USB2066-05-RBHM-15-STB-00-01-A 数据手册
4.40
3.20
H
0.80
9.9
0.50
Pin 5
4.45
.90
3.00
2x Ø0
0.05+0.05
-0.10
9.4
9.2
4x 2.00
5.50
G
2.30
4x 2.50
Pin 1
2.95
0.10
F
Specifications:
Detail A
Scale 2:1
7.70 ref.
8.90
Recommended P.C.B Layout
General Tolerance: ±0.05
as viewed from component side
6.90+0.05
-0.04
E
5.45 ref.
1.10±0.10
Solder Area
3.90 ref.
D
4.00
3.10+0.05
-0.04
1.60
4.60±0.05
Component Outline
Plating:
Contact Terminal plating:
Underplating: Nickel all over
Contact Area: 15µ" Gold
Solder Tails: Bright Tin
Metallic Shell plating: Matte Tin 50µ" all over
Underplating: Nickel 50µ" all over
Detail A
Pin 5
Pin 1
5.87±0.10
C
Ordering Grid
5.85
USB2066
05
RBHM
0.80
XX
00
0.40±0.05
0.80
Request Samples
and Quotation
Packing Options
A = Tape & Reel (With Mylar)
(Quantity per Reel: 750 pcs)
Optional Post
01 = With Post
00 = Without Post
Offset
00 = No Offset
Product Description
Mini USB Receptacle, Type B, 5 Pin, SMT, Horizontal,
Optional Post, 9.40mm Length
4th June 2009
By
Detail
Revision
Date
3
4
Mechanical:
Mating Force: 35N (3.57Kgf) Max.
Unmating Force: Initial 7N (0.71Kgf) Min.
Final 3N (0.31Kgf) Min.
Durability: 5,000 Cycles
USB2066
4.40±0.05
2
Electrical:
Voltage Rating: 30VDC
Current Rating: 1A
Operating Temperature: -50°C to +85°C
Contact Resistance: 50m Max.
Insulation Resistance: 100M Min
Dielectric Withstanding Voltage:
100VAC for 1 minute, No Discharge or Flash
Part Number
Drawing Date
3.20
1
A
Contact Plating
15 = 15u" Gold
Optional post
A
STB
15
No. of Contacts
05
1.55
B
5.45
2x Ø
Materials:
Plastic Housing: LCP UL94V-0, Black
Contact Terminal: Phosphor Bronze,T=0.25mm
Metallic Shell: Brass,T=0.4mm
5
CC
Tolerances (Except as Noted)
USB2066
D PCN
D1
17/01/20
X.° ± 1°
X.X ± 0.35
X.XX ± 0.25 X.X° ± 0.5°
X.XXX ± 0.150 X.XX° ± 0.25°
Length
Angle
6
Units:
Metric (mm)
C
3rd Angle Projection
7
This drawing is confidential and
copyright of Global Connector
Technology, Ltd (GCT).
This drawing must not be copied
or disclosed without written
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
LYH
8
Sheet No.
1/2
16.0
.5 0
ø1
4.0
11.50
24.0
H
Mylar
G
5.5
11 reels / PE Bag
Direction of unreeling
F
50
29.5
Mi 16
n 5°
ø330
Cover Tape
E
Q'TY
(750pcs)
Reel
PE Bag
18
0° Peel off angle
160mm Min
(10pcs)
Total Quantity
8250 pcs
Pcs / Reel Reels / Carton
750
11
400mm Min.
(25pcs)
Void filler
D
Inner Carton
Inner Carton
Outer Carton
Holes
C
Cover Tape
B
Label
RoHS Label
375mm
350mm
Carrier Tape
35
0m
m
Label
m
0m
35
Label
Product Description
USB2066
4th June 2009
By
Detail
Revision
Date
1
2
3
4
m
5m
36
Part Number
Drawing Date
A
36
5m
m
5
CC
USB2066
D PCN
D1
17/01/20
Length
Angle
Units:
Metric (mm)
C
6
7
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
LYH
8
Sheet No.
2/2
USB2066-05-RBHM-15-STB-00-01-A 价格&库存
很抱歉,暂时无法提供与“USB2066-05-RBHM-15-STB-00-01-A”相匹配的价格&库存,您可以联系我们找货
