PRELIMINARY SPECIFICATIONS
GP
X3S025000BA1H-U
Customer Part No.:
HELE. Part No:
Application For:
Products:
Accepted Model:
Type & Freq.: HSX321S / 25.000MHz
Sample Order No:
Date:
CRYSTAL
2011/07/08
Approved By :
HARMONY ELECTRONICS CORP.
HARMONY ELECTRONICS (THAILAND) CO., LTD.
HARMONY ELECTRONICS (SHENZHEN) CORP., LTD.
TAIPEI OFFICE:
公司:(114)
台北市內湖區堤頂大道 2 段 409 號 2 樓
2F., NO.409, SEC.2, TIDING BLVD.,
NEIHU DISTRICT, TAIPEI CITY 114,
TAIWAN (R.O.C.)
TEL:886-2-26588883
FAX:886-2-26588683
TAIWAN FACTORY:
工廠:(831)
高雄市大寮區大發工業區華東路 39 號
No.39, Hua dong Rd., Daliao Dist.,Dafa
Industrial Park., Kaohsiung City 831,
Taiwan (R.O.C.)
TEL: (07)787-1555-6
FAX: (07)787-1557
Tittle HSX321S
THAILAND FACTORY:
66MOO 5, KAONGU-BEOKPRAI RD.,
T.BEOKPRAI, A. BANPONG,
RAJCHABUREE PROVINCE 70110,
THAILAND
TEL: (032)221994-6, 200740-1
FAX: (032)200742
Country of origin
QUARTZ CRYSTAL SPECIFICATION
Date
Confirm
2011/07/08 F. S. TSAI
Check
Prepare
C. L. WANG U. F. CHEN
HARMONY
Spec. No.
SHENZHEN FACTORY:
深圳市福永鎮塘尾村塘橋路聚源工業區
QIAO TANG RD., TANGWEI VILLAGE
FU YONG TOWN SHENZHEN CITY
CHINA
TEL: 0755-7309272 / 7309262
FAX: 0755-7309755
TAIWAN FACTORY
THAILAND FACTORY
SHENZHEN FACTORY
Rev.
Page
X3S025000BA1H-U
ELECTRONICS
CORP.
HSX321S
SPECIFICATION
INDEX
ITEM
PAGE
1. QUARTZ CRYSTAL UNIT SPECIFICATION...........
3
2. MARKING & DIMENSIONS...................
4
3. INSIDE STRUCTURE......................
5
4. EMBOSS CARRIER TAPE&REEL................
a. DIMENSIONS OF CARRIER TAPE...............
6
b. DIMENSIONS OF REEL...................
6-7
c. STORAGE CONDITION...................
7
d. STANDARD PACKING QUANTITY...................
7
e. MATERIAL OF TAPE.....................
7
f. LABEL CONTENTS......................
7
g. TAPING DIMENSION.....................
8
h. JOINT OF TAPE.......................
8
i. RELEASE STRENGHT OF COVER TAPE............
8
j. PACKAGE..........................
9
5. MECHANICAL PERFORMANCE.................
10
6. ENVIRONMENTAL PERFORMANCE...............
10
7. SUPPLEMENT ........................
11-12
8. FLOW CHART.........................
13
9. Environmental Workload Chemical Substance Components List.
14
10. TEST DATA..........................
Tittle HSX321S
Country of origin
Date
Confirm
Check
Prepare
HARMONY
Spec. No.
TAIWAN FACTORY
THAILAND FACTORY
SHENZHEN FACTORY
Rev.
Page
X3S025000BA1H-U
ELECTRONICS
CORP.
1. Frequency:
25.000000MHz
2. Holder type :
HSX321S
3. Frequency tolerance:
+/-10 ppm at 25deg.C +/-3deg.C
4. Equivalent resistance:
60 ohms Max. / SERIES
5. Storage temperature range:
-40 deg.C To +85 deg.C
6. Operable temperature range:
-20 deg.C To +70 deg.C
7. Temperature drift:
+/-10ppm
8. Loading capacitance (CL) :
-20 deg.C To +70deg.C
10.0pF
9. Drive level:
10 uW
10. Shunt Capacitance:
2.0 pF Max
11. Insulation resistance :
More than 500M ohms at DC 100V
12. Mode of oscillation:
Fundamental
13. Circuit:
Measured in HP/E5100A,S&A 250B
14. Shocking :
Dropping from 50 cm height 3 times on firm wood
Variation :
(100uW Max)
Frequency less than +/-5 ppm
Resistance less than +/- 15 ﹪or 2ohms max.
15. Aging:
Less than +/-5 ppm/Year
16. Holder
HSX321S Seam type
17. Dimensions and marking
Refer to page.4
18. Emboss carrier tape & reel
Refer to page.6 and page.7
19. Note:
Tittle HSX321S
Country of origin
Date
Confirm
Check
Prepare
HARMONY
Spec. No.
TAIWAN FACTORY
THAILAND FACTORY
SHENZHEN FACTORY
Rev.
Page
X3S025000BA1H-U
ELECTRONICS
CORP.
2. HSX321S MARKING & DIMENSIONS
*Marking should be printed as following:
Logo, Nominal Frequency, Manufactured year & month
*Nominal frequency = integer only
( ex. 14.31818 MHz Æ 14 )
*Manufacturing Lot No.
(Y: year) ex. 2000 shall be marked as ‘ 0 ’ (As shown on the Table-1)
(M: month) ex. June shall be marked as ‘ F ‘ (As shown on the Table-2).
Marking : Laser marking.
(Table-1)
2000 2001 2002 2003 2004 2005 2006 2007 2008 2009
Year
2010 2011 2012 2013 2014 2015 2016 2017 2018 2019
Code
2
3
4
5
6
7
8
9
(Table-2)
Jan. Feb. Mar. Apr. May. Jun. Jul. Aug. Sep. Oct. Nov. Dec.
A
B
C
D
E
F
G
H
J
K
L
M
Tittle HSX321S
Country of origin
Date
Confirm
Check
Prepare
HARMONY
Spec. No.
TAIWAN FACTORY
THAILAND FACTORY
SHENZHEN FACTORY
Rev.
Page
X3S025000BA1H-U
ELECTRONICS
CORP.
3. INSIDE STRUCTURE
※Reference drawing
(1) Base:
Alumina Ceramic (Al2O3)
Metallized Pad: W
Ni Plating
Au Plating
Supplier: Kyocera
NTK
(2) Lid :
Fe- Ni -Co
(3) Crystal Enclosure Seal:
Seal Seam
(4) Crystal Blank
Rectangular At-Cut Quartz Crystal Blank
(5) Adhesive
Silver Conductive Silicon Resin
Adhesive bonding:
upper & lower bonding/lower bonding only
(6) PAD
Alumina Ceramic (W. Ni. Au)
(7) Cover Ring:
Fe-Ni-Co Alloy
Tittle HSX321S
The use prohibition chemistry
substance of Table 1 of DHE-0204-1
(HE-QA-24) is not included in this
item.
Country of origin
Date
Confirm
Check
Prepare
HARMONY
Spec. No.
TAIWAN FACTORY
THAILAND FACTORY
SHENZHEN FACTORY
Rev.
Page
X3S025000BA1H-U
ELECTRONICS
CORP.
4. HSX321S EMBOSS CARRIER TAPE & REEL
a.) Dimensions of Carrier Tape
b.) Dimensions of Reel
Tittle HSX321S
Country of origin
Date
Confirm
Check
Prepare
HARMONY
Spec. No.
TAIWAN FACTORY
THAILAND FACTORY
SHENZHEN FACTORY
Rev.
Page
X3S025000BA1H-U
ELECTRONICS
CORP.
(Table-2)
(UNIT: mm)
MARK
DIMENSIONS‧ANGLE
Diameter
A
ψ180+0/-3
Inner Width
W1
9.3+/-0.3
Outer Width
W2
Out Line diameter
B
11.3+/-1.0
ψ60.5+/-0.5
F1
3.0+0.5/-0
F2
4.0+0.5/-0
F3
5.0+0.5/-0
q
C
120deg
ψ13.2+/-0.5
E
3.0+/-0.2
ITEM
FLANCE
HUB
Width
Center
Core slit
Position
Spindle diameter
Key Ditch
Width
c.) Storage condition
Temperature: +40deg.C Max.
Relative Humidity: 80% Max.
d.) Standard packing quantity
3,000PCS / REEL
e.) Material of the tape
Tape
Carrier tape
Top tape
Material
PS Conductive
Polyester
f.) Label contents
Sticks label for every reel.
Tittle HSX321S
Country of origin
Date
Confirm
Check
Prepare
HARMONY
Spec. No.
TAIWAN FACTORY
THAILAND FACTORY
SHENZHEN FACTORY
Rev.
Page
X3S025000BA1H-U
ELECTRONICS
CORP.
g.) Taping dimension
Cover-tape
Leader
Carrier-tape
Cover-tape
Terminal
Carrier-tape
Terminal
The length of cover-tape in the leader is more than 400 mm including empty
embossed area.
After all products were packaged, must remain more than twenty pieces or
400 mm empty area, which should be sealed by cover-tape.
The tip of cover-tape shall be fixed temporary by paper tape and roll around
the core of reel one round.
The empty embossed area which are sealed by top cover-tape must remain
more the 40 mm.
Components
Leader
Emptv compartments
Emptv compartments
Top cover-tape
Embossed Carrier-tape
h.) Joint of tape
The carrier-tape and top cover-tape should not be jointed.
i.) Release strength of cover tape
It has to between 0.1N to 0.7N under following condition.
Pulling direction 165° to 180°
Speed
300mm/min.
Otherwise unless specified.
165°~ 180°
Pulling direction
Other standards shall be based on JIS C 0806-1990.
Tittle HSX321S
Country of origin
Date
Confirm
Check
Prepare
HARMONY
Spec. No.
TAIWAN FACTORY
THAILAND FACTORY
SHENZHEN FACTORY
Rev.
Page
X3S025000BA1H-U
ELECTRONICS
CORP.
j.) Package
Tittle HSX321S
Country of origin
Date
Confirm
Check
Prepare
HARMONY
Spec. No.
TAIWAN FACTORY
THAILAND FACTORY
SHENZHEN FACTORY
Rev.
Page
X3S025000BA1H-U
ELECTRONICS
CORP.
5. Mechanical Performance
Specifications
Code
Item
Test Methods
1
Natural Drop
2
Vibration
3
Sealing Tightness
4
Solder ability
Drop 3 times from the height of 50cm onto min. 30mm thickness hard
wooden board.
Frequency 10-55Hz, Sine Wave full amplitude of 0.8mm to X, Y and Z
3 axes, Duration of 2 hours to each axis.
Leak Rate 1.0x10-8 Pa-m3/sec. Max. Measured by Helium leak
detector. – Fine Leakage.
After applying ROSIN Flux, dipping in solder bath at
245deg.C+/-5deg.C for 3+/-0.5 sec.
6.
2
3
4
A
--B
Environment Performance
Item
1
A
Specifications
Code
Test Methods
Temperature 60℃+/-2℃,RH 90~95%, Duration of 240 hours.
Back to room temperature first, then in 1~2 hours, the component shall
be checked.
-40deg.C +/-2deg.C, Duration of 240 hours.
Back to the room temperature first, then in 1~2 hours, the component
shall be checked.
+85deg.C +/-2deg.C, Duration of 240 hours.
shall be checked.
-40deg.C +/-2deg.C (30min) ↔ +85deg.C +/-2deg.C (30min) 25
cycles. Back to the room temperature first, then in 1~2 hours, the
component shall be checked.
Humidity
Storage in Low
Temperature
Storage in High
Temperature
Temperature cycles
A
A
A
A
Specifications code
Specifications
A
Frequency variation shall be within +/-5ppm and equivalent resistance shall be within
the specification after the test
B
More than 90% of lead shall be covered by new solder.
Tittle HSX321S
Country of origin
Date
Confirm
Check
Prepare
HARMONY
Spec. No.
TAIWAN FACTORY
THAILAND FACTORY
SHENZHEN FACTORY
Rev.
Page
X3S025000BA1H-U
ELECTRONICS
CORP.
7. Supplement
7.1.Soldering
7.2.Please stay with our proposed reflow condition and do then soldering 2 times max.
Available for Lead Free Soldering
Temperature
260 deg.C
220 deg.C
(3)
160~180deg.C
(2)
(1)
Time
(1) Preheat
160~180 deg.C 120sec.
(2) Primary heat 220
deg.C 60sec.
(3) Peak
260
deg.C 10sec. Max.
7.3.Land pattern layout(Example)
7.4.Solder iron (Example)
Bit temp.:350℃max.,Time:3sec max. ,Each terminal solder a 1 time max.
Tittle HSX321S
Country of origin
Date
Confirm
Check
Prepare
HARMONY
Spec. No.
TAIWAN FACTORY
THAILAND FACTORY
SHENZHEN FACTORY
Rev.
Page
X3S025000BA1H-U
ELECTRONICS
CORP.
7.5.Mounting
This component is designed for automatic insertion.
However, you are requested to do the trial with your insertion machine in order to be sure
of proper operation and no damage of component.
Please pay attention to board warp which may damage the component and cause Soldering
Process.
7.6.Cleaning
Cleaning liquid which corrodes Nickel shall not be used
It may cause the problem on the surface, color, marking etc.
Ultra-sonic cleaning is possible, however, you are requested to check on your board.
Because we only checked as single unit.
7.7.Storage
Please keep away from high temperature and high humidity ,which may cause put solderbility. No
direct Sunlight, No dew as well.
Tittle HSX321S
Country of origin
Date
Confirm
Check
Prepare
HARMONY
Spec. No.
TAIWAN FACTORY
THAILAND FACTORY
SHENZHEN FACTORY
Rev.
Page
X3S025000BA1H-U
ELECTRONICS
CORP.
8. Flow Chart
LID(外 殼 蓋 )
BLANK(晶 片 )
LID進 料 檢 查
1
Incoming Inspection
of LID
2
LID洗 淨
Cleaning of LID
BASE(基 座 )
BLANK進 料 檢 查
4
5
6
7
BASE進 料 檢 查
Incoming Inspection
of BLANK
3
Incoming Inspection
of BASE
化學蝕刻
Etching
頻率選別
Freq. Sorting
蒸著前洗淨
Cleaning before
Base Plating
8
微蝕刻
9
基礎蒸著
Flash Etching
Base Plating
10
押入接著
11
接著硬化
12
13
14
15
16
Blank Ass'y
Adhesive Curing
接著檢查
Bonding Check
調 整 蒸 著 / ION Partial
Partial Adjustment/Ion Partial
中 間 檢 查 ($)
22
氣 密 檢 查 II (氦 氣 加 壓 )
23
氣 密 檢 查 II (HE)
Middle Check
高真空烘烤
Annealing
in High Vacuum
Leak Check II
熔 接 Seam Seal
24
17
強 勵 振 Over Drive
18
REFLOW
19
老 化 Aging
印 字 +外 觀 檢 查
Leak Check II
(Helium Pressurization)
Marking & Check
最 終 檢 查 ($)
Final Check
25
TAPING
26
Taping 外 觀 檢 查
27
出貨檢查
Check of Taping
Outgoing Inspection
21
氣 密 檢 查 I (AIR)
Leak Check I
28
出貨捆包
Packing to
Shipment/stock
($): 特 殊 特 性
(For Special Characteristics)
出 貨 Shipment
Tittle HSX321S
Country of origin
Date
Confirm
Check
Prepare
HARMONY
Spec. No.
TAIWAN FACTORY
THAILAND FACTORY
SHENZHEN FACTORY
Rev.
Page
X3S025000BA1H-U
ELECTRONICS
CORP.
TYPE
H(D)SX321S
PERCENTAGE
20.5(mg)
ppm
Si
0.04715
9.6658
Au
0.15785
32.3593
Co & Co Compound
1.21770
249.6285
Mo & Mo Compound
0.04100
8.4050
Ag
0.42640
87.4120
Cu
0.11890
24.3745
Cr & Cr Compound
0.04100
8.4050
Al
5.09630
1044.7415
Mn & Mn Compound
0.02460
5.0430
W & W Compound
0.19885
40.7643
Ni & Ni Compound
3.06680
628.6940
Fe
4.14715
850.1658
Tittle HSX321S
Country of origin
Date
Confirm
Check
Prepare
HARMONY
Spec. No.
TAIWAN FACTORY
THAILAND FACTORY
SHENZHEN FACTORY
Rev.
Page
X3S025000BA1H-U
ELECTRONICS
CORP.
REV. No.
DATE
REASON
New
CONTENTS
Tittle HSX321S
Country of origin
Date
Confirm
Check
Prepare
HARMONY
Spec. No.
TAIWAN FACTORY
THAILAND FACTORY
SHENZHEN FACTORY
Rev.
Page
X3S025000BA1H-U
ELECTRONICS
CORP.
