Technical Data Sheet
Rosenberger
HSD®
RIGHT ANGLE PLUG
FOR PCB
D4S20L-40MA5-Y
g
e
f
All dimensions are in mm; tolerances according to ISO 2768 m-H
Interface
According to
RN 059-01
Documents
Pinning instruction
Panel piercing
Test specification
RN 053-01
MB_215
RN 061-01
e
Material and plating
Connector parts
Center contact
Material
Spring bronze
Outer contact
Brass
Dielectric
Housing
LCP
HTN
Rosenberger Hochfrequenztechnik GmbH & Co. KG
P.O.Box 1260
D-84526 Tittmoning
Germany
www.rosenberger.de
Plating
Gold, 0.15 µm (Interface)
Tin, 0.5-2 µm (PCB)
Ni 3-6 µm (Interface)
Tin 3-6 µm (PCB)
e
Tel. : +49 8684 18-0
Email : info@rosenberger.de
Page
1/3
Rosenberger
HSD®
RIGHT ANGLE PLUG
FOR PCB
D4S20L-40MA5-Y
Electrical data
Impedance, differential mode
Frequency
Return loss
Insertion loss
Skew (between signal contacts)
Nearend-Crosstalk
Farend-Crosstalk
Insulation resistance
Signal contact resistance
Outer contact resistance
Test voltage
Working voltage
Power current
RF-leakage (shielding effectiveness)
100 differential signalling, for one pair or quad cable shielded
DC to 2.0 GHz
20 dB to 1.0 GHz
17 dB to 2.0 GHz
0.1 dB @ 1.0 GHz
5 psec.
30 dB
35 dB
3
1x10 M
10 m
7.5 m
250 V rms
100 V rms
1.5 A DC
75 dB up to 1 GHz (IEC 62153-4-7)
65 dB up to 2 GHz (IEC 62153-4-7)
Mechanical data
Mating cycles
Engagement force
Disengagement force
Retention force latch
Coding efficiency
25
30 N
5N
110 N
80 N
Environmental data
Temperature range
Thermal shock
Temperature and humidity
Vibration (Random)
Mechanical Shock
High-Temp. Exposure
Soldering profile
RoHS
-40°C to +105°C
DIN IEC 60068-2-14 Test Na
USCar 2 4 5.6.2
DIN IEC 60068-2-64
DIN IEC 60068-2-27
DIN IEC 60068-2-2
acc. to IEC 60068-2-58; Group 3&4
compliant
Tooling
N/A
Suitable cables
N/A
Packing
Standard
Weight
200 pcs in tape & reel
6.84 g/pce
P.O.Box 1260
D-84526 Tittmoning
Germany
www.rosenberger.de
Page
2/3
Rosenberger
HSD®
RIGHT ANGLE PLUG
FOR PCB
D4S20L-40MA5-Y
Coding
Part Number has to be accomplished by codification
Coding
Plug
Colour
RAL
Part-Number
A
black
sim. 9005
D4S20L-40MA5-A
B
white
sim. 9001
D4S20L-40MA5-B
C
blue
sim. 5005
D4S20L-40MA5-C
D
bordeaux
sim. 4004
D4S20L-40MA5-D
E
green
sim. 6002
D4S20L-40MA5-E
F
brown
sim. 8011
D4S20L-40MA5-F
Z
waterblue
sim. 5021
D4S20L-40MA5-Z
Change History
Rev.
e00
Date
28.01.14
f00
g00
07.04.14
04.04.17
Change
Documents removed
-Assembly instruction
D4V010
Material and plating changed
-Material PA 6T/66 to HTN
Right Angle Plug removed
-measurement
0,55
Dimension change
Ovrall length changed from 27,6 to 27,3
While the information has been carefully compiled to the best of our knowledge, nothing is intended as representat ion or warranty on
our part and no statement herein shall be construed as recommendation to infringe existing patents. In the effort to improve our
products, we reserve the right to make changes judged to be necessary.
Draft
Date
Approved
Date
Rev.
Engineering change number
Name
Date
T. Höfling
23.03.11
C. Wagner
04.04.17
g00
17-0557
C. Paus
04.04.17
P.O.Box 1260
D-84526 Tittmoning
Germany
www.rosenberger.de
Page
3/3
很抱歉,暂时无法提供与“D4S20L-40MA5-D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+70.709531+8.56960
- 10+63.9326010+7.74827
- 25+60.3950425+7.31954
- 50+58.9212250+7.14092
- 100+55.97533100+6.78390
