CXF-024000-3D6D40
CXF-024000-3D6D40
    AKER(安碁)
    SMD3225_4P
    频率:-;负载电容:-;
CXF-024000-3D6D40 数据手册
Customer Name : Customer P/N : Frequency : Aker Approved P/N: Aker MPN : Rev. : ISSUE DATE 24.000000 MHz CXF-024000-3D6D40 CXF-024000-3D6D40 1 : Jan.25.2019 APPROVED CHECKED Xtal PREPARED Kiku APPROVED BY CUSTOMER AKER TECHNOLOGY CO., LTD. ADDRESS : NO 11-3, Jianguo Rd., T.E.P.Z ,Tanzi Dist., Taichung City 427, Taiwan. TEL:886-4-25335978 FAX : 886-4-25336011 Web: www.aker.com.tw RoHS compliant IATF 16949 Certified AEC-Q200 Qualified CUST. P/N Aker Approved P/N APPROVED PREPARED : : : : CXF-024000-3D6D40 SHEET : 1 of 8 Xtal REV . : 1 Kiku Rev. Date Reviser Revise contents 1 2019/1/25 Kiku Initial Released CUST. P/N Aker Approved P/N APPROVED PREPARED : : : : CXF-024000-3D6D40 Xtal SHEET : 2 of 8 Kiku REV . : 1 SMD CRYSTAL SPECIFICATION 1 . ELECTRICAL CHARACTERISTICS Standard atmospheric conditions Unless otherwise specified , the standard range of atmospheric conditions for making measurement and tests are as follow : Ambient temperature : 25±5℃ Relative humidity : 40%~70% If there is any doubt about the results , measurement shall be made within the following limits : Ambient temperature : 25±3℃ Relative humidity : 40%~70% AKER Model : CXF-321 Oscillation Model : Fundamental Cutting Model : AT CUT Measurement Equipment : 350A(Measured FL) Insulation Resistance : More than 500M ohms at DC 100V Electrical Spec Parameters Nominal Frequency Symbol Min. FL Typ. Max. 24.000000 Units. Notes MHz Frequency Tolerance ±20 ppm at 25℃ ± 3℃ Frequency Stability ±20 ppm Operating Temp (Refer 25℃) Load Capacitance CL 18 Aging pF ±3 ppm First Year Operating Temperature -40 ~ 85 ℃ Storage Temperature Range -55 ~ 125 ℃ Drive Level DL 100 uW Effective Resistance Rr Rr 50 Ω Shunt Capacitance C0 3 pF *Please kindly be noted that AKER DO NOT guarantee parts quality which involves human security application.* CUST. P/N Aker Approved P/N APPROVED PREPARED : : : : CXF-024000-3D6D40 Xtal SHEET : 3 of 8 Kiku REV . : 1 2 . MARKING : FREQUENCY 24.06 AK AA AKER LOGO. Load of NOTE1 Year/Month Code:Please make refer to following tables. Production line code NOTE 1 : 3 . DIMENSION : ( Unit : mm ) CUST. P/N Aker Approved P/N APPROVED PREPARED : : : : CXF-024000-3D6D40 Xtal SHEET : 4 of 8 Kiku REV . : 1 4 . STRUCTURE ILLUSTRATION A C B D G N I K R A M E CUST. P/N Aker Approved P/N APPROVED PREPARED : : : : CXF-024000-3D6D40 Xtal SHEET : 5 of 8 Kiku REV . : 1 5 . PACKING : TAPE SPECIFICATION A A 5° (max) B-B SECTION 3.50 ± 0.05 B 0.25 ± 0.05 3.40 ± 0.10 4.0 ± 0.10 8.0 ± 0.20 1.55 ± 0.05 1.75 ± 0.10 2.0 ± 0.05 ( Unit : mm ) B 4.0 ± 0.10 1.0 (MIN) 1.40 ± 0.10 2.70 ± 0.10 5° (max) A-A SECTION 180 ± 3 ( Unit : mm ) 60.5 ± 2 OUTLINE DIMENSION 13.2 9 ± 1.0 12 ± 1.5 2.5 CUST. P/N Aker Approved P/N APPROVED PREPARED : : : : 6. COVER TAPE ADHESION STRENGTH: 7 . SOLDERING REFLOW PROFILE CXF-024000-3D6D40 Xtal SHEET : 6 of 8 Kiku REV . : 1 CUST. P/N Aker Approved P/N APPROVED PREPARED : : : : CXF-024000-3D6D40 Xtal SHEET : 7 of 8 Kiku REV . : 1 8. PACKING : 185mm 183mm 36mm BOX = 3000 PCS / REEL(MAX) Stuff 210mm 625mm 390mm SMD product packs 32 BOX=The outside box packs (3000 PCS *32 BOX = 96000 PCS)(MAX) CUST. P/N Aker Approved P/N APPROVED PREPARED : : : : CXF-024000-3D6D40 Xtal SHEET : 8 of 8 Kiku REV . : 1 9 . MECHANICAL PERFORMANCE TEST ITEMS 9.1 Temperature Cycling TEST METHODS AND TEST CONDITION PERFORMANCE -40±3℃/30min maximum~+125±3℃/30min maximum, 1000cycles 9.2 Operational Life 125℃±3°C,1000hrs±12hrs 9.3 Biased Humidity 85°C±5°C&85%±5%R.H.,1000±12hrs 9.4 Resistance To Soldering Heat Test Reflow test 2 times. 9.5 High Temperature Exposure 125℃±3°C,1000hrs±12hrs 9.6 Vibration Test Freq.range: 10~2000Hz,Peak to peak amplitude:1.52mm Peak acceleration:5G (49m/s2),3 direction(X, Y,Z) ,20min 12cycles each of 3 orientations. To satisfy the electrical performance . 9.7 Mechanical Shock 100G,6mS,3 times for each direction(X, Y, Z ),3 cycles 9.8 Physical Dimension Verify physical dimensions to the applicable device detail specification. 9.9 Solderability 260℃,Coated > 95% 9.10 Board Flex PCB=100*40(mm),Bending=2 mm (min), Duration=60+5/-0 sec 9.11 External Visual Inspect device construction and marking. 9.12 Terminal Strength A force of 17.7N for 60 seconds.
CXF-024000-3D6D40 价格&库存
很抱歉,暂时无法提供与“CXF-024000-3D6D40”相匹配的价格&库存,您可以联系我们找货
