0.50
6x 0.50
4x 0.60
12x 1.15
6.40
4.80
3.50
H
8x 0.30
A1 B12 A4 B9
G
B8
A5
A6
B7
A7
B6
A8
B5
B1 A12
B4 A9
2x 3.93
Ø0.65
4x2.18
F
Solder Area
E
3.26
Plug
6.28±0.30
6.5 Max.
C
Ø0.50±0.05
1.42±0.15
B6
A8
B5
B4 A9
B1
A12
16x 0.20
4x 0.45
2x 0.25
2x 0.75
2x 1.25
2x 1.75
2x 2.40
First
A4
VBUS
First
B9
VBUS
First
A5
CC1
Second
B8
SBU2
Second
A6
Dp1
Second
B7
Dn2
Second
A7
Dn1
Second
B6
Dp2
Second
A8
SBU1
Second
B5
CC2
Second
A9
VBUS
First
B4
VBUS
First
First
B1
GND
GND
First
GND
SHELL
GND
Ordering Grid
USB4110
GF
A
Contact Plating
GF = Gold Flash
2
Request Samples
and Quotation
Packing Options
A = Tape & Reel
Part Number
Product Description
USB4110
USB Type C Receptacle for USB 2.0
SMT Type, PCB Top Mount
Drawing Date
10th July 2019
By
(1,200 per reel)
6.40
1
GND
Mechanical & Environmental
Operating Temperature: -40°C to +85°C
Mating Force: 5 to 20 N.
Unmated Force: 6 to 20 N after test
Durability: 10,000 cycles
Plug and Receptacle Mating View
B
A
B12
5.00A collectively for VBUS pins
6.25A collectively for GND pins
1.25A for B5 pin
0.25A per pin for all other pins
Voltage Rating: 20V DC
Contact Resistance: 40mΩ max initial.
50mΩ max after test
Dielectric Withstanding Voltage: 100V AC,1 minute
Insulation Resistance: 100MΩ min
1.85 Min
A7
First
Electrical
Current Rating:
3.93
0.63
2.85
11.30±0.30
A6
GND
Plating
Contact: Gold Flash over 50µ" min. Nickel
Solder Tails: Gold Flash over 50µ" min. Nickel
Shell: 50µ" min. Nickel
0.10
5.78±0.08
B7
A1
Material
Insulator: High Temp. Plastic UL 94V-0, Black
Contact: Copper Alloy
Shell: Stainless steel
Mid Plate: Stainless Steel
7.35±0.30
B1
A5
Mating
Sequence
Specifications
Component Outline
3.16
0.10
1.68±0.20
2.56±0.04
A12
B12
B8
Signal
Tolerance:±0.05mm
7.70±0.30
8.34+0.06
-0.02
A1 B12 A4 B9
Pin
SHELL
Recommended PCB Layout
As viewed from component side
D
Mating
Sequence
5.78
10.22
8.94
A1
Signal
A12
2x 2.85
4x 2.00
GCT
Pin
3
4
Detail
Revision
Date
5
CC
USB4110
B PCN
B2
27/12/21
Tolerances (Except as Noted)
Length
Angle
X. ± 0.50
X.X ± 0.30
X.XX ± 0.20
X.XXX ± 0.10
± 2°
Units:
Metric (mm)
C
3rd Angle Projection
6
7
This drawing is confidential and
copyright of Global Connector
Technology, Ltd (GCT).
This drawing must not be copied
or disclosed without written
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
CC
8
Sheet No.
1/2
H
30.4
Label
24.4
400
Tape & Reel
min.
Peeling Angle
165° ~ 180°
Ø330
G
Vacuum Bag
F
20 pcs empty
20 pcs empty
Unloaded Section
Product Loaded Section
Unloaded Section
User Direction of Unreeling
Void filler
1.75±0.10
11.50±0.10
E
2.00±0.10
4.00±0.10
10
+0.
.00
.50 -0
Ø1
12.00±0.10
24.00±0.30
D
Box dimensions
340mm x 340mm x 295mm
C
Notes:
Peeling off force of top tape: 0.1-1.3N (Peeling direction as shown)
B
Materials:
Carrier Tape: Polystyrene (PS)
Top Tape: PE
Reel Tape: Polystyrene (PS)
Bag: PE
A
Part Number
Product Description
USB4110
Drawing Date
10th July 2019
By
Detail
1
2
3
4
Reels /
Carton
9
Pcs /
Reel
1200
Revision
Date
5
CC
USB4110
B PCN
B2
27/12/21
Length
Angle
X. ± 0.50
X.X ± 0.30
X.XX ± 0.20
X.XXX ± 0.10
± 2°
Units:
Metric (mm)
C
6
7
Total
Qualtity
10800 pcs
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
CC
8
Sheet No.
2/2
很抱歉,暂时无法提供与“USB4110-GF-A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+11.492291+1.39252
- 10+9.7321510+1.17924
- 25+9.3357225+1.13121
- 50+9.1380350+1.10725
- 100+8.74130100+1.05918
- 250+7.94636250+0.96286
- 500+7.15177500+0.86658
