PRODUCT SPECIFICATION
SPEC. NO: T-0602-141E
新弘智
DATE: Mar.14,2019
CUSTOMER'S PRODUCT NAME:
EMTEK PRODUCT NAME:
CMF4532F-SERIES-Tms
THIS SPECIFICATION IS:
□ FULLY ACCEPTED
□ DENIED
□ ACCEPTED UNDER THE FOLLOWING CONDITIONS
SIGNATURE:
NAME(PRINT):
TITLE:
本文件內容全部或部份,未經兆欣科技股份有限公
司同意不得以任何形式複製或其他用途
All rights reserved.This document or parts thereof,may
not be reproduced by any means or used in any manner
witout written permission of EMTEK CO.,LTD.
DATE:
FACTORY:
39,Chingao Rd.,(305)Hsinpu,
Hsinchu Hsien,Taiwan,R.O.C
TEL: 03-5894-433
FAX: 03-5894-523
1/9
SPEC. NO.
T-0602-141E
1. Scope
This specification applies ferrite Chip common mode filters CMF4532F-Series-Tms
to be delivered to user.
2. Product Identification
CMF 4532 F - 600 - 2P - Tms
(1) (2) (3) (4) (5) (6)
(1) Product name
(2) Shapes and dimensions
(3) Shielding Type
(4) Impedance【 at 100MHz】
600:60Ω
(5) Number of Line
2P:2-Line
(6) For Customer Design
3. Shapes and Dimensions [Dimensions in mm]
A:4.5±0.2
B:3.2±0.2
C:2.8±0.2
Drawn by
Checked by
Approved by
2/9
SPEC. NO.
T-0602-141E
4. Electrical Characterisitics
4-1 Electrical Spec.
Common-Mode Common-Mode
DC
Rated
Rated Withstanding Insulation
Our Product Part Number
Impedance
Resistance
Current
Voltage
Inductance
Voltage
Resistance
Z(Ω) at 100MHz uH at 100KHz Rdc(Ω) Max. Idc(A) Max. Vdc(V)
Vdc(V)
(MΩ)Min.
CMF4532F-600-2P-Tms
60 ±25%
0.05
2.0
50
125
10
CMF4532F-900-2P-Tms
90 ±25%
0.05
2.0
50
125
10
CMF4532F-161-2P-Tms
160 ±25%
0.08
2.0
50
125
10
CMF4532F-231-2P-Tms
230 ±25%
0.10
1.8
50
125
10
CMF4532F-421-2P-Tms
420 ±25%
0.10
1.6
50
125
10
CMF4532F-601-2P-Tms
600 ±25%
0.07
2.8
50
125
10
2.0 ±50%
Rated Current Idc : DC current (A) that will cause an approximate △T of 40℃
4-2 Characteristics (Reference)
CMF4532F- 600-2P-Tms
1000
Differential mode Z
100
10
1
1
10
100
1000
Frequency (MHz)
CMF4532F-161-2P-Tms
1000
Common mode Z
Differential mode Z
Impedance(Ω)
Impedance(Ω)
Common mode Z
100
10
1
1
10
100
Frequency (MHz)
1000
10000
3/9
SPEC. NO.
CMF4532F-421-2P-Tms
10000
Z (common mode)
Z(differential mode)
1000
Z ( ohm)
100
10
1
0.1
1
10
100
1000
Frequency(MHz)
10000
CMF4532F-601-2P-Tms
10000
Z (common mode)
Impedance( ohm)
1000
100
10
1
1
10
100
Frequency(MHz)
1000
10000
T-0602-141E
4/9
SPEC. NO.
4-3 Test Equipment
4-3-1 Impedance
Measured by using Agilent E4991A RF Impedance Analyzer.
Measurement terminal
①
④
②
③
4-3-2 DC Resistance
Measured by using Chroma 16502 mill ohm meter.
①
④
②
③
4-3-3 Insulation Resistance
Measured by using Chroma 19073
Measurement voltage : 50v, Measurement time: 60 sec.
①
④
②
③
T-0602-141E
5/9
SPEC. NO.
T-0602-141E
5.Reliability Test
Operating temperature : -40 to +125℃
Item
Solderability
Specifications
Storage temp and humidity :-40 to 85℃, 70%RH max.
Test conditions
It can be connected on the
Apply cream solder to the test circuit board .
Recommendation soldering
It is mounted on the recommendation soldering condition.
condition.
Terminal
strength
The terminal electrode and the
Solder a chip to test substrate, and then laterally apply a
ferrite must not be dam 160±25% load 1.8Kg in the arrow direction.
Strength on The terminal electrode and the
ferrite must not be damaged.
pc board
bending
Soldering a chip to a test substrate ,
bend the substrate by 2mm and then return.
Test board : Glass base epoxy multiplayer board pc board pattern.
PC board pattern : Recommended PC board pattern.
6/9
Item
Specifications
High
Appearance : Ferrite shall not be
temperature damaged.
resistance Impedance: Within ±20% of the
SPEC. NO.
T-0602-141E
Test conditions
Temperature : +125±2℃
Applied voltage : Rated voltage
Applied current : Rated current
initial value.
Testing time : 500±12 hours
insulation resistance: >10(MΩ)
Measurement : After placing for 24 hours min.
DC resistance : standard value
Humidity
resistance
inside.
Temperature : +85±2℃
Humidity : 90 to 95%RH
Thermal
cycle
Temperature : -40℃,+125℃
kept stabilized for 30 minutes each.
Cycle : 100 cycle
+125℃
Low
temperature
resistance
Vibration
Temperature : -40±2℃
damaged.
Frequency : 10 to 50 Hz
Amplitude : 1.52 mm
Dimension and times : X ,Y and Z directions
for 2 hours each.
7/9
SPEC. NO.
T-0602-141E
6.Packaging
The packaging must be done not to receive any damage during
transporting and storing
6-1 Tape dimensions
3.0±0.2
6-2 Reel dimensions
( Dimensions in mm )
Symbol
T
φA
φB
180+0,-3
φC
13±0.2
D
2.2±0.5
W
12.0±0.3
t
1.2
R
1
60+1, -0
6-3 Tapping figure
Top cover tape
Carrier tape
Sprocket hole
Cavity (chip insert)
8/9
SPEC. NO.
T-0602-141E
6-4 Packaging Form
There shall not continuation more than two vacancies of the product.
Material of carrier tape : Polystyrene
Material of cover tape : Polyester
6-5 Cover Tape Peel Strength
The force for tearing off cover tape is 0.05~0.69(N) in the arrow direction at
the following conditions:
Temperature : 5 ~ 35℃
Humidity : 45 ~ 85%
Atmospheric pressure : 860 ~ 1060 hpa
160 ~ 180。
Top cover tape
Base tape
6-6 Packing Quantity
φ180 mm reel T type : 500 pcs./reel
9/9
SPEC. NO.
T-0602-141E
7. Recommended Soldering Conditions (Please use this product by reflow soldering)
7-1 Recommended Footprint
7-2 Recommended Reflow Pattern
Reflow: until two times
7-3 Iron Soldering
Use a solder iron of less than 30W when soldering, do not allow the soldering iron tip directly tough
the ferrite body outside fo terminal electrode.
2 seconds max. at 280℃.
8. Attention in Case of Using
In case of using product, please avoid following matters:
Splashing water or salt water
Dew condenses
Toxic gas (Hydrogen sulfide, Sulfurous acid, Chlorine, Ammonia)
Vibrations or shocks which exceed the specified condition
Please be careful for the stress to this product by board flexure or something after the mounting.
*Recommended wire wound inductors should be used within 6 months from the time of delivery.
CMF4532F-900-2P-Tms 价格&库存
很抱歉,暂时无法提供与“CMF4532F-900-2P-Tms”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.50900
- 30+3.38800
- 100+3.14600
- 500+2.90400
- 1000+2.78300
