESH H L L H L H V 1 MASK WRITE-1 H L L H H L BL 1 L BA0 BA1 BA2 V C9 AP 2 H L L H H H V 1 MRR-1 ACTIVATE-2 WRITE-1 RFU L V L RFU H H L L RFU H H H L L L V 2 H H V V 2 1, 2 1, 2, 3, 11 1, 11 1, 2, 3, 6, 7, 9 1, 2 1, 2, 3, 5, 6, 7, 9 1, 2 1, 2 1, 2 2 L H L L L BL 1 L BA0 BA1 BA2 V C9 AP 2 CAS-2 (WRITE-2, MASKED WRITE-2, READ-2, MRR-2, MPC (except NOP) H L H L L H C8 1 L C2 C3 C4 C5 C6 C7 2 PRECHARGE (all/per bank) H L L L L H AB 1 L BA0 BA1 BA2 V V V 2 65 1, 2, 3, 4 2 H READ-1 1, 2, 12 2 V L 1, 2, 11 2 V L Notes 2 V L CK Edge 1, 2, 3, 6, 7, 9 1, 8, 9 1, 2, 3, 4 200b: x32 Mobile LPDDR4XSDRAM Truth Tables Table 82: Command Truth Table (Continued) Commands are transmitted to the device across a six-lane interface and use CK, CKE, and CS to control the capture of transmitted data SDR CA Pins Command CS CA0 CA1 CA2 CA3 CA4 CA5 MPC (TRAIN, NOP) H L L L L L OP6 1 L OP0 OP1 OP2 OP3 OP4 OP5 2 DESELECT L Notes: X CK Edge 1 Notes 1, 2, 13 1, 2 1. All commands except for DESELECT are two clock cycles and are defined by the current state of CS and CA[5:0] at the rising edge of the clock. DESELECT command is one clock cycle and is not latched by the device. 2. V = H or L (a defined logic level); X = "Don't Care," in which case CS, CK_t, CK_c, and CA[5:0] can be floated. 3. Bank addresses BA[2:0] determine which bank is to be operated upon. 4. AB HIGH during PRECHARGE or REFRESH commands indicate the command must be applied to all banks, and the bank addresses are "Don't Care." 5. MASK WRITE-1 command only supports BL16. For MASK WRITE-1 commands, CA5 must be driven LOW on the first rising clock cycle (R1). 6. AP HIGH during a WRITE-1, MASK WRITE-1, or READ-1 command indicates that an auto precharge will occur to the bank the command is operating on. AP LOW indicates that no auto precharge will occur and the bank will remain open upon completion of the command. 7. When enabled in the mode register, BL HIGH during a WRITE-1, MASK-WRITE-1, or READ-1 command indicates the burst length should be set on-the-fly to BL = 32; BL LOW during one of these commands indicates the burst length should be set on-the-fly to BL = 16. If on-the-fly burst length is not enabled in the mode register, this bit should be driven to a valid level and is ignored by the device. 8. For CAS-2 commands (WRITE-2, MASK WRITE-2, READ-2, MRR-2, or MPC (only write FIFO, read FIFO and read DQ calibration), C[1:0] are not transmitted on the CA [5:0] bus and are assumed to be zero. Note that for CAS-2 WRITE-2 or CAS-2 MASK WRITE-2 command, C[3:2] must be driven LOW. 9. WRITE-1, MASK-WRITE-1, READ-1, MODE REGISTER READ-1, or MPC (only write FIFO, read FIFO, and read DQ calibration) command must be immediately followed by CAS-2 command consecutively without any other command in between. WRITE-1, MASK WRITE-1, READ-1, MRR-1, or MPC (only write FIFO, read FIFO, and read DQ calibration) command must be issued first before issuing CAS-2 command. MPC (only Start and Stop DQS Oscillator, Start and Latch ZQ Calibration) commands do not require CAS-2 command; they require two additional DES or NOP commands consecutively before issuing any other commands. 10. The ACTIVATE-1 command must be followed by the ACTIVATE-2 command consecutively without any other command between them. The ACTIVATE-1 command must be issued prior to the ACTIVATE-2 command. When the ACTIVATE-1 command is issued, the ACTIVATE-2 command must be issued before issuing another ACTIVATE-1 command. 11. The MRW-1 command must be followed by the MRW-2 command consecutively without any other command between them. The MRW-1 command must be issued prior to the MRW-2 command. 12. The MRR-1 command must be followed by the CAS-2 command consecutively without any other commands between them. The MRR-1 command must be issued prior to the CAS-2 command. 66 200b: x32 Mobile LPDDR4XSDRAM ACTIVATE Command 13. The MPC command for READ or WRITE training operations must be followed by the CAS-2 command consecutively without any other commands between them. The MPC command must be issued prior to the CAS-2 command. ACTIVATE Command The ACTIVATE command must be executed before a READ or WRITE command can be issued. The ACTIVATE command is issued in two parts: The bank and upper-row addresses are entered with activate-1 and the lower-row addresses are entered with ACTIVATE-2. ACTIVATE-1 and ACTIVATE-2 are executed by strobing CS HIGH while setting CA[5:0] at valid levels (see Command table) at the rising edge of CK. The bank addresses (BA[2:0]) are used to select the desired bank. The row addresses (R[15:0]) are used to determine which row to activate in the selected bank. The ACTIVATE-2 command must be applied before any READ or WRITE operation can be executed. The device can accept a READ or WRITE command at time tRCD after the ACTIVATE-2 command is sent. After a bank has been activated, it must be precharged to close the active row before another ACTIVATE-2 command can be applied to the same bank. The bank active and precharge times are defined as tRAS and tRP, respectively. The minimum time interval between successive ACTIVATE-2 commands to the same bank is determined by the row cycle time of the device (tRC). The minimum time interval between ACTIVATE-2 commands to different banks is tRRD. Certain restrictions must be observed for bank ACTIVATE and REFpb operations. • Four-activate window (tFAW): No more than 4 banks may be activated (or refreshed, in the case of REFpb) per channel in a rolling tFAW window. Convert to clocks by dividing tFAW[ns] by tCK[ns] and rounding up to the next integer value. As an example of the rolling window, if RU[(tFAW/tCK)] is 64 clocks, and an ACTIVATE command is issued on clock N, no more than three additional ACTIVATE commands may be issued between clock N + 1 and N + 63. REFpb also counts as bank activation for the purposes of tFAW. • 8-bank per channel, precharge all banks (AB) allowance: tRP for a PRECHARGE ALL BANKS command for an 8-bank device must equal tRPab, which is greater than tRPpb. 67 200b: x32 Mobile LPDDR4XSDRAM Read and Write Access Modes Figure 11: ACTIVATE Command T0 T1 T2 T3 Ta0 RA RA BA0 RA RA RA Ta1 Ta2 Ta3 RA RA Tb0 Tb1 Tb2 Tb3 Valid BA0 CA CA Tc0 Tc1 Td0 Td1 Td2 Td3 RA RA Td4 Td5 CK_c CK_t CKE CS CA RA BA1 RA BA0 Valid RA BA0 tRP tRRD tRCD Command Activate1 Activate2 DES Activate2 Activate1 CAS2 READ1 DES DES PRECHARGE per bank DES DES Activate2 Activate1 DES tRAS tRC Don’t Care 1. A PRECHARGE command uses tRPab timing for all-bank precharge and tRPpb timing for single-bank precharge. In this figure, tRP is used to denote either all-bank precharge or a single-bank precharge. tCCD = Min, 1.5nCK postamble, 533MHz < Clock frequency ≤ 800MHz, ODT worst timing case. Note: Figure 12: tFAW Timing T0 T1 T2 T3 Ta0 RA RA BA0 RA RA RA Ta1 Ta2 Ta3 RA RA Tb0 Tb1 Tb2 Tb3 RA BA2 RA RA Tc0 Tc1 Tc2 Tc3 RA RA Tc4 Td0 Td1 Td2 Td3 Td4 RA RA BA4 RA RA CK_c CK_t CKE CS CA Command Activate1 Activate2 DES RA BA1 Activate1 Activate2 RA DES tRRD Activate1 Activate2 RA DES RA BA3 Activate1 Activate2 DES DES Activate1 Activate2 tRRD tRRD t FAW Don’t Care Note: 1. REFpb may be substituted for one of the ACTIVATE commands for the purposes of tFAW. Read and Write Access Modes After a bank has been activated, a READ or WRITE command can be executed. This is accomplished by asserting CKE asynchronously, with CS and CA[5:0] set to the proper state (see Command Truth Table) on the rising edge of CK. The device provides a fast column access operation. A single READ or WRITE command will initiate a burst READ or WRITE operation, where data is transferred to/from the device on successive clock cycles. Burst interrupts are not allowed; however, the optimal burst length may be set on-the-fly (see Command Truth Table). 68 200b: x32 Mobile LPDDR4XSDRAM Preamble and Postamble Preamble and Postamble The DQS strobe for the device requires a preamble prior to the first latching edge (the rising edge of DQS_t with data valid), and it requires a postamble after the last latching edge. The preamble and postamble options are set via MODE REGISTER WRITE commands. The read preamble is two tCK in length and is either static or has one clock toggle before the first latching edge. The read preamble option is enabled via MRW to MR1 OP[3] (0 = Static; 1 = Toggle). The read postamble has a programmable option to extend the postamble by 1nCK (tRPSTE). The extended postamble option is enabled via MRW to MR1 OP[7] (0 = 0.5nCK; 1 = 1.5nCK). Figure 13: DQS Read Preamble and Postamble – Toggling Preamble and 0.5nCK Postamble T0 T1 T2 T3 T4 Ta0 Ta1 Tb0 Tb1 Tb2 Tb3 Tb4 Tb5 Tb6 Tc0 Tc1 Tc2 Tc3 Tc4 DES DES DES DES DES DES DES DES DES DES DES DES DES DES DES CK_c CK_t Command RD-1 CAS-2 t RL DQSCK t RPRE DQS_c DQS_t t t DQSQ DQ DMI RPST Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout n0 n1 n2 n3 n4 n5 n10 n11 n12 n13 n14 n15 Notes: 1. BL = 16, Preamble = Toggling, Postamble = 0.5nCK 2. DQS and DQ terminated VSSQ 3. DQS_t/DQS_c is "Don’t care" prior to the start of tRPRE. No transition of DQS is implied, as DQS_t/DQS_c can be HIGH, LOW, or High-Z prior to tRPRE. Figure 14: DQS Read Preamble and Postamble – Static Preamble and 1.5nCK Postamble T0 T1 T2 T3 T4 Ta0 Ta1 Tb0 Tb1 Tb2 Tb3 Tb4 Tb5 Tb6 Tc0 Tc1 Tc2 Tc3 Tc4 DES DES DES DES DES DES DES DES DES DES DES DES DES DES DES CK_c CK_t Command RD-1 CAS-2 RL t DQSCK t RPRE DQS_c DQS_t t DQSQ DQ DMI t RPSTE Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout n0 n1 n2 n3 n4 n5 n10 n11 n12 n13 n14 n15 Notes: 1. BL = 16, Preamble = Static, Postamble = 1.5nCK (Extended) 2. DQS and DQ terminated VSSQ 3. DQS_t/DQS_c is "Don’t care" prior to the start of tRPRE. No transition of DQS is implied, as DQS_t/DQS_c can be HIGH, LOW, or High-Z prior to tRPRE. 69 200b: x32 Mobile LPDDR4XSDRAM Preamble and Postamble Figure 15: DQS Write Preamble and Postamble – 0.5nCK Postamble T0 T1 T2 T3 Valid Valid Valid Valid T4 Ta0 Ta1 Ta2 Ta3 Ta4 Ta5 Tb0 Tb1 Tb2 Tb3 Tb4 Tb5 Tb6 Tb7 DES DES DES DES DES DES DES DES DES DES DES DES DES DES DES CK_c CK_t CKE CS CA Command WRITE-1 CAS-2 WL tDQSS t WPRE t WPST DQS_c DQS_t BL/2 tDQS2DQ DQ DMI Din n0 Din n1 Din n2 Din n3 Din n8 Din n9 Din n10 Din n11 Din n12 Din n13 Din n14 Din n15 Don’t Care Notes: 1. BL = 16, Postamble = 0.5nCK 2. DQS and DQ terminated VSSQ 3. DQS_t/DQS_c is "Don’t care" prior to the start of tWPRE. No transition of DQS is implied, as DQS_t/DQS_c can be HIGH, LOW, or High-Z prior to tWPRE. 70 200b: x32 Mobile LPDDR4XSDRAM Preamble and Postamble Figure 16: DQS Write Preamble and Postamble – 1.5nCK Postamble T0 T1 T2 T3 Valid Valid Valid Valid T4 Ta0 Ta1 Ta2 Ta3 Ta4 Ta5 Tb0 Tb1 Tb2 Tb3 Tb4 Tb5 Tb6 Tb7 DES DES DES DES DES DES DES DES DES DES DES DES DES DES DES CK_c CK_t CKE CS CA Command WRITE-1 CAS-2 WL tDQSS t t WPST WPRE DQS_c DQS_t BL/2 tDQS2DQ DQ DMI Din n0 Din n1 Din n2 Din n3 Din n8 Din n9 Din n10 Din n11 Din n12 Din n13 Din n14 Din n15 Don’t Care Notes: 1. BL = 16, Postamble = 1.5nCK 2. DQS and DQ terminated VSSQ 3. DQS_t/DQS_c is "Don’t care" prior to the start of tWPRE. No transition of DQS is implied, as DQS_t/DQS_c can be HIGH, LOW, or High-Z prior to tWPRE. 71 200b: x32 Mobile LPDDR4XSDRAM Burst READ Operation Burst READ Operation A burst READ command is initiated with CKE, CS, and CA[5:0] asserted to the proper state on the rising edge of CK, as defined by the Command Truth Table. The command address bus inputs determine the starting column address for the burst. The two loworder address bits are not transmitted on the CA bus and are implied to be 0; therefore, the starting burst address is always a multiple of four (that is, 0x0, 0x4, 0x8, 0xC). The READ latency (RL) is defined from the last rising edge of the clock that completes a READ command (for example, the second rising edge of the CAS-2 command) to the rising edge of the clock from which the tDQSCK delay is measured. The first valid data is available RL × tCK + tDQSCK + tDQSQ after the rising edge of clock that completes a READ command. The data strobe output is driven tRPRE before the first valid rising strobe edge. The first data bit of the burst is synchronized with the first valid (post-preamble) rising edge of the data strobe. Each subsequent data-out appears on each DQ pin, edge-aligned with the data strobe. At the end of a burst, the DQS signals are driven for another half cycle post-amble, or for a 1.5-cycle post-amble if the programmable post-amble bit is set in the mode register. The RL is programmed in the mode registers. Pin timings for the data strobe are measured relative to the cross-point of DQS_t and DQS_c. Figure 17: Burst Read Timing T0 T1 T2 T3 BL BA0, CA, AP CAn CAn T4 T5 T6 T7 T15 T16 T17 T18 T19 BL BA0, CA, AP CAm CAm T20 T21 T22 T23 DES DES DES T33 T34 T35 T36 T41 T42 T43 T44 DES DES DES DES DES DES DES DES CK_c CK_t CS CA Command READ-1 CAS-2 DES DES DES t DES DES READ-1 CAS-2 DES CCD = 16 RL = 14 RL = 14 t DQSCK t DQSCK BL/2 = 8 BL/2 = 16 t t RPST RPRE DQS_c DQS_t tDQSQ DQ DMI Dout Dout Dout Dout Dout Dout Dout n1 n2 n6 n0 n3 n4 n5 tDQSQ Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout n7 n26 n27 n28 n29 n30 n31 m0 m1 m10 m11 m12 m13 m14 Dout m15 Don’t Care Notes: 1. BL = 32 for column n, BL = 16 for column m, RL = 14, Preamble = Toggle, Postamble = 0.5nCK, DQ/DQS: VSSQ termination 2. Dout n/m = data-out from column n and column m. 3. DES commands are shown for ease of illustration; other commands may be valid at these times. 72 200b: x32 Mobile LPDDR4XSDRAM Burst READ Operation Figure 18: Burst Read Followed by Burst Write or Burst Mask Write T0 T1 T2 T3 BL BA0, CA, AP CA CA T4 T5 Ta0 Ta1 Ta2 BL BA0, CA, AP Ta3 Ta4 CA CA Tb0 Tb1 Tb2 Tb3 Tb4 Tb5 DES DES DES DES DES DES Tb6 Tb7 Tc0 Tc1 DES DES DES DES Tc2 Tc3 Tc4 Tc5 Tc6 Tc7 DES DES CK_c CK_t CS CA READ-1 Command CAS-2 DES WR-1/MWR-1 DES DES CAS-2 RL + RU( tDQSCK(MAX)/ tCK) + BL/2 + RD( tRPST) - WL + tWPRE WL t DQSCK RL t DES DES DES DES t DQSS BL/2 = 8 t RPRE WPRE DQS_c DQS_t tDQSQ DQ DMI tDQS2DQ tRPST Dout Dout Dout Dout Dout Dout Dout Dout n0 n9 n10 n11 n12 n13 n14 n15 Dout Dout Dout Dout Dout Dout Dout Dout n9 n10 n11 n12 n13 n14 n15 n0 Don’t Care Notes: 1. BL=16, Read preamble = Toggle, Read postamble = 0.5nCK, Write preamble = 2nCK, Write postamble = 0.5nCK, DQ/DQS: VSSQ termination. 2. Dout n = data-out from column n and Din n = data-in to column.n. 3. DES commands are shown for ease of illustration; other commands may be valid at these times. Figure 19: Seamless Burst Read T0 T1 T2 T3 Ta0 Ta1 BL BA0, CA, AP CAn CAn BL BA0, CA, AP Ta2 Ta3 CAm CAm Tb0 Tb1 Tb2 Tb3 Tb4 Tc0 Tc1 DES DES DES Tc2 Tc3 Td0 Td1 Td2 Td3 Te0 Te1 DES DES DES DES DES Te2 Te3 CK_c CK_t CS CA Command READ-1 CAS-2 DES CAS-2 READ-1 BL DES BA1, CA, AP CAn READ-1 CAn CAS-2 DES DES DES DES t DQSCK RL t DQSCK RL RL DES t DQSCK t RPRE DQS_c DQS_t tDQSQ DQ DMI tDQSQ tDQSQ tRPST Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout n15 n10 n11 n12 n13 n14 n0 n1 n10 n11 n12 n13 n14 n15 m0 m1 m10 m11 m12 m13 m14 m15 n0 n1 Bank 0 Bank 1 Don’t Care Notes: 1. BL = 16, tCCD = 8, Preamble = Toggle, Postamble = 0.5nCK, DQ/DQS: VSSQ termination 2. Dout n/m = data-out from column n and column m. 3. DES commands are shown for ease of illustration; other commands may be valid at these times. 73 200b: x32 Mobile LPDDR4XSDRAM Burst READ Operation Read Timing Figure 20: Read Timing T0 T1 T2 T3 T4 Ta0 Ta1 Tb0 Tb1 Tb2 Tb3 Tb4 Tb5 Tb6 Tb7 Tc0 Tc1 Tc2 Tc3 DES DES DES DES DES DES DES DES DES DES DES DES DES DES DES CK_c CK_t Command RD-1 CAS-2 t HZ(DQS) t RL DQSCK t LZ(DQS) t RPRE DQS_c DQS_t t DQSQ t RPST t HZ(DQ) t LZ(DQ) DQ DMI Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout n0 n1 n2 n3 n4 n5 n10 n11 n12 n13 n14 n15 Notes: 1. 2. 3. 4. BL = 16, Preamble = Toggling, Postamble = 0.5nCK. DQS, DQ, and DMI terminated VSSQ. Output driver does not turn on before an endpoint of tLZ(DQS) and tLZ(DQ). Output driver does not turn off before an endpoint of tHZ(DQS) and tHZ(DQ) tLZ(DQS), tLZ(DQ), tHZ(DQS), tHZ(DQ) Calculation tHZ and tLZ transitions occur in the same time window as valid data transitions. These parameters are referenced to a specific voltage level that specifies when the device output is no longer driving tHZ(DQS) and tHZ(DQ), or begins driving tLZ(DQS) and tLZ(DQ). This section shows a method to calculate the point when the device is no longer driving tHZ(DQS) and tHZ(DQ), or begins driving tLZ(DQS) and tLZ(DQ), by measuring the signal at two different voltages. The actual voltage measurement points are not critical as long as the calculation is consistent. The parameters tLZ(DQS), tLZ(DQ), tHZ(DQS), and tHZ(DQ) are defined as single ended. 74 200b: x32 Mobile LPDDR4XSDRAM Burst READ Operation tLZ(DQS) and tHZ(DQS) Calculation for ATE (Automatic Test Equipment) Figure 21: tLZ(DQS) Method for Calculating Transitions and Endpoint CK_t – CK_c crossing at the second CAS-2 of READ command CK_t CK_c tLZ(DQS) DQS_c VOH 0.5 x VOH VSW2 VSW1 End point: Extrapolated point 0V Notes: 1. Conditions for calibration: Pull down driver RON = 40 ohm, VOH = VDDQ/3. 2. Termination condition for DQS_t and DQS_C = 50 ohm to VSSQ. 3. The VOH level depends on MR22 OP[2:0] and MR3 OP[0] settings as well as device tolerances. Use the actual VOH value for tHZ and tLZ measurements. Figure 22: tHZ(DQS) Method for Calculating Transitions and Endpoint CK_t – CK_c crossing at the second CAS-2 of READ command CK_t CK_c tHZ(DQS) End point: Extrapolated point VOH VSW2 0.5 x VOH VSW1 DQS_c 0V Notes: 1. Conditions for calibration: Pull down driver RON = 40 ohm, VOH = VDDQ/3. 2. Termination condition for DQS_t and DQS_C = 50 ohm to VSSQ. 75 200b: x32 Mobile LPDDR4XSDRAM Burst READ Operation 3. The VOH level depends on MR22 OP[2:0] and MR3 OP[0] settings as well as device tolerances. Use the actual VOH value for tHZ and tLZ measurements. Table 83: Reference Voltage for tLZ(DQS), tHZ(DQS) Timing Measurements Measured Parameter Symbol Vsw1 Vsw2 Unit DQS_c Low-Z time from CK_t, CK_c tLZ(DQS) 0.4 x VOH 0.6 x VOH V DQS_c High-Z time from CK_t, CK_c tHZ(DQS) 0.4 x VOH 0.6 x VOH Measured Parameter tLZ(DQ) and tHZ(DQ) Calculation for ATE (Automatic Test Equipment) Figure 23: tLZ(DQ) Method for Calculating Transitions and Endpoint CK_t – CK_c crossing at the second CAS-2 of READ command CK_t CK_c t LZ(DQ) DQs VOH 0.5 x VOH VSW2 VSW1 End point: Extrapolated point 0V Notes: 1. Conditions for calibration: Pull down driver RON = 40 ohm, VOH = VDDQ/3. 2. Termination condition for DQ and DMI = 50 ohm to VSSQ. 3. The VOH level depends on MR22 OP[2:0] and MR3 OP[0] settings as well as device tolerances. Use the actual VOH value for tHZ and tLZ measurements. 76 200b: x32 Mobile LPDDR4XSDRAM Burst READ Operation Figure 24: tHZ(DQ) Method for Calculating Transitions and Endpoint CK_t – CK_c crossing at the second CAS-2 of READ command CK_t CK_c tHZ(DQ) End point: Extrapolated point VOH VSW2 0.5 x VOH VSW1 DQs 0V Notes: 1. Conditions for calibration: Pull down driver RON = 40 ohm, VOH = VDDQ/3. 2. Termination condition for DQ and DMI = 50 ohm to VSSQ. 3. The VOH level depends on MR22 OP[2:0] and MR3 OP[0] settings as well as device tolerances. Use the actual VOH value for tHZ and tLZ measurements. Table 84: Reference Voltage for tLZ(DQ), tHZ(DQ) Timing Measurements Measured Parameter Symbol Vsw1 Vsw2 Unit DQS_c Low-Z time from CK_t, CK_c tLZ(DQ) 0.4 x VOH 0.6 x VOH V DQ High-Z time from CK_t, CK_c tHZ(DQ) 0.4 x VOH 0.6 x VOH Measured Parameter 77 200b: x32 Mobile LPDDR4XSDRAM Burst WRITE Operation Burst WRITE Operation A burst WRITE command is initiated with CKE, CS, and CA[5:0] asserted to the proper state at the rising edge of CK, as defined by the Command Truth Table. Column addresses C[3:2] should be driven LOW for burst WRITE commands, and column addresses C[1:0] are not transmitted on the CA bus and are assumed to be zero so that the starting column burst address is always aligned with a 32-byte boundary. The WRITE latency (WL) is defined from the last rising edge of the clock that completes a WRITE command (for example, the second rising edge of the CAS-2 command) to the rising edge of the clock from which tDQSS is measured. The first valid latching edge of DQS must be driven WL × t CK + tDQSS after the rising edge of clock that completes a WRITE command. The device uses an unmatched DQS DQ path for lower power, so the DQS strobe must arrive at the SDRAM ball prior to the DQ signal by tDQS2DQ. The DQS strobe output must be driven tWPRE before the first valid rising strobe edge. The tWPRE preamble is required to be 2 × tCK at any speed ranges. The DQS strobe must be trained to arrive at the DQ pad latch center-aligned with the DQ data. The DQ data must be held for TdiVW, and the DQS must be periodically trained to stay roughly centered in the TdiVW. Burst data is captured by the SDRAM on successive edges of DQS until the 16- or 32-bit data burst is complete. The DQS strobe must remain active (toggling) for tWPST (write postamble) after the completion of the burst write. After a burst WRITE operation, tWR must be satisfied before a PRECHARGE command to the same bank can be issued. Signal input timings are measured relative to the cross point of DQS_t and DQS_c. Figure 25: Burst WRITE Operation T0 T1 T2 T3 BL BA0, CA, AP CA CA T4 Ta0 Ta1 Ta2 Ta3 Ta4 Ta5 Ta6 Tb0 Tb1 Tb2 Tc0 Tc1 Tc2 Valid BA0 Tc3 Tc4 Td0 Td1 Td2 Td3 Td4 Td5 RA BA0, RA RA RA CK_c CK_t CS CA Command WRITE-1 CAS-2 DES DES DES DES DES DES DES DES DES DES DES PRECHARGE DES DES tWR tDSS tDQSS t DES DES BL/2 + 1 clock WL DES DES ACT-1 ACT-2 tRP t DSH (MIN) tDSS t DSH WPRE t WPST DQS_c DQS_t tDQS2DQ DQ DMI Din n0 Din n1 Din n2 Din n3 Din n4 Din n5 Din n12 Din n13 Din n14 Din n15 t DQSS (MAX) tWPRE DQS_c DQS_t tDQS2DQ DQ DMI Din n0 Din n1 Din n2 (MAX) Din n3 Din n4 Din n11 Din n12 Din n13 Din n14 Din n15 Don’t Care Notes: 1. BL=16, Write postamble = 0.5nCK, DQ/DQS: VSSQ termination 78 200b: x32 Mobile LPDDR4XSDRAM Burst WRITE Operation 2. Din n = data-in to column.n 3. The minimum number of clock cycles from the burst WRITE command to the burst READ command for any bank is [WL + 1 + BL/2 + RU(tWR/tCK)]. 4. tWR starts at the rising edge of CK after the last latching edge of DQS. 5. DES commands are shown for ease of illustration; other commands may be valid at these times. Figure 26: Burst Write Followed by Burst Read T0 T1 T2 T3 BL BA0, CA, AP CA CA T4 Ta0 Ta1 Ta2 Ta3 Ta4 Ta5 Ta6 Tb0 Tb1 Tb2 Tc0 Tc1 Tc2 Tc3 Tc4 Tc5 Tc6 BL BA0, CA, AP CA CA Tc7 Tc8 Tc9 Tc10 DES DES DES DES CK_c CK_t CS CA Command WRITE-1 CAS-2 DES DES DES DES DES DES DES DES DES WL DES DES DES DES tWTR tDSS tDQSS t DES DES BL/2 + 1 clock READ-1 CAS-2 RL t DSH (MIN) tDSS t DSH WPRE t WPST DQS_c DQS_t tDQS2DQ DQ DMI Din n0 Din n1 Din n2 Din n3 Din n4 Din n5 Din n12 Din n13 Din n14 Din n15 Don’t Care Notes: 1. BL=16, Write postamble = 0.5nCK, DQ/DQS: VSSQ termination 2. Din n = data-in to column.n 3. The minimum number of clock cycles from the burst WRITE command to the burst READ command for any bank is [WL + 1 + BL/2 + RU(tWTR/tCK)]. 4. tWTR starts at the rising edge of CK after the last latching edge of DQS. 5. DES commands are shown for ease of illustration; other commands may be valid at these times. 79 200b: x32 Mobile LPDDR4XSDRAM Burst WRITE Operation Write Timing Figure 27: Write Timing T0 T1 BL CA, AP T2 T3 CA CA T4 Ta0 Ta1 Ta2 Ta3 Ta4 Ta5 Ta6 DES DES DES DES DES DES DES DES Tb0 Tb1 Tb2 Tb3 Tb4 Tb5 DES DES DES DES DES DES CK_c CK_t CS CA Command BA0 Write-1 CAS-2 t WL t t DSS DQSS(MIN) t DES DSH t t WPRE DSH DSS t WPST DQS_c DQS_t t DQ DMI DQS2DQ Din Din Din Din Din Din Din Din Din Din n0 n1 n2 n3 n4 n5 n12 n13 n14 n15 t DQSS(MAX) t WPRE t DQSH t DQSL DQS_c DQS_t t DQ DMI DQS2DQ Din Din Din Din Din Din Din Din Din Din n0 n1 n2 n3 n4 n11 n12 n13 n14 n15 Don’t Care Notes: 1. BL = 16, Write postamble = 0.5nCK. 2. Din n = data-in to column.n 3. DES commands are shown for ease of illustration; other commands may be valid at these times. 80 200b: x32 Mobile LPDDR4XSDRAM Burst WRITE Operation tWPRE Calculation for ATE (Automatic Test Equipment) Figure 28: Method for Calculating tWPRE Transitions and Endpoints CK_t Vref(CA) CK_c Resulting differential signal relevant for tWPRE specification Vsw2 Vsw1 DQS_t - DQS_c 0V Begin point: Extrapolated point tWPRE Note: 1. Termination condition for DQS_t, DQS_c, DQ, and DMI = 50 ohm to VSSQ. Table 85: Method for Calculating tWPRE Transitions and Endpoints Measured Parameter Measured Parameter Symbol Vsw1 Vsw2 Unit tWPRE VIHL_AC x 0.3 VIHL_AC x 0.7 V DQS_t, DQS_c differential write preamble tWPST Calculation for ATE (Automatic Test Equipment) Figure 29: Method for Calculating tWPST Transitions and Endpoints CK_t Vref(CA) CK_c Resulting differential signal relevant for tWPST specification 0V Vsw2 Vsw1 DQS_t - DQS_c tWPST Notes: End point: Extrapolated point 1. Termination condition for DQS_t, DQS_c, DQ, and DMI = 50 ohm to VSSQ. 2. Write postamble: 0.5tCK 3. The method for calculating differential pulse widths for 1.5 tCK postamble is same as 0.5 tCK postamble. 81 200b: x32 Mobile LPDDR4XSDRAM MASK WRITE Operation Table 86: Reference Voltage for tWPST Timing Measurements Measured Parameter Measured Parameter Symbol Vsw1 Vsw2 Unit tWPST –(VIHL_AC x 0.7) –(VIHL_AC x 0.3) V DQS_t, DQS_c differential write postamble MASK WRITE Operation The device requires that WRITE operations that include a byte mask anywhere in the burst sequence must use the MASK WRITE command. This allows the device to implement efficient data protection schemes based on larger data blocks. The MASK WRITE-1 command is used to begin the operation, followed by a CAS-2 command. A MASKED WRITE command to the same bank cannot be issued until tCCDMW later, to allow the device to finish the internal READ-MODIFY-WRITE operation. One datamask-invert (DMI) pin is provided per byte lane, and the data-mask-invert timings match data bit (DQ) timing. See Data Mask Invert for more information on the use of the DMI signal. Figure 30: Mask Write Command - Same Bank T0 T1 T2 T3 BL BA0, CA, AP CA CA T4 Ta0 Ta1 Ta2 Ta3 Ta4 Ta5 Ta6 Tb0 Tb1 Tb2 Tc0 Tc1 Tc2 Tc3 Tc4 BL BA0, CA, AP Tc5 Tc6 CA CA Tc7 Tc8 Tc9 Tc10 DES DES DES DES CK_c CK_t CS CA Command Mask WRITE-1 CAS-2 DES DES DES DES DES DES DES DES DES DES t WL t t DES DES CCDMW DES DES DES Mask WRITE-1 CAS-2 WL DQSS(MIN) t WPRE WPST DQS_c DQS_t t Din n0 DQ DMI DQS2DQ Din Din n1 n2 Din Din n3 n4 Din Din Din Din Din n5 n12 n13 n14 n15 Don’t Care Notes: 1. BL=16, Write postamble = 0.5nCK, DQ/DQS: VSSQ termination 2. Din n = data-in to column.n 3. Mask-write supports only BL16 operations. For BL32 configuration, the system needs to insert only 16-bit wide data for MASKED WRITE operation. 4. DES commands are shown for ease of illustration; other commands may be valid at these time. 82 200b: x32 Mobile LPDDR4XSDRAM MASK WRITE Operation Figure 31: Masked Write Command - Different Bank T0 T1 T2 T3 T8 T9 BL BA0, CA, AP CA CA BL BA0, CA, AP T10 T11 CA CA T16 T17 T18 T19 T24 T25 T26 T27 T32 T33 T34 T35 BL BA0, CA, AP CA CA BL BA0, CA, AP CA CA BL BA0, CA, AP CA CA T36 T37 T38 DES DES DES CK_c CK_t CS CA Command Mask WRITE-1 CAS-2 Mask WRITE-1 DES t CAS-2 DES Mask WRITE-1 t CCD CAS-2 t t Mask WRITE-1 t CCD t WL DES CAS-2 DES Mask WRITE-1 t CCD CAS-2 CCD CCDMW DQSS WPRE DQS_c DQS_t t DQ DMI Din n0 DQS2DQ Din Din n1 n2 Din Din Din Din Din Din Din n3 n10 n11 n12 n13 n14 n15 Din n0 Din Din n1 n2 Din Din Din Din Din Din Din n3 n10 n11 n12 n13 n14 n15 Din n0 Din Din Din Din Din Din Din Din n1 n2 n10 n11 n12 n13 n14 n15 Din n0 Din Din n1 n2 Din Din n3 n4 Din n5 Din n6 Din n7 Din n8 Don’t Care Notes: 1. BL=16, DQ/DQS/DMI: VSSQ termination 2. Din n = data-in to column.n 3. Mask-write supports only BL16 operations. For BL32 configuration, the system needs to insert only 16-bit wide data for MASKED WRITE operation. 4. DES commands are shown for ease of illustration; other commands may be valid at these time. 83 200b: x32 Mobile LPDDR4XSDRAM MASK WRITE Operation Mask Write Timing Constraints for BL16 Table 87: Same Bank (ODT disabled) Next CMD Current CMD ACTIVE READ (BL = 16 or 32) WRITE (BL = 16 or 32) MASK WRITE PRECHARGE Illegal RU(tRCD/tCK) RU(tRCD/tCK) RU(tRCD/tCK) RU(tRAS/tCK) READ (with BL = 16) Illegal 81 RL + RL + RU(tDQSCK(MAX)/ RU(tDQSCK(MAX)/ tCK) + BL/2 - WL + tCK) + BL/2 - WL + tWPRE + RD( tRPST) tWPRE + RD( tRPST) BL/2 + MAX{(8,RU(tRTP/ tCK)} - 8 READ (with BL = 32) Illegal 162 RL + RL + RU(tDQSCK(MAX)/ RU(tDQSCK(MAX)/ tCK) + BL/2 - WL + tCK) + BL/2 - WL + tWPRE + RD( tRPST) tWPRE + RD( tRPST) BL/2 + MAX{(8,RU(tRTP/ tCK)} - 8 WRITE (with BL = 16) Illegal WL + 1+ BL/2 + RU(tWTR/tCK) 81 WRITE (with BL = 32) Illegal WL + 1 + BL/2 + RU(tWTR/tCK) 162 MASK WRITE Illegal WL + 1 + BL/2 + RU(tWTR/tCK) tCCD tCCDMW3 WL + 1 + BL/2 + RU(tWR/tCK) PRECHARGE RU(tRP/tCK), RU(tRPab/tCK) Illegal Illegal Illegal 4 ACTIVE Notes: 1. 2. 3. 4. tCCDMW3 tCCDMW + 84 WL + 1 + BL/2 + RU(tWR/tCK) WL + 1 + BL/2 + RU(tWR/tCK) In the case of BL = 16, tCCD is 8 × tCK. In the case of BL = 32, tCCD is 16 × tCK. tCCDMW = 32 × tCK (4 × tCCD at BL = 16). WRITE with BL = 32 operation is 8 × tCK longer than BL = 16. Table 88: Different Bank (ODT disabled) Next CMD Current CMD ACTIVE READ (with BL = 16) ACTIVE READ (BL = 16 or 32) WRITE (BL = 16 or 32) MASK WRITE PRECHARGE RU(tRRD/tCK) 4 4 4 22 4 81 RL + RL + 22 RU(tDQSCK(MAX)/ RU(tDQSCK(MAX)/ tCK) + BL/2 - WL + tCK) + BL/2 - WL + + RD( tRPST) tWPRE + RD( tRPST) tWPRE READ (with BL = 32) 4 162 RL + RL + RU(tDQSCK(MAX)/ RU(tDQSCK(MAX)/ tCK) 22 + BL/2 - WL + tCK) + BL/2 - WL + + RD( tRPST) tWPRE + RD( tRPST) tWPRE WRITE (with BL = 16) 4 WL + 1+ BL/2 + RU(tWTR/tCK) 81 81 22 WRITE (with BL = 32) 4 WL + 1 + BL/2 + RU(tWTR/tCK) 162 162 22 MASK WRITE 4 WL + 1 + BL/2 + RU(tWTR/tCK) 81 81 22 84 200b: x32 Mobile LPDDR4XSDRAM MASK WRITE Operation Table 88: Different Bank (ODT disabled) (Continued) Next CMD Current CMD ACTIVE READ (BL = 16 or 32) WRITE (BL = 16 or 32) MASK WRITE PRECHARGE 4 4 4 4 4 PRECHARGE Notes: 1. In the case of BL = 16, tCCD is 8 × tCK. 2. In the case of BL = 32, tCCD is 16 × tCK. Table 89: Same Bank (ODT enabled) Next CMD Current CMD ACTIVE READ (BL = 16 or 32) WRITE (BL = 16 or 32) MASK WRITE PRECHARGE ACTIVE Illegal RU(tRCD/tCK) RU(tRCD/tCK) RU(tRCD/tCK) RU(tRAS/tCK) READ (with BL = 16) Illegal 81 RL + RU( RL + RU( BL/2 + MAX{(8,RU(tRTP/ tCK)} - 8 tDQSCK(MAX)/ tCK) tDQSCK(MAX)/ tCK) + BL/2 + RD( tRPST) + BL/2 + RD( tRPST) - ODTLon - RD( - ODTLon - RD( tODTon(MIN)/ tCK) tODTon(MIN)/ tCK) READ (with BL = 32) 162 Illegal RL + RU( RL + RU( tDQSCK(MAX)/ tCK) tDQSCK(MAX)/ tCK) + BL/2 + RD( tRPST) + BL/2 + RD( tRPST) - ODTLon - RD( - ODTLon - RD( tODTon(MIN)/ tCK) tODTon(MIN)/ tCK) WRITE (with BL = 16) Illegal WL + 1+ BL/2 + RU(tWTR/tCK) 81 WRITE (with BL = 32) Illegal WL + 1 + BL/2 + RU(tWTR/tCK) 162 MASK WRITE Illegal WL + 1 + BL/2 + RU(tWTR/tCK) tCCD tCCDMW3 WL + 1 + BL/2 + RU(tWR/tCK) PRECHARGE RU(tRP/tCK), RU(tRPab/tCK) Illegal Illegal Illegal 4 Notes: 1. 2. 3. 4. tCCDMW3 BL/2 + MAX{(8,RU(tRTP/ tCK)} - 8 tCCDMW + 84 WL + 1 + BL/2 + RU(tWR/tCK) WL + 1 + BL/2 + RU(tWR/tCK) In the case of BL = 16, tCCD is 8 × tCK. In the case of BL = 32, tCCD is 16 × tCK. tCCDMW = 32 × tCK (4 × tCCD at BL = 16). WRITE with BL = 32 operation is 8 × tCK longer than BL = 16. Table 90: Different Bank (ODT enabled) Next CMD Current CMD ACTIVE READ (with BL = 16) ACTIVE READ (BL = 16 or 32) WRITE (BL = 16 or 32) MASK WRITE PRECHARGE RU(tRRD/tCK) 4 4 4 22 4 81 RL + RU( RL + RU( 22 tDQSCK(MAX)/ tCK) tDQSCK(MAX)/ tCK) + BL/2 + RD( tRPST) + BL/2 + RD( tRPST) - ODTLon - RD( - ODTLon - RD( tODTon(MIN)/ tCK) tODTon(MIN)/ tCK) 85 200b: x32 Mobile LPDDR4XSDRAM Data Mask and Data Bus Inversion (DBI[DC]) Function Table 90: Different Bank (ODT enabled) (Continued) Next CMD Current CMD ACTIVE READ (BL = 16 or 32) READ (with BL = 32) 4 162 WRITE (with BL = 16) 4 WL + 1+ BL/2 + RU(tWTR/tCK) 81 81 22 WRITE (with BL = 32) 4 WL + 1 + BL/2 + RU(tWTR/tCK) 162 162 22 MASK WRITE 4 WL + 1 + BL/2 + RU(tWTR/tCK) 81 81 22 PRECHARGE 4 4 4 4 4 Notes: WRITE (BL = 16 or 32) MASK WRITE RL + RU( RL + RU( tDQSCK(MAX)/ tCK) tDQSCK(MAX)/ tCK) + BL/2 + RD( tRPST) + BL/2 + RD( tRPST) - ODTLon - RD( - ODTLon - RD( tODTon(MIN)/ tCK) tODTon(MIN)/ tCK) PRECHARGE 22 1. In the case of BL = 16, tCCD is 8 × tCK. 2. In the case of BL = 32, tCCD is 16 × tCK. Data Mask and Data Bus Inversion (DBI[DC]) Function Data mask (DM) is supported for WRITE operations and the data bus inversion DBI(DC) is supported for READ, WRITE, MASK WRITE, MRR, and MRW operations. DM and DBI(DC) functions are supported with byte granularity. DBI(DC) for READ operations (READ, MRR) can be enabled or disabled via MR3 OP[6]. DBI(DC) for WRITE operations (WRITE, MASK WRITE, MRW) can be enabled or disabled via MR3 OP[7]. DM for MASK WRITE operations can be enabled or disabled via MR13 OP[5]. The device has one data mask inversion (DMI) pin per byte and a total of two DMI pins per channel. The DMI signal is a bidirectional DDR signal, is sampled with the DQ signals, and is electrically identical to a DQ signal. There are eight possible states for the device with the DM and DBI(DC) functions. Table 91: Function Behavior of DMI Signal During WRITE, MASKED WRITE, and READ Operations DM Function Write DBI(DC) Read DBI(DC) DMI Signal DMI Signal During During DMI Signal DMI Signal DMI Signal DMI Signal MASKED MPC DQ During During During During WRITE READ WRITE READ Com- MPC WR MPC RD Calibration Command Command mand FIFO FIFO Disabled Disabled Disabled Don't Care1 Illegal1, 3 High-Z2 Don't Care1 High-Z2 High-Z2 Disabled Enabled Disabled DBI(DC)4 Illegal3 High-Z2 Train9 Train10 Train11 Illegal3 DBI(DC)5 Train9 Train10 Train11 Care1 Disabled Disabled Enabled Disabled Enabled Enabled DBI(DC)4 Illegal3 DBI(DC)5 Train9 Train10 Train11 Enabled Disabled Disabled Don't Care6 DM7 High-Z2 Train9 Train10 Train11 Enabled Enabled Disabled DBI(DC)4 DBI(DC)8 High-Z2 Train9 Train10 Train11 DM7 DBI(DC)5 Train9 Train10 Train11 Enabled Disabled Enabled Don't Don't Care6 86 200b: x32 Mobile LPDDR4XSDRAM Data Mask and Data Bus Inversion (DBI[DC]) Function Table 91: Function Behavior of DMI Signal During WRITE, MASKED WRITE, and READ Operations (Continued) DM Function Write DBI(DC) Read DBI(DC) Enabled Enabled Enabled Notes: DMI Signal DMI Signal During During DMI Signal DMI Signal DMI Signal DMI Signal MASKED MPC DQ During During During During WRITE READ WRITE READ Com- MPC WR MPC RD Calibration Command Command mand FIFO FIFO DBI(DC)4 DBI(DC)8 DBI(DC)5 Train9 Train10 Train11 1. The DMI input signal is "Don’t Care." DMI input receivers are turned off. 2. DMI output drivers are turned off. 3. The MASK WRITE command is not allowed and is considered an illegal command when the DM function is disabled. 4. The DMI signal is treated as DBI and indicates whether the device needs to invert the write data received on DQs within a byte. The device inverts write data received on the DQ inputs if DMI is sampled HIGH and leaves the write data non-inverted if DMI is sampled LOW. 5. The device inverts read data on its DQ outputs associated within a byte and drives the DMI signal HIGH when more than four data bits =1 within a given byte lane; otherwise, the device does not invert the read data and drives DMI signal LOW. 6. The device does not perform a MASK operation when it receives a WRITE (or MRW) command. During the WRITE burst, the DMI signal must be driven LOW. 7. The device requires an explicit MASKED WRITE command for all MASKED WRITE operations. The DMI signal is treated as a data mask (DM) and indicates which bytes within a burst will be masked. When the DMI signal is sampled HIGH, the device masks that beat of the burst for the given byte lane. All DQ input signals within a byte are "Don't Care" (either HIGH or LOW) when DMI is HIGH. When the DMI signal is sampled LOW, the device does not perform a MASK operation and data received on the DQ inputs is written to the array. 8. The device requires an explicit MASKED WRITE command for all MASKED WRITE operations. The device masks the write data received on the DQ inputs if five or more data bits =1 on DQ[2:7] or DQ[10:15] (for lower byte or upper byte respectively) and the DMI signal is LOW. Otherwise, the device does not perform the MASK operation and treats it as a legal DBI pattern. The DMI signal is treated as a DBI signal, and data received on the DQ input is written to the array. 9. The DMI signal is treated as a training pattern. The device does not perform any MASK operation and does not invert write data received on the DQ inputs. 10. The DMI signal is treated as a training pattern. The device returns the data pattern written to the WR FIFO. 11. The DMI signal is treated as a training pattern. For more information, see the MPC DQ Read Training section. 87 200b: x32 Mobile LPDDR4XSDRAM Data Mask and Data Bus Inversion (DBI[DC]) Function Figure 32: MASKED WRITE Command with Write DBI Enabled; DM Enabled T0 T1 T2 T3 Ta0 Ta1 Ta2 Ta3 Ta4 Ta5 Ta6 Tb0 DES DES DES DES DES DES DES DES DES CK_c CK_t CKE CS CA Valid Valid Valid Valid Command Mask WRITE-1 CAS-2 t WL DQSS DQS_c DQS_t t t DQS2DQ WPRE DQ[7:0] Valid Valid Valid Valid Valid Valid Valid Valid Valid Valid N1 I 2 I M3 N I N M N N DMI[0] Don’t Care Notes: 1. N: Input data is written to DRAM cell 2. I: Input data is inverted, then written to DRAM cell 3. M: Input data is masked. The total count of ‘1’ data bits on DQ[7:2] is equal to or greater than five 4. Data mask (DM) is enable: MR13 OP [5] = 1, Data bus inversion (DBI) write is enable: MR3 OP[7] = 1 88 200b: x32 Mobile LPDDR4XSDRAM Data Mask and Data Bus Inversion (DBI[DC]) Function Figure 33: WRITE Command with Write DBI Enabled; DM Disabled T0 T1 T2 T3 Ta0 Ta1 Ta2 Ta3 Ta4 Ta5 Ta6 Tb0 DES DES DES DES DES DES DES DES DES CK_c CK_t CKE CS CA Valid Valid Valid Valid Command WRITE-1 CAS-2 t WL DQSS DQS_c DQS_t t DQS2DQ t WPRE DQ[7:0] Valid Valid Valid N1 N Valid Valid Valid Valid Valid Valid Valid I2 I N N I N N N DMI[0] Don’t Care Notes: 1. N: Input data is written to DRAM cell 2. I: Input data is inverted, then written to DRAM cell 3. Data mask (DM) is disable: MR13 OP [5] = 0, Data bus inversion (DBI) write is enable: MR3 OP[7] = 1 89 200b: x32 Mobile LPDDR4XSDRAM Preamble and Postamble Behavior Preamble and Postamble Behavior Preamble, Postamble Behavior in READ-To-READ Operations The following illustrations show the behavior of the device's read DQS_t and DQS_c pins during cases where the preamble, postamble, and/or data clocking overlap. DQS will be driven with the following priority 1. Data clocking edges will always be driven 2. Postamble 3. Preamble Essentially the data clocking, preamble, and postamble will be ordered such that all edges will be driven. Additional examples of seamless and borderline non-overlapping cases have been included for clarity. READ to READ Operations – Seamless Figure 34: READ Operations: tCCD = Min, Preamble = Toggle, 1.5nCK Postamble T0 T1 T2 T3 BL BA0, CA, AP CAn CAn T7 T4 T8 T9 T10 T11 CAm CAm T12 T13 T14 T15 T16 T17 T18 T19 T20 T26 T27 T28 T29 T30 T31 DES DES DES DES DES DES DES DES DES DES DES DES DES DES DES CK_c CK_t CS CA Command READ-1 CAS-2 BL DES DES t BA0, CA, AP READ-1 CAS-2 CCD = 8 RL = 6 t RL = 6 t DQSCK DQSCK t t RPST RPRE DQS_c DQS_t High-Z High-Z t DQ DMI High-Z t DQSQ DQSQ Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout n0 n1 n2 n3 n4 n5 n6 n7 n8 n9 n10 n11 n12 n13 n14 n15 m0 m1 m12 m13 m14 m15 BL/2 = 8 High-Z BL/2 = 8 Don’t Care Notes: 1. BL = 16 for column n and column m, RL = 6, Preamble = Toggle, Postamble = 1.5nCK. 2. Dout n/m = data-out from column n and column m. 3. DES commands are shown for ease of illustration; other commands may be valid at these times. 90 200b: x32 Mobile LPDDR4XSDRAM Preamble and Postamble Behavior READ to READ Operations – Consecutive Figure 35: Seamless READ: tCCD = Min +1, Preamble = Toggle, 1.5nCK Postamble T0 T1 T2 T3 BL BA0, CA, AP CAn CAn T7 T4 T8 T9 T10 T11 T12 BL BA0, CA, AP CAm CAm T13 T14 T15 T16 T17 T18 T19 T20 T21 T26 T27 T28 T29 T30 DES DES DES DES DES DES DES DES DES DES DES DES DES DES CK_c CK_t CS CA Command READ-1 CAS-2 DES DES t DES READ-1 CAS-2 CCD = 9 t RL = 6 t RL = 6 DQSCK DQSCK t t RPST RPRE t RPST DQS_c High-Z DQS_t High-Z t DQ DQSQ Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout n0 n1 n2 n3 n4 n5 n6 n7 n8 n9 n10 n11 n12 n13 n14 n15 High-Z DMI t DQSQ High-Z Dout Dout Dout Dout Dout Dout m0 m1 m12 m13 m14 m15 BL/2 = 8 High-Z BL/2 = 8 Don’t Care 1. BL = 16 for column n and column m, RL = 6, Preamble = Toggle, Postamble = 1.5nCK. 2. Dout n/m = data-out from column n and column m. 3. DES commands are shown for ease of illustration; other commands may be valid at these times. Notes: Figure 36: Consecutive READ: tCCD = Min +1, Preamble = Toggle, 0.5nCK Postamble T0 T1 T2 T3 BL BA0, CA, AP CAn CAn T7 T4 T8 T9 T10 T11 T12 CAm CAm T13 T14 T15 T16 T17 T18 T19 T20 T21 T26 T27 T28 T29 T30 DES DES DES DES DES DES DES DES DES DES DES DES DES DES CK_c CK_t CS CA Command READ-1 CAS-2 BL DES DES t DES BA0, CA, AP READ-1 CAS-2 CCD = 9 RL = 6 t RL = 6 t DQSCK DQSCK t t RPRE t RPST RPRE t RPST DQS_c DQS_t High-Z High-Z t DQ DMI High-Z t DQSQ DQSQ Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout n0 n1 n2 n3 n4 n5 n6 n7 n8 n9 n10 n11 n12 n13 n14 n15 BL/2 = 8 High-Z Dout Dout Dout Dout Dout Dout m0 m1 m12 m13 m14 m15 High-Z BL/2 = 8 Don’t Care Notes: 1. BL = 16 for column n and column m, RL = 6, Preamble = Toggle, Postamble = 0.5nCK. 2. Dout n/m = data-out from column n and column m. 91 200b: x32 Mobile LPDDR4XSDRAM Preamble and Postamble Behavior 3. DES commands are shown for ease of illustration; other commands may be valid at these times. Figure 37: Consecutive READ: tCCD = Min +1, Preamble = Static, 1.5nCK Postamble T0 T1 T2 T3 BL BA0, CA, AP CAn CAn T7 T4 T8 T9 T10 T11 T12 BL BA0, CA, AP CAm CAm T13 T14 T15 T16 T17 T18 T19 T20 T21 T26 T27 T28 T29 T30 DES DES DES DES DES DES DES DES DES DES DES DES DES DES CK_c CK_t CS CA Command READ-1 CAS-2 DES DES t DES READ-1 CAS-2 CCD = 9 t RL = 6 t RL = 6 DQSCK DQSCK t t RPST RPRE t RPST DQS_c High-Z DQS_t High-Z t DQ DQSQ DQSQ Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout n0 n1 n2 n3 n4 n5 n6 n7 n8 n9 n10 n11 n12 n13 n14 n15 High-Z DMI t High-Z Dout Dout Dout Dout Dout Dout m0 m1 m12 m13 m14 m15 High-Z BL/2 = 8 BL/2 = 8 Don’t Care 1. BL = 16 for column n and column m, RL = 6, Preamble = Static, Postamble = 1.5nCK. 2. Dout n/m = data-out from column n and column m. 3. DES commands are shown for ease of illustration; other commands may be valid at these times. Notes: Figure 38: Consecutive READ: tCCD = Min +1, Preamble = Static, 0.5nCK Postamble T0 T1 T2 T3 BL BA0, CA, AP CAn CAn T7 T4 T8 T9 T10 T11 T12 CAm CAm T13 T14 T15 T16 T17 T18 T19 T20 T21 T26 T27 T28 T29 T30 DES DES DES DES DES DES DES DES DES DES DES DES DES DES CK_c CK_t CS CA Command READ-1 CAS-2 BL DES DES t DES BA0, CA, AP READ-1 CAS-2 CCD = 9 RL = 6 RL = 6 t t DQSCK DQSCK t t RPRE RPRE t DQS_c DQS_t High-Z High-Z t DQ DMI High-Z RPST t DQSQ DQSQ Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout n0 n1 n2 n3 n4 n5 n6 n7 n8 n9 n10 n11 n12 n13 n14 n15 BL/2 = 8 High-Z Dout Dout Dout Dout Dout Dout m0 m1 m12 m13 m14 m15 High-Z BL/2 = 8 Don’t Care Notes: 1. BL = 16 for column n and column m, RL = 6, Preamble = Static, Postamble = 0.5nCK. 2. Dout n/m = data-out from column n and column m. 92 200b: x32 Mobile LPDDR4XSDRAM Preamble and Postamble Behavior 3. DES commands are shown for ease of illustration; other commands may be valid at these times. Figure 39: Consecutive READ: tCCD = Min + 2, Preamble = Toggle, 1.5nCK Postamble T0 T1 T2 T3 BL BA0, CA, AP CAn CAn T7 T4 T8 T9 T10 T11 T12 T13 BL BA0, CA, AP CAm CAm T14 T15 T16 T17 T18 T19 T20 T21 T22 T28 T29 T30 T31 DES DES DES DES DES DES DES DES DES DES DES DES DES CK_c CK_t CS CA Command READ-1 CAS-2 DES DES t DES DES READ-1 CAS-2 CCD = 10 RL = 6 t RL = 6 t DQSCK DQSCK t t RPST RPRE t RPRE t RPST DQS_c DQS_t High-Z High-Z t DQ DMI High-Z t DQSQ Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout n0 n1 n2 n3 n4 n5 n6 n7 n8 n9 n10 n11 n12 n13 n14 n15 BL/2 = 8 High-Z DQSQ Dout Dout Dout Dout Dout Dout m0 m1 m12 m13 m14 m15 High-Z BL/2 = 8 Don’t Care Notes: 1. BL = 16 for column n and column m, RL = 6, Preamble = Toggle, Postamble = 1.5nCK. 2. Dout n/m = data-out from column n and column m. 3. DES commands are shown for ease of illustration; other commands may be valid at these times. 93 200b: x32 Mobile LPDDR4XSDRAM Preamble and Postamble Behavior Figure 40: Consecutive READ: tCCD = Min + 2, Preamble = Toggle, 0.5nCK Postamble T0 T1 T2 T3 BL BA0, CA, AP CAn CAn T4 T7 T8 T9 T10 T11 T12 T13 BL BA0, CA, AP CAm CAm T14 T15 T16 T17 T18 T19 T20 T21 T22 T28 T29 T30 T31 DES DES DES DES DES DES DES DES DES DES DES DES DES CK_c CK_t CS CA Command READ-1 CAS-2 DES DES t DES DES READ-1 CAS-2 CCD = 10 t RL = 6 t RL = 6 DQSCK DQSCK t t RPRE t RPST RPRE t DQS_c RPST High-Z DQS_t High-Z t DQ DQSQ Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout n0 n1 n2 n3 n4 n5 n6 n7 n8 n9 n10 n11 n12 n13 n14 n15 High-Z DMI t High-Z DQSQ Dout Dout Dout Dout Dout Dout m0 m1 m12 m13 m14 m15 BL/2 = 8 High-Z BL/2 = 8 Don’t Care 1. BL = 16 for column n and column m, RL = 6, Preamble = Toggle, Postamble = 0.5nCK. 2. Dout n/m = data-out from column n and column m. 3. DES commands are shown for ease of illustration; other commands may be valid at these times. Notes: Figure 41: Consecutive READ: tCCD = Min + 2, Preamble = Static, 1.5nCK Postamble T0 T1 T2 T3 BL BA0, CA, AP CAn CAn T4 T7 T8 T9 T10 T11 T12 T13 BL BA0, CA, AP CAm CAm T14 T15 T16 T17 T18 T19 T20 T21 T22 T28 T29 T30 T31 DES DES DES DES DES DES DES DES DES DES DES DES DES CK_c CK_t CS CA Command READ-1 CAS-2 DES DES t DES DES READ-1 CAS-2 CCD = 10 RL = 6 t RL = 6 t DQSCK DQSCK t t RPST RPRE t t RPRE RPST DQS_c DQS_t High-Z High-Z t DQ DMI High-Z t DQSQ Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout n0 n1 n2 n3 n4 n5 n6 n7 n8 n9 n10 n11 n12 n13 n14 n15 BL/2 = 8 High-Z DQSQ Dout Dout Dout Dout Dout Dout m0 m1 m12 m13 m14 m15 High-Z BL/2 = 8 Don’t Care Notes: 1. BL = 16 for column n and column m, RL = 6, Preamble = Static, Postamble = 1.5nCK. 2. Dout n/m = data-out from column n and column m. 94 200b: x32 Mobile LPDDR4XSDRAM Preamble and Postamble Behavior 3. DES commands are shown for ease of illustration; other commands may be valid at these times. Figure 42: Consecutive READ: tCCD = Min + 2, Preamble = Static, 0.5nCK Postamble T0 T1 T2 T3 BL BA0, CA, AP CAn CAn T4 T7 T8 T9 T10 T11 T12 T13 BL BA0, CA, AP CAm CAm T14 T15 T16 T17 T18 T19 T20 T21 T22 T28 T29 T30 T31 DES DES DES DES DES DES DES DES DES DES DES DES DES CK_c CK_t CS CA Command READ-1 CAS-2 DES DES t DES DES READ-1 CAS-2 CCD = 10 RL = 6 t RL = 6 t DQSCK DQSCK t t RPRE t RPST RPRE t RPST DQS_c DQS_t High-Z High-Z t DQ DMI High-Z t DQSQ Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout n0 n1 n2 n3 n4 n5 n6 n7 n8 n9 n10 n11 n12 n13 n14 n15 BL/2 = 8 High-Z DQSQ Dout Dout Dout Dout Dout Dout m0 m1 m12 m13 m14 m15 High-Z BL/2 = 8 Don’t Care Notes: 1. BL = 16 for column n and column m, RL = 6, Preamble = Static, Postamble = 0.5nCK. 2. Dout n/m = data-out from column n and column m. 3. DES commands are shown for ease of illustration; other commands may be valid at these times. 95 200b: x32 Mobile LPDDR4XSDRAM Preamble and Postamble Behavior Figure 43: Consecutive READ: tCCD = Min + 3, Preamble = Toggle, 1.5nCK Postamble T0 T1 T2 T3 BL BA0, CA, AP CAn CAn T4 T7 T8 T9 T10 T11 T12 T13 T14 BL BA0, CA, AP CAm CAm T15 T16 T17 T18 T19 T20 T21 T22 T23 T29 T30 T31 DES DES DES DES DES DES DES DES DES DES DES DES CK_c CK_t CS CA Command READ-1 CAS-2 DES DES t DES DES DES READ-1 CAS-2 CCD = 11 t RL = 6 t RL = 6 DES DQSCK DQSCK t t t RPST RPRE RPRE t RPST DQS_c High-Z DQS_t High-Z t DQ DQSQ Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout n0 n1 n2 n3 n4 n5 n6 n7 n8 n9 n10 n11 n12 n13 n14 n15 High-Z DMI t DQSQ Dout Dout Dout Dout Dout Dout m0 m1 m12 m13 m14 m15 High-Z BL/2 = 8 High-Z BL/2 = 8 Don’t Care 1. BL = 16 for column n and column m, RL = 6, Preamble = Toggle, Postamble = 1.5nCK. 2. Dout n/m = data-out from column n and column m. 3. DES commands are shown for ease of illustration; other commands may be valid at these times. Notes: Figure 44: Consecutive READ: tCCD = Min + 3, Preamble = Toggle, 0.5nCK Postamble T0 T1 T2 T3 BL BA0, CA, AP CAn CAn T7 T4 T8 T9 T10 T11 T12 T13 T14 BL BA0, CA, AP CAm CAm T15 T16 T17 T18 T19 T20 T21 T22 T23 T29 T30 T31 DES DES DES DES DES DES DES DES DES DES DES DES CK_c CK_t CS CA Command READ-1 CAS-2 DES DES t DES DES DES READ-1 CAS-2 CCD = 11 RL = 6 t RL = 6 t DQSCK DQSCK t t RPRE t RPST RPRE t DQS_c DQS_t High-Z DMI High-Z RPST High-Z High-Z t DQ DES t DQSQ DQSQ Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout n0 n1 n2 n3 n4 n5 n6 n7 n8 n9 n10 n11 n12 n13 n14 n15 BL/2 = 8 High-Z Dout Dout Dout Dout Dout Dout m0 m1 m12 m13 m14 m15 High-Z BL/2 = 8 Don’t Care Notes: 1. BL = 16 for column n and column m, RL = 6, Preamble = Toggle, Postamble = 0.5nCK. 2. Dout n/m = data-out from column n and column m. 3. DES commands are shown for ease of illustration; other commands may be valid at these times. 96 200b: x32 Mobile LPDDR4XSDRAM Preamble and Postamble Behavior Figure 45: Consecutive READ: tCCD = Min + 3, Preamble = Static, 1.5nCK Postamble T0 T1 T2 T3 BL BA0, CA, AP CAn CAn T4 T7 T8 T9 T10 T11 T12 T13 T14 BL BA0, CA, AP CAm CAm T15 T16 T17 T18 T19 T20 T21 T22 T23 T29 T30 T31 DES DES DES DES DES DES DES DES DES DES DES DES CK_c CK_t CS CA Command READ-1 CAS-2 DES DES t DES DES DES READ-1 CAS-2 CCD = 11 t RL = 6 t RL = 6 DES DQSCK DQSCK t t t RPST RPRE t RPRE RPST DQS_c High-Z DQS_t High-Z t DQ DQSQ DQSQ Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout n0 n1 n2 n3 n4 n5 n6 n7 n8 n9 n10 n11 n12 n13 n14 n15 High-Z DMI t Dout Dout Dout Dout Dout Dout m0 m1 m12 m13 m14 m15 High-Z BL/2 = 8 High-Z BL/2 = 8 Don’t Care 1. BL = 16 for column n and column m, RL = 6, Preamble = Static, Postamble = 1.5nCK. 2. Dout n/m = data-out from column n and column m. 3. DES commands are shown for ease of illustration; other commands may be valid at these times. Notes: Figure 46: Consecutive READ: tCCD = Min + 3, Preamble = Static, 0.5nCK Postamble T0 T1 T2 T3 BL BA0, CA, AP CAn CAn T4 T7 T8 T9 T10 T11 T12 T13 T14 BL BA0, CA, AP CAm CAm T15 T16 T17 T18 T19 T20 T21 T22 T23 T29 T30 T31 DES DES DES DES DES DES DES DES DES DES DES DES CK_c CK_t CS CA Command READ-1 CAS-2 DES DES t DES DES DES READ-1 CAS-2 CCD = 11 RL = 6 t RL = 6 t DES DQSCK DQSCK t t RPRE t RPST RPRE t RPST DQS_c DQS_t High-Z DQ DMI High-Z High-Z High-Z t t DQSQ DQSQ Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout n0 n1 n2 n3 n4 n5 n6 n7 n8 n9 n10 n11 n12 n13 n14 n15 BL/2 = 8 High-Z Dout Dout Dout Dout Dout Dout m0 m1 m12 m13 m14 m15 High-Z BL/2 = 8 Don’t Care Notes: 1. BL = 16 for column n and column m, RL = 6, Preamble = Static, Postamble = 0.5nCK. 2. Dout n/m = data-out from column n and column m. 3. DES commands are shown for ease of illustration; other commands may be valid at these times. 97 200b: x32 Mobile LPDDR4XSDRAM Preamble and Postamble Behavior Write to Write Operations – Seamless Figure 47: Seamless Write: tCCD = Min, 0.5nCK Postamble T0 T1 T2 T3 BL BA0, CA CAn CAn T5 T4 T6 T7 T8 T9 T10 T11 BL BA0, CA CAm CAm T12 T13 T14 T15 T16 T17 T18 T23 T24 T25 T26 T27 T28 DES DES DES DES DES DES DES DES DES DES DES DES DES CK_c CK_t CS CA Command WRITE-1 CAS-2 DES DES t DES DES WRITE-1 CAS-2 CCD = 8 WL = 4 WL = 4 t t t DQSS DQSS WPRE t WPST DQS_c DQS_t t DQ Din n0 DMI t DQS2DQ Din Din Din n1 n2 n3 Din n4 Din Din n5 n6 Din n7 Din n8 BL/2 = 8 Din n9 Din Din Din Din Din Din n10 n11 n12 n13 n14 n15 Din m0 DQS2DQ Din m1 Din m2 Din m3 Din m12 Din Din Din m13 m14 m15 BL/2 = 8 Don’t Care Notes: 1. BL=16, Write postamble = 0.5nCK. 2. Din n/m = data-in to column n and column m. 3. The minimum number of clock cycles from the burst write command to the burst write command for any bank is BL/2. 4. DES commands are shown for ease of illustration; other commands may be valid at these times. 98 200b: x32 Mobile LPDDR4XSDRAM Preamble and Postamble Behavior Figure 48: Seamless Write: tCCD = Min, 1.5nCK Postamble, 533MHz < Clock Frequency ≤ 800MHz, ODT Worst Timing Case T0 T1 T2 T3 BL BA0, CA CAn CAn T4 T7 T8 T9 T10 T11 BL BA0, CA CAm CAm T12 T13 T14 T15 T16 T17 T23 T24 T25 DES DES DES DES DES DES DES DES DES T31 T32 T33 T34 T35 T36 DES DES DES DES DES CK_c CK_t CS CA Command WRITE-1 CAS-2 DES DES t WRITE-1 CAS-2 CCD = 8 WL = 12 WL = 12 t t t DES DQSS DQSS t WPRE WPST DQS_c DQS_t t DQ Din n0 DMI ODTLon = 6 DRAM RTT t ODTon(MAX) t DQS2DQ Din Din Din Din Din n1 n2 n13 n14 n15 BL/2 = 8 Din m0 DQS2DQ Din m1 Din m2 Din Din Din m13 m14 m15 BL/2 = 8 ODT on ODT High-Z ODTLoff = 22 ODT High-Z t ODToff(MIN) Don’t Care Notes: 1. 2. 3. 4. Clock Frequency = 800MHz, tCK(AVG) = 1.25ns. BL=16, Write postamble = 1.5nCK. Din n/m = data-in to column n and column m. The minimum number of clock cycles from the burst write command to the burst write command for any bank is BL/2. 5. DES commands are shown for ease of illustration; other commands may be valid at these times. 99 200b: x32 Mobile LPDDR4XSDRAM Preamble and Postamble Behavior Figure 49: Seamless Write: tCCD = Min, 1.5nCK Postamble T0 T1 T2 T3 BL BA0, CA CAn CAn T4 T7 T8 T9 T10 T11 BL BA0, CA CAm CAm T12 T15 T16 T17 T18 T19 T25 T26 T27 DES DES DES DES DES DES DES DES DES T33 T34 T35 T36 T37 T38 DES DES DES DES DES CK_c CK_t CS CA Command WRITE-1 CAS-2 DES DES t CCD = 8 WRITE-1 CAS-2 WL = 14 WL = 14 t t t DES DQSS DQSS t WPST WPRE DQS_c DQS_t t DQ Din n0 DMI t DQS2DQ Din Din Din Din Din n1 n2 n13 n14 n15 BL/2 = 8 Din m0 DQS2DQ Din m1 Din m2 Din Din Din m13 m14 m15 BL/2 = 8 Don’t Care Notes: 1. BL=16, Write postamble = 1.5nCK. 2. Din n/m = data-in to column n and column m. 3. The minimum number of clock cycles from the burst write command to the burst write command for any bank is BL/2. 4. DES commands are shown for ease of illustration; other commands may be valid at these times. 100 200b: x32 Mobile LPDDR4XSDRAM Preamble and Postamble Behavior Write to Write Operations – Consecutive Figure 50: Consecutive Write: tCCD = Min + 1, 0.5nCK Postamble T0 T1 T2 T3 BL BA0, CA CAn CAn T4 T8 T9 T10 T11 T12 BL BA0, CA CAm CAm T13 T14 T15 T16 T17 T23 T24 T25 T26 T32 DES DES DES DES DES DES DES DES DES T33 T34 T35 T36 T37 DES DES DES DES DES CK_c CK_t CS CA Command WRITE-1 CAS-2 DES WRITE-1 DES t CAS-2 CCD = 9 WL = 12 WL = 12 t t t DES DQSS DQSS WPRE t WPST DQS_c DQS_t t DQ DMI t DQS2DQ DQS2DQ Din m0 Din Din Din Din Din n1 n2 n13 n14 n15 Din n0 Din m2 Din m1 Din Din Din m13 m14 m15 BL/2 = 8 BL/2 = 8 Don’t Care Notes: 1. BL=16, Write postamble = 0.5nCK. 2. Din n/m = data-in to column n and column m. 3. DES commands are shown for ease of illustration; other commands may be valid at these times. Figure 51: Consecutive Write: tCCD = Min + 1, 1.5nCK Postamble T0 T1 T2 T3 BL BA0, CA CAn CAn T4 T8 T9 T10 T11 T12 BL BA0, CA CAm CAm T13 T14 T15 T16 T17 T23 T24 T25 T26 T32 DES DES DES DES DES DES DES DES DES T33 T34 T35 T36 T37 DES DES DES DES DES CK_c CK_t CS CA Command WRITE-1 CAS-2 DES WRITE-1 DES t CAS-2 CCD = 9 WL = 12 WL = 12 t t t DES DQSS DQSS t WPRE WPST DQS_c DQS_t t DQ Din n0 DMI DQS2DQ Din Din Din Din Din n1 n2 n13 n14 n15 BL/2 = 8 t Din m0 DQS2DQ Din m1 Din m2 Din Din Din m13 m14 m15 BL/2 = 8 Don’t Care Notes: 1. BL=16, Write postamble = 1.5nCK. 2. Din n/m = data-in to column n and column m. 101 200b: x32 Mobile LPDDR4XSDRAM Preamble and Postamble Behavior 3. DES commands are shown for ease of illustration; other commands may be valid at these times. Figure 52: Consecutive Write: tCCD = Min + 2, 0.5nCK Postamble T0 T1 T2 T3 BL BA0, CA CAn CAn T4 T9 T10 T11 T12 T13 BL BA0, CA CAm CAm T14 T15 T16 T17 T23 T24 T25 T26 T27 T33 T34 T35 T36 T37 T38 DES DES DES DES DES DES DES DES DES DES DES DES DES DES DES CK_c CK_t CS CA Command WRITE-1 CAS-2 DES WRITE-1 DES t CAS-2 CCD = 10 WL = 12 WL = 12 t t t DQSS DQSS t WPRE WPRE t WPST DQS_c DQS_t t DQ DQS2DQ Din m0 Din Din Din Din Din n1 n2 n13 n14 n15 Din n0 DMI t DQS2DQ Din m2 Din m1 Din Din Din m13 m14 m15 BL/2 = 8 BL/2 = 8 Don’t Care Notes: 1. BL=16, Write postamble = 0.5nCK. 2. Din n/m = data-in to column n and column m. 3. DES commands are shown for ease of illustration; other commands may be valid at these times. Figure 53: Consecutive Write: tCCD = Min + 2, 1.5nCK Postamble T0 T1 T2 T3 BL BA0, CA CAn CAn T4 T9 T10 T11 T12 T13 BL BA0, CA CAm CAm T14 T15 T16 T17 T23 T24 T25 T26 T27 T33 T34 T35 T36 T37 T38 DES DES DES DES DES DES DES DES DES DES DES DES DES DES DES CK_c CK_t CS CA Command WRITE-1 CAS-2 DES WRITE-1 DES t CAS-2 CCD = 10 WL = 12 WL = 12 t t t DQSS DQSS t WPRE t WPRE WPST DQS_c DQS_t t DQ DQS2DQ Din n0 DMI Din Din Din Din Din n1 n2 n13 n14 n15 BL/2 = 8 t Din m0 DQS2DQ Din m1 Din m2 Din Din Din m13 m14 m15 BL/2 = 8 Don’t Care Notes: 1. BL=16, Write postamble = 1.5nCK. 102 200b: x32 Mobile LPDDR4XSDRAM Preamble and Postamble Behavior 2. Din n/m = data-in to column n and column m. 3. DES commands are shown for ease of illustration; other commands may be valid at these times. Figure 54: Consecutive Write: tCCD = Min + 3, 0.5nCK Postamble T0 T1 T2 T3 BL BA0, CA CAn CAn T4 T9 T10 T11 T12 T13 T14 BL BA0, CA CAm CAm T15 T16 T17 T23 T24 T25 T26 T27 T28 T34 T35 T36 T37 T38 DES DES DES DES DES DES DES DES DES DES DES DES DES DES CK_c CK_t CS CA Command WRITE-1 CAS-2 DES DES DES t WRITE-1 CAS-2 CCD = 11 WL = 12 WL = 12 t t t DQSS DQSS WPRE t WPST t WPRE t WPST DQS_c DQS_t t DQ Din n0 DMI DQS2DQ Din Din Din Din Din n1 n2 n13 n14 n15 BL/2 = 8 t Din m0 DQS2DQ Din m1 Din m2 Din Din Din m13 m14 m15 BL/2 = 8 Don’t Care Notes: 1. BL=16, Write postamble = 0.5nCK. 2. Din n/m = data-in to column n and column m. 3. DES commands are shown for ease of illustration; other commands may be valid at these times. 103 200b: x32 Mobile LPDDR4XSDRAM Preamble and Postamble Behavior Figure 55: Consecutive Write: tCCD = Min + 3, 1.5nCK Postamble T0 T1 T2 T3 BL BA0, CA CAn CAn T4 T9 T10 T11 T12 T13 T14 BL BA0, CA CAm CAm T15 T16 T17 T23 T24 T25 T26 T27 T28 T34 T35 T36 T37 T38 DES DES DES DES DES DES DES DES DES DES DES DES DES DES CK_c CK_t CS CA Command WRITE-1 CAS-2 DES WRITE-1 DES DES t CAS-2 CCD = 11 WL = 12 WL = 12 t t t DQSS DQSS t WPRE t WPST t WPRE WPST DQS_c DQS_t t DQ DMI t DQS2DQ Din m0 Din Din Din Din Din n1 n2 n13 n14 n15 Din n0 DQS2DQ Din m2 Din m1 Din Din Din m13 m14 m15 BL/2 = 8 BL/2 = 8 Don’t Care Notes: 1. BL=16, Write postamble = 1.5nCK. 2. Din n/m = data-in to column n and column m. 3. DES commands are shown for ease of illustration; other commands may be valid at these times. Figure 56: Consecutive Write: tCCD = Min + 4, 1.5nCK Postamble T0 T1 T2 T3 BL BA0, CA CAn CAn T4 T9 T10 T11 T12 T13 T14 BL BA0, CA CAm CAm T15 T16 T17 T23 T24 T25 T26 T27 T28 T29 T35 T36 T37 T38 DES DES DES DES DES DES DES DES DES DES DES DES DES DES CK_c CK_t CS CA Command WRITE-1 CAS-2 DES DES WRITE-1 DES t CAS-2 CCD = 12 WL = 12 WL = 12 t t t DQSS DQSS t WPRE WPST t t WPRE WPST DQS_c DQS_t t DQ Din n0 DMI DQS2DQ Din Din Din Din Din n1 n2 n13 n14 n15 BL/2 = 8 t Din m0 DQS2DQ Din m1 Din m2 Din Din Din m13 m14 m15 BL/2 = 8 Don’t Care Notes: 1. BL=16, Write postamble = 1.5nCK. 2. Din n/m = data-in to column n and column m. 3. DES commands are shown for ease of illustration; other commands may be valid at these times. 104 200b: x32 Mobile LPDDR4XSDRAM PRECHARGE Operation PRECHARGE Operation The PRECHARGE command is used to precharge or close a bank that has been activated. The PRECHARGE command is initiated with CKE, CS, and CA[5:0] in the proper state (see Command Truth Table). The PRECHARGE command can be used to precharge each bank independently or all banks simultaneously. The all banks (AB) flag and the bank address bit are used to determine which bank(s) to precharge. The precharged bank(s) will be available for subsequent row access tRPab after an all-bank PRECHARGE command is issued, or tRPpb after a single-bank PRECHARGE command is issued. To ensure that the device can meet the instantaneous current demands, the row precharge time for an all-bank PRECHARGE ( tRPab) is longer than the per-bank precharge time ( tRPpb). Table 92: Precharge Bank Selection AB (CA[5], R1) BA2 (CA[2], R2) BA1 (CA[1], R2) BA0 (CA[0], R2) Precharged Bank 0 0 0 0 Bank 0 only 0 0 0 1 Bank 1 only 0 0 1 0 Bank 2 only 0 0 1 1 Bank 3 only 0 1 0 0 Bank 4 only 0 1 0 1 Bank 5 only 0 1 1 0 Bank 6 only 0 1 1 1 Bank 7 only 1 Don't Care Don't Care Don't Care All banks Burst Read Operation Followed by Precharge The PRECHARGE command can be issued as early as BL/2 clock cycles after a READ command, but the PRECHARGE command cannot be issued until after tRAS is satisfied. A new bank ACTIVATE command can be issued to the same bank after the row precharge time ( tRP ) has elapsed. The minimum read-to-precharge time must also satisfy a minimum analog time from the second rising clock edge of the CAS-2 command. t RTP begins BL/2 - 8 clock cycles after the READ command. 105 200b: x32 Mobile LPDDR4XSDRAM PRECHARGE Operation Figure 57: Burst Read Followed by Precharge – BL16, Toggling Preamble, 0.5nCK Postamble T0 T1 T2 T3 T4 Tx Valid Valid Valid Valid Valid Valid Tx+1 Tx+2 Tx+3 Tx+4 Tx+5 Tx+6 Tx+7 Ty Ty+1 Ty+2 Ty+3 Ty+4 CK_c CK_t CA[5:0] Valid Valid Valid Valid Valid Valid tRTP READ-1 Command CAS-2 Valid Valid Valid Valid Valid tRP Valid PRECHARGE Valid Valid Valid Valid ACT-2 ACT-1 DQS_t DQS_c DQ[15:0] DMI[1:0] Valid Don’t Care Transitioning Data Figure 58: Burst Read Followed by Precharge – BL32, 2tCK, 0.5nCK Postamble T0 T1 T2 T3 T4 T5 T10 T11 T12 Tx Tx+1 Tx+2 Tx+3 Tx+4 Tx+5 Tx+6 Tx+7 Valid Valid Valid Valid Valid Valid Valid Valid Valid Valid Ty Ty+1 Ty+2 Ty+3 Ty+4 CK_c CK_t CA[5:0] Valid Valid Valid Valid Valid tRTP Command READ-1 CAS-2 Valid Valid Valid Valid Valid Valid Valid Valid Valid Valid tRP PRECHARGE Valid Valid Valid ACT-1 ACT-2 DQS_t DQS_c DQ[15:0] DMI[1:0] Valid Transitioning Data Don’t Care Burst Write Followed by Precharge A write recovery time ( tWR ) must be provided before a PRECHARGE command may be issued. This delay is referenced from the next rising edge of CK after the last valid DQS clock of the burst. Devices write data to the memory array in prefetch multiples (prefetch = 16). An internal WRITE operation can only begin after a prefetch group has been clocked; therefore, tWR starts at the prefetch boundaries. The minimum write-to-precharge time for commands to the same bank is WL + BL/2 + 1 + RU( tWR / tCK ) clock cycles. 106 200b: x32 Mobile LPDDR4XSDRAM Auto Precharge Figure 59: Burst WRITE Followed by PRECHARGE – BL16, 2nCK Preamble, 0.5nCK Postamble T0 T1 T2 T3 T4 Tx Tx+1 Tx+2 Tx+3 Tx+4 Tx+5 Tx+6 Ta Ta+1 Ta+2 Tn Tn+1 Tn+2 Tn+3 Ty Ty+1 Ty+2 Ty+3 Ty+4 Valid Valid Valid Valid Valid Valid Valid Valid Valid Valid Valid Valid Valid Valid Valid Valid Valid Valid Valid Valid Valid Valid Valid Valid PRECHARGE Valid CK_c CK_t CA WL Command WRITE-1 CAS-2 Valid Valid Valid tDQSS Valid Valid Valid tWR (MAX) ACT-1 ACT-2 tRP DQS_c DQS_t tDQS2DQ DQ DMI Valid Transitioning Data Don’t Care Auto Precharge Before a new row can be opened in an active bank, the active bank must be precharged using either the PRECHARGE command or the auto precharge (AP) function. When a READ or a WRITE command is issued to the device, the AP bit (CA5) can be set to enable the active bank to automatically begin precharge at the earliest possible moment during the burst READ or WRITE cycle. If AP is LOW when the READ or WRITE command is issued, the normal READ or WRITE burst operation is executed, and the bank remains active at the completion of the burst. If AP is HIGH when the READ or WRITE command is issued, the auto PRECHARGE function is engaged. This feature enables the PRECHARGE operation to be partially or completely hidden during burst READ cycles (dependent upon READ or WRITE latency), thus improving system performance for random data access. Burst READ With Auto Precharge If AP is HIGH when a READ command is issued, the READ with auto precharge function is engaged. The devices start an auto precharge operation on the rising edge of the clock at BL/2 after the second beat of the READ w/AP command, or BL/4 - 4 + RU(tRTP /tCK ) clock cycles after the second beat of the READ w/AP command, whichever is greater. Following an auto precharge operation, an ACTIVATE command can be issued to the same bank if the following two conditions are both satisfied: 1. The RAS precharge time (tRP) has been satisfied from the clock at which the auto precharge began, and 2. The RAS cycle time (tRC) from the previous bank activation has been satisfied. 107 200b: x32 Mobile LPDDR4XSDRAM Auto Precharge Figure 60: Burst READ With Auto Precharge – BL16, Non-Toggling Preamble, 0.5nCK Postamble T0 T1 T2 T3 T4 Tx Valid Valid Valid Valid Valid Valid Tx+1 Tx+2 Tx+3 Tx+4 Tx+5 Tx+6 Tx+7 Ty Ty+1 Ty+2 Ty+3 Ty+4 CK_c CK_t CA[5:0] Valid Valid Valid Valid Valid Valid tRTP READ-1 w/AP Command CAS-2 Valid Valid Valid Valid Valid tRPpb Valid Valid Valid Valid Valid Valid ACT-2 ACT-1 DQS_t DQS_c DQ[15:0] DMI[1:0] Valid Don’t Care Transitioning Data Figure 61: Burst READ With Auto Precharge – BL32, Toggling Preamble, 1.5nCK Postamble T0 T1 T2 T3 T4 T5 T10 T11 T12 T13 T14 Tx Valid Valid Valid Valid Valid Valid Valid Valid Valid Valid Valid Valid Tx+1 Tx+2 Tx+3 Tx+4 Tx+5 Ty Ty+1 Ty+2 Ty+3 Ty+4 CK_c CK_t CA[5:0] Valid Valid Valid tRTP Command READ-1 CAS-2 Valid Valid Valid Valid Valid Valid Valid Valid Valid tRP Valid Valid Valid Valid Valid ACT-1 ACT-2 DQS_t DQS_c DQ[15:0] DMI[1:0] Valid Transitioning Data Don’t Care Burst WRITE With Auto Precharge If AP is HIGH when a WRITE command is issued, the WRITE with auto precharge function is engaged. The device starts an auto precharge on the rising edge tWR cycles after the completion of the burst WRITE. Following a write with auto precharge, an ACTIVATE command can be issued to the same bank if the following conditions are met: 1. The RAS precharge time (tRP) has been satisfied from the clock at which the auto precharge began, and 108 200b: x32 Mobile LPDDR4XSDRAM Auto Precharge 2. The RAS cycle time (tRC) from the previous bank activation has been satisfied. Figure 62: Burst WRITE With Auto Precharge – BL16, 2nCK Preamble, 0.5nCK Postamble T0 T1 T2 T3 T4 Valid Valid Valid Valid Valid Tx Tx+1 Tx+2 Tx+3 Tx+4 Tx+5 Tx+6 Ta Ta+1 Ta+2 Tn Tn+1 Tn+2 Tn+3 Ty Ty+1 Ty+2 Ty+3 Ty+4 Valid Valid Valid Valid Valid Valid Valid Valid Valid Valid Valid Valid Valid Valid Valid Valid Valid Valid Valid CK_c CK_t CA WL Command WRITE-1 CAS-2 Valid Valid Valid tDQSS Valid Valid Valid Valid Valid tWR (MAX) ACT-1 ACT-2 tRP DQS_c DQS_t tDQS2DQ DQ[15:0] DMI[1:0] Valid Transitioning Data Don’t Care Table 93: Timing Between Commands (PRECHARGE and AUTO PRECHARGE): DQ ODT is Disable Minimum Delay Between "From Command" and "To Command" Unit Notes PRECHARGE (to same bank as READ) tRTP tCK 1, 6 PRECHARGE ALL tRTP tCK 1, 6 PRECHARGE (to same bank as READ) 8tCK + tRTP tCK 1, 6 PRECHARGE ALL 8tCK + tRTP tCK 1, 6 PRECHARGE (to same bank as READ w/AP) nRTP tCK 1, 10 PRECHARGE ALL nRTP tCK 1, 10 nRTP + tRPpb tCK 1, 8, 10 WRITE or WRITE w/AP (same bank) Illegal – MASK-WR or MASK-WR w/AP (same bank) Illegal – WRITE or WRITE w/AP (different bank) RL + RU(tDQSCK,max/tCK) + BL/2 + RD(tRPST) - WL + tWPRE tCK 3, 4, 5 MASK-WR or MASK-WR w/AP (different bank) RL + RU(tDQSCK,max/tCK) + BL/2 + RD(tRPST) - WL + tWPRE tCK 3, 4, 5 READ or READ w/AP (same bank) Illegal – READ or READ w/AP (different bank) BL/2 tCK From Command To Command READ BL = 16 READ BL = 32 READ w/AP BL = 16 ACTIVATE (to same bank as READ w/AP) 109 3 200b: x32 Mobile LPDDR4XSDRAM Auto Precharge Table 93: Timing Between Commands (PRECHARGE and AUTO PRECHARGE): DQ ODT is Disable (Continued) Minimum Delay Between "From Command" and "To Command" Unit Notes PRECHARGE (to same bank as READ w/AP) 8tCK + nRTP tCK 1, 10 PRECHARGE ALL 8tCK + nRTP tCK 1, 10 tCK 1, 8, 10 From Command To Command READ w/AP BL = 32 8tCK ACTIVATE (to same bank as READ w/AP) WRITE BL = 16 and 32 MASK-WR BL = 16 WRITE w/AP BL = 16 and 32 + nRTP + tRPpb WRITE or WRITE w/AP (same bank) Illegal – MASK-WR or MASK-WR w/AP (same bank) Illegal – WRITE or WRITE w/AP (different bank) RL + RU(tDQSCK,max/tCK) + BL/2 + RD(tRPST) - WL + tWPRE tCK 3, 4, 5 MASK-WR or MASK-WR w/AP (different bank) RL + RU(tDQSCK,max/tCK) + BL/2 + RD(tRPST) - WL + tWPRE tCK 3, 4, 5 READ or READ w/AP (same bank) Illegal – READ or READ w/AP (different bank) BL/2 tCK 3 PRECHARGE (to same bank as WRITE) WL + BL/2 + tWR + 1 tCK 1, 7 PRECHARGE ALL WL + BL/2 + tWR + 1 tCK 1, 7 tCK 1, 7 tWR +1 PRECHARGE (to same bank as MASK-WR) WL + BL/2 + PRECHARGE ALL WL + BL/2 + tWR + 1 tCK 1, 7 PRECHARGE (to same bank as WRITE w/AP) WL + BL/2 + nWR + 1 tCK 1, 11 PRECHARGE ALL WL + BL/2 + nWR + 1 tCK 1, 11 tCK 1, 8, 11 ACTIVATE (to same bank as WRITE w/AP) WL + BL/2 + nWR + 1 + tRPpb WRITE or WRITE w/AP (same bank) Illegal – READ or READ w/AP (same bank) Illegal – WRITE or WRITE w/AP (different bank) BL/2 tCK 3 MASK-WR or MASK-WR w/AP (different bank) BL/2 tCK 3 WL + BL/2 + tWTR + 1 tCK 3, 9 READ or READ w/AP (different bank) 110 200b: x32 Mobile LPDDR4XSDRAM Auto Precharge Table 93: Timing Between Commands (PRECHARGE and AUTO PRECHARGE): DQ ODT is Disable (Continued) Minimum Delay Between "From Command" and "To Command" Unit Notes PRECHARGE (to same bank as MASK-WR w/AP) WL + BL/2 + nWR +1 tCK 1, 11 PRECHARGE ALL WL + BL/2 + nWR + 1 tCK 1, 11 tCK 1, 8, 11 From Command To Command MASK-WR w/AP BL = 16 WL + BL/2 + nWR + 1 + ACTIVATE (to same bank as MASK-WR w/AP) PRECHARGE PRECHARGE ALL tRPpb WRITE or WRITE w/AP (same bank) Illegal – 3 MASK-WR or MASK-WR w/AP (same bank) Illegal – 3 WRITE or WRITE w/AP (different bank) BL/2 tCK 3 MASK-WR or MASK-WR w/AP (different bank) BL/2 tCK 3 READ or READ w/AP (same bank) Illegal – 3 READ or READ w/AP (different bank) WL + BL/2 + tWTR + 1 tCK 3, 9 PRECHARGE (to same bank as PRECHARGE) 4 tCK 1 PRECHARGE ALL 4 tCK 1 PRECHARGE 4 tCK 1 PRECHARGE ALL 4 tCK 1 Notes: 1. For a given bank, the precharge period should be counted from the latest PRECHARGE command, whether per-bank or all-bank, issued to that bank. The precharge period is satisfied tRP after that latest PRECHARGE command. 2. Any command issued during the minimum delay time as specified in the table above is illegal. 3. After READ w/AP, seamless READ operations to different banks are supported. After WRITE w/AP or MASK-WR w/AP, seamless WRITE operations to different banks are supported. READ, WRITE, and MASK-WR operations may not be truncated or interrupted. 4. tRPST values depend on MR1 OP[7] respectively. 5. tWPRE values depend on MR1 OP[2] respectively. 6. Minimum Delay Between "From Command" and "To Command" in clock cycle is calculated by dividing tRTP (in ns) by tCK (in ns) and rounding up to the next integer: Minimum Delay [cycles] = Roundup(tRTP [ns] / tCK [ns]) 7. Minimum Delay Between "From Command" and "To Command" in clock cycle is calculated by dividing tWR (in ns) by tCK (in ns) and rounding up to the next integer: Minimum Delay [cycles] = Roundup(tWR [ns] / tCK [ns]) 111 200b: x32 Mobile LPDDR4XSDRAM Auto Precharge 8. Minimum Delay Between "From Command" and "To Command" in clock cycle is calculated by dividing tRPpb (in ns) by tCK (in ns) and rounding up to the next integer: Minimum Delay [cycles] = Roundup(tRPpb [ns]/tCK [ns]) 9. Minimum Delay Between "From Command" and "To Command" in clock cycle is calculated by dividing tWTR (in ns) by tCK (in ns) and rounding up to the next integer: Minimum Delay [cycles] = Roundup(tWTR [ns]/tCK [ns]) 10. For READ w/AP the value is nRTP which is defined in Mode Register 2. 11. For WRITE w/AP the value is nWR which is defined in Mode Register 1. Table 94: Timing Between Commands (PRECHARGE and AUTO PRECHARGE): DQ ODT is Enable Minimum Delay Between "From Command" and "To Command" From Command To Command READ w/AP BL = 16 WRITE or WRITE w/AP (different bank) MASK-WR or MASK-WR w/AP (different bank) READ w/AP BL = 32 WRITE or WRITE w/AP (different bank) MASK-WR or MASK-WR w/AP (different bank) Notes: Unit Notes RL + RU(tDQSCK,max/tCK) + BL/2 + RD(tRPST) - ODTLon - RD(tODTon,min/tCK) + 1 tCK 2, 3 RL + RU(tDQSCK,max/tCK) + BL/2 - ODTLon - RD(tODTon,min/tCK) + 1 tCK 2, 3 RL + RU(tDQSCK,max/tCK) + BL/2 - ODTLon - RD(tODTon,min/tCK) + 1 tCK 2, 3 RL + RU(tDQSCK,max/tCK) + BL/2 - ODTLon - RD(tODTon,min/tCK) + 1 tCK 2, 3 + RD(tRPST) + RD(tRPST) + RD(tRPST) 1. The rest of the timing about PRECHARGE and AUTO PRECHARGE is same as DQ ODT is Disable case. 2. After READ w/AP, seamless read operations to different banks are supported. READ, WRITE, and MASK-WR operations may not be truncated or interrupted. 3. tRPST values depend on MR1 OP[7] respectively. RAS Lock Function READ with AUTO PRECHARGE or WRITE/MASK WRITE with AUTO PRECHARGE commands may be issued after tRCD has been satisfied. The LPDDR4 SDRAM RAS lockout feature will schedule the internal precharge to assure that tRAS is satisfied. tRC needs to be satisfied prior to issuing subsequent ACTIVATE commands to the same bank. The figure below shows example of RAS lock function. 112 200b: x32 Mobile LPDDR4XSDRAM Auto Precharge Figure 63: Command Input Timing with RAS Lock T0 T1 T2 T3 RA RA BA0 RA RA T4 T19 T20 T21 T22 T23 T24 T25 T31 T32 T38 T39 T47 T48 Ta0 Ta1 Ta2 Ta3 Ta4 RA RA BA0 RA Ta5 CK_c CK_t CKE CS CA Command Activate-1 Activate-2 Valid DES DES BA0 CA RDA-1 tRCD CA CAS-2 DES = 20nCK DES DES 8nCK DES DES DES DES DES DES DES Activate-1 RA Activate-2 nRTP = 8nCK tRAS tRC Don’t Care 1. tCK(AVG) = 0.938ns, Data rate = 2133Mbps, tRCD(Min) = Max(18ns, 4nCK), tRAS(Min) = Max(42ns, 3nCK), nRTP = 8nCK, BL = 32. 2. tRCD = 20nCK comes from Roundup(18ns/0.938ns) 3. DES commands are shown for ease of illustration; other commands may be valid at these times. Notes: Delay time from Write to Read with Auto Precharge In the case of WRITE command followed by READ with AUTO PRECHARGE, controller must satisfy tWR for the WRITE command before initiating the device internal auto-precharge. It means that (tWTR + nRTP) should be equal or longer than (tWR) when BL setting is 16, as well as (tWTR + nRTP + 8nCK) should be equal or longer than (tWR) when BL setting is 32. Refer to the following figure for details. Figure 64: Delay Time from Write to Read with Auto Precharge T0 T1 T2 T3 BL BA0 CA CA CA T4 Ta0 Ta1 Ta2 Tb0 Tb1 Tb2 Tb3 Tc0 Tc1 Tc2 Tc3 Tc4 Tc5 Tc6 Td0 Td1 Td2 DES DES DES DES Td3 Td4 CK_c CK_t CKE CS CA Command Write-1 CAS-2 Valid DES DES WL DES DES DES DES DES DES DES DES BA0 CA RDA-1 CAS-2 tWTR BL/2 + 1 clock CA DES DES nRTP tWR Don’t Care Notes: 1. Burst length at read = 16. 113 200b: x32 Mobile LPDDR4XSDRAM REFRESH Command 2. DES commands are shown for ease of illustration; other commands may be valid at these times. REFRESH Command The REFRESH command is initiated with CS HIGH, CA0 LOW, CA1 LOW, CA2 LOW, CA3 HIGH and CA4 LOW at the first rising edge of clock. Per bank REFRESH is initiated with CA5 LOW at the first rising edge of the clock. The all-bank REFRESH is initiated with CA5 HIGH at the first rising edge of clock. A per bank REFRESH command (REFpb) is performed to the bank address as transferred on CA0, CA1, and CA2 on the second rising edge of the clock. Bank address BA0 is transferred on CA0, bank address BA1 is transferred on CA1, and bank address BA2 is transferred on CA2. A per bank REFRESH command (REFpb) to the eight banks can be issued in any order. For example, REFpb commands may be issued in the following order: 1-3-0-2-4-7-5-6. After the eight banks have been refreshed using the per bank REFRESH command, the controller can send another set of per bank REFRESH commands in the same order or a different order. One possible order can be a sequential round robin: 0-1-2-3-4-5-6-7. It is illegal to send a per bank REFRESH command to the same bank unless all eight banks have been refreshed using the per bank REFRESH command. The count of eight REFpb commands starts with the first REFpb command after a synchronization event. The bank count is synchronized between the controller and the device by resetting the bank count to zero. Synchronization can occur upon reset procedure or at every exit from self refresh. The REFab command also synchronizes the counter between the controller and the device to zero. The device can be placed in self refresh, or a REFab command can be issued at any time without cycling through all eight banks using per bank REFRESH command. After the bank count is synchronized to zero, the controller can issue per bank REFRESH commands in any order, as described above. A REFab command issued when the bank counter is not zero will reset the bank counter to zero and the device will perform refreshes to all banks as indicated by the row counter. If another REFRESH command (REFab or REFpb) is issued after the REFab command then it uses an incremented value of the row counter. The table below shows examples of both bank and refresh counter increment behavior. Table 95: Bank and Refresh Counter Increment Behavior # Command BA0 0 BA1 BA2 Refresh Bank # Reset, SRX or REFab Bank Counter # Ref. Conter # (Row Address #) To 0 – n 1 REFpb 0 0 0 0 0 to 1 2 REFpb 0 0 1 1 1 to 2 3 REFpb 0 1 0 2 2 to 3 4 REFpb 0 1 1 3 3 to 4 5 REFpb 1 0 0 4 4 to 5 6 REFpb 1 0 1 5 5 to 6 7 REFpb 1 1 0 6 6 to 7 8 REFpb 1 1 1 7 7 to 0 114 200b: x32 Mobile LPDDR4XSDRAM REFRESH Command Table 95: Bank and Refresh Counter Increment Behavior (Continued) # Command BA0 BA1 BA2 Refresh Bank # Bank Counter # Ref. Conter # (Row Address #) 9 REFpb 1 1 0 6 0 to 1 n+1 10 REFpb 1 1 1 7 1 to 2 ... 15 REFpb 0 0 0 0 6 to 7 16 REFpb 1 0 0 4 7 to 0 17 REFpb 0 0 0 0 0 to 1 18 REFpb 0 0 1 1 1 to 2 n+2 19 REFpb 0 1 0 2 2 to 3 24 REFab V V V 0 to 7 To 0 n+2 25 REFpb 1 1 0 6 0 to 1 n+3 26 REFpb 1 1 1 7 1 to 2 Snip A bank must be idle before it can be refreshed. The controller must track the bank being refreshed by the per bank REFRESH command. The REFpb command must not be issued to the device until the following conditions have been met: • • • • tRFCab has been satisfied after the prior REFab command has been satisfied after the prior REFpb command tRP has been satisfied after the prior PRECHARGE command to that bank tRRD has been satisfied after the prior ACTIVATE command (for example, after activating a row in a different bank than the one affected by the REFpb command) tRFCpb The target bank is inaccessible during per bank REFRESH cycle time (tRFCpb). However, other banks within the device are accessible and can be addressed during the cycle. During the REFpb operation, any of the banks other than the one being refreshed can be maintained in an active state or accessed by a READ or a WRITE command. When the per bank REFRESH cycle has completed, the affected bank will be in the idle state. After issuing REFpb, the following conditions must be met: • • • • tRFCpb must be satisfied before issuing a REFab command must be satisfied before issuing an ACTIVATE command to the same bank tRRD must be satisfied before issuing an ACTIVATE command to a different bank tRFCpb must be satisfied before issuing another REFpb command tRFCpb An all-bank REFRESH command (REFab) issues a REFRESH command to every bank in a channel. All banks must be idle when REFab is issued (for example, by issuing a PRECHARGE ALL command prior to issuing an all-bank REFRESH command). The REFab command must not be issued to the device until the following conditions have been met: • tRFCab has been satisfied following the prior REFab command • tRFCpb has been satisfied following the prior REFpb command 115 200b: x32 Mobile LPDDR4XSDRAM REFRESH Command • tRP has been satisfied following the prior PRECHARGE command When an all-bank REFRESH cycle has completed, all banks will be idle. After issuing REFab: • RFCab latency must be satisfied before issuing an ACTIVATE command, • RFCab latency must be satisfied before issuing a REFab or REFpb command Table 96: REFRESH Command Timing Constraints Symbol Minimum Delay From... To tRFCab REFab REFab Notes ACTIVATE command to any bank REFpb tRFCpb REFpb REFab ACTIVATE command to same bank as REFpb REFpb tRRD REFpb ACTIVATE command to a different bank than REFpb ACTIVATE REFpb 1 ACTIVATE command to a different bank than the prior ACTIVATE command 1. A bank must be in the idle state before it is refreshed; therefore, REFab is prohibited following an ACTIVATE command. REFpb is supported only if it affects a bank that is in the idle state. Note: Figure 65: All-Bank REFRESH Operation T0 T1 T2 T3 T4 Ta0 Ta1 Ta2 Ta3 Ta4 Ta5 Tb0 Tb1 Tb2 Tb3 Tb4 Tb5 Tc0 Tc1 Tc2 Tc3 CK_c CK_t CKE CS CA Valid t Command Precharge all bank Valid Valid Valid Valid Valid DES DES t RPab DES DES All-bank refresh DES DES Valid Valid t RFCab DES DES All-bank refresh DES DES RFCab DES DES Any command DES Don’t Care 116 200b: x32 Mobile LPDDR4XSDRAM REFRESH Command Figure 66: Per Bank REFRESH Operation T0 T1 T2 Ta0 T3 Ta1 Ta2 Valid BA0 Ta3 Ta4 Tb0 Tb1 Tb2 Valid BA1 Tb3 Tb4 Tc0 Tc1 Tc2 Tc3 Tc4 Valid BA1 Valid Valid Activate-1 Activate-2 Tc5 Tc6 DES DES CK_c CK_t CKE CS CA Valid Valid t Command Precharge all bank DES t RPab DES DES Per bank refresh DES t RFCpb DES DES Per bank refresh DES RFCpb DES DES Don’t Care Notes: 1. In the beginning of this example, the REFpb bank is pointing to bank 0. 2. Operations to banks other than the bank being refreshed are supported during the tRFCpb period. In general, a REFRESH command needs to be issued to the device regularly every tREFI interval. To allow for improved efficiency in scheduling and switching between tasks, some flexibility in the absolute refresh interval is provided. A maximum of eight REFRESH commands can be postponed during operation of the device, but at no point in time are more than a total of eight REFRESH commands allowed to be postponed. And a maximum number of pulled-in or postponed REF command is dependent on refresh rate. It is described in the table below. In the case where eight REFRESH commands are postponed in a row, the resulting maximum interval between the surrounding REFRESH commands is limited to 9 × tREFI. A maximum of eight additional REFRESH commands can be issued in advance (pulled in), with each one reducing the number of regular REFRESH commands required later by one. Note that pulling in more than eight REFRESH commands in advance does not reduce the number of regular REFRESH commands required later; therefore, the resulting maximum interval between two surrounding REFRESH commands is limited to 9 × tREFI. At any given time, a maximum of 16 REFRESH commands can be issued within 2 × tREFI. Self refresh mode may be entered with a maximum of eight REFRESH commands being postponed. After exiting self refresh mode with one or more REFRESH commands postponed, additional REFRESH commands may be postponed to the extent that the total number of postponed REFRESH commands (before and after self refresh) will never exceed eight. During self refresh mode, the number of postponed or pulled-in REFRESH commands does not change. 117 200b: x32 Mobile LPDDR4XSDRAM REFRESH Command Table 97: Legacy REFRESH Command Timing Constraints MR4 OP[2:0] 000b Refresh rate Max. No. of pulled-in or postponed REFab Max. Interval between two REFab Max. No. of REFab1 Per-bank Refresh Low Temp. Limit N/A N/A N/A N/A 001b 4× tREFI 010b 2 × tREFI 011b 1 × tREFI 100b tREFI 0.5 × 101b 0.25 × tREFI 110b 0.25 × tREFI 111b High Temp. Limit Note: 8 9×4× tREFI 16 1/8 of REFab 8 9 × 2 × tREFI 16 1/8 of REFab 8 9 × tREFI 16 1/8 of REFab 8 9 × 0.5 × tREFI 16 1/8 of REFab 8 9 × 0.25 × tREFI 16 1/8 of REFab 8 9 × 0.25 × tREFI 16 1/8 of REFab N/A N/A N/A N/A 1. Maximum number of REFab within MAX(2 × tREFI × refresh rate multiplier, 16 × tRFC). Table 98: Modified REFRESH Command Timing Constraints MR4 OP[2:0] Refresh rate Max. No. of pulled-in or postponed REFab 000B LOW Temp. Limit 001B 4 × tREFI 010B 2 × tREFI 011B tREFI 1× tREFI Max. Interval between two REFab Max. No. of REFab*1 N/A N/A N/A N/A 2 3 × 4 × tREFI 4 1/8 of REFab 4 5 × 2 × tREFI 8 1/8 of REFab 16 1/8 of REFab 8 9× tREFI tREFI Per-bank refresh 100B 0.5 × 8 9 × 0.5 × 16 1/8 of REFab 101B 0.25 × tREFI 8 9 × 0.25 × tREFI 16 1/8 of REFab 110B 0.25 × tREFI 8 9 × 0.25 × tREFI 16 1/8 of REFab 111B HIGH Temp. Limit N/A N/A N/A N/A Notes: 1. For any thermal transition phase where refresh mode is transitioned to either 2 × tREFI or 4 × tREFI, LPDDR4 devices will support the previous postponed refresh requirement provided the number of postponed refreshes is monotonically reduced to meet the new requirement. However, the pulled-in REFRESH commands in previous thermal phase are not applied in new thermal phase. Entering new thermal phase the controller must count the number of pulled-in REFRESH commands as zero, regardless of remaining pulled-in REFRESH commands in previous thermal phase. 2. LPDDR4 devices are refreshed properly if memory controller issues REFRESH commands with same or shorter refresh period than reported by MR4 OP[2:0]. If shorter refresh period is applied, the corresponding requirements from Table apply. For example, when MR4 OP[2:0] = 001b, controller can be in any refresh rate from 4 × tREFI to 0.25 × tREFI. When MR4 OP[2:0] = 010b, the only prohibited refresh rate is 4 × tREFI. 118 200b: x32 Mobile LPDDR4XSDRAM Refresh Requirement Figure 67: Postponing REFRESH Commands (Example) tREFI 9 tREFI t tRFC 8 REFRESH commands postponed Figure 68: Pulling In REFRESH Commands (Example) tREFI 9 tREFI t tRFC 8 REFRESH commands pulled in Refresh Requirement Between the SRX command and SRE command, at least one extra REFRESH command is required. After the SELF REFRESH EXIT command, in addition to the normal REFRESH command at tREFI interval, the device requires a minimum of one extra REFRESH command prior to the SELF REFRESH ENTRY command. Table 99: Refresh Requirement Parameters Density (per channel) Parameter Symbol 12Gb 16Gb Unit – 8 TBD TBD – (tREFW): tREFW 32 TBD TBD ms Refresh window (tREFW): 1/2 rate refresh tREFW 16 TBD TBD ms Number of banks per channel Refresh window TCASE ≤ 85˚ 2Gb 3Gb 119 4Gb 6Gb 8Gb 200b: x32 Mobile LPDDR4XSDRAM SELF REFRESH Operation Table 99: Refresh Requirement Parameters (Continued) Density (per channel) Parameter Refresh window 1/4 rate refresh Symbol (tREFW): Required number of REFRESH commands in tREFW window Average refresh internal REFab REFpb 12Gb 16Gb Unit 8 TBD TBD ms R 8192 TBD TBD – tREFI 3.904 TBD TBD μs tREFIpb 488 TBD TBD ns tREFW 2Gb 3Gb 4Gb 6Gb 8Gb REFRESH cycle time (all banks) tRFCab 130 180 280 TBD TBD ns REFRESH cycle time (per bank) tRFCpb 60 90 140 TBD TBD ns Notes: 1. Refresh for each channel is independent of the other channel on the die, or other channels in a package. Power delivery in the user’s system should be verified to make sure the DC operating conditions are maintained when multiple channels are refreshed simultaneously. 2. Self refresh abort feature is available for higher density devices starting with 6Gb density per channel device and tXSR_abort(min) is defined as tRFCpb + 17.5ns. SELF REFRESH Operation Self Refresh Entry and Exit The SELF REFRESH command can be used to retain data in the device without external REFRESH commands. The device has a built-in timer to accommodate SELF REFRESH operation. Self refresh is entered by the SELF REFRESH ENTRY command defined by having CS HIGH, CA0 LOW, CA1 LOW, CA2 LOW, CA3 HIGH, CA4 HIGH, and CA5 valid (valid meaning that it is at a logic level HIGH or LOW) for the first rising edge, and CS LOW, CA0 valid, CA1 valid, CA2 valid, CA3 valid, CA4 valid, and CA5 valid at the second rising edge of clock. The SELF REFRESH command is only allowed when READ DATA burst is completed and the device is in the idle state. During self refresh mode, external clock input is needed and all input pins of the device are activated. The device can accept the following commands: MRR-1, CAS-2, DES, SRX, MPC, MRW-1, and MRW-2, except PASR bank/segment setting. The device can operate in self refresh mode within the standard and elevated temperature ranges. It also manages self refresh power consumption when the operating temperature changes: lower at low temperatures and higher at high temperatures. For proper SELF REFRESH operation, power supply pins (VDD1, V DD2, and V DDQ) must be at valid levels. V DDQ can be turned off during self refresh with power-down after tESCKE is satisfied. (Refer the figure of Power Down Entry and Exit during Self Refresh.) Prior to exiting self refresh with power-down, V DDQ must be within specified limits. The minimum time that the device must remain in self refresh mode is tSR (MIN). Once self refresh exit is registered, only MRR-1, CAS-2, DES, MPC, MRW-1, and MRW-2 except PASR bank/segment setting are allowed until tXSR is satisfied. The use of self refresh mode introduces the possibility that an internally timed refresh event can be missed when self refresh exit is registered. Upon exit from self refresh, it is 120 200b: x32 Mobile LPDDR4XSDRAM SELF REFRESH Operation required that at least one REFRESH command (8 per-bank or 1 all-bank) is issued before entry into a subsequent self refresh. Figure 69: Self Refresh Entry/Exit Timing T0 T1 T2 T3 Tb0 Ta0 Tb1 Tc0 Td1 Te0 Tf0 Tg0 Tf1 Tg1 Th0 Tk0 Tk1 Tk2 Tk3 CK_c Note 2 CK_t t CKE t t CKELCK CKCKEH CKE t CSCKE tCKELCS t CSCKEH t CKEHCS CS t ESCKE t CMDCKE CA Valid Valid Valid t XP Valid Valid Valid t SR Note 3 Note 3 Command SELFWrite-2 REFRESH MR ENTRY Any command DES DES Enter self refresh DES Any command DES Exit self refresh Don’t Care Notes: 1. MRR-1, CAS-2, DES, SRX, MPC, MRW-1, and MRW-2 commands (except PASR bank/ segment setting) are allowed during self refresh. 2. DES commands are shown for ease of illustration; other commands may be valid at these times. Power-Down Entry and Exit During Self Refresh Entering/exiting power-down mode is allowed during self refresh mode. The related timing parameters between self refresh entry/exit and power-down entry/exit are shown below. 121 200b: x32 Mobile LPDDR4XSDRAM SELF REFRESH Operation Figure 70: Self Refresh Entry/Exit Timing with Power-Down Entry/Exit T0 T1 T2 T3 Tb0 Ta0 Tb1 Tc0 Td1 Te0 Tf0 Tg0 Tf1 Tg1 Th0 Tk0 Tk1 Tk2 Tk3 CK_c Note 2 CK_t t CKE t t CKELCK CKCKEH CKE t CSCKE tCKELCS t CSCKEH t CKEHCS CS t ESCKE t CMDCKE CA Valid Valid Valid t XP Valid Valid Valid t SR Note 3 Command SELFWrite-2 REFRESH Any command MR ENTRY Enter self refresh DES DES DES SELF REFRESH DES EXIT Exit self refresh Don’t Care Notes: 1. MRR-1, CAS-2, DES, SRX, MPC, MRW-1, and MRW-2 commands (except PASR bank/ segment setting) are allowed during self refresh. 2. Input clock frequency can be changed, or the input clock can be stopped, or floated after tCKELCK satisfied and during power-down, provided that upon exiting power-down, the clock is stable and within specified limits for a minimum of tCKCKEH of stable clock prior to power-down exit and the clock frequency is between the minimum and maximum specified frequency for the speed grade in use. 3. Two Clock command for example. Command Input Timing After Power Down Exit Command input timings after power-down exit during self refresh mode are shown below. 122 200b: x32 Mobile LPDDR4XSDRAM SELF REFRESH Operation Figure 71: Command Input Timings after Power-Down Exit during Self Refresh T0 T1 T2 T3 Ta0 Tb0 Tc0 Tb1 Td1 Te0 Tf1 Tf0 Tg0 Tg1 Th0 Tk0 Tk1 Tk2 Tk3 CK_c Note 2 CK_t t CKE t t CKELCK CKCKEH CKE t CSCKE tCKELCS t CSCKEH t CKEHCS CS t ESCKE t CMDCKE CA Valid Valid Valid t XP Valid Valid Valid t SR Note 3 Note 3 Command SELFWrite-2 REFRESH Any command MR ENTRY Enter self refresh DES DES DES Any command DES Exit self refresh Don’t Care Notes: 1. MRR-1, CAS-2, DES, SRX, MPC, MRW-1, and MRW-2 commands (except PASR bank/ segment setting) are allowed during self refresh. 2. Input clock frequency can be changed or the input clock can be stopped or floated after tCKELCK satisfied and during power-down, provided that upon exiting power-down, the clock is stable and within specified limits for a minimum of tCKCKEH of stable clock prior to power-down exit and the clock frequency is between the minimum and maximum specified frequency for the speed grade in use. 3. Two Clock command for example. Self Refresh Abort If MR4 OP[3] is enabled, the device aborts any ongoing refresh during self refresh exit and does not increment the internal refresh counter. The controller can issue a valid command after a delay of tXSR_abort instead of tXSR. The value of tXSR_abort (MIN) is defined as tRFCpb + 17.5ns. Upon exit from self refresh mode, the device requires a minimum of one extra refresh (eight per bank or one for the entire bank) before entering a subsequent self refresh mode. This requirement remains the same irrespective of the setting of the MR bit for self refresh abort. Self refresh abort feature is valid for 6Gb density per channel and larger densities only. MRR, MRW, MPC Command During tXSR, tRFC Mode Register Read (MRR), Mode Register Write (MRW) and Multi Purpose Command (MPC) can be issued during tXSR period. 123 200b: x32 Mobile LPDDR4XSDRAM SELF REFRESH Operation Figure 72: MRR, MRW, and MPC Commands Issuing Timing During tXSR T0 T1 T2 T4 T3 T5 T6 T7 Ta0 Ta1 Ta2 Ta3 Ta4 Ta5 Ta6 Tb0 Tb1 Tb2 Tb3 Tb4 Tb5 CK_c CK_t CKE CS “H” for case 2 CS CA Valid Valid Valid Valid Valid Valid Valid Valid Valid Valid t MRD Command DES (Case 1) SRX MPC (2 clock command) DES DES DES DES MRW-1 MRW-2 DES DES DES Note 3 DES Any Command t MRD Command DES (Case 2) SRX MPC (4 clock command) CAS-2 DES DES MRW-1 MRW-2 DES DES DES Note 3 DES Any Command XSR Note 2 t Don’t Care Notes: 1. MPC and MRW command are shown in figure at this time, Any combination of MRR, MRW, and MPC is allowed during tXSR period. 2. Any command also includes MRR, MRW, and all MPC command. Mode Register Read (MRR), Mode Register Write (MRW), and Multi Purpose Command (MPC) can be issued during tRFC period. 124 200b: x32 Mobile LPDDR4XSDRAM SELF REFRESH Operation Figure 73: MRR, MRW, and MPC Commands Issuing Timing During tRFC T0 T1 T2 T3 T4 T5 T6 T7 Ta0 Ta1 Ta2 Ta3 Ta4 Ta5 Ta6 Tb0 Tb1 Tb2 Tb3 Tb4 Tb5 CK_c CK_t CKE CS “H” for case 2 CS CA Valid Valid Valid Valid Valid Valid Valid Valid Valid Valid t MRD Command DES REF all bank (Case 1) MPC (2 clock command) DES DES DES DES MRW-1 MRW-2 DES DES DES Note 3 DES Any Command t MRD Command DES REF all bank (Case 2) MPC (4 clock command) CAS-2 DES DES MRW-1 MRW-2 DES DES DES Note 3 DES Any Command RFCab Note 2 t Don’t Care Notes: 1. MPC and MRW command are shown in figure at this time, Any combination of MRR, MRW, and MPC is allowed during tRFCab or tRFCpb period. 2. Refresh cycle time depends on REFRESH command. In case of REF PER BANK command issued, refresh cycle time will be tRFCpb. 3. Any command also includes MRR, MRW, and all MPC command. 125 200b: x32 Mobile LPDDR4XSDRAM Power-Down Mode Power-Down Mode Power-Down Entry and Exit Power-down is asynchronously entered when CKE is driven LOW. CKE must not go LOW while the following operations are in progress: • • • • • • • • Mode register read Mode register write Read Write VREF(CA) range and value setting via MRW VREF(DQ) range and value setting via MRW Command bus training mode entering/exiting via MRW VRCG HIGH current mode entering/exiting via MRW CKE can go LOW while any other operations such as row activation, precharge, auto precharge, or refresh are in progress. The power-down IDD specification will not be applied until such operations are complete. Power-down entry and exit are shown below. Entering power-down deactivates the input and output buffers, excluding CKE and RESET_n. To ensure that there is enough time to account for internal delay on the CKE signal path, CS input is required stable LOW level and CA input level is "Don’t care" after CKE is driven LOW, this timing period is defined as tCKELCS. Clock input is required after CKE is driven LOW, this timing period is defined as tCKELCK. CKE LOW will result in deactivation of all input receivers except RESET_n after tCKELCK has expired. In powerdown mode, CKE must be held LOW; all other input signals except RESET_n are "Don't Care". CKE LOW must be maintained until tCKE(MIN) is satisfied. VDDQ can be turned off during power-down. Prior to exiting power-down, V DDQ must be within its minimum/maximum operating range. No refresh operations are performed in power-down mode except self refresh power-down. The maximum duration in nonself-refresh power-down mode is only limited by the refresh requirements outlined in the refresh command section. The power-down state is asynchronously exited when CKE is driven HIGH. CKE HIGH must be maintained until tCKE(MIN) is satisfied. A valid, executable command can be applied with power-down exit latency tXP after CKE goes HIGH. Power-down exit latency is defined in the AC timing parameter table. Clock frequency change or clock stop is inhibited during tCMDCKE, tCKELCK, and tZQCKE periods. tCKCKEH, tXP, tMRWCKEL, If power-down occurs when all banks are idle, this mode is referred to as idle powerdown. if power-down occurs when there is a row active in any bank, this mode is referred to as active power-down. And If power-down occurs when self refresh is in progress, this mode is referred to as self refresh power-down in which the internal refresh is continuing in the same way as self refresh mode. When CA, CK and/or CS ODT is enabled via MR11 OP[6:4] and also via MR22 or CAODT pad setting, the rank providing ODT will continue to terminate the command bus in all DRAM states including power-down. The LPDDR4 DRAM cannot be placed in power-down state during start DQS interval oscillator operation. 126 200b: x32 Mobile LPDDR4XSDRAM Power-Down Mode Figure 74: Basic Power-Down Entry and Exit Timing T0 T1 Ta0 Tb0 Tb1 Tc0 CK_c Tc1 Td0 Te0 Te1 Tf0 Tf1 Tg0 Th0 Th1 Th2 Th3 Tk0 Tk1 Tk2 Note 1 CK_t tCKE t CMDCKE t CKELCK t CKE t CKCKEH t XP CKE t CSCKE t CKELCS t CSCKEH t CKEHCS CS CA Command Valid Valid Valid Valid Valid DES DES DES Valid DES DES Don’t Care Note: 1. Input clock frequency can be changed or the input clock can be stopped or floated during power-down, provided that upon exiting power-down, the clock is stable and within specified limits for a minimum of tCKCKEH of stable clock prior to power-down exit and the clock frequency is between the minimum and maximum specified frequency for the speed grade in use. 127 200b: x32 Mobile LPDDR4XSDRAM Power-Down Mode Figure 75: Read and Read with Auto Precharge to Power-Down Entry T0 T1 T2 T3 T4 Ta0 Ta1 Ta2 Tb1 Tb0 Tb2 Tb3 Tc0 Tc1 DES DES DES Tc2 Tc3 Tc4 Td0 Td1 CK_c CK_t CKE See Note 2 CS CA Valid Valid Valid Valid Command Read-1 CAS-2 DES DES DES DES DES DES t RL DES DQSCK DQS_c DQS_t t t DQ DMI RPRE RPST DO DO DO DO DO DO n0 n1 n2 n13 n14 n15 Don’t Care Notes: 1. CKE must be held HIGH until the end of the burst operation. 2. Minimum Delay time from READ command or READ with AUTO PRECHARGE command to falling edge of CKE signal is as follows. When read post-amble = 0.5nCK (MR1 OP[7] = [0] ), (RL × tCK) + tDQSCK(MAX) + ((BL/2) × tCK) + 1tCK When read post-amble = 1.5nCK (MR1 OP[7] = [1]), (RL × tCK) + tDQSCK(MAX) + ((BL/2) × tCK) + 2tCK 128 200b: x32 Mobile LPDDR4XSDRAM Power-Down Mode Figure 76: Write and Mask Write to Power-Down Entry T0 T1 T2 T3 T4 Ta0 Ta1 Ta2 Ta3 Ta4 Tb0 Tb1 Tb2 Tc0 DES DES DES DES Tc1 Tc2 Td0 Td1 Td2 CK_c CK_t CKE See Note 2 CS CA Command Valid Valid Valid Valid Write-1 Mask Write-1 CAS-2 DES DES DES WL t DES DES t DQSS WPRE t DES t DQS2DQ DI n0 DI n1 WPST BL/2 t WR DI DI DI DI n2 n13 n14 n15 Don’t Care Notes: 1. CKE must be held HIGH until the end of the burst operation. 2. Minimum delay time from WRITE command or MASK WRITE command to falling edge of CKE signal is as follows. (WL × tCK) + tDQSS(MAX) + tDQS2DQ(MAX) + ((BL/2) × tCK) + tWR 3. This timing is applied regardless of DQ ODT disable/enable setting: MR11 OP[2:0]. 4. This timing diagram only applies to the WRITE and MASK WRITE commands without auto precharge. 129 200b: x32 Mobile LPDDR4XSDRAM Power-Down Mode Figure 77: Write with Auto Precharge and Mask Write with Auto Precharge to Power-Down Entry T0 T1 T2 T3 T4 Ta0 Ta1 Ta2 Ta3 Ta4 Tb0 Tb1 Tb2 Tc0 Tc1 Tc2 Tc3 DES DES DES DES DES DES DES Tc4 Td0 CK_c CK_t CKE See Note 2 CS CA Valid Valid Valid Valid Write-1 Command Mask Write-1 CAS-2 DES DES DES DES WL t DES t DQSS WPRE t DES t DQS2DQ DI n0 DI n1 WPST BL/2 DI DI DI DI n2 n13 n14 n15 Don’t Care Notes: 1. CKE must be held HIGH until the end of the burst operation. 2. Delay time from WRITE with AUTO PRECHARGE command or MASK WRITE with AUTO PRECHARGE command to falling edge of CKE signal is more than (WL × tCK) + tDQSS(MAX) + tDQS2DQ(MAX) + ((BL/2) × tCK) + (nWR × tCK) + (2 × tCK) 3. This timing is applied regardless of DQ ODT disable/enable setting: MR11 OP[2:0]. 130 200b: x32 Mobile LPDDR4XSDRAM Power-Down Mode Figure 78: Refresh Entry to Power-Down Entry T0 T1 T2 Ta0 Ta1 Ta2 Ta3 Tb0 Tb1 Tb2 Tb3 Tb4 Tb5 Tb6 Tb7 Tb8 Tb9 Tb10 CK_c CK_t CKE t CMDCKE CS CA Valid Valid Command Refresh DES DES Don’t Care Note: 1. CKE must be held HIGH until tCMDCKE is satisfied. Figure 79: Activate Command to Power-Down Entry T0 T1 T2 T3 T4 Ta0 Ta1 Ta2 Ta3 Tb0 Tb1 Tb2 Tb4 Tb5 Tb6 Tb7 Tb8 Tb9 CK_c CK_t CKE t CMDCKE CS CA Valid Valid Valid Valid Command Activate-1 Activate-2 DES DES Don’t Care Note: 1. CKE must be held HIGH until tCMDCKE is satisfied. 131 200b: x32 Mobile LPDDR4XSDRAM Power-Down Mode Figure 80: Precharge Command to Power-Down Entry T0 T1 T2 Ta0 Ta1 Ta2 Ta3 Tb1 Tb2 Tb3 Tb4 Tb5 Tb6 Tb7 Tb8 Tb9 Tb10 Tb11 CK_c CK_t CKE t CMDCKE CS CA Valid Valid Command Precharge DES DES Don’t Care Note: 1. CKE must be held HIGH until tCMDCKE is satisfied. 132 200b: x32 Mobile LPDDR4XSDRAM Power-Down Mode Figure 81: Mode Register Read to Power-Down Entry T0 T1 T2 T3 T4 Ta0 Ta1 Ta2 Tb1 Tb0 Tb2 Tb3 Tc0 Tc1 DES DES DES Tc2 Tc3 Tc4 Td0 Td1 CK_c CK_t CKE See Note 2 CS CA Valid Valid Valid Valid Command MR Read-1 CAS-2 DES DES DES DES DES DES t RL DES DQSCK DQS_c DQS_t t t DQ DMI RPRE RPST DO DO DO DO DO DO n0 n1 n2 n13 n14 n15 Don’t Care Notes: 1. CKE must be held HIGH until the end of the burst operation. 2. Minimum delay time from MODE REGISTER READ command to falling edge of CKE signal is as follows: When read post-amble = 0.5nCK ( MR1 OP[7] = [0] ), (RL × tCK) + tDQSCK(MAX) + ((BL/2) × tCK) + 1tCK When read post-amble = 1.5nCK (MR1 OP[7] = [1]), (RL × tCK) + tDQSCK(MAX) + ((BL/2) × tCK) + 2tCK 133 200b: x32 Mobile LPDDR4XSDRAM Power-Down Mode Figure 82: Mode Register Write to Power-Down Entry T0 T1 T2 T3 T4 Ta1 Ta0 Ta2 Ta3 Ta4 Tb0 Tb1 Tb2 Tb3 Tb4 Tb5 Tb6 Tb7 CK_c CK_t CKE t MRWCKEL CS CA Valid Valid Valid Valid Command MR Write-1 MR Write-2 DES DES DES Don’t Care Notes: 1. CKE must be held HIGH until tMRWCKEL is satisfied. 2. This timing is the general definition for power down entry after MODE REGISTER WRITE command. When a MODE REGISTER WRITE command changes a parameter or starts an operation that requires special timing longer than tMRWCKEL, that timing must be satisfied before CKE is driven LOW. Changing the VREF(DQ) value is one example, in this case the appropriate tVREF-SHORT/MIDDLE/LONG must be satisfied. 134 200b: x32 Mobile LPDDR4XSDRAM Power-Down Mode Figure 83: Multi Purpose Command for Start ZQ Calibration to Power-Down Entry T0 T2 T1 Ta0 Ta1 Ta2 Tb0 Tb1 Tb2 Tb3 Tb4 Tb5 Tb6 Tb7 Tb8 Tb9 Tb10 Tb11 CK_c CK_t CKE t ZQCKE CS CA Valid Valid MPC Command Start ZQ Cal DES DES ZQ calibration progresses ZQ Cal Status t ZQCAL Don’t Care Note: 1. ZQ calibration continues if CKE goes LOW after tZQCKE is satisfied. 135 200b: x32 Mobile LPDDR4XSDRAM Input Clock Stop and Frequency Change Input Clock Stop and Frequency Change Clock Frequency Change – CKE LOW During CKE LOW, the device supports input clock frequency changes under the following conditions: • • • • tCK(abs) (MIN) is met for each clock cycle Refresh requirements apply during clock frequency change During clock frequency change, only REFab or REFpb commands may be executing Any ACTIVATE or PRECHARGE commands have completed prior to changing the frequency • Related timing conditions, tRCD and tRP, have been met prior to changing the frequency • The initial clock frequency must be maintained for a minimum of four clock cycles after CKE goes LOW • The clock satisfies tCH(abs) and tCL(abs) for a minimum of two clock cycles prior to CKE going HIGH After the input clock frequency changes and CKE is held HIGH, additional MRW commands may be required to set the WR, RL, and so forth. These settings may require adjustment to meet minimum timing requirements at the target clock frequency. Clock Stop – CKE LOW During CKE LOW, the device supports clock stop under the following conditions: • • • • CK_t is held LOW and CK_c is held HIGH, or both are floated during clock stop Refresh requirements apply during clock stop During clock stop, only REFab or REFpb commands may be executing Any ACTIVATE or PRECHARGE commands have completed prior to stopping the clock • Related timing conditions, tRCD and tRP, have been met prior to stopping the clock • The initial clock frequency must be maintained for a minimum of four clock cycles after CKE goes LOW • The clock satisfies tCH(abs) and tCL(abs) for a minimum of two clock cycles prior to CKE going HIGH Clock Frequency Change – CKE HIGH During CKE HIGH, the device supports input clock frequency change under the following conditions: • • • • tCK(abs) (MIN) is met for each clock cycle Refresh requirements apply during clock frequency change During clock frequency change, only REFab or REFpb commands may be executing Any ACTIVATE, READ, WRITE, PRECHARGE, MODE REGISTER WRITE, or MODE REGISTER READ commands (and any associated data bursts) have completed prior to changing the frequency • Related timing conditions (tRCD, tWR,tWRA, tRP, tMRW, and tMRR) have been met prior to changing the frequency 136 200b: x32 Mobile LPDDR4XSDRAM Input Clock Stop and Frequency Change • During clock frequency change, CS is held LOW • The device is ready for normal operation after the clock satisfies t CH(abs) and tCL(abs) for a minimum of 2 × tCK + tXP After the input clock frequency is changed, additional MRW commands may be required to set the WR, RL, and so forth. These settings may need to be adjusted to meet minimum timing requirements at the target clock frequency. Clock Stop – CKE HIGH During CKE HIGH, the device supports clock stop under the following conditions: • • • • • CK_t is held LOW and CK_c is held HIGH during clock stop During clock stop, CS is held LOW Refresh requirements apply during clock stop During clock stop, only REFab or REFpb commands may be executing Any ACTIVATE, READ, WRITE, PRECHARGE, MODE REGISTER WRITE, or MODE REGISTER READ commands (and any associated data bursts) have completed prior to stopping the clock • Related timing conditions (tRCD, tWR,tWRA, tRP, tMRW, and tMRR) have been met prior to stopping the clock • The device is ready for normal operation after the clock satisfies t CH(abs) and tCL(abs) for a minimum of 2 × tCK + tXP 137 200b: x32 Mobile LPDDR4XSDRAM MODE REGISTER READ Operation MODE REGISTER READ Operation The MODE REGISTER READ (MRR) command is used to read configuration and status data from the device registers. The MRR command is initiated with CS and CA[5:0] in the proper state as defined by the Command Truth Table. The mode register address operands (MA[5:0]) enable the user to select one of 64 registers. The mode register contents are available on the first four UI data bits of DQ[7:0] after RL × tCK + tDQSCK + tDQSQ following the MRR command. Subsequent data bits contain valid but undefined content. DQS is toggled for the duration of the MODE REGISTER READ burst. The MRR has a command burst length of 16. MRR operation must not be interrupted. Table 100: MRR BL 0 1 2 3 4 5 6 7 8 9 10 DQ0 OP0 V DQ1 OP1 V DQ2 OP2 V DQ3 OP3 V DQ4 OP4 V DQ5 OP5 V DQ6 OP6 V DQ7 OP7 12 13 14 15 V DQ8DQ15 V DMI0– DMI1 V Notes: 11 1. MRR data are extended to the first 4 UIs, allowing the LPDRAM controller to sample data easily. 2. DBI may apply or may not apply during normal MRR. It’s vendor specific. If read DBI is enable with MRS and vendor cannot support the DBI during MRR, DMI pin status should be LOW. 3. The read preamble and postamble of MRR are the same as for a normal read. 138 200b: x32 Mobile LPDDR4XSDRAM MODE REGISTER READ Operation Figure 84: MODE REGISTER READ Operation T0 T1 T2 T3 MA CAn CAn T4 Ta0 Ta1 Ta2 Ta3 Ta4 Ta5 Tb0 Tb1 Tb2 Tb3 Tb4 Tb5 Tc0 Tc1 DES DES DES DES DES DES DES DES DES CK_c CK_t CS CA Valid Command MR Read-1 CAS-2 DES Valid Valid Valid Valid Any command Any command DES t MRR t RL DQSCK t BL/2 = 8 RPRE DQS_c DQS_t t t DQSQ RPST OP Code out DQ7:0 Va- Va- Va- Valid lid lid lid Va- Va- Va- Va- Va- Va- Va- Valid lid lid lid lid lid lid lid DQ15:8 DMI1:0 Don’t Care Notes: 1. Only BL = 16 is supported. 2. Only DESELECT is allowed during tMRR period. 3. There are some exceptions about issuing commands after tMRR. Refer to MRR/MRW Timing Constraints Table for detail. 4. DBI is disable mode. 5. DES commands except tMRR period are shown for ease of illustration; other commands may be valid at these times. 6. DQ/DQS: VSSQ termination MRR after Read and Write Command After a prior READ command, the MRR command must not be issued earlier than BL/2 clock cycles, in a similar way WL + BL/2 + 1 + RU ( tWTR/tCK) clock cycles after a PRIOR WRITE, WRITE with AP, MASK WRITE, MASK WRITE with AP, and MPC WRITE FIFO command in order to avoid the collision of READ and WRITE burst data on device internal data bus. 139 200b: x32 Mobile LPDDR4XSDRAM MODE REGISTER READ Operation Figure 85: READ to MRR Timing T0 T1 T2 T3 BL BA0, CA, AP CAn CAn T4 T15 T16 T17 T18 T19 Valid MA CAn CAn T20 T21 T33 T34 T35 T36 T37 T43 T44 DES DES DES DES DES DES DES DES DES CK_c CK_t CS CA Command Read-1 CAS-2 DES DES MRR-1 CAS-2 RL/2 = 14 BL/2 RL = 14 t DQSCK t t DQSCK BL/2 = 8 BL/2 = 16 RPRE t RPST DQS_c DQS_t t DQSQ t DQSQ Va- Valid lid DQ7:0 Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout n0 n1 n2 n3 n26 n27 n28 n29 n30 n31 DQ15:8 DMI1:0 Dout Dout Dout Dout Dout Dout Dout Dout Dout Dout Va- Va- Va- Va- Va- Van0 n1 n2 n3 n26 n27 n28 n29 n30 n31 lid lid lid lid lid lid OP Code out Don’t Care Notes: 1. The minimum number of clock cycles from the burst READ command to the MRR command is BL/2. 2. Read BL = 32, MRR BL = 16, RL = 14, Preamble = Toggle, Postamble = 0.5nCK, DBI = Disable, DQ/DQS: VSSQ termination. 3. DES commands except tMRR period are shown for ease of illustration; other commands may be valid at these times. 140 200b: x32 Mobile LPDDR4XSDRAM MODE REGISTER READ Operation Figure 86: Write to MRR Timing T0 T1 T2 T3 BL BA0, CA, AP CAn CAn T4 Ta0 Ta1 Ta2 Ta3 Ta4 Tb0 Tb1 Tb2 Tc1 Tc2 Tc3 Tc4 Valid MA CAn CAn Tc0 Tc5 CK_c CK_t CS CA Command WRITE-1 CAS-2 DES DES DES DES DES DES DES DES DES t WPRE t DQS_c MRR-1 t BL/2 + 1 clock WL DES WTR CAS-2 DES t MMR WPST DQS_t t DQS2DQ DQ DMI Dout Dout Dout Dout Dout Dout n0 n1 n12 n13 n14 n15 Don’t Care Notes: 1. 2. 3. 4. Write BL=16, Write postamble = 0.5nCK, DQ/DQS: VSSQ termination. Only DES is allowed during tMRR period. Din n = data-in to column.n. The minimum number of clock cycles from the BURST WRITE command to MRR command is WL + BL/2 + 1 + RU(tWTR/tCK). 5. tWTR starts at the rising edge of CK after the last latching edge of DQS. 6. DES commands except tMRR period are shown for ease of illustration; other commands may be valid at these times. MRR after Power-Down Exit Following the power-down state, an additional time, tMRRI, is required prior to issuing the MODE REGISTER READ (MRR) command. This additional time (equivalent to tRCD) is required in order to be able to maximize power-down current savings by allowing more power-up time for the MRR data path after exit from power-down mode. 141 200b: x32 Mobile LPDDR4XSDRAM MODE REGISTER WRITE Figure 87: MRR Following Power-Down T0 Ta0 Tb0 Tb1 Tb2 Tc0 Tc1 Tc2 Tc3 Tc4 Tc5 Td0 Td1 Td2 Td3 Td4 Td6 Td5 Td7 Td9 Td8 CK_c CK_t t CKCKEH CKE t MMR t MRRI t XP CS CA Valid Command DES Valid Any command DES Valid Valid Valid Any command DES DES DES MA CAn CAS-2 MRR-1 DES CAn DES DES DES DON'T CARE 1. Only DES is allowed during tMRR period. 2. DES commands except tMRR period are shown for ease of illustration; other commands may be valid at these times. Notes: MODE REGISTER WRITE The MODE REGISTER WRITE (MRW) writes configuration data to the mode registers. The MRW command is initiated with CKE, CS, and CA[5:0] to valid levels at the rising edge of the clock. The mode register address and the data written to it is contained in CA[5:0] according to the Command Truth Table. The MRW command period is defined by tMRW. Mode register WRITEs to read-only registers have no impact on the functionality of the device. Figure 88: MODE REGISTER WRITE Timing T0 T1 T2 T3 OPn MA OPn OPn T4 Ta0 Ta1 Ta2 Ta3 Ta4 OPn MA OPn OPn Ta5 Tb0 Tb1 Tb2 Tb3 Tb4 Valid Valid Valid Valid Tb5 Tb6 DES DES Tb7 CK_c CK_t CS CA tMRW Command MRW-1 MRW-2 DES DES MRW-1 tMRD MRW-2 DES DES Any command Any command DES Don’t Care Mode Register Write States MRW can be issued from either a bank-idle or a bank-active state. Certain restrictions may apply for MRW from an active state. 142 200b: x32 Mobile LPDDR4XSDRAM MODE REGISTER WRITE Table 101: Truth Table for MRR and MRW Current State All banks idle Bank(s) active Command Intermediate State Next State MRR Reading mode register, all banks idle All banks idle MRW Writing mode register, all banks idle All banks idle MRR Reading mode register Bank(s) active MRW Writing mode register Bank(s) active Table 102: MRR/MRW Timing Constraints: DQ ODT is Disable Minimum Delay Between "From Command" and "To Command" Unit MRR tMRR – RD/RDA tMRR – From Command To Command MRR WR/WRA/MWR/MWRA RD/RDA RL + RU(tDQSCK(max)/tCK) nCK MRR BL/2 nCK WL + 1 + BL/2 + tXP POWER-DOWN EXIT RD with AUTO PRECHARGE WR/ MWR/ WR FIFO WR/MWR with AUTO PRECHARGE RU(tWTR/tCK) tMRD MRW RD/ RD FIFO/ RD DQ CAL nCK RL + RU(tDQSCK(max)/tCK) + BL/2 + 3 WR/WRA/MWR/ MWRA MRW + BL/2 + 3 -WL MRW + tMRRI nCK – – RD/RDA tMRD – WR/WRA/MWR/MWRA tMRD – MRW tMRW – MRW RL + BL/2 + RU(tDQSCK(max)/tCK) + RD(tRPST) + MAX(RU(7.5ns/tCK),8nCK) nCK RL + BL/2 + RU(tDQSCK(max)/tCK) + RD(tRPST) + max(RU(7.5ns/tCK),8nCK) + nRTP - 8 nCK WL + 1 + BL/2 + MAX(RU(7.5ns/tCK),8nCK) nCK WL + 1 + BL/2 + MAX(RU(7.5ns/tCK),8nCK) + nWR nCK 143 Notes 200b: x32 Mobile LPDDR4XSDRAM VREF Current Generator (VRCG) Table 103: MRR/MRW Timing Constraints: DQ ODT is Enable Minimum Delay Between "From Command" and "To Command" Unit MRR tMRR – RD/RDA tMRR – From Command To Command MRR WR/WRA/MWR/MWRA RD/RDA RL + RU(tDQSCK(max)/tCK) + BL/2 + 3 - ODTLon RD(tODTon(min)/tCK) RL + RU(tDQSCK(max)/tCK) + BL/2 + 3 nCK MRR BL/2 nCK WL + 1 + BL/2 + RU(tWTR/tCK) nCK tMRD – MRW tXP POWER-DOWN EXIT MRW RD/ RD FIFO/ RD DQ CAL nCK MRW WR/WRA/MWR/ MWRA + tMRRI – RD/RDA tMRD – WR/WRA/MWR/MWRA tMRD – MRW tMRW RU(tDQSCK(max)/tCK) MRW – RD(tRPST) RL + BL/2 + + MAX(RU(7.5ns/tCK),8nCK) RD with AUTO PRECHARGE WR/ MWR/ WR FIFO WR/MWR with AUTO PRECHARGE Notes + nCK RL + BL/2 + RU(tDQSCK(max)/tCK) + RD(tRPST) + max(RU(7.5ns/tCK),8nCK) + nRTP - 8 nCK WL + 1 + BL/2 + MAX(RU(7.5ns/tCK),8nCK) nCK WL + 1 + BL/2 + MAX(RU(7.5ns/tCK),8nCK) + nWR nCK VREF Current Generator (VRCG) LPDDR4 SDRAM V REF current generators (VRCG) incorporate a high current mode to reduce the settling time of the internal V REF(DQ) and V REF(CA) levels during training and when changing frequency set points during operation. The high current mode is enabled by setting MR13[OP3] = 1. Only deselect commands may be issued until tVRCG_ENABLE is satisfied. tVRCG_ENABLE timing is shown below. 144 200b: x32 Mobile LPDDR4X SDRAM VREF Current Generator (VRCG) Figure 89: VRCG Enable Timing T0 T1 T2 T3 T4 T5 Ta0 Ta1 Ta2 Ta3 Ta4 Ta5 Tb0 Tb1 Tb2 Tb3 Tb4 Tb5 Tb6 DES DES Valid Valid Valid Valid DES DES Valid Valid Valid Valid DES DES DES DES DES DES DES DES CK_c CK_t CKE CS CA DES MRW1 MRW1 MRW2 MRW2 Command DES VRCG enable: MR13 [OP3] = 1 t Valid Valid VRCG_ENABLE VRCG high current mode is disabled by setting MR13[OP3] = 0. Only deselect commands may be issued until tVRCG_DISABLE is satisfied. tVRCG_DISABLE timing is shown below. Figure 90: VRCG Disable Timing T0 T1 T2 T3 T4 T5 Ta0 CA DES Valid Valid Valid Valid DES DES MRW1 MRW1 MRW2 MRW2 Command DES DES DES VRCG disable: MR13 [OP3] = 0 Ta1 Ta2 Ta3 Ta4 Ta5 Tb0 Tb1 Tb2 Tb3 Tb4 Tb5 Tb6 DES DES Valid Valid Valid Valid DES DES DES DES DES DES CK_c CK_t CKE CS Valid t Valid VRCG_DISABLE Note that LPDDR4 SDRAM devices support V FER(CA) and V REF(DQ) range and value changes without enabling VRCG high current mode. Table 104: VRCG Enable/Disable Timing Parameter Symbol Min Max VREF high current mode enable time tVRCG_ENABLE – 200 ns VREF high current mode disable time tVRCG_DISABLE – 100 ns 145 Unit 200b: x32 Mobile LPDDR4XSDRAM VREF Training VREF Training VREF(CA) Training The device's internal V REF(CA) specification parameters are operating voltage range, step size, V REF step time, V REF full-range step time, and V REF valid level. The voltage operating range specifies the minimum required V REF setting range for LPDDR4 devices. The minimum range is defined by V REF,max and V REF,min. Figure 91: VREF Operating Range (VREF,max, VREF,min) VDD2 VIN(DC)max VREF,max VREF range VREF,min VIN(DC)min VSWING large System variance VSWING small Total range The V REF step size is defined as the step size between adjacent steps. However, for a given design, the device has one value for V REF step size that falls within the given range. The V REF set tolerance is the variation in the V REF voltage from the ideal setting. This accounts for accumulated error over multiple steps. There are two ranges for V REF set tolerance uncertainty. The range of V REF set tolerance uncertainty is a function of the number of steps n. The V REF set tolerance is measured with respect to the ideal line that is based on the two endpoints, where the endpoints are at the minimum and maximum V REF values for a specified range. 146 200b: x32 Mobile LPDDR4XSDRAM VREF Training Figure 92: VREF Set-Point Tolerance and Step Size VREF level Actual VREF output VREF set-point tolerance Straight line endpoint fit VREF step size VREF step setting The V REF increment/decrement step times are defined by tVREF_TIME-SHORT, t REF_TIME-MIDDLE, and VREF_TIME-LONG. The parameters are defined from TS to TE as shown below, where TE is referenced to when the V REF voltage is at the final DC level within the V REF valid tolerance (VREF,val_tol). tV The V REF valid level is defined by V REF,val_tol to qualify the step time TE (see the following figures). This parameter is used to ensure an adequate RC time constant behavior of the voltage level change after any V REF increment/decrement adjustment. This parameter is only applicable for LPDDR4 component level validation/characterization. tV REF_TIME-SHORT is for a single step size increment/decrement change in the V REF voltage. tV REF_TIME-MIDDLE is at least two stepsizes increment/decrement change within the same V REF(CA) range in V REF voltage. tV REF_TIME-LONG is the time including up to V REF,min to V REF,max or V REF,max to V REF,min change across the V REF(CA) range in V REF voltage. TS is referenced to MRW command clock. TE is referenced to V REF_val_tol. 147 200b: x32Mobile LPDDR4X SDRAM VREF Training Figure 93: tVref for Short, Middle and Long Timing Diagram T0 T1 T2 T3 T4 T5 Ta0 Ta1 Ta2 Ta3 Ta4 Ta5 Ta6 Ta7 Ta8 Ta9 Ta10 Ta11 Ta12 CK_c CK_t CKE CS CA DES MRW-1 MRW-1 MRW-2 MRW-2 DES DES DES DES DES DES DES DES DES DES DES DES DES DES Command DES VRFF(CA) value/range set DES DES DES DES DES DES DES DES DES DES DES DES DES DES VREF_time – short/middle/long New VREF setting Updating VRFF(CA) setting Old VREF setting TS VREF setting adjustment TE The MRW command to the mode register bits are as follows; MR12 OP[5:0] : V REF(CA) Setting MR12 OP[6] : V REF(CA) Range The minimum time required between two V REF MRW commands is tVREF_TIME-SHORT for a single step and tVREF_TIME-MIDDLE for a full voltage range step. Figure 94: VREF(CA) Single-Step Increment VREF voltage VREF(DC) (VDD2(DC) ) VREF_val_tol step size t1 Time 148 200b: x32 Mobile LPDDR4XSDRAM VREF Training Figure 95: VREF(CA) Single-Step Decrement VREF voltage t1 stepsize VREF_val_tol VREF(DC) (VDD2(DC) ) Time Figure 96: VREF(CA) Full Step from VREF,min to VREF,max VREF voltage VREF(DC) (VDD2(DC) ) VREF,max VREF_val_tol Full range step t1 VREF,min Time Figure 97: VREF(CA) Full Step from VREF,max to VREF,min VREF VREF,max voltage Full range step t1 VREF_val_tol VREF(DC) (VDD2(DC) ) VREF,min Time The following table contains the CA internal V REF specification that will be characterized at the component level for compliance. 149 200b: x32 Mobile LPDDR4XSDRAM VREF Training Table 105: Internal VREF(CA) Specifications Min Typ Max Unit Notes VREF(CA),max_r0 Symbol VREF(CA) range-0 MAX operating point – – 44.9% VDDQ 1, 11 VREF(CA),min_r0 VREF(CA) range-0 MIN operating point 15.0% – – VDDQ 1, 11 VREF(CA),max_r1 VREF(CA) range-1 MAX operating point – – 62.9% VDDQ 1, 11 VREF(CA),min_r1 VREF(CA) range-1 MIN operating point 32.9% – – VDDQ 1, 11 VREF(CA) step size 0.50% 0.60% 0.70% VDDQ 2 –11 0 11 mV 3, 4, 6 –1.1 0 1.1 mV 3, 5, 7 – – 100 ns 8 – – 200 ns 12 REF_TIME-LONG – – 250 ns 9 tV – – 1 ms 13, 14 –0.10% 0.00% 0.10% VDDQ 10 VREF(CA),step VREF(CA),set_tol tV REF_TIME-SHORT Parameter VREF(CA) set tolerance VREF(CA) step time tV REF_TIME-MIDDLE tV REF_time_weak VREF(CA)_val_tol VREF(CA) valid tolerance Notes: 1. VREF(CA) DC voltage referenced to VDDQ(DC). 2. VREF(CA) step size increment/decrement range. VREF(CA) at DC level. 3. VREF(CA),new = VREF(CA),old + n × VREF(CA),step; n = number of steps; if increment, use "+"; if decrement, use "–". 4. The minimum value of VREF(CA) setting tolerance = VREF(CA),new - 11mV. The maximum value of VREF(CA) setting tolerance = VREF(CA),new + 11mV. For n > 4. 5. The minimum value of VREF(CA) setting tolerance = VREF(CA),new - 1.1mV. The maximum value of VREF(CA) setting tolerance = VREF(CA),new + 1.1mV. For n ≤ 4. 6. Measured by recording the minimum and maximum values of the VREF(CA) output over the range, drawing a straight line between those points and comparing all other VREF(CA) output settings to that line. 7. Measured by recording the minimum and maximum values of the VREF(CA) output across four consecutive steps (n = 4), drawing a straight line between those points and comparing all other VREF(CA) output settings to that line. 8. Time from MRW command to increment or decrement one step size for VREF(CA) . 9. Time from MRW command to increment or decrement VREF,min to VREF,max or VREF,max to VREF,min change across the VREF(CA) range in VREF voltage. 10. Only applicable for DRAM component level test/characterization purposes. Not applicable for normal mode of operation. VREF valid is to qualify the step times which will be characterized at the component level. 11. DRAM range-0 or range-1 set by MR12 OP[6]. 12. Time from MRW command to increment or decrement more than one step size up to a full range of VREF voltage within the same VREF(CA) range. 13. Applies when VRCG high current mode is not enabled, specified by MR13 [OP3] = 0b. 14. tVREF_time_weak covers all VREF(CA) range and value change conditions are applied to tV REF_TIME-SHORT/MIDDLE/LONG. 150 200b: x32 Mobile LPDDR4XSDRAM VREF Training VREF(DQ) Training The device's internal V REF(DQ) specification parameters are operating voltage range, step size, V REF step tolerance, V REF step time and V REF valid level. The voltage operating range specifies the minimum required V REF setting range for LPDDR4 devices. The minimum range is defined by V REF,max and V REF,min. Figure 98: VREF Operating Range (VREF,max, VREF,min) VDDQ VIN(DC)max VREF,max VREF range VREF,min VIN(DC)min VSWING large System variance VSWING small Total range The V REF step size is defined as the step size between adjacent steps. However, for a given design, the device has one value for V REF step size that falls within the given range. The V REF set tolerance is the variation in the V REF voltage from the ideal setting. This accounts for accumulated error over multiple steps. There are two ranges for V REF set tolerance uncertainty. The range of V REF set tolerance uncertainty is a function of the number of steps n. The V REF set tolerance is measured with respect to the ideal line that is based on the two endpoints, where the endpoints are at the minimum and maximum V REF values for a specified range. 151 200b: x32 Mobile LPDDR4XSDRAM VREF Training Figure 99: VREF Set Tolerance and Step Size VREF level Actual VREF output VREF set-point tolerance Straight line endpoint fit VREF step size VREF step setting The V REF increment/decrement step times are defined by tVREF_TIME-SHORT, t t t REF_TIME-MIDDLE and VREF_TIME-LONG. The VREF_TIME-SHORT, VREF_TIMEt MIDDLE and VREF_TIME-LONG times are defined from TS to TE in the following figure where TE is referenced to when the V REF voltage is at the final DC level within the V REF valid tolerance (VREF,VAL_TOL). tV The V REF valid level is defined by V REF,VAL_TOL to qualify the step time TE (see the figure below). This parameter is used to ensure an adequate RC time constant behavior of the voltage level change after any V REF increment/decrement adjustment. This parameter is only applicable for DRAM component level validation/characterization. tV REF_TIME-SHORT is for a single step size increment/decrement change in the V REF voltage. tV REF_TIME-MIDDLE is at least two step sizes of increment/decrement change in the VREF(DQ) range in the V REFvoltage. tV REF_TIME-LONG is the time including and up to the full range of V REF (MIN to MAX or MAX to MIN) across the V REF(DQ) range in V REF voltage. 152 200b: x32 Mobile LPDDR4XSDRAM VREF Training Figure 100: VREF(DQ) Transition Time for Short, Middle, or Long Changes T0 T1 T2 T3 T4 T5 Ta Ta+1 Ta+2 Ta+3 Ta+4 Ta+5 Ta+6 Ta+7 Ta+8 Ta+9 T+10 T+11 T+12 CK_c CK_t CKE CS CA[5:0] DES MRW-1 MRW-1 MRW-2 MRW-2 DES DES DES DES DES DES DES DES DES DES DES DES DES DES Command DES VREF(DQ) value/range set DES DES DES DES DES DES DES DES DES DES DES DES DES DES VREF_time – short/middle/long VREF Old VREF setting Updating VREF(DQ) setting New VREF setting TS VREF setting adjustment Notes: TE 1. TS is referenced to MRW command clock. 2. TE is referenced to VREF,VAL_TOL. The MRW command to the mode register bits are defined as: MR14 OP[5:0]: V REF(DQ) setting MR14 OP[6]: V REF(DQ) range The minimum time required between two V REF MRW commands is tVREF_TIME-SHORT for a single step and tVREF_TIME-MIDDLE for a full voltage range step. Figure 101: VREF(DQ) Single-Step Size Increment VREF voltage VREF(DC) (VDDQ(DC)) VREF_val_tol step size t1 Time 153 200b: x32 Mobile LPDDR4XSDRAM VREF Training Figure 102: VREF(DQ) Single-Step Size Decrement VREF voltage t1 stepsize VREF_val_tol VREF(DC) (VDDQ(DC)) Time Figure 103: VREF(DQ) Full Step from VREF,min to VREF,max VREF voltage VREF(DC) (VDDQ(DC)) VREF,max VREF_val_tol Full range step t1 VREF,min Time Figure 104: VREF(DQ) Full Step from VREF,max to VREF,min VREF VREF,max voltage Full range step t1 VREF_val_tol VREF(DC) (VDDQ(DC)) VREF,min Time The following table contains the DQ internal V REF specification that will be characterized at the component level for compliance. 154 200b: x32 Mobile LPDDR4XSDRAM VREF Training Table 106: Internal VREF(DQ) Specifications Parameter Min Typ Max Unit Notes VREF(DQ),max_r0 Symbol VREF MAX operating point Range-0 30% – – VDDQ 1, 11 VREF(DQ),min_r0 VREF MIN operating point Range-0 – – 10% VDDQ 1, 11 VREF(DQ),max_r1 VREF MAX operating point Range-1 42% – – VDDQ 1, 11 VREF(DQ),min_r1 VREF MIN operating point Range-1 – – 22% VDDQ 1, 11 VREF(DQ) step size 0.30% 0.40% 0.50% VDDQ 2 VREF(DQ) set tolerance –1.00% 0.00% 1.00% VDDQ 3, 4, 6 –0.10% 0.00% 0.10% VDDQ 3, 5, 7 – – 100 ns 8 - - 200 ns 12 REF_TIME-LONG – – 250 ns 9 tV – – 1 ms 13, 14 –0.10% 0.00% 0.10% VDDQ 10 VREF(DQ),step VREF(DQ),set_tol tV REF_TIME-SHORT VREF(DQ) step time tV REF_TIME-MIDDLE tV REF_time_weak VREF(DQ),val_tol VREF(DQ) valid tolerance Notes: 1. VREF(DQ) DC voltage referenced to VDDQ(DC). 2. VREF(DQ) step size increment/decrement range. VREF(DQ) at DC level. 3. VREF(DQ),new = VREF(DQ),old + n × VREF(DQ),step; n = number of steps; if increment, use "+"; if decrement, use "-". 4. The minimum value of VREF(DQ)setting tolerance = VREF(DQ),new - 1.0% × VDDQ. The maximum value of VREF(DQ) setting tolerance = VREF(DQ),new + 1.0% × VDDQ. For n > 4. 5. The minimum value of VREF(DQ)setting tolerance = VREF(DQ),new - 0.10% × VDDQ. The maximum value of VREF(DQ) setting tolerance = VREF(DQ),new + 0.10% × VDDQ. For n < 4. 6. Measured by recording the minimum and maximum values of the VREF(DQ) output over the range, drawing a straight line between those points and comparing all other VREF(DQ) output settings to that line. 7. Measured by recording the minimum and maximum values of the VREF(DQ) output across four consecutive steps (n = 4), drawing a straight line between those points and comparing all other VREF(DQ) output settings to that line. 8. Time from MRW command to increment or decrement one step size for VREF(DQ) . 9. Time from MRW command to increment or decrement VREF,min to VREF,max or VREF,max to VREF,min change across the VREF(DQ) Range in VREF(DQ) Voltage. 10. Only applicable for DRAM component level test/characterization purposes. Not applicable for normal mode of operation. VREF valid is to qualify the step times which will be characterized at the component level. 11. DRAM range-0 or range-1 set by MR14 OP[6]. 12. Time from MRW command to increment or decrement more than one step size up to a full range of VREF voltage within the same VREF(DQ) range. 13. Applies when VRCG high current mode is not enabled, specified by MR13 [OP3] = 0. 14. tVREF_time_weak covers all VREF(DQ) Range and Value change conditions are applied to tV REF_TIME-SHOR/MIDDLE/LONG. 155 200b: x32 Mobile LPDDR4XSDRAM Command Bus Training Command Bus Training Command Bus Training Mode The command bus must be trained before enabling termination for high-frequency operation. The device provides an internal V REF(CA) that defaults to a level suitable for unterminated, low-frequency operation, but the V REF(CA) must be trained to achieve suitable receiver voltage margin for terminated, high-frequency operation. The training mode described here centers the internal V REF(CA) in the CA data eye and at the same time allows for timing adjustments of the CS and CA signals to meet setup/ hold requirements. Because it can be difficult to capture commands prior to training the CA inputs, the training mode described here uses a minimum of external commands to enter, train, and exit the CA bus training mode. The die has a bond-pad (ODT_CA) to control the command bus termination for multirank operation. Other mode register bits are provided to fine tune termination control in a variety of system configuration. See On-Die Termination for more information. The device uses frequency set points to enable multiple operating settings for the die. The device defaults to FSP-OP[0] at power-up, which has the default settings to operate in un-terminated, low-frequency environments. Prior to training, the termination should be enabled for one die in each channel by setting MR13 OP[6] = 1b (FSP-WR[1]) and setting all other mode register bits for FSP-OP[1] to the desired settings for highfrequency operation. Upon training entry, the device will automatically switch to FSPOP[1] and use the high-frequency settings during training (See the Command Bus Training Entry Timing figure for more information on FSP-OP register sets). Upon training exit, the device will automatically switch back to FSP-OP[0], returning to a "knowngood" state for unterminated, low-frequency operation. To enter command bus training mode, issue a MRW-1 command followed by a MRW-2 command to set MR13 OP[0] = 1b (command bus training mode enabled). After time tMRD, CKE may be set LOW, causing the device to switch to FSP-OP[1], and completing the entry into command bus training mode. A status DQS_t, DQS_c, DQ, and DMI are as noted below; the DQ ODT state will be followed by frequency set point function except in the case of output pins. • • • • • DQS_t[0], DQS_c[0] become input pins for capturing DQ[6:0] levels by toggling. DQ[5:0] become input pins for setting V REF(CA) level. DQ[6] becomes an input pin for setting V REF(CA) range. DQ[7] and DMI[0] become input pins, and their input level is valid or floating. DQ[13:8] become output pins to feedback, capturing value via the command bus using the CS signal. • DQS_t[1], DQS_c[1], DMI[1], and DQ[15:14] become output pins or are disabled, meaning the device may be driven to a valid level or may be left floating. At time tCAENT later, the device may change its V REF(CA) range and value using input signals DQS_t[0], DQS_c[0], and DQ[6:0] from existing value that is set via MR12 OP[6:0]. The mapping between MR12 OP code and DQs is shown below. At least one VREF(CA) setting is required before proceeding to the next training step. 156 200b: x32 Mobile LPDDR4XSDRAM Command Bus Training Table 107: Mapping MR12 Op Code and DQ Numbers Mapping MR12 OP Code OP6 OP5 OP4 OP3 OP2 OP1 OP0 DQ Number DQ6 DQ5 DQ4 DQ3 DQ2 DQ1 DQ0 The new V REF(CA) value must "settle" for time tVREF_LONG before attempting to latch CA information. Note: If DQ ODT is enabled in MR11-OP[2:0], then the SDRAM will terminate the DQ lanes during command bus training when entering V REF(CA) range and values on DQ[6:0]. To verify that the receiver has the correct V REF(CA) setting, and to further train the CA eye relative to clock (CK), values latched at the receiver on the CA bus are asynchronously output to the DQ bus. To exit command bus training mode, drive CKE HIGH, and after time tVREF_LONG, issue the MRW-1 command followed by the MRW-2 command to set MR13 OP[0] = 0b. After time tMRW, the device is ready for normal operation. After training exit, the device will automatically switch back to the FSP-OP registers that were in use prior to training. Command bus training (CBT) may be executed from the idle or self refresh state. When executing CBT within the self refresh state, the device must not be in a power-down state (i.e., CKE must be HIGH prior to training entry). CBT entry and exit is the same, regardless of the state from which CBT is initiated. Training Sequence for Single-Rank Systems The sequence example shown here assumes an initial low-frequency, non-terminating operating point training a high-frequency, terminating operating point. The bold text shows high-frequency instructions. Any operating point may be trained from any known good operating point. 1. Set MR13 OP[6] = 1b to enable writing to frequency set point 1 (FSP-WR[1]) (or FSP-OP[0]). 2. Write FSP-WR[1] (or FSP-WR[0]) registers for all channels to set up high-frequency operating parameters. 3. Issue MRW-1 and MRW-2 commands to enter command bus training mode. 4. Drive CKE LOW, and change CK frequency to the high-frequency operating point. 5. Perform command bus training (VREF(CA), CS, and CA). 6. Exit training by driving CKE HIGH, change CK frequency to the low-frequency operating point, and issue MRW-1 and MRW-2 commands. When CKE is driven HIGH, the device will automatically switch back to the FSP-OP registers that were in use prior to training (trained values are not retained). 7. Write the trained values to FSP-WR[1] (or FSP-WR[0]) by issuing MRW-1 and MRW-2 commands to the SDRAM and setting all applicable mode register parameters. 8. Issue MRW-1 and MRW-2 commands to switch the terminating rank to FSP-OP[1] (or FSP-OP[0]), to turn on termination, and change CK frequency to the high-frequency operating point. At this point the command bus is trained and you may proceed to other training or normal operation. 157 200b: x32 Mobile LPDDR4XSDRAM Command Bus Training Training Sequence for Multiple-Rank Systems The sequence example shown here is assuming an initial low-frequency operating point, training a high-frequency operating point. The bold text shows high-frequency instructions. Any operating point may be trained from any known good operating point. 1. Set MR13 OP[6] = 1b to enable writing to frequency set point 1 (FSP-WR[1]) (or FSP-WR[0]). 2. Write FSP-WR[1] (or FSP-WR[0]) registers for all channels and ranks to set up high-frequency operating parameters. 3. Read MR0 OP[7] on all channels and ranks to determine which die are terminating, signified by MR0 OP[7] = 1b. 4. Issue MRW-1 and MRW-2 commands to enter command bus training mode on the terminating rank. 5. Drive CKE LOW on the terminating rank (or all ranks), and change CK frequency to the high-frequency operating point. 6. Perform command bus training on the terminating rank (VREF(CA), CS, and CA). 7. Exit training by driving CKE HIGH, change CK frequency to the low-frequency operating point, and issue MRW-1 and MRW-2 commands to write the trained values to FSP-WR[1] (or FSP-WR[0]). When CKE is driven HIGH, the SDRAM will automatically switch back to the FSP-OP registers that were in use prior to training (trained values are not retained by the device). 8. Issue MRW-1 and MRW-2 commands to enter training mode on the non-terminating rank (but keep CKE HIGH). 9. Issue MRW-1 and MRW-2 commands to switch the terminating rank to FSP-OP[1] (or FSP-OP[0]), to turn on termination, and change CK frequency to the high-frequency operating point. 10. Drive CKE LOW on the non-terminating (or all) ranks. The non-terminating rank(s) will now be using FSP-OP[1] (or FSP-OP[0]). 11. Perform command bus training on the non-terminating rank (VREF(CA), CS, and CA). 12. Issue MRW-1 and MRW-2 commands to switch the terminating rank to FSPOP[0] (or FSP-OP[1]) to turn off termination. 13. Exit training by driving CKE HIGH on the non-terminating rank, change CK frequency to the low-frequency operating point, and issue MRW-1 and MRW-2 commands. When CKE is driven HIGH, the device will automatically switch back to the FSP-OP registers that were in use prior to training (that is, trained values are not retained by the device). 14. Write the trained values to FSP-WR[1] (or FSP-WR[0]) by issuing MRW-1 and MRW-2 commands and setting all applicable mode register parameters. 15. Issue MRW-1 and MRW-2 commands to switch the terminating rank to FSP-OP[1] (or FSP-OP[0]), to turn on termination, and change CK frequency to the high-frequency operating point. At this point the command bus is trained for both ranks and the user may proceed to other training or normal operation. 158 200b: x32 Mobile LPDDR4XSDRAM Command Bus Training Relation between CA Input pin DQ Output pin Table 108: Mapping CA Input pin DQ Output pin Mapping CA Number CA5 CA4 CA3 CA2 CA1 CA0 DQ Number DQ13 DQ12 DQ11 DQ10 DQ9 DQ8 Figure 105: Command Bus Training Mode Entry – CA Training Pattern I/O With VREF(CA) Value Update T0 T1 T2 T3 T4 T5 Ta Tb Tb+1 Tc See Note 1 Te Td Te+1 Te+2 Tg Tf Th Th+1 Th+2 CK_c CK_t tCKPRECS See Note 7 tCKPSTCS See Note 2 CKE tMRD tCKELCK See Note 3 tCACD CS CA DES MRW1 MRW1 MRW2 MRW2 DES DES DES DES DES Valid Valid CA training Pattern B Command DES Enter command bus training mode DES DES DES DES CA training Pattern A DES tDQSCKE tVREFca_LONG tCAENT (see Note 5) tADR See Note 4 DQS0_t DQS0_c tDS,train tDH,train Valid DQ[6:0] DQ7 DMI0 DQ[13:8] Pattern A DQ[15:14] DMI1 DQS1_t DQS1_c VREF(CA) (reference) Setting value of MR X (Y) Updating setting from FSP switching tCKELODTon ODT_CA (reference) Mode register X (Y) Updating setting Temporary setting value (see Note 6) Switching MR Mode register X (Y) Don’t Care Notes: 1. After tCKELCK, the clock can be stopped or the frequency changed any time. 2. The input clock condition should be satisfied tCKPRECS and tCKPSTCS. 3. Continue to drive CK, and hold CA and CS LOW, until tCKELCK after CKE is LOW (which disables command decoding). 4. The device may or may not capture the first rising edge of DQS_t/DQS_c due to an unstable first rising edge. Therefore, at least two consecutive pulses of DQS signal input is required every for DQS input signal while capturing DQ[6:0] signals. The captured value of the DQ[6:0] signal level by each DQS edge may be overwritten at any time and the device will temporarily update the VREF(CA) setting of MR12 after time tVREFCA_LONG. 5. tVREF_LONG may be reduced to tVREF_SHORT if the following conditions are met: 1) The new VREF setting is a single step above or below the old VREF setting; 2) The DQS pulses a single time, or the new VREF setting value on DQ[6:0] is static and meets tDS,train/ tDH,train for every DQS pulse applied. 159 200b: x32 Mobile LPDDR4XSDRAM Command Bus Training 6. When CKE is driven LOW, the device will switch its FSP-OP registers to use the alternate (non-active) set. For example, if the device is currently using FSP-OP[0], then it will switch to FSP-OP[1] when CKE is driven LOW. All operating parameters should be written to the alternate mode registers before entering command bus training to ensure that ODT settings, RL/WL/nWR setting, and so forth, are set to the correct values. If the alternate FSP-OP has ODT_CA disabled, then termination will not be enabled in command bus training mode. If the ODT_CA pad is bonded to VSS or floating, ODT_CA termination will never enable for that die. 7. When CKE is driven LOW in command bus training mode, the device will change operation to the alternate FSP, that is, the inverse of the FSP programmed in the FSP-OP mode register. Figure 106: Consecutive VREF(CA) Value Update T0 Ta Tb Tb+1 Tc See Note 1 Td Te Te+1 Te+2 Te+3 Te+4 Te+5 Te+6 Te+7 Te+8 Te+9 Te+10 Tf Tf+1 Tf+2 Tf+3 CK_c CK_t tCKELCK (see Note 2) See Note 7 CKE tCKELCK (see Note 3) CS CA DES DES Command DES DES DES DES DES DES DES DES tDQSCKE Valid CA training Pattern A tVREFca_LONG tCAENT (see Note 5) tCS_VREF See Note 4 tVREFca_LONG (see Note 5) See Note 4 DQS0_t DQS0_c tDS,train tDH,train tDS,train Valid Valid DQ[6:0] tDH,train DQ7 DMI0 tADR DQ[13:8] Pattern A DQ[15:14] DMI1 DQS1_t DQS1_c VREF(CA) (reference) Updating setting from FSP switching Setting value of MR X (Y) tCKELODTon ODT_CA (reference) Mode register X (Y) Updating setting Temporary setting value Updating setting (see Note 6) Switching MR Mode register X (Y) Don’t Care Notes: 1. After tCKELCK, the clock can be stopped or the frequency changed any time. 2. The input clock condition should be satisfied tCKPRECS and tCKPSTCS. 3. Continue to drive CK, and hold CA and CS LOW, until tCKELCK after CKE is LOW (which disables command decoding). 4. The device may or may not capture the first rising edge of DQS_t/DQS_c due to an unstable first rising edge. Therefore, at least two consecutive pulses of DQS signal input is required every for DQS input signal while capturing DQ[6:0] signals. The captured value of the DQ[6:0] signal level by each DQS edge may be overwritten at any time and the device will temporarily update the VREF(CA) setting of MR12 after time tVREFCA_LONG. 5. tVREF_LONG may be reduced to tVREF_SHORT if the following conditions are met: 1) The new VREF setting is a single step above or below the old VREF setting; 2) The DQS 160 200b: x32 Mobile LPDDR4XSDRAM Command Bus Training pulses a single time, or the new VREF setting value on DQ[6:0] is static and meets tDS,train/ tDH,train for every DQS pulse applied. 6. When CKE is driven LOW, the device will switch its FSP-OP registers to use the alternate (non-active) set. For example, if the device is currently using FSP-OP[0], then it will switch to FSP-OP[1] when CKE is driven LOW. All operating parameters should be written to the alternate mode registers before entering command bus training to ensure that ODT settings, RL/WL/nWR setting, and so forth, are set to the correct values. If the alternate FSP-OP has ODT_CA disabled, then termination will not be enabled in command bus training mode. If the ODT_CA pad is bonded to VSS or floating, ODT_CA termination will never enable for that die. 7. When CKE is driven LOW in command bus training mode, the device will change operation to the alternate FSP, that is, the inverse of the FSP programmed in the FSP-OP mode register. Figure 107: Command Bus Training Mode Exit With Valid Command T0 T1 T2 Ta Ta+1 Ta+2 Tb Tc Td Td+1 Te Te+1 Tf Tf+1 Tf+2 Tf+3 Tf+4 Tg Tg+1 Tg+2 Tg+3 Tg+4 Tg+5 Valid Valid Valid DES CK_c CK_t tCPSTCS See Note 5 CKE tCACD tCCKCKEH tFC (see Note 1) tMRW CS See Note 2 CA Valid Command Valid Valid Valid tADR tADR DES DES DES DES DES DES DES DES DES DES DES DES MRW1 MRW1 MRW2 MRW2 Exiting command bus training mode DES DES Valid Valid DES tCKEHDQS DQS0_t DQS0_c DQ[6:0] DQ7 DMI0 tMRZ DQ[13:8] Pattern A Pattern B DQ[15:14] DMI1 DQS1_t DQS1_c VREF(CA) (reference) Pattern C See Note 4 Temporary setting value Switching MR tCKELODToff ODT_CA (reference) Mode register X (Y) Setting value of MR X (Y) (see Note 3) Switching MR Mode register X (Y) Don’t Care Notes: 1. The clock can be stopped or the frequency changed any time before t CKCKEH. CK must meet t CKCKEH before CKE is driven HIGH. When CKE is driven HIGH, the clock frequency must be returned to the original frequency (that is, the frequency corresponding to the FSP at command bus training mode entry. 2. CS and CA[5:0] must be deselected (LOW) t CKCKEH before CKE is driven HIGH. 3. When CKE is driven HIGH, ODT_CA will revert to the state/value defined by FSP-OP prior to command bus training mode entry, that is, the original frequency set point (FSP-OP, MR13-OP[7]). For example, if the device was using FSP-OP[1] for training, then it will switch to FSP-OP[0] when CKE is driven HIGH. 161 200b: x32 Mobile LPDDR4XSDRAM Command Bus Training 4. Training values are not retained by the device and must be written to the FSP-OP register set before returning to operation at the trained frequency. For example, VREF(CA) will return to the value programmed in the original set point. 5. When CKE is driven HIGH, the device will revert to the FSP in operation at command bus training mode entry. Figure 108: Command Bus Training Mode Exit With Power-Down Entry T0 T1 T2 Ta Ta+1 Ta+2 Tb Tc Td Td+1 Te Te+1 Tf Tf+1 Tf+2 Tf+3 Tf+4 Tg Tg+1 Tg+2 Tg+3 Th Tk CK_c CK_t tCPSTCS tCKELCK See Note 5 CKE tCACD tCCKCKEH tFC (see Note 1) tMRD tCKELCMD CS See Note 2 CA Valid Valid CA Pattern B CA Pattern C Command tADR tADR DES DES DES DES DES DES DES DES DES DES DES DES MRW1 MRW1 MRW2 MRW2 Exiting command bus training mode DES Valid Valid DES DES DES Power-down entry DES DES tCKEHDQS DQS0_t DQS0_c DQ[6:0] DQ7 DMI0 tMRZ DQ[13:8] Pattern A Pattern B DQ[15:14] DMI1 DQS1_t DQS1_c VREF(CA) (reference) Pattern C See Note 4 Temporary setting value Switching MR tCKEHODToff ODT_CA (reference) Mode register X (Y) Setting value of MR X (Y) (see Note 3) Switching MR Mode register X (Y) Don’t Care Notes: 1. The clock can be stopped or the frequency changed any time before t CKCKEH. CK must meet t CKCKEH before CKE is driven HIGH. When CKE is driven HIGH, the clock frequency must be returned to the original frequency (that is, the frequency corresponding to the FSP at command bus training mode entry. 2. CS and CA[5:0] must be deselected (LOW) t CKCKEH before CKE is driven HIGH. 3. When CKE is driven HIGH, ODT_CA will revert to the state/value defined by FSP-OP prior to command bus training mode entry, that is, the original frequency set point (FSP-OP, MR13-OP[7]). For example, if the device was using FSP-OP[1] for training, then it will switch to FSP-OP[0] when CKE is driven HIGH. 4. Training values are not retained by the device and must be written to the FSP-OP register set before returning to operation at the trained frequency. For example, VREF(CA) will return to the value programmed in the original set point. 5. When CKE is driven HIGH, the device will revert to the FSP in operation at command bus training mode entry. 162 200b: x32 Mobile LPDDR4XSDRAM Write Leveling Write Leveling Mode Register Write-WR Leveling Mode To improve signal-integrity performance, the device provides a write-leveling feature to compensate for CK-to-DQS timing skew, affecting timing parameters such as tDQSS, tDSS, and tDSH. The memory controller uses the write-leveling feature to receive feedback from the device, enabling it to adjust the clock-to-data strobe signal relationship for each DQS_t/DQS_c signal pair. The device samples the clock state with the rising edge of DQS signals and asynchronously feeds back to the memory controller. The memory controller references this feedback to adjust the clock-to-data strobe signal relationship for each DQS_t/DQS_c signal pair. All data bits (DQ[7:0] for DQS[0], and DQ[15:8] for DQS[1]) carry the training feedback to the controller. Both DQS signals in each channel must be leveled independently. Write-leveling entry/exit is independent between channels. The device enters write leveling mode when mode register MR2-OP[7] is set HIGH. When entering write leveling mode, the state of the DQ pins is undefined. During write leveling mode, only DESELECT commands are allowed, or a MRW command to exit the WRITE LEVELING operation. Depending on the absolute values of tQSL and tQSH in the application, the value of tDQSS may have to be better than the limits provided in the AC Timing Parameters section in order to satisfy the tDSS and tDSH specifications. Upon completion of the WRITE LEVELING operation, the device exits write leveling mode when MR2-OP[7] is reset LOW. Write leveling should be performed before write training (DQS2DQ training). Write-Leveling Procedure: 1. Enter write leveling mode by setting MR2-OP[7]=1. 2. Once in write leveling mode, DQS_t must be driven LOW and DQS_c HIGH after a delay of tWLDQSEN. 3. Wait for a time tWLDQSEN before providing the first DQS signal input. The delay time tWLMRD(MAX) is controller-dependent. 4. The device may or may not capture the first rising edge of DQS_t due to an unstable first rising edge; therefore, at least two consecutive pulses of DQS signal input is required for every DQS input signal during write training mode. The captured clock level for each DQS edge is overwritten, and the device provides asynchronous feedback on all DQ bits after time tWLO. 5. The feedback provided by the device is referenced by the controller to increment or decrement the DQS_t and/or DQS_c delay settings. 6. Repeat steps 4 and 5 until the proper DQS_t/DQS_c delay is established. 7. Exit write leveling mode by setting MR2-OP[7] = 0. 163 200b: x32 Mobile LPDDR4XSDRAM Write Leveling Figure 109: Write-Leveling Timing – tDQSL (MAX) T0 T1 T2 T3 T4 Ta Ta1 Tb Tb1 Tc Tc1 MRW MA MRW MA MRW OP MRW OP DES DES DES DES DES DES DES Td Td1 Td2 Td3 Te DES DES DES DES DES Te1 Tf Tf1 Tf2 Tf3 Tf4 Tg Tg1 Tg2 Tg3 Tg4 MRW MA MRW MA MRW OP MRW OP DES DES Valid Valid Valid Valid CK_c CK_t CA[5:0] Command MRW-1 WR leveling MRW-2 WR leveling DES DES DES DES DES DES DES MRW-1 WR leveling exit DES DES MRW-2 WR leveling exit Valid DES Valid tDQSH tWLDQSEN tDQSL tWLWPRE DQS_c DQS_t tWLMRD tWLO tWLO tWLO tMRD tWLO DQ[15:0] DMI[1:0] Don’t Care 1. Clock can be stopped except during DQS toggle period (CK_t = LOW, CK_c = HIGH). However, a stable clock prior to sampling is required to ensure timing accuracy. Note: Figure 110: Write Leveling Timing – tDQSL (MIN) T0 T1 T2 T3 T4 Ta Ta1 Tb Tb1 Tc Tc1 MRW MA MRW MA MRW OP MRW OP DES DES DES DES DES DES DES Td Td1 Td2 Td3 Te DES DES DES DES DES Te1 Tf Tf1 Tf2 Tf3 Tf4 Tg Tg1 Tg2 Tg3 MRW MA MRW MA MRW OP MRW OP DES DES Valid Valid Valid Valid CK_c CK_t CA[5:0] Command MRW-1 WR leveling MRW-2 WR leveling DES tWLDQSEN DES tWLWPRE DES DES DES DES DES tDQSH DES DES MRW1 WR leveling exit MRW-2 WR leveling exit DES Valid Valid tDQSL DQS_c DQS_t tWLMRD tWLO tWLO tMRD tWLO DQ[15:0] DMI[1:0] Don’t Care Note: 1. Clock can be stopped except during DQS toggle period (CK_t = LOW, CK_c = HIGH). However, a stable clock prior to sampling is required to ensure timing accuracy. Input Clock Frequency Stop and Change The input clock frequency can be stopped or changed from one stable clock rate to another stable clock rate during write leveling mode. The frequency stop or change timing is shown below. 164 200b: x32 Mobile LPDDR4XSDRAM Write Leveling Figure 111: Clock Stop and Timing During Write Leveling T0 T1 T2 T3 Ta0 T4 Ta1 Tb0 Tb1 Tb2 Tc0 Td0 Te0 Te1 Te2 Te3 Te4 Tf0 Tf1 Tf2 Tf3 DES DES DES DES DES CK_c CK_t t CKPSTDQS t CKPRDQS CS CKE CA Command MRW MA MRW MA MRW-1 WR leveling MRW OP MRW OP DES MRW-2 WR leveling DES DES DESELECT t WLDQSEN DES DESELECT t WLWPRE DES DES DES DES DESELECT DES DES DESELECT t DQSH DES DES DESELECT DESELECT DESELECT DESELECT t DQSL DQS_t DQS_c t WLMRD t WLO t WLO t WLO t WLO DQ DMI Table 109: Write Leveling Timing Parameters Parameter DQS_t/DQS_c delay after write leveling mode is programmed Symbol Min/Max Value Units tWLDQSEN MIN 20 tCK MAX – MIN 20 Write preamble for write leveling tWLWPRE First DQS_t/DQS_c edge after write leveling mode is programmed tWLMRD Write leveling output delay tWLO Mode register set command delay tMRD Valid clock requirement before DQS toggle tCKPRDQS Valid clock requirement after DQS toggle tCKPSTDQS MAX – MIN 40 MAX – MIN 0 tCK tCK ns MAX 20 MIN MAX (14ns, 10nCK) MAX – MIN MAX(7.5ns, 4nCK) MAX – MIN MAX(7.5ns, 4nCK) MAX – ns – – Table 110: Write Leveling Setup and Hold Timing Data Rate Symbol Min/Max 1600 2400 3200 3733 4267 Unit Write leveling hold time Parameter tWLH MIN 150 100 75 62.5 50 ps Write leveling setup time tWLS MIN 150 100 75 62.5 50 ps 165 200b: x32 Mobile LPDDR4XSDRAM Write Leveling Table 110: Write Leveling Setup and Hold Timing (Continued) Data Rate Parameter Symbol Min/Max 1600 2400 3200 3733 4267 Unit Write leveling input valid window tWLIVW MIN 240 160 120 105 90 ps Notes: 1. In addition to the traditional setup and hold time specifications, there is value in a invalid window-based specification for write-leveling training. As the training is based on each device, worst case process skews for setup and hold do not make sense to close timing between CK and DQS. 2. tWLIVW is defined in a similar manner to TdIVW_total, except that here it is a DQS invalid window with respect to CK. This would need to account for all VT (voltage and temperature) drift terms between CK and DQS within the device that affect the write-leveling invalid window. The figure below shows the DQS input mask for timing with respect to CK. The “total” mask (tWLIVW) defines the time the input signal must not encroach in order for the DQS input to be successfully captured by CK with a BER of lower than TBD. The mask is a receiver property and it is not the valid data-eye. Figure 112: DQS_t/DQS_c to CK_t/CK_t Timings at the Pins Referenced from the Internal Latch Internal composite DQS eye center aligned to CK CK_c CK_t DQ_diff = DQS_t–DQS_c tWLIVW 166 200b: x32 Mobile LPDDR4XSDRAM MULTIPURPOSE Operation MULTIPURPOSE Operation The device uses the MULTIPURPOSE command to issue a NO OPERATION (NOP) command and to access various training modes. The MPC command is initiated with CS, and CA[5:0] asserted to the proper state at the rising edge of CK, as defined by the Command Truth Table. The MPC command has seven operands (OP[6:0]) that are decoded to execute specific commands in the SDRAM. OP[6] is a special bit that is decoded on the first rising CK edge of the MPC command. When OP[6] = 0, the device executes a NOP command, and when OP[6] = 1, the device further decodes one of several training commands. When OP[6] = 1 and the training command includes a READ or WRITE operation, the MPC command must be followed immediately by a CAS-2 command. For training commands that read or write, READ latency (RL) and WRITE latency (WL) are counted from the second rising CK edge of the CAS-2 command with the same timing relationship as a typical READ or WRITE command. The operands of the CAS-2 command following a MPC READ/WRITE command must be driven LOW. The following MPC commands must be followed by a CAS-2 command: • WRITE FIFO • READ FIFO • READ DQ CALIBRATION All other MPC commands do not require a CAS-2 command, including the following: • • • • • NOP START DQS INTERVAL OSCILLATOR STOP DQS INTERVAL OSCILLATOR START ZQ CALIBRATION LATCH ZQ CALIBRATION Table 111: MPC Command Definition SDR Command Pins SDR CA Pins CKE SDR Command MPC (Train, NOP) CK_t (n-1) CK_t(n) CS CA0 CA1 CA2 CA3 CA4 CA5 H H H L L L L L OP6 1 L OP0 OP1 OP2 OP3 OP4 OP5 2 Notes: CK_t Edge Notes 1, 2 1. See the Command Truth Table for more information. 2. MPC commands for READ or WRITE training operations must be immediately followed by the CAS-2 command, consecutively, without any other commands in between. The MPC command must be issued before issuing the CAS-2 command. 167 200b: x32 Mobile LPDDR4XSDRAM MULTIPURPOSE Operation Table 112: MPC Commands Function Operand Training Modes OP[6:0] Data 0XXXXXXb: NOP 1000001b: Read FIFO: RD FIFO supports only BL16 operation 1000011b: Read DQ Calibration (MR32/MR40) 1000101b: RFU 1000111b: Write FIFO: WR FIFO supports only BL16 operation 1001001b: RFU 1001011b: Start DQS Oscillator 1001101b: Stop DQS Oscillator 1001111b: ZQCal Start 1010001b: ZQCal Latch All Others: Reserved 1. See command truth table for more information. 2. MPC commands for READ or WRITE TRAINING operations must be immediately followed by CAS-2 command consecutively without any other commands in-between. MPC command must be issued first before issuing the CAS-2 command. 3. WRITE FIFO and READ FIFO commands will only operate as BL16, ignoring the burst length selected by MR1 OP[1:0]. Notes: Figure 113: WR-FIFO – tWPRE = 2nCK, tWPST = 0.5nCK T0 T1 T2 T3 BL BA0, CA CAn CAn T4 Ta0 Ta1 Ta2 Tb0 Tb1 Tc0 Tc1 Tc2 Tc3 Tc4 Valid Valid Valid Valid Tc5 Td0 Td1 Td2 Td3 Td4 Valid Valid Valid Valid Td5 Te0 Te1 Te2 Tf0 Tf1 Tg0 Tg1 Tg2 DES DES DES DES DES DES DES DES Tg3 CK_c CK_t CS CA Command WRITE-1 CAS-2 DES DES DES DES DES DES DES MPC WRITE FIFO CAS-2 DES DES MPC WRITE FIFO tCCD t WRWTR WL =8 CAS-2 DES DES WL WL tDQSS t WPRE tDQSS tDQSS t WPST WPRE t WPST DQS_c DQS_t tDQS2DQ tDQS2DQ DQ[15:0] DMI[1:0] n0 n13 n14 n15 tDQS2DQ n0 n13 n14 n15 n0 n13 n14 n15 Don’t Care Notes: 1. MPC [WR-FIFO] can be executed with a single bank or multiple banks active, during refresh or during self refresh, with CKE HIGH. 2. Write-1 to MPC is shown as an example of command-to-command timing for MPC. Timing from Write-1 to MPC [WR-FIFO] is tWRWTR. 3. Seamless MPC [WR-FIFO] commands may be executed by repeating the command every tCCD time. 4. MPC [WR-FIFO] uses the same command-to-data timing relationship (WL, tDQSS, tDQS2DQ) as a Write-1 command. 5. A maximum of five MPC [WR-FIFO] commands may be executed consecutively without corrupting FIFO data. The sixth MPC [WR-FIFO] command will overwrite the FIFO data 168 200b: x32 Mobile LPDDR4XSDRAM MULTIPURPOSE Operation from the first command. If fewer than five MPC [WR-FIFO] commands are executed, then the remaining FIFO locations will contain undefined data. 6. For the CAS-2 command following an MPC command, the CAS-2 operands must be driven LOW. 7. To avoid corrupting the FIFO contents, MPC [RD-FIFO] must immediately follow MPC [WR-FIFO]/CAS-2 without any other commands in-between. See Write Training section for more information on FIFO pointer behavior. Figure 114: RD-FIFO – tWPRE = 2nCK, tWPST = 0.5nCK, tRPRE = Toggling, tRPST = 1.5nCK T0 T1 T2 T3 T4 Ta Ta+1 Ta+2 Ta+3 Tb Tb+1 Tb+2 Tb+3 Tb+4 Tb+5 Tc+2 Tc+3 Tc+4 Tc+5 Tc+6 Tc+7 Td Td+1 Td+2 Td+3 Valid Valid Valid Valid Valid Valid Valid Td+4 Td+5 Valid Valid Te Te+1 Tf Tf+1 Tf+2 Tf+3 Tf+4 Valid Valid Valid Valid Valid Valid Valid CK_c CK_t tCCD CA[5:0] Valid Valid Valid Valid Valid Valid Valid Valid Valid Valid Valid Valid Valid Valid Valid Valid Valid WL Command MPC WRITE FIFO CAS-2 Valid RL Valid Valid Valid MPC READ FIFO tDQSS CAS-2 Valid MPC READ FIFO tWTR CAS-2 Valid Valid Valid Valid Valid Valid Valid tDQSCK DQS_t DQS_c tDQS2DQ DQ[15:0] DMI[1:0] tRPRE D0 D1 D12 D13 D14 D15 tRPST D0 D1 D2 D13 D14 D15 D0 D11 D12 D13 D14 D15 Don’t Care Notes: 1. MPC [WR-FIFO] can be executed with a single bank or multiple banks active, during refresh or during self refresh with CKE HIGH. 2. Seamless MPC [RD-FIFO] commands may be executed by repeating the command every tCCD time. 3. MPC [RD-FIFO] uses the same command-to-data timing relationship (RL, tDQSCK) as a READ-1 command. 4. Data may be continuously read from the FIFO without any data corruption. After five MPC [RD-FIFO] commands, the FIFO pointer will wrap back to the first FIFO and continue advancing. If fewer than five MPC [WR-FIFO] commands were executed, then the MPC [RD-FIFO] commands to those FIFO locations will return undefined data. See Write Training for more information on the FIFO pointer behavior. 5. For the CAS-2 command immediately following an MPC command, the CAS-2 operands must be driven LOW. 6. DMI[1:0] signals will be driven if WR-DBI, RD-DBI, or DM is enabled in the mode registers. See Write Training for more information on DMI behavior. 169 200b: x32 Mobile LPDDR4XSDRAM MULTIPURPOSE Operation Figure 115: RD-FIFO – tRPRE = Toggling, tRPST = 1.5nCK T0 T1 T2 T3 T4 Ta Ta+1 Ta+2 Ta+3 Ta+4 Ta+5 Tb Valid Valid Valid Valid Tb+1 Tb+2 Tb+3 Tb+4 Valid Valid Valid Tc Tc+1 Tc+2 Td Td+1 Td+2 Td+3 Te Te+1 Te+2 Te+3 Te+4 Te+5 Valid Valid Valid Valid Valid Valid Valid Valid Valid Valid Valid Valid Valid CK_c CK_t tRTRRD CA[5:0] Valid Valid Valid Valid Valid Valid Valid Valid Valid Valid RL RL Command MPC READ FIFO CAS-2 Valid READ-1 CAS-2 Valid Valid Valid Valid Valid Valid Valid Valid tDQSCK Valid Valid tDQSCK DQS_t DQS_c tRPST tRPRE DQ[15:0] DMI[1:0] tRPST tRPRE D0 D1 D12 D13 D14 D15 D0 D1 D12 D13 D14 D15 Don’t Care Notes: 1. MPC [WR-FIFO] can be executed with a single bank or multiple banks active, during refresh or during self refresh with CKE HIGH. 2. MPC [RD-FIFO] to READ-1 operation is shown as an example of command-to-command timing for MPC. Timing from MPC [RD-FIFO] command to read is tRTRRD. 3. Seamless MPC [RD-FIFO] commands may be executed by repeating the command every tCCD time. 4. MPC [RD-FIFO] uses the same command-to-data timing relationship (RL, tDQSCK) as a READ-1 command. 5. Data may be continuously read from the FIFO without any data corruption. After five MPC [RD-FIFO] commands, the FIFO pointer will wrap back to the first FIFO and continue advancing. If fewer than five MPC [WR-FIFO] commands are executed, then the MPC [RD-FIFO] commands to those FIFO locations will return undefined data. See Write Training for more information on the FIFO pointer behavior. 6. For the CAS-2 command immediately following an MPC command, the CAS-2 operands must be driven LOW. 7. DMI[1:0] signals will be driven if WR-DBI, RD-DBI, or DM is enabled in the mode registers. See Write Training for more information on DMI behavior. Table 113: Timing Constraints for Training Commands Previous Command Next Command Minimum Delay Unit Notes WR/MWR MPC [WR FIFO] tWRWTR nCK 1 MPC [RD FIFO] Not allowed – 2 RU(tDQSS(MAX)/tCK) MPC [RD DQ CALIBRATION] RD/MRR WL + BL/2 + RU(tWTR/tCK) + nCK MPC [WR FIFO] tRTW nCK 4 MPC [RD FIFO] Not allowed – 2 MPC [RD DQ CALIBRATION] tRTRRD nCK 3 170 200b: x32 Mobile LPDDR4XSDRAM MULTIPURPOSE Operation Table 113: Timing Constraints for Training Commands (Continued) Previous Command Next Command Minimum Delay Unit Notes MPC [WR FIFO] WR/MWR Not allowed – 2 MPC [WR FIFO] tCCD nCK RD/MRR Not allowed – RU(tDQSS(MAX)/tCK) MPC [RD FIFO] Notes: + nCK MPC [RD DQ CALIBRATION] Not allowed – 2 WR/MWR tRTW nCK 4 MPC [WR FIFO] tRTW nCK 4 RD/MRR tRTRRD nCK 3 MPC [RD FIFO] tCCD nCK MPC [RD DQ CALIBRATION] tRTRRD nCK 3 WR/MWR tRTW nCK 4 MPC [WR FIFO] tRTW nCK 4 RD/MRR tRTRRD nCK 3 MPC [RD FIFO] Not allowed – 2 MPC [RD DQ CALIBRATION] tCCD nCK MPC [RD FIFO] MPC [RD DQ CALIBRATION] WL + BL/2 + RU(tWTR/tCK) 2 1. tWRWTR = WL + BL/2 + RU(tDQSS (MAX)/tCK) + MAX(RU(7.5ns/tCK), 8nCK). 2. No commands are allowed between MPC [WR FIFO] and MPC [RD FIFO] except the MRW commands related to training parameters. 3. t RTRRD = RL + RU(tDQSCK (MAX)/tCK) + BL/2 + t RPST + 0.5 + MAX(RU(7.5ns/tCK), 8nCK). 4. In case of DQ ODT disable MR11 OP[2:0] = 000b, tRTW = RL + RU(tDQSCK (MAX)/tCK) + BL/2 - WL + tWPRE + RD(tRPST). In case of DQ ODT enable MR11 OP[2:0] ≠ 000b, tRTW = RL + RU(tDQSCK (MAX)/tCK) + BL/2 + tRPST - ODTLon - RD(tODTon(Min)/tCK) + 1. 171 200b: x32 Mobile LPDDR4XSDRAM Read DQ Calibration Training Read DQ Calibration Training The read DQ calibration training function outputs a 16-bit, user-defined pattern on the DQ pins. Read DQ calibration is initiated by issuing a MPC-1 [RD DQ CALIBRATION] command followed by a CAS-2 command, which causes the device to drive the contents of MR32, followed by the contents of MR40 on each of DQ[15:0] and DMI[1:0]. The pattern can be inverted on selected DQ pins according to user-defined invert masks written to MR15 and MR20. Read DQ Calibration Procedure 1. Issue MRW commands to write MR32 (first eight bits), MR40 (second eight bits), MR15 (eight-bit invert mask for byte 0), and MR20 (eight-bit invert mask for byte 1). In the alternative, this step could be replaced with the default pattern: • MR32 default = 5Ah • MR40 default = 3Ch • MR15 default = 55h • MR20 default = 55h 2. Issue an MPC-1 command, followed immediately by a CAS-2 command. • Each time an MPC-1 command, followed by a CAS-2, is received by the device, a 16-bit data burst will drive the eight bits programmed in MR32 followed by the eight bits programmed in MR40 on all I/O pins after the currently set RL. • The data pattern will be inverted for I/O pins with a 1 programmed in the corresponding invert mask mode register bit (see table below). • The pattern is driven on the DMI pins, but no data bus inversion function is enabled, even if read DBI is enabled in the mode register. • The MPC-1 command can be issued every tCCD seamlessly, and tRTRRD delay is required between ARRAY READ command and the MPC-1 command as well the delay required between the MPC-1 command and an ARRAY READ. • The operands received with the CAS-2 command must be driven LOW. 3. DQ DQ read training can be performed with any or no banks active during refresh, or during self refresh with CKE HIGH. Table 114: Invert Mask Assignments DQ Pin 0 1 2 3 DMI0 4 5 6 7 MR15 bit 0 1 2 3 n/a 4 5 6 7 DQ Pin 8 9 10 11 DMI1 12 13 14 15 MR20 bit 0 1 2 3 n/a 4 5 6 7 172 200b: x32 Mobile LPDDR4XSDRAM Read DQ Calibration Training Figure 116: DQ Read Training Timing: Read to Read DQ Calibration T0 T1 T2 T3 BL BA0, CA CAn CAn T4 Ta0 Ta1 Ta2 Ta3 Ta4 Ta5 Tb0 Tb1 Tb2 Tc1 Tc2 Tc3 Tc4 Tc5 Tc6 Valid Valid Tc7 Td1 Td2 Td3 Td4 Td5 Td6 Te0 DES DES DES DES DES DES DES Te1 Te2 Te3 CK_c CK_t CS CA Command Valid CAS-2 READ-1 DES DES DES DES DES DES DES DES DES DES DES Valid MPC RD DQ Cal. DES CAS-2 DES tRTRRD t RL RL DES DES DQSCK t RPST t RPRE t RPST High-Z High-Z tDQSQ DQ DMI DES DQSCK t RPRE DQS_c DQS_t t High-Z tDQSQ High-Z n0 n13 n14 n15 n0 n13 n14 n15 Don’t Care 1. Read-1 to MPC operation is shown as an example of command-to-command timing. Timing from Read-1 to MPC command is tRTRRD. 2. MPC uses the same command-to-data timing relationship (RL, tDQSCK, tDQSQ) as a Read-1 command. 3. BL = 16, Read preamble: Toggle, Read postamble: 0.5nCK. 4. DES commands are shown for ease of illustration; other commands may be valid at these times. Notes: Figure 117: DQ Read Training Timing: Read DQ Calibration to Read DQ Calibration/Read T0 T1 T2 T3 T8 T9 T10 T11 Valid Valid Valid Valid Valid Valid Valid Valid T12 T13 T14 Ta0 Ta1 Ta2 Ta3 Tb1 Tb0 Tc0 Tc1 Tc2 Tc3 Tc4 BA0, CA CAn CAn Tc5 Td0 DES DES Td1 Td2 Td3 Td4 DES DES DES Te0 Te1 CK_c CK_t CS CA Command MPC RD DQ Cal. CAS-2 DES MPC RD DQ Cal. CAS-2 BL DES DES DES DES DES DES t CCD DES DES READ-1 CAS-2 RL DES DES DES tDQSCK tDQSCK RL t RPST t RPRE High-Z High-Z t RPRE t RPST High-Z tDQSQ DQ DMI DES tDQSCK RL DQS_c DQS_t DES tRTRRD t DQSQ n0 n9 n10 n11 n12 n13 n14 n15 n0 n13 n14 n15 tDQSQ High-Z n0 n13 n14 n15 Don’t Care Notes: 1. MPC [RD DQ CALIBRATION] to MPC [RD DQ CALIBRATION] operation is shown as an example of command-to-command timing. 2. MPC [RD DQ CALIBRATION] to READ-1 operation is shown as an example of commandto-command timing. 3. MPC [RD DQ CALIBRATION] uses the same command-to-data timing relationship (RL, tDQSCK, tDQSQ) as a READ-1 command. 4. Seamless MPC [RD DQ CALIBRATION] commands may be executed by repeating the command every tCCD time. 5. Timing from MPC [RD DQ CALIBRATION] command to READ-1 is tRTRRD. 173 200b: x32 Mobile LPDDR4XSDRAM Read DQ Calibration Training 6. BL = 16, Read preamble: Toggle, Read postamble: 0.5nCK. 7. DES commands are shown for ease of illustration; other commands may be valid at these times. DQ Read Training Example An example of DQ read training output is shown in table below. This shows the 16-bit data pattern that will be driven on each DQ in byte 0 when one DQ READ TRAINING command is executed. This output assumes the following mode register values are used: • • • • MR32 = 1CH MR40 = 59H MR15 = 55H MR20 = 55H Table 115: DQ Read Calibration Bit Ordering and Inversion Example Bit Sequence → Pin Invert 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 DQ0 Yes 1 0 1 0 0 1 1 0 1 1 1 0 0 0 1 1 DQ1 No 0 1 0 1 1 0 0 1 0 0 0 1 1 1 0 0 DQ2 Yes 1 0 1 0 0 1 1 0 1 1 1 0 0 0 1 1 DQ3 No 0 1 0 1 1 0 0 1 0 0 0 1 1 1 0 0 DMI0 Never 0 1 0 1 1 0 0 1 0 0 0 1 1 1 0 0 DQ4 Yes 1 0 1 0 0 1 1 0 1 1 1 0 0 0 1 1 DQ5 No 0 1 0 1 1 0 0 1 0 0 0 1 1 1 0 0 DQ6 Yes 1 0 1 0 0 1 1 0 1 1 1 0 0 0 1 1 DQ7 No 0 1 0 1 1 0 0 1 0 0 0 1 1 1 0 0 DQ8 Yes 1 0 1 0 0 1 1 0 1 1 1 0 0 0 1 1 DQ9 No 0 1 0 1 1 0 0 1 0 0 0 1 1 1 0 0 DQ10 Yes 1 0 1 0 0 1 1 0 1 1 1 0 0 0 1 1 DQ11 No 0 1 0 1 1 0 0 1 0 0 0 1 1 1 0 0 DMI1 Never 0 1 0 1 1 0 0 1 0 0 0 1 1 1 0 0 DQ12 Yes 1 0 1 0 0 1 1 0 1 1 1 0 0 0 1 1 DQ13 No 0 1 0 1 1 0 0 1 0 0 0 1 1 1 0 0 DQ14 Yes 1 0 1 0 0 1 1 0 1 1 1 0 0 0 1 1 DQ15 No 0 1 0 1 1 0 0 1 0 0 0 1 1 1 0 0 Notes: 1. The patterns contained in MR32 and MR40 are transmitted on DQ[15:0] and DMI[1:0] when RD DQ calibration is initiated via a MPC-1 [RD DQ CALIBRATION] command. The pattern transmitted serially on each data lane, organized little endian such that the loworder bit in a byte is transmitted first. If the data pattern is 27H, then the first bit transmitted with be a 1, followed by 1, 1, 0, 0, 1, 0, and 0. The bit stream will be 00100111 →. 174 200b: x32 Mobile LPDDR4XSDRAM Read DQ Calibration Training 2. MR15 and MR20 may be used to invert the MR32/MR40 data pattern on the DQ pins. See MR15 and MR20 for more information. Data is never inverted on the DMI[1:0] pins. 3. DMI [1:0] outputs status follows MR Setting vs. DMI Status table. 4. No data bus inversion (DBI) function is enacted during RD DQ calibration, even if DBI is enabled in MR3-OP[6]. Table 116: MR Setting vs. DMI Status DM function MR13 OP[5] WRITE DBIdc function MR3 OP[7] READ DBIdc function MR3 OP[6] DMI Status 1: Disable 0: Disable 0: Disable High-Z 1: Disable 1: Enable 0: Disable The data pattern is transmitted 1: Disable 0: Disable 1: Enable The data pattern is transmitted 1: Disable 1: Enable 1: Enable The data pattern is transmitted 0: Enable 0: Disable 0: Disable The data pattern is transmitted 0: Enable 1: Enable 0: Disable The data pattern is transmitted 0: Enable 0: Disable 1: Enable The data pattern is transmitted 0: Enable 1: Enable 1: Enable The data pattern is transmitted MPC of Read DQ Calibration after Power-Down Exit Following the power-down state, an additional time, tMRRI, is required prior to issuing the MPC of READ DQ CALIBRATION command. This additional time (equivalent to tRCD) is required in order to be able to maximize power-down current savings by allowing more power-up time for the read DQ data in MR32 and MR40 data path after exit from standby, power-down mode. Figure 118: MPC Read DQ Calibration Following Power-Down State T0 Ta0 Tb0 Tb1 Tb2 Tc0 Tc1 Tc2 Tc3 Tc4 Tc5 Td0 Td1 Td2 Td3 Td4 Td5 Valid Valid Valid Td6 Td7 Td8 Td9 DES DES DES CK_c CK_t t CKCKEH CKE t MRRI t XP CS CA Command DES DES DES DES DES DES DES DES DES DES MPC READ DQ cal Valid CAS-2 DON'T CARE 175 200b: x32 Mobile LPDDR4XSDRAM Write Training Write Training The device uses an unmatched DQS-DQ path to enable high-speed performance and save power. As a result, the DQS strobe must be trained to arrive at the DQ latch centeraligned with the data eye. The DQ receiver is located at the DQ pad and has a shorter internal delay than the DQS signal. The DQ receiver will latch the data present on the DQ bus when DQS reaches the latch, and write training is accomplished by delaying the DQ signals relative to DQS such that the data eye arrives at the receiver latch centered on the DQS transition. Two modes of training are available: • Command-based FIFO WR/RD with user patterns • An internal DQS clock-tree oscillator, which determines the need for, and the magnitude of, required training The command-based FIFO WR/RD uses the MPC command with operands to enable this special mode of operation. When issuing the MPC command, if CA[5] is set LOW (OP[6] = 0), then the device will perform a NOP command. When CA[5] is set HIGH, the CA[4:0] pins enable training functions or are reserved for future use (RFU). MPC commands that initiate a read or write to the device must be followed immediately by a CAS-2 command. See the MPC Operation section for more information. To perform write training, the controller can issue an MPC [WRITE DQ FIFO] command with OP[6:0] set, followed immediately by a CAS-2 command (CAS-2 operands should be driven LOW) to initiate a WRITE DQ FIFO. Timings for MPC [WRITE DQ FIFO] are identical to WRITE commands, with WL timed from the second rising clock edge of the CAS-2 command. Up to five consecutive MPC [WRITE DQ FIFO] commands with userdefined patterns may be issued to the device, which will store up to 80 values (BL16 × 5) per pin that can be read back via the MPC [READ DQ FIFO] command. (The WRITE/ READ FIFO POINTER operation is described in a different section. After writing data with the MPC [WRITE DQ FIFO] command, the data can be read back with the MPC [READ DQ FIFO] command and results can be compared with "expected" data to determine whether further training (DQ delay) is needed. MPC [READ DQ FIFO] is initiated by issuing an MPC command, as described in the MPC Operation section, followed immediately by a CAS-2 command (CAS-2 operands must be driven LOW). Timings for the MPC [READ DQ FIFO] command are identical to READ commands, with RL timed from the second rising clock edge of the CAS-2 command. READ DQ FIFO is nondestructive to the data captured in the FIFO; data may be read continuously until it is disturbed by another command, such as a READ, WRITE, or another MPC [WRITE DQ FIFO]. If fewer than five WRITE DQ FIFO commands are executed, unwritten registers will have undefined (but valid) data when read back. For example: If five WRITE DQ FIFO commands are executed sequentially, then a series of READ DQ FIFO commands will read valid data from FIFO[0], FIFO[1]….FIFO[4] and then wrap back to FIFO[0] on the next READ DQ FIFO. However, if fewer than five WRITE DQ FIFO commands are executed sequentially (example = 3), then a series of READ DQ FIFO commands will return valid data for FIFO[0], FIFO[1], and FIFO[2], but the next two READ DQ FIFO commands will return undefined data for FIFO[3] and FIFO[4] before wrapping back to the valid data in FIFO[0]. The READ DQ FIFO pointer and WRITE DQ FIFO pointer are reset under the following conditions: 176 200b: x32 Mobile LPDDR4XSDRAM Write Training • • • • Power-up initialization RESET_n asserted Power-down entry Self refresh power-down entry The WR-FIFO and RD-FIFO pointers both advance for any normal (non-FIFO) READ operation (RD, RDA). An MPC [WRITE DQ FIFO] command advances the WR-FIFO pointer, and an MPC [READ DQ FIFO] command advances the RD-FIFO pointer. To keep the pointers aligned, the SoC memory controller must adhere to the following restriction: Figure 119: WRITE to MPC [WRITE FIFO] Operation Timing T0 T1 T2 T3 BL BA0, CA CAn CAn T4 Ta0 Ta1 Ta2 Tb0 Tb1 Tc0 Tc1 Tc2 Tc3 Tc4 Valid Valid Valid Valid Tc5 Td0 Td1 Td2 Td3 Td4 Valid Valid Valid Valid Td5 Te0 Te1 Te2 Tf0 Tf1 Tg0 Tg1 Tg2 DES DES DES DES DES DES DES Tg3 CK_c CK_t CS CA Command WRITE-1 CAS-2 DES DES DES DES DES DES DES MPC WRITE FIFO CAS-2 DES DES MPC WRITE FIFO tCCD t WRWTR WL =8 CAS-2 DES DES DES WL WL tDQSS t WPRE tDQSS tDQSS t WPST WPRE t WPST DQS_c DQS_t tDQS2DQ tDQS2DQ DQ[15:0] DMI[1:0] n0 n13 n14 n15 tDQS2DQ n0 n13 n14 n15 n0 n13 n14 n15 Don’t Care Notes: 1. MPC [WR-FIFO] can be executed with a single bank or multiple banks active, during REFRESH or during SELF REFRESH, with CKE HIGH. 2. Write-1 to MPC is shown as an example of command-to-command timing for MPC. Timing from write-1 to MPC [WR-FIFO] is tWRWTR. 3. Seamless MPC [WR-FIFO] commands may be executed by repeating the command every tCCD time. 4. MPC [WR-FIFO] uses the same command-to-data timing relationship (WL, tDQSS, tDQS2DQ) as a WRITE-1 command. 5. A maximum of 5 MPC [WR-FIFO] commands may be executed consecutively without corrupting FIFO data. The 6th MPC [WR-FIFO] command will overwrite the FIFO data from the first command. If fewer than 5 MPC [WR-FIFO] commands are executed, then the remaining FIFO locations will contain undefined data. 6. For the CAS-2 command following an MPC command, the CAS-2 operands must be driven LOW. 7. To avoid corrupting the FIFO contents, MPC [RD-FIFO] must immediately follow MPC [WR-FIFO]/CAS-2 without any other commands disturbing FIFO pointers in between. FIFO pointers are disturbed by CKE LOW, WRITE, MASKED WRITE, READ, READ DQ CALIBRATION, and MRR. 8. BL = 16, Write postamble = 0.5nCK 9. DES commands are shown for ease of illustration; other commands may be valid at these times. 177 200b: x32 Mobile LPDDR4XSDRAM Write Training Figure 120: MPC [WRITE FIFO] to MPC [READ FIFO] Timing T0 T1 T2 T3 BL BA0, CA CAn CAn T4 Ta0 Ta1 Ta2 Tb0 Tb1 Tb2 Tc0 Tc1 Tc2 Tc3 Tc4 Valid Valid Valid Valid Tc5 Td0 Td1 Td2 Td3 Td4 Valid Valid Td5 Te0 Te1 Te2 Te3 Tf0 Tf1 Tg0 Tg1 DES DES DES DES DES DES DES DES DES CK_c CK_t CS CA Command MPC WRITE FIFO CAS-2 DES DES DES WL DES DES DES DES DES MPC READ FIFO CAS-2 DES DES Valid MPC READ FIFO tCCD tWTR BL/2 + 1 clock Valid =8 RL tDQSS t WPRE CAS-2 tDQSCK t RPRE t WPST t RPST DQS_c DQS_t tDQS2DQ DQ DMI tDQSQ n0 n13 n14 n15 n0 n13 n14 n15 n0 n13 n14 n15 Don’t Care Notes: 1. MPC [WR-FIFO] can be executed with a single bank or multiple banks active, during refresh or during self refresh with CKE HIGH. 2. MPC [WR-FIFO] to MPC [RD-FIFO] is shown as an example of command-to-command timing for MPC. Timing from MPC [WR-FIFO] to MPC [RD-FIFO] is specified in the commandto-command timing table. 3. Seamless MPC [RD-FIFO] commands may be executed by repeating the command every tCCD time. 4. MPC [RD-FIFO] uses the same command-to-data timing relationship (RL, tDQSCK, tDQSQ ) as a READ-1 command. 5. Data may be continuously read from the FIFO without any data corruption. After five MPC [RD-FIFO] commands, the FIFO pointer will wrap back to the first FIFO and continue advancing. If fewer than five MPC [WR-FIFO] commands were executed, then the MPC [RD-FIFO] commands to those FIFO locations will return undefined data. See Write Training for more information on the FIFO pointer behavior. 6. For the CAS-2 command immediately following an MPC command, the CAS-2 operands must be driven LOW. 7. DMI[1:0] signals will be driven if WR-DBI, RD-DBI, or DM is enabled in the mode registers. See Write Training section for more information on DMI behavior. 8. BL = 16, Write postamble = 0.5nCK, Read preamble: Toggle, Read postamble: 0.5nCK 9. DES commands are shown for ease of illustration; other commands may be valid at these times. 178 200b: x32 Mobile LPDDR4XSDRAM Write Training Figure 121: MPC [READ FIFO] to Read Timing T0 T1 T2 T3 Valid Valid CAn CAn T4 Ta0 Ta1 Ta2 Ta3 Ta4 Ta5 Tb0 Tb1 Tb2 Tc1 Tc2 Tc3 Tc4 Tc5 Tc6 BL BA0, CA CAn CAn Tc7 Td1 Td2 Td3 Td4 Td5 Td6 Te0 DES DES DES DES DES DES DES Te1 Te2 Te3 CK_c CK_t CS CA Command MPC RAD FIFO CAS-2 DES DES DES DES DES DES DES DES DES DES DES tRTRRD RL t DES READ-1 CAS-2 DES RL t DES DES DES DQSCK DQSCK t RPRE t RPRE t RPST t RPST DQS_c DQS_t tDQSQ DQ DMI tDQSQ n0 n13 n14 n15 n0 n13 n14 n15 Don’t Care Notes: 1. MPC [WR-FIFO] can be executed with a single bank or multiple banks active, during refresh or during self refresh with CKE HIGH. 2. MPC [RD-FIFO] to READ-1 Operation is shown as an example of command-to-command timing for MPC. Timing from MPC [RD-FIFO] command to READ is tRTRRD. 3. Seamless MPC [RD-FIFO] commands may be executed by repeating the command every tCCD time. 4. MPC [RD-FIFO] uses the same command-to-data timing relationship (RL, tDQSCK, tDQSQ ) as a READ-1 command. 5. Data may be continuously read from the FIFO without any data corruption. After five MPC [RD-FIFO] commands, the FIFO pointer will wrap back to the first FIFO and continue advancing. If fewer than five MPC [WR-FIFO] commands were executed, then the MPC [RD-FIFO] commands to those FIFO locations will return undefined data. See Write Training for more information on the FIFO pointer behavior. 6. For the CAS-2 command immediately following an MPC command, the CAS-2 operands must be driven LOW. 7. DMI[1:0] signals will be driven if WR-DBI, RD-DBI, or DM is enabled in the mode registers. See Write Training for more information on DMI behavior. 8. BL = BL = 16, Read preamble: Toggle, Read postamble: 0.5nCK 9. DES commands are shown for ease of illustration; other commands may be valid at these times. 179 200b: x32 Mobile LPDDR4XSDRAM Write Training Figure 122: MPC [WRITE FIFO] with DQ ODT Timing T0 T1 T2 T3 Valid Valid Valid Valid T4 Ta0 Ta1 Ta2 Ta3 Ta4 Ta5 Ta6 Ta7 Ta8 Tb0 Tb1 Tb2 Tb3 Tb4 Tb5 Tb6 DES DES DES DES DES DES DES DES DES DES DES DES DES DES DES DES DES CK_c CK_t CS CA Command MPC WRITE FIFO CAS-2 WL tDQSS t WPRE t WPST DQS_c DQS_t tDQS2DQ DQ DMI n0 ODTLon t ODTon(MAX) t DRAM RTT ODT High-Z n1 n2 n13 n14 n15 ODTon(MIN) Transition Transition ODT On ODTLoff t t ODT High-Z ODToff(MIN) ODToff(MAX) Don’t Care Notes: 1. MPC [WR-FIFO] can be executed with a single bank or multiple banks active, during refresh or during self refresh with CKE HIGH. 2. MPC [WR-FIFO] uses the same command-to-data/ODT timing relationship (RL, tDQSCK, tDQS2DQ, ODTLon, ODTLoff, tODTon, tODToff) as a WRITE-1 command. 3. For the CAS-2 command immediately following an MPC command, the CAS-2 operands must be driven LOW. 4. BL = BL = 16, Write postamble = 0.5nCK 5. DES commands are shown for ease of illustration; other commands may be valid at these times. 180 200b: x32 Mobile LPDDR4XSDRAM Write Training Figure 123: Power Down Exit to MPC [WRITE FIFO] Timing T0 Tb0 Ta0 Tb1 Tb2 Tc0 Tc1 Tc2 Tc3 Tc4 Tc5 Td0 Td1 Td2 Td3 Td4 Td5 Td6 Td7 Td8 Td9 CK_c CK_t t CKCKEH CKE t t XP MPCWR (= t RCD + 3nCK) WL CS CA Valid Valid Valid Valid Valid Valid Valid Valid Note 1 DES Command DES Any command Any command DES DES DES DES MPC WRITE FIFO CAS-2 DES DES DES Don’t Care Notes: 1. Any commands except MPC [WR-FIFO] and other exception commands defined other section in this document (for example. MPC [Read DQ CAL]). 2. DES commands are shown for ease of illustration; other commands may be valid at these times. Table 117: MPC [WRITE FIFO] AC Timing Parameter tXP has expired until Additional time after MPC [WRITE FIFO] command may be issued Symbol tMPCWR MIN/MAX Min Value tRCD + 3nCK Unit – Internal Interval Timer As voltage and temperature change on the device, the DQS clock-tree delay will shift, requiring retraining. The device includes an internal DQS clock-tree oscillator to measure the amount of delay over a given time interval (determined by the controller), allowing the controller to compare the trained delay value to the delay value seen at a later time. The DQS oscillator will provide the controller with important information regarding the need to retrain and the magnitude of potential error. The DQS interval oscillator is started by issuing an MPC command with OP[5:0] = 101011b, which will start an internal ring oscillator that counts the number of time a signal propagates through a copy of the DQS clock tree. The DQS oscillator may be stopped by issuing an MPC [STOP DQS OSC] command with OP[6:0] set, as described in MPC Operation, or the controller may instruct the SDRAM to count for a specific number of clocks and then stop automatically (See MR23 for more information). If MR23 is set to automatically stop the DQS oscillator, then the MPC [STOP DQS OSC] command should not be used (illegal). When the DQS oscillator is stopped by either method, the result of the oscillator counter is automatically stored in MR18 and MR19. The controller may adjust the accuracy of the result by running the DQS interval oscillator for shorter (less accurate) or longer (more accurate) duration. The accuracy of the 181 200b: x32 Mobile LPDDR4XSDRAM Write Training result for a given temperature and voltage is determined by the following equation, where run time = total time between start and stop commands and DQS delay = the value of the DQS clock tree delay (tDQS2DQ MIN/MAX): DQS oscillator granularity error = 2 x (DQS delay) run time Additional matching error must be included, which is the difference between DQS training circuit and the actual DQS clock tree across voltage and temperature. The matching error is vendor specific. Therefore, the total accuracy of the DQS oscillator counter is given by: DQS oscillator accuracy = 1 - granularity error - matching error For example, if the total time between start and stop commands is 100ns, and the maximum DQS clock tree delay is 800ps (tDQS2DQ MAX), then the DQS oscillator granularity error is: DQS oscillator granularity error = 2 x (0.8ns) = 1.6% 100ns This equates to a granularity timing error of 12.8ps. Assuming a circuit matching error of 5.5ps across voltage and temperature, the accuracy is: DQS oscillator accuracy = 1 - 12.8 + 5.5 = 97.7% 800 For example, running the DQS oscillator for a longer period improves the accuracy. If the total time between start and stop commands is 500ns, and the maximum DQS clock tree delay is 800ps (tDQS2DQ MAX), then the DQS oscillator granularity error is: DQS oscillator granularity error = 2 x (0.8ns) = 0.32% 500ns This equates to a granularity timing error or 2.56ps. Assuming a circuit matching error of 5.5ps across voltage and temperature, the accuracy is: DQS oscillator accuracy = 1 - 2.56 + 5.5 = 99.0% 800 The result of the DQS interval oscillator is defined as the number of DQS clock tree delays that can be counted within the run time, determined by the controller. The result is stored in MR18-OP[7:0] and MR19-OP[7:0]. MR18 contains the least significant bits (LSB) of the result, and MR19 contains the most significant bits (MSB) of the result. MR18 and MR19 are overwritten by the SDRAM when a MPC [Stop DQS Osc] command is received. The SDRAM counter will count to its maximum value (= 2^16) and stop. If the maximum value is read from the mode registers, the memory controller must assume that the counter overflowed the register and therefore discard the result. The longest run time for the oscillator that will not overflow the counter registers can be calculated as follows: Longest runtime interval = 216 x tDQS2DQ(MIN) = 216 × 0.2ns = 13.1μs 182 200b: x32 Mobile LPDDR4XSDRAM Write Training DQS Interval Oscillator Matching Error The interval oscillator matching error is defined as the difference between the DQS training ckt(interval oscillator) and the actual DQS clock tree across voltage and temperature. Parameters: tDQS2DQ: actual DQS clock tree delay tDQS OSC: training ckt(interval oscillator) delay OSCOffset: average delay difference over voltage and temp(shown below) OSCMatch: DQS oscillator matching error Figure 124: Interval Oscillator Offset – OSCoffset Offset 2 tDQS2DQ tDQS OSC Time (ps) OSC offset = AVG(offset1, offset2) Offset 1 (at end point) = tDQS2DQ(V,T) – tDQSOSC(V,T) Offset 2 (at end point) = tDQS2DQ(V,T) – tDQSOSC(V,T) Offset 1 Temperature(T)/Voltage(V) OSCMatch : OSCMatch = [ tDQS2DQ(V,T) - tDQSOSC (V,T) - OSCoffset ] tDQS tDQS OSC: OSC(V,T) = [ Runtime 2 × Count ] Table 118: DQS Oscillator Matching Error Specification Parameter Symbol MIN MAX Unit Notes DQS Oscillator Matching Error OSCMatch –20 20 ps 1, 2, 3, 4, 5, 6, 7, 8 DQS Oscillator Offset OSCoffset –100 100 ps 2, 4. 7 Notes: 1. The OSCMatch is the matching error per between the actual DQS and DQS interval oscillator over voltage and temp. 183 200b: x32 Mobile LPDDR4XSDRAM Write Training 2. This parameter will be characterized or guaranteed by design. 3. The OSCMatch is defined as the following: OSCMatch = [ tDQS2DQ(V, T) - tDQSOSC(V, T) - OSCoffset ] Where tDQS2DQ(V,T) and tDQSOSC(V,T) are determined over the same voltage and temp conditions. 4. The runtime of the oscillator must be at least 200ns for determining tDQSOSC(V,T). tDQS OSC(V,T) = 5. 6. 7. 8. [ Runtime 2 × Count ] The input stimulus for tDQS2DQ will be consistent over voltage and temp conditions. The OSCoffset is the average difference of the endpoints across voltage and temp. These parameters are defined per channel. tDQS2DQ(V,T) delay will be the average of DQS to DQ delay over the runtime period. OSC Count Readout Time OSC Stop to its counting value readout timing is shown in following figures. Figure 125: In case of DQS Interval Oscillator is stopped by MPC Command T0 T1 T2 Valid Valid T3 T4 T5 Ta0 Ta1 Ta2 Valid Valid Ta3 Ta4 Tb0 Tb1 Tb2 Tb3 Tb4 Tb5 Valid Valid Valid Valid Tb6 CK_c CK_t CKE CS CA Command DES MPC :Start MR DQS Write-2 Oscillator DES DES DES DES MPC :Stop DQS Oscillator DES DES DES DES MRR-1 MR18/MR19 CAS-2 t OSCO Don’t Care Note: 1. DQS interval timer run time setting : MR23 OP[7:0] = 00000000b 184 200b: x32 Mobile LPDDR4XSDRAM Write Training Figure 126: In case of DQS Interval Oscillator is stopped by DQS interval timer T0 T1 T2 Valid Valid T3 T4 T5 Ta0 Ta1 Ta2 Ta3 Ta4 Tb0 Tb2 Tb3 Tb4 Tb5 Valid Valid Valid Valid Tb1 Tb6 CK_c CK_t CKE CS CA Command DES MPC :Start MR DQS Write-2 Oscillator DES DES DES DES DES DES DES DES DES MRR-1 MR18/MR19 CAS-2 t OSCO See Note 2 Don’t Care Notes: 1. DQS interval timer run time setting : MR23 OP[7:0] ≠ 00000000b 2. Setting counts of MR23 Table 119: AC Timing Parameter Delay time from OSC stop to Mode Register Readout Symbol MIN/MAX Value Unit tOSCO Min Max(40ns, 8nCK) ns 185 200b: x32 Mobile LPDDR4XSDRAM Thermal Offset Thermal Offset Because of tight thermal coupling, hot spots on an SOC can induce thermal gradients across the device. Because these hot spots may not be located near the thermal sensor, the temperature compensated self refresh (TCSR) circuit may not generate enough refresh cycles to guarantee memory retention. To address this shortcoming, the controller can provide a thermal offset that the memory can use to adjust its TCSR circuit to ensure reliable operation. This thermal offset is provided through MR4 OP[6:5] to either or both channels. This temperature offset may modify refresh behaviour for the channel to which the offset is provided. It will take a maximum of 200μs to have the change reflected in MR4 OP[2:0] for the channel to which the offset is provided. If the induced thermal gradient from the device temperature sensor location to the hot spot location of the controller is greater than 15°C, self refresh mode will not reliably maintain memory contents. To accurately determine the temperature gradient between the memory thermal sensor and the induced hot spot, the memory thermal sensor location must be provided to the controller. Support of the thermal offset function is optional. Please refer to the vendor data sheet to determine if this function is supported. Temperature Sensor The device has a temperature sensor that can be read from MR4. This sensor can be used to determine the appropriate refresh rate, to determine whether AC timing de-rating is required at an elevated temperature range, and to monitor the operating temperature. Either the temperature sensor or the device T OPER can be used to determine if operating temperature requirements are being met. The device monitors device temperature and updates MR4 according to tTSI. Upon exiting self refresh or power-down, the device temperature status bits shall be no older than tTSI. When using the temperature sensor, the actual device case temperature may be higher than the T OPER specification that applies to standard or elevated temperature ranges. For example, T CASE may be above 85°C when MR4[2:0] = b011. The device enables a 2°C temperature margin between the point when the device updates the MR4 value and the point when the controller reconfigures the system accordingly. When performing tight thermal coupling of the device to external hot spots, the maximum device temperature may be higher than indicated by MR4. To ensure proper operation when using the temperature sensor, consider the following: • TempGradient is the maximum temperature gradient experienced by the device at the temperature of interest over a range of 2°C. • ReadInterval is the time period between MR4 reads from the system. • TempSensorInterval (tTSI) is the maximum delay between the internal updates of MR4. • SysRespDelay is the maximum time between a read of MR4 and a response from the system. In order to determine the required frequency of polling MR4, the system uses the TempGradient and the maximum response time of the system in the following equation: 186 200b: x32 Mobile LPDDR4XSDRAM ZQ Calibration Table 120: Temperature Sensor Parameter Symbol Max/Min Value Unit TempGradient Max System Dependent °C/s ReadInterval Max System Dependent ms tTSI Max 32 ms System response delay SysRespDelay Max System Dependent ms Device temperature margin TempMargin Max 2 °C System temperature gradient MR4 read interval Temperature sensor interval For example, if TempGradient is 10°C/s and the SysRespDelay is 1ms: (10°C/s) x (ReadInterval + 32ms + 1ms) ≤ 2C In this case, ReadInterval shall be no greater than 167ms. Figure 127: Temperature Sensor Timing Temperature < [tTSI + ReadInterval + SysRespDelay] Device temperature margin ient Grad 2° p Tem MR4 trip level tTSI MR4 = 0x03 MR4 = 0x06 Temperature sensor update Host MR4 read MR4 = 0x06 MR4 = 0x06 ReadInterval MRR MR4 = 0x06 MR4 = 0x06 MR4 = 0x06 Time SysRespDelay MRR MR4 = 0x06 ZQ Calibration The MPC command is used to initiate ZQ calibration, which calibrates the output driver impedance and CA/DQ ODT impedance across process, temperature, and voltage. ZQ calibration occurs in the background of device operation and is designed to eliminate any need for coordination between channels (that is, it allows for channel independence). ZQ calibration is required each time that the PU-Cal value (MR3-OP[0]) is changed. Additional ZQ calibration commands may be required as the voltage and temperature change in the system environment. CA ODT values (MR11-OP[6:4]) and DQ ODT values (MR11-OP[2:0]) may be changed without performing ZQ calibration, as long as the PU-Cal value doesn’t change. 187 200b: x32 Mobile LPDDR4XSDRAM ZQ Calibration There are two ZQ calibration modes initiated with the MPC command: ZQCAL START and ZQCAL LATCH. ZQCAL START initiates the calibration procedure, and ZQCAL LATCH captures the result and loads it into the drivers. A ZQCAL START command may be issued anytime the device is not in a power-down state. A ZQCAL LATCH command may be issued anytime outside of power-down after tZQCAL has expired and all DQ bus operations have completed. The CA bus must maintain a deselect state during tZQLAT to allow CA ODT calibration settings to be updated. The DQ calibration value will not be updated until ZQCAL LATCH is performed and tZQLAT has been met. The following mode register fields that modify I/O parameters cannot be changed following a ZQCAL START command and before tZQCAL has expired: • • • • PU-Cal (pull-up calibration V OH point) PDDS (pull-down drive strength and Rx termination) DQ ODT (DQ ODT value) CA ODT (CA ODT value) ZQCAL Reset The ZQCAL RESET command resets the output impedance calibration to a default accuracy of ±30% across process, voltage, and temperature. This command is used to ensure output impedance accuracy to ±30% when ZQCAL START and ZQCAL LATCH commands are not used. The ZQCAL RESET command is executed by writing MR10-OP[0] = 1 B. Table 121: ZQ Calibration Parameters Parameter Symbol Min/Max Value Unit ZQCAL START to ZQCAL LATCH command interval tZQCAL MIN 1 μs ZQCAL LATCH to next valid command interval tZQLAT MIN MAX(30ns, 8nCK) ns ZQCAL RESET to next valid command interval tZQRESET MIN MAX(50ns, 3nCK) ns Figure 128: ZQCal Timing T0 T1 T2 T3 T4 T5 T6 T7 T8 Ta0 Ta1 Ta2 Ta3 Ta4 Ta5 Ta6 Ta7 Tb0 Tb1 Tb2 Tb3 Tb4 Tb5 Tb6 Tb7 Tc0 Tc1 Tc2 Tc3 Tc4 Valid Valid Tc5 Tc6 DES DES CK_c CK_t tZQLAT tZQCAL CA ZQCAL ZQCAL start start WR WR ZQCAL ZQCAL latch latch CAS CAS WL Command MPC train/cal DES DES WRITE CAS2 DES DES DES DES DES DES DES DES DES DES DES DES DES DES MPC train/cal DES DES DES DES PRECHARGE tDQSS DQS_t DQS_c tWPRE tWPST tDQS2DQ DQ[15:0] Transitioning Data Notes: Don’t Care 1. WRITE and PRECHARGE operations are shown for illustrative purposes. Any single or multiple valid commands may be executed within the tZQCAL time and prior to latching the results. 188 200b: x32 Mobile LPDDR4XSDRAM ZQ Calibration 2. Before the ZQCAL LATCH command can be executed, any prior commands that utilize the DQ bus must have completed. WRITE commands with DQ termination must be given enough time to turn off the DQ ODT before issuing the ZQCAL LATCH command. See the ODT section for ODT timing. Multichannel Considerations The device includes a single ZQ pin and associated ZQ calibration circuitry. Calibration values from this circuit will be used by both channels according to the following protocol: • The ZQCAL START command can be issued to either or both channels. • The ZQCAL START command can be issued when either or both channels are executing other commands, and other commands can be issued during tZQCAL. • The ZQCAL START command can be issued to both channels simultaneously. • The ZQCAL START command will begin the calibration unless a previously requested ZQ calibration is in progress. • If the ZQCAL START command is received while a ZQ calibration is in progress, the command will be ignored and the in-progress calibration will not be interrupted. • The ZQCAL LATCH command is required for each channel. • The ZQCAL LATCH command can be issued to both channels simultaneously. • The ZQCAL LATCH command will latch results of the most recent ZQCAL START command provided tZQCAL has been met. • ZQCAL LATCH commands that do not meet tZQCAL will latch the results of the most recently completed ZQ calibration. • The ZQRESET MRW commands will only reset the calibration values for the channel issuing the command. In compliance with complete channel independence, either channel may issue ZQCAL START and ZQCAL LATCH commands as needed without regard to the state of the other channel. ZQ External Resistor, Tolerance, and Capacitive Loading To use the ZQ calibration function, a 240 ohm, ±1% tolerance external resistor must be connected between the ZQ pin and V DDQ. If the system configuration shares the CA bus to form a x32 (or wider) channel, the ZQ pin of each die’s x16 channel must use a separate ZQCAL resistor. If the system configuration has more than one rank, and if the ZQ pins of both ranks are attached to a single resistor, then the SDRAM controller must ensure that the ZQCAL's don’t overlap. The total capacitive loading on the ZQ pin must be limited to 5pF. For example, if a system configuration shares a CA bus between n channels to form an n x16 wide bus, and no means are available to control the ZQCAL separately for each channel (that is, separate CS, CKE, or CK), then each x16 channel must have a separate ZQCAL resistor. For a x32, two-rank system, each x16 channel must have its own ZQCAL resistor, but the ZQCAL resistor can be shared between ranks on each x16 channel. In this configuration, the CS signal can be used to ensure that the ZQCAL commands for Rank[0] and Rank[1] don’t overlap. 189 200b: x32 Mobile LPDDR4XSDRAM Frequency Set Points Frequency Set Points Frequency set points enable the CA bus to be switched between two differing operating frequencies with changes in voltage swings and termination values, without ever being in an untrained state, which could result in a loss of communication to the device. This is accomplished by duplicating all CA bus mode register parameters, as well as other mode register parameters commonly changed with operating frequency. These duplicated registers form two sets that use the same mode register addresses, with read/write access controlled by MR bit FSP-WR (frequency set point write/read) and the operating point controlled by MR bit FSP-OP (frequency set point operation). Changing the FSP-WR bit enables MR parameters to be changed for an alternate frequency set-point without affecting the current operation. Once all necessary parameters have been written to the alternate set point, changing the FSP-OP bit will switch operation to use all of the new parameters simultaneously (within tFC), eliminating the possibility of a loss of communication that could be caused by a partial configuration change. Parameters which have two physical registers controlled by FSP-WR and FSP-OP include: Table 122: Mode Register Function with Two Physical Registers MR Number Operand MR1 OP[1:0] WR-PRE (Write preamble length) RD-PRE (Read preamble type) MR12 RD-PST (Read postamble length) RL (READ latency) OP[5:3] WL (WRITE latency) OP[6] WLS (WRITE latency set) OP[0] PU-CAL (Pull-up calibration point) OP[1] WR-PST(WRITE postamble length) PDDS (Pull-down drive strength) OP[6] DBI-RD (DBI-read enable) OP[7] DBI-WR (DBI-write enable) OP[2:0] DQ ODT (DQ bus receiver On-Die-Termination) OP[6:4] CA ODT (CA bus receiver On-Die-Termination) OP[5:0] VREF(CA) (VREF(CA) setting) OP[6] MR14 nWR (Write-recovery for auto precharge command) OP[2:0] OP[5:3] MR11 BL (Burst length) OP[3] OP[7] MR3 Notes OP[2] OP[6:4] MR2 Function OP[5:0] OP[6] VRCA (VREF(CA) range) VREF(DQ) (VREF(DQ) setting) VRDQ (VREF(DQ) range) 190 1 200b: x32 Mobile LPDDR4XSDRAM Frequency Set Points Table 122: Mode Register Function with Two Physical Registers (Continued) MR Number Operand MR22 OP[2:0] Function Notes SOC ODT (Controller ODT value for VOH calibration) OP[3] ODTE-CK (CK ODT enabled for non-terminating rank) OP[4] ODTE-CS (CS ODT enable for non-terminating rank) OP[5] ODTD-CA (CA ODT termination disable) 1. PU-CAL setting is required as the same value for both Ch.A and Ch.B before issuing ZQ Cal start command. See Mode Register Definition section for more details. Note: Table below shows how the two mode registers for each of the parameters above can be modified by setting the appropriate FSP-WR value, and how device operation can be switched between operating points by setting the appropriate FSP-OP value. The FSPWR and FSP-OP functions operate completely independently. Table 123: Relation Between MR Setting and DRAM Operation Function MR# and operand Data FSP-WR MR13 OP[6] 0 (Default) Data write to Mode Register N for FSP-OP[0] by MRW command. 1 Data write to Mode Register N for FSP-OP[1] by MRW command. FSP-OP MR13 OP[7] Notes: Operation Notes 0 (Default) DRAM operates with Mode Register N for FSP-OP[0] setting. 1 DRAM operates with Mode Register N for FSP-OP[1] setting. 1 2 1. FSP-WR stands for frequency set point write/read. 2. FSP-OP stands for frequency set point operating point. Frequency set point update Timing The frequency set point update timing is shown below. When changing the frequency set point via MR13 OP[7], the V RCG setting: MR13 OP[3] have to be changed into V REF fast response (high current) mode at the same time. After frequency change time (tFC) is satisfied. V RCG can be changed into normal operation mode via MR13 OP[3]. 191 200b: x32 Mobile LPDDR4XSDRAM Frequency Set Points Figure 129: Frequency Set Point Switching Timing . T0 T1 T2 T3 T4 T5 Ta0 Ta1 Tb0 Tb1 Tc0 Tc1 Tc2 Tc3 Tc4 Tc5 Tc6 CK_c CK_t Note 1 Frequency change tCKFSPE tVRCG_DISABLE tCKFSPX CKE CS CA DES Command DES MRW-1 MRW-1 MRW-2 MRW-2 FSP changes from 0 to 1 VRCG changes from normal to HIGH current DES DES DES DES DES MRW-1 MRW-1 MRW-2 MRW-2 DES DES DES DES DES DES VRCG changes from HIGH current tonormal DES tFC_short/middle/long Applicable mode register Mode register for FSP-OP0 Switching mode register Mode register for FSP-OP1 Don’t Care Note: 1. For frequency change during frequency set point switching, refer to input Clock Stop and Frequency Change section. Table 124: Frequency Set Point AC Timing 533 1066 1600 2133 2667 3200 3733 4267 Parameter Symbol Frequency set point switching time tFC_short MIN tFC_middle MIN tFC_long Valid clock requirement after entering FSP change tCKFSPE Valid clock requirement before first valid command after FSP change tCKFSPX Note: Data Rate Min/ Max Unit Notes 200 ns 1 200 ns MIN 250 ns MIN MAX(7.5ns, 4nCK) – MIN MAX(7.5ns, 4nCK) – 1. Frequency set point switching time depends on value of VREF(CA) setting: MR12 OP[5:0] and VREF(CA) range: MR12 OP[6] of FSP-OP 0 and 1. The details are shown in table below. Additionally change of frequency set point may affect VREF(DQ) setting. Settling time of VREF(DQ) level is the same as VREF(CA) level. Table 125: tFC Value Mapping Step Size Range Application From FSP-OP0 To FSP-OP1 From FSP -OP0 To FSP-OP1 tFC_short Base A single step size increment/decrement Base No change 192 200b: x32 Mobile LPDDR4XSDRAM Frequency Set Points Table 125: tFC Value Mapping (Continued) Step Size Range Application From FSP-OP0 To FSP-OP1 From FSP -OP0 To FSP-OP1 tFC_middle Base Two or more step size increment/decrement Base No change tFC_long – – Base Change 1. As well as change from FSP-OP1 to FSP-OP0. Note: Table 126: tFC Value Mapping VREF(ca) Setting: MR12: OP[5:0] VREF(ca) Range: MR12 OP[6] Application Notes tFC_short 1 tFC_middle 2 tFC_long 3 Case From/To FSP-OP: MR13 OP[7] 1 From 0 001100 0 To 1 001101 0 2 From 0 001100 0 To 1 001110 0 3 From 0 Don't Care 0 To 1 Don't Care 1 Notes: 1. A single step size increment/decrement for VREF(CA) setting value. 2. Two or more step size increment/decrement for VREF(CA) setting value. 3. VREF(CA) range is changed. In tis case changing VREF(CA) setting doesn’t affect tFC value. The LPDDR4-SDRAM defaults to FSP-OP[0] at power-up. Both set points default to settings needed to operate in un-terminated, low-frequency environments. To enable the device to operate at higher frequencies, Command bus training mode should be utilized to train the alternate frequency set point. See Command bus training section for more details on this training mode. 193 200b: x32 Mobile LPDDR4XSDRAM Frequency Set Points Figure 130: Training for Two Frequency Set Points Power-up/ Initialization Prepare for CA bus training of FSP1 for high frequency FSP-OP = 0 FSP-WR = 0 Freq. = Boot FSP-OP = 0 FSP-WR = 1 Freq. = Boot CA bus training, FSP-OP1 CKE High to Low FSP-WR = 1 Freq. = High CKE Low to High Exit CA bus training Switch to highspeed mode FSP-OP = 0 FSP-WR = 1 Freq. = Boot FSP-OP = 1 FSP-WR = 1 Freq. = High Prepare for CA bus training of FSP0 for medium frequency FSP-OP = 1 FSP-WR = 0 Freq. = High CKE High to Low CA bus training, FSP-OP0 Exit CA bus training FSP-WR = 0 Freq. = Medium FSP-OP = 1 FSP-WR = 0 Freq. = High CKE Low to High Operate at high speed Once both of the frequency set points have been trained, switching between points can be performed with a single MRW followed by waiting for time tFC. Figure 131: Example of Switching Between Two Trained Frequency Set Points State n-1: FSP-OP = 1 MRW command State n: FSP-OP = 0 Operate at high speed State n-1: FSP-OP = 0 MRW command State n: FSP-OP = 1 tFC Operate at medium speed Operate at high speed tFC Switching to a third (or more) set point can be accomplished if the memory controller has stored the previously-trained values (in particular the V REF(CA) calibration value) and rewrites these to the alternate set point before switching FSP-OP. 194 200b: x32 Mobile LPDDR4XSDRAM Pull-Up and Pull-Down Characteristics and Calibration Figure 132: Example of Switching to a Third Trained Frequency Set Point State n-1: FSP-WR = 1 MRW command State n: FSP-WR = 0 Operate at high speed State n-1: FSP-OP = 1 MRW command State n: FSP-OP = 0 MRW command {VREF(CA) CA ODT, DQ ODT, RL, WL, VREF(DQ), ODTD-CA...} tFC Operate at third speed tFC Pull-Up and Pull-Down Characteristics and Calibration Table 127: Pull-Down Driver Characteristics – ZQ Calibration RONPD,nom Register Min Nom Max Unit 40 Ohm RON40PD 0.90 1.0 1.10 RZQ/6 48 Ohm RON48PD 0.90 1.0 1.10 RZQ/5 60 Ohm RON60PD 0.90 1.0 1.10 RZQ/4 80 Ohm RON80PD 0.90 1.0 1.10 RZQ/3 120 Ohm RON120PD 0.90 1.0 1.10 RZQ/2 240 Ohm RON240PD 0.90 1.0 1.10 RZQ/1 1. All value are after ZQ calibration. Without ZQ calibration, RONPD values are ± 30%. Note: Table 128: Pull-Up Characteristics – ZQ Calibration VOHPU,nom VOH,nom Min Nom Max Unit VDDQ/2.5 440 0.90 1.0 1.10 VOH,nom VDDQ/3 367 0.90 1.0 1.10 VOH,nom Notes: 1. All value are after ZQ calibration. Without ZQ calibration, RONPD values are ± 30%. 2. VOH,nom (mV) values are based on a nominal VDDQ = 1.1V. Table 129: Valid Calibration Points ODT Value VOHPU 240 120 80 60 48 40 VDDQ/2.5 Valid Valid Valid DNU DNU DNU 195 200b: x32 Mobile LPDDR4XSDRAM On-Die Termination for the Command/Address Bus Table 129: Valid Calibration Points (Continued) ODT Value VOHPU 240 120 80 60 48 40 VDDQ/3 Valid Valid Valid Valid Valid Valid Notes: 1. Once the output is calibrated for a given VOH(nom) calibration point, the ODT value may be changed without recalibration. 2. If the VOH(nom) calibration point is changed, then recalibration is required. 3. DNU = Do not use. On-Die Termination for the Command/Address Bus The on-die termination (ODT) feature allows the device to turn on/off termination resistance for CK_t, CK_c, CS, and CA[5:0] signals without the ODT control pin. The ODT feature is designed to improve signal integrity of the memory channel by allowing the DRAM controller to turn on and off termination resistance for any target DRAM devices via the mode register setting. A simple functional representation of the DRAM ODT feature is shown below. Figure 133: ODT for CA RTT = VOUT |IOUT| VDD2 To other circuitry like RCV, ... ODT CA IOUT RTT VOUT VSS ODT Mode Register and ODT State Table ODT termination values are set and enabled via MR11. The CA bus (CK_t, CK_c, CS, CA[5:0]) ODT resistance values are set by MR11 OP[6:4]. The default state for the CA is ODT disabled. ODT is applied on the CA bus to the CK_t, CK_c, CS, and CA signals. The CA ODT of the device is designed to enable one rank to terminate the entire command bus in a multirank system, so only one termination load will be present even if multiple devices are 196 200b: x32 Mobile LPDDR4XSDRAM On-Die Termination for the Command/Address Bus sharing the command signals. For this reason, CA ODT remains on, even when the device is in the power-down or self refresh power-down state. The die has a bond pad (ODT_CA) for multirank operations. When the ODT_CA pad is LOW, the die will not terminate the CA bus regardless of the state of the mode register CA ODT bits (MR11 OP[6:4]). If, however, the ODT_CA bond pad is HIGH and the mode register CA ODT bits are enabled, the die will terminate the CA bus with the ODT values found in MR11 OP[6:4]. In a multirank system, the terminating rank should be trained first, followed by the non-terminating rank(s). Table 130: Command Bus ODT State CA ODT MR11[6:4] ODT_CA Bond Pad ODTD-CA MR22 OP[5] ODTE-CK MR22 OP[3] ODTE-CS MR22 OP[4] ODT State for CA ODT State for CK ODT State for CS Disabled1 Valid2 Valid3 Valid3 Valid3 Off Off Off 0 Valid3 0 0 Off Off Off Valid 3 Valid 3 0 Valid3 0 1 Off Off On Valid 3 0 Valid3 1 0 Off On Off Valid 3 0 Valid3 1 1 Off On On 0 Valid3 Valid3 On On On 1 Valid3 Valid3 Off On On Valid 3 Valid 3 1 1 Notes: 1. 2. 3. 4. Default value. Valid = H or L (a defined logic level) Valid = 0 or 1. The state of ODT_CA is not changed when the device enters power-down mode. This maintains termination for alternate ranks in multirank systems. ODT Mode Register and ODT Characteristics Table 131: ODT DC Electrical Characteristics – up to 3200 Mbps RZQ Ω ±1% over entire operating range after calibration MR11 OP[6:4] RTT VOUT 001b 010b 011b 100b Ω Ω Ω Ω Min Nom Max Unit Notes VOL(DC) = 0.1 × VDD2 0.8 1.0 1.1 RZQ/1 1, 2 VOM(DC) = 0.33 × VDD2 0.9 1.0 1.1 VOH(DC) = 0.5 × VDD2 0.9 1.0 1.2 RZQ/2 1, 2 RZQ/3 1, 2 RZQ/4 1, 2 VOL(DC) = 0.1 × VDD2 0.8 1.0 1.1 VOM(DC) = 0.33 × VDD2 0.9 1.0 1.1 VOH(DC) = 0.5 × VDD2 0.9 1.0 1.2 VOL(DC) = 0.1 × VDD2 0.8 1.0 1.1 VOM(DC) = 0.33 × VDD2 0.9 1.0 1.1 VOH(DC) = 0.5 × VDD2 0.9 1.0 1.2 VOL(DC) = 0.1 × VDD2 0.8 1.0 1.1 V OM(DC) = 0.33 × VDD2 0.9 1.0 1.1 VOH(DC) = 0.5 × VDD2 0.9 1.0 1.2 197 200b: x32 Mobile LPDDR4XSDRAM On-Die Termination for the Command/Address Bus Table 131: ODT DC Electrical Characteristics – up to 3200 Mbps (Continued) RZQ Ω ±1% over entire operating range after calibration MR11 OP[6:4] RTT VOUT 101b 110b Ω Ω Mismatch, CA -CA within clock group Notes: Min Nom Max Unit Notes VOL(DC) = 0.1 × VDD2 0.8 1.0 1.1 RZQ/5 1, 2 VOM(DC) = 0.33 × VDD2 0.9 1.0 1.1 VOH(DC) = 0.5 × VDD2 0.9 1.0 1.2 VOL(DC) = 0.1 × VDD2 0.8 1.0 1.1 RZQ/6 1, 2 VOM(DC) = 0.33 × VDD2 0.9 1.0 1.1 VOH(DC) = 0.5 × VDD2 0.9 1.0 1.2 0.33 × VDD2 – – 2 % 1, 2, 3 1. The tolerance limits are specified after calibration with stable temperature and voltage. To understand the behavior of the tolerance limits when voltage or temperature changes after calibration, see the section on voltage and temperature sensitivity. 2. Pull-down ODT resistors are recommended to be calibrated at 0.33 × VDD2. Other calibration points may be required to achieve the linearity specification shown above, e.g. calibration at 0.5 × VDD2 and 0.1 × VDD2. 3. CA to CA mismatch within clock group variation for a given component including CK_t, CK_c ,and CS (characterized). CA-to-CA mismatch = RODT (MAX) - RODT (MIN) RODT (AVG) Table 132: ODT DC Electrical Characteristics – Beyond 3200 Mbps RZQ Ω ±1% over entire operating range after calibration MR11 OP[6:4] RTT VOUT 001b 010b 011b 100b 101b Ω Ω Ω Ω Ω Min Nom Max Unit Notes RZQ/1 1, 2 RZQ/2 1, 2 RZQ/3 1, 2 RZQ/4 1, 2 RZQ/5 1, 2 VOL(DC) = 0.1 × VDD2 0.8 1.0 1.1 VOM(DC) = 0.33 × VDD2 0.9 1.0 1.1 VOH(DC) = 0.5 × VDD2 0.9 1.0 1.3 VOL(DC) = 0.1 × VDD2 0.8 1.0 1.1 VOM(DC) = 0.33 × VDD2 0.9 1.0 1.1 VOH(DC) = 0.5 × VDD2 0.9 1.0 1.3 VOL(DC) = 0.1 × VDD2 0.8 1.0 1.1 VOM(DC) = 0.33 × VDD2 0.9 1.0 1.1 VOH(DC) = 0.5 × VDD2 0.9 1.0 1.3 VOL(DC) = 0.1 × VDD2 0.8 1.0 1.1 V OM(DC) = 0.33 × VDD2 0.9 1.0 1.1 VOH(DC) = 0.5 × VDD2 0.9 1.0 1.3 VOL(DC) = 0.1 × VDD2 0.8 1.0 1.1 VOM(DC) = 0.33 × VDD2 0.9 1.0 1.1 VOH(DC) = 0.5 × VDD2 0.9 1.0 1.3 198 200b: x32 Mobile LPDDR4XSDRAM DQ On-Die Termination Table 132: ODT DC Electrical Characteristics – Beyond 3200 Mbps (Continued) RZQ Ω ±1% over entire operating range after calibration MR11 OP[6:4] RTT VOUT Ω 110b Min Nom Max Unit Notes VOL(DC) = 0.1 × VDD2 0.8 1.0 1.1 RZQ/6 1, 2 VOM(DC) = 0.33 × VDD2 0.9 1.0 1.1 VOH(DC) = 0.5 × VDD2 0.9 1.0 1.3 0.33 × VDD2 – – 2 % 1, 2, 3 Mismatch, CA -CA within clock group 1. The tolerance limits are specified after calibration with stable temperature and voltage. To understand the behavior of the tolerance limits when voltage or temperature changes after calibration, see the section on voltage and temperature sensitivity. 2. Pull-down ODT resistors are recommended to be calibrated at 0.33 × VDD2. Other calibration points may be required to achieve the linearity specification shown above, e.g. calibration at 0.5 × VDD2 and 0.1 × VDD2. 3. CA to CA mismatch within clock group variation for a given component including CK_t, CK_c ,and CS (characterized). Notes: CA-to-CA mismatch = RODT (MAX) - RODT (MIN) RODT (AVG) ODT for CA Update Time Figure 134: ODT for CA Setting Update Timing in 4-Clock Cycle Command T0 T1 T2 T3 T4 T5 Ta Ta1 Ta2 Ta3 Ta4 Ta5 Ta6 Ta7 Ta8 DES MRW1 MRW1 MRW2 MRW2 DES DES DES DES DES Valid 1 Valid 1 Valid 1 Valid 1 Valid Valid Valid Valid Valid Valid Valid Valid Valid Valid CK_c CK_t CKE CS_n Command CA[5:0] CA ODT Old setting value Updating setting New setting value tODTUP Don’t Care DQ On-Die Termination On-die termination (ODT) is a feature that allows the device to turn on/off termination resistance for each DQ, DQS, and DMI signal without the ODT control pin. The ODT feature is designed to improve signal integrity of the memory channel by allowing the 199 200b: x32 Mobile LPDDR4XSDRAM DQ On-Die Termination DRAM controller to turn on and off termination resistance for any target DRAM devices during WRITE or MASK WRITE operation. The ODT feature is off and cannot be supported in power-down and self refresh modes. The switch is enabled by the internal ODT control logic, which uses the WRITE-1 or MASK WRITE-1 command and other mode register control information. The value of RTT is determined by the MR bits. RTT = VOUT |IOUT| Figure 135: Functional Representation of DQ ODT VDDQ To other circuitry like RCV, ... ODT DQ IOUT VOUT RTT VSSQ Table 133: ODT DC Electrical Characteristics – up to 3200 Mbps RZQ Ω ±1% over entire operating range after calibration MR11 OP[2:0] RTT VOUT 001b 010b 011b 100b 101b Ω Ω Ω Ω Ω Min Nom Max Unit Notes VOL(DC) = 0.1 × VDDQ 0.8 1.0 1.1 RZQ/1 1, 2 VOM(DC) = 0.33 × VDDQ 0.9 1.0 1.1 VOH(DC) = 0.5 × VDDQ 0.9 1.0 1.2 RZQ/2 1, 2 RZQ/3 1, 2 RZQ/4 1, 2 RZQ/5 1, 2 VOL(DC) = 0.1 × VDDQ 0.8 1.0 1.1 VOM(DC) = 0.33 × VDDQ 0.9 1.0 1.1 VOH(DC) = 0.5 × VDDQ 0.9 1.0 1.2 VOL(DC) = 0.1 × VDDQ 0.8 1.0 1.1 VOM(DC) = 0.33 × VDDQ 0.9 1.0 1.1 VOH(DC) = 0.5 × VDDQ 0.9 1.0 1.2 VOL(DC) = 0.1 × VDDQ 0.8 1.0 1.1 V OM(DC) = 0.33 × VDDQ 0.9 1.0 1.1 VOH(DC) = 0.5 × VDDQ 0.9 1.0 1.2 VOL(DC) = 0.1 × VDDQ 0.8 1.0 1.1 VOM(DC) = 0.33 × VDDQ 0.9 1.0 1.1 VOH(DC) = 0.5 × VDDQ 0.9 1.0 1.2 200 200b: x32 Mobile LPDDR4XSDRAM DQ On-Die Termination Table 133: ODT DC Electrical Characteristics – up to 3200 Mbps (Continued) RZQ Ω ±1% over entire operating range after calibration MR11 OP[2:0] RTT VOUT 110b Ω Mismatch error, DQ-to-DQ within a channel Notes: Min Nom Max Unit Notes VOL(DC) = 0.1 × VDDQ 0.8 1.0 1.1 RZQ/6 1, 2 VOM(DC) = 0.33 × VDDQ 0.9 1.0 1.1 VOH(DC) = 0.5 × VDDQ 0.9 1.0 1.2 0.33 × VDDQ – – 2 % 1, 2, 3 1. The ODT tolerance limits are specified after calibration with stable temperature and voltage. To understand the behavior of the tolerance limits when voltage or temperature changes after calibration, see the following section on voltage and temperature sensitivity. 2. Pull-down ODT resistors are recommended to be calibrated at 0.33 × VDDQ. Other calibration points may be required to achieve the linearity specification shown above, (i.e., calibration at 0.5 × VDDQ and -0.1 × VDDQ. 3. DQ-to-DQ mismatch within byte variation for a given component, including DQS (characterized). DQ-to-DQ mismatch= RODT (MAX) - RODT (MIN) RODT (AVG) Table 134: ODT DC Electrical Characteristics – Beyond 3200 Mbps RZQ Ω ±1% over entire operating range after calibration MR11 OP[2:0] RTT VOUT 001b 010b 011b 100b 101b 110b Ω Ω Ω Ω Ω Ω Min Nom Max Unit Notes VOL(DC) = 0.1 × VDDQ 0.8 1.0 1.1 RZQ/1 1, 2 VOM(DC) = 0.33 × VDDQ 0.9 1.0 1.1 VOH(DC) = 0.5 × VDDQ 0.9 1.0 1.3 VOL(DC) = 0.1 × VDDQ 0.8 1.0 1.1 RZQ/2 1, 2 VOM(DC) = 0.33 × VDDQ 0.9 1.0 1.1 VOH(DC) = 0.5 × VDDQ 0.9 1.0 1.3 RZQ/3 1, 2 RZQ/4 1, 2 RZQ/5 1, 2 RZQ/6 1, 2 VOL(DC) = 0.1 × VDDQ 0.8 1.0 1.1 VOM(DC) = 0.33 × VDDQ 0.9 1.0 1.1 VOH(DC) = 0.5 × VDDQ 0.9 1.0 1.3 VOL(DC) = 0.1 × VDDQ 0.8 1.0 1.1 V OM(DC) = 0.33 × VDDQ 0.9 1.0 1.1 VOH(DC) = 0.5 × VDDQ 0.9 1.0 1.3 VOL(DC) = 0.1 × VDDQ 0.8 1.0 1.1 VOM(DC) = 0.33 × VDDQ 0.9 1.0 1.1 VOH(DC) = 0.5 × VDDQ 0.9 1.0 1.3 VOL(DC) = 0.1 × VDDQ 0.8 1.0 1.1 VOM(DC) = 0.33 × VDDQ 0.9 1.0 1.1 VOH(DC) = 0.5 × VDDQ 0.9 1.0 1.3 201 200b: x32 Mobile LPDDR4XSDRAM DQ On-Die Termination Table 134: ODT DC Electrical Characteristics – Beyond 3200 Mbps (Continued) RZQ Ω ±1% over entire operating range after calibration MR11 OP[2:0] RTT VOUT Mismatch error, DQ-to-DQ within a channel Notes: 0.33 × VDDQ Min Nom Max Unit Notes – – 2 % 1, 2, 3 1. The ODT tolerance limits are specified after calibration with stable temperature and voltage. To understand the behavior of the tolerance limits when voltage or temperature changes after calibration, see the following section on voltage and temperature sensitivity. 2. Pull-down ODT resistors are recommended to be calibrated at 0.33 × VDDQ. Other calibration points may be required to achieve the linearity specification shown above, (i.e., calibration at 0.5 × VDDQ and -0.1 × VDDQ. 3. DQ-to-DQ mismatch within byte variation for a given component, including DQS (characterized). DQ-to-DQ mismatch= RODT (MAX) - RODT (MIN) RODT (AVG) Output Driver and Termination Register Temperature and Voltage Sensitivity When temperature and/or voltage change after calibration, the tolerance limits are widen according to the tables below. Table 135: Output Driver and Termination Register Sensitivity Definition Resistor Definition Point Min Max Unit Notes RONPD 0.33 × VDDQ 90 - (dRONdT x |ΔT|) - (dRONdV x |ΔV|) 110 + (dRONdT x |ΔT|) + (dRONdV x |ΔV|) % 1, 2 VOHPU 0.33 × VDDQ 90 - (dVOHdT x |ΔT|) - (dVOHdV x |ΔV|) 110 + (dVOHdT x |ΔT|) + (dVOHdV x |ΔV|) 1, 2, 5 RTT(I/O) 0.33 × VDDQ 90 - (dRONdT x |ΔT|) - (dRONdV x |ΔV|) 110 + (dRONdT x |ΔT|) + (dRONdV x |ΔV|) 1, 2, 3 RTT(IN) 0.33 × VDD2 90 - (dRONdT x |ΔT|) - (dRONdVx |ΔV|) 110 + (dRONdT x |ΔT|) + (dRONdV x |ΔV|) 1, 2, 4 Notes: 1. ΔT = T - T(@calibration), ΔV = V - V(@calibration) 2. dRONdT, dRONdV, dVOHdT, dVOHdV, dRTTdV, and dRTTdT are not subject to production test but are verified by design and characterization. 3. This parameter applies to input/output pin such as DQS, DQ, and DMI. 4. This parameter applies to input pin such as CK, CA, and CS. 5. Refer to Pull-up/Pull-down Driver Characteristics for VOHPU. Table 136: Output Driver and Termination Register Temperature and Voltage Sensitivity Symbol Parameter Min Max Unit 0.75 %/˚C dRONdT RON temperature sensitivity 0 dRONdV RON voltage sensitivity 0 0.20 %/mV dVOHdT VOH temperature sensitivity 0 0.75 %/˚C dVOHdV VOH voltage sensitivity 0 0.35 %/mV dRTTdT RTT temperature sensitivity 0 0.75 %/˚C 202 200b: x32 Mobile LPDDR4XSDRAM DQ On-Die Termination Table 136: Output Driver and Termination Register Temperature and Voltage Sensitivity (Continued) Symbol dRTTdV Parameter Min Max Unit 0 0.20 %/mV RTT voltage sensitivity ODT Mode Register The ODT mode is enabled if MR11 OP[2:0] are non-zero. In this case, the value of RTT is determined by the settings of those bits. The ODT mode is disabled if MR11 OP[2:0] = 0. Asynchronous ODT When ODT mode is enabled in MR11 OP[2:0], DRAM ODT is always High-Z. The DRAM ODT feature is automatically turned ON asynchronously after a WRITE-1, MASK WRITE-1, or MPC (FIFO WRITE) command. After the burst write is complete, the DRAM ODT turns OFF asynchronously. The DQ bus ODT control is automatic and will turn the ODT resistance on/off if DQ ODT is enabled in the mode register. The following timing parameters apply when the DQ bus ODT is enabled: • ODTLon, tODTon,min, tODTon,max • ODTLoff, tODToff,min, tODToff,max ODTLON is a synchronous parameter and is the latency from a CAS-2 command to the tODTon reference. ODTL ON latency is a fixed latency value for each speed bin. Each speed bin has a different ODTLON latency. Minimum RTT turn-on time ( tODTon,min) is the point in time when the device termination circuit leaves High-Z and ODT resistance begins to turn on. Maximum RTT turn on time ( tODTon,max) is the point in time when the ODT resistance is fully on. tODTon,min and tODTon,max are measured once ODTLon latency is satisfied from CAS-2 command. ODTLOFF is a synchronous parameter and it is the latency from CAS-2 command to tODToff reference. ODTL OFF latency is a fixed latency value for each speed bin. Each speed bin has a different ODTLOFF latency. Minimum RTT turn-off time ( tODToff,min) is the point in time when the device termination circuit starts to turn off the ODT resistance. Maximum ODT turn off time ( tODToff,max) is the point in time when the on-die termination has reached High-Z. tODToff,min and tODToff,max are measured once ODTLoff latency is satisfied from CAS-2 command. 203 200b: x32 Mobile LPDDR4XSDRAM DQ On-Die Termination Table 137: ODTLON and ODTLOFF Latency Values ODTLON Latency1 WL Set A (nCK) WL Set B (nCK) WL Set A (nCK) WL Set B (nCK) Lower Frequency Limit (>) (MHz) N/A N/A N/A N/A 10 266 N/A N/A N/A N/A 266 533 N/A 6 N/A 22 533 800 4 12 20 28 800 1066 4 14 22 32 1066 1333 6 18 24 36 1333 1600 6 20 26 40 1600 1866 8 24 28 44 1866 2133 tWPRE = 2 tCK ODTLOFF Latency2 Upper Frequency Limit (≤ ≤) (MHz) 1. ODTLON is referenced from CAS-2 command. 2. ODTLOFF as shown in table assumes BL = 16. For BL32, 8 tCK should be added. Notes: Figure 136: Asynchronous ODTon/ODToff Timing T0 T1 T2 T3 BL BA0, CA, AP CAn CAn T4 Ta0 Ta1 Ta2 Ta3 Ta4 Ta5 Ta6 Ta7 Ta8 Ta9 Ta10 Ta11 Ta12 Ta13 Ta14 Ta15 Ta16 DES DES DES DES DES DES DES DES DES DES DES DES DES DES DES DES DES Ta17 Ta18 Ta19 Ta20 Ta21 DES DES CK_c CK_t CS CA Command WRITE-1 CAS-2 DES DES DES DES WL t DQSS(MIN) t WPRE t DQS_c WPST DQS_t t DQ DMI Din n0 t DQS2DQ Din Din n1 n2 Din n3 Din n4 Din n5 Din n6 Din Din n7 n8 Din n9 Din Din Din Din Din Din n10 n11 n12 n13 n14 n15 DQSS(MAX) t WPRE t WPST DQS_c DQS_t t DQ DMI Din n0 t ODTLon t DRAM RTT DQS2DQ Din Din n1 n2 Din n3 Din n4 Din n5 Din n6 Din n9 Din Din Din Din Din Din n10 n11 n12 n13 n14 n15 t t ODTon(MIN) ODT High-Z Din Din n7 n8 ODTon(MAX) ODToff(MIN) ODTL On Transition ODToff(MAX) Transition ODT High-Z ODTLoff Don’t Care Notes: 1. BL=16, Write postamble = 0.5nCK, DQ/DQS: VSSQ termination 2. Din n = data-in to column.n 204 200b: x32 Mobile LPDDR4XSDRAM DQ On-Die Termination 3. DES commands are shown for ease of illustration; other commands may be valid at these times. DQ ODT During Power-Down and Self Refresh Modes DQ bus ODT will be disabled in power-down mode. In self refresh mode, the ODT will be turned off when CKE is LOW but will be enabled if CKE is HIGH and DQ ODT is enabled in the mode register. ODT During Write Leveling Mode If ODT is enabled in MR11 OP[2:0] in write leveling mode, the device always provides the termination on DQS signals. DQ termination is always off in write leveling mode. Table 138: Termination State in Write Leveling Mode DQS Termination DQ[15:0]/DMI[1:0] Termination Disabled Off Off Enabled On Off ODT State in MR11 OP[2:0] 205 200b: x32 Mobile LPDDR4XSDRAM TRR Mode – Target Row Refresh TRR Mode – Target Row Refresh The device limits the number of times that a given row can be accessed within a refresh period (tREFW x 2) prior to requiring adjacent rows to be refreshed. The maximum activate count (MAC) is the maximum number of activates that a single row can sustain within a refresh period before the adjacent rows need to be refreshed. The row receiving the excessive actives is the target row (TRn), the adjacent rows to be refreshed are the victim rows. When the MAC limit is reached on TRn, either the device receives all (R x 2) REFRESH commands before another row activate is issued, or the device should be placed into targeted row refresh (TRR) mode. The TRR mode will refresh the rows adjacent to the TRn that encountered tMAC limit. If the device supports unlimited MAC value: MR24 OP[2:0] = 000 and MR24 OP[3] = 1, TARGET ROW REFRESH operation is not required. Even though the device allows to set MR24 OP[7] = 1: TRR mode enable, in this case the device behavior is vendor specific. For example, a certain device may ignore MRW command for entering/exiting TRR mode or a certain device may support commands related TRR mode. See vendor device datasheets for details about TRR mode definition at supporting unlimited MAC value case. There could be a maximum of two target rows to a victim row in a bank. The cumulative value of the activates from the two target rows on a victim row in a bank should not exceed MAC value. MR24 fields are required to support the new TRR settings. Setting MR24 OP[7] = 1 enables TRR mode and setting MR24 OP[7] = 0 disables TRR mode. MR24 OP[6:4] defines which bank (BAn) the target row is located in (refer to MR24 table for details). The TRR mode must be disabled during initialization as well as any other device calibration modes. The TRR mode is entered from a DRAM idle state, once TRR mode has been entered, no other mode register commands are allowed until TRR mode is completed; however, setting MR24 OP[7] = 0 to interrupt and reissue the TRR mode is allowed. When enabled, TRR mode is self-clearing. the mode will be disabled automatically after the completion of defined TRR flow (after the third BAn precharge has completed plus tMRD). Optionally, the TRR mode can also be exited via another MRS command at the completion of TRR by setting MR24 OP[7] = 0. If the TRR is exited via another MRS command, the value written to MR24 OP[6:4] are "Don’t Care". TRR Mode Operation 1. The timing diagram depicts TRR mode. The following steps must be performed when TRR mode is enabled. This mode requires all three ACT (ACT1, ACT2, and ACT3) and three corresponding PRE commands (PRE1, PRE2, and PRE3) to complete TRR mode. PRECHARGE All (PREA) commands issued while the device is in TRR mode will also perform precharge to BAn and counts towards PREn command. 2. Prior to issuing the MRW command to enter TRR mode, the device should be in the idle state. MRW command must be issued with MR24 OP[7] = 1 and MR24 OP[6:4] defining the bank in which the targeted row is located. All other MR24 bits should remain unchanged. 3. No activity is to occur with the device until tMRD has been satisfied. Once tMRD has been satisfied, the only commands allowed BAn, until TRR mode has completed, are ACT and PRE. 206 200b: x32 Mobile LPDDR4XSDRAM TRR Mode – Target Row Refresh 4. The first ACT to the BAn with the TRn address can now be applied; no other command is allowed at this point. All other banks must remain inactive from when the first BAn ACT command is issued until [(1.5 x tRAS) + tRP] is satisfied. 5. After the first ACT to the BAn with the TRn address is issued, PRE to BAn is to be issued (1.5 x tRAS) later; and then followed tRP later by the second ACT to the BAn with the TRn address. 6. After the second ACT to the BAn with the TRn address is issued, PRE to BAn is to be issued tRAS later and then followed tRP later by the third ACT to the BAn with the TRn address. 7. After the third ACT to the BAn with the TRn address is issued, PRE to BAn would be issued tRAS later. TRR mode is completed once tRP plus tMRD is satisfied. 8. TRR mode must be completed as specified to guarantee that adjacent rows are refreshed. Anytime the TRR mode is interrupted and not completed, the interrupted TRR mode must be cleared and then subsequently performed again. To clear an interrupted TRR mode, MR24 change is required with setting MR24 OP[7] = 0, MR24 OP[6:4] are "Don’t care", followed by three PRE to BAn, with tRP time in between each PRE command. The complete TRR sequence (steps 2-7) must be then reissued and completed to guarantee that the adjacent rows are refreshed. 9. A REFRESH command to the device, or entering self refresh mode, is not allowed while the device is in TRR mode. Figure 137: Target Row Refresh Mode T1 T0 T2 T3 Ta0 Ta1 Ta2 Ta3 Tb0 Tb1 Tc0 Tc1 Tc2 Tc3 Td0 Td1 Td2 Td3 Te0 Te1 Tf0 Tf1 Tf2 Tf3 Tg0 Tg1 Tg2 Tg3 Th0 Th1 Th2 Th3 Tk0 Tk1 Tk2 Tm0 Tm1 Tm2 Tm3 Tm4 Tm5 CK_c CK_t CKE CS ACT1 Command MRW-1 MRW-2 DES PRE1 ACT-2 ACT-1 1st ACT TRR entry N/A N/A N/A N/A N/A BAn N/A N/A Address OP MA OP OP TRn TRn TRn TRn tMRD BAn BAn in idle ACT-1 PRE2 ACT-2 DES CMD-1 CMD-2 2nd ACT BAn N/A BAn N/A N/A V Non BAn N/A N/A TRn TRn TRn TRn V V tRP DES PRE ACT3 DES CMD-1 CMD-2 DES V N/A BAn V Non BAn V V V N/A N/A V V V CMD-1 CMD-2 N/A BAn N/A N/A V Non BAn V TRn TRn TRn TRn V V 9 BAn TRR operation allowed DES PRE V V N/A BAn V V N/A N/A tRAS Activity allowed No activity allowed in other banks (Banks closed) DES DES CMD-2 CMD-1 DES 3rd PRE V t RP No activity allowed (Banks closed) DES 3rd ACT V tRAS PRE3 ACT-2 ACT-1 2nd PRE N/A 1.5 x tRAS Non BAn in idle ACT2 DES PRE 1st PRE Bank Address Non BAn DES tRP V Any BAn V V V V V V + tMRD No activity allowed (may have bank(s) open) Activity allowed Activity allowed Don’t Care Notes: 1. TRn is the targeted row. 2. Bank BAn represents the bank in which the targeted row is located. 3. TRR mode self-clears after tMRD + tRP measured from the third BAn precharge PRE3 at clock edge Th4. 4. TRR mode or any other activity can be re-engaged after tRP + tMRD from the third BAn precharge PRE3. PRE_ALL also counts if it is issued instead of PREn. TRR mode is cleared by the device after PRE3 to the BAn bank. 5. ACTIVATE commands to BAn during TRR mode do not provide refresh support (the refresh counter is unaffected). 6. The device must restore the degraded row(s) caused by excessive activation of the targeted row (TRn) necessary to meet refresh requirements. 7. A new TRR mode must wait tMRD + tRP time after the third precharge. 8. BAn may not be used with any other command. 9. ACT and PRE are the only allowed commands to BAn during TRR mode. 10. REFRESH commands are not allowed during TRR mode. 207 200b: x32 Mobile LPDDR4XSDRAM Post-Package Repair 11. All timings are to be met by DRAM during TRR mode, such as tFAW. Issuing ACT1, ACT2, and ACT3 counts towards tFAW budget. Post-Package Repair The device has fail row address repair as an optional post-package repair (PPR) feature and it is readable through MR25 OP[7:0]. PPR provides simple and easy repair method in the system and fail row address can be repaired by the electrical programming of Electrical-fuse scheme. The device can correct one row per bank with PPR. Electrical-fuse cannot be switched back to un-fused states once it is programmed. The controller should prevent unintended PPR mode entry and repair. Failed Row Address Repair 1. 2. 3. 4. 5. 6. 7. 8. Before entering PPR mode, all banks must be precharged. Enable PPR using MR4 OP[4] = 1 and wait tMRD. Issue ACT command with fail row address. Wait tPGM to allow the device repair target row address internally then issue PRECHARGE Wait tPGM_EXIT after PRECHARGE, which allows the device to recognize repaired row address RAn. Exit PPR mode with setting MR4 OP[4] = 0. The device is ready for any valid command after tPGMPST. In more than one fail address repair case, repeat step 2 to 7. Once PPR mode is exited, to confirm whether the target row has correctly repaired, the host can verify the repair by writing data into the target row and reading it back after PPR exit with MR4 OP[4] = 0 and tPGMPST. The following timing diagram shows PPR operation. 208 200b: x32 Mobile LPDDR4XSDRAM Post-Package Repair Figure 138: Post-Package Repair Timing T0 T1 T2 T3 T4 T5 Ta0 Ta1 Ta2 Ta3 Ta4 Ta5 Ta6 Tb0 Tb1 Tb2 Tb3 Tb4 Tc0 Tc1 Tc2 Tc3 Tc4 Tc5 Td0 Td1 Td2 Td3 Td4 Td5 CK_c CK_t CKE CS Command DES MR WRITE-1 MR WRITE-2 DES BA Address PPR staus ACT-1 ACT-2 DES PRE DES DES Any command MR WRITE-1 MR WRITE-2 DES Any command N/A N/A N/A N/A Valid BA Valid Valid Valid Valid N/A N/A N/A N/A Valid Valid Valid Valid MA OP RAn RAn RAn RAn Valid Valid OP MA OP Valid Valid Valid Valid OP OP Normal mode (All banks must be idle) Move to PPR mode PPR repair t MRD OP Move to PPR mode PPR recognition t PGM t PGM_Exit Normal mode t PGMPST Don’t Care Notes: 1. 2. 3. 4. During tPGM, any other commands (including refresh) are not allowed on each die. With one PPR command, only one row can be repaired at one time per die. When PPR procedure completes, reset procedure is required before normal operation. During PPR, memory contents are not refreshed and may be lost. Table 139: Post-Package Repair Timing Parameters Parameter PPR programming time PPR exit time New address setting time Symbol Min Max Units tPGM 1000 – ms tPGM_EXIT 15 – ns tPGMPST 50 – μs 209 200b: x32 Mobile LPDDR4XSDRAM Read Preamble Training Read Preamble Training Read preamble training is supported through the MPC function. This mode can be used to train or read level the DQS receivers. Once read preamble training is enabled by MR13 OP[1] = 1, the device will drive DQS_t LOW and DQS_c HIGH within tSDO and remain at these levels until an MPC DQ READ CALIBRATION command is issued. During read preamble training, the DQS preamble provided during normal operation will not be driven by the device. Once the MPC DQ READ CALIBRATION command is issued, the device will drive DQS_t/DQS_c and DQ like a normal READ burst after RL and tDQSCK. Prior to the MPC DQ READ CALIBRATION command, the device may or may not drive DQ[15:0] in this mode. While in read preamble training mode, only READ DQ CALIBRATION commands may be issued. • Issue an MPC [RD DQ CALIBRATION] command followed immediately by a CAS-2 command. • Each time an MPC [RD DQ CALIBRATION] command followed by a CAS-2 is received by the device, a 16-bit data burst will, after the currently set RL, drive the eight bits programmed in MR32 followed by the eight bits programmed in MR40 on all I/O pins. • The data pattern will be inverted for I/O pins with a 1 programmed in the corresponding invert mask mode register bit. • Note that the pattern is driven on the DMI pins, but no data bus inversion function is enabled, even if read DBI is enabled in the DRAM mode register. • This command can be issued every tCCD seamlessly. • The operands received with the CAS-2 command must be driven LOW. Read preamble training is exited within tSDO after setting MR13 OP[1] = 0. The device supports the READ preamble Training as optional feature. Refer to vendor specific datasheets. Figure 139: Read Preamble Training T0 T1 T2 T3 Ta6 T4 Ta0 Ta1 Ta2 Ta3 DES DES DES MPC-1 RD Cal MPC-1 RD Cal CAS-2 CAS-2 DES Ta4 Ta5 Tb0 Tb1 Tc0 Tc1 DES DES Tc2 Tc3 Tc4 Td1 Td0 Td2 Td3 Td4 Td5 Te0 Te1 CK_c CK_t CS Command MRW-1 MRW-1 MRW-2 MRW-2 t DES DES t RL SDO DES DES DES DES MRW-1 MRW-1 MRW-2 MRW-2 DES t DQSCK Read preamble training mode = Enable: MR13[OP1] = 1 DES DES SDO Read preamble training mode = Enable: MR13[OP1] = 0 DQS_c DQS_t t DQ DMI DQSQ Dout Dout Dout Dout Dout Dout n0 n1 n12 n13 n14 n15 DQ (High-Z or Driven ) DQ (High-Z or Driven ) Don’t Care Note: 1. Read DQ calibration supports only BL16 operation. 210 200b: x32 Mobile LPDDR4XSDRAM Electrical Specifications Electrical Specifications Absolute Maximum Ratings Stresses greater than those listed in the table below may cause permanent damage to the device. This is a stress rating only, and functional operation of the device at these conditions, or any other conditions outside those indicated in the operational sections of this document, is not implied. Exposure to absolute maximum rating conditions for extended periods may adversely affect reliability. Table 140: Absolute Maximum DC Ratings Parameter Symbol Min Max Unit Notes VDD1 –0.4 2.1 V 1 VDD2 supply voltage relative to VSS VDD2 –0.4 1.5 V 1 VDDQ supply voltage relative to VSS VDDQ –0.4 1.5 V 1 Voltage on any ball relative to VSS VIN, VOUT –0.4 1.5 V TSTG –55 125 ˚C VDD1 supply voltage relative to VSS Storage temperature Notes: 2 1. For information about relationships between power supplies, see the Voltage Ramp and Device Initialization section. 2. Storage temperature is the case surface temperature on the center/top side of the device. For measurement conditions, refer to the JESD51-2 standard. AC and DC Operating Conditions Operation or timing that is not specified is illegal. To ensure proper operation, the device must be initialized properly. Table 141: Recommended DC Operating Conditions Symbol Min Typ Max DRAM Unit Notes VDD1 1.7 1.8 1.95 Core 1 power V 1, 2 VDD2 1.06 1.1 1.17 Core 2 power/Input buffer power V 1, 2, 3 VDDQ 0.57 0.60 0.65 I/O buffer power V 2, 3 Notes: 1. VDD1 uses significantly less power than VDD2. 2. The voltage range is for DC voltage only. DC voltage is the voltage supplied at the DRAM and is inclusive of all noise up to 20 MHz at the DRAM package ball. 3. The voltage noise tolerance from DC to 20 MHz exceeding a peak-to-peak tolerance of 45mV at the DRAM ball is not included in the TdIVW. 211 200b: x32 Mobile LPDDR4XSDRAM AC and DC Operating Conditions Table 142: Input Leakage Current Parameter/Condition Symbol Min Max Unit Notes IL –2 2 μA 1, 2 Input leakage current Notes: 1. For CK_t, CK_c, CKE, CS, CA, ODT_CA and RESET_n. Any input 0V ≤ VIN ≤ VDD2. (All other pins not under test = 0V. 2. CA ODT is disabled for CK_t, CK_c, CS, and CA. Table 143: Input/Output Leakage Current Parameter/Condition Symbol Min Max Unit Notes IOZ –5 5 μA 1, 2 Input/Output leakage current Notes: 1. For DQ, DQS_t, DQS_c and DMI. Any I/O 0V ≤ VOUT ≤ VDDQ. 2. I/Os status are disabled: High Impedance and ODT off. Table 144: Operating Temperature Range Parameter/Condition Standard Symbol Min Max Unit TOPER 0 85 ˚C 85 105 ˚C Elevated Notes: 1. Operating temperature is the case surface temperature at the center of the top side of the device. For measurement conditions, refer to the JESD51-2 standard. 2. When using the device in the elevated temperature range, some derating may be required. See Mode Registers for vendor-specific derating. 3. Either the device case temperature rating or the temperature sensor can be used to set an appropriate refresh rate, determine the need for AC timing derating, and/or monitor the operating temperature (see Temperature Sensor). When using the temperature sensor, the actual device case temperature may be higher than the TOPER rating that applies for the standard or elevated temperature range. For example, TCASE could be above +85˚C when the temperature sensor indicates a temperature of less than +85˚C. 212 200b: x32 Mobile LPDDR4XSDRAM AC and DC Input Measurement Levels AC and DC Input Measurement Levels Input Levels for CKE Table 145: Input Levels Parameter Symbol Min Max Unit Notes Input high level (AC) VIH (AC) 0.75 × VDD2 (or VDDQ ) VDD2 (or VDDQ) + 0.2 V 1 Input low level (AC) VIL (AC) –0.2 0.25 × VDD2 (or VDDQ) V 1 Input high level (DC) VIH (DC) 0.65 × VDD2 (or VDDQ ) VDD2 (or VDDQ) + 0.2 V Input low level (DC) VIL(DC) –0.2 0.35 × VDD2 (or VDDQ) V 1. See the AC Overshoot and Undershoot section. Note: Figure 140: AC Input Timing Definition VIH(AC) VIH(DC) VIL(AC) VIL(DC) Input level Don’t Care Differential Input Voltage for CK The minimum input voltage needs to satisfy both V indiff_CK and V indiff_CK/2 specification at input receiver and their measurement period is 1tCK. V indiff_CK is the peak to peak voltage centered on 0 volts differential and V indiff_CK/2 is maximum and minimum peak voltage from 0 volts. 0.0 Vindiff_CK Vindiff_CK/2 Peak voltage Vindiff_CK/2 Differential Input Voltage : CK_t - CK_c Figure 141: CK Differential Input Voltage Peak voltage Time 213 200b: x32 Mobile LPDDR4XSDRAM AC and DC Input Measurement Levels Table 146: CK Differential Input Voltage 1600/1867 2133/2400/3200 3733/4267 Parameter Symbol Min Max Min Max Min Max Unit Note CK differential input voltage Vindiff_CK 420 – 380 – 360 – mV 1 1. The peak voltage of Differential CK signals is calculated in a following equation. Note: • • • • Vindiff_CK = (Maximum peak voltage) - (Minimum peak voltage) Maximum peak voltage = Max(f(t)) Minimum peak voltage = Min(f(t)) f(t) = VCK_t - VCK_c Peak Voltage Calculation Method The peak voltage of differential clock signals are calculated in a following equation. • VIH.DIFF.peak voltage = Max(f(t)) • VIL.DIFF.peak voltage = Min(f(t)) • f(t) = V CK_t - V CK_c Figure 142: Definition of Differential Clock Peak Voltage Single Ended Input Voltage CK_t Min(f(t)) Max(f(t)) VREF(CA) CK_c Time Note: 1. VREF(CA) is device internal setting value by VREF training. Single-Ended Input Voltage for Clock The minimum input voltage need to satisfy V inse_CK, V inse_CK_HIGH, and V inse_CK_LOW specification at input receiver. 214 200b: x32 Mobile LPDDR4XSDRAM AC and DC Input Measurement Levels Figure 143: Clock Single-Ended Input Voltage Vinse_CK_LOW Vinse_CK Vinse_CK_HIGH Vinse_CK_HIGH VREF(CA) Vinse_CK_LOW Vinse_CK Single Ended Input Voltage CK_t CK_c Time Note: 1. VREF(CA) is device internal setting value by VREF training. Table 147: Clock Single-Ended Input Voltage 1600/1867 2133/2400/3200 3733/4267 Parameter Symbol Min Max Min Max Min Max Unit Clock single-ended input voltage Vinse_CK 210 – 190 – 180 – mV Clock single-ended input voltage HIGH from VREF(CA) Vinse_CK_HIGH 105 – 95 – 90 – mV Clock single-ended input voltage LOW from VREF(CA) Vinse_CK_LOW 105 – 95 – 90 – mV Differential Input Slew Rate Definition for Clock Input slew rate for differential signals (CK_t, CK_c) are defined and measured as shown below in figure and the tables. 215 200b: x32 Mobile LPDDR4XSDRAM AC and DC Input Measurement Levels Figure 144: Differential Input Slew Rate Definition for CK_t, CK_c Differential Input Voltage : f(t) = CK_t - CK_c Peak Voltage VIHdiff_CK 0.0 VILdiff_CK Peak Voltage Delta TRdiff Delta TFdiff Time Notes: 1. Differential signal rising edge from VILdiff_CK to VIHdiff_CK must be monotonic slope. 2. Differential signal falling edge from VIHdiff_CK to VILdiff_CK must be monotonic slope. Table 148: Differential Input Slew Rate Definition for CK_t, CK_c Description From To Defined by Differential input slew rate for rising edge (CK_t - CK_c) VILdiff_CK VIHdiff_CK |VILdiff_CK - VIHdiff_CKΔTRdiff Differential input slew rate for falling edge (CK_t - CK_c) VIHdiff_CK VILdiff_CK |VILdiff_CK - VIHdiff_CKΔTFdiff Table 149: Differential Input Level for CK_t, CK_c 1600/1867 2133/2400/3200 3733/4267 Parameter Symbol Min Max Min Max Min Max Unit Differential Input HIGH VIHdiff_CK 175 – 155 – 145 – mV Differential Input LOW VILdiff_CK – –175 – –155 – –145 mV Table 150: Differential Input Slew Rate for CK_t, CK_c 1600/1867 Parameter Differential input slew rate for clock 2133/2400/3200 3733/4267 Symbol Min Max Min Max Min Max Unit SRIdiff_CK 2 14 2 14 2 14 V/ns 216 200b: x32 Mobile LPDDR4XSDRAM AC and DC Input Measurement Levels Differential Input Cross-Point Voltage The cross-point voltage of differential input signals (CK_t, CK_c) must meet the requirements in table below. The differential input cross-point voltage V IX is measured from the actual cross-point of true and complement signals to the mid level that is V REF(CA). Figure 145: Vix Definition (Clock) VDD Single-Ended Input Voltage CK_t Max(f(t)) ViX_CK_RF ViX_CK_FR VREF(CA) ViX_CK_RF Min(f(t)) ViX_CK_FR CK_c VSS Time Note: 1. The base levels of Vix_CK_FR and Vix_CK_RF are VREF(CA) that is device internal setting value by VREF training. Table 151: Cross-Point Voltage for Differential Input Signals (Clock) Notes 1 and 2 apply to entire table 1600/1867 Parameter Clock single-ended cross-point voltage ratio Notes: 2133/2400/3200 3733/4267 Symbol Min Max Min Max Min Max Unit Vix_CK_ratio – 25 – 25 – 25 % 1. Vix_CK_ratio is defined by this equation: Vix_CK_ratio = Vix_CK_FR/|Min(f(t))| 2. Vix_CK_ratio is defined by this equation: Vix_CK_ratio = Vix_CK_RF/Max(f(t)) Differential Input Voltage for DQS The minimum input voltage needs to satisfy both V indiff_DQS and V indiff_DQS/2 specification at input receiver and their measurement period is 1UI (tCK/2). V indiff_DQS is the peak to peak voltage centered on 0 volts differential and V indiff_DQS/2 is maximum and minimum peak voltage from 0 volts. 217 200b: x32 Mobile LPDDR4XSDRAM AC and DC Input Measurement Levels 0.0 Vindiff_DQS Vindiff_DQS /2 Peak voltage Vindiff_DQS /2 Differential Input Voltage : DQS_t - DQS_c Figure 146: DQS Differential Input Voltage Peak voltage Time Table 152: DQS Differential Input Voltage 1600/1867 2133/2400/3200 3733/4267 Parameter Symbol Min Max Min Max Min Max Unit Note DQS differential input voltage Vindiff_DQS 360 – 360 – 340 – mV 1 Note: 1. The peak voltage of Differential DQS signals is calculated in a following equation. • • • • Vindiff_DQS = (Maximum peak voltage) - (Minimum peak voltage) Maximum peak voltage = Max(f(t)) Minimum peak voltage = Min(f(t)) f(t) = VDQS_t - VDQS_c Peak Voltage Calculation Method The peak voltage of differential DQS signals are calculated in a following equation. • VIH.DIFF.peak voltage = Max(f(t)) • VIL.DIFF.peak voltage = Min(f(t)) • f(t) = V DQS_t - V DQS_c 218 200b: x32 Mobile LPDDR4XSDRAM AC and DC Input Measurement Levels Figure 147: Definition of Differential DQS Peak Voltage Single Ended Input Voltage DQS_t Min(f(t)) Max(f(t)) VREF(DQ) DQS_c Time 1. VREF(DQ) is device internal setting value by VREF training. Note: Single-Ended Input Voltage for DQS The minimum input voltage need to satisfy V inse_DQS, V inse_DQS_HIGH, and V inse_DQS_LOW specification at input receiver. Figure 148: DQS Single-Ended Input Voltage Vinse_DQS_LOW Vinse_DQS Vinse_DQS_HIGH Vinse_DQS_HIGH Vinse_DQS_LOW VREF(DQ) Vinse_DQS Single Ended Input Voltage DQS_t DQS_c Time Note: 1. VREF(DQ) is device internal setting value by VREF training. 219 200b: x32 Mobile LPDDR4XSDRAM AC and DC Input Measurement Levels Table 153: DQS Single-Ended Input Voltage 1600/1867 2133/2400/3200 3733/4267 Parameter Symbol Min Max Min Max Min Max Unit DQS single-ended input voltage Vinse_DQS 180 – 180 – 170 – mV DQS single-ended input voltage HIGH from VREF(DQ) Vinse_DQS_HIGH 90 – 90 – 85 – mV DQS single-ended input voltage LOW from VREF(DQ) Vinse_DQS_LOW 90 – 90 – 85 – mV Differential Input Slew Rate Definition for DQS Input slew rate for differential signals (DQS_t, DQS_c) are defined and measured as shown below in figure and the tables. Figure 149: Differential Input Slew Rate Definition for DQS_t, DQS_c Differential Input Voltage : f(t) = CK_t - CK_c Peak Voltage VIHdiff_CK 0.0 VILdiff_CK Peak Voltage Delta TRdiff Delta TFdiff Time Notes: 1. Differential signal rising edge from VILdiff_DQS to VIHdiff_DQS must be monotonic slope. 2. Differential signal falling edge from VIHdiff_DQS to VILdiff_DQS must be monotonic slope. Table 154: Differential Input Slew Rate Definition for DQS_t, DQS_c Description From To Differential input slew rate for rising edge (DQS_t - DQS_c) VILdiff_DQS VIHdiff_DQS |VILdiff_DQS - VIHdiff_DQSΔTRdiff Differential input slew rate for falling edge (DQS_t - DQS_c) VIHdiff_DQS VILdiff_DQS |VILdiff_DQS - VIHdiff_DQSΔTFdiff 220 Defined by 200b: x32 Mobile LPDDR4XSDRAM AC and DC Input Measurement Levels Table 155: Differential Input Level for DQS_t, DQS_c 1600/1867 Parameter 2133/2400/3200 3733/4267 Symbol Min Max Min Max Min Max Unit Differential Input HIGH VIHdiff_DQS 140 – 140 – 120 – mV Differential Input LOW VILdiff_DQS – –140 – –140 – –120 mV Table 156: Differential Input Slew Rate for DQS_t, DQS_c 1600/1867 Parameter 2133/2400/3200 3733/4267 Symbol Min Max Min Max Min Max Unit SRIdiff 2 14 2 14 2 14 V/ns Differential input slew rate Differential Input Cross-Point Voltage The cross-point voltage of differential input signals (DQS_t, DQS_c) must meet the requirements in table below. The differential input cross-point voltage V IX is measured from the actual cross-point of true and complement signals to the mid level that is VREF(DQ). Figure 150: Vix Definition (DQS) VDDQ Single-Ended Input Voltage DQS_t Max(f(t)) ViX_DQS_RF ViX_DQS_FR VREF(DQ) ViX_DQS_RF Min(f(t)) ViX_DQS_FR DQS_c VSSQ Time Note: 1. The base levels of Vix_DQS_FR and Vix_DQS_RF are VREF(DQ) that is device internal setting value by VREF training. 221 200b: x32 Mobile LPDDR4XSDRAM AC and DC Output Measurement Levels Table 157: Cross-Point Voltage for Differential Input Signals (DQS) Notes 1 and 2 apply to entire table 1600/1867 Parameter Clock single-ended cross-point voltage ratio Notes: 2133/2400/3200 3733/4267 Symbol Min Max Min Max Min Max Unit Vix_DQS_ratio – 20 – 20 – 20 % 1. Vix_DQS_ratio is defined by this equation: Vix_DQS_ratio = Vix_DQS_FR/|Min(f(t))| 2. Vix_DQS_ratio is defined by this equation: Vix_DQS_ratio = Vix_DQS_RF/Max(f(t)) Input Levels for ODT Table 158: Input Levels Parameter Symbol Min ODT input high level (AC) VIHODT(AC) 0.75 × VDD2 (or VDDQ) VDD2 (or VDDQ) + 0.2 V 1 ODT input low level (AC) VILODT(AC) –0.2 0.25 × VDD2 (or VDDQ) V 1 ODT input high level (DC) VIHODT(DC) 0.65 × VDD2 (or VDDQ) VDD2 (or VDDQ) + 0.2 V ODT input low level (DC) VILODT(DC) –0.2 0.35 × VDD2 (or VDDQ) V Note: Max Unit Notes 1. See the Overshoot and Undershoot section. AC and DC Output Measurement Levels Table 159: Single-Ended AC and DC Output Levels – ODT Enabled VOH(DC) Accuracy VOH Level Rx Termination (Nom) RZQΩ Min Typ Max 0.9 1.0 1.1 Units RZQΩ VDDQ/3 RZQΩ RZQΩ RZQΩ VOH RZQΩ RZQΩ VDDQ/2.5 0.85 1.0 1.15 RZQΩ RZQΩ Notes: 1. VOH is the calibration comparison point. The output driver calibrates to the VOH level ±10%. 2. Rx termination values must be set using the MRW command before ZQCal. 3. ZQCal is valid for any Rx termination value given the same VOH level. If the VOH level is changed, ZQCal must be retrained. Single-Ended Output Slew Rate 222 200b: x32 Mobile LPDDR4XSDRAM AC and DC Output Measurement Levels Table 160: Single-Ended Output Slew Rate Note 1-5 applies to entire table Value Parameter Symbol Min Max Units Single-ended output slew rate (VOH = VDDQ/3) SRQse 3.5 9.0 V/ns Output slew rate matching ratio (rise to fall) – 0.8 1.2 – Notes: 1. SR = Slew rate; Q = Query output; se = Single-ended signal 2. Measured with output reference load. 3. The ratio of pull-up to pull-down slew rate is specified for the same temperature and voltage, over the entire temperature and voltage range. For a given output, it represents the maximum difference between pull-up and pull-down drivers due to process variation. 4. The output slew rate for falling and rising edges is defined and measured between VOL(AC) = 0.2 × VOH(DC) and VOH(AC) = 0.8 × VOH(DC). 5. Slew rates are measured under average SSO conditions with 50% of the DQ signals per data byte switching. Figure 151: Single-Ended Output Slew Rate Definition Single-Ended Output Voltage (DQ) ¨TRSE VOH(AC) VCENT VOL(AC) ¨TFSE Time Differential Output Slew Rate Table 168: Differential Output Slew Rate Note 1-4 applies to entire table Value Parameter Symbol Min Max Units Differential output slew rate (VOH = VDDQ x 0.5) SRQdiff 6 18 V/ns Notes: 1. SR = Slew rate; Q = Query output; se = Differential signal. 2. Measured with output reference load. 3. The output slew rate for falling and rising edges is defined and measured between VOL(AC) = -0.8 × VOH(DC) and VOH(AC) = 0.8 × VOH(DC). 4. Slew rates are measured under average SSO conditions with 50% of the DQ signals per data byte switching. 223 200b: x32 Mobile LPDDR4XSDRAM AC and DC Output Measurement Levels Figure 152: Differential Output Slew Rate Definition Differential Output Voltage (DQ) ¨TRdiff 0 ¨TFdiff Time Overshoot and Undershoot Specifications Table 162: AC Overshoot/Undershoot Specifications Parameter 1600 1866 3200 3733 4267 Unit Maximum peak amplitude provided for overshoot area MAX 0.3 0.3 0.3 0.3 0.3 V Maximum peak amplitude provided for undershoot area MAX 0.3 0.3 0.3 0.3 0.3 V Maximum area above VDD/ VDDQ MAX 0.1 0.1 0.1 0.1 0.1 V-ns Maximum area below VSS/ VSSQ MAX 0.1 0.1 0.1 0.1 0.1 V-ns Notes: 1. VDD stands for VDD2 for CA[5:0], CK_t, CS_n, CKE, and ODT. VDD stands for VDDQ for DQ, DMI, DQS_t, and DQS_c. 2. VSS stands for VSS for CA[5:0], CK_t, CK_c, CS_n, CKE, and ODT. VSS stands for VSSQ for DQ, DMI, DQS_t, and DQS_c. 3. Maximum peak amplitude values are referenced from actual VDD and VSS values. 4. Maximum area values are referenced from maximum VDD and VSS values. Table 163: Overshoot/Undershoot Specification for CKE and RESET Parameter Specification Maximum peak amplitude provided for overshoot area 0.35V Maximum peak amplitude provided for undershoot area 0.35V Maximum area above VDD 0.8 V-ns Maximum area below VSS 0.8 V-ns 224 200b: x32 Mobile LPDDR4XSDRAM Driver Output Timing Reference Load Figure 153: Overshoot and Undershoot Definition Maximum amplitude Volts (V) Overshoot area VDD Time (ns) VSS Undershoot area Maximum amplitude Driver Output Timing Reference Load Timing reference loads are not intended as a precise representation of any particular system environment or depiction of an actual load presented by a production tester. System designers should use IBIS or other simulation tools to correlate the timing reference load to a system environment. Manufacturers correlate to their production test conditions, generally one or more coaxial transmission lines terminated at the tester electronics. Figure 154: Driver Output Timing Reference Load DRAM 50 Ohms Note: 1. All output timing parameter values are reported with respect to this reference load; this reference load is also used to report slew rate. LVSTL I/O System LVSTL I/O cells are comprised of a driver pull-up and pull-down and a terminator. 225 200b: x32 Mobile LPDDR4XSDRAM LVSTL I/O System Figure 155: LVSTL I/O Cell VDDQ Pull-Up DQ ODT Enabled when receiving Pull-Down VSSQ VSSQ To ensure that the target impedance is achieved, calibrate the LVSTL I/O cell as following example: 1. Calibrate the pull-down device against a 240 ohm resistor to V DDQ via the ZQ pin. • Set Strength Control to minimum setting • Increase drive strength until comparator detects data bit is less than V DDQ/3 • NMOS pull-down device is calibrated to 120 ohms 2. Calibrate the pull-up device against the calibrated pull-down device. • Set V OH target and NMOS controller ODT replica via MRS (VOH can be automatically controlled by ODT MRS) • Set Strength Control to minimum setting • Increase drive strength until comparator detects data bit is greater than VOH target • NMOS pull-up device is calibrated to V OH target 226 200b: x32 Mobile LPDDR4XSDRAM Input/Output Capacitance Figure 156: Pull-Up Calibration VDDQ Strength contol [N-1:0] N Comparator VOH target Controller ODT replica could be 60 Ohm, 120 Ohm, ... via MRS setting Calibrated NMOS PD control + ODT information VSSQ Input/Output Capacitance Table 164: Input/Output Capacitance Notes 1 and 2 apply to entire table Parameter Symbol Min Max Input capacitance, CK_t and CK_c CCK 0.5 0.9 Input capacitance delta, CK_t and CK_c CDCK 0 0.09 3 4 Unit Notes Input capacitance, all other input-only pins CI 0.5 0.9 Input capacitance delta, all other input-only pins CDI –0.1 0.1 Input/output capacitance, DQ, DMI, DQS_t, DQS_c CIO 0.7 1.3 CDDQS 0 0.1 7, 8 Input/output capacitance delta, DQ, DMI CDIO –0.1 0.1 7, 9 Input/output capacitance, ZQ pin CZQ 0 5.0 Input/output capacitance delta, DQS_t, DQS_c Notes: pF 5 6, 7 1. This parameter applies to LPDDR4 die only (does not include package capacitance). 2. This parameter is not subject to production testing; it is verified by design and characterization. The capacitance is measured according to JEP147 (procedure for measuring input capacitance using a vector network analyzer), with VDD1, VDD2, VDDQ, and VSS applied; all other pins are left floating. 3. Absolute value of CKCK_t – CKCK_c. 4. CI applies to CS, CKE, RESET_n, and CA[5:0]. 5. CDI = CI – 0.5 × (CCK_t + CKCK_c); it does not apply to CKE, RESET_n, or ODT(ca). 6. DMI loading matches DQ and DQS. 7. MR3 I/O configuration for pull-up/pull-down drive strength OP[5:0] = 000000b (RZQ/7). 8. Absolute value of CDQS_t and CDQS_c. 9. CDIO = CIO – 0.5 × (CDQS_t + CDQS_c) in byte-lane. 227 200b: x32 Mobile LPDDR4XSDRAM IDD Specification Parameters and Test Conditions IDD Specification Parameters and Test Conditions Table 165: IDD Measurement Conditions Switching for CA CK_t edge R1 R2 R3 R4 R5 R6 R7 R8 CKE HIGH HIGH HIGH HIGH HIGH HIGH HIGH HIGH CS LOW LOW LOW LOW LOW LOW LOW LOW CA0 HIGH LOW LOW LOW LOW HIGH HIGH HIGH CA1 HIGH HIGH HIGH LOW LOW LOW LOW HIGH CA2 HIGH LOW LOW LOW LOW HIGH HIGH HIGH CA3 HIGH HIGH HIGH LOW LOW LOW LOW HIGH CA4 HIGH LOW LOW LOW LOW HIGH HIGH HIGH CA5 HIGH HIGH HIGH LOW LOW LOW LOW HIGH Notes: 1. LOW = VIN ≤ VIL(DC) MAX HIGH = VIN ≥ VIH(DC) MIN STABLE = Inputs are stable at a HIGH or LOW level 2. CS must always be driven LOW. 3. 50% of CA bus is changing between HIGH and LOW once per clock for the CA bus. 4. The pattern is used continuously during IDD measurement for IDD values that require switching on the CA bus. Table 166: CA Pattern for IDD4R Clock Cycle Number CKE CS Command CA0 CA1 CA2 CA3 CA4 CA5 Read-1 L H L L L L L H L L L L L H L L H L L L L L L L N HIGH HIGH N+1 HIGH LOW N+2 HIGH HIGH N+3 HIGH LOW N+4 HIGH LOW DES L L L L L L N+5 HIGH LOW DES L L L L L L N+6 HIGH LOW DES L L L L L L N+7 HIGH LOW DES L L L L L L N+8 HIGH HIGH Read-1 L H L L L L N+9 HIGH LOW L H L L H L N+10 HIGH HIGH L H L L H H N+11 HIGH LOW H H H H H H N+12 HIGH LOW DES L L L L L L N+13 HIGH LOW DES L L L L L L N+14 HIGH LOW DES L L L L L L CAS-2 CAS-2 228 200b: x32 Mobile LPDDR4XSDRAM IDD Specification Parameters and Test Conditions Table 166: CA Pattern for IDD4R (Continued) Clock Cycle Number CKE CS Command CA0 CA1 CA2 CA3 CA4 CA5 N+15 HIGH LOW DES L L L L L L Notes: 1. BA[2:0] = 010; CA[9:4] = 000000 OR 111111; Burst order CA[3:2] = 00 or 11 (same as LPDDR3 IDDR3 spec). 2. CA pins are kept LOW with DES CMD to reduce ODT current (different from LPDDR3 IDDR3 spec). Table 167: CA Pattern for IDD4W Clock Cycle Number CKE CS Command CA0 CA1 CA2 CA3 CA4 CA5 N HIGH HIGH Write-1 L L H L L L N+1 HIGH LOW L H L L L L N+2 HIGH HIGH L H L L H L N+3 HIGH LOW L L L L L L N+4 HIGH LOW DES L L L L L L N+5 HIGH LOW DES L L L L L L N+6 HIGH LOW DES L L L L L L N+7 HIGH LOW DES L L L L L L N+8 HIGH HIGH Write-1 L L H L L L N+9 HIGH LOW L H L L H L N+10 HIGH HIGH L H L L H H N+11 HIGH LOW L L H H H H N+12 HIGH LOW DES L L L L L L N+13 HIGH LOW DES L L L L L L N+14 HIGH LOW DES L L L L L L N+15 HIGH LOW DES L L L L L L Notes: CAS-2 CAS-2 1. BA[2:0] = 010; CA[9:4] = 000000 or 111111 (same as LPDDR3 spec). 2. No burst ordering (different from LPDDR3 spec) 3. CA pins are kept LOW with DES CMD to reduce ODT current (different from LPDDR3 spec) Table 168: Data Pattern for IDD4W (DBI Off) DBI Off Case DQ[7] DQ[6] DQ[5] DQ[4] DQ[3] DQ[2] DQ[1] DQ[0] DBI # of 1s BL0 1 1 1 1 1 1 1 1 0 8 BL1 1 1 1 1 0 0 0 0 0 4 BL2 0 0 0 0 0 0 0 0 0 0 BL3 0 0 0 0 1 1 1 1 0 4 229 200b: x32 Mobile LPDDR4XSDRAM IDD Specification Parameters and Test Conditions Table 168: Data Pattern for IDD4W (DBI Off) (Continued) DBI Off Case DQ[7] DQ[6] DQ[5] DQ[4] DQ[3] DQ[2] DQ[1] DQ[0] DBI # of 1s BL4 0 0 0 0 0 0 1 1 0 2 BL5 0 0 0 0 1 1 1 1 0 4 BL6 1 1 1 1 1 1 0 0 0 6 BL7 1 1 1 1 0 0 0 0 0 4 BL8 1 1 1 1 1 1 1 1 0 8 BL9 1 1 1 1 0 0 0 0 0 4 BL10 0 0 0 0 0 0 0 0 0 0 BL11 0 0 0 0 1 1 1 1 0 4 BL12 0 0 0 0 0 0 1 1 0 2 BL13 0 0 0 0 1 1 1 1 0 4 BL14 1 1 1 1 1 1 0 0 0 6 BL15 1 1 1 1 0 0 0 0 0 4 BL16 1 1 1 1 1 1 1 1 0 8 BL17 1 1 1 1 0 0 0 0 0 4 BL18 0 0 0 0 0 0 0 0 0 0 BL19 0 0 0 0 1 1 1 1 0 4 BL20 0 0 0 0 0 0 1 1 0 2 BL21 0 0 0 0 1 1 1 1 0 4 BL22 1 1 1 1 1 1 0 0 0 6 BL23 1 1 1 1 0 0 0 0 0 4 BL24 0 0 0 0 0 0 0 0 0 0 BL25 0 0 0 0 1 1 1 1 0 4 BL26 1 1 1 1 1 1 1 1 0 8 BL27 1 1 1 1 0 0 0 0 0 4 BL28 1 1 1 1 1 1 0 0 0 6 BL29 1 1 1 1 0 0 0 0 0 4 BL30 0 0 0 0 0 0 1 1 0 2 BL31 0 0 0 0 1 1 1 1 0 4 # of 1s 16 16 16 16 16 16 16 16 Note: 1. Simplified pattern; same data pattern was applied to DQ[4], DQ[5], DQ[6], and DQ[7] to reduce complexity for IDD4W pattern programming. Table 169: Data Pattern for IDD4R (DBI Off) DBI Off Case BL0 DQ[7] DQ[6] DQ[5] DQ[4] DQ[3] DQ[2] DQ[1] DQ[0] DBI # of 1s 1 1 1 1 1 1 1 1 0 8 230 200b: x32 Mobile LPDDR4XSDRAM IDD Specification Parameters and Test Conditions Table 169: Data Pattern for IDD4R (DBI Off) (Continued) DBI Off Case DQ[7] DQ[6] DQ[5] DQ[4] DQ[3] DQ[2] DQ[1] DQ[0] DBI # of 1s BL1 1 1 1 1 0 0 0 0 0 4 BL2 0 0 0 0 0 0 0 0 0 0 BL3 0 0 0 0 1 1 1 1 0 4 BL4 0 0 0 0 0 0 1 1 0 2 BL5 0 0 0 0 1 1 1 1 0 4 BL6 1 1 1 1 1 1 0 0 0 6 BL7 1 1 1 1 0 0 0 0 0 4 BL8 1 1 1 1 1 1 1 1 0 8 BL9 1 1 1 1 0 0 0 0 0 4 BL10 0 0 0 0 0 0 0 0 0 0 BL11 0 0 0 0 1 1 1 1 0 4 BL12 0 0 0 0 0 0 1 1 0 2 BL13 0 0 0 0 1 1 1 1 0 4 BL14 1 1 1 1 1 1 0 0 0 6 BL15 1 1 1 1 0 0 0 0 0 4 BL16 1 1 1 1 1 1 1 1 0 8 BL17 1 1 1 1 0 0 0 0 0 4 BL18 0 0 0 0 0 0 0 0 0 0 BL19 0 0 0 0 1 1 1 1 0 4 BL20 0 0 0 0 0 0 1 1 0 2 BL21 0 0 0 0 1 1 1 1 0 4 BL22 1 1 1 1 1 1 0 0 0 6 BL23 1 1 1 1 0 0 0 0 0 4 BL24 0 0 0 0 0 0 0 0 0 0 BL25 0 0 0 0 1 1 1 1 0 4 BL26 1 1 1 1 1 1 1 1 0 8 BL27 1 1 1 1 0 0 0 0 0 4 BL28 1 1 1 1 1 1 0 0 0 6 BL29 1 1 1 1 0 0 0 0 0 4 BL30 0 0 0 0 0 0 1 1 0 2 BL31 0 0 0 0 1 1 1 1 0 4 # of 1s 16 16 16 16 16 16 16 16 Note: 1. Simplified pattern; same data pattern was applied to DQ[4], DQ[5], DQ[6], and DQ[7] to reduce complexity for IDD4W pattern programming. 231 200b: x32 Mobile LPDDR4XSDRAM IDD Specification Parameters and Test Conditions IDD Specifications IDD values are for the entire operating voltage range, and all of them are for the entire standard temperature range. Table 170: IDD Specification Parameters and Operating Conditions VDD2, VDDQ = 1.06–1.17V; VDD1 = 1.70–1.95V Parameter/Condition tCK tCK = Operating one bank active-precharge current: (MIN); tRC = tRC (MIN); CKE is HIGH; CS is LOW between valid commands; CA bus inputs are switching; Data bus inputs are stable; ODT is disabled Idle power-down standby current: tCK = tCK (MIN); CKE is LOW; CS is LOW; All banks are idle; CA bus inputs are switching; Data bus inputs are stable; ODT is disabled Idle power-down standby current with clock stop: CK_t = LOW, CK_c = HIGH; CKE is LOW; CS is LOW; All banks are idle; CA bus inputs are stable; Data bus inputs are stable; ODT is disabled tCK tCK = (MIN); CKE is Idle non-power-down standby current: HIGH; CS is LOW; All banks are idle; CA bus inputs are switching; Data bus inputs are stable; ODT is disabled Idle non-power-down standby current with clock stopped: CK_t = LOW; CK_c = HIGH; CKE is HIGH; CS is LOW; All banks are idle; CA bus inputs are stable; Data bus inputs are stable; ODT is disabled Active power-down standby current: tCK = tCK (MIN); CKE is LOW; CS is LOW; One bank is active; CA bus inputs are switching; Data bus inputs are stable; ODT is disabled Active power-down standby current with clock stop: CK_t = LOW, CK_c = HIGH; CKE is LOW; CS is LOW; One bank is active; CA bus inputs are stable; Data bus inputs are stable; ODT is disabled Active non-power-down standby current: tCK = tCK (MIN); CKE is HIGH; CS is LOW; One bank is active; CA bus inputs are switching; Data bus inputs are stable; ODT is disabled Active non-power-down standby current with clock stopped: CK_t = LOW, CK_c = HIGH; CKE is HIGH; CS is LOW; One bank is active; CA bus inputs are stable; Data bus inputs are stable; ODT is disabled Operating burst READ current: tCK = tCK (MIN); CS is LOW between valid commands; One bank is active; BL = 16 or 32; RL = RL (MIN); CA bus inputs are switching; 50% data change each burst transfer; ODT is disabled 232 Symbol Power Supply IDD01 VDD1 IDD02 VDD2 IDD0Q VDDQ IDD2P1 VDD1 IDD2P2 VDD2 IDD2PQ VDDQ IDD2PS1 VDD1 IDD2PS2 VDD2 IDD2PSQ VDDQ IDD2N1 VDD1 IDD2N2 VDD2 IDD2NQ VDDQ IDD2NS1 VDD1 IDD2NS2 VDD2 IDD2NSQ VDDQ IDD3P1 VDD1 IDD3P2 VDD2 IDD3PQ VDDQ IDD3PS1 VDD1 IDD3PS2 VDD2 IDD3PSQ VDDQ IDD3N1 VDD1 IDD3N2 VDD2 IDD3NQ VDDQ IDD3NS1 VDD1 IDD3NS2 VDD2 IDD3NSQ VDDQ IDD4R1 VDD1 IDD4R2 VDD2 IDD4RQ VDDQ Notes 2 2 2 2 2 2 3 3 3 4 200b: x32 Mobile LPDDR4XSDRAM IDD Specification Parameters and Test Conditions Table 170: IDD Specification Parameters and Operating Conditions (Continued) VDD2, VDDQ = 1.06–1.17V; VDD1 = 1.70–1.95V Parameter/Condition tCK tCK = (MIN); CS is LOW beOperating burst WRITE current: tween valid commands; One bank is active; BL = 16 or 32; WL = WL (MIN); CA bus inputs are switching; 50% data change each burst transfer; ODT is disabled All-bank REFRESH burst current: tCK = tCK (MIN); CKE is HIGH between valid commands; tRC = tRFCab (MIN); Burst refresh; CA bus inputs are switching; Data bus inputs are stable; ODT is disabled All-bank REFRESH average current: tCK = tCK (MIN); CKE is HIGH between valid commands; tRC = tREFI; CA bus inputs are switching; Data bus inputs are stable; ODT is disabled tCK tCK = (MIN); CKE is Per-bank REFRESH average current: HIGH between valid commands; tRC = tREFI/8; CA bus inputs are switching; Data bus inputs are stable; ODT is disabled Power-down self refresh current: CK_t = LOW, CK_c = HIGH; CKE is LOW; CA bus inputs are stable; Data bus inputs are stable; Maximum 1x self refresh rate; ODT is disabled Notes: 1. 2. 3. 4. 5. Symbol Power Supply IDD4W1 VDD1 IDD4W2 VDD2 IDD4WQ VDDQ IDD51 VDD1 IDD52 VDD2 IDD5Q VDDQ IDD5AB1 VDD1 IDD5AB2 VDD2 IDD5ABQ VDDQ IDD5PB1 VDD1 Notes 3 3 3 IDD5PB2 VDD2 IDD5PBQ VDDQ 3 IDD61 VDD1 5, 6 IDD62 VDD2 5, 6 IDD6Q VDDQ 3, 5, 6 ODT disabled: MR11[2:0] = 000b. IDD current specifications are tested after the device is properly initialized. Measured currents are the summation of VDDQ and VDD2. Guaranteed by design with output load = 5pF and RON = 40 ohm. The 1x self refresh rate is the rate at which the device is refreshed internally during self refresh before going into the elevated temperature range. 6. This is the general definition that applies to full-array self refresh. 7. For all IDD measurements, VIHCKE = 0.8 × VDD2; VILCKE = 0.2 × VDD2. 233 200b: x32 Mobile LPDDR4XSDRAM AC Timing AC Timing Table 171: Clock Timing Parameter Symbol Average clock period tCK(avg) Average HIGH pulse width tCH(avg) Average LOW pulse width tCL(avg) Absolute clock period tCK(abs) Absolute clock HIGH pulse width tCH(abs) Absolute clock LOW pulse width tCL(abs) Clock period jitter Maximum clock jitter between two consecutive clock cycles (includes clock period jitter) Data Rate Min/ Max 533 1066 1600 Min 3750 1875 1250 937 750 625 535 468 ps Max 100 100 100 100 100 100 100 100 ns 2133 2667 Min 0.46 Max 0.54 Min 0.46 Max 0.54 tCK(avg)min Min 3200 3733 4267 tCK(avg) tCK(avg) + tJIT(per)min Min 0.43 Max 0.57 Min 0.43 Max 0.57 ps tCK(avg) tCK(avg) tJIT(per)al- Min TBD TBD –70 TBD TBD –40 –34 –30 lowed Max TBD TBD 70 TBD TBD 40 34 30 Max TBD TBD 140 TBD TBD 80 68 60 tJIT(cc)al- lowed Unit ps ps Table 172: Read Output Timing Parameter Symbol DQS output access time from CK_t/CK_c tDQSCK DQS output access time from CK_t/CK_c - voltage variation DQS output access time from CK_t/CK_c - temperature variation CK to DQS rank to rank variation DQS_t, DQS_c to DQ skew total, per group, per access (DBI Disabled) DQ output hold time total from DQS_t, DQS_c (DBI Disabled) Min/ Max Data Rate 533 1066 1600 2133 2667 3200 3733 4267 Unit Notes ps 1 Min 1500 Max 3500 Max 7 ps/mV 2 Max 4 ps°/C 3 Max 1.0 ns 4, 5 tDQSQ Max 0.18 UI 6 tQH Min MIN(tQSH, tQSL) ps 6 tDQSCK_ VOLT tDQSCK_ TEMP tDQSCK_r ank2rank 234 200b: x32 Mobile LPDDR4XSDRAM AC Timing Table 172: Read Output Timing (Continued) Parameter Symbol Data output valid window time total, per pin (DBI-Disabled) DQS_t, DQS_c to DQ skew total, per group, per access (DBI-Enabled) DQ output hold time total from DQS_t, DQS_c (DBI-Enabled) Data output valid window time total, per pin (DBI-Enabled) tQW_to- tal tDQSQ_D BI tQH_DBI tQW_to- tal_DBI Min/ Max Data Rate 533 Min 1066 1600 2133 2667 3200 3733 4267 0.75 0.73 0.68 Unit Notes UI 6, 11 Max 0.18 UI 6 Min MIN(tQSH_DBI, tQSL_DBI) ps 6 UI 6, 11 Min 0.75 0.73 0.68 DQS_t, DQS_c differential output LOW time (DBIDisabled) tQSL Min tCL(abs) – 0.05 tCK(avg) 9, 11 DQS_t, DQS_c differential output HIGH time (DBIDisabled) tQSH Min tCH(abs) – 0.05 tCK(avg) 10, 11 DQS_t, DQS_c differential output LOW time (DBIEnabled) tQSL-DBI Min tCL(abs) – 0.045 tCK(avg) 9, 11 DQS_t, DQS_c differential output HIGH time (DBIEnabled) tQSH-DBI Min tCH(abs) – 0.045 tCK(avg) 10, 11 Read preamble tRPRE Min 1.8 tCK(avg) Read postamble tRPST Min 0.4 (or 1.4 if extra postamble is programmed in MR) tCK(avg) tLZ(DQS) Min (RL x tCK) + tDQSCK(Min) - (tRPRE(Max) x tCK) - 200ps ps tLZ(DQ) Min (RL x tCK) + tDQSCK(Min) - 200ps ps DQS Low-Z from clock DQ Low-Z from clock DQS High-Z from clock DQ High-Z from clock tHZ(DQS) Min tHZ(DQ) Min Notes: (RL x tCK) + tDQSCK(Max)+(BL/2 tCK) x - 100ps tCK) + (tRPST(Max) x (RL x tCK) + tDQSCK(Max) + tDQSQ(Max) + (BL/2 x tCK) 100ps ps ps 1. This parameter includes DRAM process, voltage, and temperature variation. It also includes the AC noise impact for frequencies >20 MHz and a max voltage of 45mV peakto-peak from DC-20 MHz at a fixed temperature on the package. The voltage supply noise must comply with the component min/max DC operating conditions. 2. tDQSCK_volt max delay variation as a function of DC voltage variation for VDDQ and VDD2. The voltage supply noise must comply with the component min/max DC operating conditions. The voltage variation is defined as the max[abs(tDQSCKmin@V1tDQSCKmax@V2), abs(tDQSCKmax@V1-tDQSCKmin@V2)]/abs(V1-V2). For tester measurement VDDQ = VDD2 is assumed. 3. tDQSCK_temp max delay variation as a function of temperature. 4. The same voltage and temperature are applied to tDQSCK_rank2rank. 235 200b: x32 Mobile LPDDR4XSDRAM AC Timing 5. tDQSCK_rank2rank parameter is applied to multi-ranks per byte lane within a package consisting of the same design dies. 6. DQ to DQS differential jitter where the total includes the sum of deterministic and random timing terms for a specified BER. 7. The deterministic component of the total timing. 8. This parameter will be characterized and guaranteed by design. 9. tQSL describes the instantaneous differential output low pulse width on DQS_t - DQS_c, as measured from one falling edge to the next consecutive rising edge. 10. tQSH describes the instantaneous differential output high pulse width on DQS_t DQS_c, as measured from one falling edge to the next consecutive rising edge. 11. This parameter is a function of input clock jitter. These values assume MIN tCH(abs) and tCL(abs). When the input clock jitter MIN tCH(abs) and tCL(abs) is 0.44 or greater than tCK(avg), the MIN value of tQSL will be tCL(abs) -0.04 and tQSH will be tCH(abs) - 0.04. Table 173: Write Voltage and Timing Note UI = tCK(AVG)(MIN)/2 Min/ Max Parameter Symbol Rx timing window total at VdIVW voltage levels TdIVW_t otal Rx timing window 1-bit toggle (at VdIVW voltage levels) TdIVW_1Max bit DQ and DMI input pulse width (at VCENT_DQ) DQ-to-DQS offset DQ-to-DQ offset TdIPW tDQS2DQ tDQDQ DQ-to-DQS offset temper- tDQS2DQ ature variation _temp DQ-to-DQS offset voltage variation tDQS2DQ _volt Data Rate Unit Notes UI 1, 2, 3, 4 TBD UI 1, 2, 3, 4, 5 Min 0.45 UI 8 Min 200 Max 800 ps 7 Max 30 ps 8 Max 0.6 ps/°C 9 Max 33 ps/50mV 10 Min 0.75 Max 1.25 Max 533 1066 1600 2133 2667 3200 3733 4267 0.22 0.25 WRITE command to first DQS transition tDQSS DQS input HIGH-level width tDQSH – 0.4 tCK(avg) DQS input LOW-level width tDQSL Min 0.4 tCK(avg) DQS falling edge to CK setup time tDSS Min 0.2 tCK(avg) DQS falling edge from CK hold time tDSH Min 0.2 tCK(avg) tWPST Min 0.4 (or 1.4 if extra postamble is programmed in MR) tCK(avg) Write postamble 236 tCK(avg) 200b: x32 Mobile LPDDR4XSDRAM AC Timing Table 173: Write Voltage and Timing (Continued) Note UI = tCK(AVG)(MIN)/2 Parameter Symbol tWPRE Write preamble Notes: Min/ Max Data Rate 533 1066 1600 2133 2667 3200 3733 4267 Min 1.8 Unit Notes tCK(avg) 1. Data Rx mask voltage and timing parameters are applied per pin and include the DRAM DQ-to-DQS voltage AC noise impact for frequencies >20 MHz with a maximum voltage of 45mV peak-to-peak at a fixed temperature on the package. The voltage supply noise must comply to the component MIN/MAX DC operating conditions. 2. The design specification is a BER 20 MHz and MAX voltage of 45mV peak-to-peak from DC-20 MHz at a fixed temperature on the package. For tester measurement, VDDQ = VDD2 is assumed. Table 174: CKE Input Timing Symbol Min/ Max tCKE Min Delay from valid command to CKE input LOW tCMDCKE Valid clock requirement after CKE input LOW Parameter Data Rate Unit Notes MAX(7.5ns, 4nCK) ns 1 Min MAX(1.75ns, 3nCK) ns 1 tCKELCK Min MAX(5ns, 5nCK) ns 1 Valid CS requirement before CKE input LOW tCSCKE Min 1.75 ns Valid CS requirement after CKE input LOW tCKELCS Min MAX(5ns, 5nCK) ns 1 Valid Clock requirement before CKE Input HIGH tCKCKEH Min MAX(1.75ns, 3nCK) ns 1 Exit power-down to next valid command delay tXP Min MAX(7.5ns, 5nCK) ns 1 CKE minimum pulse width (HIGH and LOW pulse width) 533 1066 1600 2133 2667 3200 3733 4267 237 200b: x32 Mobile LPDDR4XSDRAM AC Timing Table 174: CKE Input Timing (Continued) Data Rate Parameter Symbol Min/ Max Valid CS requirement before CKE input HIGH tCSCKEH Min 1.75 ns Valid CS requirement after CKE input HIGH tCKEHCS Min MAX(7.5ns, 5nCK) ns 1 Min MAX(14ns, 10nCK) ns 1 Min MAX(1.75ns, 3nCK) ns 1 Valid clock and CS requirement after CKE input LOW after MRW command tMRWCK EL Valid clock and CS requirement after CKE input LOW after ZQ calibration start command tZQCKE Note: 533 1066 1600 2133 2667 3200 3733 4267 Unit Notes 1. Delay time has to satisfy both analog time(ns) and clock count(nCK). For example, tCMDCKE will not expire until CK has toggled through at least 3 full cycles (3tCK) and 3.75ns has transpired. The case which 3nCK is applied to is shown below. Figure 157: tCMDCKE Timing T-1 T0 T1 T2 T3 T4 CK_c CK_t tCMDCKE CKE CS CA Valid Valid Command Valid DES Don’t Care Table 175: Command Address Input Timing Parameter Command/address valid window (referenced from CA VIL/VIH to CK VIX) Symbol Min/ Max tcIVW Min Data Rate 533 1066 1600 2133 2667 3200 3733 4267 0.3 238 0.35 0.4 Unit Notes tCK(avg) 1,2, 3 200b: x32 Mobile LPDDR4XSDRAM AC Timing Table 175: Command Address Input Timing (Continued) Parameter Data Rate Symbol Min/ Max 533 1066 1600 2133 2667 3200 3733 4267 tcIPW Min 0.55 0.55 Address and control input pulse width (referenced to VREF) Notes: 0.55 0.6 0.6 0.6 0.7 0.8 Unit Notes tCK(avg) 4 1. CA Rx mask timing parameters at the pin including voltage and temperature drift. 2. Rx differential CA to CK jitter total timing window at the VcIVW voltage levels. 3. Defined over the CA internal VREF range. The Rx mask at the pin must be within the internal VREF(CA) range irrespective of the input signal common mode. 4. CA only minimum input pulse width defined at the Vcent_CA(pin mid). Table 176: Boot Timing Parameters (10–55 MHz) Parameter Clock cycle time DQS output data acess time from CK DQS edge to output data edge Symbol tCKb tDQSCKb tDQSQb Min/ Max Data Rate 533 1066 1600 2133 2667 Min 18 Max 100 Min 1.0 Max 10.0 Max 1.2 3200 3733 4267 Unit ns ns ns Table 177: Mode Register Timing Parameters Data Rate Symbol Min/ Max MODE REGISTER WRITE (MRW) command period tMRW Min MAX(10ns, 10nCK) ns MODE REGISTER READ (MRR) command period tMRR Min 8 tCK(avg) Additional time after tXP has expired until the MRR command may be issued tMRRI Min tRCD(min) + 3nCK ns Delay from MRW command to DQS driven out tSDO Max MAX(12nCK, 20ns) ns Parameter 533 1066 239 1600 2133 2667 3200 3733 4267 Unit 200b: x32 Mobile LPDDR4XSDRAM AC Timing Table 178: Core Timing Parameters Refresh rate is determined by the value in MR4 OP[2:0] Data Rate Symbol Min/ Max 533 READ latency (DBI disabled) RL-A Min 6 10 14 20 24 28 32 36 tCK(avg) READ latency (DBI enabled) RL-B Min 6 12 16 22 28 32 36 40 tCK(avg) WRITE latency (Set A) WL-A Min 4 6 8 10 12 14 16 18 tCK(avg) WRITE latency (Set B) WL-B Min 4 8 12 18 22 26 30 34 tCK(avg) Parameter 1066 1600 2133 2667 3200 3733 4267 Unit Min + tRPab (with all-bank precharge) tRAS + tRPpb (with per-bank precharge) ns tSR Min MAX(15ns, 3nCK) ns Self refresh exit to next valid command delay tXSR Min MAX(tRFCab + 7.5ns, 2nCK) ns CAS-to-CAS delay tCCD Min 8 tCK(avg) CAS-to-CAS delay masked write tCCDMW MIN 32 tCK(avg) Internal READ-to-PRECHARGE command delay tRTP Min MAX(7.5ns, 8nCK) ns RAS-to-CAS delay tRCD Min MAX(18ns, 4nCK) ns Row precharge time (single bank) tRPpb Min MAX(18ns, 3nCK) ns Row precharge time (all banks) tRPab Min MAX(21ns, 3nCK) ns Notes tRAS ACTIVATE-to-ACTIVATE command period (same bank) tRC Minimum self refresh time (entry to exit) Min MAX(42ns, 3nCK) ns Max MIN(9 × tREFI × Refresh Rate1, 70.2) μs Write recovery time tWR Min MAX(18ns, 4nCK) ns Write-to-read delay tWTR Min MAX(10ns, 8nCK) ns Active bank A to active bank B tRRD Min MAX(10ns, 4nCK) ns Precharge-to-precharge delay tPPD Min 4 tCK(avg) Four-bank activate window tFAW Min 40 ns tESCKE Min MAX(1.75ns, 3nCK) – Row active time tRAS Delay from SRE command to CKE input LOW Note: 1 1. Delay time has to satisfy both analog time(ns) and clock count (nCK). It means that tESCKE will not expire until CK has toggled through at least three full cycles (3 tCK) and 1.75ns has transpired. The case which 3nCK is applied to is shown below. 240 200b: x32 Mobile LPDDR4XSDRAM AC Timing Figure 158: tESCKE Timing T-1 T0 T1 T3 T2 T4 CK_c CK_t t ESCKE CKE CS CA Valid Valid REFRESH Command SELF Entry DES Don’t Care Table 179: CA Bus ODT Timing Parameter Symbol Min/ Max CA ODT value update time tODTUP Min Data Rate RU(20ns/tCK,avg) 533-4267 Table 180: CA Bus Training Parameters Data Rate Parameter Symbol Min/ Max Valid clock requirement after CKE Input LOW tCKELCK Min MAX(5ns, 5nCK) tCK Data setup for VREF training mode tDStrain Min 2 ns Data hold for VREF training mode tDHtrain Min 2 ns Asynchronous data read tADR Max 20 ns CA BUS TRAINING command-to-command delay tCACD Min RU(tADR/tCK) tCK Valid strobe requirement before CKE LOW tDQSCKE Min 10 ns First CA BUS TRAINING command following CKE LOW tCAENT Min 250 ns Max 250 ns VREF step time – multiple steps tVREF- ca_LONG 533 1066 1600 2133 2667 3200 3733 4267 241 Unit Notes 1 200b: x32 Mobile LPDDR4XSDRAM AC Timing Table 180: CA Bus Training Parameters (Continued) Parameter Symbol Min/ Max Data Rate 533 1066 1600 2133 2667 3200 3733 4267 Unit Notes tVREF- ca_SHOR T Max 80 ns Valid clock requirement before CS HIGH tCKPRECS Min 2tCK + tXP – Valid clock requirement after CS HIGH tCKPSTCS Min MAX(7.5ns, 5nCK) – Minimum delay from CS to DQS toggle in command bus training tCS_VREF Min 2 tCK Min 10 ns Min 1.5 ns ODT turn-on latency from tCKELODCKE Ton Min 20 ns tCKEHODToff Min 20 ns VREF step time – one step Minimum delay from CKE HIGH to strobe High-Z tCKEHDQ S CA bus training CKE HIGH to DQ tri-state ODT turn-off latency from CKE tMRZ Note: 1. If tCACD is violated, the data for samples which violate tCACD will not be available, except for the last sample (where tCACD after this sample is met). Valid data for the last sample will be available after tADR. Table 181: Asynchronous ODT Turn On and Turn Off Timing Symbol 800–2133 MHz Unit tODTon,min 1.5 ns tODTon,max 3.5 ns tODToff,min 1.5 ns tODToff,max 3.5 ns Table 182: Temperature Derating Parameters Data Rate Parameter Symbol Min/ Max DQS output access time from CK_t/CK_c (derated) tDQSCKd Max tRCDd Min tRCD tRCd Min tRC RAS-to-CAS delay (derated) ACTIVATE-to-ACTIVATE command period (same bank, derated) 533 1066 1600 2133 2667 3600 242 3200 3733 4267 Unit ps + 1.875 ns + 3.75 ns 200b: x32 Mobile LPDDR4XSDRAM AC Timing Table 182: Temperature Derating Parameters (Continued) Parameter Symbol Min/ Max Data Rate 533 1066 1600 2133 2667 + 1.875 tRASd Min tRAS Row precharge time (derated) tRPd Min tRP Active bank A to active bank B (derated) tRRD Min tRRD Row active time (derated) Note: 3200 + 1.875 + 1.875 1. Timing derating applies for the operation at 85 °C to 105 °C. 243 3733 4267 Unit ns ns ns 200b: x32 Mobile LPDDR4XSDRAM CA Rx Voltage and Timing CA Rx Voltage and Timing The command and address (CA), including CS input receiver compliance mask for voltage and timing, is shown in the CA Receiver (Rx) Mask figure below. All CA and CS signals apply the same compliance mask and operate in single data rate mode. The CA input Rx mask for voltage and timing is applied across all pins, as shown in the figure below. The Rx mask defines the area that the input signal must not encroach if the DRAM input receiver is expected to successfully capture a valid input signal; it is not the valid data eye. Figure 159: CA Receiver (Rx) Mask tcIVW_total Rx Mask VCENT_CA(pin mid) VcIVW Figure 160: Across Pin VREF CA Voltage Variation CAx CAy CAz VCENT_CAz VCENT_CAx VCENT_CAy VREF variation (component) VCENT_CA(pin mid) is defined as the midpoint between the largest V CENT_CA voltage level and the smallest V CENT_CA voltage level across all CA and CS pins for a given DRAM component. Each CA V CENT level is defined by the center, which is, the widest opening of the cumulative data input eye, as depicted in the figure above. This clarifies that any DRAM component level variation must be accounted for within the CA Rx mask. The component-level V REF will be set by the system to account for RON and ODT settings. 244 200b: x32 Mobile LPDDR4XSDRAM CA Rx Voltage and Timing Figure 161: CA Timings at the DRAM Pins CK, CK Data-in at DRAM Pin Minimum CA eye center aligned CK_t VcIVW CK_c Rx mask DRAM pin CA tcIVW TcIVW for all CA signals is defined as centered on the CK_t/CK_c crossing at the DRAM pin. Note: 1. All of the timing terms in above figure are measured from the CK_t/CK_c to the center(midpoint) of the TcIVW window taken at the VcIVW_total voltage levels centered around VCENT_CA(pin mid). Figure 162: CA tcIPW and SRIN_cIVW Definition (for Each Input Pulse) tr tf Rx Mask VcIVW VCENT_CA(pin mid) tcIPW Note: 1. SRIN_cIVW = VdIVW_total/(tr or tf); signal must be monotonic within tr and tf range. Figure 163: CA VIHL_AC Definition (for Each Input Pulse) VIHL(AC)min/2 VCENT_CA Rx Mask Rx Mask Rx Mask VcIVW VIHL(AC)min/2 245 200b: x32 Mobile LPDDR4XSDRAM CA Rx Voltage and Timing Table 183: DRAM CMD/ADR, CS UI = tCK(AVG)MIN DQ – 13337 DQ – 1600/1867 DQ – 3200/3733 DQ – 4267 Symbol Parameter Min Max Min Max Min Max Min Max Unit Notes VclVW Rx mask voltage peak-topeak – 175 – 175 – 155 – 145 mV 1, 2, 3 VIHL(AC) CA AC input pulse amplitude peak-to-peak 210 – 210 – 190 – 180 – mV 4, 6 1 7 1 7 1 7 1 7 V/ns 5 SRIN_clVW Input slew rate over VclVW Notes: 1. CA Rx mask voltage and timing parameters at the pin, including voltage and temperature drift. 2. Rx mask voltage VcIVW total (MAX) must be centered around VCENT_CA(pin mid). 3. Defined over the CA internal VREF range. The Rx mask at the pin must be within the internal VREFCA range irrespective of the input signal common mode. 4. CA-only input pulse signal amplitude into the receiver must meet or exceed VIHL(AC) at any point over the total UI. No timing requirement above level. VIHL(AC) is the peak-topeak voltage centered around VCENT_CA(pin mid), such that VIHL(AC)/2 (MIN) must be met both above and below VCENT_CA. 5. Input slew rate over VcIVW mask is centered at VCENT_CA(pin mid). 6. VIHL(AC) does not have to be met when no transitions are occurring. 7. The Rx voltage and absolute timing requirements apply for DQ operating frequencies at or below 1333 for all speed bins. For example the tcIVW(ps) = 450ps at or below 1333 operating frequencies. 246 200b: x32 Mobile LPDDR4XSDRAM DQ Tx Voltage and Timing DQ Tx Voltage and Timing DRAM Data Timing Figure 164: Read Data Timing Definitions – tQH and tDQSQ Across DQ Signals per DQS Group tQSH(DQS_t) DQS_c DQS_t tQH tDQSQ Associated DQ pins DQS_c DQS_t DQx tQW tQW DQy DQz tQW 247 tQSL(DQS_t) 200b: x32 Mobile LPDDR4XSDRAM DQ Rx Voltage and Timing DQ Rx Voltage and Timing The DQ input receiver mask for voltage and timing is applied per pin, as shown in the DQ Receiver (Rx) Mask figure below. The total mask (V dIVW_total, TdIVW_total) defines the area that the input signal must not encroach in order for the DQ input receiver to successfully capture an input signal with a BER of less than TBD. The mask is a receiver property, and it is not the valid data eye. Figure 165: DQ Receiver (Rx) Mask TdIVW_total Rx Mask VdIVW VCENT_DQ(pin mid) Figure 166: Across Pin VREF DQ Voltage Variation DQx DQz DQy VCENT_DQz VCENT_DQx VCENT_DQy VREF variation (component) VCENT_DQ(pin_mid) is defined as the midpoint between the largest V CENT_DQ voltage level and the smallest V CENT_DQ voltage level across all DQ pins for a given DRAM component. Each V CENT_DQ is defined by the center, which is the widest opening of the cumulative data input eye as shown in the figure above. This clarifies that any DRAM component level variation must be accounted for within the DRAM Rx mask. The componentlevel V REF will be set by the system to account for RON and ODT settings. 248 200b: x32 Mobile LPDDR4XSDRAM DQ Rx Voltage and Timing Figure 167: DQ-to-DQS tDQS2DQ and tDQDQ DQ, DQS Data-in at DRAM Latch DQS, DQs Data-in Skews at DRAM Internal componsite data-eye center aligned to DQS Nonminimum data-eye/maximum Rx mask DQS_c DQS_c DQS_t DQS_t DQx Rx mask DRAM pin tDQS2DQy2 All DQ signals center aligned to the strobe at the device internal latch DQy Rx mask DRAM pin VdIVW_total DQx, y, z VdIVW_total tDQS2DQ2 DQz Rx mask DRAM pin VdIVW_total tDQS2DQz2 tDQDQ Notes: 1. 2. 3. 4. These timings at the DRAM pins are referenced from the internal latch. is measured at the center (midpoint) of the TdIVW window. DQz represents the MAX tDQS2DQ in this example. DQy represents the MIN tDQS2DQ in this example. tDQS2DQ All of the timing terms in DQ to DQS_t are measured from the DQS_t/DQS_c to the center (midpoint) of the TdIVW window taken at the V dIVW_total voltage levels centered around V CENT_DQ(pin_mid). In figure above, the timings at the pins are referenced with respect to all DQ signals center-aligned to the DRAM internal latch. The data-to-data offset is defined as the difference between the MIN and MAX tDQS2DQ for a given component. 249 200b: x32 Mobile LPDDR4XSDRAM DQ Rx Voltage and Timing Figure 168: DQ tDIPW and SRIN_dIVW Definition for Each Input Pulse UI = tCK(AVG) MIN/2 tr tf Rx Mask VDIVW_total VCENT_DQ(pin mid) tDIPW Note: 1. SRIN_dIVW = VdIVW_total/(tr or tf) signal must be monotonic within tr and tf range. Figure 169: DQ VIHL(AC) Definition (for Each Input Pulse) VIHL(AC)min/2 VCENT_DQ Rx Mask Rx Mask VdIVW_total Rx Mask VIHL(AC)min/2 Table 184: DQs In Receive Mode Note UI = tCK(AVG)(MIN)/2 Symbol Parameter VdIVW_total Rx mask voltage – peak-topeak VIHL(AC) DQ AC input pulse amplitude peak-to-peak SRIN_dIVW Input slew rate over VdIVW_total Notes: 1600/1867 2133/2400 3200/3733 4267 Min Max Min Max Min Max Min Max Unit Notes – 140 – 140 – 140 – 120 mV 1, 2, 3, 4 180 – 180 – 180 – 170 – mV 6, 8 1 7 1 7 1 7 1 7 V/ns 7 1. Data Rx mask voltage and timing parameters are applied per pin and include the DRAM DQ-to-DQS voltage AC noise impact for frequencies >20 MHz with a maximum voltage of 45mV peak-to-peak at a fixed temperature on the package. The voltage supply noise must comply to the component MIN/MAX DC operating conditions. 2. The design specification is a BER MHz) Upper Clock Frequency Limit (≤ ≤MHz) 6 6 4 4 6 8 10 266 10 12 6 8 12 8 266 533 16 18 8 12 16 8 533 800 22 24 10 18 22 8 800 1066 26 30 12 22 28 10 1066 1333 32 36 14 26 32 12 1333 1600 36 40 16 30 38 14 1600 1866 40 44 18 34 44 16 1866 2133 Table 197: MR8 Basic Configuration 4 (MA[7:0] = 08h) OP[7] OP[6] OP[5] OP[4] OP[3] OP[2] Density IO Width Table 198: MR8 Op-Code Bit Definitions Function Type Register Type Operand Read-Only OP[1:0] Data 00b: S16 SDRAM (16n pre-fetch) All Others: Reserved Density OP[5:2] 0000b: 2Gb per channel 0001b: 3Gb per channel 0010b: 4Gb per channel 0011b: 6Gb per channel 0100b: 8Gb per channel 0101b: 12Gb per channel 0110b: 16Gb per channel All Others: Reserved IO Width OP[7:6] 00b: x16 per channel 01b: x8 per channel All Others: Reserved 262 OP[1] OP[0] Type 200b: x32 Mobile LPDDR4XSDRAM Byte Mode Table 199: MR11 ODT Control (MA[7:0] = 0Bh) OP[7} OP[6] DQ ODTnt OP[5] OP[4] OP[3] CA ODT OP[2] DQ ODTnt OP[1] OP[0] DQ ODT Table 200: MR11 Op-Code Bit Definitions Notes 1-3 apply to entire table. Function Register Type DQ ODT (DQ bus receiver on-die termination) Write-only Operand OP[2:0] Data Notes 000b: Disable (Default) 001b: RZQ/1 010b: RZQ/2 011b: RZQ/3 100b: RZQ/4 101b: RZQ/5 110b: RZQ/6 111b: RFU DQ ODTnt (DQ bus receiver on-die termination for non-target DRAM) OP[7,3] CA ODT (CA bus receiver on-die termination) OP[6:4] 00b: Disable (Default) 4 01b: RZQ/3 10b: RZQ/5 11b: RZQ/6 000b: Disable (Default) 001b: RZQ/1 010b: RZQ/2 011b: RZQ/3 100b: RZQ/4 101b: RZQ/5 110b: RZQ/6 111b: RFU Notes: 1. All values are "typical". The actual value afer calibration will be within specified tolerance for a given voltage and temperature. Re-calibration may be required as voltage and temperature vary. 2. There are two physical registers assigned to each bit of this MR parameter, designated set point 0 and set point 1. Only the registers for the set point determined by the state of FSP-WR bit (MR13 OP[6]) will be written to with an MRW command to this MR address. 3. There are two physical registers assigned to each bit of this MR parameter, designated set point 0 and set point 1. The device will operate only according to the values stored in the registers for the active set point, i.e. the set point determined by the state of FSPOP bit (MR13 OP[7]). The values in the registers for the inactive set point will be ignored by the device, and may be changed without affecting device operation. 4. ODT for non-target DRAM is optional. 263 200b: x32 Mobile LPDDR4XSDRAM Byte Mode Table 201: MR17 PASR Segment Mask (MA[7:0] = 11h) OP[7] OP[6] OP[5] OP[4] OP[3] OP[2] OP[1] OP[0] PASR segment mask Table 202: MR17 PASR Segment Mask Definitions Function Register Type Operand PASR segment mask Write-only OP[7:0] Data 0b: Segment refresh enabled (default) 1b: Segment refresh disabled Table 203: MR17 PASR Segment Mask 4Gb 6Gb 8Gb 12Gb 16Gb 24Gb 32Gb R14:R12 R15:R13 R15:R13 R16:R14 R16:R14 TBD TBD 110b Not Allowed 110b Segment OP[n] Segment Mask 0 0 xxxxxxx1 000b 1 1 xxxxxx1x 001b 2 2 xxxxx1xx 010b 3 3 xxxx1xxx 011b 4 4 xxx1xxxx 100b 5 5 xx1xxxxx 101b 6 6 x1xxxxxx 110b 7 7 1xxxxxxx 111b Notes: Not Allowed 110b 111b Not Allowed 111b 111b 1. This table indicates the range of row addresses in each masked segment. "x" is don't care for a particular segment. 2. PASR segment-masking is per-channel. For dual channel designs, PASR for each channel must set separately. 3. For 6Gb, 12Gb and 24Gb densities, OP[7:6} must always be LOW (-00b). 264 200b: x32 Mobile LPDDR4XSDRAM Byte Mode Table 204: MR22 Register Information (MA[7:0] = 16h) OP[7] OP[6] OP[5] OP[4] OP[3] x8ODTD[15:8] x8ODTD[7:0] ODTD-CA ODTE-CS ODTE-CKE OP[2] OP[1] OP[0] SoC ODT Table 205: MR22 Register Information Register Type Function SoC ODT (Controler ODT value for VOH calibration) Write -only Operand OP[2:0] Data Notes 000b: Disable (Default) 1, 2, 3 001b: RZQ/1 010b: RZQ/2 011b: RZQ/3 100b: RZQ/4 101b: RZQ/5 110b: RZQ/6 111b: RFU ODTE-CK (CK ODT enabled for non-terminating rank) OP[3] ODTE-CS (CS ODT termination for non-terminating rank) OP[4] ODTE-CA (CA ODT termination disable) OP[5] x8ODT[7:0] (CA/CLK ODT termination disable, [7:0] byte select) OP[6] x8ODT[15:8] (CA/CLK ODT termination disable, [15:8] byte select) OP[7] 0b: ODT-CK over-ride disabled (default) 2, 3, 4, 6, 8 1b: ODT-CK over-ride enabled 0b: ODT-CS over-ride disabled (default) 2, 3, 5, 6, 8 1b: ODT-CS over-ride enabled 0b: ODT-CA obeys ODT_CA bond pad (default) 2, 3, 6, 7, 8 1b: ODT-CA disabled x8_2ch only, [7:0] byte selected device 6, 8, 9, 11 0b: ODT-CA obeys ODT_CA bond pad (default) 1b: ODT-CS/CA/CLK disabled x8_2ch only, [15:8] byte selected device 6, 8, 10, 11 0b: ODT-CA obeys ODT_CA bond pad (default) 1b: ODT-CS/CA/CLK disabled Notes: 1. All values are typical. 2. There are two physical registers assigned to each bit of this MR parameter, designated set point 0 and set point 1. Only the registers for the set point determined by the state of the FSP-WR bit (MR13 OP[6]) will be written to with an MRW command to the MR address, or read from with an MRR command to this address. 3. There are two physical registers assigned to each bit of this MR parameter, designated set point 0 and set point 1. The device will operate only according to the values stored in the registers for the active set point i.e. the set point determined by the state of the FSP OP bit (MR13 OP[7]). The values in the registers for the inactive set point will be ignored by the device and may be changed without affecting the device operation. 265 200b: x32 Mobile LPDDR4XSDRAM Byte Mode 4. When MR22 OP[3] = 1, the CK signals will be terminated to the value set by MR11 OP[6:4] regardless of the state of the ODT_CA bond pad. This over-rides the ODT_CA bond pad for configurations where CA is shared by two or more DRAM's but CK is not shared, allowing CK to terminate on all DRAMs. 5. When MR22 OP[4] = 1, the CK signals will be terminated to the value set by MR11 OP[6:4] regardless of the state of the ODT_CA bond pad. This over-rides the ODT_CA bond pad for configurations where CA is shared by two or more DRAM's but CS is not shared, allowing CS to terminate on all DRAMs. 6. For system configurations where CK, CS and CA signals are shared between packages, the package design should provide for the ODT_CA ball to be bonded on the system board outside of the memory package. This provides the necessary control of the ODT function for all die sith shared command bus signals. 7. When MR22 OP[5] = 0, CA[5:0] will terminate when the ODT_CA pad is HIGH and MR11 OP[6:4] is valid. CA[5:0] termination is disabled when ODT_CA is LOW or MR11 OP[6:4] is disabled. When OP[5] = 1, termination for CA[5:0] is disabled, regardless of the state of the ODT_CA bond pad or MR11 OP[6:4]. 8. To ensure operation in a multi-rank configuration, when CA, CK, or CS ODT are enabled via MR11 OP[6:4] and also via MR22 or CA_ODT pad setting, the rank providing ODT will continue to terminate the command bus in all DRAM states including Active self refresh, self refresh power-down, Active power-down and precharge power-down. 9. To ensure proper operation for x8_2ch devices, MR22 OP[6] = 1, disables CS/CA and CLK ODT of the lower byte selected device regardless of the MR11 and MR22 OP[5:0] settings. 10. To ensure proper operation for x8_2ch devices, MR22 OP[7] = 1, disables CS/CA and CLK ODT of the upper byte selected device regardless of the MR11 and MR22 OP[5:0] settings. 11. Designation of bytes [15:8] and [7:0] are defined by the vendor and are not programmable. Command Truth Table Truth tables provide complementary information to the state diagram. They also clarify device behavior and applicable restrictions when considering the actual state of the banks. Unspecified operation and timings are illegal. To ensure proper operation after an illegal event, the device must be either reset by asserting the RESET_n command or powerdown and then restarted using the specified initialization sequence before normal operation can continue. CKE signal has to be held HIGH when the commands listed in the command truth table input. Table 206: Command Truth Table Change CA Pins Command CS CA0 CA1 CA2 CA3 CA4 CA5 CK Edge ACTIVATE-1 H H L R12 R13 R14 R15 1 L BA0 BA1 BA2 R16 R10 R11 2 Note: The command truth table now includes R16 for byte mode addressing 266 200b: x32 Mobile LPDDR4XSDRAM Byte Mode Command Bus Training The LPDDR4-SDRAM command bus must be trained before enabling termination for high-frequency operation. the device provides an internal V REFCA that defaults to a level suitable for un-terminated, low-frequency operation. The V REFCA must be trained to achieve suitable receiver voltage margin for terminated, high-frequency operation. The training methodology described here centers the internal V REFCA in the CA data eye and at the same time allows for timing adjustments of the CS and CA signals to meet setup/ hold requirements. Because it can be difficult to capture commands prior to training the CA inputs, the training methodology described here uses a minimum of external commands to enter, train and exit the command bus training methodology. Note: It is up to the system designer to determine what constitutes low-frequency and high-frequency based on the capabilities of the system. Low-frequency should then be defined as an operating frequency in which the system can reliably communicate with the device before command bus training is executed. The byte mode device supports two command bus training (CBT) modes. 1. Mode 1: The corresponding DQ pins in this definition depends on the package configuration. DQ0 becomes DQ8 in some cases, as well as DQ1 to DQ6. DQ[6:0] only used as output and the V REFCA input procedure is removed from the CBT function for x16 2channel. device. 2. Mode 2: TBD Selection of which CBT mode set by MRx OP[y] (TBD). The LPDDR4-SDRAM die has a bond pad (ODT_CA) for MULTI-RANK operation. In the multi-rank system, the terminating rank should be trained first, followed by the nonterminating rank(s). See the ODT section for more information. Training Mode 1 The LPDDR4-SDRAM uses frequency set points (FSP) to enable multiple operating settings for the die. The device defaults to FSP-OP[0] at power-up, loading the default settings to operate in un-terminated, low-frequency environments. Prior to training, the mode register settings should be configured by setting MR13 OP[6] = 1b (FSP-WR[1]) and setting all other mode register bits including MR12 OP[6:0] (VREFCA range and setting) for FSP-OP[1] to the desired settings for high-frequency operations. Prior to entering command bus training, the device will be operating from FSP-OP[x]. Upon command bus training entry when CKE is driven LOW, the device will automatically switch to the alternate FSP register set (FSP OP[y]) and use the alternate register settings during training . Upon training exit when CKE is driven HIGH, the device will automatically switch back to the original FSP register set (FSP-OP[x]), returning to the "known-good" state thaw was operating prior to training. To set MRx OP[y] = 0b: CBT training mode 1 1. To enter CBT mode, issue an MRW-1 command followed by an MRW-2 command to set MR13 OP[0] = 1b (Command bus training enabled). 2. After time tMRD, CKE may be set LOW, causing the device to switch from FSPOP[x] to FSP-OP[y], completing entry into CBT mode. The status of DQS_t, DQS_c, DQ, and DMI are as follows 3. . After time tMRD, CKE may be set LOW, causing the device to switch from FSPOP[x] to FSP-OP[y], and completing the entry into command bus training mode. A 267 200b: x32 Mobile LPDDR4XSDRAM Byte Mode status of DQS_t, DQS_c, DQ, and DMI are as follows, and DQ ODT state will be followed FREQUENCY SET POINT function except output pins. 4. At time tCAENT later, device can accept to input CA training pattern via CA bus. 5. To verify that the receiver has the correct V REFCA setting and to further train the CA eye relative to clock (CK), values latched at the receiver on the CA bus are asynchronously output to the DQ bus. 6. . To exit command bus training mode, drive CKE HIGH, and after time tFC issue the MRW-1 command followed by the MRW-2 command to set MR13 OP[0] = 0b. After time tMRW the device is ready for normal operation. After training exit the device will automatically switch back to the FSP-OP registers that were in use prior to training. Command bus training may executed from idle or self refresh states. When executing CBT within the self refresh state, the device must not be in a power-down state (for example. CKE must be HIGH prior to training entry). Command bus training entry and exit is the same, regardless of the device state from which CBT is initiated. Training Sequence of Mode 1 for Single-Rank Systems The example shown assumes an initial low-frequency, non-terminating operating point, training a high-frequency, terminating operating point. The bold text is low-frequency, italics text is high-frequency. Any operating point may be trained from any known-good operating point. 1. Set MR13 OP[6] = 1b to enable writing to frequency set point 'y' (FSP-WR[y]) (or FSP-OP[x], See note). 2. . Write FSP-WR[y] (or FSP-WR[x]) registers for all channels to set up high-frequency operating parameters including V REFCA range and setting. 3. Issue MRW-1 and MRW-2 commands to enter command bus training mode 4. Drive CKE LOW, and change CK frequency to the high-frequency operating point. 5. Perform command bus training (CS and CA). 6. Exit training, a change CK frequency to the low-frequency operating point prior to driving CKE HIGH, then issue MRW-1 and MRW-2 commands. When CKE is driven HIGH, the device will automatically switch back to the FSP-OP registers that were in use prior to training (for example. trained values are not retained by the device). 7. Issue MRW-1 and MRW-2 commands to switch to FSP-OP[y] (or FSP-OP[x]), to turn on termination, and change CK frequency to the high frequency operating point. At this point the command bus is trained and you may proceed to other training or normal operation. Repeat steps 1 through 2 (Table below) until the proper V REFCA level is established. Table 207: Command Bus Training Steps Step 1 2 3 (1) 4 (2) Mode Normal CBT Normal CBT Operating frequency Low High Low High FSP-OP 0 1 0 1 FSP-WR 1 1 1 1 268 200b: x32 Mobile LPDDR4XSDRAM Byte Mode Table 207: Command Bus Training Steps (Continued) Step Operation 1 2 3 (1) 4 (2) VREFCA range/value set- Training pattern input VREFCA range/value set- Training pattern input ting via MRW ting via MRW then comparison bethen comparison between output data and tween output data and expected data expected data. Training Sequence of Mode 1 for Multi-Rank Systems The a example shown here is assuming an initial low-frequency operating point, training a high-frequency operating point. The bold text is low-frequency, italic text is highfrequency. Any operating point may be trained from any known-good operating point. 1. Set MR13 OP[6] = 1b to enable writing to frequency set point 'y' (FSP-WR[y]) (or FSP-WR[x]. 2. Write FSP-WR[y] (or FSP-WR[x]) registers for all channels and ranks to set up high frequency operating parameters including V REFCA range and setting. 3. Read MR0 OP[7] on all channels and ranks to determine which die are terminating, signified by MR0 OP[7] = 1b. 4. Issue MRW-1 and MRW-2 commands to enter command bus training mode on the terminating rank. 5. Drive CKE LOW on the terminating rank (or all ranks), and change CK frequency to the highfrequency operating point. 6. Perform command bus training on the terminating rank (CS and CA). 7. Exit training by driving CKE HIGH, change CK frequency to the low-frequency operating point, and issue MRW-1 and MRW-2 commands to write the trained values to FSP-WR[y] (or FSP-WR[x]). When CKE is driven HIGH, the device will automatically switch back to the FSP-OP registers that were in use prior to training. 8. Issue MRW-1 and MRW-2 command to enter training mode on the non-terminating rank (but keep CKE HIGH) 9. Issue MRW-1 and MRW-2 commands to switch the terminating rank to FSPOP[y] (or FSP-OP[x]), to turn on termination, and change CK frequency to the high frequency operating point. 10. Drive CKE LOW on the non-terminating (or all) ranks. The non-terminating rank(s) will now be using FSP-OP[y] (or FSP-OP[x]). 11. Perform command bus training on the non-terminating rank (CS and CA). 12. Issue MRW-1 and MRW-2 commands to switch the terminating rank to FSP-OP[x] (or FSP-OP[y]) to turn off termination. 13. Exit training by driving CKE HIGH on the non-terminating rank, change CK frequency to the low frequency operating point, and issue MRW-1 and MRW-2 commands. When CKE is driven HIGH, the device will automatically switch back to the FSP-OP registers that were in use prior to training. 14. Write the trained values to FSP-WR[y] (or FSP-WR[x]) by issuing MRW-1 and MRW-2 commands to the device and setting all applicable mode register parameters. 15. Issue MRW-1 and MRW-2 commands to switch the terminating rank to FSPOP[y] (or FSP-OP[x]), to turn on termination, and change CK frequency to the high frequency operating point. At this point the command bus is trained for both ranks and you may proceed to other training or normal operation. 269 200b: x32 Mobile LPDDR4XSDRAM Byte Mode Relation between the CA Input Pin and the DQ Output Pin for Mode 1 The relation between CA input pin DQ output pin is shown in the following table. Table 208: Mapping of CA Input Pin and DQ Output Pin Mapping CA Number CA5 CA4 CA3 CA2 CA1 CA0 DQ Number DQ5 DQ4 DQ3 DQ2 DQ1 DQ0 Timing for CA Training Mode 1 Figure 170: Entering CBT Mode and CA Training Pattern (Input and Output) T0 T1 T2 T3 T4 T5 Ta0 Tb0 Tb1 Tc0 Td0 Td1 Te0 Te1 Te2 Te3 Te4 Tf0 Tg0 Th0 Th1 Th2 CK_c CK_t Note 1 tCKPRECS tCKPSTCS Note 5 Note 2 CKE tCKELCK tMRD Note 3 tCACD CS CA Command MRW-1 MRW-1 MRW-2 MRW-2 DES Enter CBT mode Valid Valid DES DES DES DES CA training Pattern A DES tCAENT CA Pattern B tADR DQS_c DQS_t DQ[5:0] Pattern A DQ[7:6] DMI VREFCA (reference) Setting value of MR X (Y) Updating settin from FSP Switchinng tCKELODTon ODT_CA (reference) Mode register X (Y)) Switching MR Setting value of MR X (Y) Note 4 Mode register X (Y)) Don’t Care 1. After tCKELCK clock can be stopped or frequency changed any time. 2. The input clock condition should be satisfied tCKPRECS and tCKPSTCS. 3. Continue to drive CK, and hold CA and CS pins LOW until tCKELCK after CKE is LOW (which disables command decoding). 4. When CKE is driven LOW, the device will switch its FSP-OP registers to use the alternate (for example. non-active) set. Example: If the device is currently using FSP-OP[0], then it will switch to FSP-OP[1] when CKE is driven LOW. All operating parameters should be written to the alternate mode registers before entering command bus training to ensure that ODT settings, RL/WL/nWR setting, and so on, are set to the correct values. If the alternate FSP-OP has ODT_CA disabled then termination will not enable in CA bus training mode. If the ODT_CA pad is bonded to V SS or floating, ODT_CA termination will never enable for that die. 270 200b: x32 Mobile LPDDR4XSDRAM Byte Mode 5. When CKE is driven LOW in command bus training mode, the device will change operation to the alternate FSP, for example. non-active FSP programmed in the FSP-OP mode register. Figure 171: Exiting CBT Mode with Valid Command T0 T1 T2 Ta0 Ta1 Ta2 Tb0 Tc0 Td0 Td1 Te0 Te1 Tf0 Tf1 Tf2 Tf3 Tf4 Tg0 Tg1 Tg2 Tg3 Tg4 Tg5 CK_c CK_t tCKPSTCS Note 4 CKE tCAD tMRW tFC Note 1 tCKCKEH CS Note 2 CA Command Valid Valid CA Pattern B CA Pattern C MRW-1 MRW-1 MRW-2 MRW-2 DES DES DES DES DES DES Exit command bus training mode MRW-1 MRW-1 MRW-2 MRW-2 DES Valid DES DQS_c DQS_t tADR DQ[5:0] tADR Pattern A Pattern B tMRZ Pattern C DQ[7:6] DMI VREFCA (reference) Setting value of Updating MR Y (X) Note 3 ODT_CA (reference) Mode register Y (X) setting from FSP switching Setting value of MR X (Y) tCKELODToff Switching MR Mode register X (Y) Don’t Care 1. CK must meet tCKCKEH before CKE is driven HIGH. When CKE is driven HIGH the clock frequency must be returned to the original frequency (the frequency corresponding to the FSP at which command bus training mode was entered). 2. CS and CA[5:0] must be deselect (all LOW) tCKCKEH before CKE is driven HIGH. 3. When CKE is driven HIGH, the device's ODT_CA will revert to the state/value defined by FSP-OP prior to command bus training mode entry, for example. the original frequency set point (FSP-OP, MR13-OP[7]). Example: If the device was using FSP-OP[1] for training, then it will switch to FSP-OP[0] when CKE is driven HIGH. 4. When CKE is driven HIGH, the device will revert to the FSP in operation when command bus training mode was entered. 271 200b: x32 Mobile LPDDR4XSDRAM Byte Mode Figure 172: Exiting CBT Mode with Power Down Entry T0 T1 T2 Ta0 Ta1 Ta2 Tb0 Tc0 Td0 Td1 Te0 Te1 Tf0 Tf1 Tf2 Tf3 Tf4 Tg0 Tg1 Tg2 Tg3 Th0 Tk0 CK_c CK_t tCKPSTCS tCKCKEL Note 4 CKE tFC tCAD Note 1 tMRW tCKELCMD tCKCKEH CS Note 2 CA Command Valid Valid CA Pattern B CA Pattern C MRW-1 MRW-1 MRW-2 MRW-2 DES DES DES DES DES DES Exit Command Bus training mode DES DES DQS_c DQS_t tADR DQ[5:0] tMRZ tADR Pattern A Pattern B Pattern C DQ[7:6] DMI VREFCA (reference) Setting value of Updating setting from FSP switching MR Y (X) Note 3 ODT_CA (reference) Mode register Y (X) Setting value of MR X (Y) tCKELODToff Switching MR Mode register X (Y) Don’t Care 1. Clock can be stopped or frequency changed any time before tCKCKEH. CK must meet tCKCKEH before CKE is driven HIGH. When CKE is driven HIGH, the clock frequency must be returned to the original frequency (the frequency corresponding to the FSP at which command bus training mode was entered). 2. CS and CA[5:0] must be deselect (all LOW) tCKCKEH before CKE is driven HIGH. 3. When CKE is driven HIGH, the device's ODT_CA will revert to the state/value defined by FSP-OP prior to command bus training mode entry, for example. the original frequency set point (FSP-OP, MR13-OP[7]). Example: If the device was using FSP-OP[1] for training, then it will switch to FSP-OP[0] when CKE is driven HIGH. 4. When CKE is driven HIGH, the device will revert to the FSP in operation when command bus training mode was entered. Read DQ Training LPDDR4 devices feature a RD DQ CALIBRATION TRAINING function that outputs an 8bit user-defined pattern on the DQ pins. RD DQ calibration is initiated by issuing an MPC-1 [RD DQ CALIBRATION] command followed by a CAS-2 command. This command will cause the device to drive the contents of MR32 followed by the contents of MR40 on each of DQ[7:0] and DMI[0]. The pattern can be inverted on selected DQ pins according to user-defined invert masks written to MR15. 272 200b: x32 Mobile LPDDR4XSDRAM Byte Mode RD DQ Calibration Training Procedure The procedure for executing RD DQ calibrations is: Issue MRW commands to write MR32 (first 8 bits), MR40 (second 8 bits), MR15 (eightbit invert mask for byte 0: DQ[7:0] and MR20 (eight-bit invert mask for byte 1: DQ[15:8]. Optionally this step could be skipped to use default patterns: • • • • MR32 default = 5Ah MR40 default = 3Ch MR15 default = 55h MR20 default = 55h Issue an MPC-1 [RD DQ CALIBRATION] command followed immediately be a CAS-2 command • Each time an MPC-1 [RD DQ CALIBRATION] command followed by a CAS-2 is received by the device, a 16-bit data burst will, after the currently set RL, drive the eight bits programmed in MR32 followed by the eight bits programmed in MR40 on all I/O pins. • The data pattern will be inverted for I/O pins with a 1 programmed in the corresponding invert mask mode register bit ( see the Invert Mask Assignments Table). Note: The pattern is driven on the MCI pins, but no data bus inversion function is enabled, even if read DBI is enabled in the device mode register. • The MPC-1 command can be issued every tCCD seamlessly, and tRTRRD delay is required between ARRAY READ command and the MPC-1 command as well the delay required between the MPC-1 command and an ARRAY READ. • The operands received with the CAS-2 command must be driven LOW • DQ read training can be performed with any or no banks active, during REFRESH, or during SREF with CKE HIGH. Table 209: Invert Mask Assignments Invert Mask Assignments DQ pin 0 1 2 3 DMI0 4 5 6 7 MR15 bit 0 1 2 3 N/A 4 5 6 7 DQ pin 8 9 10 11 DMI1 12 13 14 15 MR20 bit 0 1 2 3 N/A 4 5 6 7 Notes: 1. The patterns contained in MR32 and MR40 are transmitted on the lower byte: DQ[7:0] or the upper byte: DQ[15:8] when a RD DQ calibration is initiated via an MPD-1 [RD DQ CALIBRATION] command. The pattern is transmitted serially on each data land, organized as little endian such that the low-order bit in the byte is transmitted first. If the data pattern is 27h, the fist bit transmitted will be a 1 followed by 1, 1, 0, 0, 1, 0, and 0. The bit stream will be 00100111... 2. MR15 and MR22 may be used to invert the MR32/MR40 data patterns on the DQ pins. Refer to the MR15 description for more information. Data is never inverted on the DMI[1:0] pins. 3. The data pattern is not transmitted on the DMI[1;0] pins if DBI-RD is disabled via MR3 OP[6]. 4. No DATA BUS INVERSION (DBI) function is enacted during RD DQ calibrations, even if DBI is enabled in MR3 OP[6]. 273 200b: x32 Mobile LPDDR4XSDRAM Byte Mode DQ Read Training Example An example of DQ read training output is shown in the following table. This table illustrated the 16-bit pattern that will be driven on each DQ in byte 0 when one DQ READ TRAINING command is executed. The example shown assumes the following mode register values are used; • MR32 = 1Ch • MR40 = 59h • MR15 and MR20 = 55h Table 210: DQ Read Training Output Bit Sequence Pin Invert 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 DQ0 (DQ8) Yes 1 0 1 0 0 1 1 0 1 1 1 0 0 0 1 1 DQ1 (DQ9) No 0 1 0 1 1 0 0 1 0 0 0 1 1 1 0 0 DQ2 (DQ10) Yes 1 0 1 0 0 1 1 0 1 1 1 0 0 0 1 1 DQ3 (DQ11) No 0 1 0 1 1 0 0 1 0 0 0 1 1 1 0 0 DMI0 (DMI1) Never 0 1 0 1 1 0 0 1 0 0 0 1 1 1 0 0 DQ4 (DQ12) Yes 1 0 1 0 0 1 1 0 1 1 1 0 0 0 1 1 DQ5 (DQ13) No 0 1 0 1 1 0 0 1 0 0 0 1 1 1 0 0 DQ6 (DQ14) Yes 1 0 1 0 0 1 1 0 1 1 1 0 0 0 1 1 DQ7 (DQ15) No 0 1 0 1 1 0 0 1 0 0 0 1 1 1 0 0 Figure 173: DQ Read Training Timing T0 T1 T2 T3 READ READ CAS-2 CAS-2 T4 T5 T6 T7 T8 T9 T10 T11 CAS-2 CAS-2 T12 T13 T14 T15 T16 T17 T18 T19 MPC MPC CAS-2 CAS-2 T20 T21 T22 T23 T24 25 T26 T27 T28 T29 T30 T31 CK_c CK_t tRTRRD CA Command READ Bank m CAS-2 col a MPC DES DES RL MPC MPC Read timing tCCD CAS-2 Dummy DES tRTRRD MPC Read timing DES CAS-2 Dummy Read DES DES Read READ Bank n CAS-2 CAS-2 Valid CAS-2 col b DES DES tDQSCK DQS_c DQS_t tRPRE DQ[7:0] DMI[0] tDQSQ D0 D1 D2 D3 m m m m D4 D5 m m D6 m D7 D8 D9 D10 D11 D12 D13 D14 D15 D0 D1 m m m m m m m m m cal cal D2 D3 D4 D5 cal cal cal cal D6 D7 D8 cal cal cal D9 D10 D11 D12 D13 D14 D15 D0 D1 D2 D3 D4 D5 cal cal cal cal cal cal cal cal cal cal cal cal cal Don’t Care 1. Array READ commands before and after MPC-READ commands are shown for illustration only and are not required. Note: On-Die Termination ODT Control ODT control is provided for the non-target DRAM to improve the signal integrity of the system. 274 200b: x32 Mobile LPDDR4XSDRAM Byte Mode A non-target DRAM is defines as one that receives a WRITE-1, MASK WRITE-1, READ-1, MODE REGISTER READ-1, MPC (only WRITE FIFO, READ FIFO and READ DQ CALIBRATION) command but does not receive a corresponding CAS-2 command (WRITE-2, MASK WRITE-2, READ-2, MODE REGISTER READ-2, MPC). The controller must issue two DES commands in place of a CAS-2 command to the non-target DRAM. The ODT mode for non-target DRAM is enabled if MR11 OP[7,3] is set to a non-zero value. The ODT mode for non-target DRAM is disabled if MR11 OP[7,3] = 00b. CKE must be HIGH to control ODT on the non-target rank. The DRAM may still be in the self refresh state but CKE has to be HIGH to control ODT on the non-target rank. WRITE-1, MASK WRITE-1, MPC (WRITE FIFO) case: • The CAS-2 command is replaced by two DES commands for the non-target DRAM. • ODT timings (ODTon and ODTLoff) are referenced to the second of the DES commands. • ODT latency values remain the same as for normal DQ ODT control as shown in ODTLon and ODTLoff Latency Values table in DQ On-Die Termination section. READ-1, MODE REGISTER READ-1, MPC (READ FIFO and READ DQ CALIBRATION) case: Refer to the table below. • The CAS-2 command is replaced by two DES commands for the non-target DRAM. • ODT timings (ODTon and ODTLoff) are referenced to the second of the DES commands. Table 211: ODTLon_rd and ODTLoff_rd Latency Values (Non Target DRAM) ODTLon_rd Latency 1, 2 Lower Clock Frequency Limit (MHz) Upper Clock Frequency Limit (MHz) Not Supported Not Supported Not Supported Not Supported 10 266 Not Supported Not Supported Not Supported Not Supported 266 533 Not Supported Not Supported Not Supported Not Supported 533 800 No DBI w/DBI ODTLoff_rd Latency No DBI w/DBI 14 16 32 34 800 1066 18 22 36 40 1066 1333 22 26 42 46 1333 1600 26 30 46 50 1600 1866 28 32 50 54 1866 2133 Notes: 1. ODTLoff_rd assumes BL = 16, for BL32, 8tCK should be added. 2. ODTLoff_rd assumes a fixed tRPST of 1.5tCK. (DRAM will assume 1.5tCK independent of MR settings) 3. ODT for non-target DRAM is optional. 275 200b: x32 Mobile LPDDR4XSDRAM Byte Mode AC Timing Table 212: Core AC Timing Data Rate Symbol Min/ Max Write recovery time tWR Min max(20ns, 4nCK) ns Write-to-Read delay tWTR Min max(12ns, 8nCK) ns Parameter 533 1066 1600 2133 2667 3200 3733 4267 Unit Table 213: CBT AC Timing for Mode 1 Min/ Max Data Rate Parameter Symbol Clock and command valid after CKE LOW tCKEKCK Min Asynchronous data read tADR Max 20ns ns CA BUS TRAINING command to CA BUS TRAINING command delay tCACD Min RU(tADR/tCK) tCK First CA BUS TRAINING command following CKE LOW tCAENT Min 250 ns Valid clock requirement before CS HIGH tCKPRECS Min 2tCK + tXP (tXP = max(7.5ns, 5nCK)) - Valid clock requirement after CS HIGH tCKPSTCS Min max(7.5ns, 5nCK) - Clock and command valid before CKE HIGH tCKCKEH Min 2 tCK CA bus training CKE HIGH to DQ tri-state tMRZ Min 1.5 ns ODT turn-on latency from CKE tCKELODTon Min 20 ns ODT turn-off latency from CKE tCKELODToff Min 20 ns Note: 533 1066 1600 2133 2667 3200 3733 4267 Unit Note tCK max(7.5ns, 3nCK) 1 1. If tCACD is violated, the data for samples which violate tCACD will not be available except for the last sample (where tCACD after this sample is met). Valid data for the last sample will be available after tADR. Table 214: AC Timing Parameters for 2 channel x8 CBT Mode Symbol Parameter Max/Min Value Unit Min 2 ns Max 10 ns 10 ns tLZDQ7H x8 CBT mode DQ[5:0] output LOW-Z time from DQ[7] HIGH tHZDQ7L x8 CBT mode DQ[5:0] output HIGH-Z time from DQ[7] LOW tDQSDQ7 x8 CBT mode VREFCA value/range strobe to DQ[7] HIGH Min 276 200b: x32 Mobile LPDDR4XSDRAM Byte Mode Table 214: AC Timing Parameters for 2 channel x8 CBT Mode (Continued) Symbol Parameter Max/Min Value Unit tDQ7DQS x8 CBT mode DQ[7] LOW to VREFCA value/range strobe Min 15 ns tDQ7CS x8 CBT mode DQ[7] HIGH to CA/CA latch Min 0 ns 277 200b: x32 Mobile LPDDR4XSDRAM Revision History Revision History Rev. B– 4/16 • • • • • • Updated IDD specifications Deleted Low-Frequency Operation section Added Monolithic Device Addressing (1 channel) in Monolithic Device Addressing Updated MR8 Op-Code Bit Definitions table in Mode Registers Updated MR17 PASR Segment Mask table in Mode Registers Updated Refresh Requirement Parameter table in Refresh Requirement Rev. A – 7/15 • Initial release 278
RS256M32LZ4D2BNP-62BT 价格&库存
很抱歉,暂时无法提供与“RS256M32LZ4D2BNP-62BT”相匹配的价格&库存,您可以联系我们找货
    • 6+20.74070
    库存:168
