PESDLC2FD3V3BH
PESDLC2FD3V3BH
    PRISEMI(上海芯导电子)
PESDLC2FD3V3BH 数据手册
PESDLC2FD3V3BH Bi-directional 3.3V Low Capacitance ESD Protector Description The PESDLC2FD3V3BH protects sensitive semiconductor components from damage or upset due to electrostatic discharge (ESD) and other voltage induced transient events. They feature large cross-sectional area junctions for conducting high transient currents, offer desirable electrical characteristics for board level protection, such as fast response time, low operating voltage. It gives DFN1006-2L(Bottom View) designer the flexibility to protect one bi-directional line in applications where arrays are not practical. Pin1 Feature  120W peak pulse power per line (tP = 8/20μs) Pin2 Circuit Diagram  DFN1006-2L package  Response time is typically < 1 ns  Bidirectional configurations  Low clamping voltage  RoHS compliant  Transient protection for data lines to 3BH IEC 61000-4-2(ESD) ±30kV(air), ± 30kV(contact); IEC 61000-4-5 (Lightning) 8A (8/20us) Marking (Top View) Applications Mechanical Characteristics  Cell phone handsets and accessories  Mounting position: Any  Personal digital assistants (PDA’s)  Qualified max reflow temperature:260℃  Notebooks, desktops, and servers  Device meets MSL 1 requirements  Portable instrumentation  DFN1006-2L without plating  Cordless phones  Digital cameras  Peripherals Rev.06.1 1 www.prisemi.com ESD Protector PESDLC2FD3V3BH Electronics Parameter Symbol Parameter VRWM Peak Reverse Working Voltage IR Reverse Leakage Current @ VRWM VBR Breakdown Voltage @ IT IT Test Current IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ IPP PPP Peak Pulse Power CJ Junction Capacitance IF Forward Current VF Forward Voltage @ IF I IPP VC IT IR VBRVRWM V IR IT VRWMVBR VC IPP Electrical characteristics per line@25℃ (unless otherwise specified) Parameter Symbol Conditions Min. Typ. Max. Units Peak Reverse Working Voltage VRWM - - - 3.3 V VBR It = 1mA 4.5 - - V Reverse Leakage Current IR VRWM = 3.3V - - 1 μA Clamping Voltage1) VC TLP = 16A, tp = 100ns - 17 - V RDYN - - 0.5 - Ω IPP = 3A,tP = 8/20μs - 10.5 13 V IPP = 8A,tP = 8/20μs - 17 20 V VR = 0V,f = 1MHz - 0.5 0.8 pF Breakdown Voltage Dynamic resistance1) Clamping Voltage2) VC Junction Capacitance CJ Notes: 1.TLP parameter: Z0=50Ω, tp=100ns, tr=2ns, averaging window from 60ns to 80ns. RDYN is calculated from 4A to 16A. 2.Non-repetitive current pulse, according to IEC61000-4-5. Absolute maximum rating@25℃ Rating Symbol Value Units Peak Pulse Power ( tP = 8/20μs ) PPP 120 W Peak Pulse Current ( tP = 8/20μs ) IPP 8 A Lead Soldering Temperature TL 260 (10 sec) ℃ TJ,TSTG -55~+150 ℃ ESD Protection-Contact Discharge VESD ±30 kV ESD Protection-Air Discharge VESD ±30 kV Junction and Storage Temperature Range Rev.06.1 2 www.prisemi.com ESD Protector PESDLC2FD3V3BH Typical Characteristics tr=8μs IPP – Peak Pulse Current - % of IPP 100 100 % Of Rated Power 80 60 tP =20μs(IPP /2) 40 60 40 20 20 0 80 0 5 10 15 20 25 0 30 0 25 50 75 100 125 t - Time -μs TL – Lead Temperature - ℃ Fig 1.Pulse Waveform(8/20μs) Fig 2.Power Derating Curve 25 1.0 150 f = 1MHz Pulse waveform: tp=8/20us 0.9 C - Junction Capacitance - pF VC - Clamping Voltage - V 20 15 10 5 0.8 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0 0 1 2 3 4 5 6 7 0.0 -3.5 -3.0 -2.5 -2.0 -1.5 -1.0 -0.5 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 8 IPP - Peak pulse current - A VR - Reverse voltage - V Fig 4. Capacitance vs. Reveres voltage Fig 3. Clamping voltage vs. Peak pulse current 20 10000 V_pulse 15 Pulse from a Transmission line TLP_I 100ns TLP Current - A Peak Pulse Power - W TLP_V 10 1000 100 + DUT Pin 1 to Pin 2 T = 25 ℃ 5 0 -5 -10 10 -15 1 1 10 100 1000 -15 -10 -5 0 5 10 15 20 TLP Voltage - V Pulse Duration - μs Fig 5. Non Repetitive Peak Pulse Power vs. Pulse time Rev.06.1 -20 -20 3 Fig 6. TLP Measurement www.prisemi.com ESD Protector PESDLC2FD3V3BH Fig 8. Clamping Voltage at IEC61000-4-2 -8kV Pulse Waveform Fig 7. Clamping Voltage at IEC61000-4-2 +8kV Pulse Waveform Solder Reflow Recommendation 300 Preliminary Heating Soldering Cooling(in air) Temperature of Soldering 260℃ (+0,-5℃) 250 245℃ (+0,-5℃) 200 150 120℃ 100 100℃ 50 0 2 to 5 min more than 1 min Less than 10s Remark: Pb free for 260℃;Pb for 245℃. Rev.06.1 4 www.prisemi.com ESD Protector PESDLC2FD3V3BH PCB Design For TVS diodes a low-ohmic and low-inductive path to chassis earth is absolutely mandatory in order to achieve good ESD protection. Novices in the area of ESD protection should take following suggestions to heart:  Do not use stubs, but place the cathode of the TVS diode directly on the signal trace.  Do not make false economies and save copper for the ground connection.  Place via holes to ground as close as possible to the anode of the TVS diode.  Use as many via holes as possible for the ground connection.  Keep the length of via holes in mind! The longer the more inductance they will have. Ordering information Device Package Reel Shipping PESDLC2FD3V3BH DFN1006-2L (Pb-Free) 7" 10000 / Tape & Reel Load with information USER DIRECTION OF FEED 4.0±0.1 Ø1.50±0.1 8.0±0.1 Ø0.5+±0.05 2.0±0.05 3.5±0.05 1.75±0.1 2.0±0.05 Unit:mm Rev.06.1 5 www.prisemi.com ESD Protector PESDLC2FD3V3BH Product dimension (DFN1006-2L) C D E F Top View H Bottom View A B Dim Millimeters Side View Inches Min Max Min Max A 0.340 0.498 0.013 0.020 B 0.000 0.050 0.000 0.002 C 0.950 1.080 0.037 0.043 D 0.550 0.680 0.022 0.027 E 0.400 0.600 0.016 0.024 F 0.200 0.300 0.008 0.012 H 0.400 Typ. 0.015 Typ. 1.20 0.50 0.60 0.70 Unit:mm Suggested PCB Layout Rev.06.1 6 www.prisemi.com ESD Protector PESDLC2FD3V3BH IMPORTANT NOTICE and are registered trademarks of Prisemi Electronics Co., Ltd (Prisemi), Prisemi reserves the right to make changes without further notice to any products herein. Prisemi makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does Prisemi assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation special, consequential or incidental damages. “Typical” parameters which may be provided in Prisemi data sheets and/or specifications can and do vary in different applications and actual performance may vary over time. All operating parameters, including “Typicals” must be validated for each customer application by customer’s technical experts. Prisemi does not convey any license under its patent rights nor the rights of others. The products listed in this document are designed to be used with ordinary electronic equipment or devices, Should you intend to use these products with equipment or devices which require an extremely high level of reliability and the malfunction of with would directly endanger human life (such as medical instruments, aerospace machinery, nuclear-reactor controllers, fuel controllers and other safety devices), please be sure to consult with our sales representative in advance. Website: http://www.prisemi.com For additional information, please contact your local Sales Representative. ©Copyright 2009, Prisemi Electronics is a registered trademark of Prisemi Electronics. All rights are reserved. Rev.06.1 7 www.prisemi.com
PESDLC2FD3V3BH 价格&库存
很抱歉,暂时无法提供与“PESDLC2FD3V3BH”相匹配的价格&库存,您可以联系我们找货
