PRODUCT SPECIFICATION
SPEC. NO: T-0602-102D
新弘智
DATE: Nov.27,2018
CUSTOMER'S PRODUCT NAME:
EMTEK PRODUCT NAME:
CMF4532F-Series
THIS SPECIFICATION IS:
□ FULLY ACCEPTED
□ DENIED
□ ACCEPTED UNDER THE FOLLOWING CONDITIONS
SIGNATURE:
NAME(PRINT):
TITLE:
本文件內容全部或部份,未經兆欣科技股份有限公
司同意不得以任何形式複製或其他用途
All rights reserved.This document or parts thereof,may
not be reproduced by any means or used in any manner
witout written permission of EMTEK CO.,LTD.
DATE:
FACTORY:
39,Chingao Rd.,(305)Hsinpu,
Hsinchu Hsien,Taiwan,R.O.C
TEL: 03-5894-433
FAX: 03-5894-523
1/8
SPEC. NO.
T-0602-102D
1. Scope
This specification applies ferrite Chip common mode filters CMF4532F-Series
to be delivered to user.
2. Product Identification
CMF 4532 F - 601 - 2P - T
(1) (2) (3) (4) (5) (6)
(1) Product name
(2) Shapes and dimensions
(3) Application
(4) Impedance【 at 100MHz】
601:600Ω
(5) Number of Line
2P:2-Line
(6) Taping Type
3. Shapes and Dimensions [Dimensions in mm]
A
B
Epoxy
C
A:4.5 ± 0.2 mm
B:3.2 ± 0.2 mm
C:2.8 ± 0.2 mm
D1:1.0 ± 0.1 mm
D2:1.2 ± 0.1 mm
Termination
Wires
(D2)
(D2)
(D1)
(D1)
Drawn by
Checked by
Approved by
2/8
SPEC. NO.
T-0602-102D
4. Electrical Characterisitics
4-1 Electrical Spec.
Our Product Part Number
Common-Mode
Impedance
Z(Ω) at 100MHz
CMF4532F-601-2P-T
600±25%
0.24
50
CMF4532F-801-2P-T
800±25%
0.26
CMF4532F-102-2P-T
1000±25%
CMF4532F-142-2P-T
1400±25%
CMF4532F-252-2P-T
2500±25%
4-2Characteristics(Reference)
4-2-1 Z v.s. Freq.
DC
Rated Voltage
Resistance
Vdc(V)
Rdc(Ω) Max.
Insulation
Withstand
Resistance
Voltage
(MΩ)Min.
Vdc(V)
10
125
1400
50
10
125
1000
0.30
50
10
125
1000
0.4
50
10
125
1000
0.9
50
10
125
200
Rated Current
Idc(mA) Max.
3/8
SPEC. NO.
4-3 Test Equipment
4-3-1 Impedance
Measured by using Agilent E4991A RF Impedance Analyzer.
Measurement terminal
①
④
②
③
4-3-2 DC Resistance
Measured by using Chroma 16502 mill ohm meter.
①
④
②
③
4-3-3 Insulation Resistance
Measured by using Chroma 19073
Measurement voltage : 50v .
①
④
②
③
T-0602-102D
4/8
SPEC. NO.
T-0602-102D
5.Reliability Test
Operating temperature : -40 to +125℃
Item
Specifications
Solderability It can be connected on the
Storage temp and humidity : 20~25℃ ,60%RH max.
Test conditions
Apply cream solder to the test circuit board .
Recommendation soldering condition. It is mounted on the recommendation soldering condition.
Dip pads in flux and dip in solder pot( 96.5 Sn/3.5 Ag
solder) at 255°C ±5°C.
Solder Heat Components should have not
Resistance evidence of electrical and
The device should be reflow soldered on PCB
Preheating: 150℃, 60 secs
mechannical damage
Solder temperature: Peak 260±5℃ for 10secs
Impedance:within ±15% of
Solder Composition: 96.5Sn/3.5Ag
initial value
Terminal
strength
The terminal electrode and the ferrite
Solder a chip to test substrate , and then laterally apply a
must not be damaged.
load 1.8Kg in the arrow direction.
High
Appearance : Ferrite shall not be
temperature damaged.
resistance
Temperature : +125±2℃
Testing time : 168±12 hours
Measurement : After placing for 24 hours min.
initial value.
Humidity
resistance
Thermal
cycle
insulation resistance: >10(MΩ)
Temperature : +60±2℃
DC resistance : standard value
Humidity : 90 to 95%RH
inside.
Temperature : -40℃,+125℃
kept stabilized for 30 minutes each.
Cycle : 10 cycle
1 cycle
+125℃
-40℃
30 min.
3 min.
30 min.
5/8
SPEC. NO.
Item
Specifications
Low
temperature
resistance
T-0602-102D
Test conditions
Temperature : -40±2℃
damaged.
initial value.
inside.
6.Packaging
The packaging must be done not to receive any damage during
transporting and storing
( Dimensions in mm )
Symbol
W
Dimension 12.00
SPEC.
±0.1
P
8.00
E
1.75
F
5.50
P2
2.00
±0.1
±0.1
±0.05 ±0.05
D
1.50
D1
1.50
Po
4.00
10Po
40.00
Ao
3.57
Bo
4.80
Ko
2.80
t
0.30
+0.10
-0.00
±0.1
±0.1
±0.2
±0.1
±0.1
±0.1
±0.05
6/8
SPEC. NO.
6-2 Reel dimensions
T-0602-102D
D
C
B
Symbol
T
A
B
180
C
13
D
E
16
13.2
A
E
6-3 Tapping figure
Top cover tape
Carrier tape
Sprocket hole
Cavity (chip insert)
6-4 Packaging Form
There shall not continuation more than two vacancies of the product.
(360 mm)
Blank
Chip
50 pitches
Material of carrier tape : Polystyrene
Material of cover tape : Polyester
Blank
70 pitches
Leader.
60
7/8
SPEC. NO.
T-0602-102D
6-5 Cover Tape Peel Strength
The force for tearing off cover tape is 0.05~0.69(N) in the arrow direction at
the following conditions:
Temperature : 5 ~ 35℃
Humidity : 45 ~ 85%
Atmospheric pressure : 860 ~ 1060 hpa
160 ~ 180。
Top cover tape
Base tape
6-6 Packing Quantity
φ180 mm reel T type : 500 pcs./reel
7. Recommended Soldering Conditions (Please use this product by reflow soldering)
7-1 Recommended Footprint
Termination Number : Please refer to the equivalent circuit in chapter 3.
0.7
4.8
3.8
2.5
Unit:mm
8/8
SPEC. NO.
T-0602-102D
7-2 Recommended Reflow Pattern
Reflow : until two times
10sec. Min.
255℃
217℃
Natural cooling
150sec Max..
150℃
60sec. Min.
7-3 Iron Soldering
Use a solder iron of less than 30W when soldering ,do not allow the soldering iron tip
directly touch the ferrite body outside of terminal electrode.
5 seconds max. at 260℃.
8. Attention in Case of Using
In case of using product ,please avoid following matters:
Splashing water or salt water
Dew condenses
Toxic gas (Hydrogen sulfide, Sulfurous acid ,Chlorine, Ammonia)
Vibrations or shocks which exceed the specified condition
Please be careful for the stress to this product by board flexure or something
after the mounting.
9. Others
9-1 Operating temperature range : -40~+125℃
9-2 Storage condition : Temperature 20~25℃ , Relative Humidity 40% ~ 60%
9-3 Recommended wire wound inductors should be used within 6 months from the time of delivery.
很抱歉,暂时无法提供与“CMF4532F-102-2P-T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.36412
- 50+1.91960
- 150+1.72908
