TVS DIODE
ESDLLC5V0D8BH
Trustworthy electronic circuit protection expert
ESDLLC5V0D8BH
Features
package. The small size, ultra-low capacitance and high ESD
●Ultra small package: 1.0x0.6x0.5mm
surge protection make ESDLLC5V0D8BH an ideal choice to
●Ultra low capacitance: 0.25pF typical
protect cell phone, digital video interfaces and other high speed
●Ultra low leakage: nA level
ports.
●Low operating voltage: 5V
Applications
●Low clamping voltage
●Smart phones
●2-pin leadless package
●Display Ports
●Complies with following standards:
●MDDI Ports
– IEC 61000-4-2 (ESD) immunity test
●USB Ports
Air discharge: ±20kV
●Digital Video Interface (DVI)
Contact discharge: ±15kV
●PCI Express and Serial SATA Ports
Circuit Diagram
– IEC61000-4-5 (Lightning) 4.5A (8/20μs)
●RoHS Compliant
●Lead Finish: NiPdAu
Description
The ESDLLC5V0D8BH is a bi-directional TVS diode, utilizing
leading monolithic silicon technology to provide fast response
time and low ESD clamping voltage, making this device an
ideal solution for protecting voltage sensitive high-speed data
lines. The ESDLLC5V0D8BH has an ultra-low capacitance with
a typical value at 0.25pF, and complies with the IEC 61000-4-2
(ESD) standard with ±15kV air and ±8kV contact discharge. It is
assembled into an ultra-small 1.0x0.6x0.5mm lead-free DFN
Absolute Maximum Ratings
Tamb=25°C unless otherwise specified
Parameter
Peak Pulse Power (8/20µs)
Maximum Reverse Peak Pulse Current
Symbol
Value
Unit
Ppp
110
W
*1
4.5
A
IPP
ESD per IEC 61000−4−2 (Air)
±20
VESD
ESD per IEC 61000−4−2 (Contact)
Storage Temperature Range
Operating Temperature Range
KV
±15
TSTJ
-55 to +150
TJ
-55 to +125
Electrical Characteristics
TA=25°C unless otherwise specified
Symbol
Parameter
Conditions
VRWM
Reverse Working Peak Voltage
VBR
Reverse Breakdown Voltage
IT = 1mA
IR
Reverse Current
VC
Max
Units
5.0
V
8.5
V
VRWM = 5V
0.5
μA
Clamping Voltage
IPP=1A, tP =8/20μs
12
V
VC
Clamping Voltage
IPP=4.5A, tP =8/20μs
18
V
CD
Diode Capacitance
VR = 0V, f = 1MHz
0.22
0.30
pF
www.yint.com.cn
1
Min
6.0
Typ
7.5
Rev:19.3
TVS DIODE
ESDLLC5V0D8BH
Characteristic Curves
Junction Capacitance vs. Reverse Voltage
Clamping Voltage vs. Peak Pulse Current
Peak Pulse Power vs. Pulse Time
IEC61000−4−2 Pulse Waveform
Power Derating Curve
8/20μ s Pulse Waveform
www.yint.com.cn
2
Rev:19.3
TVS DIODE
ESDLLC5V0D8BH
DFN1006-2 Package Outline & Dimensions
DIMENSIONS
SYM
MILLIMETERS
INCHES
MIN
NOM
MAX
MIN
NOM
MAX
A
0.45
0.50
0.55
0.018
0.020
0.022
A1
0.00
0.02
0.05
0.000
0.001
0.002
b
0.45
0.50
0.55
0.018
0.020
0.022
c
0.12
0.15
0.18
0.005
0.006
0.007
D
0.95
1.00
1.05
0.037
0.039
0.041
e
0.65 BSC
0.026 BSC
E
0.55
0.60
0.65
0.022
0.024
0.026
L
0.20
0.25
0.30
0.008
0.010
0.012
L1
h
0.05REF
0.07
0.12
0.002REF
0.17
0.003
0.005
0.007
Suggested Land Pattern
SYM
www.yint.com.cn
3
DIMENSIONS
MILLIMETERS
INCHES
X
0.60
0.024
Y1
0.50
0.020
Y2
0.30
0.012
Y3
0.80
0.032
Z
1.30
0.052
Rev:19.3
很抱歉,暂时无法提供与“ESDLLC5V0D8BH”相匹配的价格&库存,您可以联系我们找货
