CRYSTAL OSCILLATOR
SERIES 6N, SEAM SEALED CERAMIC 7.0X5.0MM SURFACE MOUNT PACKAGE
深圳市晶科鑫实业有限公司
样品承认书
客户代码:
C252380
物料名称:
贴片钟振
规格型号:
7050 OSC 14.31818MHZ 1.8~3.3V ±30PPM CMOS
P N/ SJK:
6N14318G33YC
承
供
应
商
承
认
签
认
制定
审 核
核 准
林雁
杨霞
黄灏东
工 程 师
盖章签署
日
章
)公 司 承 认
审 核
盖章签署
期
日
期
批示: □接受 □有条件接受
备注:
公司地址: 深圳市龙岗区天安云谷产业园一期 3 栋 C 座 12 楼 1204~1206 室
电
话:0755-88352810-837
批 准
传
真:0755-88353718
http://www.q-crystal.com Email:sjk-fae@q-caystal.com Mobile:18682088994 (Mr.huang)
1 /9
CRYSTAL OSCILLATOR
Approved by: 黄灏东
Checked by: 杨霞
Issued
by: 玉静霞
产品规格书
SPECIFICATION
PN / SJK: 6N14318G33YC
深圳市晶科鑫实业有限公司
SHENZHEN CRYSTAL TECHNOLOGY INDUSTRIAL CO., LTD.
电
话:0755-88352810-837
传
真:0755-88353718
2 /9
CRYSTAL OSCILLATOR
修 改
版次
修改日
A1
2015-6-5
项目
记 录
改定内容
改定者
确认者
初版
林雁
杨霞
3 /9
CRYSTAL OSCILLATOR
1. ELECTRICAL SPECIFICATIONS
Standard atmospheric conditions
Unless otherwise specified, the standard range of atmospheric conditions for making measurement
and tests are as follow:
Ambient temperature : 25±5℃
Relative humidity : 40%~70%
If there is any doubt about the results, measurement shall be made within the following limits:
Ambient temperature : 25±3℃
Measure equipment
Electrical characteristics measured by MD 37WX-05M or equivalent.
Crystal cutting type
The crystal is using AT CUT (thickness shear mode).
Parameters
1
2
3
SYM
Electrical Spec.
MIN
Nominal Frequency
AT 25℃
Over Operating
Temperature range
Operating Temperature
Frequency
Stability
TYPE
MAX
Notes
UNITS
14.318180
MHZ
±10
PPM
±20
PPM
Topr
-40
25
85
-55
125
4
Storage Temperature
Tstg
5
Supply Voltage
VDD
6
Input Current
Icc
7
Enable Control
8
Output Load : CMOS
CL
9
Output Voltage High
VoH
10
Output Voltage Low
VoL
10%
Vdd
V
11
Rise Time
Tr
5
ns
12
Fall Time
Tf
5
ns
13
Symmetry (Duty ratio)
TH/T
55
14
Start-up Time
Tosc
10
ms
1.8~3.3 ±10%
V
10
mA
Yes
Pad1
15
pF
90%
Vdd
45
V
70%
Vdd
15
Enable Voltage High
Vhi
16
Disable Voltage Low
Vlo
17
Aging
18
Output Disable Delay Time
T off
150
us
19
Output Enable Delay Time
T on
150
us
Phase Jitter (12KHZ~20MHZ)
1.0
ps
10%→90%VDD
Level
90%→10%VDD
Level
V
30%
Vdd
±3
0.5
V
ppm/yr.
1st. Year at 25℃
4 /9
CRYSTAL OSCILLATOR
2. DIMENSIONS
(Units :mm)
MARKING
3. TEST CIRCUIT
Control input (output enable/disable)
Logic 1 or open on pad 1: Oscillator output
Logic 0 on pad 1 : Disable output to high impedance
4. PART NUMBER GUIDE
SJK -
6N
— 14318
Frequency
14.31818MHz
G
Frequency
tolerance
G:±30ppm
33
Y
C
Supply
Fan out type
Temperatur
voltage
X:TTL/CMOS
e
33:1.8~3.3V
Y:CMOS
range
Z:TTL
C: -40-85℃
5 /9
CRYSTAL OSCILLATOR
5. WAVEFORM CONDITIONS
Waveform measurement system should
have a min. bandwidth of 5 times the
frequency being tested.
6. OUTPUT ENABLE / DISABLE DELAY
The following figure shows the oscillator timing during normal operation . Note that when the device is in
standby,
the oscillator stops. When standby is released, the oscillator starts and stable oscillator output occurs after a
short delay
7. SUGGESTED REFLOW PROFILE
Total time : 200 sec. Max / Solder melting point :220 ℃
6 /9
CRYSTAL OSCILLATOR
8. STRUCTURE ILLUSTRATION
NO
COMPONENTS
MATERIALS
FINISH/SPECIFICATIONS
1
LID
Kovar (Fe/Co/Ni)
2
Base(Package)
Ceramic (AI2O3) + Kovar (Fe/Co/Ni)+ Ag/Cu
Color black
3
PAD
Au
Tungsten metalize
+ Ni plating
+ Au plating
4
Crystal blank
SiO2
5
Conductive adhesive
Ag
6
Electrode
Noble Metal
7
IC chip
8
Bonding wire
Au
Pad 1 options : NC is 5
wires ,
EN is 6 wires.
9
Die attached
Conductive (Ag)
Epoxy resin
Silicon resin
7 /9
CRYSTAL OSCILLATOR
9. PACKING
8 /9
CRYSTAL OSCILLATOR
10. RELIABILITY TEST SPECIFICATION
1.Mechanical Endurance
No.
Test Item
Test Methods
REF. DOC
1
Drop Test
75 cm height,3 times on concrete floor .
JIS C6701
Device are shocked to half sine wave ( 1000
G ) three mutually
perpendicular axes each 3 times. 0.5m sec.
duration time
Frequency range 10 ~ 2000 Hz
Amplitude 1.52 mm/20G
Sweep time 20 minutes
Perpendicular axes each test time 4 Hrs
(Total test time 12 Hrs)
Standard Sample For Automatic Gross Leak
Detector, Test Pressure: 2kg / cm2
2
Mechanical Shock
3
Vibration
4
Gross Leak
5
Fine Leak
Helium Bomging 4.5 kgf / cm 2 for 2 Hrs
Solderability
Temperature 245 ℃ ± 5℃
Immersing depth 0.5 mm minimum
Immersion time 5 ± 1 seconds
Flux Rosin resin methyl alcohol
solvent ( 1 : 4 )
MIL-STD-883E
6
MIL-STD-202F
MIL-STD-883E
MIL-STD-883E
2.Environmental Endurance
No.
Test Item
Test Methods
REF. DOC
1
Resistance To Soldering
Heat
Pre-heat temperature 125 ℃
Pre-heat time 60 ~ 120 sec.
Test temperature 260 ± 5 ℃
Test time 10 ± 1 sec.
MIL-STD-202F
2
High Temp. Storage
+ 125 ℃ ± 3 ℃ for 1000 ± 12 Hrs
3
Low Temp. Storage
- 40 ℃ ± 3 ℃ for 1000 ± 12 Hrs
MIL-STD-883E
Total 100 cycles of the following temperature
cycle
4
Thermal Shock
MIL-STD-883E
5
Pressure Cooker
Storage
121 ± 3℃ , RH100% , 2 bar , 240 Hrs
JIS C6701
6
High Temp&Humidity
85℃ ± 3℃, RH 85% , 1000 Hrs
JIS C5023
9 /9
很抱歉,暂时无法提供与“6N14318G33YC”相匹配的价格&库存,您可以联系我们找货
