MB6F
MB6F
    YONGYUTAI(永裕泰)
    MBF
    1A表面安装玻璃钝化桥式整流器VR=600V IR=5μA MBF
MB6F 数据手册
MB1F THRU MB10F 1A SURFACE MOUNT GLASS PASSIVATED BRIDGE RECTIFIER FEATURES: PINNING Glass Passivated Chip Junction Reverse Voltage - 100 to 1000 V PIN DESCRIPTION 1 Input Pin(~) 2 Input Pin(~) Forward Current - 0.8 A High Surge Current Capability 3 Output Anode(+) Designed for Surface Mount Application 4 Output Cathode(-) MECHANICAL DATA • Case: MBF • Terminals: Solderable per MIL-STD-750, Method 2026 • A pprox. Weight: 75mg 0.0026oz 3 4 2 1 MBF Package Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %. Symbols M B1F M B2F MB4F MB6F MB8F M B10F Units Maximum Repetitive Peak Reverse Voltage V RRM 100 200 400 600 800 1000 V Maximum RMS voltage V RMS 70 140 280 420 560 700 V Maximum DC Blocking Voltage V DC 100 200 400 600 800 1000 V Parameter Average Rectified Output Current at T c = 125 °C IO 0.8 A Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load (JEDEC Method) I FSM 35 A Maximum Forward Voltage at 1.0 A VF 1.1 V IR 5 40 μA Cj 13 pF RθJA RθJC 80 25 °C/W T j , T stg -55 ~ +150 °C Maximum DC Reverse Current at Rated DC Blocking Voltage @ T A =25 °C @ T A =125 °C Typical Junction Capacitance(Note1) Typical Thermal Resistance(Note2) Operating and Storage Temperature Range Note: 1. Measured at 1MHz and applied reverse voltage of 4 V D.C. 2. Mounted on glass epoxy PC board with 4×1.5"×1.5"(3.81×3.81 cm)copper pad. www.yongyutai.com PAGE 1 MB1F THRU MB10F Fig.2 Typical Reverse Characteristics 1.2 1.0 0.8 0.6 0.4 0.2 Resistive or Inductive Load 0.0 25 50 75 100 125 150 175 Instaneous Reverse Current(μ A) Average Rectified Output Current (A) Fig.1 Average Rectified Output Current Derating Curve 100 T J =125°C 10 1.0 T J =25°C 0.1 00 T J =25°C 1.0 0.1 pulse with 300μs 1% duty cycle 0.01 0.0 40 60 80 100 120 140 Fig.4 Typical Junction Capacitance Junction Capacitance ( pF) Instaneous Forward Current (A) Fig.3 Typical Instaneous Forward Characteristics 10 20 percent of Rated Peak Reverse Voltage (%) Case Temperature (°C) 100 T J =25°C 10 1 0.5 1.0 1.5 2.0 0.1 1.0 10 100 Reverse Voltage (V) Instaneous Forward Voltage (V) Peak Forward Surage Current (A) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current 40 30 20 10 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 10 100 Number of Cycles www.yongyutai.com PAGE 2 MB1F THRU MB10F PACKAGE OUTLINE Plastic surface mounted package; 4 leads MBF ∠ALL ROUND C A a L1 L d HE e D e E MBF mechanical data A C D E HE d e L L1 a max 1.6 0.22 5.0 4.1 7.0 2.7 0.8 1.7 1.1 0.2 min 1.2 0.15 4.5 3.6 6.4 2.3 0.5 1.3 0.5 max 63 8.7 197 161 276 106 31 67 43 min 47 5.9 177 142 252 91 20 51 20 UNIT ∠ mm 7° 8 mil 6.0 236 2.5 100 0.9 35 2.4 94 www.yongyutai.com mm Unit : (mil) PAGE 3
很抱歉,暂时无法提供与“MB6F”相匹配的价格&库存,您可以联系我们找货
MB6F
    • 10+0.09985
    • 100+0.08040
    • 300+0.06960
    • 1000+0.06312
    • 5000+0.05367
    • 10000+0.05065
    库存:37191
    MB6F
    • 1+0.07280
    • 30+0.07020
    • 100+0.06760
    • 500+0.06240
    • 1000+0.05980
    • 2000+0.05824
    库存:4898
