DS12W THRU DS120W
SOD-123FL
FEATURES
Cathode Band
Top View
1.8± 0.1
1.0±0.2
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
Metal silicon junction,majority carrier conduction
Low power loss,high efficiency
High forward surge current capability
High temperature soldering guaranteed:
250 C/10 seconds,0.375”(9.5mm) lead length,
5 lbs. (2.3kg) tension
1.3± 0.15
0.10-0.30
2.8±0.1
0.6±0.25
MECHANICAL DATA
Case: JEDEC SOD-123FL molded plastic body
Terminals: Solderable per MIL-STD-750,
Method 2026
Polarity: Color band denotes cathode end
Mounting Position: Any
Weight:0.0007 ounce, 0.02 grams
3.7±0.2
Dimensions in millimeters
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Catalog
Number
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
Peak forward surge current
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Maximum instantaneous forward voltage at 1.0A
Maximum DC reverse current
TA=25 C
at rated DC blocking voltage
TA=100 C
Typical junction capacitance (NOTE 1)
Operating junction temperature range
Storage temperature range
SYMBOLS DS12W DS13W DS14W DS15W DS16W DS17W DS18W DS19W DS110W DS115W DS120W UNITS
K17
K18
K19
K110
K115
K120
K12
K13
K14
K15
K16
VRRM
VRMS
VDC
40
50
60
70
80
90
100
150
200
14
21
28
35
42
49
56
63
70
105
140
40
50
60
70
80
90
100
150
I(AV)
1.0
IFSM
25.0
VF
0.85
0.5
IR
CJ
Amps
0.70
0.55
5.0
10.0
80
110
TJ
TSTG
-65 to +125
-65 to +150
-65 to +150
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
1/2
VOLTS
VOLTS
200 VOLTS
Amp
0.95
0.2
2.0
Volts
mA
pF
C
C
FIG. 1- FORWARD CURRENT DERATING CURVE
1
0.8
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
0.6
0.4
DS12W-DS16W
DS17W-DS120W
0.2
50
75
100
125
150
PEAK FORWARD SURGE CURRENT,
AMPERES
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
DS12W THRU DS120W
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
30
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
25
10
5.0
175
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
1
TJ=25 C
PULSE WIDTH=300 µs
1%DUTY CYCLE
DS12W-DS14W
DS15W-DS16W
DS17W-DS115W
DS120W
0.1
0.01
0.2
0.4
0.6
0.8
1.0
1.1
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
10
TJ=100 C
1
TJ=75 C
0.1
JUNCTION CAPACITANCE, pF
FIG. 5-TYPICAL JUNCTION CAPACITANCE
1000
DS12W-DS14W
DS15W-DS120W
100
TJ=25 C
10
10
TJ=25 C
0.01
60
80
PERCENT OF PEAK REVERSE VOLTAGE,%
2000
1.0
100
100
0.001
INSTANTANEOUS FORWARD VOLTAGE,
VOLTS
0.1
10
NUMBER OF CYCLES AT 60 Hz
INSTANTANEOUS REVERSE CURRENT,
MILLIAMPERES
CURRENT,AMPERES
AMBIENT TEMPERATURE, C
100
REVERSE VOLTAGE,VOLTS
2/2
100
很抱歉,暂时无法提供与“DS110W”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.07833
- 200+0.07675
- 600+0.07570
- 3000+0.06338
