Technical Data Sheet
RF_35/05.10/6.0
Dieses Dokument ist urheberrechtlich geschützt ● This document is protected by copyright ● Rosenberger Hochfrequenztechnik GmbH & Co. KG
RIGHT ANGLE
RosenbergerHSD® PLUG
FOR PCB
D4S20D-40MA5-Y
e
All dimensions are in mm; tolerances according to ISO 2768 m-H
EMC-screening must be assured by chassis compartment. Control box manufacturer is responsible for EMCscreening.
Interface
According to
RN 059-01
Documents
Pinning instruction
Panel piercing
Test specification
RN 053-01
MB_215
RN 061-01
Material and plating
Connector parts
Center contact
Material
Spring bronze
Outer contact
Brass
Dielectric
Housing
Cover
LCP
PA 6T/66
Alpaca
P.O.Box 1260
D-84526 Tittmoning
Germany
www.rosenberger.de
Plating
Gold, 0.15 µm (Interface)
Tin, 0.5-2 µm (PCB)
Ni, 3-6 µm (Interface)
d
Tin, 3-6 µm (PCB)
Tel. : +49 8684 18-0
Fax : +49 8684 18-499
Email : info@rosenberger.de
c
Page
1/3
RIGHT ANGLE
FOR PCB
D4S20D-40MA5-Y
Electrical data
RF_35/05.10/6.0
Impedance, differential mode
Frequency
Return loss
Insertion loss
Skew (between signal contacts)
Nearend-Crosstalk
Farend-Crosstalk
Insulation resistance
Signal contact resistance
Outer contact resistance
Test voltage
Working voltage
Power current
RF-leakage ( shielding effectiveness )
100 differential signalling, for one pair or quad cable shielded
DC to 2.0 GHz
20 dB to 1.0 GHz
17 dB to 2.0 GHz
0.1 dB @ 1.0 GHz
5 psec.
30 dB
35 dB
1x103 M
10 m
7.5 m
250 V rms
100 V rms
1.5 A DC
75 dB up to 1 GHz (IEC 62153-4-7)
65 dB up to 2 GHz (IEC 62153-4-7),
Mechanical data
Mating cycles
Engagement force
Disengagement force
Retention force latch
Coding efficiency
25
30 N
5N
110 N
80 N
Environmental data
Temperature range
Thermal shock
Temperature and humidity
Vibration (Random)
Mechanical Shock
High-Temp. Exposure
Soldering profile
RoHS
-40°C to +105°C
DIN IEC 60068-2-14 Test Na
USCar 2 – 4 5.6.2
DIN IEC 60068-2-64
DIN IEC 60068-2-27
DIN IEC 60068-2-2
acc. to IEC 60068-2-58; Group 3&4
compliant c
Tooling
N/A
Packing
Standard
Weight
200 pcs. in tape and reel
7.0 g/ pce
P.O.Box 1260
D-84526 Tittmoning
Germany
www.rosenberger.de
Page
2/3
RIGHT ANGLE
FOR PCB
D4S20D-40MA5-Y
Coding
Part Number has to be accomplished by codification
RF_35/05.10/6.0
Coding
Plug
Colour
RAL
Part-Number
A
black
sim. 9005
D4S20D-40MA5-A
B
white
sim. 9001
D4S20D-40MA5-B
C
blue
sim. 5005
D4S20D-40MA5-C
D
bordeaux
sim. 4004
D4S20D-40MA5-D
E
green
sim. 6002
D4S20D-40MA5-E
F
brown
sim. 8011
D4S20D-40MA5-F
Z
waterblue
sim. 5021
D4S20D-40MA5-Z
Coding for special use
Control box manufacturer is responsible for pinning
Coding
Plug
Colour
RAL
Part-Number
H
violet
sim. 4003
D4S20D-40MA5-H
J
beige
sim. 1001
D4S20D-40MA5-J
Change History
Rev.
c00
Date
14.06.13
d00
03.09.13
e00
07.04.14
Change
plating defined
Environmental data specification changed from “2002/95/EC (RoHS)” to “RoHS”
Material and plating changed
-from Tin 3-6 µm to Tin 3-6 µm (PCB)
-from Ni 3-6 µm to Ni 3-6 µm (Interface)
Dimension change from □0,55/Ø0,68±0,03 to Ø0,68±0,03
While the information has been carefully compiled to the best of our knowledge, nothing is intended as representation or warranty on
our part and no statement herein shall be construed as recommendation to infringe existing patents. In the effort to improve our
products, we reserve the right to make changes judged to be necessary.
Draft
Date
Approved
Date
Rev.
Engineering change number
Name
Date
T. Höfling
03.08.12
T. Höfling
07.04.14
e00
14-0526
R. Hochheim
07.04.14
P.O.Box 1260
D-84526 Tittmoning
Germany
www.rosenberger.de
Page
3/3
很抱歉,暂时无法提供与“D4S20D-40MA5-Z”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 200+64.32584200+7.80292
- 400+57.37196400+6.95940
- 600+53.89478600+6.53760
- 1000+47.636061000+5.77840
- 国内价格 香港价格
- 1+79.936891+9.69659
- 10+71.9722710+8.73046
- 25+67.8047625+8.22493
- 50+66.0644250+8.01382
- 100+64.32584100+7.80292
