BT832
BT832
    FANSTEL
    BT832
BT832 数据手册
Bluetooth 5 Module BT832, BT832A, BT832F, BT832AF Ver 2.04 Dec. 2017 BluNor BT832 Series is a powerful, highly flexible, ultra low power Bluetooth Low Energy (BLE) modules using Nordic nRF52 SoC. With an ARM CortexTM M4(F) MCU, up to 512KB flash, 64KB RAM, embedded 2.4GHz multi-protocol transceiver, and an integrated PCB trace antenna. It allows faster time to market with reduced development cost. For applications needing limited number of IO pins, prototyping and production are easier using 16 castellated pins. Additional 24 LGA (Land Grid Array) pins provide full access to 32 GPIOs of nRF52832. Bluetooth 5 specifications allow reducing bandwidth to achieve up to 4X range while maintaining similar power requirements. Line of sight range between two BT832Fs is measured at 220 to 330 meters at 1Mbps data rate. Average of 12 measurements (rotate one antenna by 30o each time) is 270 meters. BT832Fs achieve longer range by superior antenna circuit and without an external power amplifier, not by reducing bandwidth. Specifications:
 Nordic nRF52 with ARM Cortex M4F. Complete RF solution with integrated antenna Integrated DC-DC converter Serial Wire Debug (SWD) Nordic SoftDevice Ready Over-the-Air (OTA) firmware update Flash/RAM: 512KB/64KB or 256KB/32KB. 32 General purpose I/O pins 12 bit/200KSPS ADC, 8 configurable channels with programmable gain. 3X SPI Master/Slave (8Mbps) 3X 4-channel pulse width modulator (PWM) Low power comparator 2X 2-wire Master/Slave (I2C compatible) I2S audio interface UART (with CTS/RTS and DMA) 20 channel CPU independent Programmable Peripheral Interconnect (PPI). Quadrature Demodulator (QDEC) 128-bit AES HW encryption 5 x 32 bits, 3 x 24 bits Real Time Counters (RTC) Available NFC-A tag interface for OOB pairing Receiver Sensitivity: -96 dBm at 1Mbps TX power: +/- 0 dBm; programmable 4 dBm to -20dBm in 4 dB steps. Hybrid pins: 16 castellated and 24 LGA. Integrated PCB trace antenna: Operation voltage: 1.7V to 3.6V Embedded inductors for DCDC converter Operation temperature: - 4 0 ° C t o + 8 5 ° C FCC ID: X8WBT832 IC ID: 4100A-BT832 CE: Certified QDID: 97989
 Applications
 Wearable Beacons/Proximity Fitness/Sports Smart toys Connected appliances Lighting products Sensors Home and building automation Key fobs Wireless charger Interactive entertainment devices
 Model Summaries module BT832 BT832A BT832F BT832AF SoC nRF52832 QFAA nRF52810 QFAA nRF52832 QFAA nRF52810 QFAA Flash/RAM 512KB/64KB 192KB/24KB 512KB/64KB 192KB/24KB Size 14x16x1.9mm 14x16x1.9mm 15x20.8x1.9mm 15x20.8x1.9mm Average Bluetooth range 100 meters 100 meters 270 meters 270 meters NFC No Yes No Yes !1 Bluetooth 5 Module BT832, BT832A, BT832F, BT832AF Ver 2.04 Dec. 2017 Table Of Contents 1. Introduction ........................................................................................................................................................3 BT832 Block Diagram........................................................................................................................................ 3 BT832 3 BT832A..............................................................................................................................................................4 BT832F ..............................................................................................................................................................4 BT832AF ........................................................................................................................................................... 4 2. Codes Development Using Nordic Tools ........................................................................................................... 5 Easy, fast and safe code development.............................................................................................................. 5 Over-The-Air DFU .............................................................................................................................................5 SoftDevices ....................................................................................................................................................... 5 Development Tools ............................................................................................................................................5 3. Product Overview .............................................................................................................................................. 6 Nordic SoCs ...................................................................................................................................................... 6 Mechanical Drawings ........................................................................................................................................ 8 Pin Assignments of BT832 .............................................................................................................................. 10 Pin Functions ................................................................................................................................................... 11 Mounting BT832 on the Host PCB .................................................................................................................. 12 Mounting BT832F on the Host PCB ................................................................................................................ 13 4. AT Commands .................................................................................................................................................14 Brief description of AT commands ................................................................................................................... 14 Command mode .............................................................................................................................................. 14 Data Mode ....................................................................................................................................................... 16 5. BT832 Evaluation Board .................................................................................................................................17 Communicating with a PC ............................................................................................................................... 17 Evaluation Board Schematics..........................................................................................................................17 Suggestion for Battery Power Application .......................................................................................................18 6. Miscellaneous..................................................................................................................................................18 Soldering Temperature-Time Profile for Re-Flow Soldering ............................................................................ 18 Cautions, Design Notes, and Installation Notes .............................................................................................. 18 Packaging ........................................................................................................................................................ 21 FCC Label ....................................................................................................................................................... 21 Revision History .................................................................................................................................................. 22 Contact Us ..........................................................................................................................................................23 !2 Bluetooth 5 Module BT832, BT832A, BT832F, BT832AF Ver 2.04 Dec. 2017 1. Introduction BluNor BT832 is powerful, highly flexible, ultra low power Bluetooth Low Energy (BLE) modules using Nordic nRF52 SoCs. With an ARM CortexTM M4F MCU, available 512KB flash, 64KB RAM, embedded 2.4GHz multiprotocol transceiver, and an integrated antenna, it allows faster time to market with reduced development cost. The following is a block diagram of BT832. Antenna circuit and main clock are integrated. All 32 GPIOs of nRF52832 can be accessed from main board. For lower power consumption at idle state, a 32.768 kHz crystal is added on the host board. Connection to an external NFC (Near Field Communication) antenna is provided. BlurNor BT832A, BT832F, and BT832AF are sister module of BT832. The foot print for for the main body of module is identical. The difference are in PCB trace antenna area and memory sizes. In this data sheets, BT832 and BT832A can be referred as BT832. BT832AF and BT832F can be referred as BT832F. All modules BT832, BT832A, BT832F, and BT832AF can be referred as BT832. BT832 Block Diagram BT832 Series modules have the same features except the followings. BT832 • Uses an nRF52832 QFAA with Cortex M4F MCU • 512KB flash, 64 KB RAM • Supports NFC • Integrated PCB trace range antenna. Average range is 100 meters. Minimum range and Maximum range around a circle is 75 meters and 140 meters, respectively. • Size: 14x16x1.9mm. !3 Bluetooth 5 Module BT832, BT832A, BT832F, BT832AF Ver 2.04 Dec. 2017 BT832A • Uses an nRF52810 QFAA with Cortex M4 MCU • 192 KB flash, 24 KB RAM • Does not support NFC • Integrated PCB trace range antenna. Average range is 100 meters. Minimum range and Maximum range around a circle is 75 meters and 140 meters, respectively. • Size: 14x16x1.9mm. BT832F • Uses an nRF52832 QFAA with Cortex M4F MCU • 512KB flash, 64 KB RAM • Supports NFC • Integrated PCB trace range antenna. Average range is 270 meters. Minimum range and Maximum range around a circle is 220 meters and 330 meters, respectively. • Size: 15x20.8x1.9mm. BT832AF • Uses an nRF52810 QFAA with Cortex M4 MCU • 192 KB flash, 24 KB RAM • Does not support NFC • Integrated PCB trace range antenna. Average range is 270 meters. Minimum range and Maximum range around a circle is 220 meters and 330 meters, respectively. • Size: 15x20.8x1.9mm
 !4 Bluetooth 5 Module BT832, BT832A, BT832F, BT832AF Ver 2.04 Dec. 2017 2. Codes Development Using Nordic Tools Development tools by Nordic and other third party development tools recommended by Nordic should be used . Easy, fast and safe code development Nordic development environment for nRF52 offers a clean separation between application code development and embedded protocol stacks. This means compile, link and run time dependencies with the embedded stack and associated debugging challenges are removed. The Bluetooth low energy and ANT stack is a pre-compiled binary, leaving application code to be compiled stand-alone. The embedded stack interface uses an asynchronous and event driven model removing the need for RTOS frameworks. Over-The-Air DFU The nRF52 SoC is supported by an Over-The-Air Device Firmware Upgrade (OTA DFU) feature. This allows for in the field updates of application software and SoftDevice. SoftDevices The Nordic protocol stacks are known as SoftDevices and complement the nRF52 Series SoCs. All nRF52 Series are programmable with software stacks from Nordic. This bring maximum flexibility to application development and allows the latest stack version to be programmed into the SoC. SoftDevices available from Nordic: S132: Bluetooth low energy concurrent central/peripheral/observer/broadcaster stack. Development Tools Nordic Semiconductor provides a complete range of hardware and software development tools for the nRF52 Series devices. nRF52 DK board is recommended for firmware development. !5 Bluetooth 5 Module BT832, BT832A, BT832F, BT832AF Ver 2.04 Dec. 2017 3. Product Overview Nordic SoCs For full description of the SoC, please download data sheets from Nordic Semiconductor website. https://www.nordicsemi.com/eng/Products/Bluetooth-low-energy The following is a block diagram of Nordic nRF52832 Bluetooth Low Energy (BLE) SoC. NFC is not supported in nRF52810. !6 Bluetooth 5 Module BT832, BT832A, BT832F, BT832AF Ver 2.04 Dec. 2017 The 32 bit ARM Cortex M4F MCU with hardware supports for DSP instructions and floating point operations, code density and execution speed are higher than other Cortex M MCU. The Programmable Peripheral Interconnect (PPI) system provides a 20-channel bus for direct and autonomous system peripheral communication without CPU intervention. This brings predictable latency times for peripheral to peripheral interaction and power saving benefits associated with leaving CPU idle. The device has 2 global power modes ON/OFF, but all system blocks and peripherals have individual power management control which allows for an automatic switching RUN/IDLE for system blocks based only on those required/not required to achieve particular tasks. The radio supports Bluetooth low energy and ANT. Output power is scalable from a maximum of +4dBm down to -20 dBm in 4dB steps. Sensitivity is increased to -96 dBm to -89 dBm, depending on data rate. Sensitivity for BLE is -96 dBm, and -92.5 dBm for ANT. The NFC block supports NFC-A tags with proximity detection and Wake-on-field from low power mode. The NFC enables Out-Of-Band (OOB) Bluetooth pairing of devices and thus greatly simplifying deployment. !7 Bluetooth 5 Module BT832, BT832A, BT832F, BT832AF Ver 2.04 Dec. 2017 Mechanical Drawings The followings are mechanical drawings of BT832 and BT832F. The bottom portion of module is the main body (size: 14.0 x 9.57mm) with electronic components and pins for connection to the host board. The top portion of module is for integrated PCB trace antenna. BT832 and BT832F have identical main body. BT832F has a larger antenna area to accommodate a higher performance antenna. We recommend layout the host PCB with clearance for the larger antenna area of BT832F. If the ultra long Bluetooth line of sight range of BT832F is not required, the lower cost BT832 can be installed. Two types of pins are available to meet different application requirements. • 16 castellated pins for application needing limited number of IOs. SMT equipment is not required for soldering castellated pins. • 24 LGA (Land Grid Array) pins to access all 32 GPIOs of nRF52832 when needed. BT832 and BT832A mechanical drawing, top view !8 Bluetooth 5 Module BT832, BT832A, BT832F, BT832AF BT832F and BT832AF mechanical drawing, top view !9 Ver 2.04 Dec. 2017 Bluetooth 5 Module BT832, BT832A, BT832F, BT832AF Ver 2.04 Dec. 2017 Pin Assignments of BT832 The followings are BT832 pin assignment. Pin functions are in a table in next section. Please refer to Nordic nRF52832 Product Specifications for detailed descriptions and features supported. http://infocenter.nordicsemi.com/pdf/nRF52832_PS_v1.1.pdf !10 Bluetooth 5 Module BT832, BT832A, BT832F, BT832AF Ver 2.04 Dec. 2017 Pin Functions BT832 pin# pin name 1 P26/SDA 2 P27/SCL 3 P00/XL1 4 P01/XL2 5 P02/AIN0 6 P03/AIN1 nRF52832/nRF52810 pin# pin name 38 P0.26 39 P0.27 2 P0.00/XL1 3 P0.01/XL2 4 P0.02/AIN0 5 P0.03/AIN1 7 8 9 10 11 12 13 14 15 16 A0 A1 A2 A3 P09/NFC1 P10/NFC2 VDD GND P13 P18 P20 P021/RESET SWDCLK SWDIO GND P28 P29 P04 A4 P05 7 A5 B0 B1 B2 B3 B4 B5 C0 C1 C2 C3 C4 C5 D0 D1 P07 GND P25 P30 P31 P06 P08 GND P24 P22 P17 P15 P12 GND P23 D2 Descriptions GPIO, configured as I2C SDA on EV-BT832 GPIO, configured as I2C SCL on EV-BT832 GPIO, connection for 32.768kHz crystal GPIO, connection for 32.768kHz crystal GPIO, Analog input GPIO, Analog input P0.09/NFC1 P0.10/NFC2 VDD VSS P0.13 P0.18 P0.20 P0.21/RESET SWDCLK SWDIO VSS P0.28/AIN4 P0.29/AIN5 P0.04/AIN2 GPIO, NFC antenna connection (nRF52832 only) GPIO, NFC antenna connection (nRF52832 only) DC supply 1.7V to 3.6V Ground GPIO GPIO GPIO GPIO, configurable as RESET pin Serial Wire Debug clock input Serial Wire Debug I/O Ground GPIO, Analog input GPIO, Analog input GPIO, Analog input P0.05/AIN3 GPIO, Analog input 9 45 37 42 43 8 10 45 29 27 20 18 15 45 28 P0.07 VSS P0.25 P0.30 P0.31 P0.06 P0.08 VSS P0.24 P0.22 P0.17 P0.15 P0.12 VSS P0.23 GPIO Ground GPIO GPIO GPIO GPIO GPIO Ground GPIO GPIO GPIO GPIO GPIO Ground GPIO P19 22 P0.19 GPIO D3 P16 19 P0.16 GPIO D4 D5 P14 P11 17 14 P0.14 P0.11 GPIO GPIO 11 12 13 45 16 21 23 24 25 26 45 40 41 6 !11 Bluetooth 5 Module BT832, BT832A, BT832F, BT832AF Ver 2.04 Dec. 2017 Mounting BT832 on the Host PCB The following figure shows recommended mounting of BT832 module on the host PCB. • For the best Bluetooth range performance, the antenna area of module shall extend 6 mm outside the edge of host PCB board, or 6 mm outside the edge of a ground plane. • The next choice is to place module on a corner of host PCB, the antenna area shall extend 6mm from the edge of ground plane. Ground plane shall be at least 5 mm from the edge of the antenna area of module. • Bluetooth range performance is degraded if a module is placed in the middle of the host PCB. !12 Bluetooth 5 Module BT832, BT832A, BT832F, BT832AF Ver 2.04 Dec. 2017 Mounting BT832F on the Host PCB The following figure shows recommended mounting of BT832F module on the host PCB. • For the best Bluetooth range performance, the antenna area of module shall extend 11.2 mm outside the edge of host PCB board, or 11.2 mm outside the edge of a ground plane. • The next choice is to place a module on a corner of host PCB, the antenna area shall extend 11.2 mm from the edge of ground plane. Ground plane shall be at least 5 mm from the edge of the antenna area of module. • We don’t recommend mounting BT832F module in the middle of a host PCB. For the best Bluetooth range performance, keep all external metal at least 30mm from the antenna area. !13 Bluetooth 5 Module BT832, BT832A, BT832F, BT832AF Ver 2.04 Dec. 2017 4. AT Commands AT command firmware for BT832 Series module is available. Please email info@fanstel.com. Brief description of AT commands • Each command line consists of a prefix, a body and a terminator. • All command lines begin with the prefix AT (ASCII 065, 084) or at (ASCII 097, 116). • The body is a string of characters in the ASCII range 032-255. Control characters other than (carriage return; ASCII 013) and (back space; ASCII 008) in a command line are ignored. • The terminator is . • There is no distinction between upper-case and lower-case characters. A command line can have a maximum length of 80 characters. It is automatically discarded if the input is longer. Corrections are made • AT command is case-insensitive, following /r/n for end code. • The default baud rate is 9600 one stop bit and no parity Command mode When P0.03 of nRF52832 (pin 6 of BT832) is pulled high, it is set to AT command mode. In AT command mode, the host processor communicates with the processor on BT832. Command Response Parameter example AT OK or FAIL none AT+RESET OK or FAIL none +VERSION: Software version number AT+VERSION?/r/n Device name AT+NAME?/r/n AT+VERSION? AT+NAME? OK +NAME: OK AT/r/n OK/r/n AT+RESET/r/n OK/r/n +VERSION140804 OK/ r/n +NAME:EZPro OK/r/n AT+NAME=Fanstel/r/n AT+NAME= Device name OK or FAIL Or AT_Name=”Fanstel”/r/n OK/r/n AT+UART? +UART:,, OK !14 Baud rate, AT+UART?/r/n Stop bit, +UART:115200,1,0 Parity OK/r/n Bluetooth 5 Module BT832, BT832A, BT832F, BT832AF Ver 2.04 Dec. 2017 AT+UART=115200/r/n +UART:115200,1,0 OK/r/n 1200 2400 4800 9600 default AT+UART= +UART: 19200 Baud rate 38400 57600 115200 230400 460800 921600 1000000 AT+ADDR? +ADDR: OK Device MAC address AT+REGISTER OK or FAIL none AT+QUITREGISTER OK or FAIL none AT+RX? AT+ADDR?/r/n +ADDR:abb5:cd: 604ace OK/r/n AT+REGISTER/r/n OK/r/n AT+QUITREGISTER/r/n OK/r/n +Name: AT+RX?/r/n +UART: +NAME:EZPro/r/n none +ADDR: +UART:115200,1,1/r/n +ADDR: abb5:cd: 604ace/r/n AT+DEFAULT OK or FAIL none AT+DEFAULT/r/n OK/r/n AT+RFPW?/r/n +RFPW:-4 OK/r/n 0:+4 AT_RFPW? +RFPW:parm +4~-8 1:+0 default 2:-4 3:-8 !15 Bluetooth 5 Module BT832, BT832A, BT832F, BT832AF Ver 2.04 Dec. 2017 AT+RFPW= 1/r/n OK/r/n 0:+4 AT_RFPW= OK or FAIL +4~-8 1:+0 2:-4 3:-8 AT+PIO= OK or FAIL AT+PIS= OK or FAIL P00-P05 AT+PIO=05, 0\r\n 1=High , 0=low OK/r/n P00-P05 AT+PIS=05, 1\r\n 1=output, 0=input OK/r/n Data Mode When P0.03 of nRF52832 (pin 6 of BT832) is pulled low, it is set to data mode. In data model, BT832 provides transparent data transfer between the host processor and a remote device, for example, a smartphone. !16 Bluetooth 5 Module BT832, BT832A, BT832F, BT832AF Ver 2.04 Dec. 2017 5. BT832 Evaluation Board Communicating with a PC A quick and easy way to evaluate BT832 is to use a PC as the host processor. Connect the development board EV-BT832 to a PC with an USB cable. Then, • • Set S1, BT832 is set to command mode. PC will communicate with BT832. Set switch S1 to the other position, BT832 is set to data mode. PC will communicate with a remote device through BT832 Bluetooth wireless connection. Docklight is a testing, analysis and simulation tool for serial communication protocols (RS232, RS485/422 and others). It allows you to monitor the communication between two serial devices or to test the serial communication of a single device. Docklight significantly increases productivity in a broad range of industries, including automation and control, communications, automotive, equipment manufacturers, and embedded / consumer products. Docklight is easy to use and runs on almost any standard PC using Windows 10, Windows 8, Windows 7, Windows Vista or Windows XP operating system. Docklight software can be downloaded from the following: http://www.docklight.de/download_en.htm 5 4 VDD VDD 3 2 1 R1 220R VDD VDD R3 220R U1 24CS02 P26 1 P27 2 P027/SCL 3 P000/XL1 4 P001/XL2 P01 SW1 Y1 32.768KHz 2 4 3 1 2 OFF ON A0 B0 C0 D0 A1 B1 C1 D1 A2 B2 C2 D2 A3 B3 C3 D3 P026/SDA P02 5 P03 6 P003/AIN1 P09 7 P009 P10 8 P010/NFC2 P002/AIN0 A4 A5 B4 C4 B5 C5 D4 D5 SWDIO 16 SWDIO SWCLK 15 SWCLK P021/RESET 14 P21 P020/LED 13 P20 P018 12 P18 P013 11 P13 GND 10 VDD 9 LED2 C LED1 P00 P01 P02 P03 P04 P05 P06 P07 P08 P09 P10 P11 P12 P13 P14 P15 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 P16 P17 P18 P19 P20 P21 P22 P23 P24 P25 P26 P27 P28 P29 P30 P31 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 CON16 CON18 GND 1 VDD D 1 S1 VDD RESET1 C A0 B0 C0 D0 A1 A2 A3 A4 A5 B1 B2 B3 B4 B5 C1 C2 C3 C4 C5 D1 D2 D3 D4 D5 1 VSS1 VSS2 VSS3 VSS4 P28 P29 P04 P05 P07 P25 P30 P31 P06 P08 P24 P22 P17 P15 P12 P23 P19 P16 P14 P11 C2 12pF nop C J2 J1 A U2 BT832/BT832F P00 C1 12pF nop VDD VDD R4 10K C D R2 10K 8 7 6 5 VCC WP SCL SDA A0 A1 A2 VSS A 1 2 3 4 VDD 2 2 R5 220R GND GND 3 P28 P29 P04 P05 P07 P25 P30 P31 P06 P08 P24 P22 P17 P15 P12 P23 P19 P16 P14 P11 S2 AT_COM R6 10K 2 1 GND VR1 100K P02 ADC GND P03 GND GND L1 SW2 J3 MICRO UART_TX UART_RX 14 13 12 11 10 9 8 S3 S1 CT1 10uF/10V GND 5 GND GND C7 1uF GND 5 3 EN 5 NC 4 GND 2 R7 100K VDD SW3 VO 4 3 1 2 OFF ON C3 10uF / 10V C4 10nF C5 10uF / 10V 2 4 VI BT1 CR2032 GND GND GND GND GND DEBUG - IN 1 3 5 7 9 J4 mini USB C8 0.1uF JS1 VDD GND RST C6 0.1uF 3 1 GND + A R8 10K / 1% 2 VIN 4 1 5V 2 D- NC CTS RTS RXD TXD DSR DTR GND 3 5V NC NC SUSPEND SUSPEND NC RST VBUS 4 D- 1 2 3 4 5 6 7 D+ DCD RI GND D+ DVDD REGIN 120OHM ID NC NC NC NC NC NC NC 5 G 21 20 19 18 17 16 15 2 U3 TCR3DF33 1 D+ L2 1 CP2102 120OHM B S4 S2 5VIN U4 2 S2 S4 22 23 24 25 26 27 28 29 GND 1 S1 S3 1 2 OFF ON ID 4 3 USB TO UART CONVERSION G B 5VIN GND 1 3 5 7 9 A 2 4 6 8 10 2 4 6 8 10 3.5x6.2mm SMD SWDIO SWCLK P18 JS2 P21 1 2 3 4 VDD CON4 GND GND 4 3 Evaluation Board Schematics !17 1 2 3 4 2 FANSTEL Corporation. Title NRF52832 EVM Size B Document Number Date: Tuesday, November 15, 2016 Rev 1.0 nRF52832 EVM Sheet 1 1 of 1 Bluetooth 5 Module BT832, BT832A, BT832F, BT832AF Ver 2.04 Dec. 2017 Suggestion for Battery Power Application Standby current consumption is important for battery-powered product. We suggest adding a 32.768 kHz crystal and 2 capacitors as shown in the upper left corner of the evaluation board schematics. The 32MHz main clock won’t be active at idle state to save power. Two inductors required for DCDC converter are inside BT832 module. You can enable DCDC to lower power consumption. 6. Miscellaneous Soldering Temperature-Time Profile for Re-Flow Soldering Maximum number of cycles for re-flow is 2. No opposite side re-flow is allowed due to module weight. Cautions, Design Notes, and Installation Notes Failure to follow the guidelines set forth in this document may result in degrading of the product’s functions and damage to the product. Design Notes (1)Follow the conditions written in this specification, especially the control signals of this module. (2)The supply voltage has to be free of AC ripple voltage (for example from a battery or a low noise regulator output). For noisy supply voltages, provide a decoupling circuit (for example a ferrite in series connection and a bypass capacitor to ground of at least 47uF directly at the module). (3)This product should not be mechanically stressed when installed. (4)Keep this product away from heat. Heat is the major cause of decreasing the life of these products. (5)Avoid assembly and use of the target equipment in conditions where the products' temperature may exceed the maximum tolerance. !18 Bluetooth 5 Module BT832, BT832A, BT832F, BT832AF Ver 2.04 Dec. 2017 (6)The supply voltage should not be exceedingly high or reversed. It should not carry noise and/or spikes. (7)this product away from other high frequency circuits. Notes on Antenna and PCB Layout (1)Don’t use a module with internal antenna inside a metal case. (2)For PCB layout: • • • Avoid running any signal line below module whenever possible, No ground plane below antenna, If possible, cut-off the portion of main board PCB below antenna. Installation Notes (1)Reflow soldering is possible twice based on the time-temperature profile in this data sheets. Set up the temperature at the soldering portion of this product according to this reflow profile. (2)Carefully position the products so that their heat will not burn into printed circuit boards or affect the other components that are susceptible to heat. (3)Carefully locate these products so that their temperatures will not increase due to the effects of heat generated by neighboring components. (4)If a vinyl-covered wire comes into contact with the products, then the cover will melt and generate toxic gas, damaging the insulation. Never allow contact between the cover and these products to occur. (5)This product should not be mechanically stressed or vibrated when reflowed. (6)If you want to repair your board by hand soldering, please keep the conditions of this chapter. (7)Do not wash this product. (8)Refer to the recommended pattern when designing a board. (9)Pressing on parts of the metal cover or fastening objects to the metal will cause damage to the unit. (10)For more details on LGA (Land Grid Array) soldering processes refer to the application note. Usage Condition Notes (1)Take measures to protect the unit against static electricity. If pulses or other transient loads (a large load applied in a short time) are applied to the products, check and evaluate their operation before assembly on the final products. (2)Do not use dropped products. (3)Do not touch, damage or soil the pins. (4) Follow the recommended condition ratings about the power supply applied to this product. (5)Electrode peeling strength: Do not add pressure of more than 4.9N when soldered on PCB (6) Pressing on parts of the metal cover or fastening objects to the metal cover will cause damage. (7) These products are intended for general purpose and standard use in general electronic equipment, such as home appliances, office equipment, information and communication equipment. !19 Bluetooth 5 Module BT832, BT832A, BT832F, BT832AF Ver 2.04 Dec. 2017 Storage Notes (1)The module should not be stressed mechanically during storage. (2)Do not store these products in the following conditions or the performance characteristics of the product, such as RF performance will be adversely affected: • Storage in salty air or in an environment with a high concentration of corrosive gas. • Storage in direct sunlight • Storage in an environment where the temperature may be outside the range specified. • Storage of the products for more than one year after the date of delivery storage period. (3) Keep this product away from water, poisonous gas and corrosive gas. (4) This product should not be stressed or shocked when transported. (5) Follow the specification when stacking packed crates (max. 10). Safety Conditions These specifications are intended to preserve the quality assurance of products and individual components. Before use, check and evaluate the operation when mounted on your products. Abide by these specifications, without deviation when using the products. These products may short-circuit. If electrical shocks, smoke, fire, and/or accidents involving human life are anticipated when a short circuit occurs, then provide the following failsafe functions, as a minimum. (1)Ensure the safety of the whole system by installing a protection circuit and a protection device. (2)Ensure the safety of the whole system by installing a redundant circuit or another system to prevent a dual fault causing an unsafe status. Other Cautions (1)This specification sheet is copyrighted. Reproduction of this data sheets is permissible only if reproduction is without alteration and is accompanied by all associated warranties, conditions, limitations, and notices. (2)Do not use the products for other purposes than those listed. (3)Be sure to provide an appropriate failsafe function on your product to prevent an additional damage that may be caused by the abnormal function or the failure of the product. (4)This product has been manufactured without any ozone chemical controlled under the Montreal Protocol. (5)These products are not intended for other uses, other than under the special conditions shown below. Before using these products under such special conditions, check their performance and reliability under the said special conditions carefully to determine whether or not they can be used in such a manner. • In liquid, such as water, salt water, oil, alkali, or organic solvent, or in places where liquid may splash. • In direct sunlight, outdoors, or in a dusty environment • In an environment where condensation occurs. • In an environment with a high concentration of harmful gas. !20 Bluetooth 5 Module BT832, BT832A, BT832F, BT832AF Ver 2.04 Dec. 2017 (6) If an abnormal voltage is applied due to a problem occurring in other components or circuits, replace these products with new products because they may not be able to provide normal performance even if their electronic characteristics and appearances appear satisfactory. (7) When you have any question or uncertainty, contact Fanstel. Packaging Production modules are delivered in reel, 1000 modules in each reel. FCC LABEL The Original Equipment Manufacturer (OEM) must ensure that the OEM modular transmitter must be labeled with its own FCC ID number. This includes a clearly visible label on the outside of the final product enclosure that displays the contents shown below. If the FCC ID is not visible when the equipment is installed inside another device, then the outside of the device into which the equipment is installed must also display a label referring to the enclosed equipment The end product with this module may subject to perform FCC part 15 unintentional emission test requirement and be properly authorized. This device is intended for OEM integrator only. !21 Bluetooth 5 Module BT832, BT832A, BT832F, BT832AF Revision History • December 2017, Ver. 2.04: Update module photos !22 Ver 2.04 Dec. 2017 Bluetooth 5 Module BT832, BT832A, BT832F, BT832AF Contact Us United States: Fanstel Corp. 7466 E. Monte Cristo Ave. Scottsdale AZ 85260 Tel. 1 480-948-4928 Fax. 1-480-948-5459 Email: info@fanstel.com Website: www.fanstel.com Taiwan: Fanstel Corp. 10F-10, 79 Xintai Wu Road Xizhu, New Taipei City, Taiwan 22101 泛世公司 臺灣省新北市汐止區新臺五路79號10樓之10, 22101 Tel. 886-2-2698-9328 Fax. 886-2-2698-4813 Email: info@fanstel.com Website: www.fanstel.com China: Fanstel Technologies Corp. 11 Jiale Street Ping-Dih, Long-Gang, Shen Zhen, GD 518117 泛世康科技(深圳)有限公司 廣東省深圳市龍崗區坪地鎮佳樂街11號 Tel. 86-755-8409-0928 Fax. 86-755-8409-0973 QQ. 3076221086 Email: info@fanstel.com Website: www.fanstel.com !23 Ver 2.04 Dec. 2017
BT832 价格&库存
很抱歉,暂时无法提供与“BT832”相匹配的价格&库存,您可以联系我们找货
