Push-in Y-connector
QSY-10-6
Part number: 130611
Data sheet
Feature
Value
Size
Standard
Nominal width
3.3 mm
Mounting position
Any
Pack size
10
Structural design
Push-pull principle
Operating pressure for entire temperature range
-0.95 bar ... 6 bar
Temperature-dependent operating pressure
-0.95 bar ... 14 bar
Maritime classification
See certificate
Operating medium
Compressed air as per ISO 8573-1:2010 [7:-:-]
Water as per manufacturer's declaration at www.festo.com
Information on operating and pilot media
Operation with oil lubrication possible
Corrosion resistance class (CRC)
1 - Low corrosion stress
Ambient temperature
-10 °C ... 80 °C
Product weight
19 g
No. of outlets
2
No. of supply lines
1
Pneumatic connection 1
for pneumatic tubing outside diameter 10 mm
Pneumatic connection 2
for pneumatic tubing outside diameter 6 mm
Releasing ring color
Blue
Note on materials
RoHS-compliant
Housing material
PBT
Releasing ring material
POM
Material of tubing seal
NBR
Material of tube retaining claw
High-alloy stainless steel
8/5/22 - Subject to change - Festo SE & Co. KG
1/1
很抱歉,暂时无法提供与“QSY-10-6”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+794.99271
- 5+779.09077
- 10+755.75335
