TYC-324
TYC-324
    XUNPU(讯普)
    SMD,9.85x9.64mm
    TYC-324
TYC-324 数据手册
APPROVAL SPECIFICATIONS Title. TYPE-C USB CONNECTOR Product Model. TYC-324 Customer’s Part NO. Customer’s Model: Customer’s Approval Requested. Please return this copy as a certification of your approval. Checked by: Date: Approved by: Date: APPROVE REVIEW POLT  王凯      林永坚      陈旺 XUNPU ELE CTR ONI CS CO.,LTD 东莞市讯普电子科技有限公司 TYC-324 東莞市訊普電子科技有限公司 DONGGUAN XUNPU ELECTRONICS CO.,LTD 1 TYPE-C系列产品SPEC USB 33.1 TYPE C系列产品SPEC 版本版次: B 1. Scope(范围) 制定日期 20160620 制定人:唐竹君 适用范围 通用 1.1 Contents(内容) This specification covers the performance, tests and quality requirements for the Electronics USB 3.1 TYPE‐C (此份产品规格适用于USB 3 1 TYPE‐C连接器的产品功能,测试方法及质量要求) (此份产品规格适用于USB 3.1 TYPE‐C连接器的产品功能,测试方法及质量要求) 2. Requirements (要求): 2.1 Rating(额定条件) A. Voltage rating(额定电压):30V AC B. Current rating(额定电流):5A C C. Operation Temperature Range(工作温度范围):‐30℃ Operation Temperature Range(工作温度范围): 30℃ to +80℃ to +80℃ 3. Test Condition(测试条件): 3.1 Temperature range(温度范围):‐15℃ to +35℃ 3.2 Humidity range (湿度范围):25% to 85% 4.      Test Methods and Requirements:(测试方法及要求) 4.1 Examination of product (产品外观) 4.1 Examination of product (产品外观) 4.1.1 Examination  of Product 产品外观 Visual 目视 No peeling off the plating deformation of the base or damage. 不得有电镀层剥落,塑料变形或 破损 4.2. Electrical Performance(电气性能) 4.2.1 Contact Resistance 接触阻抗 40mΩ MAX (EIA‐364‐06B) 适合USB 3.1 TYPE‐C嵌合;开放电压20mv以 下;短路电流100ma的状态下测定。 Mate applicable USB 3.1 TYPE‐C and measure by dry circuit, 20mv MAX, 100mA. 40mΩMAX 第 1 页,共 6 页 Dielectric Withstanding 4.2.2 Voltage (耐电压) 1. No Breakdown or flashover (EIA‐364‐20C) Unmated connectors, apply 100V AC (RMS.) for 2. Leakage current:0.5mA Max 1 minute between adjacent terminals of ground. 1. 不能有损坏或跳火花 2 漏电流
TYC-324 价格&库存
很抱歉,暂时无法提供与“TYC-324”相匹配的价格&库存,您可以联系我们找货
