AS2305
P-Channel MOSFET
SOT-23 Plastic-Encapsulate MOSFETS
SOT-23
FEATURE
TrenchFET Power MOSFET
1. GATE
APPLICATIONS
z
Load Switch for Portable Devices
z
DC/DC Converter
2. SOURCE
3. DRAIN
MARKING: A5
■ Maximum ratings (Ta=25℃ unless otherwise noted)
Characteristic
特性參數
Symbol
符號
Max
最大值
Unit
單位
Drain-Source Voltage
漏極-源極電壓
BVDSS
-20
V
Gate- Source Voltage
栅極-源極電壓
VGS
+10
V
Drain Current (continuous)
漏極電流-連續
ID
-3.9
A
Drain Current (pulsed)
漏極電流-脉冲
IDM
-15
A
Total Device Dissipation
總耗散功率
TA=25℃環境溫度爲 25℃
PD
1200
mW
Junction 結溫
TJ
150
Storage Temperature 儲存溫度
Tstg
-55to+150
http://www.anbonsemi.com
TEL:886-755-23776891
FAX: 886-755-81482182
Page 1
Document ID
Issued Date
Revised Date
Revision
Page.
AS-3150035
2003/03/08
2012/05/16
D
3
AS2305
P-Channel MOSFET
Characteristic
特性參數
Symbol
符號
Min
最小值
Typ
典型值
Max
最大值
Unit
單位
Drain-Source Breakdown Voltage
漏極-源極擊穿電壓(ID = -250uA,VGS=0V)
BVDSS
-20
V
Gate Threshold Voltage
栅極開启電壓(ID = -250uA,VGS= VDS)
VGS(th)
-0.5
-1.5
V
Diode Forward Voltage Drop
内附二極管正向壓降(IS= -0.75A,VGS=0V)
VSD
-1.5
V
Zero Gate Voltage Drain Current
零栅壓漏極電流(VGS=0V, VDS= -16V)
(VGS=0V, VDS= -16V, TA=55℃)
IDSS
-1
-10
uA
Gate Body Leakage
栅極漏電流(VGS=+8V, VDS=0V)
IGSS
+100
nA
Static Drain-Source On-State Resistance
静态漏源導通電阻(ID= -3.9A,VGS= -4.5V)
RDS(ON)
55
65
mΩ
静态漏源導通電阻(ID= -2A,VGS= -2.5V)
RDS(ON)
70
80
mΩ
Input Capacitance 輸入電容
(VGS=0V, VDS= -10V,f=1MHz)
CISS
600
pF
Output Capacitance 輸出電容
COSS
120
pF
Turn-ON Time 开启時間
(VDS= -10V, ID= -2.8A, RGEN=6Ω)
t(on)
8
ns
Turn-OFF Time 关断時間
t(off)
60
ns
Pulse Width
很抱歉,暂时无法提供与“AS2305”相匹配的价格&库存,您可以联系我们找货
