BT832X
BT832X
    FANSTEL
    BT832X
BT832X 数据手册
Bluetooth 5 Modules with Amplifier, BT832X and BT832XE Ver 2.01 June 2018 BluNor BT832X is a powerful, highly flexible, Bluetooth Low Energy (BLE) using Nordic nRF52832 SoC. With an ARM CortexTM M4F MCU, available 512KB flash, 64KB RAM, embedded 2.4GHz multi-protocol transceiver, power amplifier, and an integrated PCB trace antenna, or an u.FL connector for external antenna. It allows faster time to market with reduced development cost. For applications needing limited number of IO pins, prototyping and production are easier using 16 castellated pins. Additional 24 LGA (Land Grid Array) pins provide access to 29 GPIOs of nRF52832. Line of sight range between 2 BT832X is 1170 meters. Ranges between 2 BT832XE with ANT060 external antenna is 1350 meters. Specifications:
 Nordic nRF52832 with ARM Cortex M4F. Integrated DC-DC converter, inductors on board Serial Wire Debug (SWD) Nordic SoftDevice Ready Over-the-Air (OTA) firmware update Flash/RAM: 512KB/64KB 29 GPIO pins 12 bit/200KSPS ADC, 8 configurable channels with programmable gain. 3X SPI Master/Slave (8Mbps) 3X 4-channel pulse width modulator (PWM) Low power comparator 2X 2-wire Master/Slave (I2C compatible) I2S audio interface UART (with CTS/RTS and DMA) 20 channel CPU independent Programmable Peripheral Interconnect (PPI). Quadrature Demodulator (QDEC) 128-bit AES HW encryption 5 x 32 bits, 3 x 24 bits Real Time Counters (RTC) NFC-A tag interface for OOB pairing Receiver Sensitivity: -105 dBm TX power: +20 dBm Sizes: 15.0x28.0x1.9mm Hybrid pins: 16 castellated and 24 LGA. Integrated 32.768 kHz sleep crystal BT832X with an Integrated high performance PCB trace antenna BT832XE with an u.FL for external antenna Operation voltage: 1.8V to 3.6V FCC ID: X8WBT832XE IC ID: 4100A-BT832XE QDID: 97989 Operation temperature: - 4 0 ° C t o + 8 5 ° C
 Applications
 IoT (Internet of Things) Beacons Fitness/Sports Connected appliances Lighting products Sensors Home and building automation Long range equipment tracking Drone remote control Video and audio transmission
 Model Summaries module SoC Flash/RAM BT Antenna BT832X nRF52832-QFAA 512KB/64KB PCB trace BT832XE nRF52832-QFAA 512KB/64KB u.FL Range at 1Mbps Availability 1170 meters Production 1350 meters with ANT060 Production !1 Bluetooth 5 Modules with Amplifier, BT832X and BT832XE Ver 2.01 June 2018 Table Of Contents 1. Introduction ........................................................................................................................................................3 BT832X Block Diagram ..................................................................................................................................... 3 BT832X..............................................................................................................................................................3 BT832XE with ANT060 ...................................................................................................................................... 4 Antennas ANT060 and ANT061 ........................................................................................................................4 2. Codes Development Using Nordic Tools ........................................................................................................... 5 Easy, fast and safe code development.............................................................................................................. 5 Over-The-Air DFU .............................................................................................................................................5 SoftDevices ....................................................................................................................................................... 5 Development Tools ............................................................................................................................................5 3. Product Overview .............................................................................................................................................. 6 Block Diagram of nRF52832 .............................................................................................................................6 Mechanical Drawings ........................................................................................................................................ 8 Pin Assignments of BT832X .............................................................................................................................. 9 Pin Functions ................................................................................................................................................... 10 Host PCB Layout Guidelines ........................................................................................................................... 11 Mounting BT832X on the Host PCB ................................................................................................................ 12 Control Skyworks Power Amplifier................................................................................................................... 13 4. AT Commands .................................................................................................................................................15 Brief description of AT commands ................................................................................................................... 15 Command mode .............................................................................................................................................. 16 Data Mode ....................................................................................................................................................... 19 Communicating with a PC ............................................................................................................................... 19 5. Evaluation Boards and Reference Designs .....................................................................................................19 Schematics and Gerber Files ..........................................................................................................................19 Evaluation Board EV BT832X Schematics ......................................................................................................20 6. Bluetooth Line of Sight Range Measurements ................................................................................................21 Test Conditions ............................................................................................................................................... 21 Measurement results ....................................................................................................................................... 21 Conclusions and suggestions for deployment ................................................................................................ 22 7. Miscellaneous..................................................................................................................................................23 Soldering Temperature-Time Profile for Re-Flow Soldering ............................................................................ 23 Cautions, Design Notes, and Installation Notes .............................................................................................. 23 Packaging ........................................................................................................................................................ 26 FCC Label ....................................................................................................................................................... 26 Revision History .................................................................................................................................................. 27 Contact Us ..........................................................................................................................................................28 !2 Bluetooth 5 Modules with Amplifier, BT832X and BT832XE Ver 2.01 June 2018 1. Introduction BluNor BT832X is powerful, highly flexible, ultra low power Bluetooth Low Energy (BLE) modules using Nordic nRF52832 SoCs. With an ARM CortexTM M4F MCU, available 512KB flash, 64KB RAM, embedded 2.4GHz multi-protocol transceiver, power amplifier, and an integrated antenna or an u.FL connector for external antenna, it allows faster time to market with reduced development cost. The following is a block diagram of BT832X. Antenna circuit, 32 MHz main clock, and 32.768 KHz sleep clock are integrated. Three GPIOs are used to control SKY66112 power amplifier. The other 29 GPIOs of nRF52832 can be accessed from main board. Connection to an external NFC (Near Field Communication) antenna is provided. BT832X Block Diagram A high performance PCB trace antenna is integrated on BT832X. An u.FL connector on BT832XE provides connection to an external antenna. In this data sheets, both BT832X and BT832XE can be referred as BT832X. BT832X The followings are difference between BT832X and BT832 module • Uses an nRF52832 QFAA with a Skyworks SKY66112 power amplifier • Integrated PCB trace range antenna. Average range is 1170 meters. Minimum range and Maximum range around a circle is !3 Bluetooth 5 Modules with Amplifier, BT832X and BT832XE Ver 2.01 June 2018 1060 meters and 1320 meters, respectively. • Higher power consumption • 32.768 KHz sleep clock on board • 29 GPIOs, 3 GPIOs are used to control SKY66112 • Size: 15x28x1.9mm BT832XE with ANT060 ANT060 includes an antenna with SMA connector and an SMA to u.FL adaptor cable. The SMA connector side is panel-mountable. The followings are difference between BT832XE and BT832 module • Uses an nRF52832 QFAA with a Skyworks SKY66112 power amplifier • An u.FL for external antenna. When ANT060 antenna is used, range is 1350 meters for all angles. • Higher power consumption • 32.768 KHz sleep clock on board • 29 GPIOs, 3 GPIOs are used to control SKY66112 • Size: 15x28x1.9mm Antennas ANT060 and ANT061 Two external antennas ANT060 and ANT061 are FCC and IC certified to be used with BT832XE. A photo of ANT060: A photo of ANT061: !4 Bluetooth 5 Modules with Amplifier, BT832X and BT832XE Ver 2.01 June 2018 2. Codes Development Using Nordic Tools Development tools by Nordic and other third party development tools recommended by Nordic should be used . Easy, fast and safe code development Nordic development environment for nRF52832 offers a clean separation between application code development and embedded protocol stacks. This means compile, link and run time dependencies with the embedded stack and associated debugging challenges are removed. The Bluetooth low energy and ANT stack is a pre-compiled binary, leaving application code to be compiled stand-alone. The embedded stack interface uses an asynchronous and event driven model removing the need for RTOS frameworks. Over-The-Air DFU The nRF52832 is supported by an Over-The-Air Device Firmware Upgrade (OTA DFU) feature. This allows for in the field updates of application software and SoftDevice. SoftDevices The Nordic protocol stacks are known as SoftDevices and complement the nRF52 Series SoCs. All nRF52 Series are programmable with software stacks from Nordic. This bring maximum flexibility to application development and allows the latest stack version to be programmed into the SoC. SoftDevices available from Nordic: S132: Bluetooth low energy concurrent central/peripheral/observer/broadcaster stack. Development Tools Nordic Semiconductor provides a complete range of hardware and software development tools for the nRF52 Series devices. nRF52 DK board is recommended for firmware development. Nordic software development tools can be downloaded from the following webpage. http://infocenter.nordicsemi.com/index.jsp?topic=/com.nordic.infocenter.nrf52/dita/nrf52/development/ nrf52_dev_kit.html&cp=1_1 !5 Bluetooth 5 Modules with Amplifier, BT832X and BT832XE 3. Product Overview Ver 2.01 June 2018 Brief description of nRF52832 SoC is provided. For full description of the SoC, please download from Nordic Semiconductor website. https://www.nordicsemi.com/eng/Products/Bluetooth-low-energy Block Diagram of nRF52832 The following is a block diagram of Nordic nRF52832 Bluetooth Low Energy (BLE) SoC. !6 Bluetooth 5 Modules with Amplifier, BT832X and BT832XE Ver 2.01 June 2018 The 32 bit ARM Cortex M4F MCU with hardware supports for DSP instructions and floating point operations, code density and execution speed are higher than other Cortex M MCU. The Programmable Peripheral Interconnect (PPI) system provides a 20-channel bus for direct and autonomous system peripheral communication without CPU intervention. This brings predictable latency times for peripheral to peripheral interaction and power saving benefits associated with leaving CPU idle. The device has 2 global power modes ON/OFF, but all system blocks and peripherals have individual power management control which allows for an automatic switching RUN/IDLE for system blocks based only on those required/not required to achieve particular tasks. The radio supports Bluetooth low energy and ANT. Output power is scalable from a maximum of +20dBm down to -4 dBm in 4dB steps. The NFC block supports NFC-A tags with proximity detection and Wake-on-field from low power mode. The NFC enables Out-Of-Band (OOB) Bluetooth pairing of devices and thus greatly simplifying deployment. !7 Bluetooth 5 Modules with Amplifier, BT832X and BT832XE Ver 2.01 June 2018 Mechanical Drawings The followings are mechanical drawings of BT832X. Two types of pins are available to meet different application requirements. • 16 castellated pins for application needing limited number of IOs. SMT equipment is not required for soldering castellated pins. • 24 LGA (Land Grid Array) pins to access 29 GPIOs of nRF52832 when needed. 3 GPIO pins are used to control SKY66112 power amplifier. !8 Bluetooth 5 Modules with Amplifier, BT832X and BT832XE Ver 2.01 June 2018 Pin Assignments of BT832X The followings are BT832X pin assignment. Pin functions are in a table in next section. Please refer to Nordic nRF52832 Product Specifications for detailed descriptions and features supported. http://infocenter.nordicsemi.com/pdf/nRF52832_PS_v1.1.pdf !9 Bluetooth 5 Modules with Amplifier, BT832X and BT832XE Ver 2.01 June 2018 Pin Functions BT832X pin# pin name 1 P26/SDA 2 P27/SCL 3 NC 4 NC 5 P02/AIN0 6 P03/AIN1 7 8 9 10 11 12 13 14 15 16 A0 A1 A2 A3 P09/NFC1 P10/NFC2 VDD GND P13 P18 P20 P021/RESET SWDCLK SWDIO GND P28 P29 P04 A4 A5 B0 B1 B2 B3 B4 B5 C0 C1 C2 C3 C4 C5 D0 D1 P05 P07 GND P25 P30 P31 NC P08 GND P24 P22 NC P15 P12 GND P23 D2 nRF52832 pin# pin name 38 P0.26 39 P0.27 2 P0.00/XL1 3 P0.01/XL2 4 P0.02/AIN0 5 P0.03/AIN1 11 12 13 45 16 21 23 24 25 26 45 40 41 6 Descriptions GPIO, configured as I2C SDA on EV-BT832 GPIO, configured as I2C SCL on EV-BT832 32.768kHz crystal on module 32.768kHz crystal on module GPIO, Analog input GPIO, Analog input P0.09/NFC1 P0.10/NFC2 VDD VSS P0.13 P0.18 P0.20 P0.21/RESET SWDCLK SWDIO VSS P0.28/AIN4 P0.29/AIN5 P0.04/AIN2 GPIO, NFC antenna connection GPIO, NFC antenna connection DC supply 1.7V to 3.6V Ground GPIO GPIO GPIO GPIO, configurable as RESET pin Serial Wire Debug clock input Serial Wire Debug I/O Ground GPIO, Analog input GPIO, Analog input GPIO, Analog input 9 45 37 42 43 8 10 45 29 27 20 18 15 45 28 P0.05/AIN3 P0.07 VSS P0.25 P0.30 P0.31 P0.06 P0.08 VSS P0.24 P0.22 P0.17 P0.15 P0.12 VSS P0.23 GPIO, Analog input GPIO Ground GPIO GPIO GPIO No Connect, used for SKY66112 on module GPIO Ground GPIO GPIO No Connect, used for SKY66112 on module GPIO GPIO Ground GPIO NC 22 P0.19 No Connect, used for SKY66112 on module D3 P16 19 P0.16 GPIO D4 D5 F0 P14 P11 GND 17 14 P0.14 P0.11 GPIO GPIO Ground 7 !10 Bluetooth 5 Modules with Amplifier, BT832X and BT832XE F1 F2 F3 GND GND GND Ver 2.01 June 2018 Ground Ground Ground Host PCB Layout Guidelines For the best Bluetooth range performance, we recommend using library component extracted from EV BT840F V3 or newer Gerber files. It can be downloaded from http://www.fanstel.com/download-document/. • There are 21 additional BT840F pins not used by BT832X. These pins are in solid dark color below. • As much ground plane under BT832X, on top side of host PCB as possible. Use EV BT840F/EV BT832X Gerber files as an example. • We recommend 4 or more layers for the host PCB. The top side shall be mostly ground. Signal routing shall be in the middle layers. !11 Bluetooth 5 Modules with Amplifier, BT832X and BT832XE Ver 2.01 June 2018 Mounting BT832X on the Host PCB The following figure shows recommended mounting of BT832X module on the host PCB. These mounting guidelines are not applicable for BT832XE. • For the best Bluetooth range performance, the antenna area of module shall extend 11.2 mm outside the edge of host PCB board, or 11.2 mm outside the edge of a ground plane. • Except required for pin connection, ground plane to cover top layer of main board. We recommend multiple layers main board avoiding routing on the top layer. For the best Bluetooth range performance, keep all external metal away from the antenna area. !12 Bluetooth 5 Modules with Amplifier, BT832X and BT832XE Ver 2.01 June 2018 Control Skyworks Power Amplifier BT832X uses SKYWORKS SKY66112-11 power amplifier. The connection diagram with control signal pins is below. 5 4 3 2 1 D D POWER UART Filter nRF52832 C C I2C GPIO P17 CTX P19 CRX P06 CPS BT832X PA SKY66112 ANT1 PCB ANT 1 B B X'TAL RESET 32MHz FANSTEL Corporation. A A Title BT832X Module 5 4 3 Size A Document Number Date: Wednesday, April 05, 2017 Rev 1.0 BLOCK Sheet 2 1 of 1 1 A firmware configuration example to control Skyworks SKY66112 power amplifier is below. This firmware file, SKY66112_PAconfig.txt can be downloaded from http://www.fanstel.com/download-document/. //PCA10040.h //set the clock #define NRF_CLOCK_LFCLKSRC .rc_ctiv {.source = 0, = NRF_CLOCK_LF_SRC_SYNTH, \ .rc_temp_ctiv = 0, \ .xtal_accuracy = NRF_CLOCK_LF_XTAL_ACCURACY_250_PPM} !13 \ Bluetooth 5 Modules with Amplifier, BT832X and BT832XE //main.c //config the PA/LNA #ifdef APP_PA_LAN #define APP_PA_PIN 17 #define APP_LNA_PIN 19 #define APP_CPS_PIN 6 #define APP_AMP_PPI_CH_ID_SET 0 #define APP_AMP_PPI_CH_ID_CLR 1 #define APP_AMP_GPIOTE_CH_ID 0 static void pa_lna_setup(void) { uint32_t err_code; nrf_gpio_cfg_output(APP_CPS_PIN); nrf_gpio_pin_clear(APP_CPS_PIN); //enable nrf_gpio_cfg_output(APP_PA_PIN); nrf_gpio_pin_clear(APP_PA_PIN); // nrf_gpio_cfg_output(APP_LNA_PIN); nrf_gpio_pin_clear(APP_LNA_PIN); // static ble_opt_t pa_lna_opts = { .common_opt = { .pa_lna = { .pa_cfg = { .enable = 1, .active_high = 1, !14 Ver 2.01 June 2018 Bluetooth 5 Modules with Amplifier, BT832X and BT832XE Ver 2.01 June 2018 .gpio_pin = APP_PA_PIN }, .lna_cfg = { .enable = 1, .active_high = 1, .gpio_pin = APP_LNA_PIN }, .ppi_ch_id_set = APP_AMP_PPI_CH_ID_SET, .ppi_ch_id_clr = APP_AMP_PPI_CH_ID_CLR, .gpiote_ch_id = APP_AMP_GPIOTE_CH_ID } } }; NRF_GPIO->DIRSET |= (1
BT832X 价格&库存
很抱歉,暂时无法提供与“BT832X”相匹配的价格&库存,您可以联系我们找货
BT832X
  • 1+153.577641+18.62944
  • 10+138.9848710+16.85929
  • 25+128.0130225+15.52837
  • 100+117.04086100+14.19742
  • 250+109.72580250+13.31008
  • 500+102.41089500+12.42276
BT832X
  • 1000+97.290381000+11.80162
