PRODUCT SPECIFICATION
SPEC. NO:
新弘智
T-0621-005A
DATE: Nov.27,2018
CUSTOMER'S PRODUCT NAME:
EMTEK PRODUCT NAME:
HQC1008-36NJ-T1
THIS SPECIFICATION IS:
□ FULLY ACCEPTED
□ DENIED
□ ACCEPTED UNDER THE FOLLOWING CONDITIONS
SIGNATURE:
NAME(PRINT):
TITLE:
DATE:
FACTORY:
本文件內容全部或部份,未經兆欣科技股份有限公
司同意不得以任何形式複製或其他用途
All rights reserved.This document or parts thereof,may
not be reproduced by any means or used in any manner
witout written permission of EMTEK CO.,LTD.
39,Chingao Rd.,(305)Hsinpu,
Hsinchu Hsien,Taiwan,R.O.C
TEL: 03-5894-433
FAX: 03-5894-523
1/7
SPEC. NO.
T-0621-005A
1. Scope
This specification applies Ceramic Chip Inductance HQC1008-36N□-T1
to be delivered to user.
2. Product Identification
HQC 1008 - 36N □ - T1
(1) (2) (3) (4) (5)
(1) Product name
(2) Shapes and dimensions
(3) Inductance
36N : 36 nH
(4) Tolerance
s=±0.3% , G=±2% , J=±5% , K=±10%
(5) Taping Type
3. Shapes and Dimensions
C
B
D
E
A max. : 2.90 mm
B max. : 2.54 mm
C max. : 2.03 mm
A
D ref.
E :
: 1.30 mm
0.45 ± 0.1 mm
Equivalent circuit
No Polarity
Drawn by
Checked by
Approved by
2/7
SPEC. NO.
T-0621-005A
4. Electrical Characteristics
Customer
Our Product
Inductance
Inductance
Q/MHz
SRF(Min.)
Rdc±20%
Irms Max.
Part Number
Part Number
(nH)/MHz
Tolerance
Min.
(MHz)
(Ω)
(mA)
75/350
1500
0.09
1300
Color Coding
1st
2nd
3rd
G
36/50
HQC1008-36N□-T1
J
K
1. When ordering, please specify tolerance and packaging codes. Ex: HQC1008-36NJ-T1
Tolerance : s=±0.3% , G = ±2% , J = ±5% , K = ±10%
Packaging : Clear tape and reel { standard }.
2. L , Q、SRF : Agilent/HP E4991A+ Agilent/HP16197A
(The electrical specification test by the smallest gap position) or HP16193A
3. Rdc : Chroma Milliohmmeter 16502, or equivalent.
4. Irms for a 15℃ rise above 25℃ ambient.
5. Operating temperature range from -40℃ to 125℃.
6. Color coding is not necessarily same position.
5. Material list
Item
Material
Core
Al2O3 96%
Wire
Copper wire
Epoxy
UV Eopxy
Orange Blue
Black
3/7
SPEC. NO.
T-0621-005A
6.Reliability Test
Specifications
Item
Solderability The metalized area must have 90%
minimum solder coverage.
Resistance
to
soldering
heat
Test conditions
Dip pads in flux and dip in solder pot( 96.5 Sn/3.5 Ag
solder) at 255°C ±5°C.
There must be no case deformation or Inductors shall be reflowed onto a PC board using
change in dimensions.
96.5 Sn/3.5 Ag solder paste.
Inductance must not change more than Solder process shall be at a maximum temperature
the stated tolerance.
of 260°C.
For 96.5 Sn/3.5 Ag solder paste:>217°C for 90 seconds
Vibration
There must be no case deformation or Solder specimen inductor on the test printed circuit
board. Apply vibrations in each of the x,y and z
Inductance must not change more than directions for 2 hours for a total of 6 hours.
Frequency : 10~50 Hz
Amplitude
: 1.5mm
There must be no case deformation or Inductors shall be subjected to temperature 125±2℃
High
for 50±12 hours.
temperature change in dimensions.
resistance Inductance must not change more thanMeasure the test items after leaving the inductors at
Static
Humidity
room temperature and humidity for 2 hours.
Inductors must not have a shorted or Inductors shall be subjected to temperature 85±2℃
and 90 to 95%RH. for ten 24-hours.
openwinding.
at room temperature and humidity for 2 hours.
Component Inductors shall be subjected to 1.8Kg Inductors shall be reflow soldered (255°C ±5°C for
10 seconds) to a tinned copper substrate.
adhesion
A force gauge shall be applied to the side of the
(push test)
component.
The device must withstand the stated force
without a failure of the termination.
4/7
SPEC. NO.
T-0621-005A
Specifications
Test conditions
Item
Low
-40±2℃ for 48±12 hours.
than the stated tolerance.
at room temperature and humidity for 1 to 2
hours.
Resistance
to
solvent
There must be no case deformation,
Thermal
shock
There must be no case deformation or Inductors shall be subjected to 10 cycles to the
the following temperature cycle:
Inductors must withstand 6 minutes of alcohol or water.
change in dimensions, or obliteration
of marking.
1 cycle
30 min.
30 sec
+125℃
-40℃
30 min.
5/7
SPEC. NO.
T-0621-005A
7.Packaging
The packaging must be done not to receive any damage during transporting
and storing.
7-1 Tape dimensions
Ko
P1
P0
P
W
Bo
t
Ao
( Dimensions in mm; Tolerance:±0.1)
Symbol
W
P
P0
P1
Ao
Bo
Ko
t
Dimension
8
4
4
2
2.5
2.85
2
0.22
7-2 Reel dimensions
D
( Dimensions in mm )
C B
A
Symbol
T
A
B
180
C
13
D
14.4
E
8.4
E
7-3 Tapping figure
Top cover tape
Carrier tape
Sprocket hole
Cavity (chip insert)
60
6/7
SPEC. NO.
T-0621-005A
7-4 Packaging Form
There shall not continuation more than two vacancies of the product.
(360 mm)
Leader.
Blank
(50 pitches)
Chip
Blank
(70 pitches)
7-5 Cover Tape Peel Strength
The force for tearing off cover tape is 0.1~0.6(N) in the arrow direction at the following conditions:
Temperature : 5 ~ 35℃
Humidity : 45 ~ 85%
Atmospheric pressure : 860 ~ 1060 hpa
160 ~ 180。
Top cover tape
Base tape
7-6 Packing Quantity
φ180 mm reel type : 2,000 pcs./reel
7/7
SPEC. NO.
T-0621-005A
8. Recommended Soldering Conditions
(Please use this product by reflow soldering)
8-1 Recommended Footprint
1.02
1.27
1.02
2.54
Unit: mm
8-2 Recommended Reflow Pattern
Reflow : until two times
10sec. Min.
255℃
217℃
Natural cooling
150sec. Max.
150℃
60sec. Min.
8-3 Iron Soldering
Use a solder iron of less than 30W when soldering ,do not allow the soldering iron tip
directly touch the Ceramic body outside of terminal electrode.
5 seconds max. at 260℃.
9. Attention in Case of Using
In case of using product ,please avoid following matters:
Splashing water or salt water
Dew condenses
Toxic gas (Hydrogen sulfide, Sulfurous acid ,Chlorine, Ammonia)
Vibrations or shocks which exceed the specified condition
Please be careful for the stress to this product by board flexure or something after the mounting.
10. Others
10-1 Operating temperature range
: Ceramic Series :-40~+125℃
10-2 Storage condition
: Temperature 20°~25℃﹐Relative Humidity 40%~60%
10-3 Recommended wire wound inductors should be used within 6 months from the time of delivery.
很抱歉,暂时无法提供与“HQC1008-36NJ-T1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.27264
- 50+0.14858
- 150+0.06600
- 500+0.05978
- 2000+0.05480
- 4000+0.05231
