MB4F-MB10F
SILICON BRIDGE RECTIFIERS
MBF
FEATURES
Dim
Min
A
4.6
Max
5
B
3.6
4.0
C
1.2
1.6
D
6.5
7.0
E
0.15
0.35
z
Glass:passivated chip junctions
F
0.7
1.1
I
0.5
0.8
z
High surge overload rating: 30A peak
K
2.3
2.7
z
Saves space on printed circuit boards
z
High temperature soldering guaranteed: 260°C/10 seconds at 5 lbs. (2.3kg) tension
All Dimensions in mm
MECHANICAL DATA
z
Case: Molded plastic body over passivated junctions
z
Terminals: Plated leads solderable per MIL-STD-750, Method 2026
Maximum Ratings (@TA = 25°C unless otherwise specified)
Characteristic
Peak Repetitive Reverse Voltage
RMS Reverse Voltage
DC Blocking Voltage
Maximum average forward Output current
@TA=25℃
Peak forward surge current 8.3ms single halfsine-wave superimposed on rated load
Current squared time t < 8.3ms , Ta = 25℃
Symbol
VRRM
VRMS
VDC
MB05F
MB1F
MB2F
MB4F
MB6F
MB8F
MB10F
UNITS
100
200
400
600
800
1000
V
70
140
280
420
560
700
V
100
200
400
600
800
1000
V
50
35
50
IF(AV)
0.8
1.0
A
IFSM
30
A
3.7
As
2
It
2
Thermal Characteristics
Characteristic
Typical junction capacitance per leg (NOTE 1)
Symbol
MB4F
MB6F
MB8F
MB10F
UNITS
CJ
8
Typical thermal resistance per leg
R ΘJA
67
(Note 2))
R ΘJC
24
R ΘJL
13
TJ
- 55 ---- + 150
TSTG
- 55 ---- + 150
Operating junction temperature range
Storage temperature range
pF
°C/W
Note:
1. Measured at 1.0 MHz and applied reverse voltage of 4.0 Volts
2. Device mounted on PCB with 10 mm x 20 mm x 0.1mm copper pad areas
Electrical Characteristics (@TA = 25°C unless otherwise specified)
Characteristic
Maximum instantaneous forward voltage
at 0.4 A
Maximum reverse current @TA=25℃
at rated DC blocking voltage @TA=100℃
Revision:20170701-P1
Symbol
VF
IR
ht t p : //
MB4F
MB6F
MB8F
MB10F
UNITS
1.0
V
5.0
μA
0.1
mA
www.lgesemi .c o m
mail:lge@lgesemi.com
MB4F-MB10F
2
1
TJ=100°C
TJ=25°C
TJ=125°C
TJ=75°C
0.1
0.4
0.6
0.8
1
1.2
Device
Package
Shipping
MB4F--MB10F
MBF
5000/Tape&Reel
ht t p : //
www.lgesemi .c o m
很抱歉,暂时无法提供与“MB6F”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.11701
- 100+0.10921
- 300+0.10141
- 500+0.09360
- 2000+0.08970
- 5000+0.08736
- 国内价格
- 10+4.80545
- 100+1.21014
- 250+0.82780
- 325+0.75064
- 755+0.54632
