74HC393D,652
74HC393D,652
    NEXPERIA(安世)
    SOIC14_150MIL
    双4位二进制纹波计数器
74HC393D,652 数据手册
74HC393; 74HCT393 Dual 4-bit binary ripple counter Rev. 6 — 3 December 2015 Product data sheet 1. General description The 74HC393; 7474HCT393 is a dual 4-stage binary ripple counter. Each counter features a clock input (nCP), an overriding asynchronous master reset input (nMR) and 4 buffered parallel outputs (nQ0 to nQ3). The counter advances on the HIGH-to-LOW transition of nCP. A HIGH on nMR clears the counter stages and forces the outputs LOW, independent of the state of nCP. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2. Features and benefits  Input levels:  For 74HC393: CMOS level  For 74HCT393: TTL level  Complies with JEDEC standard no. 7A  ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V.  Two 4-bit binary counters with individual clocks  Divide by any binary module up to 28 in one package  Two master resets to clear each 4-bit counter individually 3. Ordering information Table 1. Ordering information Type number Package 74HC393D Temperature range Name Description Version 40 C to +125 C SO14 plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 40 C to +125 C SSOP14 plastic shrink small outline package; 14 leads; body width 5.3 mm SOT337-1 40 C to +125 C TSSOP14 plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 40 C to +125 C DHVQFN14 plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 14 terminals; body 2.5  3  0.85 mm 74HCT393D 74HC393DB 74HCT393DB 74HC393PW 74HCT393PW 74HC393BQ 74HCT393BQ SOT762-1 74HC393; 74HCT393 Nexperia Dual 4-bit binary ripple counter 4. Functional diagram 4  &75  &3 4    4  4  4   05  &75 &3 4     4  4   05 Fig 2. &3 05 %,7 %,1$5
74HC393D,652 价格&库存
很抱歉,暂时无法提供与“74HC393D,652”相匹配的价格&库存,您可以联系我们找货
