Customer Name :
Customer P/N
Frequency
Aker Approved P/N:
Aker MPN
Rev.
ISSUE DATE
13.553125
MHz
CXF-013553-3E7X40
CXF-013553-3E7X40
1
: Oct.27.2017
APPROVED
CHECKED
Tachan
PREPARED
Kiku
APPROVED BY CUSTOMER
AKER TECHNOLOGY CO., LTD.
ADDRESS : NO 11-3, Jianguo Rd., T.E.P.Z ,Tanzi Dist., Taichung City 427, Taiwan.
TEL:886-4-25335978
FAX : 886-4-25336011
Web: www.aker.com.tw
RoHS compliant
TS-16949 Certified
AEC-Q200 Qualified
CUST. P/N
Aker Approved P/N
APPROVED
PREPARED
CXF-013553-3E7X40
SHEET : 1 of 8
Tachan
REV . : 1
Kiku
Rev.
Date
Reviser
Revise contents
1
2017/10/27
Kiku
Initial Released
CUST. P/N
Aker Approved P/N
APPROVED
PREPARED
CXF-013553-3E7X40
Tachan
SHEET : 2 of 8
Kiku
REV . : 1
SMD CRYSTAL SPECIFICATION
1 . ELECTRICAL CHARACTERISTICS
Standard atmospheric conditions
Unless otherwise specified , the standard range of atmospheric conditions for making measurement
and tests are as follow :
Ambient temperature : 25±5℃
Relative humidity
: 40%~70%
If there is any doubt about the results , measurement shall be made within the following limits :
Ambient temperature : 25±3℃
Relative humidity
: 40%~70%
AKER Model : CXF-321
Oscillation Model : Fundamental
Cutting Model : AT CUT
Measurement Equipment : 350A(Measured FL)
Insulation Resistance : More than 500M ohms at DC 100V
Electrical Spec
Parameters
Nominal Frequency
Symbol
Min.
Typ.
Max.
13.553125
FL
Units.
Notes
MHz
Frequency Tolerance
±15
ppm at 25℃ ± 3℃
Frequency Stability
±30
ppm Operating Temp (Refer 25℃)
Load Capacitance
CL
12
Aging
pF
±3
ppm Year
Operating Temperature
-40
85
Storage Temperature Range
-55
125
Drive Level
DL
100
uW
Effective Resistance Rr
Rr
100
Ω
Shunt Capacitance
C0
3
pF
*Please kindly be noted that AKER DO NOT guarantee parts quality which involves human security application.*
CUST. P/N
Aker Approved P/N
APPROVED
PREPARED
CXF-013553-3E7X40
Tachan
SHEET : 3 of 8
Kiku
REV . : 1
2 . MARKING :
FREQUENCY
13.57
AK Ak
AKER LOGO.
Load of NOTE1
Year/Month Code:Please make refer to following tables.
Production line code
NOTE 1 :
3 . DIMENSION :
( Unit : mm )
CUST. P/N
Aker Approved P/N
APPROVED
PREPARED
CXF-013553-3E7X40
Tachan
SHEET : 4 of 8
Kiku
REV . : 1
4 . STRUCTURE ILLUSTRATION
A
C
B
D
G
N
I
K
R
A
M
E
CUST. P/N
Aker Approved P/N
APPROVED
PREPARED
CXF-013553-3E7X40
Tachan
SHEET : 5 of 8
Kiku
REV . : 1
5 . PACKING :
TAPE SPECIFICATION
A
A
4.0 ± 0.10
5° (max)
B
1.0 (MIN)
B-B SECTION
3.50 ± 0.05
B
0.25 ± 0.05
3.40 ± 0.10
4.0 ± 0.10
8.0 ± 0.20
1.55 ± 0.05
1.75 ± 0.10
2.0 ± 0.05
( Unit : mm )
1.40 ± 0.10
2.70 ± 0.10
5° (max)
A-A SECTION
180 ± 3
( Unit : mm )
60.5 ± 2
OUTLINE DIMENSION
13.2
9 ± 1.0
12 ± 1.5
2.5
CUST. P/N
Aker Approved P/N
APPROVED
PREPARED
6. COVER TAPE ADHESION STRENGTH:
7 . SOLDERING REFLOW PROFILE
CXF-013553-3E7X40
Tachan
SHEET : 6 of 8
Kiku
REV . : 1
CUST. P/N
Aker Approved P/N
APPROVED
PREPARED
CXF-013553-3E7X40
Tachan
SHEET : 7 of 8
Kiku
REV . : 1
8. PACKING :
185mm
183mm
36mm
BOX = 3000 PCS / REEL(MAX)
Stuff
210mm
625mm
390mm
SMD product packs 32 BOX=The outside box packs (3000 PCS *32 BOX = 96000 PCS)(MAX)
CUST. P/N
Aker Approved P/N
APPROVED
PREPARED
CXF-013553-3E7X40
Tachan
SHEET : 8 of 8
Kiku
REV . : 1
9 . MECHANICAL PERFORMANCE
TEST ITEMS
9.1 Temperature
Cycling
TEST METHODS AND TEST CONDITION
PERFORMANCE
-40±3℃/30min maximum~+125±3℃/30min maximum,
1000cycles
9.2 Operational Life
125℃±3°C,1000hrs±12hrs
9.3 Biased Humidity
85°C±5°C&85%±5%R.H.,1000±12hrs
9.4 Resistance To
Soldering Heat Test
Reflow test 2 times.
9.5 High Temperature
Exposure
9.6 Vibration Test
Freq.range: 10~2000Hz,Peak to peak amplitude:1.52mm
Peak acceleration:5G (49m/s2),3 direction(X, Y,Z)
,20min 12cycles each of 3 orientations.
To satisfy the electrical
performance .
9.7 Mechanical Shock
100G,6mS,3 times for each direction(X, Y, Z ),3 cycles
9.8 Physical Dimension
Verify physical dimensions to the applicable device
detail specification.
9.9 Solderability
260℃,Coated > 95%
9.10 Board Flex
PCB=100*40(mm),Bending=2 mm (min),
Duration=60+5/-0 sec
9.11 External Visual
Inspect device construction and marking.
9.12 Terminal Strength
A force of 17.7N for 60 seconds.
很抱歉,暂时无法提供与“CXF-013553-3E7X40”相匹配的价格&库存,您可以联系我们找货
